path: root/include
2010-10-05fib: RCU conversion of fib_lookup()Eric Dumazet
fib_lookup() converted to be called in RCU protected context, no reference taken and released on a contended cache line (fib_clntref) fib_table_lookup() and fib_semantic_match() get an additional parameter. struct fib_info gets an rcu_head field, and is freed after an rcu grace period. Stress test : (Sending 160.000.000 UDP frames on same neighbour, IP route cache disabled, dual E5540 @2.53GHz, 32bit kernel, FIB_HASH) (about same results for FIB_TRIE) Before patch : real 1m31.199s user 0m13.761s sys 23m24.780s After patch: real 1m5.375s user 0m14.997s sys 15m50.115s Before patch Profile : 13044.00 15.4% __ip_route_output_key vmlinux 8438.00 10.0% dst_destroy vmlinux 5983.00 7.1% fib_semantic_match vmlinux 5410.00 6.4% fib_rules_lookup vmlinux 4803.00 5.7% neigh_lookup vmlinux 4420.00 5.2% _raw_spin_lock vmlinux 3883.00 4.6% rt_set_nexthop vmlinux 3261.00 3.9% _raw_read_lock vmlinux 2794.00 3.3% fib_table_lookup vmlinux 2374.00 2.8% neigh_resolve_output vmlinux 2153.00 2.5% dst_alloc vmlinux 1502.00 1.8% _raw_read_lock_bh vmlinux 1484.00 1.8% kmem_cache_alloc vmlinux 1407.00 1.7% eth_header vmlinux 1406.00 1.7% ipv4_dst_destroy vmlinux 1298.00 1.5% __copy_from_user_ll vmlinux 1174.00 1.4% dev_queue_xmit vmlinux 1000.00 1.2% ip_output vmlinux After patch Profile : 13712.00 15.8% dst_destroy vmlinux 8548.00 9.9% __ip_route_output_key vmlinux 7017.00 8.1% neigh_lookup vmlinux 4554.00 5.3% fib_semantic_match vmlinux 4067.00 4.7% _raw_read_lock vmlinux 3491.00 4.0% dst_alloc vmlinux 3186.00 3.7% neigh_resolve_output vmlinux 3103.00 3.6% fib_table_lookup vmlinux 2098.00 2.4% _raw_read_lock_bh vmlinux 2081.00 2.4% kmem_cache_alloc vmlinux 2013.00 2.3% _raw_spin_lock vmlinux 1763.00 2.0% __copy_from_user_ll vmlinux 1763.00 2.0% ip_output vmlinux 1761.00 2.0% ipv4_dst_destroy vmlinux 1631.00 1.9% eth_header vmlinux 1440.00 1.7% _raw_read_unlock_bh vmlinux Reference results, if IP route cache is enabled : real 0m29.718s user 0m10.845s sys 7m37.341s 25213.00 29.5% __ip_route_output_key vmlinux 9011.00 10.5% dst_release vmlinux 4817.00 5.6% ip_push_pending_frames vmlinux 4232.00 5.0% ip_finish_output vmlinux 3940.00 4.6% udp_sendmsg vmlinux 3730.00 4.4% __copy_from_user_ll vmlinux 3716.00 4.4% ip_route_output_flow vmlinux 2451.00 2.9% __xfrm_lookup vmlinux 2221.00 2.6% ip_append_data vmlinux 1718.00 2.0% _raw_spin_lock_bh vmlinux 1655.00 1.9% __alloc_skb vmlinux 1572.00 1.8% sock_wfree vmlinux 1345.00 1.6% kfree vmlinux Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05bonding: add retransmit membership reports tunableFlavio Leitner
Allow sysadmins to configure the number of multicast membership report sent on a link failure event. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net neigh: RCU conversion of neigh hash tableEric Dumazet
David This is the first step for RCU conversion of neigh code. Next patches will convert hash_buckets[] and "struct neighbour" to RCU protected objects. Thanks [PATCH net-next] net neigh: RCU conversion of neigh hash table Instead of storing hash_buckets, hash_mask and hash_rnd in "struct neigh_table", a new structure is defined : struct neigh_hash_table { struct neighbour **hash_buckets; unsigned int hash_mask; __u32 hash_rnd; struct rcu_head rcu; }; And "struct neigh_table" has an RCU protected pointer to such a neigh_hash_table. This means the signature of (*hash)() function changed: We need to add a third parameter with the actual hash_rnd value, since this is not anymore a neigh_table field. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: add a core netdev->rx_dropped counterEric Dumazet
In various situations, a device provides a packet to our stack and we drop it before it enters protocol stack : - softnet backlog full (accounted in /proc/net/softnet_stat) - bad vlan tag (not accounted) - unknown/unregistered protocol (not accounted) We can handle a per-device counter of such dropped frames at core level, and automatically adds it to the device provided stats (rx_dropped), so that standard tools can be used (ifconfig, ip link, cat /proc/net/dev) This is a generalization of commit 8990f468a (net: rx_dropped accounting), thus reverting it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05ipv6: make __ipv6_isatap_ifid staticstephen hemminger
Another exported symbol only used in one file Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05fib: fib_rules_cleanup can be staticstephen hemminger
fib_rules_cleanup_ups is only defined and used in one place. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: relax rtnl_dereference()David S. Miller
rtnl_dereference() is used in contexts where RTNL is held, to fetch an RCU protected pointer. Updates to this pointer are prevented by RTNL, so we dont need smp_read_barrier_depends() and the ACCESS_ONCE() provided in rcu_dereference_check(). rtnl_dereference() is mainly a macro to document the locking invariant. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: dynamic ingress_queue allocationEric Dumazet
ingress being not used very much, and net_device->ingress_queue being quite a big object (128 or 256 bytes), use a dynamic allocation if needed (tc qdisc add dev eth0 ingress ...) dev_ingress_queue(dev) helper should be used only with RTNL taken. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-10-03net: introduce DST_NOCACHE flagEric Dumazet
While doing stress tests with IP route cache disabled, and multi queue devices, I noticed a very high contention on one rwlock used in neighbour code. When many cpus are trying to send frames (possibly using a high performance multiqueue device) to the same neighbour, they fight for the neigh->lock rwlock in order to call neigh_hh_init(), and fight on hh->hh_refcnt (a pair of atomic_inc/atomic_dec_and_test()) But we dont need to call neigh_hh_init() for dst that are used only once. It costs four atomic operations at least, on two contended cache lines, plus the high contention on neigh->lock rwlock. Introduce a new dst flag, DST_NOCACHE, that is set when dst was not inserted in route cache. With the stress test bench, sending 160000000 frames on one neighbour, results are : Before patch: real 2m28.406s user 0m11.781s sys 36m17.964s After patch: real 1m26.532s user 0m12.185s sys 20m3.903s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-10-03ipmr: RCU protection for mfc_cache_arrayEric Dumazet
Use RCU & RTNL protection for mfc_cache_array[] ipmr_cache_find() is called under rcu_read_lock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-01Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2010-10-01neigh: reorder fields in struct neighbourEric Dumazet
On 64bit arches, there are two 32bit holes that we can remove. sizeof(struct neighbour) shrinks from 0xf8 to 0xf0 bytes Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-30ipv4: introduce __ip_dev_find()Eric Dumazet
ip_dev_find(net, addr) finds a device given an IPv4 source address and takes a reference on it. Introduce __ip_dev_find(), taking a third argument, to optionally take the device reference. Callers not asking the reference to be taken should be in an rcu_read_lock() protected section. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29tcp: tcp_enter_quickack_mode can be staticstephen hemminger
Function only used in tcp_input.c Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29arp: remove unnecessary export of arp_broken_opsstephen hemminger
arp_broken_ops is only used in arp.c Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29net: rename netdev rx_queue to ingress_queueEric Dumazet
There is some confusion with rx_queue name after RPS, and net drivers private rx_queue fields. I suggest to rename "struct net_device"->rx_queue to ingress_queue. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29dummy: percpu stats and lockless xmitEric Dumazet
Converts dummy network device driver to : - percpu stats - 64bit stats - lockless xmit (NETIF_F_LLTX) - performance features added (NETIF_F_SG | NETIF_F_FRAGLIST | NETIF_F_TSO | NETIF_F_NO_CSUM | NETIF_F_HIGHDMA) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-28ipv4: Allow configuring subnets as local addressesTom Herbert
This patch allows a host to be configured to respond to any address in a specified range as if it were local, without actually needing to configure the address on an interface. This is done through routing table configuration. For instance, to configure a host to respond to any address in 10.1/16 received on eth0 as a local address we can do: ip rule add from all iif eth0 lookup 200 ip route add local 10.1/16 dev lo proto kernel scope host src 127.0.0.1 table 200 This host is now reachable by any 10.1/16 address (route lookup on input for packets received on eth0 can find the route). On output, the rule will not be matched so that this host can still send packets to 10.1/16 (not sent on loopback). Presumably, external routing can be configured to make sense out of this. To make this work, we needed to modify the logic in finding the interface which is assigned a given source address for output (dev_ip_find). We perform a normal fib_lookup instead of just a lookup on the local table, and in the lookup we ignore the input interface for matching. This patch is useful to implement IP-anycast for subnets of virtual addresses. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27net: Add netif_copy_real_num_queues() for use by virtual net driversBen Hutchings
This sets the active numbers of queues on a net device to match another. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27net: Allow changing number of RX queues after device allocationBen Hutchings
For RPS, we create a kobject for each RX queue based on the number of queues passed to alloc_netdev_mq(). However, drivers generally do not determine the numbers of hardware queues to use until much later, so this usually represents the maximum number the driver may use and not the actual number in use. For TX queues, drivers can update the actual number using netif_set_real_num_tx_queues(). Add a corresponding function for RX queues, netif_set_real_num_rx_queues(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27tunnels: prepare percpu accountingEric Dumazet
Tunnels are going to use percpu for their accounting. They are going to use a new tstats field in net_device. skb_tunnel_rx() is changed to be a wrapper around __skb_tunnel_rx() IPTUNNEL_XMIT() is changed to be a wrapper around __IPTUNNEL_XMIT() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27Phonet: Implement Pipe Controller to support Nokia Slim ModemsKumar Sanghvi
Phonet stack assumes the presence of Pipe Controller, either in Modem or on Application Processing Engine user-space for the Pipe data. Nokia Slim Modems like WG2.5 used in ST-Ericsson U8500 platform do not implement Pipe controller in them. This patch adds Pipe Controller implemenation to Phonet stack to support Pipe data over Phonet stack for Nokia Slim Modems. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27tcp: Fix >4GB writes on 64-bit.David S. Miller
Fixes kernel bugzilla #16603 tcp_sendmsg() truncates iov_len to an 'int' which a 4GB write to write zero bytes, for example. There is also the problem higher up of how verify_iovec() works. It wants to prevent the total length from looking like an error return value. However it does this using 'int', but syscalls return 'long' (and thus signed 64-bit on 64-bit machines). So it could trigger false-positives on 64-bit as written. So fix it to use 'long'. Reported-by: Olaf Bonorden <bono@onlinehome.de> Reported-by: Daniel Büse <dbuese@gmx.de> Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27tproxy: check for transparent flag in ip_route_newportsUlrich Weber
as done in ip_route_connect() Signed-off-by: Ulrich Weber <uweber@astaro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27mac80211: move packet flags into packetJohannes Berg
commit 8c0c709eea5cbab97fb464cd68b06f24acc58ee1 Author: Johannes Berg <johannes@sipsolutions.net> Date: Wed Nov 25 17:46:15 2009 +0100 mac80211: move cmntr flag out of rx flags moved the CMNTR flag into the skb RX flags for some aggregation cleanups, but this was wrong since the optimisation this flag tried to make requires that it is kept across the processing of multiple interfaces -- which isn't true for flags in the skb. The patch not only broke the optimisation, it also introduced a bug: under some (common!) circumstances the flag will be set on an already freed skb! However, investigating this in more detail, I found that most of the flags that we set should be per packet, _except_ for this one, due to a-MPDU processing. Additionally, the flags used for processing (currently just this one) need to be reset before processing a new packet. Since we haven't actually seen bugs reported as a result of the wrong flags handling (which is not too surprising -- the only real bug case I can come up with is an a-MSDU contained in an a-MPDU), I'll make a different fix for rc. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-27mac80211/ath9k: Support AMPDU with multiple VIFs.Ben Greear
The old ieee80211_find_sta_by_hw method didn't properly find VIFS when there was more than one per AP. This caused AMPDU logic in ath9k to get the wrong VIF when trying to account for transmitted SKBs. This patch changes ieee80211_find_sta_by_hw to take a localaddr argument to distinguish between VIFs with the same AP but different local addresses. The method name is changed to ieee80211_find_sta_by_ifaddr. Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/qlcnic/qlcnic_init.c net/ipv4/ip_output.c
2010-09-26ipv6: add a missing unregister_pernet_subsys callNeil Horman
Clean up a missing exit path in the ipv6 module init routines. In addrconf_init we call ipv6_addr_label_init which calls register_pernet_subsys for the ipv6_addr_label_ops structure. But if module loading fails, or if the ipv6 module is removed, there is no corresponding unregister_pernet_subsys call, which leaves a now-bogus address on the pernet_list, leading to oopses in subsequent registrations. This patch cleans up both the failed load path and the unload path. Tested by myself with good results. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> include/net/addrconf.h | 1 + net/ipv6/addrconf.c | 11 ++++++++--- net/ipv6/addrlabel.c | 5 +++++ 3 files changed, 14 insertions(+), 3 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26net: loopback driver cleanupEric Dumazet
loopback driver uses dev->ml_priv to store its percpu stats pointer. It uses ugly casts "(void __percpu __force *)" to shut up sparse complains. Define an union to better document we use ml_priv in loopback driver and define a lstats field with appropriate types. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26net: update SOCK_MIN_RCVBUFEric Dumazet
SOCK_MIN_RCVBUF current value is 256 bytes It doesnt permit to receive the smallest possible frame, considering socket sk_rmem_alloc/sk_rcvbuf account skb truesizes. On 64bit arches, sizeof(struct sk_buff) is 240 bytes. Add the typical 64 bytes of headroom, and we go over the limit. With old kernels and 32bit arches, we were under the limit, if netdriver was doing copybreak. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26net: reset skb queue mapping when rx'ing over tunnelTom Herbert
Reset queue mapping when an skb is reentering the stack via a tunnel. On second pass, the queue mapping from the original device is no longer valid. Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26net: skb_frag_t can be smaller on small archesEric Dumazet
On 32bit arches, if PAGE_SIZE is smaller than 65536, we can use 16bit offset and size fields. This patch saves 72 bytes per skb on i386, or 128 bytes after rounding. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-24stmmac: review the wake-up supportGiuseppe Cavallaro
If the PM support is available this is passed through the platform instead to be hard-coded in the core files. WoL on Magic Frame can be enabled by using the ethtool support. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-24mac80211: clear txflags for ps-filtered framesChristian Lamparter
This patch fixes stale mac80211_tx_control_flags for filtered / retried frames. Because ieee80211_handle_filtered_frame feeds skbs back into the tx path, they have to be stripped of some tx flags so they won't confuse the stack, driver or device. Cc: <stable@kernel.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-22net: Move "struct net" declaration inside the __KERNEL__ macro guardOllie Wild
This patch reduces namespace pollution by moving the "struct net" declaration out of the userspace-facing portion of linux/netlink.h. It has no impact on the kernel. (This came up because we have several C++ applications which use "net" as a namespace name.) Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21Merge branch 'for-davem' of ↵David S. Miller
2010-09-21ipv6: addrconf.h cleanupsEric Dumazet
- Use rcu_dereference_rtnl() in __in6_dev_get - kerneldoc for __in6_dev_get() and in6_dev_get() - Use inline functions instead of macros Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21net: constify some ppp/pptp structsEric Dumazet
2010-09-21Merge branch 'dccp' of git://eden-feed.erg.abdn.ac.uk/net-next-2.6David S. Miller
2010-09-21ethtool: Add Ethernet MAC-level filtering/steeringBen Hutchings
2010-09-21ethtool: Define RX n-tuple action to clear a ruleBen Hutchings
2010-09-21Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: arch/arm/mach-omap2/board-omap3pandora.c drivers/net/wireless/ath/ath5k/base.c
2010-09-21wl1271: make ref_clock configurable by boardOhad Ben-Cohen
The wl1271 device is using a reference clock that may change between board to board. Make the ref_clock parameter configurable by board settings instead of having a hard coded value in the sources. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-21wl12xx: add platform data passing supportOhad Ben-Cohen
Add a simple mechanism to pass platform data to the SDIO instances of wl12xx. This way there is no confusion over who owns the 'embedded data', typechecking is preserved, and no possibility for the wrong driver to pick up the data. Originally proposed by Russell King. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-21wl12xx: make wl12xx.h common to both spi and sdioOhad Ben-Cohen
Move wl12xx.h outside of the spi-specific location, so it can be shared with both spi and sdio solutions. Update all users of spi/wl12xx.h accordingly Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-21dccp: Replace magic CCID-specific numbers by symbolic constantsGerrit Renker
The constants DCCPO_{MIN,MAX}_CCID_SPECIFIC are nowhere used in the code, but instead for the CCID-specific options numbers are used. This patch unifies the use of CCID-specific option numbers, by adding symbolic names reflecting the definitions in RFC 4340, 10.3. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2010-09-20xfrm: Allow different selector family in temporary stateThomas Egerer
The family parameter xfrm_state_find is used to find a state matching a certain policy. This value is set to the template's family (encap_family) right before xfrm_state_find is called. The family parameter is however also used to construct a temporary state in xfrm_state_find itself which is wrong for inter-family scenarios because it produces a selector for the wrong family. Since this selector is included in the xfrm_user_acquire structure, user space programs misinterpret IPv6 addresses as IPv4 and vice versa. This patch splits up the original init_tempsel function into a part that initializes the selector respectively the props and id of the temporary state, to allow for differing ip address families whithin the state. Signed-off-by: Thomas Egerer <thomas.egerer@secunet.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
