path: root/include/trace
2012-08-13tracing: Clock lock trace eventsAntti P Miettinen
Add tracing for clock lock/unlock operations. Bug 960307 Change-Id: Id5c2d8be25900bc701e5dcd73f87c068ab6e5894 Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-on: http://git-master/r/122666 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-08-13workqueue: CPU hotplug keep idle workersMitch Luban
This change merges two patchsets. The first set, containing 6 patches, reimplements WQ_HIGHPRI to use a seperate worker_pool. gcwq->pools[0] is used for normal priority work and pools[1] for high priority. The second patchset contains 9 patches and reimplements CPU hotplug to keep idle workers. Updates workqueue CPU hotplug path to use a disassociated global_cwq, which runs as an unbound one (WQ_UNBOUND). While this requires rebinding idle workers, overall hotplug path is much simpler. Original patchset: http://thread.gmane.org/gmane.linux.kernel/1329164 Bug 978010 Change-Id: Ic66ec8848a8d111b5278e63ef6a410846dfd8fcc Signed-off-by: Mitch Luban <mluban@nvidia.com> Reviewed-on: http://git-master/r/118387 Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-08-03input: touch: atmel_mxt_ts: Add Ftrace logging.Vikas Jain
This change assists automating system wide touch driver performance. Bug 928954 Change-Id: Iea21dfea1c31748ce5835652cecc0856c4f4028d Signed-off-by: Vikas Jain <vjain@nvidia.com> Reviewed-on: http://git-master/r/118984 Reviewed-by: Sachin Nikam <snikam@nvidia.com> Reviewed-by: David Jung <djung@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User
2012-06-21nvmap: Add trace points for nvmap.Krishna Reddy
Change-Id: I86e68c57846fe14de7620edf4c241ad7d9e46df2 Signed-off-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-on: http://git-master/r/106491 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Satya Popuri <spopuri@nvidia.com>
2012-05-29video: tegra: host: Throttle lower priority jobsTerje Bergstrom
Implement per channel counter for jobs in each priority level. If there are jobs active with higher priority than the one being submitted, throttle. Bug 926690 Change-Id: I5fed341e3f248325873b31d1c53bf57bf0a78074 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/104939 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
2012-05-25video: tegra: host: Replace nvmap structs with ownTerje Bergstrom
Replace usage of nvmap_pinarray_elem with own nvhost_reloc and nvhost_reloc_shift structs. Bug 965206 Change-Id: I90618d8a34d79156d8880d9925dadbf416353811 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/104450 Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
2012-05-24video: tegra: host: rewrite nvhost_job_pin/unpin APIsMayuresh Kulkarni
- remove usage of custom interface of nvmap to patch the relocs and and pin the gathers/relocs - convert code that references nvmap_handle to nvmap_handle_ref - add logic to pin and map only unique gathers and relocs - rename nvhost_channel_gather to nvhost_job_gather, because it's used in nvhost_job code only Bug 965206 Change-Id: Iaa7fbac9e4a7b08c0a7c1e184b8dd3566e1edfe2 Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/95299 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-05-14ARM: tegra: pm: suspend trace eventSivaram Nair
A new trace event is added for tracing cpu suspend start and end Change-Id: I2506e3aed0692c44fb4325e9d381cea53228b0c3 Signed-off-by: Sivaram Nair <sivaramn@nvidia.com> Reviewed-on: http://git-master/r/101748 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-05-10video: tegra: host: Add syncpt trace eventsTerje Bergstrom
Add trace events for updating the syncpt value from hardware, and wait check. Change-Id: If17de153ae36c0665fe0af2f405dfe42f7fcd656 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/101524 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-by: Ken Adams <kadams@nvidia.com>
2012-05-10video: tegra: host: Add context switch to trace dumpTerje Bergstrom
Add context switch to the ftrace dump. Change-Id: I5df032273982b919fb94263cff38d8b8b6b6be45 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/101523 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-04-15regmap: Add tracepoints for cache only and cache bypassMark Brown
Useful for figuring out where the hardware interaction went or came from. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> (cherry picked from commit 5d5b7d4f80ed6e861c1c220fd57e3dad0912526e) Change-Id: Ie7c0659458a3a4a2f100d86db552c606d9da0e6b Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/96488 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-04-12tracing: Add tracepoints for cluster switchAntti P Miettinen
Simple trace points for measuring cluster switch latencies. Bug 958262 Change-Id: Ia1e5e13131d5e55aaa0a44e9e8b5196539df54e7 Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-on: http://git-master/r/93841 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-04-12tracing: Add tracepoints for CPU scalingAntti P Miettinen
Simple tracepoints for measuring CPU scaling latencies. Bug 960307 Change-Id: I6fd4e67e352a2ff134da58866d943457506d080b Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-on: http://git-master/r/93080 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-04-12tracing: Add tracepoints for hotplugAntti P Miettinen
Simple trace points for measuring hotplug up/down times. Bug 960310 Change-Id: I1927aae6edb74cba7ca3e9522d138407b48325dc Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-on: http://git-master/r/92920 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Satya Popuri <spopuri@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-03-23video: tegra: host: Split submit into subfunctionsTerje Bergstrom
Split host1x_channel_submit() into subfunctions. Bug 926690 Change-Id: I8be55cbc9d25ee76c758a918de4a9bb27e2ea846 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/90626 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-03-05regmap: Add trace event for successful cache readsMark Brown
Currently we only trace physical reads, there's no instrumentation if the read is satisfied from cache. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> (cherry picked from commit bc7ee55633867909bb05e71f957a4d3c1aa1b488) Change-Id: Ibbd7caff4e97b8a511f1d36b98bfdaa706ff8af4 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/87572
2012-02-29regmap: merge 7cccbdc84487616c3dbe493b04bfa1f362f4bc56Laxman Dewangan
Merge commit '7cccbdc84487616c3dbe493b04bfa1f362f4bc56' into origin/android-tegra-nv-3.1 Conflicts: drivers/base/regmap/regmap.c Change-Id: I7c74b1745e592390538419a2c8026a3ba29be8ea Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-02-18video: tegra: host: Add syncpt value to tracesTerje Bergstrom
Add current values of sync points to sync point read and wait IOCTL's. Change-Id: I479a66e283b47867ed13685b75c1858b4fb65c2d Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/80006 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2011-12-08video: tegra: host: Support for right shift on reloc patchesTerje Bergstrom
Some hardware architectures require that only select MSB bits be supplied to them for addresses. They do the reverse transformation while accessing the actual memory. Bug 857531 Change-Id: I215f099ff0ee86daff1c1eb1e5b70edf8ae856d9 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/66654 Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> Reviewed-by: Shashank Garg <sgarg@nvidia.com>
2011-11-30video: tegra: host: Add syncpt and cmdbuf to traceTerje Bergstrom
Add sync point information and contents of command buffers to ftrace output. Change-Id: Ie30e2208da3f76315e6d706c841190eff22dd09d Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/66072 Tested-by: Gerrit_Virtual_Submit Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> Rebase-Id: Rcb8cda3b5720036e28b112558baa0f4d2b37a7a8
2011-11-30nvhost: Move include files to kernel/includeTerje Bergstrom
To prepare for kernel modularization, nvhost include files need to be moved from mach-tegra/include to kernel/include. At the same time user space specific part is split into nvhost_ioctl.h. Bug 854182 Original-Change-Id: I3694a40d786028733310ecf5b59341282af571be Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/43211 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com> Rebase-Id: Rc4fadf65d59ddfb5bb924e7adfccd39e86a0b2c7
2011-09-19regmap: Add the regcache_sync trace eventDimitris Papastamos
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-31writeback: show raw dirtied_when in trace writeback_single_inodeWu Fengguang
Save inode->dirtied_when in the raw trace output for reliable scripting, and to also show in formatted output the relative age in seconds for easy human reading. CC: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
2011-08-19Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: (23 commits) Revert "cfq: Remove special treatment for metadata rqs." block: fix flush machinery for stacking drivers with differring flush flags block: improve rq_affinity placement blktrace: add FLUSH/FUA support Move some REQ flags to the common bio/request area allow blk_flush_policy to return REQ_FSEQ_DATA independent of *FLUSH xen/blkback: Make description more obvious. cfq-iosched: Add documentation about idling block: Make rq_affinity = 1 work as expected block: swim3: fix unterminated of_device_id table block/genhd.c: remove useless cast in diskstats_show() drivers/cdrom/cdrom.c: relax check on dvd manufacturer value drivers/block/drbd/drbd_nl.c: use bitmap_parse instead of __bitmap_parse bsg-lib: add module.h include cfq-iosched: Reduce linked group count upon group destruction blk-throttle: correctly determine sync bio loop: fix deadlock when sysfs and LOOP_CLR_FD race against each other loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop devices loop: add management interface for on-demand device allocation loop: replace linked list of allocated devices with an idr index ...
2011-08-11blktrace: add FLUSH/FUA supportNamhyung Kim
Add FLUSH/FUA support to blktrace. As FLUSH precedes WRITE and/or FUA follows WRITE, use the same 'F' flag for both cases and distinguish them by their (relative) position. The end results look like (other flags might be shown also): - WRITE: W - WRITE_FLUSH: FW - WRITE_FUA: WF - WRITE_FLUSH_FUA: FWF Note that we reuse TC_BARRIER due to lack of bit space of act_mask so that the older versions of blktrace tools will report flush requests as barriers from now on. Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-10regmap: Use int rather than size_t for lengths when logging blocksMark Brown
x86_64 warns as size_t is not an int. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au>
2011-08-08regmap: Add basic tracepointsMark Brown
Trace single register reads and writes, plus start/stop tracepoints for the actual I/O to see where we're spending time. This makes it easy to have always on logging without overwhelming the logs and also lets us take advantage of all the context and time information that the trace subsystem collects for us. We don't currently trace register values for bulk operations as this would add complexity and overhead parsing the cooked data that's being worked with. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (60 commits) ext4: prevent memory leaks from ext4_mb_init_backend() on error path ext4: use EXT4_BAD_INO for buddy cache to avoid colliding with valid inode # ext4: use ext4_msg() instead of printk in mballoc ext4: use ext4_kvzalloc()/ext4_kvmalloc() for s_group_desc and s_group_info ext4: introduce ext4_kvmalloc(), ext4_kzalloc(), and ext4_kvfree() ext4: use the correct error exit path in ext4_init_inode_table() ext4: add missing kfree() on error return path in add_new_gdb() ext4: change umode_t in tracepoint headers to be an explicit __u16 ext4: fix races in ext4_sync_parent() ext4: Fix overflow caused by missing cast in ext4_fallocate() ext4: add action of moving index in ext4_ext_rm_idx for Punch Hole ext4: simplify parameters of reserve_backup_gdb() ext4: simplify parameters of add_new_gdb() ext4: remove lock_buffer in bclean() and setup_new_group_blocks() ext4: simplify journal handling in setup_new_group_blocks() ext4: let setup_new_group_blocks() set multiple bits at a time ext4: fix a typo in ext4_group_extend() ext4: let ext4_group_add_blocks() handle 0 blocks quickly ext4: let ext4_group_add_blocks() return an error code ext4: rename ext4_add_groupblocks() to ext4_group_add_blocks() ... Fix up conflict in fs/ext4/inode.c: commit aacfc19c626e ("fs: simplify the blockdev_direct_IO prototype") had changed the ext4_ind_direct_IO() function for the new simplified calling convention, while commit dae1e52cb126 ("ext4: move ext4_ind_* functions from inode.c to indirect.c") moved the function to another file.
2011-07-30ext4: change umode_t in tracepoint headers to be an explicit __u16Theodore Ts'o
As requested by Al Viro, since umode_t may be changing to a u32 for some architectures. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@ZenIV.linux.org.uk>
2011-07-29Merge branch 'upstream/xen-tracing2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/xen-tracing2' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen/tracing: fix compile errors when tracing is disabled.
2011-07-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t ext3.txt: update the links in the section "useful links" to the latest ones ext3: Fix data corruption in inodes with journalled data ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get ext3: Fix compilation with -DDX_DEBUG quota: Remove unused declaration jbd: Use WRITE_SYNC in journal checkpoint. jbd: Fix oops in journal_remove_journal_head() ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs() ext3/ioctl.c: silence sparse warnings about different address spaces ext3/ext4 Documentation: remove bh/nobh since it has been deprecated ext3: Improve truncate error handling ext3: use proper little-endian bitops ext2: include fs.h into ext2_fs.h ext3: Fix oops in ext3_try_to_allocate_with_rsv() jbd: fix a bug of leaking jh->b_jcount jbd: remove dependency on __GFP_NOFAIL ext3: Convert ext3 to new truncate calling convention jbd: Add fixed tracepoints ext3: Add fixed tracepoints Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and new fixed tracepoints.
2011-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback: (27 commits) mm: properly reflect task dirty limits in dirty_exceeded logic writeback: don't busy retry writeback on new/freeing inodes writeback: scale IO chunk size up to half device bandwidth writeback: trace global_dirty_state writeback: introduce max-pause and pass-good dirty limits writeback: introduce smoothed global dirty limit writeback: consolidate variable names in balance_dirty_pages() writeback: show bdi write bandwidth in debugfs writeback: bdi write bandwidth estimation writeback: account per-bdi accumulated written pages writeback: make writeback_control.nr_to_write straight writeback: skip tmpfs early in balance_dirty_pages_ratelimited_nr() writeback: trace event writeback_queue_io writeback: trace event writeback_single_inode writeback: remove .nonblocking and .encountered_congestion writeback: remove writeback_control.more_io writeback: skip balance_dirty_pages() for in-memory fs writeback: add bdi_dirty_limit() kernel-doc writeback: avoid extra sync work at enqueue time writeback: elevate queue_io() into wb_writeback() ... Fix up trivial conflicts in fs/fs-writeback.c and mm/filemap.c
2011-07-25xen/tracing: fix compile errors when tracing is disabled.Jeremy Fitzhardinge
When CONFIG_FUNCTION_TRACER is disabled, compilation fails as follows: CC arch/x86/xen/setup.o In file included from arch/x86/include/asm/xen/hypercall.h:42, from arch/x86/xen/setup.c:19: include/trace/events/xen.h:31: warning: 'struct multicall_entry' declared inside parameter list include/trace/events/xen.h:31: warning: its scope is only this definition or declaration, which is probably not what you want include/trace/events/xen.h:31: warning: 'struct multicall_entry' declared inside parameter list include/trace/events/xen.h:31: warning: 'struct multicall_entry' declared inside parameter list include/trace/events/xen.h:31: warning: 'struct multicall_entry' declared inside parameter list [...] arch/x86/xen/trace.c:5: error: '__HYPERVISOR_set_trap_table' undeclared here (not in a function) arch/x86/xen/trace.c:5: error: array index in initializer not of integer type arch/x86/xen/trace.c:5: error: (near initialization for 'xen_hypercall_names') arch/x86/xen/trace.c:6: error: '__HYPERVISOR_mmu_update' undeclared here (not in a function) arch/x86/xen/trace.c:6: error: array index in initializer not of integer type arch/x86/xen/trace.c:6: error: (near initialization for 'xen_hypercall_names') Fix this by making sure struct multicall_entry has a declaration in scope at all times, and don't bother compiling xen/trace.c when tracing is disabled. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2011-07-24Merge branch 'upstream/xen-tracing2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/xen-tracing2' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen/trace: use class for multicall trace xen/trace: convert mmu events to use DECLARE_EVENT_CLASS()/DEFINE_EVENT() xen/multicall: move *idx fields to start of mc_buffer xen/multicall: special-case singleton hypercalls xen/multicalls: add unlikely around slowpath in __xen_mc_entry() xen/multicalls: disable MC_DEBUG xen/mmu: tune pgtable alloc/release xen/mmu: use extend_args for more mmuext updates xen/trace: add tlb flush tracepoints xen/trace: add segment desc tracing xen/trace: add xen_pgd_(un)pin tracepoints xen/trace: add ptpage alloc/release tracepoints xen/trace: add mmu tracepoints xen/trace: add multicall tracing xen/trace: set up tracepoint skeleton xen/multicalls: remove debugfs stats trace/xen: add skeleton for Xen trace events
2011-07-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits) ALSA: asihpi - Replace with snd_ctl_boolean_mono_info() ALSA: asihpi - HPI version 4.08 ALSA: asihpi - Add volume mute controls ALSA: asihpi - Control name updates ALSA: asihpi - Use size_t for sizeof result ALSA: asihpi - Explicitly include mutex.h ALSA: asihpi - Add new node and message defines ALSA: asihpi - Make local function static ALSA: asihpi - Fix minor typos and spelling ALSA: asihpi - Remove unused structures, macros and functions ALSA: asihpi - Remove spurious adapter index check ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro ALSA: asihpi - DSP code loader API now independent of OS ALSA: asihpi - Remove controlex structs and associated special data transfer code ALSA: asihpi - Increase request and response buffer sizes ALSA: asihpi - Give more meaningful name to hpi request message type ALSA: usb-audio - Add quirk for Roland / BOSS BR-800 ALSA: hda - Remove a superfluous argument of via_auto_init_output() ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs ALSA: hda - Add documentation for codec-specific mixer controls ...
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-07-20vmscan: add shrink_slab tracepointsDave Chinner
It is impossible to understand what the shrinkers are actually doing without instrumenting the code, so add a some tracepoints to allow insight to be gained. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-18xen/trace: use class for multicall traceJeremy Fitzhardinge
2011-07-18xen/trace: convert mmu events to use DECLARE_EVENT_CLASS()/DEFINE_EVENT()Jeremy Fitzhardinge
2011-07-18xen/trace: add tlb flush tracepointsJeremy Fitzhardinge
2011-07-18xen/trace: add segment desc tracingJeremy Fitzhardinge
2011-07-18xen/trace: add xen_pgd_(un)pin tracepointsJeremy Fitzhardinge
2011-07-18xen/trace: add ptpage alloc/release tracepointsJeremy Fitzhardinge
2011-07-18xen/trace: add mmu tracepointsJeremy Fitzhardinge
2011-07-18xen/trace: add multicall tracingJeremy Fitzhardinge
2011-07-18trace/xen: add skeleton for Xen trace eventsJeremy Fitzhardinge
2011-07-11ext4: Add new ext4 trim tracepointsTao Ma
Add ext4_trim_extent and ext4_trim_all_free. Reviewed-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-10ext4: add tracepoint for ext4_journal_startTheodore Ts'o
This will help debug who is responsible for starting a jbd2 transaction. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-10jbd2: remove jbd2_dev_to_name() from jbd2 tracepointsTheodore Ts'o
Using function calls in TP_printk causes perf heartburn, so print the MAJOR/MINOR device numbers instead. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
