path: root/include
2014-06-20can: dev: let can_get_echo_skb() return dlc of CAN frameMarc Kleine-Budde
can_get_echo_skb() is usually called in the TX complete handler. The stats->tx_packets and stats->tx_bytes should be updated there, too. This patch simplifies to figure out the size of the sent CAN frame. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-01-27input: touchscreen: added platform data for Fusion touchscreenStefan Agner
Added platform data struct to define interrupt and reset GPIO. This allows to initialize the touchscreen controller inside the driver rather then in each platform and use the driver as a module.
2013-11-05mvf_adc: support all 32 channelsStefan Agner
Enable support for all 32 ADC channels, even the internal one. This is needed to read out the internal temperature since the sensor is at channel 26.
2013-11-05mvf_adc: fix register configuration in adc_setStefan Agner
Several registers in adc_set were set logical inverse or even the wrong bits in the registers. Also, return the users ioctrl if the configuration is not valid.
2013-10-21Merge branch '3.0-mvf' into colibri_vfMarcel Ziswiler
2013-10-04Add mvf_sema4.h to header install list and allow to be includedAnthony Felice
outside of the kernel.
2013-10-02colibri-vf50-ts/mvf-adc: Moved touchscreen support in a moduleStefan Agner
The touchscreen support backed by hardware on the Colibri VF50 module and the Vybrid ADC is now moved to a own module for better maintainability. The mvf-adc driver exports some of its method now. A good good locking mechanism is still missing.
2013-09-23mtd: nand: add Eon Silicon Solutions manufacturer IDBrian Norris
Eon's new NAND flash: EN27LN1G08. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-07-31add a test call to determine state ofEd Nash
semaphore without requesting it
2013-07-29add support for spin locksEd Nash
2013-07-29add latency stats and make debugfs writeableEd Nash
2013-07-28fix debugfs worng directory for gate.Ed Nash
cleanup debug comment / code in i2c-imx
2013-07-27add debugfs statistics and some code cleanupEd Nash
2013-02-17add semaphore protection with MQX of I2C busEd Nash
2012-12-12ENGR00181365-2: ADC: Add driver support for ADC VybridWang Xiaojun
Add driver support for ADC Vybrid. Signed-off-by: Wang Xiaojun <b41435@freescale.com>
2012-12-12ENGR00216087-1: ASRC support for VybridJingchang Lu
The ASRC driver supports stereo audio streams resample, the ASRCK1 serial clock using audio external clock source can not support 44.1K sample rate due to divider and prescaler restriction. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-12-12ENGR00216076-2: DCU: Update DCU driver for PM and blending issueAlison Wang
Fix layers blending and reinitialization issue for DCU driver. Update power management part for DCU driver. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-17ENGR00181395-1: Add UART MISC functions support for FaradayJingchang Lu
Add hardware flow control support, Add transmit DMA support, Add FIFO operation support, Add MSB/LSB on data support, Add 9-bits MARK/SPACE support. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-09-12ENGR00181396-2: high-speed USB device disconnection managementJingchang Lu
Detection of high-speed USB device disconnection should be enable on connection and disable on disconnection. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-09-12ENGR00212251-1: sai: add platform support for SAI driverAlison Wang
Add platform support for SAI driver. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-03-07ENGR00176147-3: usb: change data types for wakeup_eventPeter Chen
In order to know which wakeup event occurs for usb wakeup Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-03-07ENGR00176061-2 usb: otg: add discharge vbus flagPeter Chen
Add discharge vbus flag Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-03-07ENGR00175864 [MMC]pipeline mmc requestsTony Lin
the patch is based on a series of patches by Per Forlin the patch is sdhci host side implementation. using a toshiba SDHC3.0 card, the performance increases from 48.5MB/s to 52.4MB/s. cmd: dd if=/dev/mmcblk0 of=/dev/null bs=1M count=500 the performance results running@1GHz, 200MHz CPU freq are: 52.4MB/s -> 20.7MB/s Signed-off-by: Tony Lin <tony.lin@freescale.com>
2012-03-06ENGR00170526-2 AUDIO: Remove struct field rst_gpio to audio platform dataLionel Xu
Remove rst_gpio field to mxc_audio_platform_data. Signed-off-by: Lionel Xu <Lionel.Xu@freescale.com>
2012-03-01mmc: queue: let host controllers specify maximum discard timeoutAdrian Hunter
Some host controllers will not operate without a hardware timeout that is limited in value. However large discards require large timeouts, so there needs to be a way to specify the maximum discard size. A host controller driver may now specify the maximum discard timeout possible so that max_discard_sectors can be calculated. However, for eMMC when the High Capacity Erase Group Size is not in use, the timeout calculation depends on clock rate which may change. For that case Preferred Erase Size is used instead. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-03-01mmc: block: allow get_card_status() to return error statusRussell King - ARM Linux
If the MMC_SEND_STATUS command is not successful, we should not return a zero status word, but instead allow the caller to know positively that an error occurred. Convert the open-coded get_card_status() to use the helper function, and provide definitions for the card state field. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-03-01mmc: core: add non-blocking mmc request functionPer Forlin
Previously there has only been one function mmc_wait_for_req() to start and wait for a request. This patch adds: * mmc_start_req() - starts a request wihtout waiting If there is on ongoing request wait for completion of that request and start the new one and return. Does not wait for the new command to complete. This patch also adds new function members in struct mmc_host_ops only called from core.c: * pre_req - asks the host driver to prepare for the next job * post_req - asks the host driver to clean up after a completed job The intention is to use pre_req() and post_req() to do cache maintenance while a request is active. pre_req() can be called while a request is active to minimize latency to start next job. post_req() can be used after the next job is started to clean up the request. This will minimize the host driver request end latency. post_req() is typically used before ending the block request and handing over the buffer to the block layer. Add a host-private member in mmc_data to be used by pre_req to mark the data. The host driver will then check this mark to see if the data is prepared or not. Signed-off-by: Per Forlin <per.forlin@linaro.org> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Venkatraman S <svenkatr@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-02-28plist: Remove the need to supply locks to plist headsDima Zavin
This was legacy code brought over from the RT tree and is no longer necessary. Signed-off-by: Dima Zavin <dima@android.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Walker <dwalker@codeaurora.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-23ENGR00175221-02 [MX6] MMCSD: clear EXE_TUNE bit after tuning finishes.Ryan QIAN
- add hook for post tuning in common code - add hook for post tuning for platform code to deal with clean up stuff on finishing tuning. Signed-off-by: Ryan QIAN <b32804@freescale.com>
2012-02-22ENGR00174734-3 usb: change function name for discharge data linePeter Chen
In order to reflect the function well, it needs to discharge both dp and dm, so change the function name. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-02-21ENGR00171079-3 fsl_devices add generic audio codec platform dataAdrian Alonso
* Add generic audio codec platform_data to be able to pass specific settings to audio codecs found in Freescale target boards. * cs42888 get this platform data to override specific settings Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2012-02-17ENGR00173964 make hdmi audio init dependent on hdmi video initAlan Tull
Don't show hdmi as an audio playback device if hdmi isn't configured on the command line. Signed-off-by: Alan Tull <r80115@freescale.com>
2012-02-17ENGR00174747 ASRC:fix spinlock bugChen Liangjun
When use clk_enable and clk_disable function, system may enter sleep. so these 2 funciton can not used surrounding with spin lock/unlock. And the clk_enable/disable function already keep the counter of open and close and it is no need to keep the counter in driver. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-02-17ENGR00174732 ASRC:close core clock if ASRC idleChen Liangjun
Close ASRC core clock when ASRC device is not used. Open ASRC core clock when an ASRC device is open. Close ASRC core clock when an ASRC device is close. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-02-15ENGR00174106-3 - EPDC fb: Support EPDC v2.0Danny Nold
- Added new register definitions for EPDCv2.0 - Added support for 64 LUTs - Conditionalized code for EPDC versions 1.0, 2.0, and 2.1 - Support for EPDC auto-waveform selection - Support for collision test mode - Support for PxP bypassing - Support for LUT cancellation - Support for new PxP limitations - Support for collision minimization EPDC feature - Added workaround for collision status bug (can't clear IRQ before reading collision status for LUTs 16-63) Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-02-14ENGR00174299-1: driver part: Add ePxP v2 DMAENGINE driverRobby Cai
add ePxP v2 DMAENGINE driver Signed-off-by: Robby Cai <R63905@freescale.com>
2012-02-14ENGR00174121-1 power: max8903 add support for dcm always high.Zhang Jiejing
add this to support MX6Q_SABRESD board hardware design. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-02-10ENGR00174128-3 Revert "Remove the discharge for VBUS and DP -3"Peter Chen
This reverts commit cc9616316bf044382ec422da5a6d4ed007235a3d. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-02-09ENGR00174037-3 Add HSIC suspend/resume featureTony LIU
head file Signed-off-by: Tony LIU <junjie.liu@freescale.com>
2012-02-08ENGR00172342-2 EDID parse audio data blocksAlan Tull
Add functionality to parse Audio Data Blocks from EDID data to find out what modes of LPCM are suppored by the HDMI sink device. The parsed settings are saved in the hdmi mfd. The HDMI audio driver will check the settings when the audio stream is opened and will then apply appropriate constraints. If we are unable to read from the EDID, then we default to supporting Basic Audio as defined by the HDMI specification (stereo, 16 bit, 32KHz, 44.1KHz, 48KHz PCM). Signed-off-by: Alan Tull <r80115@freescale.com>
2012-02-08ENGR00173864 MX6Q ipu capture: add multi camera switchYuxi Sun
Add IOCTRL command V4L2_CID_MXC_SWITCH_CAM for multi camera switch Signed-off-by: Yuxi Sun <b36102@freescale.com>
2012-02-08ENGR00174038 [mx6 mmc]fix build errTony Lin
fix build error: incompatible pointer type Signed-off-by: Tony Lin <tony.lin@freescale.com>
2012-02-08ENGR00174031 [MX6Q] Support AR6003 SDIO wifi on kernel v3.0Ryan QIAN
- add macros and struct used in new ath6kl. Signed-off-by: Ryan QIAN <b32804@freescale.com>
2012-02-08ENGR00173947-1 mtd/gpmi : add BBT support to gpmi nand driverHuang Shijie
Add a new field to gpmi_nand_platform_data{}. Make the BBT support to board specific. Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-02-07ENGR00173731-1 mxs-dma : rename the dma.h for mxs-dmaHuang Shijie
Move the header to a more common place. The mxs dma engine is not only used in mx23/mx28, but also used in mx50/mx6q. It will also be used in the future chips. rename it to mxs-dma.h Acked-by: Lily Zhang <r58066@freescale.com> Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-02-06ENGR00173288-02 merge "[MX6Q]add SDHC3.0 support on uSDHC controller"Ryan QIAN
ENGR152547-03 [MX6Q]add SDHC3.0 support on uSDHC controller add voltage switch function due to SDHC3.0 spec requirement add tuning function due to SDHC3.0 spec requirement extend some functions to support SDR50 & SDR104 speed mode - adjust the sequence of current_limit and bus_speed_mode - add FSL specific tuning procedure Signed-off-by: Ryan QIAN <b32804@freescale.com>
2012-01-31ENGR00173397 MTD: add NAND_BBT_USE_FLASH macroHuang Shijie
add the new macro to fix a compiling error. Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-01-31mtd: abstract last MTD partition parser argumentDmitry Eremin-Solenikov
Encapsulate last MTD partition parser argument into a separate structure. Currently it holds only 'origin' field for RedBoot parser, but will be extended in future to contain at least device_node for OF devices. Amended commentary to make kerneldoc happy Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2012-01-31mtd: add new API for handling MTD registrationDmitry Eremin-Solenikov
Lots (nearly all) mtd drivers contain nearly the similar code that calls parse_mtd_partitions, provides some platform-default values, if parsing fails, and registers mtd device. This is an aim to provide single implementation of this scenario: mtd_device_parse_register() which will handle all this parsing and defaults. Artem: amended comments Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2012-01-31clk: add helper functions clk_prepare_enable and clk_disable_unprepareRichard Zhao
It's for migrating to generic clk framework API. The helper functions help cases clk_enable/clk_disable is used in non-atomic context. For example, Call clk_enable in probe and clk_disable in remove. Signed-off-by: Richard Zhao <richard.zhao@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Marek Vasut <marek.vasut@gmail.com>
