path: root/include/sound/tea575x-tuner.h
2006-06-25V4L/DVB (4210b): git-dvb: tea575x-tuner build fixAndrew Morton
In file included from sound/i2c/other/tea575x-tuner.c:30: include/sound/tea575x-tuner.h:36: error: field 'vd' has incomplete type include/sound/tea575x-tuner.h:37: error: field 'fops' has incomplete type sound/i2c/other/tea575x-tuner.c:89: warning: 'struct inode' declared inside parameter list sound/i2c/other/tea575x-tuner.c:89: warning: its scope is only this definition or declaration, which is probably not what you want sound/i2c/other/tea575x-tuner.c: In function 'snd_tea575x_ioctl': sound/i2c/other/tea575x-tuner.c:91: warning: implicit declaration of function 'video_devdata' sound/i2c/other/tea575x-tuner.c:91: warning: initialization makes pointer from integer without a cast sound/i2c/other/tea575x-tuner.c:92: warning: implicit declaration of function 'video_get_drvdata' sound/i2c/other/tea575x-tuner.c:92: warning: initialization makes pointer from integer without a cast sound/i2c/other/tea575x-tuner.c:96: warning: implicit declaration of function '_IOR' sound/i2c/other/tea575x-tuner.c:96: error: syntax error before 'struct' sound/i2c/other/tea575x-tuner.c:99: error: 'v' undeclared (first use in this function) sound/i2c/other/tea575x-tuner.c:99: error: (Each undeclared identifier is reported only once sound/i2c/other/tea575x-tuner.c:99: error: for each function it appears in.) sound/i2c/other/tea575x-tuner.c:108: warning: implicit declaration of function 'copy_to_user' sound/i2c/other/tea575x-tuner.c:112: warning: implicit declaration of function '_IOWR' sound/i2c/other/tea575x-tuner.c:112: error: syntax error before 'struct' sound/i2c/other/tea575x-tuner.c:115: warning: implicit declaration of function 'copy_from_user' sound/i2c/other/tea575x-tuner.c: At top level: sound/i2c/other/tea575x-tuner.c:129: error: syntax error before 'case' sound/i2c/other/tea575x-tuner.c:146: warning: type defaults to 'int' in declaration of 'snd_tea575x_set_freq' sound/i2c/other/tea575x-tuner.c:146: warning: parameter names (without types) in function declaration sound/i2c/other/tea575x-tuner.c:146: error: conflicting types for 'snd_tea575x_set_freq' sound/i2c/other/tea575x-tuner.c:62: error: previous definition of 'snd_tea575x_set_freq' was here sound/i2c/other/tea575x-tuner.c:146: warning: data definition has no type or storage class sound/i2c/other/tea575x-tuner.c:147: error: syntax error before 'return' sound/i2c/other/tea575x-tuner.c:151: error: syntax error before '&' token sound/i2c/other/tea575x-tuner.c:152: error: syntax error before '.' token sound/i2c/other/tea575x-tuner.c:152: warning: type defaults to 'int' in declaration of 'strcpy' sound/i2c/other/tea575x-tuner.c:152: warning: function declaration isn't a prototype sound/i2c/other/tea575x-tuner.c:152: error: conflicting types for 'strcpy' sound/i2c/other/tea575x-tuner.c:152: warning: data definition has no type or storage class sound/i2c/other/tea575x-tuner.c: In function 'snd_tea575x_init': sound/i2c/other/tea575x-tuner.c:194: warning: implicit declaration of function 'video_set_drvdata' sound/i2c/other/tea575x-tuner.c:197: error: 'video_exclusive_open' undeclared (first use in this function) sound/i2c/other/tea575x-tuner.c:198: error: 'video_exclusive_release' undeclared (first use in this function) sound/i2c/other/tea575x-tuner.c:200: warning: implicit declaration of function 'video_register_device' sound/i2c/other/tea575x-tuner.c:200: error: 'VFL_TYPE_RADIO' undeclared (first use in this function) sound/i2c/other/tea575x-tuner.c: In function 'snd_tea575x_exit': sound/i2c/other/tea575x-tuner.c:215: warning: implicit declaration of function 'video_unregister_device' distcc[7333] ERROR: compile sound/i2c/other/tea575x-tuner.c on x/32 failed make[1]: *** [sound/i2c/other/tea575x-tuner.o] Error 1 Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-03[ALSA] Remove xxx_t typedefs: I2C driversTakashi Iwai
Remove xxx_t typedefs from the i2c drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-09[PATCH] v4l: Remove kernel version dependency from tea575x-tuner.hMauro Carvalho Chehab
- Removed kernel version dependency from tea575x-tuner.h Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
