The WM8962 features five GPIOs, add support for controlling their output
state via gpiolib.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add the widget for MICBIAS power control and allow configuration of the
microphone bias setup via the platform data for the WM8962. When
microphone status signals are brought out to GPIO this should be
sufficient to enable microphone detection.
Provide an initial hookup for interrupts on the WM8962. Currently we simply
report error status via log messages if an IRQ is provided for the device.
Some devices have more flexible microphone detection and can detect
a wider range of buttons.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Swapping the bias level enumeration is only meant to help debugging. It is
easier if number 0 means bias off and bigger number means bigger bias level.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
The current code in pcm_lib.c do all checks using only the position
in the ring buffer. Unfortunately, where the interrupts gets delayed or
merged into one, we need another timing source to check when the
buffer size boundary overlaps to avoid the wrong updating of the
ring buffer pointers.
This code uses jiffies to check the right time window without any
performance impact.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
With some hardware combinations, the PCM interrupts are acknowledged
before the period boundary from the emu10k1 chip. The midlevel PCM code
gets confused and the playback stream is interrupted.
It seems that the interrupt processing shift by 2 samples is enough
to fix this issue. This default value does not harm other,
non-affected hardware.
More information: Kernel bugzilla bug#16300
[A copmile warning fixed by tiwai]
Cc: <stable@kernel.org>
Fairly simple conflicts, the most serious ones are the i.MX ones which I
suspect now need another rename.
arch/arm/mach-mx2/clock_imx27.c
arch/arm/mach-mx2/devices.c
arch/arm/mach-omap2/board-rx51-peripherals.c
arch/arm/mach-omap2/board-zoom2.c
sound/soc/fsl/mpc5200_dma.c
sound/soc/fsl/mpc5200_dma.h
sound/soc/fsl/mpc8610_hpcd.c
sound/soc/pxa/spitz.c
unifdef-y and header-y has same semantic.
So there is no need to have both.
Drop the unifdef-y variant and sort all lines again
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into for-2.6.37
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits)
ALSA: hda - Add pin-fix for HP dc5750
ALSA: als4000: Fix potentially invalid DMA mode setup
ALSA: als4000: enable burst mode
ALSA: hda - Fix initial capsrc selection in patch_alc269()
ASoC: TWL4030: Capture route runtime DAPM ordering fix
ALSA: hda - Add PC-beep whitelist for an Intel board
ALSA: hda - More relax for pending period handling
ALSA: hda - Define AC_FMT_* constants
ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs
ALSA: hda - Add support for HDMI HBR passthrough
ALSA: hda - Set Stream Type in Stream Format according to AES0
ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed
ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF
ASoC: wm9081: fix resource reclaim in wm9081_register error path
ASoC: wm8978: fix a memory leak if a wm8978_register fail
ASoC: wm8974: fix a memory leak if another WM8974 is registered
ASoC: wm8961: fix resource reclaim in wm8961_register error path
ASoC: wm8955: fix resource reclaim in wm8955_register error path
ASoC: wm8940: fix a memory leak if wm8940_register return error
ASoC: wm8904: fix resource reclaim in wm8904_register error path
The WM8962 is a low power, high performance stereo CODEC designed for
portable digital audio applications.
This initial driver release supports the key audio paths of the WM8962.
Extended functionality, such as microphone detection, digital microphones
and the advanced DSP signal enhancements provided by the device are not
yet supported.
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
Platform parameter to enable automatic FIFO configuration when
the codec is in Mode1 or Mode7 FIFO mode.
When this mode is selected, the controls for changing
nSample (in Mode1), and UTHR (in Mode7) are not added.
The driver configures the FIFO configuration based on
the stream's period size in a way, that every burst will
read period size of data from the host.
In Mode7 we need to use a formula, which gives close enough
aproximation for the burst length from the host point
of view.
Replace the hardwired latency definition with platform data
parameter, and simplify the nSample parameter calculation.
All current users of pm_qos_add_request() have the ability to supply
the memory required by the pm_qos routines, so make them do this and
eliminate the kmalloc() with pm_qos_add_request(). This has the
double benefit of making the call never fail and allowing it to be
called from atomic context.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Signed-off-by: mark gross <markgross@thegnar.org>
Specified ID is necessary, when some codecs are used with FSI.
This patch add hw_params to snd_soc_dai_ops,
because board specific set_rate is needed
when FSI was used as master mode.
This patch remove fsi_clk_ctrl from fsi_dai_startup,
because clock should be disabled before set_rate.
There is no necessity that each bit in this area has the meaning.
This patch modify it to sequence number
When using poll() to wait for the next period -- or avail_min samples --
one gets a consistent delay for each system call that is usually just a
little short of the selected period time. However, When using
snd_pcm_read/write(), one gets a jittery delay that alternates between
less than a millisecond and approximately two period times. This is
caused by snd_pcm_lib_{read,write}1() transferring any available samples
to the user's buffer and adjusting the application pointer prior to
sleeping to the end of the current period. When the next period
interrupt occurs, there is then less than avail_min samples remaining to
be transferred in the period, so we end up sleeping until a second
period occurs.
This is solved by using runtime->twake as the number of samples needed
for a wakeup in addition to selecting the proper wait queue to wake in
snd_pcm_update_state(). This requires twake to be non-zero when used
by snd_pcm_lib_{read,write}1() even if avail_min is zero.
Signed-off-by: Dave Dillow <dave@thedillows.org>
This change wipes out a hardcoded macro, which enables codec bias
level control. Now is_powered_on_standby value shall be used instead.
Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Some systems codecs need to configure some registers before and after
powering down some of their part. As a convenience add a macro for that.
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
This defines the 24bps and 40bps (8khz sample rate) G.723 codec
formats. They are going to be used once I submit the driver for
an mpeg4/g723 compression card.
I've updated the signed value to -1 as per Takashi's comments
since these are non-linear formats.
Signed-off-by: Ben Collins <bcollins@bluecherry.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits)
ALSA: hda: Storage class should be before const qualifier
ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies
ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT
ASoC: sdp4430 - add sdp4430 pcm ops to DAI.
ASoC: TWL6040: Enable earphone path in codec
ASoC: SDP4430: Add support for Earphone speaker
ASoC: SDP4430: Add sdp4430 machine driver
ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF
ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function
ALSA: sound/pci/asihpi: Use kzalloc
ALSA: hdmi - dont fail on extra nodes
ALSA: intelhdmi - add id for the CougarPoint chipset
ALSA: intelhdmi - user friendly codec name
ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS
ALSA: asihpi: incorrect range check
ALSA: asihpi: testing the wrong variable
ALSA: es1688: add pedantic range checks
ARM: McBSP: Add support for omap4 in McBSP driver
ARM: McBSP: Fix request for irq in OMAP4
OMAP: McBSP: Add 32-bit mode support
sound/soc/codecs/ad1938.c
This patch is adding a new control which has the following capabilities:
- tlv
- variable data size (for instance, 7 ou 8 bit)
- double mixer
- data range centered around 0
Acked-by: Liam Girdwood <lrg@opensource.wolfsonmicro.com>
This fixes some whitespace/indentation flaws I stumbled over.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
If the register for the volume needs invert, than the inversion
need to be done from the chip maximum, and not from the platform
dependent limit.
Introduce soc_mixer_control.platform_max value, which initially
equals to chip maximum.
The snd_soc_limit_volume function only modify the platform_max,
all volsw_info call returns this as well.
The .max value holds the chip default (maximum), and it is used
for the inversion, if it is needed.
Additional check in the volsw_info call has been added to check
the validity of the platform_max in case, when custom macros
used by codec drivers are not initializing it correctly.
This patch changes the string based list management to a handle base
implementation to help with the hot path use of pm-qos, it also renames
much of the API to use "request" as opposed to "requirement" that was
used in the initial implementation. I did this because request more
accurately represents what it actually does.
Also, I added a string based ABI for users wanting to use a string
interface. So if the user writes 0xDDDDDDDD formatted hex it will be
accepted by the interface. (someone asked me for it and I don't think
it hurts anything.)
This patch updates some documentation input I got from Randy.
Signed-off-by: markgross <mgross@linux.intel.com>
As well as allowing DAPM pins to be marked as ignoring suspend allow DAI
links to be similarly marked. This is primarily intended for digital
links between CODECs and non-CPU devices such as basebands in mobile
phones and will suppress all suspend calls for the DAI link. It is
likely that this will need to be revisited if used with devices which
are part of the SoC CPU.
Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Some devices can usefully run audio while the Linux system is suspended.
One of the most common examples is smartphone systems, which are normally
designed to allow audio to be run between the baseband and the CODEC
without passing through the CPU and so can suspend the CPU when on a
voice call for additional power savings.
Support such systems by providing an API snd_soc_dapm_ignore_suspend().
This can be used to mark DAPM endpoints as not being sensitive to
system suspend. When the system is being suspended paths between
endpoints which are marked as ignoring suspend will be kept active.
Both source and sink must be marked, and there must already be an
active path between the two endpoints prior to suspend.
When paths are active over suspend the bias management will hold the
device bias in the ON state. This is used to avoid suspending the
CODEC while it is still in use.
We now manage suspend within the main power analysis rather than by
flipping the state of widgets.
The ESS ES968 chip is nothing more then a PnP companion
for a non-PnP audio chip. It was paired with non-PnP ESS' chips:
ES688 and ES1688. The ESS' audio chips are handled by the es1688
driver in native mode. The PnP cards are handled by the ES968
driver in SB compatible mode.
Move the ES968 chip handling to the es1688 driver so the driver
can handle both PnP and non-PnP cards. The es968 is removed.
Also, a new PnP id is added for the card I acquired (the change
was tested on this card).
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Allocate the snd_es1688 during the snd_card allocation.
This allows to remove the card pointer from the snd_es1688 structure.
This reverts commit 6f3991152f20933b77eff30413e893bf1a15e578.
Since core has now support for limiting the volume on controls this
patch is not needed. Furthermore, this patch actually prevents the core
to set new volume on the TPA.
Add support for the core to limit the maximum volume on an
existing control.
The function will modify the soc_mixer_control.max value
of the given control.
The new value must be lower than the original one (chip maximum)
If there is a need for limiting a gain on a given control,
than machine drivers can do the following in their
snd_soc_dai_link.init function:
snd_soc_limit_volume(codec, "TPA6140A2 Headphone Playback Volume", 21);
This will modify the original 31 (chip maximum) to 21, so user
space will not be able to set the gain higher than this.
Add support for platform dependent gain limiting on the
tpa6130a2 (and tpa6140a2) Headset amplifier.
Handle the reset GPIO within the codec driver in order to follow
the startup protocol for the tlv320aic3x codecs.
Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
The WM9090 is a high performance low power audio subsystem, including
headphone and class D speaker drivers.
Note that this driver is a standalone CODEC driver and so is only
immediately suitable for use with the WM9090 as a standalone sound card
taking line inputs, or with a DAC with no software control. The pending
ASoC multi-CODEC support will expand the range of systems that can use
the driver, or system-specific adaptations can be made.
This patch adds support for Philips UDA1345 CODEC. The CODEC has only
volume control, de-emphasis, mute, DC filtering and power control features.
