Bug 992947
Change-Id: I0d1ecc9f8f042956cbe631779260a38573936616
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/105776
GVS: Gerrit_Virtual_Submit
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Add a macro of_match_ptr() that allows the .of_match_table
entry in the driver structures to be assigned without having
an #ifdef xxx NULL for the case that OF is not enabled
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
(cherry picked from commit 3a1e362e3f3cd571b3974b8d44b8e358ec7a098c)
Change-Id: Ib0365629efb6f203f8d87b487f66f99417e71bb3
Reviewed-on: http://git-master/r/105929
As gpio support for tps65910 is on gpio driver, registering
gpio support as the mfd sub devices instead of calling gpio_init()
from the core probe.
(cherry picked from commit 32df986e985921386b75b4bd1117102bf65fe095)
Change-Id: I631596313528ab192d7d8c2f376965ccc989c313
Reviewed-on: http://git-master/r/105926
This change removes the read/write callback functions in favor of common
regmap accessors inside the header file. This change also makes use of
regmap_read/write for single register access which maps better onto what this
driver actually needs.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
(Cherry-pick from mainline
3f7e82759c692df473675ed06fb90b20f1f225c3)
Change-Id: Ida79b196acf65ed14ff9fd2cc1f7c0048f99ba2b
Reviewed-on: http://git-master/r/105922
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
Adding support for device sleep through the external input control
signal "SLEEP".
Changing the SLEEP signal state can switch the device into SLEEP and
ACTIVE state.
Also adding sleep configuration for different resources so that they
should be keep on during sleep state of device.
(Cherry-picked from mainline
201cf052810d20814a77ca0e0045a2c1a3508a1f)
Change-Id: Iec18bfcc7a1df6442e833dccaa1d39407918f710
Reviewed-on: http://git-master/r/105920
Change the mechanism of enabling the force PWM mode through
regulator set mode. This can be dynamically configured now.
In the REGULATOR_MODE_FAST the force PWM is enabled and in
REGULATOR_MODE_NORMAL the force PWM is disabled.
Cherry-picked from mainline commit 9a00630
Change-Id: I39a77dbe5d0c4c2a5b81dbfe51163a65894bc98c
Reviewed-on: http://git-master/r/105832
Bug 949219
Change-Id: I91a67d30869e9800c483f112d58b9f76e2dbe361
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103534
Reviewed-by: Simone Willett <swillett@nvidia.com>
The PMIC device RC5T583 from RICOH supports 8 gpios.
Adding gpio driver for this device to access the pins
control through gpio library.
[grant.likely: slight cosmetic changes]
e9fe32bcadb8a7a40411d77f168abd45941b049b)
Change-Id: Id11f0dec229a92ce0ddcf606376ff83b6e14ca90
Reviewed-on: http://git-master/r/105885
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
The combination of commit 1b1247dd75aa5cf5fae54a3bec7280046e9c7957
"mfd: Add support for RICOH PMIC RC5T583"
and commit 6ffc3270210efa2bea526953a142ffc908f5bd86
"regulator: Add support for RICOH PMIC RC5T583 regulator"
are causing the i386 allmodconfig builds to fail with this:
ERROR: "rc5t583_update" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_set_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_clear_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_read" [drivers/regulator/rc5t583-regulator.ko] undefined!
and this:
ERROR: "rc5t583_ext_power_req_config" [drivers/regulator/rc5t583-regulator.ko] undefined!
For the 1st four, make the simple ops static inline, instead of
polluting the namespace with trivial exports. For the last one,
add an EXPORT_SYMBOL.
(cherry picked from commit 82ea267f7dc853a5e6a724916a70a10656efdfc2)
Change-Id: I7f03cc5c0005883eb8355170cdc7996a9c392091
Reviewed-on: http://git-master/r/105878
The RC5T583 PMIC from RICOH consists of 4 DCDC and 10
LDOs. This driver supports the control of different
regulator output through regulator interface.
This driver depends on MFD driver of RC5T583 and uses
mfd rc5t583 apis to communicate to device for accessing
different device's registers.
(Cherry-picked from mainline commit
6ffc3270210efa2bea526953a142ffc908f5bd86)
Change-Id: If6bcc9c987fc97ff6f0c61e53de715cd84d0151b
Reviewed-on: http://git-master/r/105877
Bug 986402
Change-Id: Id12540e31f8d7d9a04d764ed012310a685eafb8d
Signed-off-by: Tom Cherry <tcherry@nvidia.com>
Reviewed-on: http://git-master/r/104269
Change default PM QoS request value for minimum online cpus
parameter from 1 to 0. This is consistent with all other
PM_QOS_MAX type parameters, and allow to differentiate request
for 1 CPU and "no request".
Change-Id: I548449d0b7a443b77f7f065e1e1f10dffc5587ed
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/102119
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Satya Popuri <spopuri@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Implements a group hold so that the gain, frame length, and
coarse time can all be written in one ioctl call
Also fixes AEC manual control register value
Also implements bulk i2c send in the same way as ov5650
Bug 953910
Change-Id: Iaa2e8ac6c0156564920696afaa099321db6314f6
Signed-off-by: Pablo Ceballos <pceballos@nvidia.com>
Reviewed-on: http://git-master/r/94380
Reviewed-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Patrick Shehane <pshehane@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Implement per channel counter for jobs in each priority level. If
there are jobs active with higher priority than the one being
submitted, throttle.
Bug 926690
Change-Id: I5fed341e3f248325873b31d1c53bf57bf0a78074
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/104939
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Remove nvmap_pin_array() and nvmap_patch_word() and their utility
functions.
Bug 965206
Change-Id: I217a427934b0b99b5252b33ab3ac4eaaa8c7e076
Reviewed-on: http://git-master/r/104451
Replace usage of nvmap_pinarray_elem with own nvhost_reloc and
nvhost_reloc_shift structs.
Bug 965206
Change-Id: I90618d8a34d79156d8880d9925dadbf416353811
Reviewed-on: http://git-master/r/104450
Modify USB structures of platform data. Based on the new
platform data structures modifying the initialization in
board files.
Bug 887361
Change-Id: Ie6347a078c9a596a4debe21a353e127ddde35220
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103597
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
- Implement new focuser ad5816 driver.
- Complies to latest NVC framework.
Bug 947792
Change-Id: I1661de027062d2a9b4112fd24dc255d810c7afa0
Signed-off-by: Sudhir Vyas <svyas@nvidia.com>
Reviewed-on: http://git-master/r/103131
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
- remove usage of custom interface of nvmap to patch the relocs and
and pin the gathers/relocs
- convert code that references nvmap_handle to nvmap_handle_ref
- add logic to pin and map only unique gathers and relocs
- rename nvhost_channel_gather to nvhost_job_gather, because it's
used in nvhost_job code only
Bug 965206
Change-Id: Iaa7fbac9e4a7b08c0a7c1e184b8dd3566e1edfe2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/95299
Avoid multiple CONFIG_TEGRA_NVMAP ifdefs.
Change-Id: Ic186a8203d8b2291d3d39ce8b612b33bee16f531
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/103937
Add id for nct1008 compatible thermal sensor:
NCT72
Bug 961970
Change-Id: I792af664f73b6d1c8317a35c66330cf571cf3aba
Reviewed-on: http://git-master/r/100465
Signed-off-by: Chandler Zhang <chazhang@nvidia.com>
[danifu@nvidia.com: resolved conflicits in nct1008.c]
Signed-off-by: Daniel Fu <danifu@nvidia.com>
Reviewed-on: http://git-master/r/103581
- currently, function pointers are inside nvhost_device
- these functions abstract the device specific implementation
of a functionality per SoC
- move them to nvhost_driver so that nvhost_device can be
instantiated from arch code using board files/device trees
- add support to use single driver for multiple devices using
concept of id_table. this will be useful in supporting
multiple SoC devices binding single driver
- also add some notes about how device name is expected
Bug 871237
Change-Id: I4c75d7121d26c3bdc50f058e0d144d89ca0edbd9
Reviewed-on: http://git-master/r/100985
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Export nvmap_duplicate_handle_id() for usage by other drivers. It is
already being used in nvavp and tegradc, and nvhost needs it to be
able to move the relocation code to inside nvhost.
Bug 965206
Change-Id: I3f818d1faa967886e834aa457a99dfdb61bc6b85
Reviewed-on: http://git-master/r/103587
Adds a global alpha parameter to each window. It provides a default
alpha value for pixel formats that do not include alpha.
Change-Id: I5465864877a727b4daed0eb32fb8219e2ccb663e
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/101806
To prepare for kernel modularization, nvmap include file need to be
moved from mach-tegra/include to kernel/include.
Bug 854182
Change-Id: I9eab484830d114873f15a99fb93355aac3405709
Reviewed-on: http://git-master/r/102719
Enable output discharge always to have faster ramp-down
time.
bug 981330
Change-Id: I0a00ab38e9be631a58bc8b11148be5c3c508d119
Reviewed-on: http://git-master/r/102882
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Add EMC clock rate control to tegra_camera ioctl.
This change allows user space to change EMC clock requirement
for camera based on use case and resolution.
For example, video recording use case needs more than double
memory bandwidth of preview use case.
Bug 964635
Change-Id: Ibe5a77a810869b53b6e057f2ee62ebb96997c2f4
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/101274
Allow clk API users to simplify their cleanup paths by providing a
managed version of clk_get() and clk_put().
a8a97db984bdc5e89d42e41891543d2daaf314cb
Change-Id: Ib36c0c82063928937166b6014fca92025bc83878
Reviewed-on: http://git-master/r/102860
This driver supports ivoltage regulator driver for MAX8973
voltage regulator chip. The MAX8973 high-efficiency, three-phase,
DC-DC step-down switching regulator delivers up to 9A of
output current.
bug 981355
Change-Id: I6e4ff62139face4e47e2be269554a64c2654e74b
Reviewed-on: http://git-master/r/102148
The regulator module consists of 1 DCDC. The output voltage
is configurable and is meant for supply power to the core
voltage of Soc.
Change-Id: Ic62d100a588f7b6f1b30c11fd44a925c97393069
Reviewed-on: http://git-master/r/100653
A new trace event is added for tracing cpu suspend start and end
Change-Id: I2506e3aed0692c44fb4325e9d381cea53228b0c3
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Reviewed-on: http://git-master/r/101748
add ov5640 yuv sensor support - initial.
bug 921322
Change-Id: I813afa8963e39afe475f9fdd43152cfaf1a16ae1
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/99506
Add trace events for updating the syncpt value from hardware, and
wait check.
Change-Id: If17de153ae36c0665fe0af2f405dfe42f7fcd656
Reviewed-on: http://git-master/r/101524
Reviewed-by: Ken Adams <kadams@nvidia.com>
Add context switch to the ftrace dump.
Change-Id: I5df032273982b919fb94263cff38d8b8b6b6be45
Reviewed-on: http://git-master/r/101523
This implementation sets governor for a cpu using existing
cpufreq interfaces.
bug 871958
Change-Id: Ic4e7e2a2b0babaf1829b559b5db211666d449b86
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/97939
bug 949219
Change-Id: Ied38dc0ff7ade8b15561747cde6d552f2597e9e6
Reviewed-on: http://git-master/r/92307
The sequence of read fuse id is:
1. write to OTP index register 0x3d00.
2. read out byte from ox3d04.
3. repeat step 1 to the next byte with its index respectively.
also fixed ov5650_read_reg always fail issue.
bug 957657
Change-Id: I649a7765320d0d4be8111a7f523d8487b872b620
Reviewed-on: http://git-master/r/98330
Reviewed-by: Wei Chen <wechen@nvidia.com>
Change-Id: Ib16ea10bf1acc2c7171935429635502aee80f3f4
Signed-off-by: Rahul Mittal <rmittal@nvidia.com>
Reviewed-on: http://git-master/r/99072
Reviewed-by: Nikesh Oswal <noswal@nvidia.com>
Update correct status to fuel-gauge driver
when charger cable is disconnected.
Bug 960318
Change-Id: I4c3ad2030ada7c06825e80a3eb4697b669fe7cb6
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/98719
- Abort initialization if an I2C error to avoid excessive load on the I2C bus
since it is heavily used during initialization.
- Updated to the latest NVC framework.
- Added feature that allows for the key focus points to be set at runtime
and the relative positions recalculated.
Bug 929133
Bug 938934
Change-Id: Ida4ab885bf35057ae6df131e3ec3587a891a7dc9
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/93944
Sometimes 3D unit comes up with incorrect scissor configuration.
Earlier patch added the scissor registers to the context save list,
but that did not solve the problem. Remove the extra registers, and
reset 3D after powering it up.
Bug 939307
Change-Id: Id795f2d99ec3c6b907da2785b1816ce753af7a3f
Reviewed-on: http://git-master/r/87654
Reviewed-by: Graziano Misuraca <gmisuraca@nvidia.com>
Tested-by: Graziano Misuraca <gmisuraca@nvidia.com>
There are a couple of issues found in tegra_camera.
1. clock enable/disable is controlled by user space.
-> If client process crashes, there is no way to disable clock.
2. power enable/disable is associated with clock enable.
-> There is no reason to relate power with clock.
-> There is only one regulator for this driver.
-> As same as #1, it may leave power up when client process crashes.
3. driver allows multiple clients to access.
-> This is not the case for this driver.
This changes addresses the problems described above.
Bug 948780
Change-Id: Ie534771327175f56cf0e138f1c07096ddba470a8
Reviewed-on: http://git-master/r/92386
Reviewed-by: David Schalig <dschalig@nvidia.com>
- Add valid flag to GPIO runtime structure so that scratch
flag can be used for other purposes.
Bug 852480
Change-Id: Ie5e36b733fe67b504e83efcf606be264725c987c
Reviewed-on: http://git-master/r/94156
Add nvavp_force_clock_stay_on ioctl which provides way for user-mode driver
to stay on AVP clock state. This change is to fix LP0 resume fail during
Widevine playback. Since VDE/BSEV clocks are used by OTF driver in secure
world during closing sesssion, the change makes VDE/BSEV clocks running
while entering LP0.
Bug 960130
Bug 961015
Change-Id: I7eaaa9a33537a72b6ae0a016372bc513fef532e2
Reviewed-on: http://git-master/r/96302
Reviewed-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Tested-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Reviewed-on: http://git-master/r/92819
Addition of reglator interface to detect the usb cable
plug/unplug detection.
Bug 961166
Bug 966874
Change-Id: Ida297bc39df9aca8cffe60c29bc24f2d32819f56
Reviewed-on: http://git-master/r/96440
a6ecc18e92 removed the sources for the interrupt_key driver, this
removes the include file as well. There are no in-tree users of this
header file.
Change-Id: I90a8c25e8aed5daa6480407b095ebb82d83f7137
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/96262
0cb53fae65 removed the sources for the gpio-switch-regulator, but missed
the header file. There are no in-tree users of this header file.
Change-Id: Ib497e97b9374025c18c7b20a2006d0c66e2b68a7
Reviewed-on: http://git-master/r/96258
This patch introduces the module_i2c_driver macro which is a convenience macro
for I2C driver modules similar to module_platform_driver. It is intended to be
used by drivers which init/exit section does nothing but register/unregister
the I2C driver. By using this macro it is possible to eliminate a few lines of
boilerplate code per I2C driver.
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Jean Delvare <khali@linux-fr.org>
(cherry picked from mainline commit
7c92784a546d2945b6d6973a30f7134be78eb7a4)
Change-Id: Ic4ea530ae9c00de75e154eba0f74ff93712c81cf
Reviewed-on: http://git-master/r/95641
This patch generalizes the module_platform_driver macro and introduces a new
module_driver macro. The module_driver macro takes a driver name, a register
and a unregister function for this driver type. Using these it construct the
module init and exit sections which register and unregister the driver. Since
such init/exit sections are commonly found in drivers this macro can be used
to eliminate a lot of boilerplate code.
The macro is not intended to be used by driver modules directly, instead it
should be used to generate bus specific macros for registering drivers like
the module_platform_driver macro.
Acked-by: Jonathan Cameron <jic23@kernel.org>
907d0ed1c84114d4e8dafd66af982515d3739c90
Change-Id: Ib83ecc2ca10c53c84ab8ffbc94ee8212d72c2993
Reviewed-on: http://git-master/r/95640
