Implement xen_register_gsi to setup the correct triggering and polarity
properties of a gsi.
Implement xen_register_pirq to register a particular gsi as pirq and
receive interrupts as events.
Call xen_setup_pirqs to register all the legacy ISA irqs as pirqs.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Map MSIs into pirqs, writing 0 in the MSI vector data field and the pirq
number in the MSI destination id field.
Disable pcifront when running on HVM: it is meant to be used with pv
guests that don't have PCI bus.
Use acpi_register_gsi_xen_hvm to remap GSIs into pirqs.
xen_hvm_register_pirq allows the kernel to map a GSI into a Xen pirq and
receive the interrupt as an event channel from that point on.
Use PHYSDEVOP_get_nr_pirqs to get the maximum number of pirqs from xen.
PHYSDEVOP_map_pirq might return a pirq different from what we asked if
we are running as an HVM guest, so we need to be able to support pirqs
that are different from linux irqs.
Rather than simply using a flat memory map from Xen, use its provided
E820 map. This allows the domain builder to tell the domain to reserve
space for more pages than those initially provided at domain-build time.
It also allows the host to specify holes in the address space (for
PCI-passthrough, for example).
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
This allows xenfs to be built as a module, previously it required flush_tlb_all
and arbitrary_virt_to_machine to be exported.
The privcmd interface in xenfs allows the tool stack in the privileged
domain to get fairly direct access to the hypervisor in order to do
various management things such as domain construction.
[ Impact: new xenfs interface for privileged operations ]
This is a port of the 2.6.18 Xen PCI front driver with fixes
to make it build under 2.6.34 and later (for the full list of
changes: git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen.git
historic/xen-pcifront-0.1). It also includes the fixes
to make it work properly.
[v2: Updated Kconfig, removed crud, added Reviewed-by]
[v3: Added 'static', fixed grant table leak, redid Kconfig]
[v4: Added one more 'static' and removed comments]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Jan Beulich <JBeulich@novell.com>
The Xen PCI front driver adds two new states that are utilizez
for PCI hotplug support. This is a patch pulled from the
linux-2.6-xen-sparse tree.
Signed-off-by: Noboru Iwamatsu <n_iwamatsu@jp.fujitsu.com>
Signed-off-by: Yosuke Iwamatsu <y-iwamatsu@ab.jp.nec.com>
The frontend stub lives in arch/x86/pci/xen.c, alongside other
sub-arch PCI init code (e.g. olpc.c).
It provides a mechanism for Xen PCI frontend to setup/destroy
legacy interrupts, MSI/MSI-X, and PCI configuration operations.
[ Impact: add core of Xen PCI support ]
[ v2: Removed the IOMMU code and only focusing on PCI.]
[ v3: removed usage of pci_scan_all_fns as that does not exist]
[ v4: introduced pci_xen value to fix compile warnings]
[ v5: squished fixes+features in one patch, changed Reviewed-by to Ccs]
[ v7: added Acked-by]
Signed-off-by: Alex Nixon <alex.nixon@citrix.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Qing He <qing.he@intel.com>
Cc: x86@kernel.org
In driver/xen/events.c, whether bind_pirq is shareable or not is
determined by desc->action is NULL or not. But in __setup_irq,
startup(irq) is invoked before desc->action is assigned with
new action. So desc->action in startup_irq is always NULL, and
bind_pirq is always not shareable. This results in pt_irq_create_bind
failure when passthrough a device which shares irq to other devices.
This patch doesn't use probing_irq to determine if pirq is shareable
or not, instead set shareable flag in irq_info according to trigger
mode in xen_allocate_pirq. Set level triggered interrupts shareable.
Thus use this flag to set bind_pirq flag accordingly.
[v2: arch/x86/xen/pci.c no more, so file skipped]
Signed-off-by: Weidong Han <weidong.han@intel.com>
The 'xen_poll_irq_timeout' provides a method to pass in
the poll timeout for IRQs if requested. We also export
those two poll functions as Xen PCI fronted uses them.
Impact: cleanup
Make pirq show useful information in /proc/interrupts
[v2: Removed the parts for arch/x86/xen/pci.c ]
Signed-off-by: Gerd Hoffmann <kraxel@xeni.home.kraxel.org>
A privileged PV Xen domain can get direct access to hardware. In
order for this to be useful, it must be able to get hardware
interrupts.
Being a PV Xen domain, all interrupts are delivered as event channels.
PIRQ event channels are bound to a pirq number and an interrupt
vector. When a IO APIC raises a hardware interrupt on that vector, it
is delivered as an event channel, which we can deliver to the
appropriate device driver(s).
This patch simply implements the infrastructure for dealing with pirq
event channels.
[ Impact: integrate hardware interrupts into Xen's event scheme ]
by defining in terms of (1<<N).
XEN_UNPLUG_UNNECESSARY and XEN_UNPLUG_NEVER are only used within the
kernel and are not defined as a bit on the unplug IO port. Therefore
use a bit which is outside the potentially valid range of the 16 bit
IO port.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Stefano Stabellini <Stefano.Stabellini@eu.citrix.com>
It is not immediately clear what this option causes to become
ignored. The actual meaning is that it is not necessary to unplug the
emulated devices to safely use the PV ones, even if the platform does
not support the unplug protocol. (pressumably the user will only add
this option if they have ensured that their domain configuration is
safe).
I think xen_emul_unplug=unnecessary better captures this.
this allows the user to disable pvhvm and revert to emulated devices
in case of a system misconfiguration (e.g. initramfs with only
emulated drivers in it).
* 'stable/xen-swiotlb-0.8.6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
x86: Detect whether we should use Xen SWIOTLB.
pci-swiotlb-xen: Add glue code to setup dma_ops utilizing xen_swiotlb_* functions.
swiotlb-xen: SWIOTLB library for Xen PV guest with PCI passthrough.
xen/mmu: inhibit vmap aliases rather than trying to clear them out
vmap: add flag to allow lazy unmap to be disabled at runtime
xen: Add xen_create_contiguous_region
xen: Rename the balloon lock
xen: Allow unprivileged Xen domains to create iomap pages
xen: use _PAGE_IOMAP in ioremap to do machine mappings
Fix up trivial conflicts (adding both xen swiotlb and xen pci platform
driver setup close to each other) in drivers/xen/{Kconfig,Makefile} and
include/xen/xen-ops.h
This patchset:
PV guests under Xen are running in an non-contiguous memory architecture.
When PCI pass-through is utilized, this necessitates an IOMMU for
translating bus (DMA) to virtual and vice-versa and also providing a
mechanism to have contiguous pages for device drivers operations (say DMA
operations).
Specifically, under Xen the Linux idea of pages is an illusion. It
assumes that pages start at zero and go up to the available memory. To
help with that, the Linux Xen MMU provides a lookup mechanism to
translate the page frame numbers (PFN) to machine frame numbers (MFN)
and vice-versa. The MFN are the "real" frame numbers. Furthermore
memory is not contiguous. Xen hypervisor stitches memory for guests
from different pools, which means there is no guarantee that PFN==MFN
and PFN+1==MFN+1. Lastly with Xen 4.0, pages (in debug mode) are
allocated in descending order (high to low), meaning the guest might
never get any MFN's under the 4GB mark.
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Albert Herranz <albert_herranz@yahoo.es>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
When a pagetable is about to be destroyed, we notify Xen so that the
hypervisor can clear the related shadow pagetable.
Add a xen_emul_unplug command line option to the kernel to unplug
xen emulated disks and nics.
Set the default value of xen_emul_unplug depending on whether or
not the Xen PV frontends and the Xen platform PCI driver have
been compiled for this kernel (modules or built-in are both OK).
The user can specify xen_emul_unplug=ignore to enable PV drivers on HVM
even if the host platform doesn't support unplug.
Use xen_vcpuop_clockevent instead of hpet and APIC timers as main
clockevent device on all vcpus, use the xen wallclock time as wallclock
instead of rtc and use xen_clocksource as clocksource.
The pv clock algorithm needs to work correctly for the xen_clocksource
and xen wallclock to be usable, only modern Xen versions offer a
reliable pv clock in HVM guests (XENFEAT_hvm_safe_pvclock).
Using the hpet as clocksource means a VMEXIT every time we read/write to
the hpet mmio addresses, pvclock give us a better rating without
VMEXITs. Same goes for the xen wallclock and xen_vcpuop_clockevent
Signed-off-by: Don Dutile <ddutile@redhat.com>
Suspend/resume requires few different things on HVM: the suspend
hypercall is different; we don't need to save/restore memory related
settings; except the shared info page and the callback mechanism.
Add the xen pci platform device driver that is responsible
for initializing the grant table and xenbus in PV on HVM mode.
Few changes to xenbus and grant table are necessary to allow the delayed
initialization in HVM mode.
Grant table needs few additional modifications to work in HVM mode.
The Xen PCI platform device raises an irq every time an event has been
delivered to us. However these interrupts are only delivered to vcpu 0.
The Xen PCI platform interrupt handler calls xen_hvm_evtchn_do_upcall
that is a little wrapper around __xen_evtchn_do_upcall, the traditional
Xen upcall handler, the very same used with traditional PV guests.
When running on HVM the event channel upcall is never called while in
progress because it is a normal Linux irq handler (and we cannot switch
the irq chip wholesale to the Xen PV ones as we are running QEMU and
might have passed in PCI devices), therefore we cannot be sure that
evtchn_upcall_pending is 0 when returning.
For this reason if evtchn_upcall_pending is set by Xen we need to loop
again on the event channels set pending otherwise we might loose some
event channel deliveries.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
Set the callback to receive evtchns from Xen, using the
callback vector delivery mechanism.
The traditional way for receiving event channel notifications from Xen
is via the interrupts from the platform PCI device.
The callback vector is a newer alternative that allow us to receive
notifications on any vcpu and doesn't need any PCI support: we allocate
a vector exclusively to receive events, in the vector handler we don't
need to interact with the vlapic, therefore we avoid a VMEXIT.
A memory region must be physically contiguous in order to be accessed
through DMA. This patch adds xen_create_contiguous_region, which
ensures a region of contiguous virtual memory is also physically
contiguous.
Based on Stephen Tweedie's port of the 2.6.18-xen version.
Remove contiguous_bitmap[] as it's no longer needed.
Ported from linux-2.6.18-xen.hg 707:e410857fd83c
[ Impact: add Xen-internal API to make pages phys-contig ]
* xen_create_contiguous_region needs access to the balloon lock to
ensure memory doesn't change under its feet, so expose the balloon
lock
* Change the name of the lock to xen_reservation_lock, to imply it's
now less-specific usage.
[ Impact: cleanup ]
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Move xen_domain and related tests out of asm-x86 to xen/xen.h so they
can be included whenever they are necessary.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
'for-linus/xen/xenfs' and 'for-linus/xen/sys-hypervisor' into for-linus/xen/master
* for-linus/xen/dev-evtchn:
xen/dev-evtchn: clean up locking in evtchn
xen: export ioctl headers to userspace
xen: add /dev/xen/evtchn driver
xen: add irq_from_evtchn
* for-linus/xen/xenbus:
xen/xenbus: export xenbus_dev_changed
xen: use device model for suspending xenbus devices
xen: remove suspend_cancel hook
* for-linus/xen/xenfs:
xen: add "capabilities" file
* for-linus/xen/sys-hypervisor:
xen: drop kexec bits from /sys/hypervisor since kexec isn't implemented yet
xen/sys/hypervisor: change writable_pt to features
xen: add /sys/hypervisor support
drivers/xen/Makefile
Adds support for Xen info under /sys/hypervisor. Taken from Novell 2.6.27
backport tree.
Remove suspend_cancel hook from xenbus_driver, in preparation for using
the device model for suspending.
This driver is used by application which wish to receive notifications
from the hypervisor or other guests via Xen's event channel
mechanism. In particular it is used by the xenstore daemon in domain
0.
Given an evtchn, return the corresponding irq.
The xenfs filesystem exports various interfaces to usermode. Initially
this exports a file to allow usermode to interact with xenbus/xenstore.
Traditionally this appeared in /proc/xen. Rather than extending procfs,
this patch adds a backward-compat mountpoint on /proc/xen, and provides
a xenfs filesystem which can be mounted there.
Signed-off-by: Alex Zeffertt <alex.zeffertt@eu.citrix.com>
Impact: cleanup
hypervisor.h had accumulated a lot of crud, including lots of spurious
#includes. Clean it all up, and go around fixing up everything else
accordingly.
The balloon driver doesn't have any externally callable functions at
the moment, so remove the (effectively empty) header. We can add it
back if we need to.
A spinlock can be interrupted while spinning, so make sure we preserve
the previous lock of interest if we're taking a lock from within an
interrupt handler.
We also need to deal with the case where the blocking path gets
interrupted between testing to see if the lock is free and actually
blocking. If we get interrupted there and end up in the state where
the lock is free but the irq isn't pending, then we'll block
indefinitely in the hypervisor. This fix is to make sure that any
nested lock-takers will always leave the irq pending if there's any
chance the outer lock became free.
Acked-by: Jan Beulich <jbeulich@novell.com>
The standard ticket spinlocks are very expensive in a virtual
environment, because their performance depends on Xen's scheduler
giving vcpus time in the order that they're supposed to take the
spinlock.
This implements a Xen-specific spinlock, which should be much more
efficient.
The fast-path is essentially the old Linux-x86 locks, using a single
lock byte. The locker decrements the byte; if the result is 0, then
they have the lock. If the lock is negative, then locker must spin
until the lock is positive again.
When there's contention, the locker spin for 2^16[*] iterations waiting
to get the lock. If it fails to get the lock in that time, it adds
itself to the contention count in the lock and blocks on a per-cpu
event channel.
When unlocking the spinlock, the locker looks to see if there's anyone
blocked waiting for the lock by checking for a non-zero waiter count.
If there's a waiter, it traverses the per-cpu "lock_spinners"
variable, which contains which lock each CPU is waiting on. It picks
one CPU waiting on the lock and sends it an event to wake it up.
This allows efficient fast-path spinlock operation, while allowing
spinning vcpus to give up their processor time while waiting for a
contended lock.
[*] 2^16 iterations is threshold at which 98% locks have been taken
according to Thomas Friebel's Xen Summit talk "Preventing Guests from
Spinning Around". Therefore, we'd expect the lock and unlock slow
paths will only be entered 2% of the time.
Cc: Christoph Lameter <clameter@linux-foundation.org>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Virtualization <virtualization@lists.linux-foundation.org>
Cc: Xen devel <xen-devel@lists.xensource.com>
Cc: Thomas Friebel <thomas.friebel@amd.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
fix:
arch/x86/xen/built-in.o: In function `set_page_prot':
enlighten.c:(.text+0x111d): undefined reference to `xen_raw_printk'
arch/x86/xen/built-in.o: In function `xen_start_kernel':
: undefined reference to `xen_raw_console_write'
Copy 64-bit definitions of various interface structures into place.
Cc: Stephen Tweedie <sct@redhat.com>
Cc: Eduardo Habkost <ehabkost@redhat.com>
Cc: Mark McLoughlin <markmc@redhat.com>
add xen_timer_resume() hook.
Timer resume should be done after event channel is resumed.
add xen_arch_resume() hook when ipi becomes usable after resume.
After resume, some cpu specific resource must be reinitialized
on ia64 that can't be set by another cpu.
However available hooks is run once on only one cpu so that ipi has
to be used.
During stop_machine_run() ipi can't be used because interrupt is masked.
So add another hook after stop_machine_run().
Another approach might be use resume hook which is run by
device_resume(). However device_resume() may be executed on
suspend error recovery path.
So it is necessary to determine whether it is executed on real resume path
or error recovery path.
Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp>
Xen has a pte update function which will update a pte while preserving
its accessed and dirty bits. This means that ptep_modify_prot_start() can be
implemented as a simple read of the pte value. The hardware may
update the pte in the meantime, but ptep_modify_prot_commit() updates it while
preserving any changes that may have happened in the meantime.
The updates in ptep_modify_prot_commit() are batched if we're currently in lazy
mmu mode.
The mmu_update hypercall can take a batch of updates to perform, but
this code doesn't make particular use of that feature, in favour of
using generic multicall batching to get them all into the hypervisor.
The net effect of this is that each mprotect pte update turns from two
expensive trap-and-emulate faults into they hypervisor into a single
hypercall whose cost is amortized in a batched multicall.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Hugh Dickins <hugh@veritas.com>
arch/x86/xen/enlighten.c
arch/x86/xen/mmu.c
This patch updates the xen guest to use the pvclock structs
and helper functions.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
