Adds a global alpha parameter to each window. It provides a default
alpha value for pixel formats that do not include alpha.
Change-Id: I5465864877a727b4daed0eb32fb8219e2ccb663e
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/101806
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
This change adds a flag to flip windows in cursor mode. Cursor mode
will cause flips to be skipped over if there are newer flip requests
waiting in the workqueue.
Add CURSOR_MODE to caps bitfield.
bug 942762
Change-Id: Ib52a0a5565f961cdd9650e4204cd65b86f96fee1
Signed-off-by: Adam Cheney <acheney@nvidia.com>
Reviewed-on: http://git-master/r/90418
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Defines a new ioctl for querying a bitfield of DC capabilities.
The first defined caps bit is for "cursor mode" flipping support.
bug 942631
Change-Id: Iea8a0dfe4e400e0dad4bb9f23509c3ac0ca532ba
Reviewed-on: http://git-master/r/87066
Tested-by: Adam Cheney <acheney@nvidia.com>
This adds flags for horizontal and vertical surface mirroring,
and updates the ioctl handling code to set the appropriate core
dc mirroring flags when the dc_ext mirroring flags are passed.
Bug 905578
Change-Id: Idbe0c95cb0807aa9e26ccfdc42cf4ef0dc9eb38f
Reviewed-on: http://git-master/r/64110
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Tested-by: Michael Frydrych <mfrydrych@nvidia.com>
Reviewed-by: Markus Holtmanns <mholtmanns@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Rebase-Id: R5795faa3988df9f87e669f40aab9b0281111a4b0
This adds a new flags field to the dc_ext flip ioctl, adds a flag for
tiled surfaces, and updates the ioctl handling code to set the
appropriate core dc tiling flag when the dc_ext tiled flag is passed.
Bug 831397
Change-Id: I36cbf4a59173885a98209e559f77404bddcf54cd
Reviewed-on: http://git-master/r/64109
Rebase-Id: Rf741be9e6945b6b92699e26fb1745fafef4d8fe4
Add support to set a global gamma correction table via fbdev cmap
API. The 3 Tegra DC windows have their own local gamma tables, which
can either override or alter the global table.
Bug 868060
Change-Id: I0be1c5e4afa8fd8c010b772c7808c883c0848ab4
Reviewed-on: http://git-master/r/60201
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R7e613b1c8ac469242172bd81db9dfba25176e0c3
- enable gamma look-up hardware only when needed to save power
- add flags field to ioctl TEGRA_DC_EXT_SET_LUT for forward compatibility
Bug 868060
Change-Id: I690f8b8856e0b1acd6215907ca8bd78ecaf30b17
Reviewed-on: http://git-master/r/57736
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
Rebase-Id: Rf6081a9372ba7d6e53a66b9b58a50a62ad409d9a
Adds ioctl TEGRA_DC_EXT_SET_LUT to dc_ext driver for setting
a DC window's color palette.
Bug 868060
Change-Id: I57ffcf3a3f91e76efd1c7f1f972b73c2edbaed82
Reviewed-on: http://git-master/r/56392
Rebase-Id: R712c71151d0c3e3d274279f334bedf312e26e75d
This change implements the TEGRA_DC_EXT_CONTROL_GET_OUTPUT_EDID ioctl in
the dc_ext interface.
It first adds a way for the tegra dc EDID module to export EDID data
safely, without the risk of reading an incomplete or corrupted EDID in
the presence of hotplug, by moving the actual data to a substructure
with a lifetime maintained by a kref. Then, that support is plumbed
through the hdmi block (which is currently the only way to get at the
EDID) and out to userspace.
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Bug 817119
Original-Change-Id: I78cd170e15322011b428cb71ffad2c0c3ea058ac
Reviewed-on: http://git-master/r/49127
Rebase-Id: Rafafc0a6fbacda5494b12162ad99a8c70ceeb2e0
Currently, dc_ext only takes a single nvmap memory ID per overlay, even
in the YUV case (the U and V planes are expected to be differentiated
using an offset from the beginning of the nvmap allocation).
This is problematic for some software flows, such as certain video
interlacing algorithms that will vary the luma plane while keeping the
chrome plane constant.
This change allows dc_ext clients to specify a different nvmap
allocation for each of the Y, U, and V planes. If a YUV surface is
used and no U or V plane allocation is specified, the old behavior is
preserved: the U and V offsets are assumed to be within the same
allocation as Y.
Note: this changes the behavior of the offset parameter: the old code
added offset to offset_u and offset_v when using it. The new code
treats all three offsets as relative to the beginning of the allocation.
It also fixes a bug in the code where offset was applied twice to the Y
plane. I believe this is safe because the presence of this bug means
that no existing clients are using offset != 0 (or if they are, they're
already broken).
Bug 850882
Original-Change-Id: I230e03db25baaae73a3bdc0d45a2aec162b87fa4
Reviewed-on: http://git-master/r/41471
Rebase-Id: Ra6dd17a50de7150edf104d2a6c9b3b9949919022
This change adds a new tegra_dc_ext ioctl to allow userspace to query
whether a head is currently enabled or not. This is necessary for the X
server to be able to restore the outputs that were enabled before it was
started.
bug 818525
Original-Change-Id: I6d209894081312621f623a722cdd3fcb53553c61
Reviewed-by: Aaron Plattner <aplattner@nvidia.com>
Reviewed-by: Olof Johansson <olofj@chromium.org>
Reviewed-on: http://git-master/r/40530
Rebase-Id: Re42eae066099587529fbcc677c06ddefef18d36d
This change adds support for userspace to query the syncpoint that
display autoincrements every vblank. This can be useful for
applications to time buffer submissions to throttle rendering and
prevent excessive host stalls.
bug 818525
Original-Change-Id: I050e4dcd08609da802f10eeec5b70da181b21717
Reviewed-on: http://git-master/r/40529
Rebase-Id: Rac929d8ba6b14e469fef4c2753b040e02fae0b8e
This change adds support for userspace to query which heads an output
may be bound to. Since our implementation currently hardcodes the head
to output mapping, we currently always fill in a single bit. However,
for future implementations we will be able to dynamically bind outputs
to heads.
bug 818525
Original-Change-Id: Ib0dead7748620a538c8f8d6ef548ca8b13a9c2b2
Reviewed-on: http://git-master/r/40528
Rebase-Id: R524f90dca82a3a67fa3289a3ebc4c7e32716749b
This adds configurability of the per-window color space conversion
support in the Tegra display controller through the dc extension
interface. The CSC matrix defaults to its previously-hardcoded values,
but can be overridden by userspace.
bug 818525
Original-Change-Id: I00d8e48dd38a40e5b8c36d4624d31c834e5cd9de
Reviewed-on: http://git-master/r/40527
Rebase-Id: R1f445ab544b4c06f56dde1e3f0e9db3c930a9c14
This change makes the input rect for Tegra windows be a 20.12
fixed-point number instead of an integer. This allows software to
specify sub-pixel precision.
bug 818525
Original-Change-Id: I130f63b68159ed896d1113ea537307997875ca40
Reviewed-on: http://git-master/r/40526
Rebase-Id: R848e901645aa49776d4dc41fa4210b6b594a8d84
This device exposes control over everything that's not specific to one
of T20's two display controllers. It supports:
- output devices
- event delivery
- hotplug events
bug 818525
Original-Change-Id: I3a46f1dddc483b08ed3ee91a4f9c64111c1fd7eb
Reviewed-on: http://git-master/r/40520
Rebase-Id: R9e49fe41f3327b797ec65c3729f4f94edbb45307
This change adds full support for specify the cursor image and
manipulating its position.
bug 818525
Original-Change-Id: I101a951aff358b0ac0998afc6fe5f6c5c4d37c64
Reviewed-on: http://git-master/r/40518
Rebase-Id: R93f0c68a14e4419f200a77d48a17eb8862f2e4e1
This is necessary so that multiple clients can open /dev/fb* at the same
time. The functionaly has been moved to the dc extension device nodes.
bug 818525
Original-Change-Id: I299e060fce3bb9e3cbf976f3d94dbabc4b3f1654
Reviewed-on: http://git-master/r/40515
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Rebase-Id: R32908db3f1e344eea13d628f0341600ed698783d
This is very similar to the tegra_fb FLIP ioctl.
bug 818525
Original-Change-Id: Iba32ab5bf730b575477c62a8ae4394f1779ef65e
Reviewed-on: http://git-master/r/40514
Rebase-Id: R9a79363b09d2df38bec4b8a8666f97b1feff76ff
This implements:
- GET_WINDOW
- PUT_WINDOW
and adds a stub for FLIP.
bug 818525
Original-Change-Id: I467b58a77242b2a8077e236106b542b8545f5353
Reviewed-on: http://git-master/r/40513
Rebase-Id: R4fc354fdae76f3eac189d481fb346a0982146db5
Change-Id: I82497fc756552740836eaa2f608fecaea409cfeb
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Change-Id: Ied3851e0cb801f607499493f1e552f42daa97e6b
Signed-off-by: Ari Hirvonen <ahirvonen@nvidia.com>
Device /dev/nvhdcpX is used to manage NVHDCP on framebuffer /dev/fbX.
These devices are created on hdmi driver initialition when it is
attached to dc. Currently only one nvhdcp device may be created. An ioctl
interface is in video/nvhdcp.h
Check for repeaters and store repeater info. userspace application
queries this status to authenticate the connection. When authentication
fails, auto-renegotiate every 1.75 seconds. Give up after 5 failed attempts,
reset after hotplug or policy change.
use TEGRA_DC_OUT_NVHDCP_POLICY_ON_DEMAND in tegra_dc_out.flags in board
panel configuration to select a different default policy at probe. Currently
only TEGRA_DC_OUT_NVHDCP_POLICY_ALWAYS_ON is supported.
Change-Id: I0db66fc86096b98d2604544061721d291523de75
Tested-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Phillip Smith <psmith@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Signed-off-by: Erik Gilling <konkers@android.com>
Change-Id: I4bed4d37bc275cca9ef69390c217498529121db0
Change-Id: Ic312271b96a8bb8d8b2696448d3ff7fd73a7a851
includes changes by:
Antti Hatala <ahatala@nvidia.com> (1)
Gary King <gking@nvidia.com> (1)
Erik Gilling <konkers@android.com> (2)
video: tegra: dc: use nvhost driver for host1x power management
video: tegra: fb: add ioctl to flip dc windows to nvmap handles
video: tegra: dc: increment syncpoints following window flips
video: tegra: drain syncpt waits on display disable
Original commit messages:
Incrementing the frame done syncpoint value from the display interrupt
requires that the host module is powered on. As the syncpoint state is
saved and restored automatically by the host driver a cpu increment of
a syncpoint in the powered down state will be lost.
Also adds checks for host module being powered.
tegra user-space graphics drivers may allocate framebuffers using
nvmap rather than rendering to the common framebuffer, this may
be done to support deeper buffer pipelining, color formats
and pixel layouts other than the initial bootup framebuffer,
etc.
to use this ioctl, a caller must first specify an nvmap fd
which is already open in the calling process so that the
subsequent flip ioctls may be properly validated. flips are performed
asynchronously, with flip completion notifications provided back to
the caller via the host1x syncpoint mechanism
based on earlier changes made by Antti Hatala <ahatala@nvidia.com>
and Erik Gilling <konkers@android.com>
Change-Id: I4e8a8bb92085a485d65fd87d89112b2969ee37ff
Signed-off-by: Gary King <gking@nvidia.com>
opt_clock_available() is no longer needed, so remove it.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The function to get device's context loss count has changed from
omap_pm_get_last_off_on_transaction_id() to
omap_pm_get_dev_context_loss_count()
Change name of the function pointer in omapdss.h accordingly, and use
the term "context loss count" instead of "context id" in the code.
Restructure the context loss count functions to handle errors properly,
and ensure that context is always considered lost if an error happens.
Add Color Phase Rotation (CPR) support and sysfs files to enable CPR and
to set the CPR coefficient matrix.
CPR is enabled via manager?/cpr_enable file, and the coefficient matrix
is set via manager?/cpr_coef file. The values in cpr_coef are in the
following order:
RR RG RB GR GG GB BR BG BB
Remove the whole update_mode stuff from omapdss driver. If automatic
update for manual update displays is needed, it's better implemented in
higher layers.
omapdss.h included platform_device.h and atomic.h, neither of which is
needed by omapdss.h. Remove those includes from omapdss.h, and fix the
affected .c files which did not include platform_device.h even though
they should.
master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6
drivers/video/omap2/dss/dsi.c
drivers/video/omap2/dss/dss_features.c
drivers/video/omap2/dss/dss_features.h
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Since the NV24 framebuffer has a CbCr plane that is twice as wide
as the Y plane, it needs to be handled as a special case.
Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp>
Based on the patch by Takanari Hayama <taki@igel.co.jp>
Adds support framework necessary to use Media RAM (MERAM)
caching functionality with the LCDC. The MERAM is accessed
through up to 4 Interconnect Buffers (ICBs).
ICB numbers and MERAM address ranges to use are specified in
by filling in the .meram_cfg member of the LCDC platform data
Add the support for NV12 color format.
Configure base address for UV component of NV12 color format.
Change the way chroma scaling is handled for YUV formats on OMAP4 by enabling
chroma-resampling for video pipeline and hence using FIR2 register set for
scaling UV.
Changes to _dispc_set_scaling(), because of the reason above, are:
- call _dispc_set_scaling_common() to handle scaling for all color formats
except for OMAP4 where it only handles scaling for RGB or Y-component
- call _dispc_set_scaling_uv() for special handling required for UV
component on OMAP4.
- dispc_set_scaling_uv() also resets chroma-resampling bit for RGB color modes.
Contains chroma scaling (_dispc_set_scaling_uv) design and implemented by
Lajos Molnar <molnar@ti.com>
Signed-off-by: Amber Jain <amber@ti.com>
Add new color formats supported by OMAP4: NV12, RGBA16, RGBX16,
ARGB16_1555, XRGB16_1555.
NV12 color format is defined here, its support in DSS will be added separately.
On OMAP3, the DSI module has 2 data lanes. On OMAP4, DSI1 has 4 data lanes
and DSI2 has 2 data lanes. Introduce function dsi_get_num_data_lanes() which
returns the number of data lanes on the dsi interface, introduce function
dsi_get_num_data_lanes_dssdev() which returns the number of data lanes used by
the omap_dss_device connected to the lanes.
Use the DSI_GNQ register on OMAP4 to get the number of data lanes, modify
dsi.c to use the number of lanes and the extra data lanes on DSI1.
Signed-off-by: Archit Taneja <archit@ti.com>
Add omap_rfbi_configure() which the panel driver can use to reconfigure
the data element size and the number of data lines in the RFBI bus.
Add similar bus lock to RFBI as is in DSI. The panel driver can use the
bus lock to mark that the RFBI bus is currently in use.
Introduce DSI2 PLL clock sources needed by LCD2 channel and DSI2 Protocol
engine and DISPC Functional clock. Do the following:
- Modify dss_get_dsi_clk_source() and dss_select_dsi_clk_source() to take the
dsi module number as an argument.
- Create debugfs files for dsi2, split the corresponding debugfs functions.
- Allow DPI to use these new clock sources.
The DSI interface is represented as a platform device, using the DSI platform
driver(dsi.c). The current DSI driver design is capable of running only one
instance of a DSI device. On OMAP4, there are 2 very similar DSI modules which
can be represented as instances of "omapdss_dsi" platform device.
Add member "module" in "dssdev.phy.dsi" that tells us which DSI module's lanes
the panel is connected to. Modify dsi.c functions to take the device's
platform_device struct pointer, provide functions dsi_get_dsidev_from_dssdev()
and dsi_get_dsidev_from_id() take the panel's omap_dss_device and module number
respectively, and return the platform_device pointer. Currently, the dsi struct
is declared globally and is accessed when dsi data is needed. The new pdev
argument will be used later to provide the platform device's dsi related data.
Add pointer to omap_dss_device struct as an argument in the functions which
are exported to dsi panel drivers. This argument will tell the DSI driver
which DSI interface's data it has to choose.
ULPS is a low power state where the DSI lanes are kept at ground. This
patch implements ULPS by having a DSI bus inactivity timer which
triggers the entry to ULPS. ULPS exit will happen automatically when the
driver needs to do something on the DSI lanes.
The ulps_timeout is configurable from board file or via sysfs.
Additionally another sysfs file, "ulps", can be used to check the
current ULPS state, or to manually enter or exit ULPS.
ESD check in Taal driver is currently on/off feature with hardcoded
interval. This patch changes it to a configurable interval, which can be
set from the board file.
Add dsi_mux_pads function pointer to omap_dss_board_info, and use the
function pointer in DSI code to configure the DSI pads either to normal
DSI operation, or to pull down when in ULPS.
Add parameter to omapdss_dsi_display_disable() which the panel driver
can use to tell if the DSI lanes should be put to ULPS before disabling
the interface.
This can be used to skip ULPS entry in cases where the panel doesn't
care about ULPS state, for example when the panel will be reset, or when
the display interface will be enabled again right after the disable.
This will speed up the operation considerably in cases where entering
ULPS would fail with timeout, and the panel driver isn't even interested
in entering ULPS.
The DSI pins are powered by VDDS_DSI. If VDDS_DSI is off, the DSI pins
are floating even if they are pinmuxed to, say, safe mode and there's a
pull down/up.
This patch gives the panel drivers an option to leave the VDDS_DSI power
enabled while the DSS itself is turned off. This can be used to keep the
DSI lanes in a valid state while DSS is off, if the DSI pins are muxed
for pull down (not done in this patch).
There will be a slight power consumption increase (~100 uA?) when the
VDDS_DSI is left on, but because this option is used when the panel is
left on, the regulator consumption is negligible compared to panel power
consumption.
When the panel is fully turned off the VDDS_DSI is also turned off.
As an added bonus this will give us faster start up time when starting
up the DSS and the regulator is already enabled.
Move some of the configurable HDMI PLL parameters to dssdev.clock struct.
Cleanup the function hdmi_compute_pll() by using the parameters defined in the
board file and do some cosmetic modifications.
Add enum dss_clock_source in dssdev.clocks struct so that the clock sources can
be specified in the board file.
Replace hard coded clock sources in dsi.c, dpi.c and replace them with the new
clock source members in dssdev.clocks. Modify the sdp4430_lcd_device struct in
board-4430sdp.c to specify clock sources for DISPC_FCLK, LCD1_CLK and DSI1_FCLK.
