Add ePxP V4L2 output driver, which calls ePxP DMAEngine internally.
Support rotation, overlay, alpha-blending, colorkey, etc.
Signed-off-by: Robby Cai <R63905@freescale.com>
Add support for platform-level selection of PMIC pass version. 1 and 2
supported currently. Also support platform-level selection of VCOM
voltage value.
Signed-off-by: Danny Nold <dannynold@freescale.com>
Ability added to control the delay between all updates being complete
and the EPDC powering down. This provides user space control over
how frequently the EPDC is undertaking a time-consuming enable/disable
process.
It's easy to reproduce by run below cmd:
./mxc_v4l2_output.out -iw 320 -ih 240 -ow 1024 -oh 768 -fr 80 -d 3
qvga.yuv
For performance, we did not check display in IC interrupt handle before.
Output must sync to display.
In this patch:
1. make stream begin with one buffer.
2. change timer_work name to icbypass_work.
3. add display sync to timer interrupt handler.
Signed-off-by: Jason Chen <b02280@freescale.com>
Enable the configurations of the boot enable on the eMMC cards.
Add the interface that used to configure the boot_bus_width
In order to make sure that the re-read the ext-csd of card
can be completed successfully, add the method to wait for
the finish of the busy state.
NOTE:
The following are the valid inputs when configure the boot
bus width of the eMMC cards.
| Bit7 Bit6 Bit5 | Bit4 Bit3 | Bit2 | Bit1 Bit0 |
| X | BOOT_MODE | RESET_BOOT_BUS_WIDTH | BOOT_BUS_WIDTH |
Bit [4:3] : BOOT_MODE (non-volatile)
0x0 : Use single data rate + backward compatible timings in boot
operation (default)
0x1 : Use single data rate + high speed timings in boot operation mode
0x2 : Use dual data rate in boot operation
0x3 : Reserved
Bit [2]: RESET_BOOT_BUS_WIDTH (non-volatile)
0x0 : Reset bus width to x1, single data rate and backward compatible
timings after boot operation (default)
0x1 : Retain boot bus width and boot mode after boot operation
Bit[1:0] : BOOT_BUS_WIDTH (non-volatile)
0x0 : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
0x1 : x4 (sdr/ddr) bus width in boot operation mode
0x2 : x8 (sdr/ddr) bus width in boot operation mode
0x3 : Reserved
partitions of the eMMC cards.
| Bit7 | Bit6 | Bit5 Bit4 Bit3 | Bit2 Bit1 Bit0 |
| X | BOOT_ACK | BOOT_PARTITION_ENABLE | PARTITION_ACCESS |
Bit7: Reserved
Bit6: always set to vaule '1' when boot_part is enabled
Bit[5:3]:
0x0 : Device not boot enabled (default)
0x1 : Boot partition 1 enabled for boot
0x2 : Boot partition 2 enabled for boot
0x7 : User area enabled for boot
Bit[2:0]:
0x0 : No access to boot partition (default)
0x1 : R/W boot partition 1
0x2 : R/W boot partition 2
So only the '0, 1, 2; 8, 9, 10; 16, 17, 18; 56, 57, 58' are
valid parameters when configure the boot_partiton.
Signed-off-by: Richard Zhu <r65037@freescale.com>
Add mac field at platform data
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Add check in mxcfb_check_var(), if fg size is bigger than bg, then
make it same size as bg.
Change the include/linux/ipu.h
User can get eMMC partitions info from user space layer in
linux OS enviroment.
User can do switch operations between the eMMC boot partitions
and the user partition.
User can access the eMMC boot partitions from user space layer
in linux OS enviroment.
NOTE:This func had been verified on TOSHIBA eMMC44 card only.
Signed-off-by: Rob Herring <r.herring@freescale.com>
The modifications of linux kernel common codes
when enable the eMMC44 DDR mode
Add pxp_dma.h into KBuild
Added basic EPDC driver, including support for PXP conversions (rotation,
auto-waveform selection, CSC). Self-clock gating also supported.
Use Common DMA-Engine framework to implement ePXP driver
Use a dma client driver to access ePxP staff.
Added new regulator driver to control voltage supplies for
E-Ink panel.
Ignore UGDE using for non YUYV output formats
Signed-off-by: Mark Gutman <r58412@freescale.com>
support imx53 evk board OTG and Host1 vbus active
and inactive to low the power consume, fix fsl_otg.c
build failt, add vbus power control function pointer
in struct fsl_usb2_platform_data.
Signed-off-by: Hu hui <b29976@freescale.com>
1) Support select VDI input channel buffer ioctrl.
2) Add VDI input channels' EOF interrupt.
Signed-off-by: Liu Ying <b17645@freescale.com>
The support for YUV422 different combinations are added
The YUV422 is supported for DI1 interface for 720P frames with 16bits bus only:
di1_primary video=mxcdi1fb:YUYV16,720P60
To define required YUV422 format use one of:
YUYV16
YVYU16
UYVY16
VYUY16
This can be used for AHCI-compatible interfaces implemented inside
System-On-Chip solutions, or AHCI devices connected via localbus.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Hopefully results in fewer on-the-wire FIS's and no breakage. We'll see!
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
/unit_test//unit_tests/mxc_v4l2_output.out -iw 1920 -ih 1080 -ow 1920
-oh 1080 -d 3 -l 600 -fr 80 /dev/shm/1920_1080_E18_c2.yuv
Error information:
It report the following error:
video4linux video16: unable to update buffer 0 address rc=-13
Fix above issue by modify the operation of ic-bypass mode.
Fix ipu lib compile error after 4-stripes resize patch pushed.
The updated algorithm allows output frame size up to 2048x2048
Signed-off-by: Mark Gutman <Mark.Gutman@freescale.com>
commit 541cd3ee00a4fe975b22fac6a3bc846bacef37f7 ("phylib: Fix deadlock
on resume") caused TI DaVinci EMAC ethernet driver to oops upon resume:
PM: resume of devices complete after 237.098 msecs
Restarting tasks ... done.
kernel BUG at kernel/workqueue.c:354!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
Backtrace:
[<c002c598>] (__bug+0x0/0x2c) from [<c0052a54>] (queue_delayed_work_on+0x74/0xf8)
[<c00529e0>] (queue_delayed_work_on+0x0/0xf8) from [<c0052b30>] (queue_delayed_work+0x2c/0x30)
The oops pops up because TI DaVinci EMAC driver detaches PHY on
suspend and attaches it back on resume. Attaching makes phylib call
phy_start_machine() that initializes a workqueue. On the other hand,
PHY's resume routine will call phy_start_machine() again, and that
will cause the oops since we just destroyed the already scheduled
workqueue.
This patch fixes the issue by moving workqueue initialization to
phy_device_create().
p.s. We don't see this oops with ucc_geth and gianfar drivers because
they perform a fine-grained suspend, i.e. they just stop the PHYs
without detaching.
Reported-by: Sekhar Nori <nsekhar@ti.com>
Tested-by: Sekhar Nori <nsekhar@ti.com>
Since hibernation assumes power loss, we should fully reinitialize
PHYs (including platform fixups), as if PHYs were just attached.
This patch factors phy_init_hw() out of phy_attach_direct(), then
converts mdio_bus to dev_pm_ops and adds an appropriate restore()
callback.
Implement RTC_READ_TIME_47BIT and RTC_WAIT_FOR_TIME_SET ioctls.
Updates based on review comments.
Signed-off-by: Anish Trivedi <anish@freescale.com>
This patch adds LDB driver support.
L2 Switch resources definition for MX28
Signed-off-by: Niu Xule <b23300@freescale.com>
Deleted the old drivers.
Broke the driver into separate files, for readability and to isolate
hardware dependencies.
Fixed bad block problems in the boot area for the i.MX23.
At this writing, UBI can't handle MTDs larger than 2GiB. If the
general use partition is larger than 2GiB, the driver will create
sub-partitions, none of which are larger than 2GiB.
Updated the default configs for the i.MX23 and i.MX28.
Other, miscellaneous changes.
Signed-off-by: Patrick Turley <patrick.turley@freescale.com>
This driver unifies the i.MX23 and i.MX28 NAND Flash drivers into a single
driver that supports both SoC's.
iMX23 evk RevC using gpio as usb id.
usb_id pin is conflict with mmcsd detection pin
Add USB 100mA limitation feature for mx28 to mach usb 2.0 current requirment
Signed-off-by: Frank Li <Frank.li@freescale.com>
add usb support for mx28
include usb host and usb device
Signed-off-by: Albert Chen <r65187@freescale.com>
FEC driver support for i.MX28
Signed-off-by:Jason Liu <r64343@freescale.com>
To preview with V4L2 overlay and capture at the same time may fail.
This patch implements workaround for this issue by enabling CSI after
PRP channels are setup.
Add IPU_CSC_UPDATE case for ipu ioctl.
Signed-off-by: Sammy He <r62914@freescale.com>
Add iram allocation functions using GENERIC_ALLOCATOR. The
allocation size is 4KB multiples to guarantee alignment.
blank/unblank fb during v4l2 playback, unblank will cause current buffer
of display channel to be 1. This patch make the sequence of select
display buffer correct.
1. Blank BG during video play on FG:
./mxc_v4l2_output.out -iw 320 -ih 240 -ow 1024 -oh 768 -d 3 qvga.yuv
echo 1 > /sys/class/graphics/fb0/blank
echo 0 > /sys/class/graphics/fb0/blank
2. The same input and output (ic_bypass):
./mxc_v4l2_output.out -iw 320 -ih 240 -ow 320 -oh 240 -d 3 qvga.yuv
Modify MXCFB_SET_LOC_ALPHA ioctrl to support DP local alpha with
alpha value contained in pixel.
To support 720p output for ipu lib.
If there is no usb devices connectted or all connectted usb
devices are in suspend state, usb host can suspend its whole bus,
then put the PHY into low power mode and close all usb clocks.
(The patch is splitted 2 patches, this is common code part.)
Signed-off-by: Li Jun <r65092@freescale.com>
Changed bit definition from 0x8000 to 0x4000
Support DP gamma by setting piecewise linear approximation,
application need set coefficient const[k] and slope[k]. The algorithm to
calculate these coefficient pls refer to unit test.
Added the device identification and timing database. Adjusted the GPMI
NAND Flash driver to use this information.
Follow the approach suggested by Russell King and implemented by him in
the clkdev API and allow consumer device supply mapings to be set up
using the dev_name() for the consumer instead of the struct device.
In order to avoid making existing machines instabuggy and creating merge
issues the use of struct device is still supported for the time being.
This resolves problems working with buses such as I2C which make the
struct device available late providing that the final device name is
known, which is the case for most embedded systems with fixed setups.
Consumers must still use the struct device when calling regulator_get().
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add i.MX specific files into include/linux/Kbuild
Signed-off-by: Lily Zhang <r58066@freescale.com>
-Added kernel error message to handle hang due to SCC HW failure.
-Eliminated unwanted sleeps.
-Kernel error message to handle the case when SCC key fuses are not blown.
Signed-off-by: Raj Rajasekaran <b10872@freescale.com>
A new feature is added to support to upsizing by horizontal stripes
via IC PP channels double using.
MX233: Restructure the STMP378xxx USB Host and Gadget device structures
to be similar to MXC structures. Enable fsl_otg_arc driver to work on
MX233 platform. Remove FSL_USB2_DONT_REMAP requirement.
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
arch/arm/mach-stmp3xxx/Kconfig
arch/arm/mach-stmp3xxx/Makefile
arch/arm/mach-stmp3xxx/devices.c
arch/arm/mach-stmp3xxx/include/mach/stmp3xxx.h
arch/arm/mach-stmp3xxx/stmp378x_devb.c
USB will enter low power mode if no vbus power supply.
Only finished this feature in Mx37.
1. When enter low power mode, driver will close usb related clocks
as possible as could.
set usb IP to stop.
Set PHY to low power suspend by setting PHCD bit of portsc.
2. This patch doesn't support low power mode in OTG mode yet.
