path: root/include/sound/pcm.h
2012-10-23ALSA: core: add hooks for audio timestampsPierre-Louis Bossart
ALSA did not provide any direct means to infer the audio time for A/V sync and system/audio time correlations (eg. PulseAudio). Applications had to track the number of samples read/written and add/subtract the number of samples queued in the ring buffer. This accounting led to small errors, typically several samples, due to the two-step process. Computing the audio time in the kernel is more direct, as all the information is available in the same routines. Also add new .audio_wallclock routine to enable fine-grain synchronization between monotonic system time and audio hardware time. Using the wallclock, if supported in hardware, allows for a much better sub-microsecond precision and a common drift tracking for all devices sharing the same wall clock (master clock). Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-23ALSA: core: keep track of boundary wrap-aroundPierre-Louis Bossart
Keep track of boundary crossing when hw_ptr exceeds boundary limit and wraps-around. This will help keep track of total number of frames played/received at the kernel level Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-09Merge tag 'sound-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This contains pretty many small commits covering fairly large range of files in sound/ directory. Partly because of additional API support and partly because of constantly developed ASoC and ARM stuff. Some highlights: - Introduced the helper function and documentation for exposing the channel map via control API, as discussed in Plumbers; most of PCI drivers are covered, will follow more drivers later - Most of drivers have been replaced with the new PM callbacks (if the bus is supported) - HD-audio controller got the support of runtime PM and the support of D3 clock-stop. Also changing the power_save option in sysfs kicks off immediately to enable / disable the power-save mode. - Another significant code change in HD-audio is the rewrite of firmware loading code. Other than that, most of changes in HD-audio are continued cleanups and standardization for the generic auto parser and bug fixes (HBR, device-specific fixups), in addition to the support of channel-map API. - Addition of ASoC bindings for the compressed API, used by the mid-x86 drivers. - Lots of cleanups and API refreshes for ASoC codec drivers and DaVinci. - Conversion of OMAP to dmaengine. - New machine driver for Wolfson Microelectronics Bells. - New CODEC driver for Wolfson Microelectronics WM0010. - Enhancements to the ux500 and wm2000 drivers - A new driver for DA9055 and the support for regulator bypass mode." Fix up various arm soc header file reorg conflicts. * tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits) ALSA: hda - Add new codec ALC283 ALC290 support ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls ALSA: hda - fix indices on boost volume on Conexant ALSA: aloop - add locking to timer access ALSA: hda - Fix hang caused by race during suspend. sound: Remove unnecessary semicolon ALSA: hda/realtek - Fix detection of ALC271X codec ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310 ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event ALSA: hda - make a generic unsol event handler ASoC: codecs: Add DA9055 codec driver ASoC: eukrea-tlv320: Convert it to platform driver ALSA: ASoC: add DT bindings for CS4271 ASoC: wm_hubs: Ensure volume updates are handled during class W startup ASoC: wm5110: Adding missing volume update bits ASoC: wm5110: Add OUT3R support ASoC: wm5110: Add AEC loopback support ASoC: wm5110: Rename EPOUT to HPOUT3 ASoC: arizona: Add more clock rates ASoC: arizona: Add more DSP options for mixer input muxes ...
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel ↵David Howells
system headers Convert #include "..." to #include <path/...> in kernel system headers. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-09-23ALSA: Make snd_sgbuf_get_{ptr|addr}() available for non-SG casesTakashi Iwai
Passing struct snd_dma_buffer pointer instead, so that they work no matter whether real SG buffer is used or not. This is a preliminary work for the HD-audio DSP loader code. Signed-off-by: Ian Minett <ian_minett@creativelabs.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-06ALSA: PCM: channel mapping API implementationTakashi Iwai
This patch implements the basic data types for the standard channel mapping API handling. - The definitions of the channel positions and the new TLV types are added in sound/asound.h and sound/tlv.h, so that they can be referred from user-space. - Introduced a new helper function snd_pcm_add_chmap_ctls() to create control elements representing the channel maps for each PCM (sub)stream. - Some standard pre-defined channel maps are provided for convenience. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: fix pcm.h kernel-doc warning and notationRandy Dunlap
Fix kernel-doc warning in <sound/pcm.h> and add function name to make the kernel-doc notation complete. Warning(include/sound/pcm.h:1081): No description found for parameter 'substream' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-19Merge tag 'asoc-3.6' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Updates for 3.6 This has been a pretty quiet release - very little activity in framework terms, mostly just a few new drivers and updates: - Added the ability to add and remove DAPM paths dynamically, mostly for reparenting on clock changes. - New machine drivers for Marvell Brownstone, ST-Ericsson Ux500 reference platform and ttc-dkp. - New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP, Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF - New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500, TI Isabelle and Wolfson Microelectronics WM5102 and WM5110
2012-07-05ALSA: pcm: Make constraints lists constMark Brown
They aren't modified by the core so the drivers can declare them const. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18ALSA: pcm: Add snd_pcm_rate_bit_to_rate()Dimitris Papastamos
This is essentially the reverse of snd_pcm_rate_to_rate_bit(). This is generally useful as the Compress API uses the rate bit directly and it helps to be able to map back to the actual sample rate. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-03ALSA: pcm: Add debug-print helper functionOla Lilja
Adds a function getting the stream-name as a string for a specific stream. Signed-off-by: Ola Lilja <ola.o.lilja@stericsson.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-18Merge branch 'topic/asoc' into for-linusTakashi Iwai
2012-03-15ALSA: pcm: Constify the list in snd_pcm_hw_constraint_listMark Brown
Allows the constraint lists to be declared const by drivers which seems reasonable; there's plenty of other constification we could do if we were being complete but this was easy and quick. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-09ALSA: PCM - Add PCM creation API for internal PCMs.Liam Girdwood
The new ASoC dynamic PCM core needs to create PCMs and substreams that are for use by internal ASoC drivers only and not visible to userspace for direct IO. These new PCMs are similar to regular PCMs expect they have no device nodes or procfs entries. The ASoC component drivers use them in exactly the same way as regular PCMs for PCM and DAI operations. The intention is that a dynamic PCM based driver will register both regular PCMs and internal PCMs. The regular PCMs will be used for all IO with userspace however the internal PCMs will be used by the driver to route digital audio through numerous back end DAI links (with potentially a DSP providing different hw_params, DAI formats based on the regular front end PCM params) to devices like CODECs, MODEMs, Bluetooth, FM, DMICs, etc This patch adds a new snd_pcm_new_internal() API call to create the internal PCM without device nodes or procfs. It also adds adds a new internal flag to snd_pcm. [fixed minor coding-style issues by tiwai] Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits) ALSA: hda - Fix ADC input-amp handling for Cx20549 codec ALSA: hda - Keep EAPD turned on for old Conexant chips ALSA: hda/realtek - Fix missing volume controls with ALC260 ASoC: wm8940: Properly set codec->dapm.bias_level ALSA: hda - Fix pin-config for ASUS W90V ALSA: hda - Fix surround/CLFE headphone and speaker pins order ALSA: hda - Fix typo ALSA: Update the sound git tree URL ALSA: HDA: Add new revision for ALC662 ASoC: max98095: Convert codec->hw_write to snd_soc_write ASoC: keep pointer to resource so it can be freed ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2 ASoC: da7210: Add support for line out and DAC ASoC: da7210: Add support for DAPM ALSA: hda/realtek - Fix DAC assignments of multiple speakers ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value ASoC: Set sgtl5000->ldo in ldo_regulator_register ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture ...
2011-10-26Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-09-28ALSA: pcm - Export snd_pcm_lib_default_mmap() helperTakashi Iwai
Export the default mmap function, snd_pcm_lib_default_mmap(). The upcoming non-snooping support in HD-audio driver will use this to override the mmap method. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-20ALSA: pcm: add snd_pcm_hw_rule_noresample()Clemens Ladisch
Add a helper function to allow drivers to disable hardware resampling when the application has specified the SNDRV_PCM_HW_PARAMS_NORESAMPLE flag. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-25PM QoS: Minor clean-upsJean Pihet
- Misc fixes to improve code readability: * rename struct pm_qos_request_list to struct pm_qos_request, * rename pm_qos_req parameter to req in internal code, consistenly use req in the API parameters, * update the in-kernel API callers to the new parameters names, * rename of fields names (requests, list, node, constraints) Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: markgross <markgross@thegnar.org> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-08-25PM QoS: Move and rename the implementation filesJean Pihet
The PM QoS implementation files are better named kernel/power/qos.c and include/linux/pm_qos.h. The PM QoS support is compiled under the CONFIG_PM option. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: markgross <markgross@thegnar.org> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-26ALSA: Make pcm.h self-containedTakashi Iwai
Move the macros depending on snd_mask_min() and co out of pcm.h into pcm_params.h. Otherwise using some params_*() macros will give comiple errors without inclusion of pcm_params.h. Also use hw_param_interval_c() and hw_param_mask_c() for const pointer. Reported-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-24ALSA: Make snd_pcm_debug_name usable outside pcm_libEliot Blennerhassett
Formatting a PCM name is useful for module debug too. Add snd_prefix when making function public. [minor coding-style fixes by tiwai] Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-25ALSA: vmalloc buffers should use normal mmapBenjamin Herrenschmidt
It's a big no-no to use pgprot_noncached() when mmap'ing such buffers into userspace since they are mapped cachable in kernel space. This can cause all sort of interesting things ranging from to garbled sound to lockups on various architectures. I've observed that usb-audio is broken on powerpc 4xx for example because of that. Also remove the now unused snd_pcm_lib_mmap_noncached(). It's an arch business to know when to use uncached mappings, there's already hacks for MIPS inside snd_pcm_default_mmap() and other archs are supposed to use dma_mmap_coherent(). (See my separate patch that adds dma_mmap_coherent() to powerpc) Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-14ALSA: core: sparse cleanupsClemens Ladisch
Change the core code where sparse complains. In most cases, this means just adding annotations to confirm that we indeed want to do the dirty things we're doing. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: pcm: support for period wakeup disablingClemens Ladisch
This patch allows to disable period interrupts which are not needed when the application relies on a system timer to wake-up and refill the ring buffer. The behavior of the driver is left unchanged, and interrupts are only disabled if the application requests this configuration. The behavior in case of underruns is slightly different, instead of being detected during the period interrupts the underruns are detected when the application calls snd_pcm_update_avail, which in turns forces a refresh of the hw pointer and shows the buffer is empty. More specifically this patch makes a lot of sense when PulseAudio relies on timer-based scheduling to access audio devices such as HDAudio or Intel SST. Disabling interrupts removes two unwanted wake-ups due to period elapsed events in low-power playback modes. It also simplifies PulseAudio voice modules used for speech calls. To quote Lennart "This patch looks very interesting and desirable. This is something have long been waiting for." Support for this in hardware drivers is optional. Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@intel.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-18ALSA: pcm midlevel code - add time check for double interrupt acknowledgeJaroslav Kysela
The current code in pcm_lib.c do all checks using only the position in the ring buffer. Unfortunately, where the interrupts gets delayed or merged into one, we need another timing source to check when the buffer size boundary overlaps to avoid the wrong updating of the ring buffer pointers. This code uses jiffies to check the right time window without any performance impact. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-07-19pm_qos: Get rid of the allocation in pm_qos_add_request()James Bottomley
All current users of pm_qos_add_request() have the ability to supply the memory required by the pm_qos routines, so make them do this and eliminate the kmalloc() with pm_qos_add_request(). This has the double benefit of making the call never fail and allowing it to be called from atomic context. Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: mark gross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-07-05Merge branch 'devel' of git://git.alsa-project.org/alsa-kernel into topic/miscTakashi Iwai
2010-06-28ALSA: pcm_lib: avoid timing jitter in snd_pcm_read/write()David Dillow
When using poll() to wait for the next period -- or avail_min samples -- one gets a consistent delay for each system call that is usually just a little short of the selected period time. However, When using snd_pcm_read/write(), one gets a jittery delay that alternates between less than a millisecond and approximately two period times. This is caused by snd_pcm_lib_{read,write}1() transferring any available samples to the user's buffer and adjusting the application pointer prior to sleeping to the end of the current period. When the next period interrupt occurs, there is then less than avail_min samples remaining to be transferred in the period, so we end up sleeping until a second period occurs. This is solved by using runtime->twake as the number of samples needed for a wakeup in addition to selecting the proper wait queue to wake in snd_pcm_update_state(). This requires twake to be non-zero when used by snd_pcm_lib_{read,write}1() even if avail_min is zero. Signed-off-by: Dave Dillow <dave@thedillows.org> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-05-31ALSA: pcm: Define G723 3-bit and 5-bit formatsBen Collins
This defines the 24bps and 40bps (8khz sample rate) G.723 codec formats. They are going to be used once I submit the driver for an mpeg4/g723 compression card. I've updated the signed value to -1 as per Takashi's comments since these are non-linear formats. Signed-off-by: Ben Collins <bcollins@bluecherry.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-10PM QOS updateMark Gross
This patch changes the string based list management to a handle base implementation to help with the hot path use of pm-qos, it also renames much of the API to use "request" as opposed to "requirement" that was used in the initial implementation. I did this because request more accurately represents what it actually does. Also, I added a string based ABI for users wanting to use a string interface. So if the user writes 0xDDDDDDDD formatted hex it will be accepted by the interface. (someone asked me for it and I don't think it hurts anything.) This patch updates some documentation input I got from Randy. Signed-off-by: markgross <mgross@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-01-26Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-01-26ALSA: pcm_lib - return back hw_ptr_interruptJaroslav Kysela
Clemens Ladisch noted for hw_ptr_removal in "cleanup & merge hw_ptr update functions" commit: "It is possible for the status/delay ioctls to be called when the sound card's pointer register alreay shows a position at the beginning of the new period, but immediately before the interrupt is actually executed. (This happens regularly on a SMP machine with mplayer.) When that happens, the code thinks that the position must be at least one period ahead of the current position and drops an entire buffer of data." Return back the hw_ptr_interrupt variable. The last interrupt pointer is always computed from the latest hw_ptr instead of tracking it separately (in this case all hw_ptr checks and modifications might influence also hw_ptr_interrupt and it is difficult to keep it consistent). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-21Merge branch 'topic/noncached-mmap' into topic/miscTakashi Iwai
2010-01-21Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-01-21ALSA: pcm_core: Fix wake_up() optimizationJaroslav Kysela
This change fixes the "ALSA: pcm_lib - optimize wake_up() calls for PCM I/O" commit. New sleeping queue is introduced to separate user space and kernel space wake_ups. runtime->nowake is renamed to twake (transfer wake). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-18ALSA: pcm - Call pgprot_noncached() for vmalloc'ed buffersTakashi Iwai
pgprot_noncached() can be set for vmalloc'ed buffers safely, and we'd need non-cached behavior more or less, even for the intermediate ring- buffers. Now snd_pcm_lib_mmap_vmalloc() is added as the common PCM mmap callback that is coupled with snd_pcm_lib_alloc_vmalloc_buffer() & co. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-12Merge commit alsa/devel into topic/miscTakashi Iwai
Conflicts: include/sound/version.h
2010-01-07ALSA: pcm_lib - optimize wake_up() calls for PCM I/OJaroslav Kysela
As noted by pl bossart <bossart.nospam@gmail.com>, the PCM I/O routines (snd_pcm_lib_write1, snd_pcm_lib_read1) should block wake_up() calls until all samples are not processed. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-07ALSA: pcm_lib - cleanup & merge hw_ptr update functionsJaroslav Kysela
Do general cleanup in snd_pcm_update_hw_ptr*() routines and merge them. The main change is hw_ptr_interrupt variable removal to simplify code logic. This variable can be computed directly from hw_ptr. Ensure that updated hw_ptr is not lower than previous one (it was possible with old code in some obscure situations when interrupt was delayed or the lowlevel driver returns wrong ring buffer position value). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-07ALSA: pcm_lib - add possibility to log last 10 DMA ring buffer positionsJaroslav Kysela
In some debug cases, it might be usefull to see previous ring buffer positions to determine position problems from the lowlevel drivers. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-12-18sound: pcm: add vmalloc buffer helper functionsClemens Ladisch
There are now five copies of the code to allocate a PCM buffer using vmalloc(). Add a sixth in the core so that the others can be removed. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-10sound: pcm: record a substream's owner processClemens Ladisch
Record the pid of the task that opened a PCM substream. For sound cards with hardware mixing, this allows determining which process is associated with a specific substream's volume control. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-10Merge branch 'topic/dummy' into for-linusTakashi Iwai
* topic/dummy: ALSA: dummy - Increase MAX_PCM_SUBSTREAMS to 128 ALSA: dummy - Add debug proc file ALSA: Add const prefix to proc helper functions ALSA: Re-export snd_pcm_format_name() function ALSA: dummy - Fake buffer allocations ALSA: dummy - Fix the timer calculation in systimer mode ALSA: dummy - Add more description ALSA: dummy - Better jiffies handling ALSA: dummy - Support high-res timer mode
2009-09-08ALSA: Re-export snd_pcm_format_name() functionTakashi Iwai
Re-export snd_pcm_format_name() function to be used outside the PCM core. As a first example, usbaudio is changed to use it now again. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-08ALSA: Fix SG-buffer DMA with non-coherent architecturesTakashi Iwai
Using SG-buffers with dma_alloc_coherent() is often very inefficient on non-coherent architectures because a tracking record could be allocated in addition for each dma_alloc_coherent() call. Instead, simply disable SG-buffers but just allocate normal continuous buffers on non-supported (currently all but x86) architectures. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10Merge branch 'topic/pcm-jiffies-check' into for-linusTakashi Iwai
* topic/pcm-jiffies-check: ALSA: pcm - A helper function to compose PCM stream name for debug prints ALSA: pcm - Fix update of runtime->hw_ptr_interrupt ALSA: pcm - Fix a typo in hw_ptr update check ALSA: PCM midlevel: lower jiffies check margin using runtime->delay value ALSA: PCM midlevel: Do not update hw_ptr_jiffies when hw_ptr is not changed ALSA: PCM midlevel: introduce mask for xrun_debug() macro ALSA: PCM midlevel: improve fifo_size handling
2009-06-10Merge branch 'topic/pcm-delay' into for-linusTakashi Iwai
* topic/pcm-delay: ALSA: usbaudio - Add delay account ALSA: Add extra delay count in PCM
2009-06-05ALSA: Clean up 64bit division functionsTakashi Iwai
Replace the house-made div64_32() with the standard div_u64*() functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
