commit aad560b7f63b495f48a7232fd086c5913a676e6f upstream.
At IO preparation we calculate the max pages at each device and
allocate a BIO per device of that size. The calculation was wrong
on some unaligned corner cases offset/length combination and would
make prepare return with -ENOMEM. This would be bad for pnfs-objects
that would in that case IO through MDS. And fatal for exofs were it
would fail writes with EIO.
Fix it by doing the proper math, that will work in all cases. (I
ran a test with all possible offset/length combinations this time
round).
Also when reading we do not need to allocate for the parity units
since we jump over them.
Also lower the max_io_length to take into account the parity pages
so not to allocate BIOs bigger than PAGE_SIZE
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit d8d14bd09cddbaf0168d61af638455a26bd027ff upstream.
Commit d5dc77bfeeab ("consolidate compat lookup_dcookie()") coverted all
architectures to the new compat_sys_lookup_dcookie() syscall.
The "len" paramater of the new compat syscall must have the type
compat_size_t in order to enforce zero extension for architectures where
the ABI requires that the caller of a function performed zero and/or
sign extension to 64 bit of all parameters.
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
commit dfd948e32af2e7b28bcd7a490c0a30d4b8df2a36 upstream.
We got a report that the pwritev syscall does not work correctly in
compat mode on s390.
It turned out that with commit 72ec35163f9f ("switch compat readv/writev
variants to COMPAT_SYSCALL_DEFINE") we lost the zero extension of a
couple of syscall parameters because the some parameter types haven't
been converted from unsigned long to compat_ulong_t.
This is needed for architectures where the ABI requires that the caller
of a function performed zero and/or sign extension to 64 bit of all
parameters.
commit a1c3bfb2f67ef766de03f1f56bdfff9c8595ab14 upstream.
The VM is currently heavily tuned to avoid swapping. Whether that is
good or bad is a separate discussion, but as long as the VM won't swap
to make room for dirty cache, we can not consider anonymous pages when
calculating the amount of dirtyable memory, the baseline to which
dirty_background_ratio and dirty_ratio are applied.
A simple workload that occupies a significant size (40+%, depending on
memory layout, storage speeds etc.) of memory with anon/tmpfs pages and
uses the remainder for a streaming writer demonstrates this problem. In
that case, the actual cache pages are a small fraction of what is
considered dirtyable overall, which results in an relatively large
portion of the cache pages to be dirtied. As kswapd starts rotating
these, random tasks enter direct reclaim and stall on IO.
Only consider free pages and file pages dirtyable.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Tejun Heo <tj@kernel.org>
Tested-by: Tejun Heo <tj@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 06bdadd7634551cfe8ce071fe44d0311b3033d9e upstream.
audit_syscall_exit() saves a result of regs_return_value() in intermediate
"int" variable and passes it to __audit_syscall_exit(), which expects its
second argument as a "long" value. This will result in truncating the
value returned by a system call and making a wrong audit record.
I don't know why gcc compiler doesn't complain about this, but anyway it
causes a problem at runtime on arm64 (and probably most 64-bit archs).
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 28a625cbc2a14f17b83e47ef907b2658576a32aa upstream.
Having this struct in module memory could Oops when if the module is
unloaded while the buffer still persists in a pipe.
Since sock_pipe_buf_ops is essentially the same as fuse_dev_pipe_buf_steal
merge them into nosteal_pipe_buf_ops (this is the same as
default_pipe_buf_ops except stealing the page from the buffer is not
allowed).
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit ecd75ad514d73efc1bbcc5f10a13566c3ace5f53 upstream.
For some reason, some early WD drives spin up and down drives
erratically when the link is put into slumber mode which can reduce
the life expectancy of the device significantly. Unfortunately, we
don't have full list of devices and given the nature of the issue it'd
be better to err on the side of false positives than the other way
around. Let's disable LPM on all WD devices which match one of the
known problematic model prefixes and are SATA-I.
As horkage list doesn't support matching SATA capabilities, this is
implemented as two horkages - WD_BROKEN_LPM and NOLPM. The former is
set for the known prefixes and sets the latter if the matched device
is SATA-I.
Note that this isn't optimal as this disables all LPM operations and
partial link power state reportedly works fine on these; however, the
way LPM is implemented in libata makes it difficult to precisely map
libata LPM setting to specific link power state. Well, these devices
are already fairly outdated. Let's just disable whole LPM for now.
Reported-and-tested-by: Nikos Barkas <levelwol@gmail.com>
Reported-and-tested-by: Ioannis Barkas <risc4all@yahoo.com>
References: https://bugzilla.kernel.org/show_bug.cgi?id=57211
commit 27c73ae759774e63313c1fbfeb17ba076cea64c5 upstream.
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Guillaume Morin <guillaume@morinfr.org>
commit f92f455f67fef27929e6043499414605b0c94872 upstream.
{,set}page_address() are macros if WANT_PAGE_VIRTUAL. If
!WANT_PAGE_VIRTUAL, they're plain C functions.
If someone calls them with a void *, this pointer is auto-converted to
struct page * if !WANT_PAGE_VIRTUAL, but causes a build failure on
architectures using WANT_PAGE_VIRTUAL (arc, m68k and sparc64):
drivers/md/bcache/bset.c: In function `__btree_sort':
drivers/md/bcache/bset.c:1190: warning: dereferencing `void *' pointer
drivers/md/bcache/bset.c:1190: error: request for member `virtual' in something not a structure or union
Convert them to static inline functions to fix this. There are already
plenty of users of struct page members inside <linux/mm.h>, so there's
no reason to keep them as macros.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: David Rientjes <rientjes@google.com>
[ Upstream commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ]
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
[ Upstream commit 12663bfc97c8b3fdb292428105dd92d563164050 ]
unix_dgram_recvmsg() will hold the readlock of the socket until recv
is complete.
In the same time, we may try to setsockopt(SO_PEEK_OFF) which will hang until
unix_dgram_recvmsg() will complete (which can take a while) without allowing
us to break out of it, triggering a hung task spew.
Instead, allow set_peek_off to fail, this way userspace will not hang.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
commit 0d651e4e65e96989f72236bf83bd4c6e55eb6ce4 upstream.
Switching between reading the virtual or physical counters is
problematic, as some core code wants a view of time before we're fully
set up. Using a function pointer and switching the source after the
first read can make time appear to go backwards, and having a check in
the read function is an unfortunate block on what we want to be a fast
path.
Instead, this patch makes us always use the virtual counters. If we're a
guest, or don't have hyp mode, we'll use the virtual timers, and as such
don't care about CNTVOFF as long as it doesn't change in such a way as
to make time appear to travel backwards. As the guest will use the
virtual timers, a (potential) KVM host must use the physical timers
(which can wake up the host even if they fire while a guest is
executing), and hence a host must have CNTVOFF set to zero so as to have
a consistent view of time between the physical timers and virtual
counters.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Mark Brown <broonie@kernel.org>
commit dd935f44a40f8fb02aff2cc0df2269c92422df1c upstream.
Without a way to flush the osd client's notify workqueue, a watch
event that is unregistered could continue receiving callbacks
indefinitely.
Unregistering the event simply means no new notifies are added to the
queue, but there may still be events in the queue that will call the
watch callback for the event. If the queue is flushed after the event
is unregistered, the caller can be sure no more watch callbacks will
occur for the canceled watch.
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@linaro.org>
commit eb845ff13a44477f8a411baedbf11d678b9daf0a upstream.
handle_reply() calls complete_request() only if the first OSD reply
has ONDISK flag.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
table updates
commit af2c1401e6f9177483be4fad876d0073669df9df upstream.
According to documentation on barriers, stores issued before a LOCK can
complete after the lock implying that it's possible tlb_flush_pending
can be visible after a page table update. As per revised documentation,
this patch adds a smp_mb__before_spinlock to guarantee the correct
ordering.
commit 20841405940e7be0617612d521e206e4b6b325db upstream.
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
commit e0acd0a68ec7dbf6b7a81a87a867ebd7ac9b76c4 upstream.
This is only theoretical, but after try_to_wake_up(p) was changed
to check p->state under p->pi_lock the code like
__set_current_state(TASK_INTERRUPTIBLE);
schedule();
can miss a signal. This is the special case of wait-for-condition,
it relies on try_to_wake_up/schedule interaction and thus it does
not need mb() between __set_current_state() and if(signal_pending).
However, this __set_current_state() can move into the critical
section protected by rq->lock, now that try_to_wake_up() takes
another lock we need to ensure that it can't be reordered with
"if (signal_pending(current))" check inside that section.
The patch is actually one-liner, it simply adds smp_wmb() before
spin_lock_irq(rq->lock). This is what try_to_wake_up() already
does by the same reason.
We turn this wmb() into the new helper, smp_mb__before_spinlock(),
for better documentation and to allow the architectures to change
the default implementation.
While at it, kill smp_mb__after_lock(), it has no callers.
Perhaps we can also add smp_mb__before/after_spinunlock() for
prepare_to_wait().
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 966fbe193f47c68e70a80ec9991098e88e7959cb upstream.
Some device require DMADIR to be enabled, but are not detected as such
by atapi_id_dmadir. One such example is "Asus Serillel 2"
SATA-host-to-PATA-device bridge: the bridge itself requires DMADIR,
even if the bridged device does not.
As atapi_dmadir module parameter can cause problems with some devices
(as per Tejun Heo's memory), enabling it globally may not be possible
depending on the hardware.
This patch adds atapi_dmadir in the form of a "force" horkage value,
allowing global, per-bus and per-device control.
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
commit f60900f2609e893c7f8d0bccc7ada4947dac4cd5 upstream.
Commit 2171364d1a92 ("powerpc: Add HWCAP2 aux entry") introduced a new
AT_ auxv entry type AT_HWCAP2 but failed to update AT_VECTOR_SIZE_BASE
accordingly.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Fixes: 2171364d1a92 (powerpc: Add HWCAP2 aux entry)
Acked-by: Michael Neuling <michael@neuling.org>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
commit d00adcc8ae9e22eca9d8af5f66c59ad9a74c90ec upstream.
Fixes rendering corruption due to incorrect
gfx configuration.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=63599
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 95cadace8f3959282e76ebf8b382bd0930807d2c upstream.
This patch allows FILEIO to update hw_max_sectors based on the current
max_bytes_per_io. This is required because vfs_[writev,readv]() can accept
a maximum of 2048 iovecs per call, so the enforced hw_max_sectors really
needs to be calculated based on block_size.
This addresses a >= v3.5 bug where block_size=512 was rejecting > 1M
sized I/O requests, because FD_MAX_SECTORS was hardcoded to 2048 for
the block_size=4096 case.
(v2: Use max_bytes_per_io instead of ->update_hw_max_sectors)
Reported-by: Henrik Goldman <hg@x-formation.com>
commit 503cf95c061a0551eb684da364509297efbe55d9 upstream.
When compiling with icc, <linux/compiler-gcc.h> ends up included
because the icc environment defines __GNUC__. Thus, we neither need
nor want to have this macro defined in both compiler-gcc.h and
compiler-intel.h, and the fact that they are inconsistent just makes
the compiler spew warnings.
Reported-by: Sunil K. Pandey <sunil.k.pandey@intel.com>
Cc: Kevin B. Smith <kevin.b.smith@intel.com>
Link: http://lkml.kernel.org/n/tip-0mbwou1zt7pafij09b897lg3@git.kernel.org
commit 4fc9bbf98fd66f879e628d8537ba7c240be2b58e upstream.
Add a flag to tell the PCI subsystem that kernel is shutting down in
preparation to kexec a kernel. Add code in PCI subsystem to use this flag
to clear Bus Master bit on PCI devices only in case of kexec reboot.
This fixes a power-off problem on Acer Aspire V5-573G and likely other
machines and avoids any other issues caused by clearing Bus Master bit on
PCI devices in normal shutdown path. The problem was introduced by
b566a22c2332 ("PCI: disable Bus Master on PCI device shutdown").
This patch is based on discussion at
http://marc.info/?l=linux-pci&m=138425645204355&w=2
Link: https://bugzilla.kernel.org/show_bug.cgi?id=63861
Reported-by: Chang Liu <cl91tp@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Konstantin Khlebnikov <koct9i@gmail.com>
commit 932e9dec380c67ec15ac3eb073bb55797d8b4801 upstream.
When running a 32bit kernel the hda_intel driver is still reporting
a 64bit dma_mask if the HW supports it.
From sound/pci/hda/hda_intel.c:
/* allow 64bit DMA address if supported by H/W */
if ((gcap & ICH6_GCAP_64OK) && !pci_set_dma_mask(pci, DMA_BIT_MASK(64)))
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(64));
else {
pci_set_dma_mask(pci, DMA_BIT_MASK(32));
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(32));
which means when there is a call to dma_alloc_coherent from
snd_malloc_dev_pages a machine address bigger than 32bit can be returned.
This can be true in particular if running the 32bit kernel as a pv dom0
under the Xen Hypervisor or PAE on bare metal.
The problem is that when calling setup_bdle to program the BLE the
dma_addr_t returned from the dma_alloc_coherent is wrongly truncated
from snd_sgbuf_get_addr if running a 32bit kernel:
static inline dma_addr_t snd_sgbuf_get_addr(struct snd_dma_buffer *dmab,
size_t offset)
struct snd_sg_buf *sgbuf = dmab->private_data;
dma_addr_t addr = sgbuf->table[offset >> PAGE_SHIFT].addr;
addr &= PAGE_MASK;
return addr + offset % PAGE_SIZE;
where PAGE_MASK in a 32bit kernel is zeroing the upper 32bit af addr.
Without this patch the HW will fetch the 32bit truncated address,
which is not the one obtained from dma_alloc_coherent and will result
to a non working audio but can corrupt host memory at a random location.
The current patch apply to v3.13-rc3-74-g6c843f5
Signed-off-by: Stefano Panella <stefano.panella@citrix.com>
Reviewed-by: Frediano Ziglio <frediano.ziglio@citrix.com>
commit 6733cf572a9e20db2b7580a5dd39d5782d571eec upstream.
snd_pcm_uframes_t is defined as unsigned long so it would take
different sizes depending on 32 or 64bit architectures. As we don't
want this ABI incompatibility, and there is no real 64bit user yet,
let's make it the fixed size with __u32.
Also bump the protocol version number to 0.1.2.
Acked-by: Vinod Koul <vinod.koul@intel.com>
commit 389a5390583a18e45bc4abd4439291abec5e7a63 upstream.
Now that scatterwalk_sg_chain sets the chain pointer bit the sg_page
call in scatterwalk_sg_next hits a BUG_ON when CONFIG_DEBUG_SG is
enabled. Use sg_chain_ptr instead of sg_page on a chain entry.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 674470d97958a0ec72f72caf7f6451da40159cc7 upstream.
In struct gen_pool_chunk, end_addr means the end address of memory chunk
(inclusive), but in the implementation it is treated as address + size of
memory chunk (exclusive), so it points to the address plus one instead of
correct ending address.
The ending address of memory chunk plus one will cause overflow on the
memory chunk including the last address of memory map, e.g. when starting
address is 0xFFF00000 and size is 0x100000 on 32bit machine, ending
address will be 0x100000000.
Use correct ending address like starting address + size - 1.
[akpm@linux-foundation.org: add comment to struct gen_pool_chunk:end_addr]
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
commit 54b2b50c20a61b51199bedb6e5d2f8ec2568fb43 upstream.
Some host adapters do not pass commands through to the target disk
directly. Instead they provide an emulated target which may or may not
accurately report its capabilities. In some cases the physical device
characteristics are reported even when the host adapter is processing
commands on the device's behalf. This can lead to adapter firmware hangs
or excessive I/O errors.
This patch disables WRITE SAME for devices connected to host adapters
that provide an emulated target. Driver writers can disable WRITE SAME
by setting the no_write_same flag in the host adapter template.
[jejb: fix up rejections due to eh_deadline patch]
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 41da8b5adba77e22584f8b45f9641504fa885308 upstream.
The scatterwalk_crypto_chain function invokes the scatterwalk_sg_chain
function to chain two scatterlists, but the chain pointer indication
bit is not set. When the resulting scatterlist is used, for example,
by sg_nents to count the number of scatterlist entries, a segfault occurs
because sg_nents does not follow the chain pointer to the chained scatterlist.
Update scatterwalk_sg_chain to set the chain pointer indication bit as is
done by the sg_chain function.
commit 72403b4a0fbdf433c1fe0127e49864658f6f6468 upstream.
Commit 0255d4918480 ("mm: Account for a THP NUMA hinting update as one
PTE update") was added to account for the number of PTE updates when
marking pages prot_numa. task_numa_work was using the old return value
to track how much address space had been updated. Altering the return
value causes the scanner to do more work than it is configured or
documented to in a single unit of work.
This patch reverts that commit and accounts for the number of THP
updates separately in vmstat. It is up to the administrator to
interpret the pair of values correctly. This is a straight-forward
operation and likely to only be of interest when actively debugging NUMA
balancing problems.
The impact of this patch is that the NUMA PTE scanner will scan slower
when THP is enabled and workloads may converge slower as a result. On
the flip size system CPU usage should be lower than recent tests
reported. This is an illustrative example of a short single JVM specjbb
test
specjbb
3.12.0 3.12.0
vanilla acctupdates
TPut 1 26143.00 ( 0.00%) 25747.00 ( -1.51%)
TPut 7 185257.00 ( 0.00%) 183202.00 ( -1.11%)
TPut 13 329760.00 ( 0.00%) 346577.00 ( 5.10%)
TPut 19 442502.00 ( 0.00%) 460146.00 ( 3.99%)
TPut 25 540634.00 ( 0.00%) 549053.00 ( 1.56%)
TPut 31 512098.00 ( 0.00%) 519611.00 ( 1.47%)
TPut 37 461276.00 ( 0.00%) 474973.00 ( 2.97%)
TPut 43 403089.00 ( 0.00%) 414172.00 ( 2.75%)
3.12.0 3.12.0
vanillaacctupdates
User 5169.64 5184.14
System 100.45 80.02
Elapsed 252.75 251.85
Performance is similar but note the reduction in system CPU time. While
this showed a performance gain, it will not be universal but at least
it'll be behaving as documented. The vmstats are obviously different but
here is an obvious interpretation of them from mmtests.
3.12.0 3.12.0
vanillaacctupdates
NUMA page range updates 1408326 11043064
NUMA huge PMD updates 0 21040
NUMA PTE updates 1408326 291624
"NUMA page range updates" == nr_pte_updates and is the value returned to
the NUMA pte scanner. NUMA huge PMD updates were the number of THP
updates which in combination can be used to calculate how many ptes were
updated from userspace.
Reported-by: Alex Thorlton <athorlton@sgi.com>
Cc: <stable@vger.kernel.org>
commit ccf33d6880f39a35158fff66db13000ae4943fac upstream.
We want to be able to remove clockevent modules as well. Add a
refcount so we don't remove a module with an active clock event
device.
Cc: John Stultz <john.stultz@linaro.org>
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130425143436.307435149@linutronix.de
Cc: Kim Phillips <kim.phillips@linaro.org>
commit 7172a286ced0c1f4f239a0fa09db54ed37d3ead2 upstream.
7+ years and still a single user. Kill it.
Link: http://lkml.kernel.org/r/20130425143436.098520211@linutronix.de
[ Upstream commit 6aafeef03b9d9ecf255f3a80ed85ee070260e1ae ]
Pushing original fragments through causes several problems. For example
for matching, frags may not be matched correctly. Take following
example:
<example>
On HOSTA do:
ip6tables -I INPUT -p icmpv6 -j DROP
ip6tables -I INPUT -p icmpv6 -m icmp6 --icmpv6-type 128 -j ACCEPT
and on HOSTB you do:
ping6 HOSTA -s2000 (MTU is 1500)
Incoming echo requests will be filtered out on HOSTA. This issue does
not occur with smaller packets than MTU (where fragmentation does not happen)
</example>
As was discussed previously, the only correct solution seems to be to use
reassembled skb instead of separete frags. Doing this has positive side
effects in reducing sk_buff by one pointer (nfct_reasm) and also the reams
dances in ipvs and conntrack can be removed.
Future plan is to remove net/ipv6/netfilter/nf_conntrack_reasm.c
entirely and use code in net/ipv6/reassembly.c instead.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
functions
[ Upstream commit 85fbaa75037d0b6b786ff18658ddf0b4014ce2a4 ]
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit 51c37a70aaa3f95773af560e6db3073520513912 ]
For properly initialising the Tausworthe generator [1], we have
a strict seeding requirement, that is, s1 > 1, s2 > 7, s3 > 15.
Commit 697f8d0348 ("random32: seeding improvement") introduced
a __seed() function that imposes boundary checks proposed by the
errata paper [2] to properly ensure above conditions.
However, we're off by one, as the function is implemented as:
"return (x < m) ? x + m : x;", and called with __seed(X, 1),
__seed(X, 7), __seed(X, 15). Thus, an unwanted seed of 1, 7, 15
would be possible, whereas the lower boundary should actually
be of at least 2, 8, 16, just as GSL does. Fix this, as otherwise
an initialization with an unwanted seed could have the effect
that Tausworthe's PRNG properties cannot not be ensured.
Note that this PRNG is *not* used for cryptography in the kernel.
[1] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme.ps
[2] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme2.ps
Joint work with Hannes Frederic Sowa.
Fixes: 697f8d0348a6 ("random32: seeding improvement")
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
commit c13a84a830a208fb3443628773c8ca0557773cc7 upstream.
Commit 68b80f11 (netfilter: nf_nat: fix RCU races) introduced
RCU protection for freeing extension data when reallocation
moves them to a new location. We need the same protection when
freeing them in nf_ct_ext_free() in order to prevent a
use-after-free by other threads referencing a NAT extension data
via bysource list.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
commit 4e58e54754dc1fec21c3a9e824bc108b05fdf46e upstream.
If an TRACE_EVENT() uses __assign_str() or __get_str on a NULL pointer
then the following oops will happen:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<c127a17b>] strlen+0x10/0x1a
*pde = 00000000 ^M
Oops: 0000 [#1] PREEMPT SMP
Modules linked in:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.13.0-rc1-test+ #2
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006^M
task: f5cde9f0 ti: f5e5e000 task.ti: f5e5e000
EIP: 0060:[<c127a17b>] EFLAGS: 00210046 CPU: 1
EIP is at strlen+0x10/0x1a
EAX: 00000000 EBX: c2472da8 ECX: ffffffff EDX: c2472da8
ESI: c1c5e5fc EDI: 00000000 EBP: f5e5fe84 ESP: f5e5fe80
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 00000000 CR3: 01f32000 CR4: 000007d0
Stack:
f5f18b90 f5e5feb8 c10687a8 0759004f 00000005 00000005 00000005 00200046
00000002 00000000 c1082a93 f56c7e28 c2472da8 c1082a93 f5e5fee4 c106bc61^M
00000000 c1082a93 00000000 00000000 00000001 00200046 00200082 00000000
Call Trace:
[<c10687a8>] ftrace_raw_event_lock+0x39/0xc0
[<c1082a93>] ? ktime_get+0x29/0x69
[<c106bc61>] lock_release+0x57/0x1a5
[<c10824dd>] read_seqcount_begin.constprop.7+0x4d/0x75
[<c1082a93>] ? ktime_get+0x29/0x69^M
[<c1082a93>] ktime_get+0x29/0x69
[<c108a46a>] __tick_nohz_idle_enter+0x1e/0x426
[<c10690e8>] ? lock_release_holdtime.part.19+0x48/0x4d
[<c10bc184>] ? time_hardirqs_off+0xe/0x28
[<c1068c82>] ? trace_hardirqs_off_caller+0x3f/0xaf
[<c108a8cb>] tick_nohz_idle_enter+0x59/0x62
[<c1079242>] cpu_startup_entry+0x64/0x192
[<c102299c>] start_secondary+0x277/0x27c
Code: 90 89 c6 89 d0 88 c4 ac 38 e0 74 09 84 c0 75 f7 be 01 00 00 00 89 f0 48 5e 5d c3 55 89 e5 57 66 66 66 66 90 83 c9 ff 89 c7 31 c0 <f2> ae f7 d1 8d 41 ff 5f 5d c3 55 89 e5 57 66 66 66 66 90 31 ff
EIP: [<c127a17b>] strlen+0x10/0x1a SS:ESP 0068:f5e5fe80
CR2: 0000000000000000
---[ end trace 01bc47bf519ec1b2 ]---
New tracepoints have been added that have allowed for NULL pointers
being assigned to strings. To fix this, change the TRACE_EVENT() code
to check for NULL and if it is, it will assign "(null)" to it instead
(similar to what glibc printf does).
Reported-by: Shuah Khan <shuah.kh@samsung.com>
Reported-by: Jovi Zhangwei <jovi.zhangwei@gmail.com>
Link: http://lkml.kernel.org/r/CAGdX0WFeEuy+DtpsJzyzn0343qEEjLX97+o1VREFkUEhndC+5Q@mail.gmail.com
Link: http://lkml.kernel.org/r/528D6972.9010702@samsung.com
Fixes: 9cbf117662e2 ("tracing/events: provide string with undefined size support")
commit ca499fc87ed945094d952da0eb7eea7dbeb1feec upstream.
The PCI host bridge scan handler installs its own notify handler,
handle_hotplug_event_root(), by itself. Nevertheless, the ACPI
hotplug framework also installs the common notify handler,
acpi_hotplug_notify_cb(), for PCI root bridges. This causes
acpi_hotplug_notify_cb() to call _OST method with unsupported
error as hotplug.enabled is not set.
To address this issue, introduce hotplug.ignore flag, which
indicates that the scan handler installs its own notify handler by
itself. The ACPI hotplug framework does not install the common
notify handler when this flag is set.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
[rjw: Changed the name of the new flag]
audit_names record
commit 79f6530cb59e2a0af6953742a33cc29e98ca631c upstream.
The old audit PATH records for mq_open looked like this:
type=PATH msg=audit(1366282323.982:869): item=1 name=(null) inode=6777
dev=00:0c mode=041777 ouid=0 ogid=0 rdev=00:00
obj=system_u:object_r:tmpfs_t:s15:c0.c1023
type=PATH msg=audit(1366282323.982:869): item=0 name="test_mq" inode=26732
dev=00:0c mode=0100700 ouid=0 ogid=0 rdev=00:00
obj=staff_u:object_r:user_tmpfs_t:s15:c0.c1023
...with the audit related changes that went into 3.7, they now look like this:
type=PATH msg=audit(1366282236.776:3606): item=2 name=(null) inode=66655
type=PATH msg=audit(1366282236.776:3606): item=1 name=(null) inode=6926
type=PATH msg=audit(1366282236.776:3606): item=0 name="test_mq"
Both of these look wrong to me. As Steve Grubb pointed out:
"What we need is 1 PATH record that identifies the MQ. The other PATH
records probably should not be there."
Fix it to record the mq root as a parent, and flag it such that it
should be hidden from view when the names are logged, since the root of
the mq filesystem isn't terribly interesting. With this change, we get
a single PATH record that looks more like this:
type=PATH msg=audit(1368021604.836:484): item=0 name="test_mq" inode=16914
dev=00:0c mode=0100644 ouid=0 ogid=0 rdev=00:00
obj=unconfined_u:object_r:user_tmpfs_t:s0
In order to do this, a new audit_inode_parent_hidden() function is
added. If we do it this way, then we avoid having the existing callers
of audit_inode needing to do any sort of flag conversion if auditing is
inactive.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reported-by: Jiri Jaburek <jjaburek@redhat.com>
Cc: Steve Grubb <sgrubb@redhat.com>
commit a4d62babf988fe5dfde24437fa135ef147bc7aa0 upstream.
Hardware:
CPU: XLP832,the 64-bit OS
NOR Flash:S29GL128S 128M
Software:
Kernel:2.6.32.41
Filesystem:JFFS2
When writing files, errors appear:
Write len 182 but return retlen 180
Write of 182 bytes at 0x072c815c failed. returned -5, retlen 180
Write len 186 but return retlen 184
Write of 186 bytes at 0x072caff4 failed. returned -5, retlen 184
These errors exist only in 64-bit systems,not in 32-bit systems. After analysis, we
found that the left shift operation is wrong in map_word_load_partial. For instance:
unsigned char buf[3] ={0x9e,0x3a,0xea};
map_bankwidth(map) is 4;
for (i=0; i < 3; i++) {
int bitpos;
bitpos = (map_bankwidth(map)-1-i)*8;
orig.x[0] &= ~(0xff << bitpos);
orig.x[0] |= buf[i] << bitpos;
The value of orig.x[0] is expected to be 0x9e3aeaff, but in this situation(64-bit
System) we'll get the wrong value of 0xffffffff9e3aeaff due to the 64-bit sign
extension:
buf[i] is defined as "unsigned char" and the left-shift operation will convert it
to the type of "signed int", so when left-shift buf[i] by 24 bits, the final result
will get the wrong value: 0xffffffff9e3aeaff.
If the left-shift bits are less than 24, then sign extension will not occur. Whereas
the bankwidth of the nor flash we used is 4, therefore this BUG emerges.
Signed-off-by: Pang Xunlei <pang.xunlei@zte.com.cn>
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Signed-off-by: Lu Zhongjun <lu.zhongjun@zte.com.cn>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit 9bf76ca325d5e9208eb343f7bd4cc666f703ed30 upstream.
Negative message lengths make no sense -- so don't do negative queue
lenghts or identifier counts. Prevent them from getting negative.
Also change the underlying data types to be unsigned to avoid hairy
surprises with sign extensions in cases where those variables get
evaluated in unsigned expressions with bigger data types, e.g size_t.
In case a user still wants to have "unlimited" sizes she could just use
INT_MAX instead.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 4e9b45a19241354daec281d7a785739829b52359 upstream.
On 64 bit systems the test for negative message sizes is bogus as the
size, which may be positive when evaluated as a long, will get truncated
to an int when passed to load_msg(). So a long might very well contain a
positive value but when truncated to an int it would become negative.
That in combination with a small negative value of msg_ctlmax (which will
be promoted to an unsigned type for the comparison against msgsz, making
it a big positive value and therefore make it pass the check) will lead to
two problems: 1/ The kmalloc() call in alloc_msg() will allocate a too
small buffer as the addition of alen is effectively a subtraction. 2/ The
copy_from_user() call in load_msg() will first overflow the buffer with
userland data and then, when the userland access generates an access
violation, the fixup handler copy_user_handle_tail() will try to fill the
remainder with zeros -- roughly 4GB. That almost instantly results in a
system crash or reset.
,-[ Reproducer (needs to be run as root) ]--
| #include <sys/stat.h>
| #include <sys/msg.h>
| #include <unistd.h>
| #include <fcntl.h>
| int main(void) {
| long msg = 1;
| int fd;
| fd = open("/proc/sys/kernel/msgmax", O_WRONLY);
| write(fd, "-1", 2);
| close(fd);
| msgsnd(0, &msg, 0xfffffff0, IPC_NOWAIT);
| return 0;
Fix the issue by preventing msgsz from getting truncated by consistently
using size_t for the message length. This way the size checks in
do_msgsnd() could still be passed with a negative value for msg_ctlmax but
we would fail on the buffer allocation in that case and error out.
Also change the type of m_ts from int to size_t to avoid similar nastiness
in other code paths -- it is used in similar constructs, i.e. signed vs.
unsigned checks. It should never become negative under normal
circumstances, though.
Setting msg_ctlmax to a negative value is an odd configuration and should
be prevented. As that might break existing userland, it will be handled
in a separate commit so it could easily be reverted and reworked without
reintroducing the above described bug.
Hardening mechanisms for user copy operations would have catched that bug
early -- e.g. checking slab object sizes on user copy operations as the
usercopy feature of the PaX patch does. Or, for that matter, detect the
long vs. int sign change due to truncation, as the size overflow plugin
of the very same patch does.
[akpm@linux-foundation.org: fix i386 min() warnings]
Cc: Pax Team <pageexec@freemail.hu>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: Manfred Spraul <manfred@colorfullife.com>
commit 5017b2851373ee15c7035151853bb1448800cae2 upstream.
dmi_match() considers a substring match to be a successful match. This is
not always sufficient to distinguish between DMI data for different
systems. Add support for exact string matching using strcmp() in addition
to the substring matching using strstr().
The specific use case in the i915 driver is to allow us to use an exact
match for D510MO, without also incorrectly matching D510MOV:
.ident = "Intel D510MO",
.matches = {
DMI_MATCH(DMI_BOARD_VENDOR, "Intel"),
DMI_EXACT_MATCH(DMI_BOARD_NAME, "D510MO"),
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Cc: <annndddrr@gmail.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Cornel Panceac <cpanceac@gmail.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit f44f2a5417b2968a8724b352cc0b2545a6bcb1f4 upstream.
The drain and drain_notify callback were blocked by low level driver
until the draining was complete. Due to this being invoked with big
fat mutex held, others ops like reading timestamp, calling pause, drop
were blocked.
So to fix this we add a new snd_compr_drain_notify() API. This would
be required to be invoked by low level driver when drain or partial
drain has been completed by the DSP. Thus we make the drain and
partial_drain callback as non blocking and driver returns immediately
after notifying DSP. The waiting is done while releasing the lock so
that other ops can go ahead.
[ The commit 917f4b5cba78 was wrongly applied from the preliminary
patch. This commit corrects to the final version.
Sorry for inconvenience! -- tiwai ]
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 917f4b5cba78980a527098a910d94139d3e82c8d upstream.
The drain and drain_notify callback were blocked by low level driver untill the
draining was complete. Due to this being invoked with big fat mutex held, others
ops like reading timestamp, calling pause, drop were blocked.
So to fix this we add a new snd_compr_drain_notify() API. This would be required
to be invoked by low level driver when drain or partial drain has been completed
by the DSP. Thus we make the drain and partial_drain callback as non blocking
and driver returns immediately after notifying DSP.
The waiting is done while relasing the lock so that other ops can go ahead.
commit d049f74f2dbe71354d43d393ac3a188947811348 upstream.
The get_dumpable() return value is not boolean. Most users of the
function actually want to be testing for non-SUID_DUMP_USER(1) rather than
SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a
protected state. Almost all places did this correctly, excepting the two
places fixed in this patch.
Wrong logic:
if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ }
or
if (dumpable == 0) { /* be protective */ }
or
if (!dumpable) { /* be protective */ }
Correct logic:
if (dumpable != SUID_DUMP_USER) { /* be protective */ }
or
if (dumpable != 1) { /* be protective */ }
Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a
user was able to ptrace attach to processes that had dropped privileges to
that user. (This may have been partially mitigated if Yama was enabled.)
The macros have been moved into the file that declares get/set_dumpable(),
which means things like the ia64 code can see them too.
CVE-2013-2929
Reported-by: Vasily Kulikov <segoon@openwall.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit ea8117478918a4734586d35ff530721b682425be upstream.
Mike reported that commit 7d1a9417 ("x86: Use generic idle loop")
regressed several workloads and caused excessive reschedule
interrupts.
The patch in question failed to notice that the x86 code had an
inverted sense of the polling state versus the new generic code (x86:
default polling, generic: default !polling).
Fix the two prominent x86 mwait based idle drivers and introduce a few
new generic polling helpers (fixing the wrong smp_mb__after_clear_bit
usage).
Also switch the idle routines to using tif_need_resched() which is an
immediate TIF_NEED_RESCHED test as opposed to need_resched which will
end up being slightly different.
Reported-by: Mike Galbraith <bitbucket@online.de>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: lenb@kernel.org
Cc: tglx@linutronix.de
Link: http://lkml.kernel.org/n/tip-nc03imb0etuefmzybzj7sprf@git.kernel.org
commit bf378d341e4873ed928dc3c636252e6895a21f50 upstream.
The PPC64 people noticed a missing memory barrier and crufty old
comments in the perf ring buffer code. So update all the comments and
add the missing barrier.
When the architecture implements local_t using atomic_long_t there
will be double barriers issued; but short of introducing more
conditional barrier primitives this is the best we can do.
Reported-by: Victor Kaplansky <victork@il.ibm.com>
Tested-by: Victor Kaplansky <victork@il.ibm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: michael@ellerman.id.au
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: anton@samba.org
Cc: benh@kernel.crashing.org
Link: http://lkml.kernel.org/r/20131025173749.GG19466@laptop.lan
