timespec_add_ns is used from the x86-64 vdso, which cannot call out to
other kernel code. Make sure that timespec_add_ns is always inlined
(and only uses always_inlined functions) to make sure there are no
unexpected calls.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
iter_div_u64_rem is used in the x86-64 vdso, which cannot call other
kernel code. For this case, provide the always_inlined version,
__iter_div_u64_rem.
We have a few instances of the open-coded iterative div/mod loop, used
when we don't expcet the dividend to be much bigger than the divisor.
Unfortunately modern gcc's have the tendency to strength "reduce" this
into a full mod operation, which isn't necessarily any faster, and
even if it were, doesn't exist if gcc implements it in libgcc.
The workaround is to put a dummy asm statement in the loop to prevent
gcc from performing the transformation.
This patch creates a single implementation of this loop, and uses it
to replace the open-coded versions I know about.
Cc: john stultz <johnstul@us.ibm.com>
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Christian Kujau <lists@nerdbynature.de>
Cc: Robert Hancock <hancockr@shaw.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/core: Remove IB_DEVICE_SEND_W_INV capability flag
IB/umem: Avoid sign problems when demoting npages to integer
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6:
Blackfin serial driver: fix up tty core set_ldisc API change breakage bug
Blackfin arch: protect only the SPI bus controller with CONFIG_SPI_BFIN
Blackfin arch: fixup warnings with the new cplb saved values
Blackfin Serial Driver: Clean up BF54x macro in blackfin UART driver.
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] ehea: Remove dependency on MEMORY_HOTPLUG
[POWERPC] Make walk_memory_resource available with MEMORY_HOTPLUG=n
[POWERPC] Use dev_set_name in pci_64.c
[POWERPC] Fix incorrect enabling of VMX when building signal or user context
[POWERPC] boot/Makefile CONFIG_ variable fixes
Minor source code cleanup of page flags in mm/page_alloc.c.
Move the definition of the groups of bits to page-flags.h.
The purpose of this clean up is that the next patch will
conditionally add a page flag to the groups. Doing that
in a header file is cleaner than adding #ifdefs to the
C code.
Signed-off-by: Russ Anderson <rja@sgi.com>
In 2.6.26, we added some support for send with invalidate work
requests, including a device capability flag to indicate whether a
device supports such requests. However, the support was incomplete:
the completion structure was not extended with a field for the key
contained in incoming send with invalidate requests.
Full support for memory management extensions (send with invalidate,
local invalidate, fast register through a send queue, etc) is planned
for 2.6.27. Since send with invalidate is not very useful by itself,
just remove the IB_DEVICE_SEND_W_INV bit before the 2.6.26 final
release; we will add an IB_DEVICE_MEM_MGT_EXTENSIONS bit in 2.6.27,
which makes things simpler for applications, since they will not have
quite as confusing an array of fine-grained bits to check.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The ehea driver was recently changed[1] to use walk_memory_resource() to
detect the system's memory layout. However, walk_memory_resource() is
available only when memory hotplug is enabled. So CONFIG_EHEA was
made to depend on MEMORY_HOTPLUG [2], but it is inappropriate for a
network driver to have such a dependency.
Make the declaration of walk_memory_resource() and its powerpc
implementation (ehea is powerpc-specific) unconditionally available.
[1] 48cfb14f8b89d4d5b3df6c16f08b258686fb12ad
"ehea: Add DLPAR memory remove support"
[2] fb7b6ca2b6b7c23b52be143bdd5f55a23b9780c8
"ehea: Add dependency to Kconfig"
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Acked-by: Badari Pulavarty <pbadari@us.ibm.com>
Commit 73f20e58b1d586e9f6d3ddc3aad872829aca7743 ("FAT_VALID_MEDIA():
remove pointless test") wrongly added the new fat_valid_media() function
to the userspace-visible part of include/linux/msdos_fs.h
Move it to the part of include/linux/msdos_fs.h that is not exported to
userspace.
Reported-by: Onur Küçük <onur@pardus.org.tr>
Reported-by: S.Çağlar Onur <caglar@pardus.org.tr>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: enable barriers by default
jbd2: Fix barrier fallback code to re-lock the buffer head
ext4: Display the journal_async_commit mount option in /proc/mounts
jbd2: If a journal checksum error is detected, propagate the error to ext4
jbd2: Fix memory leak when verifying checksums in the journal
ext4: fix online resize bug
ext4: Fix uninit block group initialization with FLEX_BG
ext4: Fix use of uninitialized data with debug enabled.
use_mm() was changed to use switch_mm() instead of activate_mm(), since
then nobody calls (and nobody should call) activate_mm() with
PF_BORROWED_MM bit set.
As Jeff Dike pointed out, we can also remove the "old != new" check, it is
always true.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Jeff Dike <jdike@addtoit.com>
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6:
capabilities: remain source compatible with 32-bit raw legacy capability support.
LSM: remove stale web site from MAINTAINERS
To get zeroed out memory from a particular NUMA node. To be used by
sunrpc.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
This patch fixes the following compile error caused by
commit 4016a1390d07f15b267eecb20e76a48fd5c524ef
(mm/nommu.c: return 0 from kobjsize with invalid objects):
/home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c: In function 'kobjsize':
/home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: 'memory_end' undeclared (first use in this function)
/home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: (Each undeclared identifier is reported only once
/home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: for each function it appears in.)
The patch also removes now no longer required memory_{start,end}
declarations inside access_ok().
Reported-by: Adrian Bunk <adrian.bunk@movial.fi>
Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Michael Hennerich <Michael.Hennerich@analog.com>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
When posting:
[PATCH 1/8] Scaling msgmni to the amount of lowmem
(see http://article.gmane.org/gmane.linux.kernel/637849/) I changed the
MSGPOOL value to make it fit what is said in the man pages (i.e. a size
in bytes).
But Michael Kerrisk rightly complained that this change could affect the
ABI. So I'm posting this patch to make MSGPOOL expressed back in Kbytes.
Michael, on his side, has fixed the man page.
Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net>
Cc: Pierre Peiffer <peifferp@gmail.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Acked-by: Michael Kerrisk <mtk.manpages@googlemail.com>
This patch introduces memory_read_from_buffer().
The only difference between memory_read_from_buffer() and
simple_read_from_buffer() is which address space the function copies to.
simple_read_from_buffer copies to user space memory.
memory_read_from_buffer copies to normal memory.
Cc: Doug Warzecha <Douglas_Warzecha@dell.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Matt Domsch <Matt_Domsch@dell.com>
Cc: Abhay Salunke <Abhay_Salunke@dell.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Markus Rechberger <markus.rechberger@amd.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Bob Moore <robert.moore@intel.com>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Len Brown <lenb@kernel.org>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Cc: Michael Holzheu <holzheu@de.ibm.com>
Cc: Brian King <brking@us.ibm.com>
Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Andrew Vasquez <linux-driver@qlogic.com>
Cc: Seokmann Ju <seokmann.ju@qlogic.com>
Bluetooth will be able to use this.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Dave Young <hidave.darkstar@gmail.com>
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Although if people have questions about ARCnet, perhaps it's _better_
for them to be mailing dwmw2@cam.ac.uk about it...
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] pxa: fix tosa.c build error
[ARM] 5067/1: _raw_write_can_lock macro bugfix
[ARM] 5070/1: pxa: add GPIO104_PSKTSEL to pxa27x MFP configuration
[ARM] 5068/1: PXA2xx Additional gpio definitions
[ARM] 5066/2: EM-X270: Fix DM9000 IRQ flags initialisation
[ARM] 5065/2: CM-X270: Fix DM9000 IRQ flags initialisation
[ARM] 5062/1: pxa: remove unused definition of CONFIG_ARCH_COTULLA_IDP
[ARM] 5060/1: remove unnecessary include of asm/io.h
[ARM] fix AT91 include loops
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (48 commits)
V4L/DVB (8001): dib0070: fix dib0070_attach when !CONFIG_DVB_TUNER_DIB0070
V4L/DVB (8000): tda827x: fix NULL pointer in tda827xa_lna_gain
V4L/DVB (7990): Fix entry for PowerColor RA 330 and make it run with firmware version 2.7
V4L/DVB (7983): tda18271_calc_rf_cal must return the return value of tda18271_lookup_map
V4L/DVB (7978): cx18: explicitly test for XC2028 tuner
V4L/DVB (7977): cx18: fix init order and remove duplicate open_on_first_use.
V4L/DVB (7975): saa7134_empress
V4L/DVB (7974): fix MEDIA_TUNER && FW_LOADER build error
V4L/DVB (7972): or51132.c: unaligned
V4L/DVB (7971): usb: unaligned
V4L/DVB (7970): mix trivial endianness annotations
V4L/DVB (7969): m920x: unaligned access
V4L/DVB (7968): zoran: endianness annotations
V4L/DVB (7967): bt8xx: unaligned access
V4L/DVB (7966): cx18: direct dereferencing of iomem
V4L/DVB (7965): annotate bcx_riscmem
V4L/DVB (7964): cx18 iomem annotations
V4L/DVB (7963): ivtv: trivial annotations
V4L/DVB (7962): ttusb endianness annotations and fixes
V4L/DVB (7961): fix endianness bug in dib0700_devices.c
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
Fix divide by zero error in build_clear_page() and build_copy_page()
[MIPS] Fix typo in header guard
[MIPS] Fix build error - Delete debugging crap that crept in with CMP
[MIPS] Add accessors for random register.
[MIPS] IP27: misc fixes
[MIPS] IP27: Fix clockevent setup
[MIPS] IP27: Fix bootmem memory setup
[MIPS] remove CONFIG_CPU_R4000 line from Makefile
[MIPS] Fix check for valid stack pointer during backtrace
[MIPS] Add missing braces to pte_mkyoung
[MIPS] R4700: Fix build_tlb_probe_entry
[MIPS] Alchemy: dbdma: add API to delete custom DDMA device ids.
[MIPS] Alchemy: export get_au1x00_speed for modules
ip_fast_csum() requires a memory clobber on its inline asm as it accesses
memory in a fashion that gcc can't predict.
The GCC manual says:
If your assembler instructions access memory in an unpredictable
fashion, add `memory' to the list of clobbered registers. This will
cause GCC to not keep memory values cached in registers across the
assembler instruction and not optimize stores or loads to that memory.
The bug hasn't been noticed in FRV, but it has been seen in PA-RISC.
Only the version pte_mkyoung for 36-bit pagetables on 32-bit hw was
affected and with this bug being around since November 29, 2004 there
is evidence to suport the assumption it was benign ;-)
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Add API to delete custom DDMA device ids create with
au1xxx_ddma_device_add().
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
These were removed in commit 26d507fcfef7f7d0cd2eec874a87169cc121c835:
> -#define V4L2_CID_HCENTER (V4L2_CID_BASE+22)
> -#define V4L2_CID_VCENTER (V4L2_CID_BASE+23)
> -#define V4L2_CID_LASTP1 (V4L2_CID_BASE+24) /*
> last CID + 1 */
> +/* Deprecated, use V4L2_CID_PAN_RESET and V4L2_CID_TILT_RESET */
> +#define V4L2_CID_HCENTER_DEPRECATED (V4L2_CID_BASE+22)
> +#define V4L2_CID_VCENTER_DEPRECATED (V4L2_CID_BASE+23)
But there was no warning in Documentation/feature-removal-schedule.txt
and I'm receiving reports that it's breaking userspace apps (the
gstreamer-v4l2 plugin breaks in Fedora rawhide). You can't just pull
things from the published userspace API like that.
Please can we revert the addition of _DEPRECATED to these ioctl
definitions. Perhaps we can add a runtime warning if they actually get
used? Or a compile-time warning if we can manage that?
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The v4l2_video_std_fps function has been removed by Adrian Bunk in 2004
but then its prototype re-appeared in include/media/v4l2-dev.h. Remove it.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits)
l2tp: Fix possible oops if transmitting or receiving when tunnel goes down
tcp: Fix for race due to temporary drop of the socket lock in skb_splice_bits.
tcp: Increment OUTRSTS in tcp_send_active_reset()
raw: Raw socket leak.
lt2p: Fix possible WARN_ON from socket code when UDP socket is closed
USB ID for Philips CPWUA054/00 Wireless USB Adapter 11g
ssb: Fix context assertion in ssb_pcicore_dev_irqvecs_enable
libertas: fix command size for CMD_802_11_SUBSCRIBE_EVENT
ipw2200: expire and use oldest BSS on adhoc create
airo warning fix
b43legacy: Fix controller restart crash
sctp: Fix ECN markings for IPv6
sctp: Flush the queue only once during fast retransmit.
sctp: Start T3-RTX timer when fast retransmitting lowest TSN
sctp: Correctly implement Fast Recovery cwnd manipulations.
sctp: Move sctp_v4_dst_saddr out of loop
sctp: retran_path update bug fix
tcp: fix skb vs fack_count out-of-sync condition
sunhme: Cleanup use of deprecated calls to save_and_cli and restore_flags.
xfrm: xfrm_algo: correct usage of RIPEMD-160
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc: switch /proc/led to seq_file
sparc64: IO accessors fix
Commit e9df2e8fd8fbc95c57dbd1d33dada66c4627b44c ("[IPV6]: Use
appropriate sock tclass setting for routing lookup.") also changed the
way that ECN capable transports mark this capability in IPv6. As a
result, SCTP was not marking ECN capablity because the traffic class
was never set. This patch brings back the markings for IPv6 traffic.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
When we are trying to fast retransmit the lowest outstanding TSN, we
need to restart the T3-RTX timer, so that subsequent timeouts will
correctly tag all the packets necessary for retransmissions.
Tested-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Correctly keep track of Fast Recovery state and do not reduce
congestion window multiple times during sucht state.
git://git.linux-ipv6.org/gitroot/yoshfuji/linux-2.6-fix
IPv6 UDP sockets wth IPv4 mapped address use udp_sendmsg to send the data
actually. In this case ip_flush_pending_frames should be called instead
of ip6_flush_pending_frames.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
- Allow longer lifetimes (>= 0x7fffffff/HZ) on 64bit archs
by using unsigned long.
- Shadow this arithmetic overflow workaround by introducing
helper functions: addrconf_timeout_fixup() and
addrconf_finite_timeout().
Commit 7cbca67c073263c179f605bdbbdc565ab29d801d ("[IPV6]: Support
Source Address Selection API (RFC5014)") introduced NULL dereference
of asoc to sctp_v6_get_saddr in net/sctp/ipv6.c.
Pointed out by Johann Felix Soden <johfel@users.sourceforge.net>.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
[ALSA] hda - COMPAL IFL90/JFL-92 laptop quirk
[ALSA] hda - Fix resume of auto-config mode with Realtek codecs
[ALSA] hda - Fix model for LG LS75 laptop
[ALSA] hda - Fix mic input on HP2133
[ALSA] ac97 - Fix ASUS A9T laptop output
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip:
x86, fpu: fix CONFIG_PREEMPT=y corruption of application's FPU stack
suspend-vs-iommu: prevent suspend if we could not resume
x86: section mismatch fix
x86: fix Xorg crash with xf86MapVidMem error
x86: fix pointer type warning in arch/x86/mm/init_64.c:early_memtest
x86: fix bad pmd ffff810000207xxx(9090909090909090)
x86: ioremap fix failing nesting check
x86: fix broken math-emu with lazy allocation of fpu area
x86: enable preemption in delay
x86: disable preemption in native_smp_prepare_cpus
x86: fix APIC warning on 32bit v2
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata-sff: Fix oops reported in kerneloops.org for pnp devices with no ctl
libata: kill unused constants
sata_mv: PHY_MODE4 cleanups
[libata] ata_piix: more acer short cable quirks
[libata] ACPI: Properly handle bay devices in dock stations
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6.26:
sh: Add defconfig for RSK7203.
sh: Update SE7206 defconfig.
sh: Disable 4KSTACKS on nommu.
sh: fix miscompilation of ip_fast_csum with gcc >= 4.3
sh: module.c use kernel unaligned helpers
sh/kernel/cpu/irq/intc-sh5.c build fix
Fix the math emulation that got broken with the recent lazy allocation of FPU
area. init_fpu() need to be added for the math-emulation path aswell
for the FPU area allocation.
math emulation enabled kernel booted fine with this, in the presence
of "no387 nofxsr" boot param.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: hpa@zytor.com
Cc: mingo@elte.hu
- Make ata_sff_altstatus private so nobody uses it by mistake
- Drop the 400nS delay from it
Add
ata_sff_irq_status - encapsulates the IRQ check logic
This function keeps the existing behaviour for altstatus using devices. I
actually suspect the logic was wrong before the changes but -rc isn't the
time to play with that
ata_sff_sync - ensure writes hit the device
Really we want an io* operation for 'is posted' eg ioisposted(ioaddr) so
that we can fix the nasty delay this causes on most systems.
- ata_sff_pause - 400nS delay
Ensure the command hit the device and delay 400nS
- ata_sff_dma_pause
Ensure the I/O hit the device and enforce an HDMA1:0 transition delay.
Requires altstatus register exists, BUG if not so we don't risk
corruption in MWDMA modes. (UDMA the checksum will save your backside in
theory)
The only other complication then is devices with their own handlers.
rb532 can use dma_pause but scc needs to access its own altstatus
register for internal errata workarounds so directly call the drivers own
altstatus function.
Signed-off-by: Alan Cox <alan@redhat.com>
Kill a few unused constants.
Signed-off-by: Tejun Heo <htejun@gmail.com>
The field was supposed to allow the creation of an anycast route by
assigning an anycast address to an address prefix. It was never
implemented so this field is unused and serves no purpose. Remove it.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and
nla_nest_cancel() void functions.
Return -EMSGSIZE instead of -1 if the provided message buffer is not
big enough.
