path: root/include/sound/jack.h
2010-09-07ALSA: Add more jack button slotsMark Brown
Some devices have more flexible microphone detection and can detect a wider range of buttons. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-17ALSA: Add support for key reporting via the jack interfaceMark Brown
Some devices provide support for detection of a small number of buttons on their jacks. One common implementation provides a single button, implemented by shorting the microphone to ground and detected along with microphone presence detection by detecting varying current draws on the microphone bias signal. Provide support for up to three buttons via the jack interface. These default to reporting BTN_n but an API is provided to allow these to be remapped to other keys by the machine driver where it knows what the keys are. More keys can be added with ease if required. This is only intended to support simple accessory button designs. If the interface is limiting then either creating a child device for the accessory or accessing the input device in the jack directly is recommended. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-14ALSA: add private_data to struct snd_jackTakashi Iwai
Added private_data and private_free fields to struct snd_jack so that the caller can assign the data. It'll be helpful for avoiding the double-free of the jack instance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-07ALSA: Add support for video out to the jack reporting APIJani Nikula
Add support for reporting new jack types SND_JACK_VIDEOOUT and SND_JACK_AVOUT (a combination of LINEOUT and VIDEOOUT) to the jack reporting API. Also add the corresponding SW_VIDEOOUT_INSERT switch to the input system header. Signed-off-by: Jani Nikula <ext-jani.1.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-03ALSA: Reduce boilerplate for new jack typesMark Brown
Use a lookup table rather than explicit code to map input subsystem jack types into ASoC ones, implemented as suggested by Takashi Iwai. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-10ALSA: Add support for mechanical jack insertionMark Brown
Some systems support both mechanical and electrical jack detection, allowing them to report that a jack is physically present but does not have any functioning connections. Add a new jack type for these, allowing user space to report faulty connections. Thanks to Guillem Jover for the suggestion. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-27ALSA: jack: lineout support to jack abstraction layerMatthew Ranostay
This patch introduces support for reporting SW_LINEOUT_INSERT detection events via the jack abstraction layer. Also adds a SND_JACK_LINEOUT define to the input system header. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Cc: Dmitry Torokhov <dtor@mail.ru> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-29ALSA: Add jack reporting APIMark Brown
Currently very few systems provide information about jack status to user space, even though many have hardware facilities to do detection. Those systems that do use an input device with the existing SW_HEADPHONE_INSERT switch type to do so, often independently of ALSA. This patch introduces a standard method for representing jacks to user space into ALSA. It allows drivers to register jacks for a sound card with the input subsystem, binding the input device to the card to help user space associate the input devices with their sound cards. The created input devices are named in the form "card longname jack" where jack is provided by the driver when allocating a jack. By default the parent for the input device is the sound card but this can be overridden by the card driver. The existing user space API with SW_HEADPHONE_INSERT is preserved. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
