Some USB function drivers (e.g. f_mass_storage.c) need to delay or defer the
data/status stages of standard control requests like SET_CONFIGURATION or
SET_INTERFACE till they are done with their bookkeeping and are actually ready
for accepting new commands to their interface.
They can now achieve this functionality by returning USB_GADGET_DELAYED_STATUS
in their setup handlers (e.g. set_alt()). The composite framework will then
defer completion of the control transfer by not completing the data/status stages.
This ensures that the host does not send new packets to the interface till the
function driver is ready to take them.
When the function driver that requested for USB_GADGET_DELAYED_STATUS is done
with its bookkeeping, it should signal the composite framework to continue with
the data/status stages of the control transfer. It can do so by invoking
the new API usb_composite_setup_continue(). This is where the control transfer's
data/status stages are completed and host can initiate new transfers.
The DELAYED_STATUS mechanism is currently only supported if the expected data phase
is 0 bytes (i.e. w_length == 0). Since SET_CONFIGURATION and SET_INTERFACE are the
only cases that will use this mechanism, this is not a limitation.
(cherry picked from commit 1b9ba000177ee47bcc5b44c7c34e48e735f5f9b1)
Change-Id: I4aaf702e03898573f92e58223a29eafbc9612219
Reviewed-on: http://git-master/r/36273
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Signed-off-by: Mike Lockwood <lockwood@android.com>
(cherry picked from commit 99b7fdff26bdaa2dbdecd45db18834f9d7447632)
Change-Id: Ic4e663abf1a3c6d0ea21983f5e2171a34c0e6641
Reviewed-on: http://git-master/r/32891
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
- Add URI string
- Replace type string with a description string
- Add a control call to retrieve accessory protocol version (currently 1)
- Driver read() and write() calls now fail after USB disconnect until
driver file is closed and reopened.
- Misc cleanup work
(cherry picked from commit 5dcd55b2e98ffdaf54a5cdd67a3101e1e5dd3aa1)
Change-Id: I5b45ee76d5f83b626555e42d34f450db9b69f47b
Reviewed-on: http://git-master/r/32887
(cherry picked from commit 5826bb3c467116287087703472261f51f71ca090)
Change-Id: I6d66f0e6ff137467f8656d28f1107d7478a22720
Reviewed-on: http://git-master/r/32886
Change-Id: I035a6cd254342fe11f074cb85439f378a7675943
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Reviewed-on: http://git-master/r/33038
Reviewed-by: Brian Anderson <branderson@nvidia.com>
Change-Id: I6ec62abdaf3a8ec2e59e2a533b36b280d69538e1
Signed-off-by: Ari Hirvonen <ahirvonen@nvidia.com>
Reviewed-on: http://git-master/r/33037
Reviewed-by: Michael I Gold <gold@nvidia.com>
Tested-by: Michael I Gold <gold@nvidia.com>
Change-Id: I8ee718e0d56ff8dc2f2c2e1b5215d195f317f0e2
Reviewed-on: http://git-master/r/31084
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Return last requested position if the motor settled or timeout occurs.
Reviewed-on: http://git-master/r/27978
(cherry picked from commit edb393adc0317a097858edeb4b9f5477d164b955)
Change-Id: I54572b180bf151785d55edde9060876ed0393ee3
Reviewed-on: http://git-master/r/31741
Reviewed-by: Frank Chen <frankc@nvidia.com>
Tested-by: Gary Zhang <garyz@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Gary Zhang <garyz@nvidia.com>
Change-Id: I6f0bc3b5859c8545853051f10bda60ab6ac3dd8b
Bug 819975
Change-Id: I19e1448b07702bebaf2889efc3a304fcd2d07df8
Reviewed-on: http://git-master/r/29467
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
apis added to program max8907c regulator to power down and up core supply rail
via the pwren signal on enter and exit deep sleep mode.
Bug 817378
Change-Id: I5af04db22b6c84fc4359c1a0cf209710ca144159
Reviewed-on: http://git-master/r/28434
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
arch/arm/mm/proc-v7.S
drivers/video/tegra/dc/dc.c
Change-Id: I40be0d615f14f1c01305388a706d257f624ba968
PPP handles packet loss but does not work with out of order packets.
This change performs reordering of incoming data packets within a
sliding window of one second. Since sequence number is optional,
receiving a packet without it will drop all queued packets.
Currently the logic is triggered by incoming packets, so queued
packets have to wait till another packet is arrived. It is done for
simplicity since no additional locks or threads are required. For
reliable protocols, a retransmission will kick it. For unreliable
protocols, queued packets just seem like packet loss. Time-critical
protocols might be broken, but they never work with queueing anyway.
Signed-off-by: Chia-chi Yeh <chiachi@android.com>
Bug: 783488
Change-Id: I0d70ec5bb0fd880b167e9ced0e002829abeccdbf
Reviewed-on: http://git-master/r/24969
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add AD5820 focuser driver for Whistler.
Bug 783488
Change-Id: I0d8a08e7df9f472ffc4edfe7bfa255357bff5126
Reviewed-on: http://git-master/r/26970
Register assignments were wrong for incoming overlay blend
parameters. DisplayManagerLite policy sets src combine mode
to premult to signal dst premult aplha blending. But the DC
expects premult set for the dst window for this mode.
Bug 796009
Change-Id: I5929bc4cd362ac60c7a9f14bb4ae83da04b857ab
Reviewed-on: http://git-master/r/26835
-Removed unused sensor mode mode_1920x1088
-Added ov5650_write_reg_helper function to do write_reg()
according to camera_mode.
-ov5650_get_status function is removed as it is reading reg 2
value and there is not any definition of reg 2 in datasheet and
even user space is not using it's value at all.
-Added ov5650_set_power function to on/off camera sensors power
-Added ioctl OV5650_IOCTL_SET_CAMERA_MODE to set camera_mode
from user space.
-Added i2c driver for right ov5650.
Bug 809921
Change-Id: Ib3cf43d0a064c18c218d0850e849fff84e18e661
Reviewed-on: http://git-master/r/26857
Tested-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-by: George Bauernschmidt <georgeb@nvidia.com>
This kernel driver will replace the functionality that was
previously in the NVRM daemon root process and allow multiple
instances of OpenMAX to function and AVP resource tracking and
cleanup.
Bug 772210
Change-Id: Ia5eb559cde4644bae5fd8b23a1de57cd65f3fdd8
Reviewed-on: http://git-master/r/25115
Tested-by: Stephen Holmes <sholmes@nvidia.com>
Reviewed-by: Stephen Holmes <sholmes@nvidia.com>
- added the tegra dependent layer of the caif protocol.
- integrated with the open source rainbow caif.
- verified the functionality using latest rainbow RIL.
bug 785523
Change-Id: I75be8d2ef6e5562facf902a3f963f34d241bb6c3
Reviewed-on: http://git-master/r/23421
Adds SND_JACK_NO_TYPE_SPECIFIED to handle the cases
where jack type is not known.
Change-Id: Ifd604694602fa22a497aff209e621f5cc00d0871
Reviewed-on: http://git-master/r/27179
Tested-by: Manjula Gupta <magupta@nvidia.com>
Reviewed-by: Boris Suvorov <bsuvorov@nvidia.com>
CMD38 argument is passed through EXT_CSD[113].
Change-Id: I47e9d5e2cf44d9274a65a3b1955026185cb8f2b8
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
Needed for Sandisk workaround (manipulate EXT_CSD).
Change-Id: I7bfe50a1503ac73ae072db718b60c27526521e41
The current mechanism is SDIO-only. This allows us to create
function-specific quirks, without creating messy Kconfig dependencies,
or polluting core/ with function-specific code.
Change-Id: If31a151c20a8a1fddb0774674821e9fdc4aa61a0
Some cards have quirks valid for every platforms using current
platform quirk hooks leads to a lot of code and debug duplication.
So we inspire a bit from what exists in PCI subsystem and do our own
per vendorid/deviceid quirk. We still drop the complexity of the pci
quirk system (with special section tables, and so on).
That can be added later if needed.
Change-Id: Ib67a3e97486023267f5ea3e7c6ef8fc99b13a704
Signed-off-by: Pierre Tardy <pierre.tardy@intel.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Ohad Ben-Cohen <ohad@wizery.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Generated with the script:
find \( -name "*.c" -or -name "*.h" -or -name "*akefile" -or \
-name "*\.mk" \) -type f -perm /+x | xargs chmod -x
Change-Id: Iabae1aa20fd49a1c8db439fc132182d0f629deab
Reviewed-on: http://git-master/r/26806
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Tested-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Janne Hellsten <jhellsten@nvidia.com>
New i2c slave should be configured with a non-zero i2c address.
Configure i2c slave with an i2c address assigned by platform
data for an i2c dev.
BUG 788286
Reviewed-on: http://git-master/r/25100
(cherry picked from commit e6e0610c72ffce3b734e079faf88fad3f0468d07)
Change-Id: I440aa2cc72007d2835b2027c0b26089d0aad9263
Reviewed-on: http://git-master/r/25223
Currently the machine driver can only do bias level configuration before
the CODEC bias level is brought up. This means that the machine cannot do
any configuration which depends on the CODEC bias level being maintained.
Provide a post-CODEC callback which allows the machine driver to do things
like enable the FLL on a CODEC which is brought down to BIAS_OFF when idle.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cherry-picked from mainline kernel.
Change-Id: Ib0a8533e3762dfc67ee21209a28e9a6603d31a37
Reviewed-on: http://git-master/r/23058
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Add UART_CAP_HW_CTSRTS flag to tegra type for supporting auto control
of RTSCTS.
Bug 803910
Change-Id: I7b69e4b203e66903ba5755338fcb55f4a87b9a43
Reviewed-on: http://git-master/r/24463
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
- fix an incorrect i2c address and a function return check.
- add checks for function returns.
- remove the developer name in the beginning comment.
- fix an uninitialized variable..
Change-Id: I2d42025b7ff47eb6228e626e65990f4da04b94ac
Reviewed-on: http://git-master/r/23594
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Qinggang Zhou <qzhou@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
In systems with multiple framebuffer devices, one of the devices might
be blanked while another is unblanked. In order for the backlight
blanking logic to know whether to turn off the backlight for a
particular framebuffer's blanking notification, it needs to be able to
check if a given framebuffer device corresponds to the backlight.
This plumbs the check_fb hook from core backlight through the
pwm_backlight helper to allow platform code to plug in a check_fb hook.
Originally reviewed on http://git-master/r/21716
Reviewed-on: http://git-master/r/23100
(cherry picked from commit c7831cb27fc6a2701b020676a6daf9c76e9470d9)
Change-Id: I32895d6f2c5988b09680a350e169f1f3c9b56da6
Reviewed-on: http://git-master/r/23725
Tested-by: Gaurav Sarode <gsarode@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
The intensity of the backlight can be varied from a range of
max_brightness to zero. Though most, if not all the pwm based backlight
devices start flickering at lower brightness value. And also for each
device there exists a brightness value below which the backlight appears
to be turned off though the value is not equal to zero.
If the range of brightness for a device is from zero to max_brightness. A
graph is plotted for brightness Vs intensity for the pwm based backlight
device has to be a linear graph.
intensity
0 max_brightness
But pratically on measuring the above we note that the intensity of
backlight goes to zero(OFF) when the value in not zero almost nearing to
zero(some x%). so the graph looks like
intensity
0 x max_brightness
In order to overcome this drawback knowing this x% i.e nothing but the low
threshold beyond which the backlight is off and will have no effect, the
brightness value is being offset by the low threshold value(retaining the
linearity of the graph). Now the graph becomes
intensity
0 max_brightness
With this for each and every digit increment in the brightness from zero
there is a change in the intensity of backlight. Devices having this
behaviour can set the low threshold brightness(lth_brightness) and pass
the same as platform data else can have it as zero.
Signed-off-by: Arun Murthy <arun.murthy@stericsson.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Reviewed-on: http://git-master/r/23099
(cherry picked from commit 92db79791aa60cacb3fa90d1cb2e942420c29408)
Change-Id: Icbe49b593dfa6608934ff274b4c9281e43c30b5c
Reviewed-on: http://git-master/r/23724
Update Invensense Motion Library (MPL) to production version
v3.3.3. Previous version was engineering release and is not
suitable for mass production. This version of the MPL most
notably fixes problems with suspend/resume where touch screen
would quit working during a suspend/resume cycle.
Change-Id: Ia33433a677862b3d1e31d410aac7176d7a381a8f
Reviewed-on: http://git-master/r/22987
Correct PRE_BYPASS (clock scaler 32kHz/1kHz select) bitfield.
Add platform data to tune RTC XTAL capacitance in board file.
Bug 798832, Tested on Ventana/wake via Alarm Clock
Change-Id: I82d67610a815866707fc1db934d7d4d7cf93d883
Reviewed-on: http://git-master/r/22402
Reviewed-by: David Schalig <dschalig@nvidia.com>
TPS6586x SM0, SM1 and SM2 port have 2 power switching modes:
- PWM only, or
- PMW-PFM auto mode
Some of TPS6586x have voltage spike in PFM-to-FWM transition can lockup
the CPU if choose PWM-PFM auto mode.
This patch enables such mode selection on SMs ports from the board level
power configuration file.
BUG 796364
Change-Id: I7015798151d6753ff5dcc329703338fde105e2b0
Reviewed-on: http://git-master/r/22701
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
This focuser is from SEMCO and is integrated with OV5650 sensor and LC898211 driver.
bug 778859
Change-Id: I6e5dcc129c72aed7d92a00a1d926424050583c1d
Reviewed-on: http://git-master/r/22711
Reviewed-by: Qinggang Zhou <qzhou@nvidia.com>
On Linux, when an interface goes down all its IPv6
addresses are deleted, so relying on knowing the previous
IPv6 addresses on the interface is brittle. Instead,
support nuking all sockets that are bound to IP addresses
that are not configured and up on the system. This
behaviour is triggered by specifying the unspecified
address (:: or 0.0.0.0). If an IP address is specified, the
behaviour is unchanged, except the ioctl now supports IPv6
as well as IPv4.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Add an api to power off max8907c by setting power off bit in RESET_CNFG reg.
Bug 799957
Bug 800602 (Cold boot)
Change-Id: Ie0206d684a86fecc75273c1d3b087bb2d47b4c56
Reviewed-on: http://git-master/r/22385
* Move include/linux/tegra_usb.h to
include/linux/platform_data/tegra_usb.h
Change-Id: I5b7799c5af8029b15ad206978718b337afac8814
Reviewed-on: http://git-master/r/22165
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Following are the fixes;
- Supportng half duplex.
- Only using SW based CS.
- Write to readback with command register does not work. Fixing issue.
- Using cpu based transfer for smaller size and dma based for larger size.
- reading proper transfer status after every transaction.
bug 791149
bug 791780
Change-Id: I293b3f1b571276f5d8fe4ad4da67f827926e4b73
Reviewed-on: http://git-master/r/20581
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Amit Kamath <akamath@nvidia.com>
arch/arm/mach-tegra/include/mach/system.h
arch/arm/mach-tegra/include/mach/usb_phy.h
arch/arm/mach-tegra/usb_phy.c
drivers/usb/host/ehci-tegra.c
drivers/video/tegra/dc/hdmi.c
Change-Id: Ic1f4f2b360893e8de6b867a8ecc239aca02367da
Exposed gpio pins on wm8903 via GPIOLIB. This will help ALSA control
drivers to manipulate the codec much more easier.
Change-Id: I070eafa6e9a533cc0c285c1780d1b8393105def1
Reviewed-on: http://git-master/r/20883
Change-Id: Id5cb40c9823c7fcfd26e45e4608c45b16a2d431a
Reviewed-on: http://git-master/r/21351
Reviewed-by: Erik M Lilliebjerg <elilliebjerg@nvidia.com>
Tested-by: Erik M Lilliebjerg <elilliebjerg@nvidia.com>
This change allows the max8907c to wake the system when receiving an
irq. It also masks all non-wake conditions from causing an irq when
going into suspend and unmasks these conditions when resuming to not
cause spurious wake-up events.
Change-Id: I5eadb929ff4aded8a6ec11426ab424f0f692c042
Reviewed-on: http://git-master/r/20100
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Add generic access ops for controllers with a ulpi viewport register
(e.g. Chipidea based controller).
Change-Id: I53d50857d4716f8df708af199ad1def1ff9d4beb
Signed-off-by: Benoit Goby <benoit@android.com>
Change-Id: I846d43b1ecbe6c726f024b6a0fb318d6300a3746
Change-Id: Ic093d07858eb6e27aae9cd04d4c59407b5b1d76d
Change-Id: I10fd2dbcc07d7961dd75e10a2c4de926457c2912
Device /dev/nvhdcpX is used to manage NVHDCP on framebuffer /dev/fbX.
These devices are created on hdmi driver initialition when it is
attached to dc. Currently only one nvhdcp device may be created. An ioctl
interface is in video/nvhdcp.h
Check for repeaters and store repeater info. userspace application
queries this status to authenticate the connection. When authentication
fails, auto-renegotiate every 1.75 seconds. Give up after 5 failed attempts,
reset after hotplug or policy change.
use TEGRA_DC_OUT_NVHDCP_POLICY_ON_DEMAND in tegra_dc_out.flags in board
panel configuration to select a different default policy at probe. Currently
only TEGRA_DC_OUT_NVHDCP_POLICY_ALWAYS_ON is supported.
Change-Id: I0db66fc86096b98d2604544061721d291523de75
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Tested-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Phillip Smith <psmith@nvidia.com>
Signed-off-by: Erik Gilling <konkers@android.com>
The driver now supports thermal throttling.
When the temperature reaches a certain threshold,
thermal throttling is enabled and when the chip cools
off to a certain threshold, throttling is disabled.
Bug 786378
Change-Id: I7e769bd98e0bfe0d1f2decdba4432f91a0133d54
Reviewed-on: http://git-master/r/20372
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
