path: root/include
2012-10-07serial: set correct baud_base for EXSYS EX-41092 Dual 16950Flavio Leitner
commit 26e8220adb0aec43b7acafa0f1431760eee28522 upstream. Apparently the same card model has two IDs, so this patch complements the commit 39aced68d664291db3324d0fcf0985ab5626aac2 adding the missing one. Signed-off-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02kthread_worker: reimplement flush_kthread_work() to allow freeing the work ↵Tejun Heo
item being executed commit 46f3d976213452350f9d10b0c2780c2681f7075b upstream. kthread_worker provides minimalistic workqueue-like interface for users which need a dedicated worker thread (e.g. for realtime priority). It has basic queue, flush_work, flush_worker operations which mostly match the workqueue counterparts; however, due to the way flush_work() is implemented, it has a noticeable difference of not allowing work items to be freed while being executed. While the current users of kthread_worker are okay with the current behavior, the restriction does impede some valid use cases. Also, removing this difference isn't difficult and actually makes the code easier to understand. This patch reimplements flush_kthread_work() such that it uses a flush_work item instead of queue/done sequence numbers. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Colin Cross <ccross@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02time: Move ktime_t overflow checking into timespec_valid_strictJohn Stultz
commit cee58483cf56e0ba355fdd97ff5e8925329aa936 upstream Andreas Bombe reported that the added ktime_t overflow checking added to timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of timekeeping inputs") was causing problems with X.org because it caused timeouts larger then KTIME_T to be invalid. Previously, these large timeouts would be clamped to KTIME_MAX and would never expire, which is valid. This patch splits the ktime_t overflow checking into a new timespec_valid_strict function, and converts the timekeeping codes internal checking to use this more strict function. Reported-and-tested-by: Andreas Bombe <aeb@debian.org> Cc: Zhouping Liu <zliu@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02time: Improve sanity checking of timekeeping inputsJohn Stultz
commit 4e8b14526ca7fb046a81c94002c1c43b6fdf0e9b upstream. Unexpected behavior could occur if the time is set to a value large enough to overflow a 64bit ktime_t (which is something larger then the year 2262). Also unexpected behavior could occur if large negative offsets are injected via adjtimex. So this patch improves the sanity check timekeeping inputs by improving the timespec_valid() check, and then makes better use of timespec_valid() to make sure we don't set the time to an invalid negative value or one that overflows ktime_t. Note: This does not protect from setting the time close to overflowing ktime_t and then letting natural accumulation cause the overflow. Reported-by: CAI Qian <caiqian@redhat.com> Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Zhouping Liu <zliu@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1344454580-17031-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02sched: Fix race in task_group()Peter Zijlstra
commit 8323f26ce3425460769605a6aece7a174edaa7d1 upstream. Stefan reported a crash on a kernel before a3e5d1091c1 ("sched: Don't call task_group() too many times in set_task_rq()"), he found the reason to be that the multiple task_group() invocations in set_task_rq() returned different values. Looking at all that I found a lack of serialization and plain wrong comments. The below tries to fix it using an extra pointer which is updated under the appropriate scheduler locks. Its not pretty, but I can't really see another way given how all the cgroup stuff works. Reported-and-tested-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1340364965.18025.71.camel@twins Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Bluetooth: Change signature of smp_conn_security()Vinicius Costa Gomes
commit cc110922da7e902b62d18641a370fec01a9fa794 upstream. To make it clear that it may be called from contexts that may not have any knowledge of L2CAP, we change the connection parameter, to receive a hci_conn. This also makes it clear that it is checking the security of the link. Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02drm: Check for invalid cursor flagsJakob Bornecrantz
commit 7c4eaca4162d0b5ad4fb39f974d7ffd71b9daa09 upstream. Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02mutex: Place lock in contended state after fastpath_lock failureWill Deacon
commit 0bce9c46bf3b15f485d82d7e81dabed6ebcc24b1 upstream. ARM recently moved to asm-generic/mutex-xchg.h for its mutex implementation after the previous implementation was found to be missing some crucial memory barriers. However, this has revealed some problems running hackbench on SMP platforms due to the way in which the MUTEX_SPIN_ON_OWNER code operates. The symptoms are that a bunch of hackbench tasks are left waiting on an unlocked mutex and therefore never get woken up to claim it. This boils down to the following sequence of events: Task A Task B Task C Lock value 0 1 1 lock() 0 2 lock() 0 3 spin(A) 0 4 unlock() 1 5 lock() 0 6 cmpxchg(1,0) 0 7 contended() -1 8 lock() 0 9 spin(C) 0 10 unlock() 1 11 cmpxchg(1,0) 0 12 unlock() 1 At this point, the lock is unlocked, but Task B is in an uninterruptible sleep with nobody to wake it up. This patch fixes the problem by ensuring we put the lock into the contended state if we fail to acquire it on the fastpath, ensuring that any blocked waiters are woken up when the mutex is released. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Chris Mason <chris.mason@fusionio.com> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-6e9lrw2avczr0617fzl5vqb8@git.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02NFS: Fix the initialisation of the readdir 'cookieverf' arrayTrond Myklebust
commit c3f52af3e03013db5237e339c817beaae5ec9e3a upstream. When the NFS_COOKIEVERF helper macro was converted into a static inline function in commit 99fadcd764 (nfs: convert NFS_*(inode) helpers to static inline), we broke the initialisation of the readdir cookies, since that depended on doing a memset with an argument of 'sizeof(NFS_COOKIEVERF(inode))' which therefore changed from sizeof(be32 cookieverf[2]) to sizeof(be32 *). At this point, NFS_COOKIEVERF seems to be more of an obfuscation than a helper, so the best thing would be to just get rid of it. Also see: https://bugzilla.kernel.org/show_bug.cgi?id=46881 Reported-by: Andi Kleen <andi@firstfloor.org> Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02tracing: Don't call page_to_pfn() if page is NULLWen Congyang
commit 85f2a2ef1d0ab99523e0b947a2b723f5650ed6aa upstream. When allocating memory fails, page is NULL. page_to_pfn() will cause the kernel panicked if we don't use sparsemem vmemmap. Link: http://lkml.kernel.org/r/505AB1FF.8020104@cn.fujitsu.com Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02xen/m2p: do not reuse kmap_op->dev_bus_addrStefano Stabellini
commit 2fc136eecd0c647a6b13fcd00d0c41a1a28f35a5 upstream. If the caller passes a valid kmap_op to m2p_add_override, we use kmap_op->dev_bus_addr to store the original mfn, but dev_bus_addr is part of the interface with Xen and if we are batching the hypercalls it might not have been written by the hypervisor yet. That means that later on Xen will write to it and we'll think that the original mfn is actually what Xen has written to it. Rather than "stealing" struct members from kmap_op, keep using page->index to store the original mfn and add another parameter to m2p_remove_override to get the corresponding kmap_op instead. It is now responsibility of the caller to keep track of which kmap_op corresponds to a particular page in the m2p_override (gntdev, the only user of this interface that passes a valid kmap_op, is already doing that). Reported-and-Tested-By: Sander Eikelenboom <linux@eikelenboom.it> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02mm/ia64: fix a memory block size bugJianguo Wu
commit 05cf96398e1b6502f9e191291b715c7463c9d5dd upstream. I found following definition in include/linux/memory.h, in my IA64 platform, SECTION_SIZE_BITS is equal to 32, and MIN_MEMORY_BLOCK_SIZE will be 0. #define MIN_MEMORY_BLOCK_SIZE (1 << SECTION_SIZE_BITS) Because MIN_MEMORY_BLOCK_SIZE is int type and length of 32bits, so MIN_MEMORY_BLOCK_SIZE(1 << 32) will will equal to 0. Actually when SECTION_SIZE_BITS >= 31, MIN_MEMORY_BLOCK_SIZE will be wrong. This will cause wrong system memory infomation in sysfs. I think it should be: #define MIN_MEMORY_BLOCK_SIZE (1UL << SECTION_SIZE_BITS) And "echo offline > memory0/state" will cause following call trace: kernel BUG at mm/memory_hotplug.c:885! sh[6455]: bugcheck! 0 [1] Pid: 6455, CPU 0, comm: sh psr : 0000101008526030 ifs : 8000000000000fa4 ip : [<a0000001008c40f0>] Not tainted (3.6.0-rc1) ip is at offline_pages+0x210/0xee0 Call Trace: show_stack+0x80/0xa0 show_regs+0x640/0x920 die+0x190/0x2c0 die_if_kernel+0x50/0x80 ia64_bad_break+0x3d0/0x6e0 ia64_native_leave_kernel+0x0/0x270 offline_pages+0x210/0xee0 alloc_pages_current+0x180/0x2a0 Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: "Luck, Tony" <tony.luck@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02kobject: fix oops with "input0: bad kobj_uevent_env content in show_uevent()"Bjørn Mork
commit 60e233a56609fd963c59e99bd75c663d63fa91b6 upstream. Fengguang Wu <fengguang.wu@intel.com> writes: > After the __devinit* removal series, I can still get kernel panic in > show_uevent(). So there are more sources of bug.. > > Debug patch: > > @@ -343,8 +343,11 @@ static ssize_t show_uevent(struct device > goto out; > > /* copy keys to file */ > - for (i = 0; i < env->envp_idx; i++) > + dev_err(dev, "uevent %d env[%d]: %s/.../%s\n", env->buflen, env->envp_idx, top_kobj->name, dev->kobj.name); > + for (i = 0; i < env->envp_idx; i++) { > + printk(KERN_ERR "uevent %d env[%d]: %s\n", (int)count, i, env->envp[i]); > count += sprintf(&buf[count], "%s\n", env->envp[i]); > + } > > Oops message, the env[] is again not properly initilized: > > [ 44.068623] input input0: uevent 61 env[805306368]: input0/.../input0 > [ 44.069552] uevent 0 env[0]: (null) This is a completely different CONFIG_HOTPLUG problem, only demonstrating another reason why CONFIG_HOTPLUG should go away. I had a hard time trying to disable it anyway ;-) The problem this time is lots of code assuming that a call to add_uevent_var() will guarantee that env->buflen > 0. This is not true if CONFIG_HOTPLUG is unset. So things like this end up overwriting env->envp_idx because the array index is -1: if (add_uevent_var(env, "MODALIAS=")) return -ENOMEM; len = input_print_modalias(&env->buf[env->buflen - 1], sizeof(env->buf) - env->buflen, dev, 0); Don't know what the best action is, given that there seem to be a *lot* of this around the kernel. This patch "fixes" the problem for me, but I don't know if it can be considered an appropriate fix. [ It is the correct fix for now, for 3.7 forcing CONFIG_HOTPLUG to always be on is the longterm fix, but it's too late for 3.6 and older kernels to resolve this that way - gregkh ] Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Bjørn Mork <bjorn@mork.no> Tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02mmc: card: Skip secure erase on MoviNAND; causes unrecoverable corruption.Ian Chen
commit 3550ccdb9d8d350e526b809bf3dd92b550a74fe1 upstream. For several MoviNAND eMMC parts, there are known issues with secure erase and secure trim. For these specific MoviNAND devices, we skip these operations. Specifically, there is a bug in the eMMC firmware that causes unrecoverable corruption when the MMC is erased with MMC_CAP_ERASE enabled. References: http://forum.xda-developers.com/showthread.php?t=1644364 https://plus.google.com/111398485184813224730/posts/21pTYfTsCkB#111398485184813224730/posts/21pTYfTsCkB Signed-off-by: Ian Chen <ian.cy.chen@samsung.com> Reviewed-by: Namjae Jeon <linkinjeon@gmail.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02perf_event: Switch to internal refcount, fix race with close()Al Viro
commit a6fa941d94b411bbd2b6421ffbde6db3c93e65ab upstream. Don't mess with file refcounts (or keep a reference to file, for that matter) in perf_event. Use explicit refcount of its own instead. Deal with the race between the final reference to event going away and new children getting created for it by use of atomic_long_inc_not_zero() in inherit_event(); just have the latter free what it had allocated and return NULL, that works out just fine (children of siblings of something doomed are created as singletons, same as if the child of leader had been created and immediately killed). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120820135925.GG23464@ZenIV.linux.org.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02vfs: dcache: use DCACHE_DENTRY_KILLED instead of DCACHE_DISCONNECTED in d_kill()Miklos Szeredi
commit b161dfa6937ae46d50adce8a7c6b12233e96e7bd upstream. IBM reported a soft lockup after applying the fix for the rename_lock deadlock. Commit c83ce989cb5f ("VFS: Fix the nfs sillyrename regression in kernel 2.6.38") was found to be the culprit. The nfs sillyrename fix used DCACHE_DISCONNECTED to indicate that the dentry was killed. This flag can be set on non-killed dentries too, which results in infinite retries when trying to traverse the dentry tree. This patch introduces a separate flag: DCACHE_DENTRY_KILLED, which is only set in d_kill() and makes try_to_ascend() test only this flag. IBM reported successful test results with this patch. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02bnx2x: fix 57840_MF pci idYuval Mintz
[ Upstream commit 5c879d2094946081af934739850c7260e8b25d3c ] Commit c3def943c7117d42caaed3478731ea7c3c87190e have added support for new pci ids of the 57840 board, while failing to change the obsolete value in 'pci_ids.h'. This patch does so, allowing the probe of such devices. Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02af_netlink: force credentials passing [CVE-2012-3520]Eric Dumazet
[ Upstream commit e0e3cea46d31d23dc40df0a49a7a2c04fe8edfea ] Pablo Neira Ayuso discovered that avahi and potentially NetworkManager accept spoofed Netlink messages because of a kernel bug. The kernel passes all-zero SCM_CREDENTIALS ancillary data to the receiver if the sender did not provide such data, instead of not including any such data at all or including the correct data from the peer (as it is the case with AF_UNIX). This bug was introduced in commit 16e572626961 (af_unix: dont send SCM_CREDENTIALS by default) This patch forces passing credentials for netlink, as before the regression. Another fix would be to not add SCM_CREDENTIALS in netlink messages if not provided by the sender, but it might break some programs. With help from Florian Weimer & Petr Matousek This issue is designated as CVE-2012-3520 Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Florian Weimer <fweimer@redhat.com> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02af_packet: don't emit packet on orig fanout groupEric Leblond
[ Upstream commit c0de08d04215031d68fa13af36f347a6cfa252ca ] If a packet is emitted on one socket in one group of fanout sockets, it is transmitted again. It is thus read again on one of the sockets of the fanout group. This result in a loop for software which generate packets when receiving one. This retransmission is not the intended behavior: a fanout group must behave like a single socket. The packet should not be transmitted on a socket if it originates from a socket belonging to the same fanout group. This patch fixes the issue by changing the transmission check to take fanout group info account. Reported-by: Aleksandr Kotov <a1k@mail.ru> Signed-off-by: Eric Leblond <eric@regit.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02tcp: Apply device TSO segment limit earlierBen Hutchings
[ Upstream commit 1485348d2424e1131ea42efc033cbd9366462b01 ] Cache the device gso_max_segs in sock::sk_gso_max_segs and use it to limit the size of TSO skbs. This avoids the need to fall back to software GSO for local TCP senders. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02net: Allow driver to limit number of GSO segments per skbBen Hutchings
[ Upstream commit 30b678d844af3305cda5953467005cebb5d7b687 ] A peer (or local user) may cause TCP to use a nominal MSS of as little as 88 (actual MSS of 76 with timestamps). Given that we have a sufficiently prodigious local sender and the peer ACKs quickly enough, it is nevertheless possible to grow the window for such a connection to the point that we will try to send just under 64K at once. This results in a single skb that expands to 861 segments. In some drivers with TSO support, such an skb will require hundreds of DMA descriptors; a substantial fraction of a TX ring or even more than a full ring. The TX queue selected for the skb may stall and trigger the TX watchdog repeatedly (since the problem skb will be retried after the TX reset). This particularly affects sfc, for which the issue is designated as CVE-2012-3412. Therefore: 1. Add the field net_device::gso_max_segs holding the device-specific limit. 2. In netif_skb_features(), if the number of segments is too high then mask out GSO features to force fall back to software GSO. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-26USB: add USB_VENDOR_AND_INTERFACE_INFO() macroGustavo Padovan
commit d81a5d1956731c453b85c141458d4ff5d6cc5366 upstream. A lot of Broadcom Bluetooth devices provides vendor specific interface class and we are getting flooded by patches adding new device support. This change will help us enable support for any other Broadcom with vendor specific device that arrives in the future. Only the product id changes for those devices, so this macro would be perfect for us: { USB_VENDOR_AND_INTERFACE_INFO(0x0a5c, 0xff, 0x01, 0x01) } Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Acked-by: Henrik Rydberg <rydberg@bitmath.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-26ext4: make sure the journal sb is written in ext4_clear_journal_err()Theodore Ts'o
commit d796c52ef0b71a988364f6109aeb63d79c5b116b upstream. After we transfer set the EXT4_ERROR_FS bit in the file system superblock, it's not enough to call jbd2_journal_clear_err() to clear the error indication from journal superblock --- we need to call jbd2_journal_update_sb_errno() as well. Otherwise, when the root file system is mounted read-only, the journal is replayed, and the error indicator is transferred to the superblock --- but the s_errno field in the jbd2 superblock is left set (since although we cleared it in memory, we never flushed it out to disk). This can end up confusing e2fsck. We should make e2fsck more robust in this case, but the kernel shouldn't be leaving things in this confused state, either. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-26drm/radeon: add some new SI pci idsAlex Deucher
commit 2f292004dd1fb005788dc0a9cdd5559812ed866e upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15Input: eeti_ts: pass gpio value instead of IRQArnd Bergmann
commit 4eef6cbfcc03b294d9d334368a851b35b496ce53 upstream. The EETI touchscreen asserts its IRQ line as soon as it has data in its internal buffers. The line is automatically deasserted once all data has been read via I2C. Hence, the driver has to monitor the GPIO line and cannot simply rely on the interrupt handler reception. In the current implementation of the driver, irq_to_gpio() is used to determine the GPIO number from the i2c_client's IRQ value. As irq_to_gpio() is not available on all platforms, this patch changes this and makes the driver ignore the passed in IRQ. Instead, a GPIO is added to the platform_data struct and gpio_to_irq is used to derive the IRQ from that GPIO. If this fails, bail out. The driver is only able to work in environments where the touchscreen GPIO can be mapped to an IRQ. Without this patch, building raumfeld_defconfig results in: drivers/input/touchscreen/eeti_ts.c: In function 'eeti_ts_irq_active': drivers/input/touchscreen/eeti_ts.c:65:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration] Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Sven Neumann <s.neumann@raumfeld.com> Cc: linux-input@vger.kernel.org Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15ARM: pxa: remove irq_to_gpio from ezx-pcap driverArnd Bergmann
commit 59ee93a528b94ef4e81a08db252b0326feff171f upstream. The irq_to_gpio function was removed from the pxa platform in linux-3.2, and this driver has been broken since. There is actually no in-tree user of this driver that adds this platform device, but the driver can and does get enabled on some platforms. Without this patch, building ezx_defconfig results in: drivers/mfd/ezx-pcap.c: In function 'pcap_isr_work': drivers/mfd/ezx-pcap.c:205:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: remove rand_initialize_irq()Theodore Ts'o
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream. With the new interrupt sampling system, we are no longer using the timer_rand_state structure in the irq descriptor, so we can stop initializing it now. [ Merged in fixes from Sedat to find some last missing references to rand_initialize_irq() ] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: add tracepoints for easier debugging and verificationTheodore Ts'o
commit 00ce1db1a634746040ace24c09a4e3a7949a3145 upstream. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: add new get_random_bytes_arch() functionTheodore Ts'o
commit c2557a303ab6712bb6e09447df828c557c710ac9 upstream. Create a new function, get_random_bytes_arch() which will use the architecture-specific hardware random number generator if it is present. Change get_random_bytes() to not use the HW RNG, even if it is avaiable. The reason for this is that the hw random number generator is fast (if it is present), but it requires that we trust the hardware manufacturer to have not put in a back door. (For example, an increasing counter encrypted by an AES key known to the NSA.) It's unlikely that Intel (for example) was paid off by the US Government to do this, but it's impossible for them to prove otherwise --- especially since Bull Mountain is documented to use AES as a whitener. Hence, the output of an evil, trojan-horse version of RDRAND is statistically indistinguishable from an RDRAND implemented to the specifications claimed by Intel. Short of using a tunnelling electronic microscope to reverse engineer an Ivy Bridge chip and disassembling and analyzing the CPU microcode, there's no way for us to tell for sure. Since users of get_random_bytes() in the Linux kernel need to be able to support hardware systems where the HW RNG is not present, most time-sensitive users of this interface have already created their own cryptographic RNG interface which uses get_random_bytes() as a seed. So it's much better to use the HW RNG to improve the existing random number generator, by mixing in any entropy returned by the HW RNG into /dev/random's entropy pool, but to always _use_ /dev/random's entropy pool. This way we get almost of the benefits of the HW RNG without any potential liabilities. The only benefits we forgo is the speed/performance enhancements --- and generic kernel code can't depend on depend on get_random_bytes() having the speed of a HW RNG anyway. For those places that really want access to the arch-specific HW RNG, if it is available, we provide get_random_bytes_arch(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: create add_device_randomness() interfaceLinus Torvalds
commit a2080a67abe9e314f9e9c2cc3a4a176e8a8f8793 upstream. Add a new interface, add_device_randomness() for adding data to the random pool that is likely to differ between two devices (or possibly even per boot). This would be things like MAC addresses or serial numbers, or the read-out of the RTC. This does *not* add any actual entropy to the pool, but it initializes the pool to different values for devices that might otherwise be identical and have very little entropy available to them (particularly common in the embedded world). [ Modified by tytso to mix in a timestamp, since there may be some variability caused by the time needed to detect/configure the hardware in question. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: make 'add_interrupt_randomness()' do something saneTheodore Ts'o
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream. We've been moving away from add_interrupt_randomness() for various reasons: it's too expensive to do on every interrupt, and flooding the CPU with interrupts could theoretically cause bogus floods of entropy from a somewhat externally controllable source. This solves both problems by limiting the actual randomness addition to just once a second or after 64 interrupts, whicever comes first. During that time, the interrupt cycle data is buffered up in a per-cpu pool. Also, we make sure the the nonblocking pool used by urandom is initialized before we start feeding the normal input pool. This assures that /dev/urandom is returning unpredictable data as soon as possible. (Based on an original patch by Linus, but significantly modified by tytso.) Tested-by: Eric Wustrow <ewust@umich.edu> Reported-by: Eric Wustrow <ewust@umich.edu> Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu> Reported-by: Zakir Durumeric <zakir@umich.edu> Reported-by: J. Alex Halderman <jhalderm@umich.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream. Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09workqueue: perform cpu down operations from low priority cpu_notifier()Tejun Heo
commit 6575820221f7a4dd6eadecf7bf83cdd154335eda upstream. Currently, all workqueue cpu hotplug operations run off CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to ensure that workqueue is up and running while bringing up a CPU before other notifiers try to use workqueue on the CPU. Per-cpu workqueues are supposed to remain working and bound to the CPU for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even with workqueue offlining running with higher priority because workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which runs the per-cpu workqueue without concurrency management without explicitly detaching the existing workers. However, if the trustee needs to create new workers, it creates unbound workers which may wander off to other CPUs while CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU down is cancelled, the per-CPU workqueue may end up with workers which aren't bound to the CPU. While reliably reproducible with a convoluted artificial test-case involving scheduling and flushing CPU burning work items from CPU down notifiers, this isn't very likely to happen in the wild, and, even when it happens, the effects are likely to be hidden by the following successful CPU down. Fix it by using different priorities for up and down notifiers - high priority for up operations and low priority for down operations. Workqueue cpu hotplug operations will soon go through further cleanup. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09tun: fix a crash bug and a memory leakMikulas Patocka
commit b09e786bd1dd66418b69348cb110f3a64764626a upstream. This patch fixes a crash tun_chr_close -> netdev_run_todo -> tun_free_netdev -> sk_release_kernel -> sock_release -> iput(SOCK_INODE(sock)) introduced by commit 1ab5ecb90cb6a3df1476e052f76a6e8f6511cb3d The problem is that this socket is embedded in struct tun_struct, it has no inode, iput is called on invalid inode, which modifies invalid memory and optionally causes a crash. sock_release also decrements sockets_in_use, this causes a bug that "sockets: used" field in /proc/*/net/sockstat keeps on decreasing when creating and closing tun devices. This patch introduces a flag SOCK_EXTERNALLY_ALLOCATED that instructs sock_release to not free the inode and not decrement sockets_in_use, fixing both memory corruption and sockets_in_use underflow. It should be backported to 3.3 an 3.4 stabke. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09x86/mce: Fix siginfo_t->si_addr value for non-recoverable memory faultsTony Luck
commit 6751ed65dc6642af64f7b8a440a75563c8aab7ae upstream. In commit dad1743e5993f1 ("x86/mce: Only restart instruction after machine check recovery if it is safe") we fixed mce_notify_process() to force a signal to the current process if it was not restartable (RIPV bit not set in MCG_STATUS). But doing it here means that the process doesn't get told the virtual address of the fault via siginfo_t->si_addr. This would prevent application level recovery from the fault. Make a new MF_MUST_KILL flag bit for memory_failure() et al. to use so that we will provide the right information with the signal. Signed-off-by: Tony Luck <tony.luck@intel.com> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09target: Add generation of LOGICAL BLOCK ADDRESS OUT OF RANGERoland Dreier
commit e2397c704429025bc6b331a970f699e52f34283e upstream. Many SCSI commands are defined to return a CHECK CONDITION / ILLEGAL REQUEST with ASC set to LOGICAL BLOCK ADDRESS OUT OF RANGE if the initiator sends a command that accesses a too-big LBA. Add an enum value and case entries so that target code can return this status. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19NFC: Export nfc.h to userlandSamuel Ortiz
commit dbd4fcaf8d664fab4163b1f8682e41ad8bff3444 upstream. The netlink commands and attributes, along with the socket structure definitions need to be exported. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19timekeeping: Provide hrtimer update functionThomas Gleixner
This is a backport of f6c06abfb3972ad4914cef57d8348fcb2932bc3b To finally fix the infamous leap second issue and other race windows caused by functions which change the offsets between the various time bases (CLOCK_MONOTONIC, CLOCK_REALTIME and CLOCK_BOOTTIME) we need a function which atomically gets the current monotonic time and updates the offsets of CLOCK_REALTIME and CLOCK_BOOTTIME with minimalistic overhead. The previous patch which provides ktime_t offsets allows us to make this function almost as cheap as ktime_get() which is going to be replaced in hrtimer_interrupt(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: John Stultz <johnstul@us.ibm.com> Link: http://lkml.kernel.org/r/1341960205-56738-7-git-send-email-johnstul@us.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19hrtimer: Provide clock_was_set_delayed()John Stultz
This is a backport of f55a6faa384304c89cfef162768e88374d3312cb clock_was_set() cannot be called from hard interrupt context because it calls on_each_cpu(). For fixing the widely reported leap seconds issue it is necessary to call it from hard interrupt context, i.e. the timer tick code, which does the timekeeping updates. Provide a new function which denotes it in the hrtimer cpu base structure of the cpu on which it is called and raise the hrtimer softirq. We then execute the clock_was_set() notificiation from softirq context in run_hrtimer_softirq(). The hrtimer softirq is rarely used, so polling the flag there is not a performance issue. [ tglx: Made it depend on CONFIG_HIGH_RES_TIMERS. We really should get rid of all this ifdeffery ASAP ] Signed-off-by: John Stultz <johnstul@us.ibm.com> Reported-by: Jan Engelhardt <jengelh@inai.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1341960205-56738-2-git-send-email-johnstul@us.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19sched/nohz: Rewrite and fix load-avg computation -- againPeter Zijlstra
commit 5167e8d5417bf5c322a703d2927daec727ea40dd upstream. Thanks to Charles Wang for spotting the defects in the current code: - If we go idle during the sample window -- after sampling, we get a negative bias because we can negate our own sample. - If we wake up during the sample window we get a positive bias because we push the sample to a known active period. So rewrite the entire nohz load-avg muck once again, now adding copious documentation to the code. Reported-and-tested-by: Doug Smythies <dsmythies@telus.net> Reported-and-tested-by: Charles Wang <muming.wq@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1340373782.18025.74.camel@twins [ minor edits ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16memblock: free allocated memblock_reserved_regions laterYinghai Lu
commit 29f6738609e40227dabcc63bfb3b84b3726a75bd upstream. memblock_free_reserved_regions() calls memblock_free(), but memblock_free() would double reserved.regions too, so we could free the old range for reserved.regions. Also tj said there is another bug which could be related to this. | I don't think we're saving any noticeable | amount by doing this "free - give it to page allocator - reserve | again" dancing. We should just allocate regions aligned to page | boundaries and free them later when memblock is no longer in use. in that case, when DEBUG_PAGEALLOC, will get panic: memblock_free: [0x0000102febc080-0x0000102febf080] memblock_free_reserved_regions+0x37/0x39 BUG: unable to handle kernel paging request at ffff88102febd948 IP: [<ffffffff836a5774>] __next_free_mem_range+0x9b/0x155 PGD 4826063 PUD cf67a067 PMD cf7fa067 PTE 800000102febd160 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU 0 Pid: 0, comm: swapper Not tainted 3.5.0-rc2-next-20120614-sasha #447 RIP: 0010:[<ffffffff836a5774>] [<ffffffff836a5774>] __next_free_mem_range+0x9b/0x155 See the discussion at https://lkml.org/lkml/2012/6/13/469 So try to allocate with PAGE_SIZE alignment and free it later. Reported-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16memory hotplug: fix invalid memory access caused by stale kswapd pointerJiang Liu
commit d8adde17e5f858427504725218c56aef90e90fc7 upstream. kswapd_stop() is called to destroy the kswapd work thread when all memory of a NUMA node has been offlined. But kswapd_stop() only terminates the work thread without resetting NODE_DATA(nid)->kswapd to NULL. The stale pointer will prevent kswapd_run() from creating a new work thread when adding memory to the memory-less NUMA node again. Eventually the stale pointer may cause invalid memory access. An example stack dump as below. It's reproduced with 2.6.32, but latest kernel has the same issue. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81051a94>] exit_creds+0x12/0x78 PGD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/system/memory/memory391/state CPU 11 Modules linked in: cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq microcode fuse loop dm_mod tpm_tis rtc_cmos i2c_i801 rtc_core tpm serio_raw pcspkr sg tpm_bios igb i2c_core iTCO_wdt rtc_lib mptctl iTCO_vendor_support button dca bnx2 usbhid hid uhci_hcd ehci_hcd usbcore sd_mod crc_t10dif edd ext3 mbcache jbd fan ide_pci_generic ide_core ata_generic ata_piix libata thermal processor thermal_sys hwmon mptsas mptscsih mptbase scsi_transport_sas scsi_mod Pid: 7949, comm: sh Not tainted 2.6.32.12-qiuxishi-5-default #92 Tecal RH2285 RIP: 0010:exit_creds+0x12/0x78 RSP: 0018:ffff8806044f1d78 EFLAGS: 00010202 RAX: 0000000000000000 RBX: ffff880604f22140 RCX: 0000000000019502 RDX: 0000000000000000 RSI: 0000000000000202 RDI: 0000000000000000 RBP: ffff880604f22150 R08: 0000000000000000 R09: ffffffff81a4dc10 R10: 00000000000032a0 R11: ffff880006202500 R12: 0000000000000000 R13: 0000000000c40000 R14: 0000000000008000 R15: 0000000000000001 FS: 00007fbc03d066f0(0000) GS:ffff8800282e0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000000 CR3: 000000060f029000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process sh (pid: 7949, threadinfo ffff8806044f0000, task ffff880603d7c600) Stack: ffff880604f22140 ffffffff8103aac5 ffff880604f22140 ffffffff8104d21e ffff880006202500 0000000000008000 0000000000c38000 ffffffff810bd5b1 0000000000000000 ffff880603d7c600 00000000ffffdd29 0000000000000003 Call Trace: __put_task_struct+0x5d/0x97 kthread_stop+0x50/0x58 offline_pages+0x324/0x3da memory_block_change_state+0x179/0x1db store_mem_state+0x9e/0xbb sysfs_write_file+0xd0/0x107 vfs_write+0xad/0x169 sys_write+0x45/0x6e system_call_fastpath+0x16/0x1b Code: ff 4d 00 0f 94 c0 84 c0 74 08 48 89 ef e8 1f fd ff ff 5b 5d 31 c0 41 5c c3 53 48 8b 87 20 06 00 00 48 89 fb 48 8b bf 18 06 00 00 <8b> 00 48 c7 83 18 06 00 00 00 00 00 00 f0 ff 0f 0f 94 c0 84 c0 RIP exit_creds+0x12/0x78 RSP <ffff8806044f1d78> CR2: 0000000000000000 [akpm@linux-foundation.org: add pglist_data.kswapd locking comments] Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16splice: fix racy pipe->buffers usesEric Dumazet
commit 047fe3605235888f3ebcda0c728cb31937eadfe6 upstream. Dave Jones reported a kernel BUG at mm/slub.c:3474! triggered by splice_shrink_spd() called from vmsplice_to_pipe() commit 35f3d14dbbc5 (pipe: add support for shrinking and growing pipes) added capability to adjust pipe->buffers. Problem is some paths don't hold pipe mutex and assume pipe->buffers doesn't change for their duration. Fix this by adding nr_pages_max field in struct splice_pipe_desc, and use it in place of pipe->buffers where appropriate. splice_shrink_spd() loses its struct pipe_inode_info argument. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Tom Herbert <therbert@google.com> Tested-by: Dave Jones <davej@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> [bwh: Backported to 3.2: - Adjust context in vmsplice_to_pipe() - Update one more call to splice_shrink_spd(), from skb_splice_bits()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16thp: avoid atomic64_read in pmd_read_atomic for 32bit PAEAndrea Arcangeli
commit e4eed03fd06578571c01d4f1478c874bb432c815 upstream. In the x86 32bit PAE CONFIG_TRANSPARENT_HUGEPAGE=y case while holding the mmap_sem for reading, cmpxchg8b cannot be used to read pmd contents under Xen. So instead of dealing only with "consistent" pmdvals in pmd_none_or_trans_huge_or_clear_bad() (which would be conceptually simpler) we let pmd_none_or_trans_huge_or_clear_bad() deal with pmdvals where the low 32bit and high 32bit could be inconsistent (to avoid having to use cmpxchg8b). The only guarantee we get from pmd_read_atomic is that if the low part of the pmd was found null, the high part will be null too (so the pmd will be considered unstable). And if the low part of the pmd is found "stable" later, then it means the whole pmd was read atomically (because after a pmd is stable, neither MADV_DONTNEED nor page faults can alter it anymore, and we read the high part after the low part). In the 32bit PAE x86 case, it is enough to read the low part of the pmdval atomically to declare the pmd as "stable" and that's true for THP and no THP, furthermore in the THP case we also have a barrier() that will prevent any inconsistent pmdvals to be cached by a later re-read of the *pmd. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Jonathan Nieder <jrnieder@gmail.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Tested-by: Andrew Jones <drjones@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16mm: pmd_read_atomic: fix 32bit PAE pmd walk vs pmd_populate SMP race conditionAndrea Arcangeli
commit 26c191788f18129af0eb32a358cdaea0c7479626 upstream. When holding the mmap_sem for reading, pmd_offset_map_lock should only run on a pmd_t that has been read atomically from the pmdp pointer, otherwise we may read only half of it leading to this crash. PID: 11679 TASK: f06e8000 CPU: 3 COMMAND: "do_race_2_panic" #0 [f06a9dd8] crash_kexec at c049b5ec #1 [f06a9e2c] oops_end at c083d1c2 #2 [f06a9e40] no_context at c0433ded #3 [f06a9e64] bad_area_nosemaphore at c043401a #4 [f06a9e6c] __do_page_fault at c0434493 #5 [f06a9eec] do_page_fault at c083eb45 #6 [f06a9f04] error_code (via page_fault) at c083c5d5 EAX: 01fb470c EBX: fff35000 ECX: 00000003 EDX: 00000100 EBP: 00000000 DS: 007b ESI: 9e201000 ES: 007b EDI: 01fb4700 GS: 00e0 CS: 0060 EIP: c083bc14 ERR: ffffffff EFLAGS: 00010246 #7 [f06a9f38] _spin_lock at c083bc14 #8 [f06a9f44] sys_mincore at c0507b7d #9 [f06a9fb0] system_call at c083becd start len EAX: ffffffda EBX: 9e200000 ECX: 00001000 EDX: 6228537f DS: 007b ESI: 00000000 ES: 007b EDI: 003d0f00 SS: 007b ESP: 62285354 EBP: 62285388 GS: 0033 CS: 0073 EIP: 00291416 ERR: 000000da EFLAGS: 00000286 This should be a longstanding bug affecting x86 32bit PAE without THP. Only archs with 64bit large pmd_t and 32bit unsigned long should be affected. With THP enabled the barrier() in pmd_none_or_trans_huge_or_clear_bad() would partly hide the bug when the pmd transition from none to stable, by forcing a re-read of the *pmd in pmd_offset_map_lock, but when THP is enabled a new set of problem arises by the fact could then transition freely in any of the none, pmd_trans_huge or pmd_trans_stable states. So making the barrier in pmd_none_or_trans_huge_or_clear_bad() unconditional isn't good idea and it would be a flakey solution. This should be fully fixed by introducing a pmd_read_atomic that reads the pmd in order with THP disabled, or by reading the pmd atomically with cmpxchg8b with THP enabled. Luckily this new race condition only triggers in the places that must already be covered by pmd_none_or_trans_huge_or_clear_bad() so the fix is localized there but this bug is not related to THP. NOTE: this can trigger on x86 32bit systems with PAE enabled with more than 4G of ram, otherwise the high part of the pmd will never risk to be truncated because it would be zero at all times, in turn so hiding the SMP race. This bug was discovered and fully debugged by Ulrich, quote: ---- [..] pmd_none_or_trans_huge_or_clear_bad() loads the content of edx and eax. 496 static inline int pmd_none_or_trans_huge_or_clear_bad(pmd_t *pmd) 497 { 498 /* depend on compiler for an atomic pmd read */ 499 pmd_t pmdval = *pmd; // edi = pmd pointer 0xc0507a74 <sys_mincore+548>: mov 0x8(%esp),%edi ... // edx = PTE page table high address 0xc0507a84 <sys_mincore+564>: mov 0x4(%edi),%edx ... // eax = PTE page table low address 0xc0507a8e <sys_mincore+574>: mov (%edi),%eax [..] Please note that the PMD is not read atomically. These are two "mov" instructions where the high order bits of the PMD entry are fetched first. Hence, the above machine code is prone to the following race. - The PMD entry {high|low} is 0x0000000000000000. The "mov" at 0xc0507a84 loads 0x00000000 into edx. - A page fault (on another CPU) sneaks in between the two "mov" instructions and instantiates the PMD. - The PMD entry {high|low} is now 0x00000003fda38067. The "mov" at 0xc0507a8e loads 0xfda38067 into eax. ---- Reported-by: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16SUNRPC: new svc_bind() routine introducedStanislav Kinsbursky
upstream commit 9793f7c88937e7ac07305ab1af1a519225836823. This new routine is responsible for service registration in a specified network context. The idea is to separate service creation from per-net operations. Note also: since registering service with svc_bind() can fail, the service will be destroyed and during destruction it will try to unregister itself from rpcbind. In this case unregistration has to be skipped. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16Lockd: pass network namespace to creation and destruction routinesStanislav Kinsbursky
upstream commit e3f70eadb7dddfb5a2bb9afff7abfc6ee17a29d0. v2: dereference of most probably already released nlm_host removed in nlmclnt_done() and reclaimer(). These routines are called from locks reclaimer() kernel thread. This thread works in "init_net" network context and currently relays on persence on lockd thread and it's per-net resources. Thus lockd_up() and lockd_down() can't relay on current network context. So let's pass corrent one into them. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16PCI: EHCI: fix crash during suspend on ASUS computersAlan Stern
commit dbf0e4c7257f8d684ec1a3c919853464293de66e upstream. Quite a few ASUS computers experience a nasty problem, related to the EHCI controllers, when going into system suspend. It was observed that the problem didn't occur if the controllers were not put into the D3 power state before starting the suspend, and commit 151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during suspend on ASUS computers) was created to do this. It turned out this approach messed up other computers that didn't have the problem -- it prevented USB wakeup from working. Consequently commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b (USB: add NO_D3_DURING_SLEEP flag and revert 151b61284776be2) was merged; it reverted the earlier commit and added a whitelist of known good board names. Now we know the actual cause of the problem. Thanks to AceLan Kao for tracking it down. According to him, an engineer at ASUS explained that some of their BIOSes contain a bug that was added in an attempt to work around a problem in early versions of Windows. When the computer goes into S3 suspend, the BIOS tries to verify that the EHCI controllers were first quiesced by the OS. Nothing's wrong with this, but the BIOS does it by checking that the PCI COMMAND registers contain 0 without checking the controllers' power state. If the register isn't 0, the BIOS assumes the controller needs to be quiesced and tries to do so. This involves making various MMIO accesses to the controller, which don't work very well if the controller is already in D3. The end result is a system hang or memory corruption. Since the value in the PCI COMMAND register doesn't matter once the controller has been suspended, and since the value will be restored anyway when the controller is resumed, we can work around the BIOS bug simply by setting the register to 0 during system suspend. This patch (as1590) does so and also reverts the second commit mentioned above, which is now unnecessary. In theory we could do this for every PCI device. However to avoid introducing new problems, the patch restricts itself to EHCI host controllers. Finally the affected systems can suspend with USB wakeup working properly. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=37632 Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42728 Based-on-patch-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Dâniel Fraga <fragabr@gmail.com> Tested-by: Javier Marcet <jmarcet@gmail.com> Tested-by: Andrey Rahmatullin <wrar@wrar.name> Tested-by: Oleksij Rempel <bug-track@fisher-privat.net> Tested-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16SCSI: libsas: fix taskfile corruption in sas_ata_qc_fill_rtfDan Williams
commit 6ef1b512f4e6f936d89aa20be3d97a7ec7c290ac upstream. fill_result_tf() grabs the taskfile flags from the originating qc which sas_ata_qc_fill_rtf() promptly overwrites. The presence of an ata_taskfile in the sata_device makes it tempting to just copy the full contents in sas_ata_qc_fill_rtf(). However, libata really only wants the fis contents and expects the other portions of the taskfile to not be touched by ->qc_fill_rtf. To that end store a fis buffer in the sata_device and use ata_tf_from_fis() like every other ->qc_fill_rtf() implementation. Reported-by: Praveen Murali <pmurali@logicube.com> Tested-by: Praveen Murali <pmurali@logicube.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16SCSI: Fix NULL dereferences in scsi_cmd_to_driverMark Rustad
commit 222a806af830fda34ad1f6bc991cd226916de060 upstream. Avoid crashing if the private_data pointer happens to be NULL. This has been seen sometimes when a host reset happens, notably when there are many LUNs: host3: Assigned Port ID 0c1601 scsi host3: libfc: Host reset succeeded on port (0c1601) BUG: unable to handle kernel NULL pointer dereference at 0000000000000350 IP: [<ffffffff81352bb8>] scsi_send_eh_cmnd+0x58/0x3a0 <snip> Process scsi_eh_3 (pid: 4144, threadinfo ffff88030920c000, task ffff880326b160c0) Stack: 000000010372e6ba 0000000000000282 000027100920dca0 ffffffffa0038ee0 0000000000000000 0000000000030003 ffff88030920dc80 ffff88030920dc80 00000002000e0000 0000000a00004000 ffff8803242f7760 ffff88031326ed80 Call Trace: [<ffffffff8105b590>] ? lock_timer_base+0x70/0x70 [<ffffffff81352fbe>] scsi_eh_tur+0x3e/0xc0 [<ffffffff81353a36>] scsi_eh_test_devices+0x76/0x170 [<ffffffff81354125>] scsi_eh_host_reset+0x85/0x160 [<ffffffff81354291>] scsi_eh_ready_devs+0x91/0x110 [<ffffffff813543fd>] scsi_unjam_host+0xed/0x1f0 [<ffffffff813546a8>] scsi_error_handler+0x1a8/0x200 [<ffffffff81354500>] ? scsi_unjam_host+0x1f0/0x1f0 [<ffffffff8106ec3e>] kthread+0x9e/0xb0 [<ffffffff81509264>] kernel_thread_helper+0x4/0x10 [<ffffffff8106eba0>] ? kthread_freezable_should_stop+0x70/0x70 [<ffffffff81509260>] ? gs_change+0x13/0x13 Code: 25 28 00 00 00 48 89 45 c8 31 c0 48 8b 87 80 00 00 00 48 8d b5 60 ff ff ff 89 d1 48 89 fb 41 89 d6 4c 89 fa 48 8b 80 b8 00 00 00 <48> 8b 80 50 03 00 00 48 8b 00 48 89 85 38 ff ff ff 48 8b 07 4c RIP [<ffffffff81352bb8>] scsi_send_eh_cmnd+0x58/0x3a0 RSP <ffff88030920dc50> CR2: 0000000000000350 Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Tested-by: Marcus Dennis <marcusx.e.dennis@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
