[ Upstream commit 5ee4433efe99b9f39f6eff5052a177bbcfe72cea ]
By definition net_generic should never be called when it can return
NULL. Fail conspicously with a BUG_ON to make it clear when people mess
up that a NULL return should never happen.
Recently there was a bug in the CAIF subsystem where it was registered
with register_pernet_device instead of register_pernet_subsys. It was
erroneously concluded that net_generic could validly return NULL and
that net_assign_generic was buggy (when it was just inefficient).
Hopefully this BUG_ON will prevent people to coming to similar erroneous
conclusions in the futrue.
Tested-by: Sasha Levin <levinsasha928@gmail.com>
Change-Id: I7936b0403664d9745e4932aad72fd09c100f526c
Reviewed-on: http://git-master/r/79690
Add an ioctl, EVIOCSSUSPENDBLOCK, to enable a wakelock that will block
suspend while the event queue is not empty. This allows userspace code to
process input events while the device appears to be asleep.
The current code holds the wakelock for up 5 seconds for every input
device and client. This can prevent suspend if sensor with a high data
rate is active, even when that sensor is not capable of waking the
device once it is suspended.
(cherry picked from commit 4dc43d7079bdae572212368e1d29abea0177c932 from
android.googlesource.com/common.git)
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Change-Id: I160d2afe77aa76c9d2bbe01cd4b81434201361a9
Reviewed-on: http://git-master/r/78895
Add a comment pointing out the use of enum station_info_flags for
all new struct station_info fields. In addition, memset the sinfo
buffer to zero before use on all paths in the current tree to avoid
leaving uninitialized pointers in the data.
(cherry picked from commit 87159de9c30dab02b84cbaffa7498140d4ebc1a1 from
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
Change-Id: I24301d45108587e66c8421a7f2a94ea98300ebeb
Reviewed-on: http://git-master/r/78887
When user space SME/MLME (e.g., hostapd) is not used in AP mode, the
IEs from the (Re)Association Request frame that was processed in
firmware need to be made available for user space (e.g., RSN IE for
hostapd). Allow this to be done with cfg80211_new_sta().
(cherry picked from commit d692df224b8605095cb7f770c1c99d3150834daf from
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Change-Id: I211171ca4953832cc998402c149ecf3fc429f9e6
Reviewed-on: http://git-master/r/78886
(cherry picked from commit d1e94136fc4fe8ea608f4e9d21befa00c86e1e29 from
Change-Id: I48d9778007e1e9eed2bb34e33ceee818c23afaa5
Signed-off-by: Dima Zavin <dima@android.com>
Reviewed-on: http://git-master/r/78885
Added GLPM(Global Low-Power Mode) to support Low-Power Mode
during sleep mode.
Bug 924686
Reviewed-on: http://git-master/r/75627
Change-Id: Ia4be1b6b24de95f29ac173bed71c045a246cbcde
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/78701
Change-Id: Ifddccc5407d517b098c448c568a909750abe8380
Reviewed-on: http://git-master/r/78444
This is the first step in defining a dma buffer sharing mechanism.
A new buffer object dma_buf is added, with operations and API to allow easy
sharing of this buffer object across devices.
The framework allows:
- creation of a buffer object, its association with a file pointer, and
associated allocator-defined operations on that buffer. This operation is
called the 'export' operation.
- different devices to 'attach' themselves to this exported buffer object, to
facilitate backing storage negotiation, using dma_buf_attach() API.
- the exported buffer object to be shared with the other entity by asking for
its 'file-descriptor (fd)', and sharing the fd across.
- a received fd to get the buffer object back, where it can be accessed using
the associated exporter-defined operations.
- the exporter and user to share the scatterlist associated with this buffer
object using map_dma_buf and unmap_dma_buf operations.
Atleast one 'attach()' call is required to be made prior to calling the
map_dma_buf() operation.
Couple of building blocks in map_dma_buf() are added to ease introduction
of sync'ing across exporter and users, and late allocation by the exporter.
For this first version, this framework will work with certain conditions:
- *ONLY* exporter will be allowed to mmap to userspace (outside of this
framework - mmap is not a buffer object operation),
- currently, *ONLY* users that do not need CPU access to the buffer are
allowed.
More details are there in the documentation patch.
This is based on design suggestions from many people at the mini-summits[1],
most notably from Arnd Bergmann <arnd@arndb.de>, Rob Clark <rob@ti.com> and
Daniel Vetter <daniel@ffwll.ch>.
The implementation is inspired from proof-of-concept patch-set from
Tomasz Stanislawski <t.stanislaws@samsung.com>, who demonstrated buffer sharing
between two v4l2 devices. [2]
[1]: https://wiki.linaro.org/OfficeofCTO/MemoryManagement
[2]: http://lwn.net/Articles/454389
Change-Id: I8ebd858ad86242ee7b02d5f42bb25c3edbd64fca
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Signed-off-by: Sumit Semwal <sumit.semwal@ti.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Dave Airlie <airlied@redhat.com>
Reviewed-and-Tested-by: Rob Clark <rob.clark@linaro.org>
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
[Hiroshi DOYU: Backported from v3.3-rc1]
Reviewed-on: http://git-master/r/78384
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
A lot of files pull in module.h when all they are really
looking for is the basic EXPORT_SYMBOL functionality. The
recent data from Ingo[1] shows that this is one of several
instances that has a significant impact on compile times,
and it should be targeted for factoring out (as done here).
Note that several commonly used header files in include/*
directly include <linux/module.h> themselves (some 34 of them!)
The most commonly used ones of these will have to be made
independent of module.h before the full benefit of this change
can be realized.
We also transition THIS_MODULE from module.h to export.h,
since there are lots of files with subsystem structs that
in turn will have a struct module *owner and only be doing:
.owner = THIS_MODULE;
and absolutely nothing else modular. So, we also want to have
the THIS_MODULE definition present in the lightweight header.
[1] https://lkml.org/lkml/2011/5/23/76
Change-Id: I52c16cc63f483d7c572cd0ef2475ef642dfa11c1
[Hiroshi DOYU: Backported from v3.3-rc1 for DMABUF]
Reviewed-on: http://git-master/r/78383
android-tegra-nv-3.1
Change-Id: I9001bb291779f107bbcb593d48f9f0f734074d0e
Few board specific calls use this function. Compilation fails if
calls from the board file is not protected by CONFIG_TI_ST, which
is not recommended.
Bug 926128
Reviewed-on: http://git-master/r/77435
Change-Id: Idb4fa9001a102f1cb983afd131bfd4c0c8cf08f3
Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-on: http://git-master/r/78020
This new value is a new type of clock setting that is used by wl128x
chipsets.
Bug 926128
Reviewed-on: http://git-master/r/77361
(cherry picked from commit 62c7d085e1f2a1f2b4d89560551eff18d703b3b1)
Change-Id: I2cf2af565a2574cf789ae73a59b4891969506491
Signed-off-by: Luciano Coelho <coelho@ti.com>
Reviewed-on: http://git-master/r/78019
patch is for following feature
1) use set_power() defined in platform file to
switch on/off BT.
2) send_ll_cmd according to state
Reviewed-on: http://git-master/r/77318
Change-Id: I48ccb310ee4ce97c82835ef5701673c6f40231d4
Reviewed-on: http://git-master/r/78018
This is Synaptics' open source driver except one line
change to accomodate an SPI kernel driver feature
which does not accomodate optional byte-delay. It
will be fully original driver when we add byte-delay
into Tegra SPI kernel drivers.
Bug 912775
Reviewed-on: http://git-master/r/74642
Change-Id: I0f39928c48bc0e633de0d2c1f595bcef47268d52
Signed-off-by: Peter Zu <pzu@nvidia.com>
Reviewed-on: http://git-master/r/77774
CPU register read did not have access to nvhost power management.
Due to this only modules that were powered on previously are actually
accessible via the API. This patch refactors CPU access to:
* Move mutexes to sync point, as they're sync point operations
* Move register address spaces to nvhost_device
* Call register read with access to the respective nvhost_device
* Initialize module completely at boot-up so that register reads
can be done without an initialized channel.
Reviewed-on: http://git-master/r/75275
Change-Id: I0db38cef7b2cd92dc64e7f55d227bdd2fdb8f752
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/77764
Grouphold gain and coarse_time register writes.
Make gain and coarse_time set in one ioctl call.
Bug 924213
Reviewed-on: http://git-master/r/74622
Change-Id: I648e4c24c1a048629757abc21afba092d1484d04
Signed-off-by: Yining Deng <ydeng@nvidia.com>
Reviewed-on: http://git-master/r/77762
Reviewed-on: http://git-master/r/77504
Change-Id: Iafe31126fbcec1bfd01b51e0c122b44d3a71bbda
Reviewed-on: http://git-master/r/77759
Bug: 924817
Reviewed-on: http://git-master/r/77236
Change-Id: Iea767c952cfac8cb1643e28b7e29e43ad298909e
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/77755
Added i2c high speed support.
Bug 873879
Reviewed-on: http://git-master/r/71997
Change-Id: I5a2c5f272485e6f7c8bb6c11d7c3b6850fdcd768
Signed-off-by: Alok Chauhan <alokc@nvidia.com>
Reviewed-on: http://git-master/r/77741
Count of selector voltage is required for regulator_set_voltage
to work via set_voltage_sel. VDD1/2 currently have it as zero,
so regulator_set_voltage won't work for VDD1/2.
Update count (n_voltages) for VDD1/2.
Output Voltage = (step value * 12.5 mV + 562.5 mV) * gain
With above expr, number of voltages that can be selected is
step value count * gain count
constant for gain count will be called VDD1_2_NUM_VOLT_COARSE
existing constant for step value count is VDD1_2_NUM_VOLTS,
use VDD1_2_NUM_VOLT_FINE instead to make clear that step value
is not the only component in deciding selectable voltage count
Signed-off-by: Afzal Mohammed <afzal@ti.com>
Cherry picked from mainline's commit
780dc9ba4eb682a89be48d5b814feae6722a19e0
Change-Id: I1c246a02f1c647fe3c647b3dde2a0633c2783764
Reviewed-on: http://git-master/r/77536
Create an array of fixed size for the platform to pass regulator
initalization data through.
Passing an array of pointers to init data also allows more flexible
definition of init data as well as prevents reading past the end of the
array should the platform define an incorrectly sized array.
Signed-off-by: Kyle Manna <kyle.manna@fuel7.com>
cherry picked from mainline's commit
c1fc1480249dfe059254779a4bb7ca27cf5f8038
Change-Id: Ia298bbd2828e644d24e10ab67ff76f1169cf7f51
Reviewed-on: http://git-master/r/77535
Move the regulator defintions to the header so that platform board file
can use them to configure specific regulators.
Cherry picked from mainline's commit:
72c108cc4947db2fcdd3f3e8a2b60bd65e74a1cc
Change-Id: I7659c33cab6f20c91dc4bf36e1c157e1878993ab
Reviewed-on: http://git-master/r/77534
The regulator module consists of 1 DCDC. The output voltage
is configurable and is meant for supply power to the core
voltage of Soc.
Cherrypick from Mainline commit
6219929f5f82708309b3054ec7db6cb6e3ee47d5
Change-Id: Idfdbf06f7d01e0faaabcb658311a9aa5324ddc68
Reviewed-on: http://git-master/r/77341
Bug 901367
Change-Id: I73fe7c19f5f50530f7d0a73d0a6b9ba2092c71d2
Reviewed-on: http://git-master/r/76664
Reviewed-by: Steve Lin <stlin@nvidia.com>
Signed-off-by: Raj Jayaraman <rjayaraman@nvidia.com>
Change-Id: I309eb6178a7f39714f9e5f963faf011a1a79b079
Reviewed-on: http://git-master/r/77309
Adding option for non std freq tuning for
host controllers that have deviation in the
tuning procedure.
Bug 920089
Change-Id: I8ca6962c6f0380c1160460e5094c47aee241d6e3
Reviewed-on: http://git-master/r/72603
Reviewed-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Change-Id: I97cceb39fd27b159823ebce6706c5e74e53deccd
Reviewed-on: http://git-master/r/77303
Fix build error caused by missing arg.
Change-Id: I5ab0efed314db320aaa70a3acb406f37b17b183a
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/76759
promotion_build
Use standard drvdata interface for storing and accessing nvhost_master.
Reviewed-on: http://git-master/r/72846
Change-Id: I191987c8f6d313a6ede9b59f723269cb6a197e8a
Reviewed-on: http://git-master/r/76815
Linux 3.1.10
Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118
In i915 driver, we do not enable either rc6 or semaphores on SNB when dmar
is enabled. The new 'intel_iommu_enabled' variable signals when the
iommu code is in operation.
Cc: Ted Phelps <phelps@gnusto.com>
Cc: Peter <pab1612@gmail.com>
Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz>
Cc: Andrew Lutomirski <luto@mit.edu>
CC: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
This call-back is invoked when the task that is bound to a
pasid is about to exit. The driver can use it to shutdown
all context related to that context in a safe way.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
This function can be used to find out which features
necessary for IOMMUv2 usage are available on a given device.
This callback can be used to change the PRI response code
sent to a device when a PPR fault fails.
This patch adds routines to bind a specific process
address-space to a given PASID.
This patch adds the amd_iommu_init_device() and
amd_iommu_free_device() functions which make a device and
the IOMMU ready for IOMMUv2 usage.
Add infrastructure for errata-handling and handle two known
erratas in the IOMMUv2 code.
An IOMMU group is a set of devices for which the IOMMU cannot
distinguish transactions. For PCI devices, a group often occurs
when a PCI bridge is involved. Transactions from any device
behind the bridge appear to be sourced from the bridge itself.
We leave it to the IOMMU driver to define the grouping restraints
for their platform.
Using this new interface, the group for a device can be retrieved
using the iommu_device_group() callback. Users will compare the
value returned against the value returned for other devices to
determine whether they are part of the same group. Devices with
no group are not translated by the IOMMU. There should be no
expectations about the group numbers as they may be arbitrarily
assigned by the IOMMU driver and may not be persistent across boots.
We also provide a sysfs interface to the group numbers here so
that userspace can understand IOMMU dependencies between devices
for managing safe, userspace drivers.
[Some code changes by Joerg Roedel <joerg.roedel@amd.com>]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
include/linux/iommu.h
Change-Id: I524607da569e42730bdc706759c49c4e0783555c
When mapping a memory region, split it to page sizes as supported
by the iommu hardware. Always prefer bigger pages, when possible,
in order to reduce the TLB pressure.
The logic to do that is now added to the IOMMU core, so neither the iommu
drivers themselves nor users of the IOMMU API have to duplicate it.
This allows a more lenient granularity of mappings; traditionally the
IOMMU API took 'order' (of a page) as a mapping size, and directly let
the low level iommu drivers handle the mapping, but now that the IOMMU
core can split arbitrary memory regions into pages, we can remove this
limitation, so users don't have to split those regions by themselves.
Currently the supported page sizes are advertised once and they then
remain static. That works well for OMAP and MSM but it would probably
not fly well with intel's hardware, where the page size capabilities
seem to have the potential to be different between several DMA
remapping devices.
register_iommu() currently sets a default pgsize behavior, so we can convert
the IOMMU drivers in subsequent patches. After all the drivers
are converted, the temporary default settings will be removed.
Mainline users of the IOMMU API (kvm and omap-iovmm) are adopted
to deal with bytes instead of page order.
Many thanks to Joerg Roedel <Joerg.Roedel@amd.com> for significant review!
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Joerg Roedel <Joerg.Roedel@amd.com>
Cc: Stepan Moskovchenko <stepanm@codeaurora.org>
Cc: KyongHo Cho <pullip.cho@samsung.com>
Cc: Hiroshi DOYU <hdoyu@nvidia.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: kvm@vger.kernel.org
Express sizes in bytes rather than in page order, to eliminate the
size->order->size conversions we have whenever the IOMMU API is calling
the low level drivers' map/unmap methods.
Adopt all existing drivers.
With all IOMMU drivers being converted to bus_set_iommu the
global iommu_ops are no longer required. The same is true
for the deprecated register_iommu function.
With per-bus iommu_ops the iommu_found function needs to
work on a bus_type too. This patch adds a bus_type parameter
to that function and converts all call-places.
The function is also renamed to iommu_present because the
function now checks if an iommu is present for a given bus
and does not check for a global iommu anymore.
This is necessary to store a pointer to the bus-specific
iommu_ops in the iommu-domain structure. It will be used
later to call into bus-specific iommu-ops.
drivers/iommu/iommu.c
Change-Id: Iddbd561739552b663a4be293f1992314eb0f775a
This is the starting point to make the iommu_ops used for
the iommu-api a per-bus-type structure. It is required to
easily implement bus-specific setup in the iommu-layer.
The first user will be the iommu-group attribute in sysfs.
This makes it impossible to compile an iommu driver into the
kernel without selecting CONFIG_IOMMU_API.
Make report_iommu_fault() return -ENOSYS whenever an iommu fault
handler isn't installed, so IOMMU drivers can then do their own
platform-specific default behavior if they wanted.
Fault handlers can still return -ENOSYS in case they want to elicit the
default behavior of the IOMMU drivers.
Change the CONFIG_DMAR to CONFIG_INTEL_IOMMU to be consistent
with the other IOMMU options.
Rename the CONFIG_INTR_REMAP to CONFIG_IRQ_REMAP to match the
irq subsystem name.
And define the CONFIG_DMAR_TABLE for the common ACPI DMAR
routines shared by both CONFIG_INTEL_IOMMU and CONFIG_IRQ_REMAP.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: youquan.song@intel.com
Cc: joerg.roedel@amd.com
Cc: tony.luck@intel.com
Cc: dwmw2@infradead.org
Link: http://lkml.kernel.org/r/20110824001456.558630224@sbsiddha-desk.sc.intel.com
arch/x86/include/asm/irq_remapping.h
arch/x86/kernel/apic/io_apic.c
drivers/iommu/Makefile
Change-Id: I3f09baf327e59d94f38801d107268f4e20c1da8e
Link: http://lkml.kernel.org/r/20110824001456.386003047@sbsiddha-desk.sc.intel.com
Move the IOMMU specific routines to intel-iommu.c leaving the
dmar.c to the common ACPI dmar code shared between DMA-remapping
and Interrupt-remapping.
Link: http://lkml.kernel.org/r/20110824001456.282401285@sbsiddha-desk.sc.intel.com
On the platforms which are x2apic and interrupt-remapping
capable, Linux kernel is enabling x2apic even if the BIOS
doesn't. This is to take advantage of the features that x2apic
brings in.
Some of the OEM platforms are running into issues because of
this, as their bios is not x2apic aware. For example, this was
resulting in interrupt migration issues on one of the platforms.
Also if the BIOS SMI handling uses APIC interface to send SMI's,
then the BIOS need to be aware of x2apic mode that OS has
enabled.
On some of these platforms, BIOS doesn't have a HW mechanism to
turnoff the x2apic feature to prevent OS from enabling it.
To resolve this mess, recent changes to the VT-d2 specification:
http://download.intel.com/technology/computing/vptech/Intel(r)_VT_for_Direct_IO.pdf
includes a mechanism that provides BIOS a way to request system
software to opt out of enabling x2apic mode.
Look at the x2apic optout flag in the DMAR tables before
enabling the x2apic mode in the platform. Also print a warning
that we have disabled x2apic based on the BIOS request.
Kernel boot parameter "intremap=no_x2apic_optout" can be used to
override the BIOS x2apic optout request.
Signed-off-by: Youquan Song <youquan.song@intel.com>
Link: http://lkml.kernel.org/r/20110824001456.171766616@sbsiddha-desk.sc.intel.com
