path: root/include/video
2008-08-12atmel_lcdfb: add board parameter specify framebuffer memory sizeHaavard Skinnemoen
Specify how much physically continuous, DMA capable memory will be allocated at driver initialization time. This allow to create framebuffer device with larger virtual resolution. Combine with y-panning this can be used to implement double buffering acceleration method. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12radeonfb: fix accel engine hangsDavid Miller
Some chips appear to have the 2D engine hang during screen redraw, typically in a sequence of copyarea operations. This appear to be solved by adding a flush of the engine destination pixel cache and waiting for the engine to be idle before issuing the accel operation. The performance impact seems to be fairly small. Here is a trace on an RV370 (PCI device ID 0x5b64), it records the RBBM_STATUS register, then the source x/y, destination x/y, and width/height used for the copy: ---------------------------------------- radeonfb_prim_copyarea: STATUS[00000140] src[210:70] dst[210:60] wh[a0:10] radeonfb_prim_copyarea: STATUS[00000140] src[2b8:70] dst[2b8:60] wh[88:10] radeonfb_prim_copyarea: STATUS[00000140] src[348:70] dst[348:60] wh[40:10] radeonfb_prim_copyarea: STATUS[80020140] src[390:70] dst[390:60] wh[88:10] radeonfb_prim_copyarea: STATUS[8002613f] src[40:80] dst[40:70] wh[28:10] radeonfb_prim_copyarea: STATUS[80026139] src[a8:80] dst[a8:70] wh[38:10] radeonfb_prim_copyarea: STATUS[80026133] src[e8:80] dst[e8:70] wh[80:10] radeonfb_prim_copyarea: STATUS[8002612d] src[170:80] dst[170:70] wh[30:10] radeonfb_prim_copyarea: STATUS[80026127] src[1a8:80] dst[1a8:70] wh[8:10] radeonfb_prim_copyarea: STATUS[80026121] src[1b8:80] dst[1b8:70] wh[88:10] radeonfb_prim_copyarea: STATUS[8002611b] src[248:80] dst[248:70] wh[68:10] ---------------------------------------- When things are going fine the copies complete before the next ROP is even issued, but all of a sudden the 2D unit becomes active (bit 17 in RBBM_STATUS) and the FIFO retry (bit 13) and FIFO pipeline busy (bit 14) are set as well. The FIFO begins to backup until it becomes full. What happens next is the radeon_fifo_wait() times out, and we access the chip illegally leading to a bus error which usually wedges the box. None of this makes it to the console screen, of course :-) radeon_fifo_wait() should be modified to reset the accelerator when this timeout happens instead of programming the chip anyways. ---------------------------------------- radeonfb: FIFO Timeout ! ERROR(0): Cheetah error trap taken afsr[0010080005000000] afar[000007f900800e40] TL1(0) ERROR(0): TPC[595114] TNPC[595118] O7[459788] TSTATE[11009601] ERROR(0): TPC<radeonfb_copyarea+0xfc/0x248> ERROR(0): M_SYND(0), E_SYND(0), Privileged ERROR(0): Highest priority error (0000080000000000) "Bus error response from system bus" ERROR(0): D-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000] ERROR(0): D-cache data0[0000000000000000] data1[0000000000000000] data2[0000000000000000] data3[0000000000000000] ERROR(0): I-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000] u[0000000000000000] l[00\ ERROR(0): I-cache INSN0[0000000000000000] INSN1[0000000000000000] INSN2[0000000000000000] INSN3[0000000000000000] ERROR(0): I-cache INSN4[0000000000000000] INSN5[0000000000000000] INSN6[0000000000000000] INSN7[0000000000000000] ERROR(0): E-cache idx[800e40] tag[000000000e049f4c] ERROR(0): E-cache data0[fffff8127d300180] data1[00000000004b5384] data2[0000000000000000] data3[0000000000000000] Ker:xnel panic - not syncing: Irrecoverable deferred error trap. ---------------------------------------- Another quirk is that these copyarea calls will not happen until the first drivers/char/vt.c:redraw_screen() occurs. This will only happen if you 1) VC switch or 2) run "consolechars" or 3) unblank the screen. This seems to happen because until a redraw_screen() the screen scrolling method used by fbcon is not finalized yet. I've seen this with other fb drivers too. So if all you do is boot straight into X you will never see this bug on the relevant chips. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-05radeon: misc correctionsDavid Miller
I have a new PCI-E radeon RV380 series card (PCI device ID 5b64) that hangs in my sparc64 boxes when the init scripts set the font. The problem goes away if I disable acceleration. I haven't figured out that bug yet, but along the way I found some corrections to make based upon some auditing. 1) The RB2D_DC_FLUSH_ALL value used by the kernel fb driver and the XORG video driver differ. I've made the kernel match what XORG is using. 2) In radeonfb_engine_reset() we have top-level code structure that roughly looks like: if (family is 300, 350, or V350) do this; else do that; ... if (family is NOT 300, OR family is NOT 350, OR family is NOT V350) do another thing; this last conditional makes no sense, is always true, and obviously was likely meant to be "family is NOT 300, 350, or V350". So I've made the code match the intent. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26include/video/atmel_lcdc.h must #include <linux/workqueue.h>Adrian Bunk
This patch fixes the following compile error caused by commit d22579b837358cbef12ccca5adaf7e93ae09ab7a ("atmel_lcdfb: FIFO underflow management"): In file included from arch/avr32/boards/atstk1000/atstk1004.c:21: include/video/atmel_lcdc.h:40: error: field 'task' has incomplete type Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24neofb: drop the xtimings structureKrzysztof Helt
Remove the xtimings structure which only stored some values to be used later (mostly once). Calculate and use these values in places they are needed. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24lcd: add platform_lcd driverBen Dooks
Add a platform_lcd driver to allow boards with simple lcd power controls to register themselves easily. [akpm@linux-foundation.org: build fix] Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24fb: add support for the ILI9320 video display controllerBen Dooks
Provide support for the ILI9320 display controller chip which is found in many LCD displays. Included with this is support for an example LCD using this chip, the VGG2432A4. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24atmel_lcdfb: FIFO underflow managementNicolas Ferre
Manage atmel_lcdfb FIFO underflow Resetting the LCD and DMA allows to fix screen shifting after a FIFO underflow. It follows reset sequence from errata "LCD Screen Shifting After a Reset". Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: add imageblit acceleration for Blade3D familyKrzysztof Helt
Add imageblit acceleration for the Blade3D family of cores. The code is based on code from the cyblafb driver. It is a step toward assimilating back the cyblafb driver into the tridentfb driver. The cyblafb driver handles a subfamily of the Trident Blade3d cores. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: source code improvementsKrzysztof Helt
This patch contains general source code improvments: - more simple functions are inline - removes some meaningless output and the VERSION string as it is no use - eng_par is moved into the tridentfb_par - removed small section of code for CyberBladeXPAi1 which is maybe right for only one resolution and refresh rate and is probably redundant now - other minor improvements Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: acceleration code improvementsKrzysztof Helt
This patch brings various acceleration improvements: - set copyarea/fillrect for non-accelerated framebuffer (fix) - remove 15 bpp depth handling to simplify code as it hardly works (15 bpp handling was obviously missing in some switches) - add fb_sync call and move waiting before accelerated function to make acceleration more asynchronous to cpu (few % of speed improvement) - add cpu_relax() call in waiting loops - make longer register names and name more registers - move registers' definition to header - general code improvements (shortening, simplifying) Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: add TGUI 9440 supportKrzysztof Helt
Add support for TGUI 9440 chip. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: improved register values on TGUI 9680Krzysztof Helt
Improved values for some registers after Xorg Trident driver. The main problem was that values set by BIOS have been ignored. This patch completely remove random pixels ("snow") on the TGUI 9680 and 9440 (not supported yet by the driver). It does not help with the "snow" on 3DImage and Blade3D cards. There is also small improvement in timing calculations (hblank start and vblank start) Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: make use of functions and constants from the vga.hKrzysztof Helt
Make use of functions and constants from the vga.h header to compact the code and make it more readable. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: convert is_blade and is_xp macros into functionsKrzysztof Helt
This patch converts the is_blade() and is_xp() macros into local functions. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: move global flat panel variable into structureKrzysztof Helt
This patch moves flat panel indicator into tridentfb_par structure and removes related global variables and macros. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: platforming hecubafb and n411Jaya Kumar
This patch splits hecubafb into the platform independent hecubafb and the platform dependent n411. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: platforming metronomefb and am200epdJaya Kumar
This patch splits metronomefb into the platform independent metronomefb and the platform dependent am200epd. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: wiring BGR to RGB color modeNicolas Ferre
Adds different wiring mode for the LCD screen. The legacy atmel LCDC IP uses a non standard color mode, "BGR-555.1" instead "RGB-565". The major part of graphic stacks for embedded systems uses only "RGB-565". It is possible to swap LCD IOs instead of doing this bit swapping by software (See application note AT91SAM9 LCD Controller http://www.atmel.com/dyn/resources/prod_documents/doc6300.pdf) This wire swapping is done on the at91sam9rl-ek board (board code using this patch will come later). Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <avictor.za@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: suspend/resume supportDavid Brownell
Teach atmel_lcdfb driver how to suspend/resume. Note that the backlight control should probably do more of the same stuff: turning off display power (more than just the backlight) and stopping the clocks (and dma to drive the no-longer-seen display). No point in wasting power to generate images that can't be observed, after all... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <avictor.za@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06atmel_lcdfb: backlight controlDavid Brownell
On the sam9 EK boards, the LCD backlight is hooked up to a PWM output from the LCD controller. It's controlled by "contrast" registers though. This patch lets boards declare that they have that kind of backlight control. The driver can then export this control, letting screenblank and other operations actually take effect ... reducing the typically substantial power drain from the backlight. Note that it's not fully cooked - doesn't force backlight off during system suspend - the "power" and "blank" events may not be done right This should be easily added in the future. [nicolas.ferre@atmel.com: remove unneeded inline and rename functions] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06atmel_lcdfb: validate display timingsHaavard Skinnemoen
Setting a display timing parameter too high or too low may cause it to wrap around and thus become completely wrong. Validate the timings in atmel_lcdfb_check_var() and saturate to the highest or lowest possible value if necessary. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23Make asm-x86/bootparam.h includable from userspace.Rusty Russell
To actually write a bootloader (or, say, the lguest launcher) currently requires duplication of these structures. Making them includable from userspace is much nicer. We merge the common userspace-required definitions of e820_32/64.h into e820.h for export. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: hardware cursor support for the Permedia2Krzysztof Helt
This patch adds hardware cursor support for the Permedia 2 chip. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: header file cleanupKrzysztof Helt
This patch fixes white spaces, redudant definitions and formating in the pm3fb header file. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: Permedia 2V hardware cursor supportKrzysztof Helt
This patch adds hardware cursor support for Permedia 2V chips. The hardware cursor is disabled by default. It does not blink - the same issue is mentioned in the x11 driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: mtrr supportKrzysztof Helt
This patch adds mtrr support to the tdfxfb driver. It also kills one redundant include and initialization value. [akpm@linux-foundation.org: cleanups] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: hardware cursorKrzysztof Helt
This patch adds hardware cursor support to the tdfxfb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: code improvementsKrzysztof Helt
This patch improves source code mainly by killing redundant variable loads, reducing number of variables, simplifying conditional branches, etc. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: coding style improvementKrzysztof Helt
This patch contains coding style improvements to the tdfxfb driver (white spaces, indentations, long lines). It also moves fb_ops structure to the end of file, so forward declarations of ops functions are redundant. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mbxfb: Improvements and new featuresRaphael Assenat
This contains the following changes: * Overlay surface alpha is configured separately from the overlay. This prevents display glitches (configure and fill the overlay first, set alpha to a visible value next) * Added an ioctl for configuring transparency of the Overlay and graphics planes. Blend mode, colorkey mode and global alpha mode are supported. * Added an ioctl for setting the plane order. The overlay plance can be placed over or under the graphics plane. * Added an ioctl for setting and reading chip registers, with mask. * Updated copyright for 2007 [adaplas] * Coding style changes Signed-off-by: Raphael Assenat <raph@8d.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: Permedia 2V initialization fixesKrzysztof Helt
This patch: - initializes correctly the Permedia2V chip if it is not initialized by BIOS - puts back clock frequency for the ELSA WINNER board to 100kHz - fixes returned error values from setcolreg() function - uses more general classes for PCI ids Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm2fb: accelerated imageblitKrzysztof Helt
This patch adds accelerated imageblit function. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: header file reductionKrzysztof Helt
This patch removes constants named AAA_DISABLE with value 0. They are redudant and misleading ( a |= AAA_DISABLE does nothing and usually should be a &= ~AAA_ENABLE). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: copyarea and partial imageblit supporKrzysztof Helt
This patch adds accelerated copyarea and partially accelerated imageblit functions. There is also fixed one register address in the pm3fb.h file. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uvesafb: the driver coreMichal Januszewski
uvesafb is an enhanced version of vesafb. It uses a userspace helper (v86d) to execute calls to the x86 Video BIOS functions. The driver is not limited to any specific arch and whether it works on a given arch or not depends on that arch being supported by the userspace daemon. It has been tested on x86_32 and x86_64. A single BIOS call is represented by an instance of the uvesafb_ktask structure. This structure contains a buffer, a completion struct and a uvesafb_task substructure, containing the values of the x86 registers, a flags field and a field indicating the length of the buffer. Whenever a BIOS call is made in the driver, uvesafb_exec() builds a message using the uvesafb_task substructure and the contents of the buffer. This message is then assigned a random ack number and sent to the userspace daemon using the connector interface. The message's sequence number is used as an index for the uvfb_tasks array, which provides a mapping from the messages coming from userspace to the in-kernel uvesafb_ktask structs. The userspace daemon performs the requested operation and sends a reply in the form of a uvesafb_task struct and, optionally, a buffer. The seq and ack numbers in the reply should be exactly the same as those in the request. Each message from userspace is processed by uvesafb_cn_callback() and after passing a few sanity checks leads to the completion of a BIOS call request. Signed-off-by: Michal Januszewski <spock@gentoo.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Paulo Marques <pmarques@grupopie.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31remove tx3912fbYoichi Yuasa
Remove tx3912fb. Nino has already removed. It is no longer needed. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17tgafb: actually allocate memory for the pseudo_paletteAntonino A. Daplas
No memory allocation was done for the pseudo_palette. Allocate one for it. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11atmel_lcdfb: AT91/AT32 LCD Controller framebuffer driverNicolas Ferre
Adds a framebuffer driver to ATMEL AT91SAM9x and AT32 aka AVR32 platforms. Those chips share quite the same IP and this code is suitable for both architectures. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11pm3fb: Preliminary 2.4 to 2.6 portKrzysztof Helt
This is a basic port from 2.4 kernel to 2.6. Acceleration is lost and big endian support probably too. The driver works in 8, 16 and 32 bit mode. [adaplas] - change VESA_* to FB_BLANK_* constants - removed unused function clear_memory - fix uninitialized variable compiler warning - some whitespace cleaning [akpm@linux-foundation.org: Nuke pestiferous CVS string] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: halve XCLK with Mobility and 32bit memoryVille Syrjala
Laptops with Rage Mobility and 32bit memory interface seem to require halved XCLK to operate correctly. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: Permedia 2V memory clock settingKrzysztof Helt
Permedia 2V uses its own registers to set a memory clock. The patch adds these registers and uses them in the set_memclock() function. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tgafb: TURBOchannel supportMaciej W. Rozycki
This is support for the TC variations of the TGA boards (properly known as SFB+ or Smart Frame Buffer Plus boards). The 8-plane SFB+ board uses the Bt459 RAMDAC (unlike its PCI TGA counterpart, which uses the Bt485), so bits have been added to support this chip as well. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: James Simmons <jsimmons@infradead.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Video: fb, add true ref_count atomicityJiri Slaby
Some of fb drivers uses atomic_t in bad manner, since there are still some race-prone gaps. Use mutexes to protect open/close code sections with ref_count testing and finally use simple uint. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Denis Oliver Kropp <dok@directfb.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] remove the broken FB_S3TRIO driverAdrian Bunk
The FB_S3TRIO driver: - has been marked as BROKEN for more than two years and - is still marked as BROKEN. Drivers that had been marked as BROKEN for such a long time seem to be unlikely to be revived in the forseeable future. But if anyone wants to ever revive this driver, the code is still present in the older kernel releases. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: James Simmons <jsimmons@infradead.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] sstfb: add sysfs interfaceHelge Deller
Modify the sstfb (Voodoo1/2) driver: - fix a memleak when removing the sstfb module - fix sstfb to use the fbdev default videomode database - add module option "mode_option" to set initial screen mode - add sysfs-interface to turn VGA-passthrough on/off via /sys/class/graphics/fbX/vgapass - remove old debug functions from ioctl interface Signed-off-by: Helge Deller <deller@gmx.de> Acked-By: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] video: pm3fb macros fixMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] mbxfb: Add YUV video overlay supportRaphael Assenat
This patch adds a way to create and use the video plane (YUV overlay) and scaling video scaling features of the chip. The overlay is configured, resized and modified using a device specific ioctl. Also included in this patch: - If no platform data was passed, print an error and exit instead of crashing. - Added a write_reg(_dly) macro. This improves readability when manipulating chip registers. (no more udelay() after each write). - Comments about some issues. Signed-off-by: Raphael Assenat <raph@8d.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
