[ Upstream commit d9d10a30964504af834d8d250a0c76d4ae91eb1e ]
commit 8742f229b635bf1c1c84a3dfe5e47c814c20b5c8 upstream.
Ensure that user_namespace->parent chain can't grow too much.
Currently we use the hardroded 32 as limit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit 148519120c6d1f19ad53349683aeae9f228b0b8d upstream.
Revert commit 69a37bea (cpuidle: Quickly notice prediction failure for
repeat mode), because it has been identified as the source of a
significant performance regression in v3.8 and later as explained by
Jeremy Eder:
We believe we've identified a particular commit to the cpuidle code
that seems to be impacting performance of variety of workloads.
The simplest way to reproduce is using netperf TCP_RR test, so
we're using that, on a pair of Sandy Bridge based servers. We also
have data from a large database setup where performance is also
measurably/positively impacted, though that test data isn't easily
share-able.
Included below are test results from 3 test kernels:
kernel reverts
1) vanilla upstream (no reverts)
2) perfteam2 reverts e11538d1f03914eb92af5a1a378375c05ae8520c
3) test reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
In summary, netperf TCP_RR numbers improve by approximately 4%
after reverting 69a37beabf1f0a6705c08e879bdd5d82ff6486c4. When
69a37beabf1f0a6705c08e879bdd5d82ff6486c4 is included, C0 residency
never seems to get above 40%. Taking that patch out gets C0 near
100% quite often, and performance increases.
The below data are histograms representing the %c0 residency @
1-second sample rates (using turbostat), while under netperf test.
- If you look at the first 4 histograms, you can see %c0 residency
almost entirely in the 30,40% bin.
- The last pair, which reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4,
shows %c0 in the 80,90,100% bins.
Below each kernel name are netperf TCP_RR trans/s numbers for the
particular kernel that can be disclosed publicly, comparing the 3
test kernels. We ran a 4th test with the vanilla kernel where
we've also set /dev/cpu_dma_latency=0 to show overall impact
boosting single-threaded TCP_RR performance over 11% above
baseline.
3.10-rc2 vanilla RX + c0 lock (/dev/cpu_dma_latency=0):
TCP_RR trans/s 54323.78
3.10-rc2 vanilla RX (no reverts)
TCP_RR trans/s 48192.47
Receiver %c0
0.0000 - 10.0000 [ 1]: *
10.0000 - 20.0000 [ 0]:
20.0000 - 30.0000 [ 0]:
30.0000 - 40.0000 [ 59]:
40.0000 - 50.0000 [ 1]: *
50.0000 - 60.0000 [ 0]:
60.0000 - 70.0000 [ 0]:
70.0000 - 80.0000 [ 0]:
80.0000 - 90.0000 [ 0]:
90.0000 - 100.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 11]: ***********
40.0000 - 50.0000 [ 49]:
3.10-rc2 perfteam2 RX (reverts commit
e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 49698.69
Receiver %c0
10.0000 - 20.0000 [ 1]: *
40.0000 - 50.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 2]: **
40.0000 - 50.0000 [ 58]:
3.10-rc2 test RX (reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
and e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 47766.95
Receiver %c0
30.0000 - 40.0000 [ 27]: ***************************
40.0000 - 50.0000 [ 2]: **
60.0000 - 70.0000 [ 2]: **
90.0000 - 100.0000 [ 28]: ****************************
Sender:
50.0000 - 60.0000 [ 1]: *
70.0000 - 80.0000 [ 3]: ***
80.0000 - 90.0000 [ 7]: *******
90.0000 - 100.0000 [ 38]: **************************************
These results demonstrate gaining back the tendency of the CPU to
stay in more responsive, performant C-states (and thus yield
measurably better performance), by reverting commit
Requested-by: Jeremy Eder <jeder@redhat.com>
Tested-by: Len Brown <len.brown@intel.com>
commit 561bf15892375597ee59d473a704a3e634c4f311 upstream
This patch moves ISCSI_OP_REJECT failures into iscsit_sequence_cmd()
in order to avoid external iscsit_reject_cmd() reject usage for all
PDU types.
It also updates PDU specific handlers for traditional iscsi-target
code to not reset the session after posting a ISCSI_OP_REJECT during
setup.
(v2: Fix CMDSN_LOWER_THAN_EXP for ISCSI_OP_SCSI to call
target_put_sess_cmd() after iscsit_sequence_cmd() failure)
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
commit ba159914086f06532079fc15141f46ffe7e04a41 upstream
This patch changes iscsit_add_reject() + iscsit_add_reject_from_cmd()
usage to not sleep on iscsi_cmd->reject_comp to address a free-after-use
usage bug in v3.10 with iser-target code.
It saves ->reject_reason for use within iscsit_build_reject() so the
correct value for both transport cases. It also drops the legacy
fail_conn parameter usage throughput iscsi-target code and adds
two iscsit_add_reject_cmd() and iscsit_reject_cmd helper functions,
along with various small cleanups.
(v2: Re-enable target_put_sess_cmd() to be called from
iscsit_add_reject_from_cmd() for rejects invoked after
target_get_sess_cmd() has been called)
commit 0699a73af3811b66b1ab5650575acee5eea841ab upstream.
Commit 18d627113b83 (firewire: prevent dropping of completed iso packet
header data) was intended to be an obvious bug fix, but libdc1394 and
FlyCap2 depend on the old behaviour by ignoring all returned information
and thus not noticing that not all packets have been received yet. The
result was that the video frame buffers would be saved before they
contained the correct data.
Reintroduce the old behaviour for old clients.
Tested-by: Stepan Salenikovich <stepan.salenikovich@gmail.com>
Tested-by: Josep Bosch <jep250@gmail.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit b2cb96494d83b894a43ba8b9023eead8ff50684b upstream.
This patch addresses a bug where RDMA_CM_EVENT_DISCONNECTED may occur
before the connection shutdown has been completed by rx/tx threads,
that causes isert_free_conn() to wait indefinately on ->conn_wait.
This patch allows isert_disconnect_work code to invoke rdma_disconnect
when isert_disconnect_work() process context is started by client
session reset before isert_free_conn() code has been reached.
It also adds isert_conn->conn_mutex protection for ->state within
isert_disconnect_work(), isert_cq_comp_err() and isert_free_conn()
code, along with isert_check_state() for wait_event usage.
(v2: Add explicit iscsit_cause_connection_reinstatement call
during isert_disconnect_work() to force conn reset)
commit 88d84ac97378c2f1d5fec9af1e8b7d9a662d6b00 upstream.
Fix the following:
BUG: key ffff88043bdd0330 not in .data!
WARNING: at kernel/lockdep.c:2987 lockdep_init_map+0x565/0x5a0()
DEBUG_LOCKS_WARN_ON(1)
Modules linked in: glue_helper sb_edac(+) edac_core snd acpi_cpufreq lrw gf128mul ablk_helper iTCO_wdt evdev i2c_i801 dcdbas button cryptd pcspkr iTCO_vendor_support usb_common lpc_ich mfd_core soundcore mperf processor microcode
CPU: 2 PID: 599 Comm: modprobe Not tainted 3.10.0 #1
Hardware name: Dell Inc. Precision T3600/0PTTT9, BIOS A08 01/24/2013
0000000000000009 ffff880439a1d920 ffffffff8160a9a9 ffff880439a1d958
ffffffff8103d9e0 ffff88043af4a510 ffffffff81a16e11 0000000000000000
ffff88043bdd0330 0000000000000000 ffff880439a1d9b8 ffffffff8103dacc
Call Trace:
dump_stack
warn_slowpath_common
warn_slowpath_fmt
lockdep_init_map
? trace_hardirqs_on_caller
? trace_hardirqs_on
debug_mutex_init
__mutex_init
bus_register
edac_create_sysfs_mci_device
edac_mc_add_mc
sbridge_probe
pci_device_probe
driver_probe_device
__driver_attach
? driver_probe_device
bus_for_each_dev
driver_attach
bus_add_driver
driver_register
__pci_register_driver
? 0xffffffffa0010fff
sbridge_init
do_one_initcall
load_module
? unset_module_init_ro_nx
SyS_init_module
tracesys
---[ end trace d24a70b0d3ddf733 ]---
EDAC MC0: Giving out device to 'sbridge_edac.c' 'Sandy Bridge Socket#0': DEV 0000:3f:0e.0
EDAC sbridge: Driver loaded.
What happens is that bus_register needs a statically allocated lock_key
because the last is handed in to lockdep. However, struct mem_ctl_info
embeds struct bus_type (the whole struct, not a pointer to it) and the
whole thing gets dynamically allocated.
Fix this by using a statically allocated struct bus_type for the MC bus.
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Signed-off-by: Tony Luck <tony.luck@intel.com>
[ Upstream commit d4b812dea4a236f729526facf97df1a9d18e191c ]
In commit 48cc32d38a52d0b68f91a171a8d00531edc6a46e
("vlan: don't deliver frames for unknown vlans to protocols")
Florian made sure we set pkt_type to PACKET_OTHERHOST
if the vlan id is set and we could find a vlan device for this
particular id.
But we also have a problem if prio bits are set.
Steinar reported an issue on a router receiving IPv6 frames with a
vlan tag of 4000 (id 0, prio 2), and tunneled into a sit device,
because skb->vlan_tci is set.
Forwarded frame is completely corrupted : We can see (8100:4000)
being inserted in the middle of IPv6 source address :
16:48:00.780413 IP6 2001:16d8:8100:4000:ee1c:0:9d9:bc87 >
9f94:4d95:2001:67c:29f4::: ICMP6, unknown icmp6 type (0), length 64
0x0000: 0000 0029 8000 c7c3 7103 0001 a0ae e651
0x0010: 0000 0000 ccce 0b00 0000 0000 1011 1213
0x0020: 1415 1617 1819 1a1b 1c1d 1e1f 2021 2223
0x0030: 2425 2627 2829 2a2b 2c2d 2e2f 3031 3233
It seems we are not really ready to properly cope with this right now.
We can probably do better in future kernels :
vlan_get_ingress_priority() should be a netdev property instead of
a per vlan_dev one.
For stable kernels, lets clear vlan_tci to fix the bugs.
Reported-by: Steinar H. Gunderson <sesse@google.com>
[ Upstream commit cc229884d3f77ec3b1240e467e0236c3e0647c0c ]
This adds a way to check ring empty state after enable_cb outside any
locks. Will be used by virtio_net.
Note: there's room for more optimization: caller is likely to have a
memory barrier already, which means we might be able to get rid of a
barrier here. Deferring this optimization until we do some
benchmarking.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
pending data
[ Upstream commit 8822b64a0fa64a5dd1dfcf837c5b0be83f8c05d1 ]
We accidentally call down to ip6_push_pending_frames when uncorking
pending AF_INET data on a ipv6 socket. This results in the following
splat (from Dave Jones):
skbuff: skb_under_panic: text:ffffffff816765f6 len:48 put:40 head:ffff88013deb6df0 data:ffff88013deb6dec tail:0x2c end:0xc0 dev:<NULL>
kernel BUG at net/core/skbuff.c:126!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in: dccp_ipv4 dccp 8021q garp bridge stp dlci mpoa snd_seq_dummy sctp fuse hidp tun bnep nfnetlink scsi_transport_iscsi rfcomm can_raw can_bcm af_802154 appletalk caif_socket can caif ipt_ULOG x25 rose af_key pppoe pppox ipx phonet irda llc2 ppp_generic slhc p8023 psnap p8022 llc crc_ccitt atm bluetooth
+netrom ax25 nfc rfkill rds af_rxrpc coretemp hwmon kvm_intel kvm crc32c_intel snd_hda_codec_realtek ghash_clmulni_intel microcode pcspkr snd_hda_codec_hdmi snd_hda_intel snd_hda_codec snd_hwdep usb_debug snd_seq snd_seq_device snd_pcm e1000e snd_page_alloc snd_timer ptp snd pps_core soundcore xfs libcrc32c
CPU: 2 PID: 8095 Comm: trinity-child2 Not tainted 3.10.0-rc7+ #37
task: ffff8801f52c2520 ti: ffff8801e6430000 task.ti: ffff8801e6430000
RIP: 0010:[<ffffffff816e759c>] [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP: 0018:ffff8801e6431de8 EFLAGS: 00010282
RAX: 0000000000000086 RBX: ffff8802353d3cc0 RCX: 0000000000000006
RDX: 0000000000003b90 RSI: ffff8801f52c2ca0 RDI: ffff8801f52c2520
RBP: ffff8801e6431e08 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000001 R12: ffff88022ea0c800
R13: ffff88022ea0cdf8 R14: ffff8802353ecb40 R15: ffffffff81cc7800
FS: 00007f5720a10740(0000) GS:ffff880244c00000(0000) knlGS:0000000000000000
CR2: 0000000005862000 CR3: 000000022843c000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600
Stack:
ffff88013deb6dec 000000000000002c 00000000000000c0 ffffffff81a3f6e4
ffff8801e6431e18 ffffffff8159a9aa ffff8801e6431e90 ffffffff816765f6
ffffffff810b756b 0000000700000002 ffff8801e6431e40 0000fea9292aa8c0
Call Trace:
[<ffffffff8159a9aa>] skb_push+0x3a/0x40
[<ffffffff816765f6>] ip6_push_pending_frames+0x1f6/0x4d0
[<ffffffff810b756b>] ? mark_held_locks+0xbb/0x140
[<ffffffff81694919>] udp_v6_push_pending_frames+0x2b9/0x3d0
[<ffffffff81694660>] ? udplite_getfrag+0x20/0x20
[<ffffffff8162092a>] udp_lib_setsockopt+0x1aa/0x1f0
[<ffffffff811cc5e7>] ? fget_light+0x387/0x4f0
[<ffffffff816958a4>] udpv6_setsockopt+0x34/0x40
[<ffffffff815949f4>] sock_common_setsockopt+0x14/0x20
[<ffffffff81593c31>] SyS_setsockopt+0x71/0xd0
[<ffffffff816f5d54>] tracesys+0xdd/0xe2
Code: 00 00 48 89 44 24 10 8b 87 d8 00 00 00 48 89 44 24 08 48 8b 87 e8 00 00 00 48 c7 c7 c0 04 aa 81 48 89 04 24 31 c0 e8 e1 7e ff ff <0f> 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55
RIP [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP <ffff8801e6431de8>
This patch adds a check if the pending data is of address family AF_INET
and directly calls udp_push_ending_frames from udp_v6_push_pending_frames
if that is the case.
This bug was found by Dave Jones with trinity.
(Also move the initialization of fl6 below the AF_INET check, even if
not strictly necessary.)
Cc: Dave Jones <davej@redhat.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 8965779d2c0e6ab246c82a405236b1fb2adae6b2, with
some bits from commit b7b1bfce0bb68bd8f6e62a28295922785cc63781
("ipv6: split duplicate address detection and router solicitation timer")
to get the __ipv6_get_lladdr() used by this patch. ]
dingtianhong reported the following deadlock detected by lockdep:
[ INFO: possible circular locking dependency detected ]
3.4.24.05-0.1-default #1 Not tainted
ksoftirqd/0/3 is trying to acquire lock:
(&ndev->lock){+.+...}, at: [<ffffffff8147f804>] ipv6_get_lladdr+0x74/0x120
but task is already holding lock:
(&mc->mca_lock){+.+...}, at: [<ffffffff8149d130>] mld_send_report+0x40/0x150
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&mc->mca_lock){+.+...}:
[<ffffffff810a8027>] validate_chain+0x637/0x730
[<ffffffff810a8417>] __lock_acquire+0x2f7/0x500
[<ffffffff810a8734>] lock_acquire+0x114/0x150
[<ffffffff814f691a>] rt_spin_lock+0x4a/0x60
[<ffffffff8149e4bb>] igmp6_group_added+0x3b/0x120
[<ffffffff8149e5d8>] ipv6_mc_up+0x38/0x60
[<ffffffff81480a4d>] ipv6_find_idev+0x3d/0x80
[<ffffffff81483175>] addrconf_notify+0x3d5/0x4b0
[<ffffffff814fae3f>] notifier_call_chain+0x3f/0x80
[<ffffffff81073471>] raw_notifier_call_chain+0x11/0x20
[<ffffffff813d8722>] call_netdevice_notifiers+0x32/0x60
[<ffffffff813d92d4>] __dev_notify_flags+0x34/0x80
[<ffffffff813d9360>] dev_change_flags+0x40/0x70
[<ffffffff813ea627>] do_setlink+0x237/0x8a0
[<ffffffff813ebb6c>] rtnl_newlink+0x3ec/0x600
[<ffffffff813eb4d0>] rtnetlink_rcv_msg+0x160/0x310
[<ffffffff814040b9>] netlink_rcv_skb+0x89/0xb0
[<ffffffff813eb357>] rtnetlink_rcv+0x27/0x40
[<ffffffff81403e20>] netlink_unicast+0x140/0x180
[<ffffffff81404a9e>] netlink_sendmsg+0x33e/0x380
[<ffffffff813c4252>] sock_sendmsg+0x112/0x130
[<ffffffff813c537e>] __sys_sendmsg+0x44e/0x460
[<ffffffff813c5544>] sys_sendmsg+0x44/0x70
[<ffffffff814feab9>] system_call_fastpath+0x16/0x1b
-> #0 (&ndev->lock){+.+...}:
[<ffffffff810a798e>] check_prev_add+0x3de/0x440
[<ffffffff814f6c82>] rt_read_lock+0x42/0x60
[<ffffffff8149b036>] mld_newpack+0xb6/0x160
[<ffffffff8149b18b>] add_grhead+0xab/0xc0
[<ffffffff8149d03b>] add_grec+0x3ab/0x460
[<ffffffff8149d14a>] mld_send_report+0x5a/0x150
[<ffffffff8149f99e>] igmp6_timer_handler+0x4e/0xb0
[<ffffffff8105705a>] call_timer_fn+0xca/0x1d0
[<ffffffff81057b9f>] run_timer_softirq+0x1df/0x2e0
[<ffffffff8104e8c7>] handle_pending_softirqs+0xf7/0x1f0
[<ffffffff8104ea3b>] __do_softirq_common+0x7b/0xf0
[<ffffffff8104f07f>] __thread_do_softirq+0x1af/0x210
[<ffffffff8104f1c1>] run_ksoftirqd+0xe1/0x1f0
[<ffffffff8106c7de>] kthread+0xae/0xc0
[<ffffffff814fff74>] kernel_thread_helper+0x4/0x10
actually we can just hold idev->lock before taking pmc->mca_lock,
and avoid taking idev->lock again when iterating idev->addr_list,
since the upper callers of mld_newpack() already take
read_lock_bh(&idev->lock).
Reported-by: dingtianhong <dingtianhong@huawei.com>
Cc: dingtianhong <dingtianhong@huawei.com>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Tested-by: Ding Tianhong <dingtianhong@huawei.com>
Tested-by: Chen Weilong <chenweilong@huawei.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit b1a5a34bd0b8767ea689e68f8ea513e9710b671e ]
Ver and type in pppoe_hdr should be swapped as defined by RFC2516
section-4.
commit e8d39240d635ed9bcaddbec898b1c9f063c5dbb2 upstream.
The function stub for cpufreq_cooling_get_level introduced
in 57df81069 "Thermal: exynos: fix cooling state translation"
is not syntactically correct C and needs to be fixed to avoid
this error:
In file included from drivers/thermal/db8500_thermal.c:20:0:
include/linux/cpu_cooling.h: In function 'cpufreq_cooling_get_level':
include/linux/cpu_cooling.h:57:1:
error: parameter name omitted unsigned long cpufreq_cooling_get_level(unsigned int, unsigned int) ^
include/linux/cpu_cooling.h:57:1: error: parameter name omitted
Acked-by: Eduardo Valentin <eduardo.valentin@ti.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Amit Daniel kachhap <amit.daniel@samsung.com>
Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
commit 1c297a66654a3295ae87e2b7f3724d214eb2b5ec upstream.
Since the info_mask split, iio_channel_has_info() is not working correctly.
info_mask_separate and info_mask_shared_by_type, it is not possible to compare
them directly with the iio_chan_info_enum enum. Correct that bit using the BIT()
macro.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit c378f70adbc1bbecd9e6db145019f14b2f688c7c upstream.
Currently, when a disconnect is requested by the user (via NBD_DISCONNECT
ioctl) the return from NBD_DO_IT is undefined (it is usually one of
several error codes). This means that nbd-client does not know if a
manual disconnect was performed or whether a network error occurred.
Because of this, nbd-client's persist mode (which tries to reconnect after
error, but not after manual disconnect) does not always work correctly.
This change fixes this by causing NBD_DO_IT to always return 0 if a user
requests a disconnect. This means that nbd-client can correctly either
persist the connection (if an error occurred) or disconnect (if the user
requested it).
Signed-off-by: Paul Clements <paul.clements@steeleye.com>
Acked-by: Rob Landley <rob@landley.net>
commit 14611e51a57df10240817d8ada510842faf0ec51 upstream.
task->cgroups is a RCU pointer pointing to struct css_set. A task
switches to a different css_set on cgroup migration but a css_set
doesn't change once created and its pointers to cgroup_subsys_states
aren't RCU protected.
task_subsys_state[_check]() is the macro to acquire css given a task
and subsys_id pair. It RCU-dereferences task->cgroups->subsys[] not
task->cgroups, so the RCU pointer task->cgroups ends up being
dereferenced without read_barrier_depends() after it. It's broken.
Fix it by introducing task_css_set[_check]() which does
RCU-dereference on task->cgroups. task_subsys_state[_check]() is
reimplemented to directly dereference ->subsys[] of the css_set
returned from task_css_set[_check]().
This removes some of sparse RCU warnings in cgroup.
v2: Fixed unbalanced parenthsis and there's no need to use
rcu_dereference_raw() when !CONFIG_PROVE_RCU. Both spotted by Li.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Li Zefan <lizefan@huawei.com>
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream.
The futex_keys of process shared futexes are generated from the page
offset, the mapping host and the mapping index of the futex user space
address. This should result in an unique identifier for each futex.
Though this is not true when futexes are located in different subpages
of an hugepage. The reason is, that the mapping index for all those
futexes evaluates to the index of the base page of the hugetlbfs
mapping. So a futex at offset 0 of the hugepage mapping and another
one at offset PAGE_SIZE of the same hugepage mapping have identical
futex_keys. This happens because the futex code blindly uses
page->index.
Steps to reproduce the bug:
1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0
and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs
mapping.
The mutexes must be initialized as PTHREAD_PROCESS_SHARED because
PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as
their keys solely depend on the user space address.
2. Lock mutex1 and mutex2
3. Create thread1 and in the thread function lock mutex1, which
results in thread1 blocking on the locked mutex1.
4. Create thread2 and in the thread function lock mutex2, which
results in thread2 blocking on the locked mutex2.
5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2
still blocks on mutex2 because the futex_key points to mutex1.
To solve this issue we need to take the normal page index of the page
which contains the futex into account, if the futex is in an hugetlbfs
mapping. In other words, we calculate the normal page mapping index of
the subpage in the hugetlbfs mapping.
Mappings which are not based on hugetlbfs are not affected and still
use page->index.
Thanks to Mel Gorman who provided a patch for adding proper evaluation
functions to the hugetlbfs code to avoid exposing hugetlbfs specific
details to the futex code.
[ tglx: Massaged changelog ]
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn>
Reviewed-by: 'Mel Gorman' <mgorman@suse.de>
Acked-by: 'Darren Hart' <dvhart@linux.intel.com>
Cc: 'Peter Zijlstra' <peterz@infradead.org>
Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com
commit 8b8cf8917f9b5d74e04f281272d8719ce335a497 upstream.
__kernel_time_t is a long, which cannot hold a U32_MAX on 32-bit
architectures. Just drop this check as it has limited value.
This fixes a crash like:
[ 957.905812] kernel BUG at /srv/autobuild-ceph/gitbuilder.git/build/include/linux/ceph/decode.h:164!
[ 957.914849] Internal error: Oops - BUG: 0 [#1] SMP ARM
[ 957.919978] Modules linked in: rbd libceph libcrc32c ipmi_devintf ipmi_si ipmi_msghandler nfsd nfs_acl auth_rpcgss nfs fscache lockd sunrpc
[ 957.932547] CPU: 1 Tainted: G W (3.9.0-ceph-19bb6a83-highbank #1)
[ 957.939881] PC is at ceph_osdc_build_request+0x8c/0x4f8 [libceph]
[ 957.945967] LR is at 0xec520904
[ 957.949103] pc : [<bf13e76c>] lr : [<ec520904>] psr: 20000153
[ 957.949103] sp : ec753df8 ip : 00000001 fp : ec53e100
[ 957.960571] r10: ebef25c0 r9 : ec5fa400 r8 : ecbcc000
[ 957.965788] r7 : 00000000 r6 : 00000000 r5 : ffffffff r4 : 00000020
[ 957.972307] r3 : 51cc8143 r2 : ec520900 r1 : ec753e58 r0 : ec520908
[ 957.978827] Flags: nzCv IRQs on FIQs off Mode SVC_32 ISA ARM Segment user
[ 957.986039] Control: 10c5387d Table: 2c59c04a DAC: 00000015
[ 957.991777] Process rbd (pid: 2138, stack limit = 0xec752238)
[ 957.997514] Stack: (0xec753df8 to 0xec754000)
[ 958.001864] 3de0: 00000001 00000001
[ 958.010032] 3e00: 00000001 bf139744 ecbcc000 ec55a0a0 00000024 00000000 ebef25c0 fffffffe
[ 958.018204] 3e20: ffffffff 00000000 00000000 00000001 ec5fa400 ebef25c0 ec53e100 bf166b68
[ 958.026377] 3e40: 00000000 0000220f fffffffe ffffffff ec753e58 bf13ff24 51cc8143 05b25ed2
[ 958.034548] 3e60: 00000001 00000000 00000000 bf1688d4 00000001 00000000 00000000 00000000
[ 958.042720] 3e80: 00000001 00000060 ec5fa400 ed53d200 ed439600 ed439300 00000001 00000060
[ 958.050888] 3ea0: ec5fa400 ed53d200 00000000 bf16a320 00000000 ec53e100 00000040 ec753eb8
[ 958.059059] 3ec0: ec51df00 ed53d7c0 ed53d200 ed53d7c0 00000000 ed53d7c0 ec5fa400 bf16ed70
[ 958.067230] 3ee0: 00000000 00000060 00000002 ed53d200 00000000 bf16acf4 ed53d7c0 ec752000
[ 958.075402] 3f00: ed980e50 e954f5d8 00000000 00000060 ed53d240 ed53d258 ec753f80 c04f44a8
[ 958.083574] 3f20: edb7910c ec664700 01ade920 c02e4c44 00000060 c016b3dc ec51de40 01adfb84
[ 958.091745] 3f40: 00000060 ec752000 ec753f80 ec752000 00000060 c0108444 00000007 ec51de48
[ 958.099914] 3f60: ed0eb8c0 00000000 00000000 ec51de40 01adfb84 00000001 00000060 c0108858
[ 958.108085] 3f80: 00000000 00000000 51cc8143 00000060 01adfb84 00000007 00000004 c000dd68
[ 958.116257] 3fa0: 00000000 c000dbc0 00000060 01adfb84 00000007 01adfb84 00000060 01adfb80
[ 958.124429] 3fc0: 00000060 01adfb84 00000007 00000004 beded1a8 00000000 01adf2f0 01ade920
[ 958.132599] 3fe0: 00000000 beded180 b6811324 b6811334 800f0010 00000007 2e7f5821 2e7f5c21
[ 958.140815] [<bf13e76c>] (ceph_osdc_build_request+0x8c/0x4f8 [libceph]) from [<bf166b68>] (rbd_osd_req_format_write+0x50/0x7c [rbd])
[ 958.152739] [<bf166b68>] (rbd_osd_req_format_write+0x50/0x7c [rbd]) from [<bf1688d4>] (rbd_dev_header_watch_sync+0xe0/0x204 [rbd])
[ 958.164486] [<bf1688d4>] (rbd_dev_header_watch_sync+0xe0/0x204 [rbd]) from [<bf16a320>] (rbd_dev_image_probe+0x23c/0x850 [rbd])
[ 958.175967] [<bf16a320>] (rbd_dev_image_probe+0x23c/0x850 [rbd]) from [<bf16acf4>] (rbd_add+0x3c0/0x918 [rbd])
[ 958.185975] [<bf16acf4>] (rbd_add+0x3c0/0x918 [rbd]) from [<c02e4c44>] (bus_attr_store+0x20/0x2c)
[ 958.194850] [<c02e4c44>] (bus_attr_store+0x20/0x2c) from [<c016b3dc>] (sysfs_write_file+0x168/0x198)
[ 958.203984] [<c016b3dc>] (sysfs_write_file+0x168/0x198) from [<c0108444>] (vfs_write+0x9c/0x170)
[ 958.212768] [<c0108444>] (vfs_write+0x9c/0x170) from [<c0108858>] (sys_write+0x3c/0x70)
[ 958.220768] [<c0108858>] (sys_write+0x3c/0x70) from [<c000dbc0>] (ret_fast_syscall+0x0/0x30)
[ 958.229199] Code: e59d1058 e5913000 e3530000 ba000114 (e7f001f2)
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Pull networking fixes from David Miller:
1) Found via trinity:
If you connect up an ipv6 socket to an ipv4 mapped address then an
ipv6 one, sendmsg() can croak because ip6_sk_dst_check() assumes the
route cached in the socket is an ipv6 one. In this case there is an
ipv4 route attached, so it gets stomped on.
Reported by Dave Jones and Hannes Frederic Sowa, fixed by Eric
Dumazet.
2) AF_KEY notifications leak some kernel memory to userspace, fix from
Mathias Krause.
3) DLCI calls __dev_get_by_name() without proper locking, and dlci_del
doesn't validate that the device being deleted is actually a DLCI
one. Fixes from Li Zefan.
4) Length check on bluetooth l2cap information responses is wrong, each
response type has a different lenth, so we should make sure it's in
a given range rather than enforce one single valid length. From
Jaganath Kanakkassery.
5) Receive FIFO overflow is really easy to trigger in stress scenerios
in the sh_eth driver, but the event isn't being handled properly at
all. Specifically, the mask of error interrupts doesn't include the
event so we never clear it, resulting in the driver becomming wedged
processing an interrupt that never gets cleared.
Fix from Sergei Shtylyov.
6) qlcnic sleeps while holding a spinlock, use mdelay() instead of
msleep(). From Shahed Shaikh.
7) Missing curly braces causes SIP netfilter NAT module to always drop
packets. Fix from Balazs Peter Odor.
8) ipt_ULOG in netfilter passes the wrong value to timer setup, causing
the timer to dereference crap when it fires. Fix from Gao Feng.
9) Missing RCU protection around txq->axq_acq traversal in
ath_txq_schedule(). Fix from Felix Fietkau.
10) Idle state transition test in ath9k_htc_config() is reversed, fix
from Sujith Manoharan.
11) IPV6 forwarding handles unicast Router Alert packets incorrectly.
It tests the wrong option state. Previously opt->ra being non-zero
indicated a router alert marking in the SKB, but now it's indicated
by a bit in opt->flags. Fix from YOSHIFUJI Hideaki.
12) SKB leak in GRE tunnel GSO handling, from Eric Dumazet.
13) get_user_pages_fast() error handling in TUN and MACVTAP use the same
local variable for the base index and the loop iterator for page
traversal, oops! Fix from Michael S Tsirkin.
14) ipv6_get_lladdr() can fail, and we must therefore check it's return
value in inet6_set_iftoken(). For from Hannes Frederic Sowa.
15) If you change an interface name and meanwhile can sneak in something
that looks up the name (like SO_BINDTODEVICE or SIOCGIFNAME) we can
deadlock with CONFIG_PREEMPT=n. Fix this by providing a helper
function that properly uses raw_seqcount_begin(). From Nicolas
Schichan.
16) Chain noise calibration test is inverted in iwlwifi, fix from
Nikolay Martynov.
17) Properly set TX iwlwifi descriptor flags for back requests. Fix
from Emmanuel Grumbach.
18) We can't assume skb_transport_header() is set in xt_TCPOPTSTRAP
module, fix from Pablo Neira Ayuso.
19) Some crummy APs don't provide the proper High Throughput info in
association response frames. Add a workaround by assume we'll use
whatever is in the beacon/probe. Fix from Johannes Berg.
20) mac80211 call to rate_idx_match_mask() swaps two arguments (mask and
channel width). Fix from Simon Wunderlich.
21) xt_TCPMSS (like xt_TCPOPTSTRAP) must not try to handle fragmented
frames. Fix from Phil Oester.
22) Fix rate control regression causing iwlwifi/iwlegacy chips to use
1Mbit/s on pre-11n networks. From Moshe Benji and Stanslaw Gruszka.
23) Disable brcmsmac power-save functions, they cause regressions. From
Arend van Spriel.
24) Enforce a sane minimum MTU in l2cap_build_cmd() otherwise we can
easily crash. Fix from Anderson Lizardo.
25) If a learning packet arrives during vxlan_stop() we crash, easily
fixed by checking netif_running(). From Stephen Hemminger.
26) Static vxlan FDB entries should not be migrated, also from Stephen.
27) skb_clone() failures not handled in vxlan_xmit(), oops. Also from
Stephen.
28) Add minimal driver for AR816x/AR817x ethernet chips, from Johannes
Berg.
29) Fix regression in userspace VLAN acceleration control, added by the
802.1ad support changes. Fix from Fernando Luis Vazquez Cao.
30) Interval selection for MLD queries in the bridging code was
reversed. Fix from Linus Lüssing.
31) ipv6's ndisc_send_redirect() erroneously writes to the packet we
received not the packet we are building to send out. Fix from
Matthias Schiffer.
32) Don't free netdev before unregistering it, in usb_8dev can driver.
From Marc Kleine-Budde.
33) Fix nl80211 attribute buffer races, from Johannes Berg.
34) Although netlink_diag.h is under uapi/ it isn't present in Kbuild.
35) Wrong address and family passed to MD5 key lookups in TCP, from
Aydin Arik.
36) phy_type attribute created by SFC driver should not be writable.
From Ben Hutchings.
37) Receive/Transmit queue allocations in pxa168_eth and mv643xx_eth
should use kzalloc(). Otherwise if setup fails half-way, we'll
dereference garbage when trying to teardown the rings. From Lubomir
Rintel.
38) Fix double-allocation of dst (resulting in unfreeable net device) in
ipv6's init_loopback(). From Gao Feng.
39) Fix fragmentation handling SKB leak in netfilter conntrack, we were
freeing the wrong skb pointer. From Phil Oester.
40) Don't report "-1" (SPEED_UNKNOWN) in bond_miimon_commit(), from
Nikolay Aleksandrov.
41) davinci_cpdma doesn't check for DMA mapping errors, letting the
device scribble to random addresses. From Sebastian Siewior.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (69 commits)
dlci: validate the net device in dlci_del()
dlci: acquire rtnl_lock before calling __dev_get_by_name()
af_key: fix info leaks in notify messages
ipv6: ip6_sk_dst_check() must not assume ipv6 dst
net: fix kernel deadlock with interface rename and netdev name retrieval.
net/tg3: Avoid delay during MMIO access
ipv6: check return value of ipv6_get_lladdr
macvtap: fix recovery from gup errors
tun: fix recovery from gup errors
gre: fix a possible skb leak
ipv6: Process unicast packet with Router Alert by checking flag in skb.
ath9k_htc: Handle IDLE state transition properly
ath9k: fix an RCU issue in calling ieee80211_get_tx_rates
netfilter: ipt_ULOG: fix incorrect setting of ulog timer
netfilter: ctnetlink: send event when conntrack label was modified
netfilter: nf_nat_sip: fix mangling
qlcnic: Do not sleep while holding spinlock
drivers: net: cpsw: fix compilation error with cpsw driver
tcp: doc : fix the syncookies default value
sh_eth: fix misreporting of transmit abort
When the kernel (compiled with CONFIG_PREEMPT=n) is performing the
rename of a network interface, it can end up waiting for a workqueue
to complete. If userland is able to invoke a SIOCGIFNAME ioctl or a
SO_BINDTODEVICE getsockopt in between, the kernel will deadlock due to
the fact that read_secklock_begin() will spin forever waiting for the
writer process (the one doing the interface rename) to update the
devnet_rename_seq sequence.
This patch fixes the problem by adding a helper (netdev_get_name())
and using it in the code handling the SIOCGIFNAME ioctl and
SO_BINDTODEVICE setsockopt.
The netdev_get_name() helper uses raw_seqcount_begin() to avoid
spinning forever, waiting for devnet_rename_seq->sequence to become
even. cond_resched() is used in the contended case, before retrying
the access to give the writer process a chance to finish.
The use of raw_seqcount_begin() will incur some unneeded work in the
reader process in the contended case, but this is better than
deadlocking the system.
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
commit 68c331631143 ("v4 GRE: Add TCP segmentation offload for GRE")
added a possible skb leak, because it frees only the head of segment
list, in case a skb_linearize() call fails.
This patch adds a kfree_skb_list() helper to fix the bug.
Cc: Pravin B Shelar <pshelar@nicira.com>
Cc: Daniel Borkmann <dborkman@redhat.com>
The interactions between the ACPI dock driver and the ACPI-based PCI
hotplug (acpiphp) are currently problematic because of ordering
issues during hot-remove operations.
First of all, the current ACPI glue code expects that physical
devices will always be deleted before deleting the companion ACPI
device objects. Otherwise, acpi_unbind_one() will fail with a
warning message printed to the kernel log, for example:
[ 185.026073] usb usb5: Oops, 'acpi_handle' corrupt
[ 185.035150] pci 0000:1b:00.0: Oops, 'acpi_handle' corrupt
[ 185.035515] pci 0000:18:02.0: Oops, 'acpi_handle' corrupt
[ 180.013656] port1: Oops, 'acpi_handle' corrupt
This means, in particular, that struct pci_dev objects have to
be deleted before the struct acpi_device objects they are "glued"
with.
Now, the following happens the during the undocking of an ACPI-based
dock station:
1) hotplug_dock_devices() invokes registered hotplug callbacks to
destroy physical devices associated with the ACPI device objects
depending on the dock station. It calls dd->ops->handler() for
each of those device objects.
2) For PCI devices dd->ops->handler() points to
handle_hotplug_event_func() that queues up a separate work item
to execute _handle_hotplug_event_func() for the given device and
returns immediately. That work item will be executed later.
3) hotplug_dock_devices() calls dock_remove_acpi_device() for each
device depending on the dock station. This runs acpi_bus_trim()
for each of them, which causes the underlying ACPI device object
to be destroyed, but the work items queued up by
handle_hotplug_event_func() haven't been started yet.
4) _handle_hotplug_event_func() queued up in step 2) are executed
and cause the above failure to happen, because the PCI devices
they handle do not have the companion ACPI device objects any
more (those objects have been deleted in step 3).
The possible breakage doesn't end here, though, because
hotplug_dock_devices() may return before at least some of the
_handle_hotplug_event_func() work items spawned by it have a
chance to complete and then undock() will cause _DCK to be
evaluated and that will cause the devices handled by the
_handle_hotplug_event_func() to go away possibly while they are
being accessed.
This means that dd->ops->handler() for PCI devices should not point
to handle_hotplug_event_func(). Instead, it should point to a
function that will do the work of _handle_hotplug_event_func()
synchronously. For this reason, introduce such a function,
hotplug_event_func(), and modity acpiphp_dock_ops to point to
it as the handler.
Unfortunately, however, this is not sufficient, because if the dock
code were not changed further, hotplug_event_func() would now
deadlock with hotplug_dock_devices() that called it, since it would
run unregister_hotplug_dock_device() which in turn would attempt to
acquire the dock station's hp_lock mutex already acquired by
hotplug_dock_devices().
To resolve that deadlock use the observation that
unregister_hotplug_dock_device() won't need to acquire hp_lock
if PCI bridges the devices on the dock station depend on are
prevented from being removed prematurely while the first loop in
hotplug_dock_devices() is in progress.
To make that possible, introduce a mechanism by which the callers of
register_hotplug_dock_device() can provide "init" and "release"
routines that will be executed, respectively, during the addition
and removal of the physical device object associated with the
given ACPI device handle. Make acpiphp use two new functions,
acpiphp_dock_init() and acpiphp_dock_release(), that call
get_bridge() and put_bridge(), respectively, on the acpiphp bridge
holding the given device, for this purpose.
In addition to that, remove the dock station's list of
"hotplug devices" and make the dock code always walk the whole list
of "dependent devices" instead in such a way that the loops in
hotplug_dock_devices() and dock_event() (replacing the loops over
"hotplug devices") will take references to the list entries that
register_hotplug_dock_device() has been called for. That prevents
the "release" routines associated with those entries from being
called while the given entry is being processed and for PCI
devices this means that their bridges won't be removed (by a
concurrent thread) while hotplug_event_func() handling them is
being executed.
This change is based on two earlier patches from Jiang Liu.
References: https://bugzilla.kernel.org/show_bug.cgi?id=59501
Reported-and-tested-by: Alexander E. Patrakov <patrakov@gmail.com>
Tracked-down-by: Jiang Liu <jiang.liu@huawei.com>
Tested-by: Illya Klymov <xanf@xanf.me>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Cc: 3.9+ <stable@vger.kernel.org>
Pull vfs fixes from Al Viro:
"Several fixes for bugs caught while looking through f_pos (ab)users"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
aout32 coredump compat fix
splice: don't pass the address of ->f_pos to methods
mconsole: we'd better initialize pos before passing it to vfs_read()...
Pull ACPI fixes from Rafael Wysocki:
- Fix for a regression causing a failure to turn on some devices on
some systems during initialization introduced by a recent revert of
an ACPI PM change that broke something else. Fortunately, we know
exactly what devices are affected, so we can add a fix just for them
leaving everyone else alone.
- ACPI power resources initialization fix preventing a NULL pointer
from being dereferenced in the acpi_add_power_resource() error code
path.
- ACPI dock station driver fix that adds missing locking to
write_undock().
- ACPI resources allocation fix changing the scope of an old workaround
so that it doesn't affect systems that aren't actually buggy. This
was reported a couple of days ago to fix DMA problems on some new
platforms so we need it in -stable. From Mika Westerberg.
* tag 'acpi-3.10-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / LPSS: Power up LPSS devices during enumeration
ACPI / PM: Fix error code path for power resources initialization
ACPI / dock: Take ACPI scan lock in write_undock()
ACPI / resources: call acpi_get_override_irq() only for legacy IRQ resources
Pull scheduler fixes from Ingo Molnar:
"Two smaller fixes - plus a context tracking tracing fix that is a bit
bigger"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tracing/context-tracking: Add preempt_schedule_context() for tracing
sched: Fix clear NOHZ_BALANCE_KICK
sched/x86: Construct all sibling maps if smt
Pull perf fixes from Ingo Molnar:
"Four fixes. The mmap ones are unfortunately larger than desired -
fuzzing uncovered bugs that needed perf context life time management
changes to fix properly"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86: Fix broken PEBS-LL support on SNB-EP/IVB-EP
perf: Fix mmap() accounting hole
perf: Fix perf mmap bugs
kprobes: Fix to free gone and unused optprobes
Pull timer fixes from Thomas Gleixner:
- Fix inconstinant clock usage in virtual time accounting
- Fix a build error in KVM caused by the NOHZ work
- Remove a pointless timekeeping duty assignment which breaks NOHZ
- Use a proper notifier return value to avoid random behaviour
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tick: Remove useless timekeeping duty attribution to broadcast source
nohz: Fix notifier return val that enforce timekeeping
kvm: Move guest entry/exit APIs to context_tracking
vtime: Use consistent clocks among nohz accounting
After addition of 8021AD h_vlan_proto can be either ETH_P_8021Q or
ETH_P_8021AD.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
The netlink_diag.h is in include/uapi/linux but not in the Kbuild necessary
to cause it to be exported by make headers_install.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Commit 7cd8407 (ACPI / PM: Do not execute _PS0 for devices without
_PSC during initialization) introduced a regression on some systems
with Intel Lynxpoint Low-Power Subsystem (LPSS) where some devices
need to be powered up during initialization, but their device objects
in the ACPI namespace have _PS0 and _PS3 only (without _PSC or power
resources).
To work around this problem, make the ACPI LPSS driver power up
devices it knows about by using a new helper function
acpi_device_fix_up_power() that does all of the necessary
sanity checks and calls acpi_dev_pm_explicit_set() to put the
device into D0.
Reported-and-tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Dave Jones hit the following bug report:
[ INFO: suspicious RCU usage. ]
3.10.0-rc2+ #1 Not tainted
include/linux/rcupdate.h:771 rcu_read_lock() used illegally while idle!
RCU used illegally from idle CPU! rcu_scheduler_active = 1, debug_locks = 0
RCU used illegally from extended quiescent state!
2 locks held by cc1/63645:
#0: (&rq->lock){-.-.-.}, at: [<ffffffff816b39fd>] __schedule+0xed/0x9b0
#1: (rcu_read_lock){.+.+..}, at: [<ffffffff8109d645>] cpuacct_charge+0x5/0x1f0
CPU: 1 PID: 63645 Comm: cc1 Not tainted 3.10.0-rc2+ #1 [loadavg: 40.57 27.55 13.39 25/277 64369]
Hardware name: Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H, BIOS F12a 04/23/2010
0000000000000000 ffff88010f78fcf8 ffffffff816ae383 ffff88010f78fd28
ffffffff810b698d ffff88011c092548 000000000023d073 ffff88011c092500
0000000000000001 ffff88010f78fd60 ffffffff8109d7c5 ffffffff8109d645
Call Trace:
[<ffffffff816ae383>] dump_stack+0x19/0x1b
[<ffffffff810b698d>] lockdep_rcu_suspicious+0xfd/0x130
[<ffffffff8109d7c5>] cpuacct_charge+0x185/0x1f0
[<ffffffff8109d645>] ? cpuacct_charge+0x5/0x1f0
[<ffffffff8108dffc>] update_curr+0xec/0x240
[<ffffffff8108f528>] put_prev_task_fair+0x228/0x480
[<ffffffff816b3a71>] __schedule+0x161/0x9b0
[<ffffffff816b4721>] preempt_schedule+0x51/0x80
[<ffffffff816b4800>] ? __cond_resched_softirq+0x60/0x60
[<ffffffff816b6824>] ? retint_careful+0x12/0x2e
[<ffffffff810ff3cc>] ftrace_ops_control_func+0x1dc/0x210
[<ffffffff816be280>] ftrace_call+0x5/0x2f
[<ffffffff816b681d>] ? retint_careful+0xb/0x2e
[<ffffffff816b4805>] ? schedule_user+0x5/0x70
What happened was that the function tracer traced the schedule_user() code
that tells RCU that the system is coming back from userspace, and to
add the CPU back to the RCU monitoring.
Because the function tracer does a preempt_disable/enable_notrace() calls
the preempt_enable_notrace() checks the NEED_RESCHED flag. If it is set,
then preempt_schedule() is called. But this is called before the user_exit()
function can inform the kernel that the CPU is no longer in user mode and
needs to be accounted for by RCU.
The fix is to create a new preempt_schedule_context() that checks if
the kernel is still in user mode and if so to switch it to kernel mode
before calling schedule. It also switches back to user mode coming back
from schedule in need be.
The only user of this currently is the preempt_enable_notrace(), which is
only used by the tracing subsystem.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1369423420.6828.226.camel@gandalf.local.home
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"Series of fixes for 3.10. There are some usual driver fixes (mostly
on s5p/exynos playform drivers), plus some fixes at V4L2 core"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (40 commits)
[media] soc_camera: error dev remove and v4l2 call
[media] sh_veu: fix the buffer size calculation
[media] sh_veu: keep power supply until the m2m context is released
[media] sh_veu: invoke v4l2_m2m_job_finish() even if a job has been aborted
[media] v4l2-ioctl: don't print the clips list
[media] v4l2-ctrls: V4L2_CTRL_CLASS_FM_RX controls are also valid radio controls
[media] cx88: fix NULL pointer dereference
[media] DocBook/media/v4l: update version number
[media] exynos4-is: Remove "sysreg" clock handling
[media] exynos4-is: Fix reported colorspace at FIMC-IS-ISP subdev
[media] exynos4-is: Ensure fimc-is clocks are not enabled until properly configured
[media] exynos4-is: Prevent NULL pointer dereference when firmware isn't loaded
[media] s5p-mfc: Add NULL check for allocated buffer
[media] s5p-mfc: added missing end-of-lines in debug messages
[media] s5p-mfc: v4l2 controls setup routine moved to initialization code
[media] s5p-mfc: separate encoder parameters for h264 and mpeg4
[media] s5p-mfc: Remove special clock usage in driver
[media] s5p-mfc: Remove unused s5p_mfc_get_decoded_status_v6() function
[media] v4l2: mem2mem: save irq flags correctly
[media] coda: v4l2-compliance fix: add VIDIOC_CREATE_BUFS support
1) Fix RTNL locking in batman-adv, from Matthias Schiffer.
2) Don't allow non-passthrough macvlan devices to set NOPROMISC via
netlink, otherwise we can end up with corrupted promisc counter
values on the device. From Michael S Tsirkin.
3) Fix stmmac driver build with debugging defines enabled, from Dinh
Nguyen.
4) Make sure name string we give in socket address in AF_PACKET is NULL
terminated, from Daniel Borkmann.
5) Fix leaking of two uninitialized bytes of memory to userspace in
l2tp, from Guillaume Nault.
6) Clear IPCB(skb) before tunneling otherwise we touch dangling IP
options state and crash. From Saurabh Mohan.
7) Fix suspend/resume for davinci_mdio by using suspend_late and
resume_early. From Mugunthan V N.
8) Don't tag ip_tunnel_init_net and ip_tunnel_delete_net with
__net_{init,exit}, they can be called outside of those contexts.
From Eric Dumazet.
9) Fix RX length error in sh_eth driver, from Yoshihiro Shimoda.
10) Fix missing sctp_outq initialization in some code paths of SCTP
stack, from Neil Horman.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (21 commits)
sctp: fully initialize sctp_outq in sctp_outq_init
netiucv: Hold rtnl between name allocation and device registration.
tulip: Properly check dma mapping result
net: sh_eth: fix incorrect RX length error if R8A7740
ip_tunnel: remove __net_init/exit from exported functions
drivers: net: davinci_mdio: restore mdio clk divider in mdio resume
drivers: net: davinci_mdio: moving mdio resume earlier than cpsw ethernet driver
net/ipv4: ip_vti clear skb cb before tunneling.
tg3: Wait for boot code to finish after power on
l2tp: Fix sendmsg() return value
l2tp: Fix PPP header erasure and memory leak
bonding: fix igmp_retrans type and two related races
bonding: reset master mac on first enslave failure
packet: packet_getname_spkt: make sure string is always 0-terminated
net: ethernet: stmicro: stmmac: Fix compile error when STMMAC_XMIT_DEBUG used
be2net: Fix 32-bit DMA Mask handling
xen-netback: don't de-reference vif pointer after having called xenvif_put()
macvlan: don't touch promisc without passthrough
batman-adv: Don't handle address updates when bla is disabled
batman-adv: forward late OGMs from best next hop
Thanks to commit f91eb62f71b3 ("init: scream bloody murder if interrupts
are enabled too early"), "bloody murder" is now being screamed.
With a MIPS OCTEON config, we use on_each_cpu() in our
irq_chip.irq_bus_sync_unlock() function. This gets called in early as a
result of the time_init() call. Because the !SMP version of
on_each_cpu() unconditionally enables irqs, we get:
WARNING: at init/main.c:560 start_kernel+0x250/0x410()
Interrupts were enabled early
CPU: 0 PID: 0 Comm: swapper Not tainted 3.10.0-rc5-Cavium-Octeon+ #801
Call Trace:
show_stack+0x68/0x80
warn_slowpath_common+0x78/0xb0
warn_slowpath_fmt+0x38/0x48
Suggested fix: Do what we already do in the SMP version of
on_each_cpu(), and use local_irq_save/local_irq_restore. Because we
need a flags variable, make it a static inline to avoid name space
issues.
[ Change from v1: Convert on_each_cpu to a static inline function, add
#include <linux/irqflags.h> to avoid build breakage on some files.
on_each_cpu_mask() and on_each_cpu_cond() suffer the same problem as
on_each_cpu(), but they are not causing !SMP bugs for me, so I will
defer changing them to a less urgent patch. ]
Signed-off-by: David Daney <david.daney@cavium.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu
Pull RCU fixes from Paul McKenney:
"I must confess that this past merge window was not RCU's best showing.
This series contains three more fixes for RCU regressions:
1. A fix to __DECLARE_TRACE_RCU() that causes it to act as an
interrupt from idle rather than as a task switch from idle.
This change is needed due to the recent use of _rcuidle()
tracepoints that can be invoked from interrupt handlers as well
as from idle. Without this fix, invoking _rcuidle() tracepoints
from interrupt handlers results in splats and (more seriously)
confusion on RCU's part as to whether a given CPU is idle or not.
This confusion can in turn result in too-short grace periods and
therefore random memory corruption.
2. A fix to a subtle deadlock that could result due to RCU doing
a wakeup while holding one of its rcu_node structure's locks.
Although the probability of occurrence is low, it really
does happen. The fix, courtesy of Steven Rostedt, uses
irq_work_queue() to avoid the deadlock.
3. A fix to a silent deadlock (invisible to lockdep) due to the
interaction of timeouts posted by RCU debug code enabled by
CONFIG_PROVE_RCU_DELAY=y, grace-period initialization, and CPU
hotplug operations. This will not occur in production kernels,
but really does occur in randconfig testing. Diagnosis courtesy
of Steven Rostedt"
* 'rcu/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu:
rcu: Fix deadlock with CPU hotplug, RCU GP init, and timer migration
rcu: Don't call wakeup() with rcu_node structure ->lock held
trace: Allow idle-safe tracepoints to be called from irq
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound
Pull ASoC sound updates from Mark Brown:
"Takashi is travelling at the minute and it'd be good to get the
MAINTAINERS update in here merged so sending directly.
As well as the usual driver specifics we've got a couple of core fixes
here, one fixing capabilities for unidirectional streams and the other
fixing suspend while audio streams are active.
The suspend fix is a little involved but mostly as a result of
removing some special casing that was doing the wrong thing."
* tag 'asoc-v3.10-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound:
ASoC: tlv320aic3x: Remove deadlock from snd_soc_dapm_put_volsw_aic3x()
ASoC: dapm: Treat DAI widgets like AIF widgets for power
ASoC: arizona: Correct AEC loopback enable
ASoC: pcm: Require both CODEC and CPU support when declaring stream caps
MAINTAINERS: Remove myself from Wolfson maintainers
ASoC: wm8994: Ensure microphone detection state is reset on removal
ASoC: wm8994: Avoid leaking pm_runtime reference on removed jack race
ASoC: cs42l52: fix hp_gain_enum shift value.
ASoC: cs42l52: use correct PCM mixer TLV dB scale to match datasheet.
If CONFIG_NET_NS is not set then __net_init is the same as __init and
__net_exit is the same as __exit. These functions will be removed from
memory after the module loads or is removed. Functions that are exported
for use by other functions should never be labeled for removal.
Bug introduced by commit c54419321455631079c
("GRE: Refactor GRE tunneling code.")
Reported-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
Pull networking update from David Miller:
1) Fix dump iterator in nfnl_acct_dump() and ctnl_timeout_dump() to
dump all objects properly, from Pablo Neira Ayuso.
2) xt_TCPMSS must use the default MSS of 536 when no MSS TCP option is
present. Fix from Phil Oester.
3) qdisc_get_rtab() looks for an existing matching rate table and uses
that instead of creating a new one. However, it's key matching is
incomplete, it fails to check to make sure the ->data[] array is
identical too. Fix from Eric Dumazet.
4) ip_vs_dest_entry isn't fully initialized before copying back to
userspace, fix from Dan Carpenter.
5) Fix ubuf reference counting regression in vhost_net, from Jason
Wang.
6) When sock_diag dumps a socket filter back to userspace, we have to
translate it out of the kernel's internal representation first.
From Nicolas Dichtel.
7) davinci_mdio holds a spinlock while calling pm_runtime, which
sleeps. Fix from Sebastian Siewior.
8) Timeout check in sh_eth_check_reset is off by one, from Sergei
Shtylyov.
9) If sctp socket init fails, we can NULL deref during cleanup. Fix
10) netlink_mmap() does not propagate errors properly, from Patrick
McHardy.
11) Disable powersave and use minstrel by default in ath9k. From Sujith
Manoharan.
12) Fix a regression in that SOCK_ZEROCOPY is not set on tuntap sockets
which prevents vhost from being able to use zerocopy. From Jason
Wang.
13) Fix race between port lookup and TX path in team driver, from Jiri
Pirko.
14) Missing length checks in bluetooth L2CAP packet parsing, from Johan
Hedberg.
15) rtlwifi fails to connect to networking using any encryption method
other than WPA2. Fix from Larry Finger.
16) Fix iwlegacy build due to incorrect CONFIG_* ifdeffing for power
management stuff. From Yijing Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (35 commits)
b43: stop format string leaking into error msgs
ath9k: Use minstrel rate control by default
Revert "ath9k_hw: Update rx gain initval to improve rx sensitivity"
ath9k: Disable PowerSave by default
net: wireless: iwlegacy: fix build error for il_pm_ops
rtlwifi: Fix a false leak indication for PCI devices
wl12xx/wl18xx: scan all 5ghz channels
wl12xx: increase minimum singlerole firmware version required
wl12xx: fix minimum required firmware version for wl127x multirole
rtlwifi: rtl8192cu: Fix problem in connecting to WEP or WPA(1) networks
mwifiex: debugfs: Fix out of bounds array access
Bluetooth: Fix mgmt handling of power on failures
Bluetooth: Fix missing length checks for L2CAP signalling PDUs
Bluetooth: btmrvl: support Marvell Bluetooth device SD8897
Bluetooth: Fix checks for LE support on LE-only controllers
team: fix checks in team_get_first_port_txable_rcu()
team: move add to port list before port enablement
team: check return value of team_get_port_by_index_rcu() for NULL
tuntap: set SOCK_ZEROCOPY flag during open
netlink: fix error propagation in netlink_mmap()
Pull block layer fixes from Jens Axboe:
"Outside of bcache (which really isn't super big), these are all
few-liners. There are a few important fixes in here:
- Fix blk pm sleeping when holding the queue lock
- A small collection of bcache fixes that have been done and tested
since bcache was included in this merge window.
- A fix for a raid5 regression introduced with the bio changes.
- Two important fixes for mtip32xx, fixing an oops and potential data
corruption (or hang) due to wrong bio iteration on stacked devices."
* 'for-linus' of git://git.kernel.dk/linux-block:
scatterlist: sg_set_buf() argument must be in linear mapping
raid5: Initialize bi_vcnt
pktcdvd: silence static checker warning
block: remove refs to XD disks from documentation
blkpm: avoid sleep when holding queue lock
mtip32xx: Correctly handle bio->bi_idx != 0 conditions
mtip32xx: Fix NULL pointer dereference during module unload
bcache: Fix error handling in init code
bcache: clarify free/available/unused space
bcache: drop "select CLOSURES"
bcache: Fix incompatible pointer type warning
There is div64_long() to handle the s64/long division, but no mocro do
u64/ul division. It is necessary in some scenarios, so add this
function.
Signed-off-by: Alex Shi <alex.shi@intel.com>
When we have a page fault for the address which is backed by a hugepage
under migration, the kernel can't wait correctly and do busy looping on
hugepage fault until the migration finishes. As a result, users who try
to kick hugepage migration (via soft offlining, for example) occasionally
experience long delay or soft lockup.
This is because pte_offset_map_lock() can't get a correct migration entry
or a correct page table lock for hugepage. This patch introduces
migration_entry_wait_huge() to solve this.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: <stable@vger.kernel.org> [2.6.35+]
The dmesg_restrict sysctl currently covers the syslog method for access
dmesg, however /dev/kmsg isn't covered by the same protections. Most
people haven't noticed because util-linux dmesg(1) defaults to using the
syslog method for access in older versions. With util-linux dmesg(1)
defaults to reading directly from /dev/kmsg.
To fix /dev/kmsg, let's compare the existing interfaces and what they
allow:
- /proc/kmsg allows:
- open (SYSLOG_ACTION_OPEN) if CAP_SYSLOG since it uses a destructive
single-reader interface (SYSLOG_ACTION_READ).
- everything, after an open.
- syslog syscall allows:
- anything, if CAP_SYSLOG.
- SYSLOG_ACTION_READ_ALL and SYSLOG_ACTION_SIZE_BUFFER, if
dmesg_restrict==0.
- nothing else (EPERM).
The use-cases were:
- dmesg(1) needs to do non-destructive SYSLOG_ACTION_READ_ALLs.
- sysklog(1) needs to open /proc/kmsg, drop privs, and still issue the
destructive SYSLOG_ACTION_READs.
AIUI, dmesg(1) is moving to /dev/kmsg, and systemd-journald doesn't
clear the ring buffer.
Based on the comments in devkmsg_llseek, it sounds like actions besides
reading aren't going to be supported by /dev/kmsg (i.e.
SYSLOG_ACTION_CLEAR), so we have a strict subset of the non-destructive
syslog syscall actions.
To this end, move the check as Josh had done, but also rename the
constants to reflect their new uses (SYSLOG_FROM_CALL becomes
SYSLOG_FROM_READER, and SYSLOG_FROM_FILE becomes SYSLOG_FROM_PROC).
SYSLOG_FROM_READER allows non-destructive actions, and SYSLOG_FROM_PROC
allows destructive actions after a capabilities-constrained
SYSLOG_ACTION_OPEN check.
- /dev/kmsg allows:
- open if CAP_SYSLOG or dmesg_restrict==0
- reading/polling, after open
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=903192
[akpm@linux-foundation.org: use pr_warn_once()]
Reported-by: Christian Kujau <lists@nerdbynature.de>
Tested-by: Josh Boyer <jwboyer@redhat.com>
Cc: Kay Sievers <kay@vrfy.org>
There are instances in the kernel where we would like to disable CPU
hotplug (from sysfs) during some important operation. Today the freezer
code depends on this and the code to do it was kinda tailor-made for
that.
Restructure the code and make it generic enough to be useful for other
usecases too.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Shawn Guo <shawn.guo@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
If hci_dev_open fails we need to ensure that the corresponding
mgmt_set_powered command gets an appropriate response. This patch fixes
the missing response by adding a new mgmt_set_powered_failed function
that's used to indicate a power on failure to mgmt. Since a situation
with the device being rfkilled may require special handling in user
space the patch uses a new dedicated mgmt status code for this.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Cc: stable@vger.kernel.org
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
should be checked if "cur" is txable, not "port".
Introduced by commit 6e88e1357c "team: use function team_port_txable()
for determing enabled and up port"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Pull kvm bugfixes from Gleb Natapov:
"There is one more fix for MIPS KVM ABI here, MIPS and PPC build
breakage fixes and a couple of PPC bug fixes"
* 'fixes' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvm/ppc/booke64: Fix lazy ee handling in kvmppc_handle_exit()
kvm/ppc/booke: Hold srcu lock when calling gfn functions
kvm/ppc/booke64: Disable e6500 support
kvm/ppc/booke64: Fix AltiVec interrupt numbers and build breakage
mips/kvm: Use KVM_REG_MIPS and proper size indicators for *_ONE_REG
kvm: Add definition of KVM_REG_MIPS
KVM: add kvm_para_available to asm-generic/kvm_para.h
We use 0x7000000000000000ULL as 0x6000000000000000ULL is reserved for
ARM64.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
