path: root/include/sound/mpu401.h
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] mpu-401: remove MPU401_INFO_UART_ONLY flagClemens Ladisch
Since the last patch made the ENTER_UART command optional, the enter_uart option and its corresponding flag have become superfluous. The uart_enter option remains for backward compatibility but just prints a warning when used. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] mpu401 - Add MPU401_INFO_UART_ONLY bitflagTakashi Iwai
Added MPU401_INFO_UART_ONLY bitflag to avoid issueing UART_ENTER command at opening streams. Some devices support only UART mode and give errors to UART_ENTER. A new module option, uart_enter, is added to snd-mpu401 driver. For UART-only devices, set uart_enter=0. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-06-22[ALSA] Change an arugment of snd_mpu401_uart_new() to bit flagsTakashi Iwai
Change the 5th argument of snd_mpu401_uart_new() to bit flags instead of a boolean. The argument takes bits that consist of MPU401_INFO_XXX flags. The callers that used the value 1 there are replaced with MPU401_INFO_INTEGRATED. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: MPU401Takashi Iwai
Modules: MPU401 UART Remove xxx_t typedefs from the MPU401-UART and MPU401 drivers Signed-off-by: Takashi Iwai <tiwai@suse.de>
