Adds SNMP counter for drops caused by MD5 mismatches.
The current syslog might help, but a counter is more precise and helps
monitoring.
Track success and failure of TCP PMTU probing.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
Diagnosing problems related to Window Probes has been hard because
we lack a counter.
TCPWinProbe counts the number of ACK packets a sender has to send
at regular intervals to make sure a reverse ACK packet opening back
a window had not been lost.
TCPKeepAlive counts the number of ACK packets sent to keep TCP
flows alive (SO_KEEPALIVE)
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Nandita Dukkipati <nanditad@google.com>
Helpers for mitigating ACK loops by rate-limiting dupacks sent in
response to incoming out-of-window packets.
This patch includes:
- rate-limiting logic
- sysctl to control how often we allow dupacks to out-of-window packets
- SNMP counter for cases where we rate-limited our dupack sending
The rate-limiting logic in this patch decides to not send dupacks in
response to out-of-window segments if (a) they are SYNs or pure ACKs
and (b) the remote endpoint is sending them faster than the configured
rate limit.
We rate-limit our responses rather than blocking them entirely or
resetting the connection, because legitimate connections can rely on
dupacks in response to some out-of-window segments. For example, zero
window probes are typically sent with a sequence number that is below
the current window, and ZWPs thus expect to thus elicit a dupack in
response.
We allow dupacks in response to TCP segments with data, because these
may be spurious retransmissions for which the remote endpoint wants to
receive DSACKs. This is safe because segments with data can't
realistically be part of ACK loops, which by their nature consist of
each side sending pure/data-less ACKs to each other.
The dupack interval is controlled by a new sysctl knob,
tcp_invalid_ratelimit, given in milliseconds, in case an administrator
needs to dial this upward in the face of a high-rate DoS attack. The
name and units are chosen to be analogous to the existing analogous
knob for ICMP, icmp_ratelimit.
The default value for tcp_invalid_ratelimit is 500ms, which allows at
most one such dupack per 500ms. This is chosen to be 2x faster than
the 1-second minimum RTO interval allowed by RFC 6298 (section 2, rule
2.4). We allow the extra 2x factor because network delay variations
can cause packets sent at 1 second intervals to be compressed and
arrive much closer.
Reported-by: Avery Fay <avery@mixpanel.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
When deploying FQ pacing, one thing we noticed is that CUBIC Hystart
triggers too soon.
Having SNMP counters to have an idea of how often the various Hystart
methods trigger is useful prior to any modifications.
This patch adds SNMP counters tracking, how many time "ack train" or
"Delay" based Hystart triggers, and cumulative sum of cwnd at the time
Hystart decided to end SS (Slow Start)
myhost:~# nstat -a | grep Hystart
TcpExtTCPHystartTrainDetect 9 0.0
TcpExtTCPHystartTrainCwnd 20650 0.0
TcpExtTCPHystartDelayDetect 10 0.0
TcpExtTCPHystartDelayCwnd 360 0.0
Train detection was triggered 9 times, and average cwnd was
20650/9=2294,
Delay detection was triggered 10 times and average cwnd was 36
As NIC multicast filtering isn't perfect, and some platforms are
quite content to spew broadcasts, we should not trigger an event
for skb:kfree_skb when we do not have a match for such an incoming
datagram. We do though want to avoid sweeping the matter under the
rug entirely, so increment a suitable statistic.
This incorporates feedback from David L. Stevens, Karl Neiss and Eric
Dumazet.
V3 - use bool per David Miller
Add the following snmp stats:
TCPFastOpenActiveFail: Fast Open attempts (SYN/data) failed beacuse
the remote does not accept it or the attempts timed out.
TCPSynRetrans: number of SYN and SYN/ACK retransmits to break down
retransmissions into SYN, fast-retransmits, timeout retransmits, etc.
TCPOrigDataSent: number of outgoing packets with original data (excluding
retransmission but including data-in-SYN). This counter is different from
TcpOutSegs because TcpOutSegs also tracks pure ACKs. TCPOrigDataSent is
more useful to track the TCP retransmission rate.
Change TCPFastOpenActive to track only successful Fast Opens to be symmetric to
TCPFastOpenPassive.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Signed-off-by: Lawrence Brakmo <brakmo@google.com>
Three counters are added:
- one to track when we went from non-zero to zero window
- one to track the reverse
- one counter incremented when we want to announce zero window,
but can't because we would shrink current window.
Suggested-by: Eric Dumazet <edumazet@google.com>
With the introduction of TCP Small Queues, TSO auto sizing, and TCP
pacing, we can implement Automatic Corking in the kernel, to help
applications doing small write()/sendmsg() to TCP sockets.
Idea is to change tcp_push() to check if the current skb payload is
under skb optimal size (a multiple of MSS bytes)
If under 'size_goal', and at least one packet is still in Qdisc or
NIC TX queues, set the TCP Small Queue Throttled bit, so that the push
will be delayed up to TX completion time.
This delay might allow the application to coalesce more bytes
in the skb in following write()/sendmsg()/sendfile() system calls.
The exact duration of the delay is depending on the dynamics
of the system, and might be zero if no packet for this flow
is actually held in Qdisc or NIC TX ring.
Using FQ/pacing is a way to increase the probability of
autocorking being triggered.
Add a new sysctl (/proc/sys/net/ipv4/tcp_autocorking) to control
this feature and default it to 1 (enabled)
Add a new SNMP counter : nstat -a | grep TcpExtTCPAutoCorking
This counter is incremented every time we detected skb was under used
and its flush was deferred.
Tested:
Interesting effects when using line buffered commands under ssh.
Excellent performance results in term of cpu usage and total throughput.
lpq83:~# echo 1 >/proc/sys/net/ipv4/tcp_autocorking
lpq83:~# perf stat ./super_netperf 4 -t TCP_STREAM -H lpq84 -- -m 128
9410.39
Performance counter stats for './super_netperf 4 -t TCP_STREAM -H lpq84 -- -m 128':
35209.439626 task-clock # 2.901 CPUs utilized
2,294 context-switches # 0.065 K/sec
101 CPU-migrations # 0.003 K/sec
4,079 page-faults # 0.116 K/sec
97,923,241,298 cycles # 2.781 GHz [83.31%]
51,832,908,236 stalled-cycles-frontend # 52.93% frontend cycles idle [83.30%]
25,697,986,603 stalled-cycles-backend # 26.24% backend cycles idle [66.70%]
102,225,978,536 instructions # 1.04 insns per cycle
# 0.51 stalled cycles per insn [83.38%]
18,657,696,819 branches # 529.906 M/sec [83.29%]
91,679,646 branch-misses # 0.49% of all branches [83.40%]
12.136204899 seconds time elapsed
lpq83:~# echo 0 >/proc/sys/net/ipv4/tcp_autocorking
6624.89
40045.864494 task-clock # 3.301 CPUs utilized
171 context-switches # 0.004 K/sec
53 CPU-migrations # 0.001 K/sec
4,080 page-faults # 0.102 K/sec
111,340,458,645 cycles # 2.780 GHz [83.34%]
61,778,039,277 stalled-cycles-frontend # 55.49% frontend cycles idle [83.31%]
29,295,522,759 stalled-cycles-backend # 26.31% backend cycles idle [66.67%]
108,654,349,355 instructions # 0.98 insns per cycle
# 0.57 stalled cycles per insn [83.34%]
19,552,170,748 branches # 488.244 M/sec [83.34%]
157,875,417 branch-misses # 0.81% of all branches [83.34%]
12.130267788 seconds time elapsed
Rename mib counter from "low latency" to "busy poll"
v1 also moved the counter to the ip MIB (suggested by Shawn Bohrer)
Eric Dumazet suggested that the current location is better.
So v2 just renames the counter to fit the new naming convention.
Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com>
With GRO/LRO processing, there is a problem because Ip[6]InReceives SNMP
counters do not count the number of frames, but number of aggregated
segments.
Its probably too late to change this now.
This patch adds four new counters, tracking number of frames, regardless
of LRO/GRO, and on a per ECN status basis, for IPv4 and IPv6.
Ip[6]NoECTPkts : Number of packets received with NOECT
Ip[6]ECT1Pkts : Number of packets received with ECT(1)
Ip[6]ECT0Pkts : Number of packets received with ECT(0)
Ip[6]CEPkts : Number of packets received with Congestion Experienced
lph37:~# nstat | egrep "Pkts|InReceive"
IpInReceives 1634137 0.0
Ip6InReceives 3714107 0.0
Ip6InNoECTPkts 19205 0.0
Ip6InECT0Pkts 52651828 0.0
IpExtInNoECTPkts 33630 0.0
IpExtInECT0Pkts 15581379 0.0
IpExtInCEPkts 6 0.0
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
Just one patch this time.
1) Drop packets when the matching SA is in larval state and add a
statistic counter for that. From Fan Du.
Please pull or let me know if there are problems.
Adds an ndo_ll_poll method and the code that supports it.
This method can be used by low latency applications to busy-poll
Ethernet device queues directly from the socket code.
sysctl_net_ll_poll controls how many microseconds to poll.
Default is zero (disabled).
Individual protocol support will be added by subsequent patches.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Tested-by: Willem de Bruijn <willemb@google.com>
When host ping its peer, ICMP echo request packet triggers IPsec
policy, then host negotiates SA secret with its peer. After IKE
installed SA for OUT direction, but before SA for IN direction
installed, host get ICMP echo reply from its peer. At the time
being, the SA state for IN direction could be XFRM_STATE_ACQ,
then the received packet will be dropped after adding
LINUX_MIB_XFRMINSTATEINVALID statistic.
Adding a LINUX_MIB_XFRMACQUIREERROR statistic counter for such
scenario when SA in larval state is much clearer for user than
LINUX_MIB_XFRMINSTATEINVALID which indicates the SA is totally
bad.
Signed-off-by: Fan Du <fan.du@windriver.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Add MIB counters for checksum errors in IP layer,
and TCP/UDP/ICMP layers, to help diagnose problems.
$ nstat -a | grep Csum
IcmpInCsumErrors 72 0.0
TcpInCsumErrors 382 0.0
UdpInCsumErrors 463221 0.0
Icmp6InCsumErrors 75 0.0
Udp6InCsumErrors 173442 0.0
IpExtInCsumErrors 10884 0.0
Host queues (Qdisc + NIC) can hold packets so long that TCP can
eventually retransmit a packet before the first transmit even left
the host.
Its not clear right now if we could avoid this in the first place :
- We could arm RTO timer not at the time we enqueue packets, but
at the time we TX complete them (tcp_wfree())
- Cancel the sending of the new copy of the packet if prior one
is still in queue.
This patch adds instrumentation so that we can at least see how
often this problem happens.
TCPSpuriousRtxHostQueues SNMP counter is incremented every time
we detect the fast clone is not yet freed in tcp_transmit_skb()
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Willem de Bruijn <willemb@google.com>
This is the second of the TLP patch series; it augments the basic TLP
algorithm with a loss detection scheme.
This patch implements a mechanism for loss detection when a Tail
loss probe retransmission plugs a hole thereby masking packet loss
from the sender. The loss detection algorithm relies on counting
TLP dupacks as outlined in Sec. 3 of:
http://tools.ietf.org/html/draft-dukkipati-tcpm-tcp-loss-probe-01
The basic idea is: Sender keeps track of TLP "episode" upon
retransmission of a TLP packet. An episode ends when the sender receives
an ACK above the SND.NXT (tracked by tlp_high_seq) at the time of the
episode. We want to make sure that before the episode ends the sender
receives a "TLP dupack", indicating that the TLP retransmission was
unnecessary, so there was no loss/hole that needed plugging. If the
sender gets no TLP dupack before the end of the episode, then it reduces
ssthresh and the congestion window, because the TLP packet arriving at
the receiver probably plugged a hole.
This patch series implement the Tail loss probe (TLP) algorithm described
in http://tools.ietf.org/html/draft-dukkipati-tcpm-tcp-loss-probe-01. The
first patch implements the basic algorithm.
TLP's goal is to reduce tail latency of short transactions. It achieves
this by converting retransmission timeouts (RTOs) occuring due
to tail losses (losses at end of transactions) into fast recovery.
TLP transmits one packet in two round-trips when a connection is in
Open state and isn't receiving any ACKs. The transmitted packet, aka
loss probe, can be either new or a retransmission. When there is tail
loss, the ACK from a loss probe triggers FACK/early-retransmit based
fast recovery, thus avoiding a costly RTO. In the absence of loss,
there is no change in the connection state.
PTO stands for probe timeout. It is a timer event indicating
that an ACK is overdue and triggers a loss probe packet. The PTO value
is set to max(2*SRTT, 10ms) and is adjusted to account for delayed
ACK timer when there is only one oustanding packet.
TLP Algorithm
On transmission of new data in Open state:
-> packets_out > 1: schedule PTO in max(2*SRTT, 10ms).
-> packets_out == 1: schedule PTO in max(2*RTT, 1.5*RTT + 200ms)
-> PTO = min(PTO, RTO)
Conditions for scheduling PTO:
-> Connection is in Open state.
-> Connection is either cwnd limited or no new data to send.
-> Number of probes per tail loss episode is limited to one.
-> Connection is SACK enabled.
When PTO fires:
new_segment_exists:
-> transmit new segment.
-> packets_out++. cwnd remains same.
no_new_packet:
-> retransmit the last segment.
Its ACK triggers FACK or early retransmit based recovery.
ACK path:
-> rearm RTO at start of ACK processing.
-> reschedule PTO if need be.
In addition, the patch includes a small variation to the Early Retransmit
(ER) algorithm, such that ER and TLP together can in principle recover any
N-degree of tail loss through fast recovery. TLP is controlled by the same
sysctl as ER, tcp_early_retrans sysctl.
tcp_early_retrans==0; disables TLP and ER.
==1; enables RFC5827 ER.
==2; delayed ER.
==3; TLP and delayed ER. [DEFAULT]
==4; TLP only.
The TLP patch series have been extensively tested on Google Web servers.
It is most effective for short Web trasactions, where it reduced RTOs by 15%
and improved HTTP response time (average by 6%, 99th percentile by 10%).
The transmitted probes account for <0.5% of the overall transmissions.
Acked-by: Yuchung Cheng <ycheng@google.com>
Remove the check if x->km.state equal to XFRM_STATE_VALID in
xfrm_state_check_expire(), which will be done before call
xfrm_state_check_expire().
add a LINUX_MIB_XFRMOUTSTATEINVALID statistic to record the
outbound error due to invalid xfrm state.
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
