path: root/include
2015-02-03mmc: Add tracepoints of mmc block operationsKen Sumrall
Add tracepoints to record the start and end of each mmc block operation. This includes read, write, erase, secure erase, trim, secure trim1 and secure trim 2, discard and sanitize commands. Change-Id: Ic5d1cbdb9adb940d8b1a2a13c73970023575df50 Signed-off-by: Ken Sumrall <ksumrall@android.com> Signed-off-by: Iliyan Malchev <malchev@google.com> Conflicts: drivers/mmc/card/block.c drivers/mmc/core/core.c (cherry picked from commit 4de9a433c26e47d9b4a93105eb92935321100786)
2015-02-03mmc: core: new discard feature support at Samsung eMMC v4.41+.singhome_lee
Support discard feature if MID field in the CID register is 0x15, EXT.CSD[192] (device version) is 5 and Bit 0 in the EXT.CSD[64] is 1. Also removed REQ_SECURE flag check to avoid kernel hang. This patch is released from samsung. Change-Id: I4023a900680e9bca10c40311b09ed077a22617db (cherry picked from commit 4acc227edfb631d377e14911287c1b73682fc9c2) Conflicts: drivers/mmc/card/block.c
2015-02-03eMMC: Add Product revision, Sector count and driver init logban_feng
Change-Id: I89b544afbb0a109a222621a9948399fba8f77693 Change-Id: Ie366a152100a478e7811b4395f3fae9794bb1386 Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45221 Reviewed-by: Ban Feng <Ban_Feng@asus.com> Tested-by: Ban Feng <Ban_Feng@asus.com> Reviewed-by: Sam hblee <Sam_hblee@asus.com> Conflicts: drivers/mmc/core/mmc.c include/linux/mmc/card.h asdf
2015-01-16Merge remote-tracking branch 'remotes/nvidia/l4t/l4t-r16-r2' into tegra-nextMarcel Ziswiler
(tegra-l4t-r16-16.5) Conflicts: drivers/media/video/tegra_v4l2_camera.c drivers/mmc/host/sdhci.c drivers/watchdog/tegra_wdt.c include/media/tegra_v4l2_camera.h
2015-01-09media: Added Analog Devices ADV7280 video decoder driverWojciech Bieganski
2014-07-31video: tegra: nvhost: validate nvmap_handle_refBibek Basu
nvhost_job_unpin should always get the nvmap_handle_ref from rb_entry after validating handle and presence in the tree. Bug 1478467 Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/436076 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2014-06-04Added continuous mode capture supportAlex Feinman
Signed-off-by: Bryan Wu <pengw@nvidia.com> Change-Id: I67c50ff86b53a6c1001d2b688251dc55bd2eff55 Reviewed-on: http://git-master/r/419070 Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2014-05-28mmc: sdhci: add quirk for lack of 1.8v supportJeetesh Burman
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Bug 1402031 Change-Id: I7ca070a13241e6403eb2e243ebbc441a311110bc Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Jeetesh Burman <jburman@nvidia.com> Reviewed-on: http://git-master/r/346323 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2014-04-22media: added camera settings per decoderWojciech Bieganski
This commit adds settings such as: - values of horizontal/vertical active start, - enabling/disabling internal sync, to the private data of decoders: MAX9526, ADV7180, TVP5150, OV7670 and AS0260. The feature is available through *_tegra_camera_platform_data struct initialised in board-*.c files.
2014-03-31ptp: Add a method for obtaining the device index.Richard Cochran
This commit adds a method that MAC drivers may call in order to find out the device number of their associated PTP Hardware Clock. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-31ethtool: Introduce a method for getting time stamping capabilities.Richard Cochran
This commit adds a new ethtool ioctl that exposes the SO_TIMESTAMPING capabilities of a network interface. In addition, user space programs can use this ioctl to discover the PTP Hardware Clock (PHC) device associated with the interface. Since software receive time stamps are handled by the stack, the generic ethtool code can answer the query correctly in case the MAC or PHY drivers lack special time stamping features. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-31ethtool: Centralise validation of ETHTOOL_{G, S}RXFHINDIR parametersBen Hutchings
Add a new ethtool operation (get_rxfh_indir_size) to get the indirectional table size. Use this to validate the user buffer size before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get the number of RX rings, and validate the contents of the new indirection table before calling set_rxfh_indir. Remove this validation from drivers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: drivers/media/video/tegra_v4l2_camera.c reverted to current driver supporting ACM rather than CSI2 drivers/media/video/videobuf2-dma-nvmap.c drivers/video/tegra/host/Makefile
2014-01-29input: touchscreen: added platform data for Fusion touchscreenStefan Agner
Added platform data struct to define interrupt and reset GPIO. This allows to initialize the touchscreen controller inside the driver rather then in each platform and use the driver as a module.
2013-12-09mfd: stmpe: add ADC block resourcesStefan Agner
In order to use the auxiliar ADC inputs of STMPE811 devices we need to add resources for the ADC block. Also move the ADC macros from the touchscreen driver to the general header file. We will need them for the ADC driver in future.
2013-06-24hwmon: lm95245: add local critical shutdown temp hookMax Krummenacher
export access to the 'Local Shared OS and T_Crit Limit' register.
2013-04-18mmc: sdhci: add quirk for lack of 1.8v supportDaniel Drake
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-03-05media: soc_camera: add OV5650 SoC camera I2C device driverBryan Wu
OV5650 is a RAW sensor outputing Bayer RAW 8 or RAW 10 data. This driver uses SoC camera interface and supports several different resolution. Change-Id: I8075b63b42f7949a264bdef446f5ed8bdc0a9eee Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/200223 GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-03-05tegra: Make tegra_vi01_device accessibleAndrew Chew
Make it accessible outside of drivers/video/tegra. V4L2 driver needs to set some platform_data. Add suport for T20. Change-Id: I98353c2874ea28cfa0a7a5dd8a1dc4c586af4dd7 Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/200220 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-03-03Make it accessible outside of drivers/video/tegra. V4L2 driver needs toAndrew Chew
set some platform_data. Signed-off-by: Andrew Chew <achew@nvidia.com>
2013-03-03Conflicts:Marcel Ziswiler
arch/arm/mach-tegra/common.c drivers/ata/ahci-tegra.c
2013-01-25fbcon: logo: allow easy integration of a custom Linux boot logoT30_LinuxImageV2.0Beta1_20130314T20_LinuxImageV2.0_20130305T20_LinuxImageV2.0Beta2_20130129Marcel Ziswiler
This patch allows for easy integration of a custom Linux boot logo to replace the Tux' being shown by default. Use gimp or the like to create a raw PPM in your desired resolution. Reduce the number of colours in the image to 224: user@host:~$ ppmquant 224 Toradex-640x480.ppm > \ Toradex-640x480-224.ppm ppmquant: making histogram... ppmquant: 370 colors found ppmquant: choosing 224 colors... ppmquant: mapping image to new colors... Convert it from raw PPM to ASCII format: user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \ Toradex-640x480-ascii-224.ppm Copy it into the Linux sources: cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\ logo_custom_clut224.ppm Activate exclusively custom Linux logo in the kernel configuration: Device Drivers -> Graphics support -> Bootup logo -> Custom 224-color Linux logo And re-compile the kernel.
2013-01-09hwmon: lm95245: add local temp and remote critical shutdown temp hooksMarcel Ziswiler
In order to allow tighter integration with external thermal throttling code add local temperature and remote critical shutdown temperature hooks. Rename the existing hooks for clarity.
2013-01-07hwmon: lm95245: add probe callback and remote OS hooksMarcel Ziswiler
In order to allow integrating with external thermal throttling code add a probe callback and remote over-temperature shutdown hooks.
2013-01-07hwmon: lm95245: implement remote over-temperature shutdown alarm limitMarcel Ziswiler
In addition to the critical temperature alarm limit this chip features a second alarm limit called remote over-temperature shutdown ROS with a separate pin configurable as trigger output. Implement this feature and add platform data to allow configuring respective pin as output.
2012-12-17media: ov5640: Add Omnivision OV5640 supportAndrew Chew
Based on ov5642 driver. There seem to be some register differences, so forking the driver to make those changes. Change-Id: Idb4a79757cbbcd15d5456ce82a708f433faaff7a Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/169836 Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17tegra: Add nvmap_mark_global()Andrew Chew
Add this function, to be able to set the global field of an nvmap_handle while preserving the nvmap API's encapsulation mechanisms. Change-Id: I62de773a65119722f059b114e2d0e906c7e04e83 Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/169834 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17media: tegra: Tegra videobuf2Andrew Chew
This is based off of videobuf2-dma-contig, except we use Tegra's nvmap for the buffer allocations. Signed-off-by: Andrew Chew <achew@nvidia.com> Change-Id: I15e689c33ee7b4fc0aade794c78701c82483df3f Reviewed-on: http://git-master/r/145345 (cherry picked from commit 70a4f20fbdd6c2c719400d6c59ef58d845657031) Signed-off-by: Bryan Wu <pengw@nvidia.com> Change-Id: Ia0632d7fcb28415e33fbb22c48f29117d7436f1d Reviewed-on: http://git-master/r/170824 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Andrew Chew <achew@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17media: tegra: Tegra V4L2 cameraAndrew Chew
This is the Tegra V4L2 camera host driver, for Tegra2/Tegra3's VI/CSI controller. Signed-off-by: Andrew Chew <achew@nvidia.com> Change-Id: If2d9eefe53c2119c1a6ae518216e1a3c3ed216ef Reviewed-on: http://git-master/r/145346 (cherry picked from commit 5a9bfd588b755f354ae21471a3a2a3e559ca6fae) Signed-off-by: Bryan Wu <pengw@nvidia.com> Change-Id: I4db33b17efdb401938603cb2153d73bf3421ba61 Reviewed-on: http://git-master/r/170823 Reviewed-by: Andrew Chew <achew@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17tegra_camera: fix building error when disable CONFIG_TEGRA_CAMERABryan Wu
LD vmlinux.o drivers/built-in.o: In function `is_tegra_camera_on': /home/roc/Work/bug_vip/source_vibrante/kernel/include/media/ tegra_camera.h:59: multiple definition of `is_tegra_camera_on' arch/arm/mach-tegra/built-in.o:/home/roc/Work/bug_vip/source_vibrante /kernel/include/media/tegra_camera.h:59: first defined here make: *** [vmlinux.o] Error 1 Commit '678708d WAR: gr3d: limit 3d clock when camera is on' introduced a function is_tegra_camera_on(), which is dummy when CONFIG_TEGRA_CAMERA is disabled. But it will be multiple defined when includ this header file in multiple C files. So marking it as static will kill this error. Change-Id: I9dbcf1231f744c23e761d70da0bfc874fb286e4a Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/167510 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-04bluetooth: hid: make Android code conditionalMursalin Akon
Commit 7c786ce33a1b4194cb95aa1e68bc38d552eda932 introduced couple of fields, which are not used in standard bluez user space stack. However, Android bluez use them. This CL, conditionally builds the part of the code introduced in the above commit. Bug 1178960 Change-Id: I7254fe83c7fb4bbfd14e00dda3ec3a14afc1b234 Signed-off-by: Mursalin Akon <makon@nvidia.com> (cherry picked from commit e3375fd96fa5e0d7cfcda848d797cd512c12b7a6) Reviewed-on: http://git-master/r/167540 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Eric Brower <ebrower@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2012-11-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: arch/arm/mach-tegra/tegra3_usb_phy.c arch/arm/mach-tegra/usb_phy.c drivers/usb/gadget/tegra_udc.c drivers/usb/otg/Makefile drivers/video/tegra/fb.c sound/soc/tegra/tegra_pcm.c
2012-09-10WAR: gr3d: limit 3d clock when camera is onJihoon Bang
As WAR, limit 3d clock frequency and emc clock frequency when camera is on and chip is AP37. 3d clock is set to 361MHz and 437MHz is requested for emc clock with this change. This change allows 3d to request 1.1V in Core instead of 1.3V in AP37. Bug 1001262 Bug 1019309 Change-Id: I9f46f93d8da0fcf5afe05839177bf0d6e43a5840 Signed-off-by: Jihoon Bang <jbang@nvidia.com> Reviewed-on: http://git-master/r/130945 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-09-10Merge branch 'l4t/l4t-r16' into colibriMarcel Ziswiler
Merge with latest NVIDIA L4T R16. Only real conflict concerning inverted VBUS gpio support.
2012-09-04usbnet: fix skb traversing races during unlink(v2)Ming Lei
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid recursive locking in usbnet_stop()) fixes the recursive locking problem by releasing the skb queue lock before unlink, but may cause skb traversing races: - after URB is unlinked and the queue lock is released, the refered skb and skb->next may be moved to done queue, even be released - in skb_queue_walk_safe, the next skb is still obtained by next pointer of the last skb - so maybe trigger oops or other problems This patch extends the usage of entry->state to describe 'start_unlink' state, so always holding the queue(rx/tx) lock to change the state if the referd skb is in rx or tx queue because we need to know if the refered urb has been started unlinking in unlink_urbs. The other part of this patch is based on Huajun's patch: always traverse from head of the tx/rx queue to get skb which is to be unlinked but not been started unlinking. Signed-off-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: Oliver Neukum <oneukum@suse.de> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> (cherry picked from commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa) Bug 1040642 Change-Id: I1a8c248016529bebf71d540738ad4726cf3f59b7 Signed-off-by: Steve Lin <stlin@nvidia.com> Reviewed-on: http://git-master/r/128693 GVS: Gerrit_Virtual_Submit
2012-09-04ASoC: dapm: Use DAPM mutex for DAPM ops instead of codec mutexLiam Girdwood
It has now become necessary to use a DAPM mutex instead of the codec mutex to lock the DAPM operations. This is due to the recent multi component support and forth coming Dynamic PCM updates. Currently we lock DAPM operations with the codec mutex of the calling RTD context. However, DAPM operations can span the whole card context and all components. This patch updates the DAPM operations that use the codec mutex to now use the DAPM mutex PCM subclass for all DAPM ops. We also add a mutex subclass for DAPM init and PCM operations. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> (cherry picked from commit a73fb2df01866b772a48fab93401fe3edbe0b38d) Updated call sequences Bug 1039523 Change-Id: If079bbe5032971251d6b5426c752cbcc6ad6bcf5 Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com> Reviewed-on: http://git-master/r/128937 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-08-29video: tegra: host: Disable irq when clock gatingTerje Bergstrom
Disable host1x interrupts when clock gating host1x. This fixes a race where host1x interrupt was raised at the same time when host1x clock is turned off. Bug 1031724 Change-Id: I169cd5796608b8888a6b48ed99bb5da754559b2c Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/125129 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-08-28E1853 BRINGUP Linux Snor: Micron SupportBob Johnston
Expanding NOR functionality to work with ADMUX and Burst mode for Micron Support in E1853. Bug 989919 Bug 966833 - Adding fields for picking MUX vs NONMUX and picking Async, Paging, Burst mode for reads - Added run time decision between them - 1853 specific settings for Async NOR - 1852 specific settings for NOR - 1853 NOR timings changed Reviewed-on: http://git-master/r/122286 (cherry picked from commit a242e7194c7de559d22fe5b275a8782086f10e50) Change-Id: I79de1d52d4c7199c83b380c2fa6d8cae6b35f09d Signed-off-by: Bob Johnston <BJohnston@nvidia.com> Reviewed-on: http://git-master/r/124946 Tested-by: Bob Johnston <bjohnston@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-08-27drivers: mfd: Add support for TI aic3262 driverManoj Gangwal
Bug 1034241 Change-Id: I5607d53cf0bdd25c5e2b8447cd7e676b64cd32a2 Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/125169 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
2012-08-21media: video: tegra: ar0832: Add slew rate supportNaren Bhat
Add slew rate support for AR0832 focuser. bug 1028733 Change-Id: I4fd0245fad7f7c820fc30a7c4bfc970d52903da6 Signed-off-by: Naren Bhat <nbhat@nvidia.com> Reviewed-on: http://git-master/r/124695 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Jon Mayo <jmayo@nvidia.com> Reviewed-by: Frank Chen <frankc@nvidia.com> Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
2012-08-16USB: gadget: f_accessory: Add support for HID input devicesRakesh Bodla
Bug 1026047 Signed-off-by: Mike Lockwood <lockwood@google.com> (cherry picked from commit 7a3d01af4f04950a86a18f5a439f1802d8093650) Conflicts: drivers/usb/gadget/f_accessory.c Change-Id: I30bc02a1bcf636967d56370db83578f49f0e7514 Signed-off-by: Rakesh Bodla <rbodla@nvidia.com> Reviewed-on: http://git-master/r/123342 Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2012-08-16Add ACCESSORY_SET_AUDIO_MODE control request and ioctlMike Lockwood
The control request will be used by the host to enable/disable USB audio and the ioctl will be used by userspace to read the audio mode Bug 1026047 Signed-off-by: Mike Lockwood <lockwood@google.com> (cherry picked from commit 3e1ff6142761eef148c667e540381d1fbc437d4f) Signed-off-by: Rakesh Bodla <rbodla@nvidia.com> Change-Id: I5f449de230ca8f44e2dae30a0f87772310b68f20 Reviewed-on: http://git-master/r/123341 Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2012-08-15video: tegra: nvmap: Add support for zeroed pagesAlex Waterman
Add support to alloc zeroed pages for user space alloc requests. Also define a config option to force userspace allocation requests to be zeroed. Change-Id: I75d3b2bc36e808f1470b423578ec4cba99e0f967 Signed-off-by: Alex Waterman <alexw@nvidia.com> Reviewed-on: http://git-master/r/122549 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-08-13tracing: Clock lock trace eventsAntti P Miettinen
Add tracing for clock lock/unlock operations. Bug 960307 Change-Id: Id5c2d8be25900bc701e5dcd73f87c068ab6e5894 Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-on: http://git-master/r/122666 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-08-13workqueue: CPU hotplug keep idle workersMitch Luban
This change merges two patchsets. The first set, containing 6 patches, reimplements WQ_HIGHPRI to use a seperate worker_pool. gcwq->pools[0] is used for normal priority work and pools[1] for high priority. The second patchset contains 9 patches and reimplements CPU hotplug to keep idle workers. Updates workqueue CPU hotplug path to use a disassociated global_cwq, which runs as an unbound one (WQ_UNBOUND). While this requires rebinding idle workers, overall hotplug path is much simpler. Original patchset: http://thread.gmane.org/gmane.linux.kernel/1329164 Bug 978010 Change-Id: Ic66ec8848a8d111b5278e63ef6a410846dfd8fcc Signed-off-by: Mitch Luban <mluban@nvidia.com> Reviewed-on: http://git-master/r/118387 Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-08-08mfd: add support for MAXIM77665Laxman Dewangan
Maxim 77665 is Companion PMIC for Smartphones and Tablets. This support Flash, Fuel Gauge, Haptic, MUIC and battery charging. This patch add the core driver for interface for accessing resgister of the device. Change-Id: I7d5dff8c222147b2ca1cd21a652f593cd7294601 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/121587 Reviewed-by: Automatic_Commit_Validation_User
2012-08-07mfd: tps80031: remove support for subdevs registrationLaxman Dewangan
The mfd sub devices should get added through the mfd_add_devices() not through legacy style of adding sub devices. Change-Id: If275d41629d799f1e22d95fd442ebe7d3ace448e Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/121137 Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-08-07power: tps80031: battery-charger: register as mfd sub deviceLaxman Dewangan
Register battery charger driver of TPS80031 as mfd sub driver in place of adding it as a sub devices. This is inline with the mfd driver policy. Change-Id: I8cff39f5c9b22434f7c5b9d4ed9f3865ff4c0001 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/121135 Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-08-07power: tps80031: battery-gauge: register as mfd sub deviceLaxman Dewangan
Register battery gauge driver of TPS80031 as mfd sub driver in place of adding it as a sub devices. This is inline with the mfd driver policy. Change-Id: I15765be19fc138695de2d813e5fa025400747c86 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/121134 Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-08-07rtc: tps80031: register as mfd sub deviceLaxman Dewangan
register RTC driver of TPS80031 as mfd sub driver in place of adding it as a sub devices. This is inline with the mfd driver policy. Change-Id: I2f9c13478a1e85c9670dd7bc576ec761f2e24733 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/121133 Reviewed-by: Automatic_Commit_Validation_User
