Add proper device tree support for SEMA4 driver. Also rename the
source and header file to the mainline SoC name "vf610_".
Extend the MSCM driver with CPU2CPU interrupt support. Those
interrupts are mainly used for the external MCC kernel module
which uses the functionality to pass messages to the secondary
Cortex-M4 core.
In Timesys version (at least up to 1.06), the interrupt handling
was directly done in the MCC kernel module. However, because newer
kernels use virtual interrupt numbers, it is not possible to use
hardcoded hardware IRQ number by default. By requesting the
interupts within the MSCM driver and exporting some helper
functions.
drivers/input/touchscreen/Makefile
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
(cherry picked from commit cb82730b70f31af3b43041ac4e47de69c18016c9)
Linux 3.18
This driver controls the hardware sema4 on the Vybrid Tower. The MCC kernel
module uses this driver to control access to shared RAM.
Signed-off-by: Anthony Felice <tony.felice@timesys.com>
The 2-bit gates found i.MX and Vybrid SoC support different clock
configuration:
0b00: clk disabled
0b01: clk enabled in RUN mode but disabled in WAIT and STOP mode
0b10: clk enabled in RUN, WAIT and STOP mode (only Vybrid)
0b11: clk enabled in RUN and WAIT mode
For some clocks, we might want to configure different behaviour,
e.g. a memory clock should be on even in STOP mode. Add a new
function imx_clk_gate2_cgr which allow to configure specific
gate values through the cgr_val parameter.
A typo "header=y" was introduced by commit 7071cf7fc435 ("uapi: add
missing network related headers to kbuild").
Cc: Stephen Hemminger <stephen@networkplumber.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO driver fixes from Greg KH:
"Here are some staging and IIO driver fixes for 3.18-rc7 that resolve a
number of reported issues, and a new device id for a staging wireless
driver.
All of these have been in linux-next"
* tag 'staging-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: r8188eu: Add new device ID for DLink GO-USB-N150
staging: r8188eu: Fix scheduling while atomic error introduced in commit fadbe0cd
iio: accel: bmc150: set low default thresholds
iio: accel: bmc150: Fix iio_event_spec direction
iio: accel: bmc150: Send x, y and z motion separately
iio: accel: bmc150: Error handling when mode set fails
iio: gyro: bmg160: Fix iio_event_spec direction
iio: gyro: bmg160: Send x, y and z motion separately
iio: gyro: bmg160: Don't let interrupt mode to be open drain
iio: gyro: bmg160: Error handling when mode set fails
iio: adc: men_z188_adc: Add terminating entry for men_z188_ids
iio: accel: kxcjk-1013: Fix kxcjk10013_set_range
iio: Fix IIO_EVENT_CODE_EXTRACT_DIR bit mask
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"No excitement, here are only minor fixes: an endian fix for the new
DSD format we added in 3.18, a fix for HP mute LED, and a fix for
Native Instrument quirk"
* tag 'sound-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: pcm: Add big-endian DSD sample formats and fix XMOS DSD sample format
ALSA: hda - One more HP machine needs to change mute led quirk
ALSA: usb-audio: Use snd_usb_ctl_msg() for Native Instruments quirk
Pull networking fixes from David Miller:
"Several small fixes here:
1) Don't crash in tg3 driver when the number of tx queues has been
configured to be different from the number of rx queues. From
Thadeu Lima de Souza Cascardo.
2) VLAN filter not disabled properly in promisc mode in ixgbe driver,
from Vlad Yasevich.
3) Fix OOPS on dellink op in VTI tunnel driver, from Xin Long.
4) IPV6 GRE driver WCCP code checks skb->protocol for ETH_P_IP
instead of ETH_P_IPV6, whoops. From Yuri Chislov.
5) Socket matching in ping driver is buggy when packet AF does not
match socket's AF. Fix from Jane Zhou.
6) Fix checksum calculation errors in VXLAN due to where the
udp_tunnel6_xmit_skb() helper gets it's saddr/daddr from. From
Alexander Duyck.
7) Fix 5G detection problem in rtlwifi driver, from Larry Finger.
8) Fix NULL deref in tcp_v{4,6}_send_reset, from Eric Dumazet.
9) Various missing netlink attribute verifications in bridging code,
from Thomas Graf.
10) tcp_recvmsg() unconditionally calls ipv4 ip_recv_error even for
ipv6 sockets, whoops. Fix from Willem de Bruijn"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (29 commits)
net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socks
bridge: Sanitize IFLA_EXT_MASK for AF_BRIDGE:RTM_GETLINK
bridge: Add missing policy entry for IFLA_BRPORT_FAST_LEAVE
net: Check for presence of IFLA_AF_SPEC
net: Validate IFLA_BRIDGE_MODE attribute length
bridge: Validate IFLA_BRIDGE_FLAGS attribute length
stmmac: platform: fix default values of the filter bins setting
net/mlx4_core: Limit count field to 24 bits in qp_alloc_res
net: dsa: bcm_sf2: reset switch prior to initialization
net: dsa: bcm_sf2: fix unmapping registers in case of errors
tg3: fix ring init when there are more TX than RX channels
tcp: fix possible NULL dereference in tcp_vX_send_reset()
rtlwifi: Change order in device startup
rtlwifi: rtl8821ae: Fix 5G detection problem
Revert "netfilter: conntrack: fix race in __nf_conntrack_confirm against get_next_corpse"
vxlan: Fix boolean flip in VXLAN_F_UDP_ZERO_CSUM6_[TX|RX]
ip6_udp_tunnel: Fix checksum calculation
net-timestamp: Fix a documentation typo
net/ping: handle protocol mismatching scenario
af_packet: fix sparse warning
TCP timestamping introduced MSG_ERRQUEUE handling for TCP sockets.
If the socket is of family AF_INET6, call ipv6_recv_error instead
of ip_recv_error.
This change is more complex than a single branch due to the loadable
ipv6 module. It reuses a pre-existing indirect function call from
ping. The ping code is safe to call, because it is part of the core
ipv6 module and always present when AF_INET6 sockets are active.
Fixes: 4ed2d765 (net-timestamp: TCP timestamping)
Signed-off-by: Willem de Bruijn <willemb@google.com>
It may also be worthwhile to add WARN_ON_ONCE(sk->family == AF_INET6)
to ip_recv_error.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
Third set of IIO fixes for the 3.18 cycle.
Most of these are fairly standard little fixes, a bmc150 and bmg160 patch
is to make an ABI change to indicated a specific axis in an event rather
than the generic option in the original drivers. As both of these drivers
are new in this cycle it would be ideal to push this minor change through
even though it isn't strictly a fix. A couple of other 'fixes' change
defaults for some settings on these new drivers to more intuitive calues.
Looks like some useful feedback has been coming in for this driver
since it was applied.
* IIO_EVENT_CODE_EXTRACT_DIR bit mask was wrong and has been for a while
0xCF clearly doesn't give a contiguous bitmask.
* kxcjk-1013 range setting was failing to mask out the previous value
in the register and hence was 'enable only'.
* men_z188 device id table wasn't null terminated.
* bmg160 and bmc150 both failed to correctly handling an error in mode
setting.
* bmg160 and bmc150 both had a bug in setting the event direction in the
event spec (leads to an attribute name being incorrect)
* bmg160 defaulted to an open drain output for the interrupt - as a default
this obviously only works with some interrupt chips - hence change the
default to push-pull (note this is a new driver so we aren't going to
cause any regressions with this change).
* bmc150 had an unintuitive default for the rate of change (motion detector)
so change it to 0 (new driver so change of default won't cause any
regressions).
This reverts commit 85c8555ff0 ("KVM: check for !is_zero_pfn() in
kvm_is_mmio_pfn()") and renames the function to kvm_is_reserved_pfn.
The problem being addressed by the patch above was that some ARM code
based the memory mapping attributes of a pfn on the return value of
kvm_is_mmio_pfn(), whose name indeed suggests that such pfns should
be mapped as device memory.
However, kvm_is_mmio_pfn() doesn't do quite what it says on the tin,
and the existing non-ARM users were already using it in a way which
suggests that its name should probably have been 'kvm_is_reserved_pfn'
from the beginning, e.g., whether or not to call get_page/put_page on
it etc. This means that returning false for the zero page is a mistake
and the patch above should be reverted.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fixes from Ben Herrenschmidt:
"This series fix a nasty issue with radeon adapters on powerpc servers,
it's all CC'ed stable and has the relevant maintainers ack's/reviews.
Basically, some (radeon) adapters have issues with MSI addresses above
1T (only support 40-bits). We had powerpc specific quirk but it only
listed a specific revision of an adapter that we shipped with our
machines and didn't properly handle the audio function which some
distros enable nowadays.
So we made the quirk generic and fixed both the graphic and audio
drivers properly to use it.
Without that, ppc64 server machines will crash at boot with a radeon
adapter.
Note: This has been brewing for a while, it just needed a last respin
which got delayed due to us moving ozlabs to a new location in town
and other such things taking priority"
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/pci: Remove unused force_32bit_msi quirk
powerpc/pseries: Honor the generic "no_64bit_msi" flag
powerpc/powernv: Honor the generic "no_64bit_msi" flag
sound/radeon: Move 64-bit MSI quirk from arch to driver
gpu/radeon: Set flag to indicate broken 64-bit MSI
PCI/MSI: Add device flag indicating that 64-bit MSIs don't work
ALSA: hda - Limit 40bit DMA for AMD HDMI controllers
https://git.linaro.org/people/mike.turquette/linux
Pull clock fixes from Mike Turquette:
"The fixes for the clock framework are all regressions in drivers, plus
a single fix in one of the basic clock templates. No fixes to the
core this time around.
As with most clock driver fixes these run the gamut from fixing a
build warning to fixing wrecked memory timings, with a little USB
tossed in for fun"
* tag 'clk-fixes-for-linus' of https://git.linaro.org/people/mike.turquette/linux:
clk: pxa: fix pxa27x CCCR bit usage
clk-divider: Fix READ_ONLY when divider > 1
clk: qcom: Fix duplicate rbcpr clock name
clk: at91: usb: fix at91sam9x5 recalc, round and set rate
clk: at91: usb: fix at91rm9200 round and set rate
This can be set by quirks/drivers to be used by the architecture code
that assigns the MSI addresses.
We additionally add verification in the core MSI code that the values
assigned by the architecture do satisfy the limitation in order to fail
gracefully if they don't (ie. the arch hasn't been updated to deal with
that quirk yet).
CC: <stable@vger.kernel.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu fix from Tejun Heo:
"This contains one patch to fix a race condition which can lead to
percpu_ref using a percpu pointer which is corrupted with a set DEAD
bit. The bug was introduced while separating out the ATOMIC mode flag
from the DEAD flag. The fix is pretty straight forward.
I just committed the patch to the percpu tree but am sending out the
pull request early as I'll be on vacation for a week. The patch
should be fairly safe and while the latency will be higher I'll be
checking emails"
* 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu-ref: fix DEAD flag contamination of percpu pointer
While decoupling ATOMIC and DEAD flags, f47ad4578461 ("percpu_ref:
decouple switching to percpu mode and reinit") updated
__ref_is_percpu() so that it only tests ATOMIC flag to determine
whether the ref is in percpu mode or not; however, while DEAD implies
ATOMIC, the two flags are set separately during percpu_ref_kill() and
if __ref_is_percpu() races percpu_ref_kill(), it may see DEAD w/o
ATOMIC. Because __ref_is_percpu() returns @ref->percpu_count_ptr
value verbatim as the percpu pointer after testing ATOMIC, the pointer
may now be contaminated with the DEAD flag.
This can be fixed by clearing the flag bits before returning the
pointer which was the fix proposed by Shaohua; however, as DEAD
implies ATOMIC, we can just test for both flags at once and avoid the
explicit masking.
Update __ref_is_percpu() so that it tests that both ATOMIC and DEAD
are clear before returning @ref->percpu_count_ptr as the percpu
pointer.
Reported-and-Reviewed-by: Shaohua Li <shli@kernel.org>
Link: http://lkml.kernel.org/r/995deb699f5b873c45d667df4add3b06f73c2c25.1416638887.git.shli@kernel.org
Fixes: f47ad4578461 ("percpu_ref: decouple switching to percpu mode and reinit")
1) Fix BUG when decrypting empty packets in mac80211, from Ronald Wahl.
2) nf_nat_range is not fully initialized and this is copied back to
userspace, from Daniel Borkmann.
3) Fix read past end of b uffer in netfilter ipset, also from Dan
Carpenter.
4) Signed integer overflow in ipv4 address mask creation helper
inet_make_mask(), from Vincent BENAYOUN.
5) VXLAN, be2net, mlx4_en, and qlcnic need ->ndo_gso_check() methods to
properly describe the device's capabilities, from Joe Stringer.
6) Fix memory leaks and checksum miscalculations in openvswitch, from
Pravin B SHelar and Jesse Gross.
7) FIB rules passes back ambiguous error code for unreachable routes,
making behavior confusing for userspace. Fix from Panu Matilainen.
8) ieee802154fake_probe() doesn't release resources properly on error,
from Alexey Khoroshilov.
9) Fix skb_over_panic in add_grhead(), from Daniel Borkmann.
10) Fix access of stale slave pointers in bonding code, from Nikolay
Aleksandrov.
11) Fix stack info leak in PPP pptp code, from Mathias Krause.
12) Cure locking bug in IPX stack, from Jiri Bohac.
13) Revert SKB fclone memory freeing optimization that is racey and can
allow accesses to freed up memory, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (71 commits)
tcp: Restore RFC5961-compliant behavior for SYN packets
net: Revert "net: avoid one atomic operation in skb_clone()"
virtio-net: validate features during probe
cxgb4 : Fix DCB priority groups being returned in wrong order
ipx: fix locking regression in ipx_sendmsg and ipx_recvmsg
openvswitch: Don't validate IPv6 label masks.
pptp: fix stack info leak in pptp_getname()
brcmfmac: don't include linux/unaligned/access_ok.h
cxgb4i : Don't block unload/cxgb4 unload when remote closes TCP connection
ipv6: delete protocol and unregister rtnetlink when cleanup
net/mlx4_en: Add VXLAN ndo calls to the PF net device ops too
bonding: fix curr_active_slave/carrier with loadbalance arp monitoring
mac80211: minstrel_ht: fix a crash in rate sorting
vxlan: Inline vxlan_gso_check().
can: m_can: update to support CAN FD features
can: m_can: fix incorrect error messages
can: m_can: add missing delay after setting CCCR_INIT bit
can: m_can: fix not set can_dlc for remote frame
can: m_can: fix possible sleep in napi poll
can: m_can: add missing message RAM initialization
"This batch ended up as a relatively high volume due to pending ASoC
fixes. But most of fixes there are trivial and/or device- specific
fixes and quirks, so safe to apply. The only (ASoC) core fixes are
the DPCM race fix and the machine-driver matching fix for
componentization"
* tag 'sound-3.18-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - fix the mic mute led problem for Latitude E5550
ALSA: hda - move DELL_WMI_MIC_MUTE_LED to the tail in the quirk chain
ASoC: wm_adsp: Avoid attempt to free buffers that might still be in use
ALSA: usb-audio: Set the Control Selector to SU_SELECTOR_CONTROL for UAC2
ALSA: usb-audio: Add ctrl message delay quirk for Marantz/Denon devices
ASoC: sgtl5000: Fix SMALL_POP bit definition
ASoC: cs42l51: re-hook of_match_table pointer
ASoC: rt5670: change dapm routes of PLL connection
ASoC: rt5670: correct the incorrect default values
ASoC: samsung: Add MODULE_DEVICE_TABLE for Snow
ASoC: max98090: Correct pclk divisor settings
ASoC: dpcm: Fix race between FE/BE updates and trigger
ASoC: Fix snd_soc_find_dai() matching component by name
ASoC: rsnd: remove unsupported PAUSE flag
ASoC: fsi: remove unsupported PAUSE flag
ASoC: rt5645: Mark RT5645_TDM_CTRL_3 as readable
ASoC: rockchip-i2s: fix infinite loop in rockchip_snd_rxctrl
ASoC: es8328-i2c: Fix i2c_device_id name field in es8328_id
ASoC: fsl_asrc: Add reg_defaults for regmap to fix kernel dump
Pull scheduler fixes from Ingo Molnar:
"Misc fixes: two NUMA fixes, two cputime fixes and an RCU/lockdep fix"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/cputime: Fix clock_nanosleep()/clock_gettime() inconsistency
sched/cputime: Fix cpu_timer_sample_group() double accounting
sched/numa: Avoid selecting oneself as swap target
sched/numa: Fix out of bounds read in sched_init_numa()
sched: Remove lockdep check in sched_move_task()
Pull core fix from Ingo Molnar:
"Fix GENMASK macro shift overflow"
Nobody seems to currently use GENMASK() to fill every single last bit
(which is what overflows) in-tree, and gcc would warn about it, so we
have that going for us. But apparently there are pending changes that
want this.
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
bitops: Fix shift overflow in GENMASK macros
This patch fixes XMOS DSD sample format to DSD_U32_BE and also adds
DSD_U16_BE and DSD_U32_BE sample formats.
Signed-off-by: Jussi Laako <jussi@sonarnerd.net>
Acked-by: Jurgen Kramer <gtmkramer@xs4all.nl>
git://gitorious.org/linux-can/linux-can
Marc Kleine-Budde says:
pull-request: can 2014-11-18
this is a pull request of 17 patches for net/master for the v3.18 release
cycle.
The last patch of this pull request ("can: m_can: update to support CAN FD
features") adds, as the description says, a new feature to the m_can driver. As
the m_can driver has been added in v3.18 there is no risk of causing a
regression. Give me a note if this is not okay and I'll create a new pull
request without it.
There is a patch for the CAN infrastructure by Thomas Körper which fixes
calling kfree_skb() from interrupt context. Roman Fietze fixes a typo also in
the infrastructure. A patch by Dong Aisheng adds a generic helper function to
tell if a skb is normal CAN or CAN-FD frame. Alexey Khoroshilov of the Linux
Driver Verification project fixes a memory leak in the esd_usb2 driver. Two
patches by Sudip Mukherjee remove unused variables and fixe the signess of a
variable. Three patches by me add the missing .ndo_change_mtu callback to the
xilinx_can, rcar_can and gs_usb driver.
The remaining patches improve the m_can driver: David Cohen adds the missing
CONFIG_HAS_IOMEM dependency. Dong Aisheng provides 6 bugfix patches (most
important: missing RAM init, sleep in NAPI poll, dlc in RTR). While the last of
his patches adds CAN FD support to the driver.
arch/arm/boot/dts/vf610-twr.dts
include/dt-bindings/clock/vf610-clock.h
This patch adds DCU and TCON clock support for Vybrid VF610 platform.
Signed-off-by: Alison Wang <b18965@freescale.com>
[rebased to 3.18]
Signed-off-by: Stefan Agner <stefan@agner.ch>
This patch adds support for clock gating of
the SNVS peripheral.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
The ARM clock is a virtual clock feeding the ARM partition of
the SoC. It controls multiple other clocks to ensure the right
sequencing when cpufreq changes the CPU clock rate.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This is the bypass clock used to feed the ARM partition
while we reprogram PLL1 to another rate.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Add imx6sx iomux-gpr register field define in "imx6q-iomuxc-gpr.h" header
file, which is not fully define all iomux-gpr registers and fields, only
align with freescale internal tree related GPR macro define.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Suggested-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Joe Stringer <joestringer@nicira.com>
The CAN device drivers can use can_is_canfd_skb() to check if the frame to send
is on CAN FD mode or normal CAN mode.
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Dong Aisheng <b29396@freescale.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Commit 79c6ab509558 (clk: divider: add CLK_DIVIDER_READ_ONLY flag) in
v3.16 introduced the CLK_DIVIDER_READ_ONLY flag which caused the
recalc_rate() and round_rate() clock callbacks to be omitted.
However using this flag has the unfortunate side effect of causing the
clock recalculation code when a clock rate change is attempted to always
treat it as a pass-through clock, i.e. with a fixed divide of 1, which
may not be the case. Child clock rates are then recalculated using the
wrong parent rate.
Therefore instead of dropping the recalc_rate() and round_rate()
callbacks, alter clk_divider_bestdiv() to always report the current
divider as the best divider so that it is never altered.
For me the read only clock was the system clock, which divided the PLL
rate by 2, from which both the UART and the SPI clocks were divided.
Initial setting of the UART rate set it correctly, but when the SPI
clock was set, the other child clocks were miscalculated. The UART clock
was recalculated using the PLL rate as the parent rate, resulting in a
UART new_rate of double what it should be, and a UART which spewed forth
garbage when the rate changes were propagated.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Max Schwarz <max.schwarz@online.de>
Cc: <stable@vger.kernel.org> # v3.16+
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
There is a duplication in a clock name for apq8084 platform that causes
the following warning: "RBCPR_CLK_SRC" redefined
Resolve this by adding a MMSS_ prefix to this clock and making its name
coherent with msm8974 platform.
Fixes: 2b46cd23a5a2 ("clk: qcom: Add APQ8084 Multimedia Clock Controller (MMCC) support")
Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
'asoc/fix/dpcm', 'asoc/fix/es8328', 'asoc/fix/fsl-asrc', 'asoc/fix/max98090', 'asoc/fix/rcar', 'asoc/fix/rockchip' and 'asoc/fix/rt5645' into asoc-linus
Pull ARM SoC fixes from Olof Johansson:
"Another small set of fixes:
- some DT compatible typo fixes
- irq setup fix dealing with irq storms on orion
- i2c quirk generalization for mvebu
- a handful of smaller fixes for OMAP
- a couple of added file patterns for OMAP entries in MAINTAINERS"
* tag 'armsoc-for-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: at91/dt: Fix sama5d3x typos
pinctrl: dra: dt-bindings: Fix output pull up/down
MAINTAINERS: Update entry for omap related .dts files to cover new SoCs
MAINTAINERS: add more files under OMAP SUPPORT
ARM: dts: AM437x-SK-EVM: Fix DCDC3 voltage
ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltage
ARM: dts: AM43x-EPOS-EVM: Fix DCDC3 voltage
ARM: dts: am335x-evm: Fix 5th NAND partition's name
ARM: orion: Fix for certain sequence of request_irq can cause irq storm
ARM: mvebu: armada xp: Generalize use of i2c quirk
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Merge "omap fixes against v3.18-rc4" from Tony Lindgren:
Few omap fixes for hangs and wrong pinctrl defines, and update
MAINTAINERS file to avoid missing PMIC and SoC related patches:
- Fix random hangs on am437x because of incorrect default
value for the DDR regulator
- Fix wrong partition name for NAND on am335x-evm
- Fix wrong pinctrl defines for dra7xx
- Update maintainers entries for PMICs and SoCs
* tag 'omap-fixes-against-v3.18-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
Pablo Neira Ayuso says:
Netfilter/IPVS fixes for net
The following patchset contains Netfilter updates for your net tree,
they are:
1) Fix missing initialization of the range structure (allocated in the
stack) in nft_masq_{ipv4, ipv6}_eval, from Daniel Borkmann.
2) Make sure the data we receive from userspace contains the req_version
structure, otherwise return an error incomplete on truncated input.
From Dan Carpenter.
3) Fix handling og skb->sk which may cause incorrect handling
of connections from a local process. Via Simon Horman, patch from
Calvin Owens.
4) Fix wrong netns in nft_compat when setting target and match params
structure.
5) Relax chain type validation in nft_compat that was recently included,
this broke the matches that need to be run from the route chain type.
Now iptables-test.py automated regression tests report success again
and we avoid the only possible problematic case, which is the use of
nat targets out of nat chain type.
6) Use match->table to validate the tablename, instead of the match->name.
Again patch for nft_compat.
7) Restore the synchronous release of objects from the commit and abort
path in nf_tables. This is causing two major problems: splats when using
nft_compat, given that matches and targets may sleep and call_rcu is
invoked from softirq context. Moreover Patrick reported possible event
notification reordering when rules refer to anonymous sets.
8) Fix race condition in between packets that are being confirmed by
conntrack and the ctnetlink flush operation. This happens since the
removal of the central spinlock. Thanks to Jesper D. Brouer to looking
into this.
While looking over the cpu-timer code I found that we appear to add
the delta for the calling task twice, through:
thread_group_cputimer()
thread_group_cputime()
times->sum_exec_runtime += task_sched_runtime();
*sample = cputime.sum_exec_runtime + task_delta_exec();
Which would make the sample run ahead, making the sleep short.
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20141112113737.GI10476@twins.programming.kicks-ass.net
On some 32 bits architectures, including x86, GENMASK(31, 0) returns 0
instead of the expected ~0UL.
This is the same on some 64 bits architectures with GENMASK_ULL(63, 0).
This is due to an overflow in the shift operand, 1 << 32 for GENMASK,
1 << 64 for GENMASK_ULL.
Reported-by: Eric Paire <eric.paire@st.com>
Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
Cc: <stable@vger.kernel.org> # v3.13+
Cc: linux@rasmusvillemoes.dk
Cc: gong.chen@linux.intel.com
Cc: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Fixes: 10ef6b0dffe4 ("bitops: Introduce a more generic BITMASK macro")
Link: http://lkml.kernel.org/r/1415267659-10563-1-git-send-email-maxime.coquelin@st.com
Pull power supply updates from Sebastian Reichel:
"Power supply and reset changes for the v3.18-rc:
- misc. charger-manager fixes
- year 2038 fix in ab8500_fg
- fix error handling of bq2415x_charger"
* tag 'for-v3.18-rc' of git://git.infradead.org/battery-2.6:
power: charger-manager: Fix accessing invalidated power supply after charger unbind
power: charger-manager: Fix accessing invalidated power supply after fuel gauge unbind
power: charger-manager: Avoid recursive thermal get_temp call
power_supply: Add no_thermal property to prevent recursive get_temp calls
power: bq2415x_charger: Fix memory leak on DTS parsing error
power: bq2415x_charger: Properly handle ENODEV from power_supply_get_by_phandle
power: ab8500_fg.c: use 64-bit time types
Pull NFS client bugfixes from Trond Myklebust:
"Highlights include:
- stable patches to fix NFSv4.x delegation reclaim error paths
- fix a bug whereby we were advertising NFSv4.1 but using NFSv4.2
features
- fix a use-after-free problem with pNFS block layouts
- fix a memory leak in the pNFS files O_DIRECT code
- replace an intrusive and Oops-prone performance fix in the NFSv4
atomic open code with a safer one-line version and revert the two
original patches"
* tag 'nfs-for-3.18-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
sunrpc: fix sleeping under rcu_read_lock in gss_stringify_acceptor
NFS: Don't try to reclaim delegation open state if recovery failed
NFSv4: Ensure that we call FREE_STATEID when NFSv4.x stateids are revoked
NFSv4: Fix races between nfs_remove_bad_delegation() and delegation return
NFSv4.1: nfs41_clear_delegation_stateid shouldn't trust NFS_DELEGATED_STATE
NFSv4: Ensure that we remove NFSv4.0 delegations when state has expired
NFS: SEEK is an NFS v4.2 feature
nfs: Fix use of uninitialized variable in nfs_getattr()
nfs: Remove bogus assignment
nfs: remove spurious WARN_ON_ONCE in write path
pnfs/blocklayout: serialize GETDEVICEINFO calls
nfs: fix pnfs direct write memory leak
Revert "NFS: nfs4_do_open should add negative results to the dcache."
Revert "NFS: remove BUG possibility in nfs4_open_and_get_state"
NFSv4: Ensure nfs_atomic_open set the dentry verifier on ENOENT
The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask
in order to retrieve it, that is 0x7F, not 0xCF as it is now.
Fixes: ade7ef7ba (staging:iio: Differential channel handling)
Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Most NICs that report NETIF_F_GSO_UDP_TUNNEL support VXLAN, and not
other UDP-based encapsulation protocols where the format and size of the
header differs. This patch implements a generic ndo_gso_check() for
VXLAN which will only advertise GSO support when the skb looks like it
contains VXLAN (or no UDP tunnelling at all).
Implementation shamelessly stolen from Tom Herbert:
http://thread.gmane.org/gmane.linux.network/332428/focus=333111
There could be a signed overflow in the following code.
The expression, (32-logmask) is comprised between 0 and 31 included.
It may be equal to 31.
In such a case the left shift will produce a signed integer overflow.
According to the C99 Standard, this is an undefined behavior.
A simple fix is to replace the signed int 1 with the unsigned int 1U.
Signed-off-by: Vincent BENAYOUN <vincent.benayoun@trust-in-soft.com>
Pull ACPI and power management fixes from Rafael Wysocki:
"These are three regression fixes, two recent (generic power domains,
suspend-to-idle) and one older (cpufreq), an ACPI blacklist entry for
one more machine having problems with Windows 8 compatibility, a minor
cpufreq driver fix (cpufreq-dt) and a fixup for new callback
definitions (generic power domains).
Specifics:
- Fix a crash in the suspend-to-idle code path introduced by a recent
commit that forgot to check a pointer against NULL before
dereferencing it (Dmitry Eremin-Solenikov).
- Fix a boot crash on Exynos5 introduced by a recent commit making
that platform use generic Device Tree bindings for power domains
which exposed a weakness in the generic power domains framework
leading to that crash (Ulf Hansson).
- Fix a crash during system resume on systems where cpufreq depends
on Operation Performance Points (OPP) for functionality, but
CONFIG_OPP is not set. This leads the cpufreq driver registration
to fail, but the resume code attempts to restore the pre-suspend
cpufreq configuration (which does not exist) nevertheless and
crashes. From Geert Uytterhoeven.
- Add a new ACPI blacklist entry for Dell Vostro 3546 that has
problems if it is reported as Windows 8 compatible to the BIOS
(Adam Lee).
- Fix swapped arguments in an error message in the cpufreq-dt driver
(Abhilash Kesavan).
- Fix up the prototypes of new callbacks in struct generic_pm_domain
to make them more useful. Users of those callbacks will be added
in 3.19 and it's better for them to be based on the correct struct
definition in mainline from the start. From Ulf Hansson and Kevin
Hilman"
* tag 'pm+acpi-3.18-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM / Domains: Fix initial default state of the need_restore flag
PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is set
PM / Domains: Change prototype for the attach and detach callbacks
cpufreq: Avoid crash in resume on SMP without OPP
cpufreq: cpufreq-dt: Fix arguments in clock failure error message
ACPI / blacklist: blacklist Win8 OSI for Dell Vostro 3546
* pm-domains:
* pm-sleep:
* pm-cpufreq:
1) sunhme driver lacks DMA mapping error checks, based upon a report by
Meelis Roos.
2) Fix memory leak in mvpp2 driver, from Sudip Mukherjee.
3) DMA memory allocation sizes are wrong in systemport ethernet driver,
fix from Florian Fainelli.
4) Fix use after free in mac80211 defragmentation code, from Johannes
Berg.
5) Some networking uapi headers missing from Kbuild file, from Stephen
Hemminger.
6) TUN driver gets csum_start offset wrong when VLAN accel is enabled,
and macvtap has a similar bug, from Herbert Xu.
7) Adjust several tunneling drivers to set dev->iflink after registry,
because registry sets that to -1 overwriting whatever we did. From
Steffen Klassert.
8) Geneve forgets to set inner tunneling type, causing GSO segmentation
to fail on some NICs. From Jesse Gross.
9) Fix several locking bugs in stmmac driver, from Fabrice Gasnier and
Giuseppe CAVALLARO.
10) Fix spurious timeouts with NewReno on low traffic connections, from
Marcelo Leitner.
11) Fix descriptor updates in enic driver, from Govindarajulu
Varadarajan.
12) PPP calls bpf_prog_create() with locks held, which isn't kosher.
Fix from Takashi Iwai.
13) Fix NULL deref in SCTP with malformed INIT packets, from Daniel
Borkmann.
14) psock_fanout selftest accesses past the end of the mmap ring, fix
from Shuah Khan.
15) Fix PTP timestamping for VLAN packets, from Richard Cochran.
16) netlink_unbind() calls in netlink pass wrong initial argument, from
Hiroaki SHIMODA.
17) vxlan socket reuse accidently reuses a socket when the address
family is different, so we have to explicitly check this, from
Marcelo Lietner.
18) Fix missing include in nft_reject_bridge.c breaking the build on ppc
and other architectures, from Guenter Roeck.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits)
vxlan: Do not reuse sockets for a different address family
smsc911x: power-up phydev before doing a software reset.
lib: rhashtable - Remove weird non-ASCII characters from comments
net/smsc911x: Fix delays in the PHY enable/disable routines
net/smsc911x: Fix rare soft reset timeout issue due to PHY power-down mode
netlink: Properly unbind in error conditions.
net: ptp: fix time stamp matching logic for VLAN packets.
cxgb4 : dcb open-lldp interop fixes
selftests/net: psock_fanout seg faults in sock_fanout_read_ring()
net: bcmgenet: apply MII configuration in bcmgenet_open()
net: bcmgenet: connect and disconnect from the PHY state machine
net: qualcomm: Fix dependency
ixgbe: phy: fix uninitialized status in ixgbe_setup_phy_link_tnx
net: phy: Correctly handle MII ioctl which changes autonegotiation.
ipv6: fix IPV6_PKTINFO with v4 mapped
net: sctp: fix memory leak in auth key management
net: sctp: fix NULL pointer dereference in af->from_addr_param on malformed packet
net: ppp: Don't call bpf_prog_create() in ppp_lock
net/mlx4_en: Advertize encapsulation offloads features only when VXLAN tunnel is set
cxgb4 : Fix bug in DCB app deletion
In free_area_init_core(), zone->managed_pages is set to an approximate
value for lowmem, and will be adjusted when the bootmem allocator frees
pages into the buddy system.
But free_area_init_core() is also called by hotadd_new_pgdat() when
hot-adding memory. As a result, zone->managed_pages of the newly added
node's pgdat is set to an approximate value in the very beginning.
Even if the memory on that node has node been onlined,
/sys/device/system/node/nodeXXX/meminfo has wrong value:
hot-add node2 (memory not onlined)
cat /sys/device/system/node/node2/meminfo
Node 2 MemTotal: 33554432 kB
Node 2 MemFree: 0 kB
Node 2 MemUsed: 33554432 kB
Node 2 Active: 0 kB
This patch fixes this problem by reset node managed pages to 0 after
hot-adding a new node.
1. Move reset_managed_pages_done from reset_node_managed_pages() to
reset_all_zones_managed_pages()
2. Make reset_node_managed_pages() non-static
3. Call reset_node_managed_pages() in hotadd_new_pgdat() after pgdat
is initialized
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.16+]
