path: root/include
2009-08-12 ENGR00114284: MX51: Add IPU interlace support in 2 more motion algorithmsRan Ferderber
Add algorithms for medium and low motion streams Signed-off-by: Ran Ferderber Ran.Ferderber@freescale.com
2009-08-08ENGR00114795 fix usb OTG co-work with remote wakeup issue.Jun Li
This patch fix OTG pin-detect failure issue. via sysfs set power/wakeup, i.MX51 can: Put usb phy into low power mode when system enters stop or standby mode; Enable usb device remote wakeup system by Vbus and usb host remote wakeup system by device connection or disconnection. Signed-off-by: Li Jun <r65092@freescale.com>
2009-06-17ENGR00113176: MX51:Add IPU vdi supportRan
Add IPU vdi support Signed-off-by: Ran Ferderber <Ran.Ferderber@freescale.com>
2009-06-17ENGR00112832 fix copyright problem with Huashan USB gadget patchJun Li
If the original codes is 1994 and update was only done in 2009, then it should read: Copyright 1994, 2009 Freescale Semiconductor, Inc. Signed-off-by: Li Jun <r65092@freescale.com>
2009-06-15ENGR00096014-1 ASRC-ESAI per_2_per transferWallace Wang
Add ASRC-ESAI p2p transfer support Signed-off-by: Wallace Wang <r59996@freescale.com>
2009-06-12ENGR00112889 ASRC driver multi-instance supportWilliam Lai
1. Support multi-instance 2. Support pause and restart 3. Support seek/flush feature Signed-off-by: William Lai <b04597@freescale.com>
2009-06-12ENGR00113242 IPUv3: Add new ioctl to get ipu channel type of fb.b02550
Add new ioctl to get ipu channel type to avoid the conflict between 3Stack and BBG board. Signed-off-by: DingQiang <b02550@freescale.com>
2009-06-02ENGR00112635-1 Port MC34704 regulator driver to kernel-2.6.28Xiexiaobo
Port MC34704 regulator driver to kernel-2.6.28. Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
2009-05-26ENGR00112025 ASRC driver enhancementWilliam Lai
1. Add interface to get the asrc status. 2. Add ASRTFR1 register initilization. 3. Bug fixes: remove the proc directoy. 4. Add underrun/overflow error handler. Signed-off-by: William Lai <b04597@freescale.com>
2009-05-19ENGR00112588 stmp3780 usb gadget support.Jun Li
port stmp378x usb gadget driver to linux 2.6.28. use one gadget driver for all i.MX and STMP3XXX chips usb. Signed-off-by: Li Jun <r65092@freescale.com>
2009-05-08ENGR00112184 IPUv3:Correct resersed input/output IRT EOF bitsLiu Ying
The input and output EOF interrupt bits of IC IRT channels are reversed. This patch fix this problem. Signed-off-by: Liu Ying <b17645@freescale.com> (cherry picked from commit 306f77291e37057b05572ad5c226b64ffc73e218)
2009-05-08ENGR00070770 MX51 SIM driverRichard Zhu
Enable MXC SIM module driver Signed-off-by: Richard Zhu <r65037@freescale.com>
2009-05-05ENGR00112199 Import EA 3780 release 4Rob Herring
This is from EA P4 release with the following changes: Ported to 2.6.28 UBI support is stock 2.6.28. USB is not integrated Regulator code is not yet ported. Removed 3700 specific files Fix copyrights Signed-off-by: Rob Herring <r.herring@freescale.com>
2009-05-05ENGR00112200 Add cryptodev deviceMichal Ludvig
Linux driver for /dev/crypto (aka CryptoDev) See http://www.logix.cz/michal/devel/cryptodev for details. Signed-off-by: Michal Ludvig <mludvig@suse.cz> Signed-off-by: Rob Herring <r.herring@freescale.com>
2009-05-05ENGR00112201 mtd: export nand_do_read/write_ops functionsRob Herring
mtd: export nand_do_read/write_ops functions Signed-off-by: Rob Herring <r.herring@freescale.com>
2009-05-05ENGR00112155 Error bool definition in ipu.h for user space c++ compilerSam Yang
When compiling android opencore, a redeclared compiling error occur because of bool definition in ipu.h. Signed-off-by:Sam Yang <r52096@freescale.com>
2009-04-30ENGR00111898-1 mx37: wm8350 soc audio supportAlan Tull
Enable WM8350 soc audio. Disable SGTL5000 audio. Don't store snd_soc_codec in wm8350 struct. Add regulator names to wm8350 audio platform data. Signed-off-by: Alan Tull <r80115@freescale.com>
2009-04-27ASoC: Add WM8350 AudioPlus codec driverMark Brown
The WM8350 is an integrated audio and power management subsystem which provides a single-chip solution for portable audio and multimedia systems. The integrated audio CODEC provides all the necessary functions for high-quality stereo recording and playback. Programmable on-chip amplifiers allow for the direct connection of headphones and microphones with a minimum of external components. A programmable low-noise bias voltage is available to feed one or more electret microphones. Additional audio features include programmable high-pass filter in the ADC input path. This driver was originally written by Liam Girdwood with further updates from me. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-20ENGR00108639 ipuv3: add IC overlay supportJason Chen
enable IC graphic combination feature. Signed-off-by: Jason Chen <b02280@freescale.com>
2009-04-17ENGR00110363 MX35: MCU-PMIC driver porting to 2.6.28Zhou Jingyu
MX35: MCU-PMIC driver porting to 2.6.28 Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com>
2009-04-14mfd: Add WM8350 revision H supportMark Brown
No other software changes are required. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-04-14ENGR00111379-1 backlight: update wm8350 for 2.6.28Rob Herring
Update wm8350 backlight support for 2.6.28 Signed-off-by: Alan Tull <r80115@freescale.com>
2009-04-14serial: RS485 ioctl structure uses __u32 include linux/types.hAndy Whitcroft
In the commit below a new struct serial_rs485 was introduced for a new ioctl: commit c26c56c0f40e200e61d1390629c806f6adaffbcc Author: Alan Cox <alan@redhat.com> Date: Mon Oct 13 10:37:48 2008 +0100 tty: Cris has a nice RS485 ioctl so we should steal it This structure uses the __u32 types for some of its members, which leads to the following compile error: $ cc -I.../include -c X.c In file included from X.c:2: .../include/linux/serial.h:185: error: expected specifier-qualifier-list before ‘__u32’ $ It seems that these types are appropriate for this structure as it is to be exposed to userspace. These types are available via linux/types.h so move the include of that outside the __KERNEL__ section. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-08ENGR00110536-2 Port mc13783 to 2.6.28Ann Thornton
reg-mc13893 was moved up a directory and modified to use the new API for 2.6.28. Some functions were added. Signed-off-by: Ann Thornton <Ann.Thornton@freescale.com>
2009-04-08ENGR00110536-1 Made files less regulator specific. Added some error checking.Ann Thornton
The structure pmic_platform_data is used to specify the init function instead of conditional compilations. pmic_alloc_data is added instead of regulator specific initialization. Checks are made before getting and enabling regulators. Signed-off-by: Ann Thornton <Ann.Thornton@freescale.com>
2009-03-24ENGR00109658 V4l2 capture:Add seperate VF and ENC rotation ioctlsLiu Ying
Add seperate VF and ENC rotation controls for IPUv1 and IPUv3. This prevents capture task and preview task from impacting on each other when doing rotation. Signed-off-by: Liu Ying <b17645@freescale.com>
2009-03-24ENGR00108463 Support i.MX31 USB host remote wakeup by USB device.Jun Li
When i.MX31 acts as USB host and is in SR/STOP mode, it can be waked up by usb device connection, disconnection, or usb activity of usb hid device. Signed-off-by: Li Jun <r65092@freescale.com>
2009-03-20ENGR00107699 ipu: support new ipu device libJason Chen
1.Add ipu_is_channel_busy functions to support new ipu device lib. 2.Ipu device driver modification to support. change the irq get event method to make the multi ipu device operations work. 3.Add suspend/resume for the case that entering power gating mode while some ipu channel are running. NOTE: there still is a bug for ipu suspend/resume function, ipu may not resume correctly while ipu were using double buffer, cause we can not set ipu current buffer register. Signed-off-by: Jason Chen <b02280@freescale.com> (cherry picked from commit 0a0a8c64a0c72eb3e4fe92375a2bd84f3faecb0d)
2009-03-03ENGR00108529 mxcfb: rework lcd interface definitionsRob Herring
-Add support for custom fb memory allocations -update custom FB_SYNC defines. redefine them so most panels don't need them. They cause problems for X server init. -Add platform_data to specify the lcd interface pixel format. Signed-off-by: Rob Herring <r.herring@freescale.com>
2009-03-03ENGR00107856 IPUv3: Add RGB565 and LVDS666 pixel formats support for DC mappingLiu Ying
Add RGB565 and LVDS666 pixel formats support for DC mapping. Signed-off-by: Liu Ying <b17645@freescale.com>
2009-03-03ENGR00107844-4 mc13892: add regulator driverAnn Thornton
The files for the mc13892 regulator were modified for the new 2.6.28 regulator API. Signed-off-by: Ann Thornton <Ann.Thornton@freescale.com>
2009-02-17ENGR00107844-2: regulator: update drivers to mainline regulator apira43240
Update drivers for mainline regulator support. Signed-off-by: Ann Thornton <Ann.Thornton@freescale.com>
2009-02-17ENGR00107392 Move asm/arch headers to linux inc dirRob Herring
Architecture specific headers moved and are not accessible to userspace in 2.6.28. So they are moved to linux include directory. Signed-off-by: Rob Herring <r.herring@freescale.com>
2009-02-17ENGR00107731-2: Port imx 3.3.0 release to 2.6.28Rob Herring
Port rel_imx_2.6.26_3.3.0 to 2.6.28. PMIC Regulator and ASoC drivers are removed and not yet ported. Updated asm/arch headers for move to plat-mxc/include/mach device_create parameters changed. sysdev attribute functions changed. Adopt mainline MX3 timer code and update clock init flow. Signed-off-by: Rob Herring <r.herring@freescale.com>
2009-02-16ENGR00068619 JFFS2 community fix with not use OOBJason Liu
JFFS2 community fix with not use OOB at MLC NAND, this patch is coming from the MTD community Signed-off-by: Jason Liu <r64343@freescale.com>
2008-12-19ACPI: don't cond_resched() when irqs_disabled()Wu Fengguang
The ACPI interpreter usually runs with irqs enabled. However, during suspend/resume it runs with irqs disabled to evaluate _GTS/_BFS, as well as by irqrouter_resume() which evaluates _CRS, _PRS, _SRS. http://bugzilla.kernel.org/show_bug.cgi?id=12252 Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-19ACPI: fix 2.6.28 acpi.debug_level regressionBjorn Helgaas
acpi_early_init() was changed to over-write the cmdline param, making it really inconvenient to set debug flags at boot-time. Also, This sets the default level to "info", which is what all the ACPI drivers use. So to enable messages from drivers, you only have to supply the "layer" (a.k.a. "component"). For non-"info" ACPI core and ACPI interpreter messages, you have to supply both level and layer masks, as before. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: bnx2: Fix bug in bnx2_free_rx_mem(). irda: Add irda_skb_cb qdisc related padding jme: Fixed a typo net: kernel BUG at drivers/net/phy/mdio_bus.c:165! drivers/net: starfire: Fix napi ->poll() weight handling tlan: Fix pci memory unmapping enc28j60: use netif_rx_ni() to deliver RX packets tlan: Fix small (< 64 bytes) datagram transmissions netfilter: ctnetlink: fix missing CTA_NAT_SEQ_UNSPEC
2008-12-17irda: Add irda_skb_cb qdisc related paddingSamuel Ortiz
We need to pad irda_skb_cb in order to keep it safe accross dev_queue_xmit() calls. This is some ugly and temporary hack triggered by recent qisc code changes. Even though it fixes bugzilla.kernel.org bug #11795, it will be replaced by a proper fix before 2.6.29 is released. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-17USB: fix comment about endianness of descriptorsPhil Endecott
This patch fixes a comment and clarifies the documentation about the endianness of descriptors. The current policy is that descriptors will be little-endian at the API even on big-endian systems; however the /proc/bus/usb API predates this policy and presents descriptors with some multibyte fields byte-swapped. Signed-off-by: Phil Endecott <usb_endian_patch@chezphil.org> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-16netfilter: ctnetlink: fix missing CTA_NAT_SEQ_UNSPECPablo Neira Ayuso
This patch fixes an inconsistency in nfnetlink_conntrack.h that I introduced myself. The problem is that CTA_NAT_SEQ_UNSPEC is missing from enum ctattr_natseq. This inconsistency may lead to problems in the message parsing in userspace (if the message contains the CTA_NAT_SEQ_* attributes, of course). This patch breaks backward compatibility, however, the only known client of this code is libnetfilter_conntrack which indeed crashes because it assumes the existence of CTA_NAT_SEQ_UNSPEC to do the parsing. The CTA_NAT_SEQ_* attributes were introduced in 2.6.25. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: Phonet: keep TX queue disabled when the device is off SCHED: netem: Correct documentation comment in code. netfilter: update rwlock initialization for nat_table netlabel: Compiler warning and NULL pointer dereference fix e1000e: fix double release of mutex IA64: HP_SIMETH needs to depend upon NET netpoll: fix race on poll_list resulting in garbage entry ipv6: silence log messages for locally generated multicast sungem: improve ethtool output with internal pcs and serdes tcp: tcp_vegas cong avoid fix sungem: Make PCS PHY support partially work again.
2008-12-15Define smp_call_function_many for UPRusty Russell
Otherwise those using it in transition patches (eg. kvm) can't compile with CONFIG_SMP=n: arch/x86/kvm/../../../virt/kvm/kvm_main.c: In function 'make_all_cpus_request': arch/x86/kvm/../../../virt/kvm/kvm_main.c:380: error: implicit declaration of function 'smp_call_function_many' Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10Revert "radeonfb: accelerate imageblit and other improvements"Linus Torvalds
This reverts commit b1ee26bab14886350ba12a5c10cbc0696ac679bf, along with the "fixes" for it that all just caused problems: - c4c6fa9891f3d1bcaae4f39fb751d5302965b566 "radeonfb: fix problem with color expansion & alignment" - f3179748a157c21d44d929fd3779421ebfbeaa93 "radeonfb: Disable new color expand acceleration unless explicitely enabled" because even when disabled, it breaks for people. See http://bugzilla.kernel.org/show_bug.cgi?id=12191 for the latest example. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: James Cloos <cloos@jhcloos.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Jean-Luc Coulon <jean.luc.coulon@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10MN10300: Fix __put_user_asm8()Akira Takeuchi
Fix __put_user_asm8() by jumping to the end label (3:) from the exception handler, rather than jumping back to retry the second store instruction (label 2:). Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10KSYM_SYMBOL_LEN fixesHugh Dickins
Miles Lane tailing /sys files hit a BUG which Pekka Enberg has tracked to my 966c8c12dc9e77f931e2281ba25d2f0244b06949 sprint_symbol(): use less stack exposing a bug in slub's list_locations() - kallsyms_lookup() writes a 0 to namebuf[KSYM_NAME_LEN-1], but that was beyond the end of page provided. The 100 slop which list_locations() allows at end of page looks roughly enough for all the other stuff it might print after the symbol before it checks again: break out KSYM_SYMBOL_LEN earlier than before. Latencytop and ftrace and are using KSYM_NAME_LEN buffers where they need KSYM_SYMBOL_LEN buffers, and vmallocinfo a 2*KSYM_NAME_LEN buffer where it wants a KSYM_SYMBOL_LEN buffer: fix those before anyone copies them. [akpm@linux-foundation.org: ftrace.h needs module.h] Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc Miles Lane <miles.lane@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10atomic: fix a typo in atomic_long_xchg()Eric Dumazet
atomic_long_xchg() is not correctly defined for 32bit arches. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10revert "percpu_counter: new function percpu_counter_sum_and_set"Andrew Morton
Revert commit e8ced39d5e8911c662d4d69a342b9d053eaaac4e Author: Mingming Cao <cmm@us.ibm.com> Date: Fri Jul 11 19:27:31 2008 -0400 percpu_counter: new function percpu_counter_sum_and_set As described in revert "percpu counter: clean up percpu_counter_sum_and_set()" the new percpu_counter_sum_and_set() is racy against updates to the cpu-local accumulators on other CPUs. Revert that change. This means that ext4 will be slow again. But correct. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10revert "percpu counter: clean up percpu_counter_sum_and_set()"Andrew Morton
Revert commit 1f7c14c62ce63805f9574664a6c6de3633d4a354 Author: Mingming Cao <cmm@us.ibm.com> Date: Thu Oct 9 12:50:59 2008 -0400 percpu counter: clean up percpu_counter_sum_and_set() Before this patch we had the following: percpu_counter_sum(): return the percpu_counter's value percpu_counter_sum_and_set(): return the percpu_counter's value, copying that value into the central value and zeroing the per-cpu counters before returning. After this patch, percpu_counter_sum_and_set() has gone, and percpu_counter_sum() gets the old percpu_counter_sum_and_set() functionality. Problem is, as Eric points out, the old percpu_counter_sum_and_set() functionality was racy and wrong. It zeroes out counters on "other" cpus, without holding any locks which will prevent races agaist updates from those other CPUS. This patch reverts 1f7c14c62ce63805f9574664a6c6de3633d4a354. This means that percpu_counter_sum_and_set() still has the race, but percpu_counter_sum() does not. Note that this is not a simple revert - ext4 has since started using percpu_counter_sum() for its dirty_blocks counter as well. Note that this revert patch changes percpu_counter_sum() semantics. Before the patch, a call to percpu_counter_sum() will bring the counter's central counter mostly up-to-date, so a following percpu_counter_read() will return a close value. After this patch, a call to percpu_counter_sum() will leave the counter's central accumulator unaltered, so a subsequent call to percpu_counter_read() can now return a significantly inaccurate result. If there is any code in the tree which was introduced after e8ced39d5e8911c662d4d69a342b9d053eaaac4e was merged, and which depends upon the new percpu_counter_sum() semantics, that code will break. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-09netpoll: fix race on poll_list resulting in garbage entryNeil Horman
A few months back a race was discused between the netpoll napi service path, and the fast path through net_rx_action: http://kerneltrap.org/mailarchive/linux-netdev/2007/10/16/345470 A patch was submitted for that bug, but I think we missed a case. Consider the following scenario: INITIAL STATE CPU0 has one napi_struct A on its poll_list CPU1 is calling netpoll_send_skb and needs to call poll_napi on the same napi_struct A that CPU0 has on its list CPU0 CPU1 net_rx_action poll_napi !list_empty (returns true) locks poll_lock for A poll_one_napi napi->poll netif_rx_complete __napi_complete (removes A from poll_list) list_entry(list->next) In the above scenario, net_rx_action assumes that the per-cpu poll_list is exclusive to that cpu. netpoll of course violates that, and because the netpoll path can dequeue from the poll list, its possible for CPU0 to detect a non-empty list at the top of the while loop in net_rx_action, but have it become empty by the time it calls list_entry. Since the poll_list isn't surrounded by any other structure, the returned data from that list_entry call in this situation is garbage, and any number of crashes can result based on what exactly that garbage is. Given that its not fasible for performance reasons to place exclusive locks arround each cpus poll list to provide that mutal exclusion, I think the best solution is modify the netpoll path in such a way that we continue to guarantee that the poll_list for a cpu is in fact exclusive to that cpu. To do this I've implemented the patch below. It adds an additional bit to the state field in the napi_struct. When executing napi->poll from the netpoll_path, this bit will be set. When a driver calls netif_rx_complete, if that bit is set, it will not remove the napi_struct from the poll_list. That work will be saved for the next iteration of net_rx_action. I've tested this and it seems to work well. About the biggest drawback I can see to it is the fact that it might result in an extra loop through net_rx_action in the event that the device is actually contended for (i.e. the netpoll path actually preforms all the needed work no the device, and the call to net_rx_action winds up doing nothing, except removing the napi_struct from the poll_list. However I think this is probably a small price to pay, given that the alternative is a crash. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
