path: root/include
2009-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: dm snapshot: extend exception store functions dm snapshot: split out exception store implementations dm snapshot: rename struct exception_store dm snapshot: separate out exception store interface dm mpath: move trigger_event to system workqueue dm: add name and uuid to sysfs dm table: rework reference counting dm: support barriers on simple devices dm request: extend target interface dm request: add caches dm ioctl: allow dm_copy_name_and_uuid to return only one field dm log: ensure log bitmap fits on log device dm log: move region_size validation dm log: avoid reinitialising io_req on every operation dm: consolidate target deregistration error handling dm raid1: fix error count dm log: fix dm_io_client leak on error paths dm snapshot: change yield to msleep dm table: drop reference at unbind
2009-01-06dm: support barriers on simple devicesAndi Kleen
Implement barrier support for single device DM devices This patch implements barrier support in DM for the common case of dm linear just remapping a single underlying device. In this case we can safely pass the barrier through because there can be no reordering between devices. NB. Any DM device might cease to support barriers if it gets reconfigured so code must continue to allow for a possible -EOPNOTSUPP on every barrier bio submitted. - agk Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm request: extend target interfaceKiyoshi Ueda
This patch adds the following target interfaces for request-based dm. map_rq : for mapping a request rq_end_io : for finishing a request busy : for avoiding performance regression from bio-based dm. Target can tell dm core not to map requests now, and that may help requests in the block layer queue to be bigger by I/O merging. In bio-based dm, this behavior is done by device drivers managing the block layer queue. But in request-based dm, dm core has to do that since dm core manages the block layer queue. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm: consolidate target deregistration error handlingMikulas Patocka
Change dm_unregister_target to return void and use BUG() for error reporting. dm_unregister_target can only fail because of programming bug in the target driver. It can't fail because of user's behavior or disk errors. This patch changes unregister_target to return void and use BUG if someone tries to unregister non-registered target or unregister target that is in use. This patch removes code duplication (testing of error codes in all dm targets) and reports bugs in just one place, in dm_unregister_target. In some target drivers, these return codes were ignored, which could lead to a situation where bugs could be missed. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-05Merge branch 'for-next' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-next' of git://git.o-hand.com/linux-mfd: (30 commits) mfd: Fix section mismatch in da903x mfd: move drivers/i2c/chips/menelaus.c to drivers/mfd mfd: move drivers/i2c/chips/tps65010.c to drivers/mfd mfd: dm355evm msp430 driver mfd: Add missing break from wm3850-core mfd: Add WM8351 support mfd: Support configurable numbers of DCDCs and ISINKs on WM8350 mfd: Handle missing WM8350 platform data mfd: Add WM8352 support mfd: Use irq_to_desc in twl4030 code power_supply: Add Dialog DA9030 battery charger driver mfd: Dialog DA9030 battery charger MFD driver mfd: Register WM8400 codec device mfd: Pass driver_data onto child devices mfd: Fix twl4030-core.c build error mfd: twl4030 regulator bug fixes mfd: twl4030: create some regulator devices mfd: twl4030: cleanup symbols and OMAP dependency mfd: twl4030: simplified child creation code power_supply: Add battery health reporting for WM8350 ...
2009-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: module: convert to stop_machine_create/destroy. stop_machine: introduce stop_machine_create/destroy. parisc: fix module loading failure of large kernel modules module: fix module loading failure of large kernel modules for parisc module: fix warning of unused function when !CONFIG_PROC_FS kernel/module.c: compare symbol values when marking symbols as exported in /proc/kallsyms. remove CONFIG_KMOD
2009-01-05Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: swiotlb: Don't include linux/swiotlb.h twice in lib/swiotlb.c intel-iommu: fix build error with INTR_REMAP=y and DMAR=n swiotlb: add missing __init annotations
2009-01-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (22 commits) HID: fix error condition propagation in hid-sony driver HID: fix reference count leak hidraw HID: add proper support for pensketch 12x9 tablet HID: don't allow DealExtreme usb-radio be handled by usb hid driver HID: fix default Kconfig setting for TopSpeed driver HID: driver for TopSeed Cyberlink quirky remote HID: make boot protocol drivers depend on EMBEDDED HID: avoid sparse warning in HID_COMPAT_LOAD_DRIVER HID: hiddev cleanup -- handle all error conditions properly HID: force feedback driver for GreenAsia 0x12 PID HID: switch specialized drivers from "default y" to !EMBEDDED HID: set proper dev.parent in hidraw HID: add dynids facility HID: use GFP_KERNEL in hid_alloc_buffers HID: usbhid, use usb_endpoint_xfer_int HID: move usbhid flags to usbhid.h HID: add n-trig digitizer support HID: add phys and name ioctls to hidraw HID: struct device - replace bus_id with dev_name(), dev_set_name() HID: automatically call usbhid_set_leds in usbhid driver ...
2009-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmwLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: (27 commits) GFS2: Use DEFINE_SPINLOCK GFS2: Fix use-after-free bug on umount (try #2) Revert "GFS2: Fix use-after-free bug on umount" GFS2: Streamline alloc calculations for writes GFS2: Send useful information with uevent messages GFS2: Fix use-after-free bug on umount GFS2: Remove ancient, unused code GFS2: Move four functions from super.c GFS2: Fix bug in gfs2_lock_fs_check_clean() GFS2: Send some sensible sysfs stuff GFS2: Kill two daemons with one patch GFS2: Move gfs2_recoverd into recovery.c GFS2: Fix "truncate in progress" hang GFS2: Clean up & move gfs2_quotad GFS2: Add more detail to debugfs glock dumps GFS2: Banish struct gfs2_rgrpd_host GFS2: Move rg_free from gfs2_rgrpd_host to gfs2_rgrpd GFS2: Move rg_igeneration into struct gfs2_rgrpd GFS2: Banish struct gfs2_dinode_host GFS2: Move i_size from gfs2_dinode_host and rename it to i_disksize ...
2009-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (44 commits) qlge: Fix sparse warnings for tx ring indexes. qlge: Fix sparse warning regarding rx buffer queues. qlge: Fix sparse endian warning in ql_hw_csum_setup(). qlge: Fix sparse endian warning for inbound packet control block flags. qlge: Fix sparse warnings for byte swapping in qlge_ethool.c myri10ge: print MAC and serial number on probe failure pkt_sched: cls_u32: Fix locking in u32_change() iucv: fix cpu hotplug af_iucv: Free iucv path/socket in path_pending callback af_iucv: avoid left over IUCV connections from failing connects af_iucv: New error return codes for connect() net/ehea: bitops work on unsigned longs Revert "net: Fix for initial link state in 2.6.28" tcp: Kill extraneous SPLICE_F_NONBLOCK checks. tcp: don't mask EOF and socket errors on nonblocking splice receive dccp: Integrate the TFRC library with DCCP dccp: Clean up ccid.c after integration of CCID plugins dccp: Lockless integration of CCID congestion-control plugins qeth: get rid of extra argument after printk to dev_* conversion qeth: No large send using EDDP for HiperSockets. ...
2009-01-05Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Fix on resume, now preserves user policy min/max. [CPUFREQ] Add Celeron Core support to p4-clockmod. [CPUFREQ] add to speedstep-lib additional fsb values for core processors [CPUFREQ] Disable sysfs ui for p4-clockmod. [CPUFREQ] p4-clockmod: reduce noise [CPUFREQ] clean up speedstep-centrino and reduce cpumask_t usage
2009-01-05Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: (138 commits) ocfs2: Access the right buffer_head in ocfs2_merge_rec_left. ocfs2: use min_t in ocfs2_quota_read() ocfs2: remove unneeded lvb casts ocfs2: Add xattr support checking in init_security ocfs2: alloc xattr bucket in ocfs2_xattr_set_handle ocfs2: calculate and reserve credits for xattr value in mknod ocfs2/xattr: fix credits calculation during index create ocfs2/xattr: Always updating ctime during xattr set. ocfs2/xattr: Remove extend_trans call and add its credits from the beginning ocfs2/dlm: Fix race during lockres mastery ocfs2/dlm: Fix race in adding/removing lockres' to/from the tracking list ocfs2/dlm: Hold off sending lockres drop ref message while lockres is migrating ocfs2/dlm: Clean up errors in dlm_proxy_ast_handler() ocfs2/dlm: Fix a race between migrate request and exit domain ocfs2: One more hamming code optimization. ocfs2: Another hamming code optimization. ocfs2: Don't hand-code xor in ocfs2_hamming_encode(). ocfs2: Enable metadata checksums. ocfs2: Validate superblock with checksum and ecc. ocfs2: Checksum and ECC for directory blocks. ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: inotify: fix type errors in interfaces fix breakage in reiserfs_new_inode() fix the treatment of jfs special inodes vfs: remove duplicate code in get_fs_type() add a vfs_fsync helper sys_execve and sys_uselib do not call into fsnotify zero i_uid/i_gid on inode allocation inode->i_op is never NULL ntfs: don't NULL i_op isofs check for NULL ->i_op in root directory is dead code affs: do not zero ->i_op kill suid bit only for regular files vfs: lseek(fd, 0, SEEK_CUR) race condition
2009-01-05mm lockless pagecache barrier fixNick Piggin
An XFS workload showed up a bug in the lockless pagecache patch. Basically it would go into an "infinite" loop, although it would sometimes be able to break out of the loop! The reason is a missing compiler barrier in the "increment reference count unless it was zero" case of the lockless pagecache protocol in the gang lookup functions. This would cause the compiler to use a cached value of struct page pointer to retry the operation with, rather than reload it. So the page might have been removed from pagecache and freed (refcount==0) but the lookup would not correctly notice the page is no longer in pagecache, and keep attempting to increment the refcount and failing, until the page gets reallocated for something else. This isn't a data corruption because the condition will be detected if the page has been reallocated. However it can result in a lockup. Linus points out that ACCESS_ONCE is also required in that pointer load, even if it's absence is not causing a bug on our particular build. The most general way to solve this is just to put an rcu_dereference in radix_tree_deref_slot. Assembly of find_get_pages, before: .L220: movq (%rbx), %rax #* ivtmp.1162, tmp82 movq (%rax), %rdi #, prephitmp.1149 .L218: testb $1, %dil #, prephitmp.1149 jne .L217 #, testq %rdi, %rdi # prephitmp.1149 je .L203 #, cmpq $-1, %rdi #, prephitmp.1149 je .L217 #, movl 8(%rdi), %esi # <variable>._count.counter, c testl %esi, %esi # c je .L218 #, after: .L212: movq (%rbx), %rax #* ivtmp.1109, tmp81 movq (%rax), %rdi #, ret testb $1, %dil #, ret jne .L211 #, testq %rdi, %rdi # ret je .L197 #, cmpq $-1, %rdi #, ret je .L211 #, movl 8(%rdi), %esi # <variable>._count.counter, c testl %esi, %esi # c je .L212 #, (notice the obvious infinite loop in the first example, if page->count remains 0) Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05inotify: fix type errors in interfacesMichael Kerrisk
The problems lie in the types used for some inotify interfaces, both at the kernel level and at the glibc level. This mail addresses the kernel problem. I will follow up with some suggestions for glibc changes. For the sys_inotify_rm_watch() interface, the type of the 'wd' argument is currently 'u32', it should be '__s32' . That is Robert's suggestion, and is consistent with the other declarations of watch descriptors in the kernel source, in particular, the inotify_event structure in include/linux/inotify.h: struct inotify_event { __s32 wd; /* watch descriptor */ __u32 mask; /* watch mask */ __u32 cookie; /* cookie to synchronize two events */ __u32 len; /* length (including nulls) of name */ char name[0]; /* stub for possible name */ }; The patch makes the changes needed for inotify_rm_watch(). Signed-off-by: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Robert Love <rlove@google.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-05add a vfs_fsync helperChristoph Hellwig
Fsync currently has a fdatawrite/fdatawait pair around the method call, and a mutex_lock/unlock of the inode mutex. All callers of fsync have to duplicate this, but we have a few and most of them don't quite get it right. This patch adds a new vfs_fsync that takes care of this. It's a little more complicated as usual as ->fsync might get a NULL file pointer and just a dentry from nfsd, but otherwise gets afile and we want to take the mapping and file operations from it when it is there. Notes on the fsync callers: - ecryptfs wasn't calling filemap_fdatawrite / filemap_fdatawait on the lower file - coda wasn't calling filemap_fdatawrite / filemap_fdatawait on the host file, and returning 0 when ->fsync was missing - shm wasn't calling either filemap_fdatawrite / filemap_fdatawait nor taking i_mutex. Now given that shared memory doesn't have disk backing not doing anything in fsync seems fine and I left it out of the vfs_fsync conversion for now, but in that case we might just not pass it through to the lower file at all but just call the no-op simple_sync_file directly. [and now actually export vfs_fsync] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-05jbd2: Add buffer triggersJoel Becker
Filesystems often to do compute intensive operation on some metadata. If this operation is repeated many times, it can be very expensive. It would be much nicer if the operation could be performed once before a buffer goes to disk. This adds triggers to jbd2 buffer heads. Just before writing a metadata buffer to the journal, jbd2 will optionally call a commit trigger associated with the buffer. If the journal is aborted, an abort trigger will be called on any dirty buffers as they are dropped from pending transactions. ocfs2 will use this feature. Initially I tried to come up with a more generic trigger that could be used for non-buffer-related events like transaction completion. It doesn't tie nicely, because the information a buffer trigger needs (specific to a journal_head) isn't the same as what a transaction trigger needs (specific to a tranaction_t or perhaps journal_t). So I implemented a buffer set, with the understanding that journal/transaction wide triggers should be implemented separately. There is only one trigger set allowed per buffer. I can't think of any reason to attach more than one set. Contrast this with a journal or transaction in which multiple places may want to watch the entire transaction separately. The trigger sets are considered static allocation from the jbd2 perspective. ocfs2 will just have one trigger set per block type, setting the same set on every bh of the same type. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Export dquot_alloc() and dquot_destroy() functionsJan Kara
These are default functions for creating and destroying quota structures and they should be used from filesystems. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Unexport dqblk_v1.h and dqblk_v2.hJan Kara
Unexport header files dqblk_v[12].h since except for quota format ID they don't contain information userspace should be interested in. Move ID definitions to quota.h. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05jbd2: Add BH_JBDPrivateStartMark Fasheh
Add this so that file systems using JBD2 can safely allocate unused b_state bits. In this case, we add it so that Ocfs2 can define a single bit for tracking the validation state of a buffer. Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Implement function for scanning active dquotsJan Kara
OCFS2 needs to scan all active dquots once in a while and sync quota information among cluster nodes. Provide a helper function for it so that it does not have to reimplement internally a list which VFS already has. Moreover this function is probably going to be useful for other clustered filesystems if they decide to use VFS quotas. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Add helpers to allow ocfs2 specific quota initialization, freeing and ↵Jan Kara
recovery OCFS2 needs to peek whether quota structure is already in memory so that it can avoid expensive cluster locking in that case. Similarly when freeing dquots, it checks whether it is the last quota structure user or not. Finally, it needs to get reference to dquot structure for specified id and quota type when recovering quota file after crash. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Update version numberJan Kara
Increase reported version number of quota support since quota core has changed significantly. Also remove __DQUOT_NUM_VERSION__ since nobody uses it. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Keep which entries were set by SETQUOTA quotactlJan Kara
Quota in a clustered environment needs to synchronize quota information among cluster nodes. This means we have to occasionally update some information in dquot from disk / network. On the other hand we have to be careful not to overwrite changes administrator did via SETQUOTA. So indicate in dquot->dq_flags which entries have been set by SETQUOTA and quota format can clear these flags when it properly propagated the changes. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Allow negative usage of space and inodesJan Kara
For clustered filesystems, it can happen that space / inode usage goes negative temporarily (because some node is allocating another node is freeing and they are not completely in sync). So let quota code allow this and change qsize_t so a signed type so that we don't underflow the variables. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Convert union in mem_dqinfo to a pointerJan Kara
Coming quota support for OCFS2 is going to need quite a bit of additional per-sb quota information. Moreover having fs.h include all the types needed for this structure would be a pain in the a**. So remove the union from mem_dqinfo and add a private pointer for filesystem's use. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Split off quota tree handling into a separate fileJan Kara
There is going to be a new version of quota format having 64-bit quota limits and a new quota format for OCFS2. They are both going to use the same tree structure as VFSv0 quota format. So split out tree handling into a separate file and make size of leaf blocks, amount of space usable in each block (needed for checksumming) and structures contained in them configurable so that the code can be shared. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Move quotaio_v[12].h from include/linux/ to fs/Jan Kara
Since these include files are used only by implementation of quota formats, there's no need to have them in include/linux/. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Introduce DQUOT_QUOTA_SYS_FILE flagJan Kara
If filesystem can handle quota files as system files hidden from users, we can skip a lot of cache invalidation, syncing, inode flags setting etc. when turning quotas on, off and quota_sync. Allow filesystem to indicate that it is hiding quota files from users by DQUOT_QUOTA_SYS_FILE flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Remove compatibility function sb_any_quota_enabled()Jan Kara
2009-01-05quota: Allow to separately enable quota accounting and enforcing limitsJan Kara
Split DQUOT_USR_ENABLED (and DQUOT_GRP_ENABLED) into DQUOT_USR_USAGE_ENABLED and DQUOT_USR_LIMITS_ENABLED. This way we are able to separately enable / disable whether we should: 1) ignore quotas completely 2) just keep uptodate information about usage 3) actually enforce quota limits This is going to be useful when quota is treated as filesystem metadata - we then want to keep quota information uptodate all the time and just enable / disable limits enforcement. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Make _SUSPENDED just a flagJan Kara
Upto now, DQUOT_USR_SUSPENDED behaved like a state - i.e., either quota was enabled or suspended or none. Now allowed states are 0, ENABLED, ENABLED | SUSPENDED. This will be useful later when we implement separate enabling of quota usage tracking and limits enforcement because we need to keep track of a state which has been suspended. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Increase size of variables for limits and inode usageJan Kara
So far quota was fine with quota block limits and inode limits/numbers in a 32-bit type. Now with rapid increase in storage sizes there are coming requests to be able to handle quota limits above 4TB / more that 2^32 inodes. So bump up sizes of types in mem_dqblk structure to 64-bits to be able to handle this. Also update inode allocation / checking functions to use qsize_t and make global structure keep quota limits in bytes so that things are consistent. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Add callbacks for allocating and destroying dquot structuresJan Kara
Some filesystems would like to keep private information together with each dquot. Add callbacks alloc_dquot and destroy_dquot allowing filesystem to allocate larger dquots from their private slab in a similar fashion we currently allocate inodes. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05GFS2: Support for FIEMAP ioctlSteven Whitehouse
This patch implements the FIEMAP ioctl for GFS2. We can use the generic code (aside from a lock order issue, solved as per Ted Tso's suggestion) for which I've introduced a new variant of the generic function. We also have one exception to deal with, namely stuffed files, so we do that "by hand", setting all the required flags. This has been tested with a modified (I could only find an old version) of Eric's test program, and appears to work correctly. This patch does not currently support FIEMAP of xattrs, but the plan is to add that feature at some future point. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Eric Sandeen <sandeen@redhat.com>
2009-01-04Merge branch 'audit.b61' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b61' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: audit: validate comparison operations, store them in sane form clean up audit_rule_{add,del} a bit make sure that filterkey of task,always rules is reported audit rules ordering, part 2 fixing audit rule ordering mess, part 1 audit_update_lsm_rules() misses the audit_inode_hash[] ones sanitize audit_log_capset() sanitize audit_fd_pair() sanitize audit_mq_open() sanitize AUDIT_MQ_SENDRECV sanitize audit_mq_notify() sanitize audit_mq_getsetattr() sanitize audit_ipc_set_perm() sanitize audit_ipc_obj() sanitize audit_socketcall don't reallocate buffer in every audit_sockaddr()
2009-01-04gro: Add page frag supportHerbert Xu
This patch allows GRO to merge page frags (skb_shinfo(skb)->frags) in one skb, rather than using the less efficient frag_list. It also adds a new interface, napi_gro_frags to allow drivers to inject page frags directly into the stack without allocating an skb. This is intended to be the GRO equivalent for LRO's lro_receive_frags interface. The existing GSO interface can already handle page frags with or without an appended frag_list so nothing needs to be changed there. The merging itself is rather simple. We store any new frag entries after the last existing entry, without checking whether the first new entry can be merged with the last existing entry. Making this check would actually be easy but since no existing driver can produce contiguous frags anyway it would just be mental masturbation. If the total number of entries would exceed the capacity of a single skb, we simply resort to using frag_list as we do now. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-04ipv6: Fix sporadic sendmsg -EINVAL when sending to multicast groups.David S. Miller
Thanks to excellent diagnosis by Eduard Guzovsky. The core problem is that on a network with lots of active multicast traffic, the neighbour cache can fill up. If we try to allocate a new route and thus neighbour cache entry, the bog-standard GC attempt the neighbour layer does in ineffective because route entries hold a reference to the existing neighbour entries and GC can only liberate entries with no references. IPV4 already has a way to handle this, by doing a route cache GC in such situations (when neigh attach returns -ENOBUFS). So simply mimick this on the ipv6 side. Tested-by: Eduard Guzovsky <eguzovsky@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-05stop_machine: introduce stop_machine_create/destroy.Heiko Carstens
Introduce stop_machine_create/destroy. With this interface subsystems that need a non-failing stop_machine environment can create the stop_machine machine threads before actually calling stop_machine. When the threads aren't needed anymore they can be killed with stop_machine_destroy again. When stop_machine gets called and the threads aren't present they will be created and destroyed automatically. This restores the old behaviour of stop_machine. This patch also converts cpu hotplug to the new interface since it is special: cpu_down calls __stop_machine instead of stop_machine. However the kstop threads will only be created when stop_machine gets called. Changing the code so that the threads would be created automatically on __stop_machine is currently not possible: when __stop_machine gets called we hold cpu_add_remove_lock, which is the same lock that create_rt_workqueue would take. So the workqueue needs to be created before the cpu hotplug code locks cpu_add_remove_lock. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-05module: fix module loading failure of large kernel modules for pariscHelge Deller
When creating the final layout of a kernel module in memory, allow the module loader to reserve some additional memory in front of a given section. This is currently only needed for the parisc port which needs to put the stub entries there to fulfill the 17/22bit PCREL relocations with large kernel modules like xfs. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (renamed fn)
2009-01-04rtc: add alarm/update irq interfacesAlessandro Zummo
Add standard interfaces for alarm/update irqs enabling. Drivers are no more required to implement equivalent ioctl code as rtc-dev will provide it. UIE emulation should now be handled correctly and will work even for those RTC drivers who cannot be configured to do both UIE and AIE. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04fs: symlink write_begin allocation context fixNick Piggin
With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04fs: introduce bgl_lock_ptr()Pekka Enberg
As suggested by Andreas Dilger, introduce a bgl_lock_ptr() helper in <linux/blockgroup_lock.h> and add separate sb_bgl_lock() helpers to filesystem specific header files to break the hidden dependency to struct ext[234]_sb_info. Also, while at it, convert the macros to static inlines to try make up for all the times I broke Andrew Morton's tree. Acked-by: Andreas Dilger <adilger@sun.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04spi.h uses/needs device.hRandy Dunlap
Include header files as used/needed: In file included from drivers/leds/leds-dac124s085.c:16: include/linux/spi/spi.h:66: error: field 'dev' has incomplete type include/linux/spi/spi.h: In function 'to_spi_device': include/linux/spi/spi.h:100: warning: type defaults to 'int' in declaration of '__mptr' ... Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04audit: validate comparison operations, store them in sane formAl Viro
Don't store the field->op in the messy (and very inconvenient for e.g. audit_comparator()) form; translate to dense set of values and do full validation of userland-submitted value while we are at it. ->audit_init_rule() and ->audit_match_rule() get new values now; in-tree instances updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04audit rules ordering, part 2Al Viro
Fix the actual rule listing; add per-type lists _not_ used for matching, with all exit,... sitting on one such list. Simplifies "do something for all rules" logics, while we are at it... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04fixing audit rule ordering mess, part 1Al Viro
Problem: ordering between the rules on exit chain is currently lost; all watch and inode rules are listed after everything else _and_ exit,never on one kind doesn't stop exit,always on another from being matched. Solution: assign priorities to rules, keep track of the current highest-priority matching rule and its result (always/never). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_log_capset()Al Viro
* no allocations * return void * don't duplicate checked for dummy context Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_fd_pair()Al Viro
* no allocations * return void Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_mq_open()Al Viro
* don't bother with allocations * don't do double copy_from_user() * don't duplicate parts of check for audit_dummy_context() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
