Original-Change-Id: I7be84ad877d1865c639ee5856f546276c8fdac73
Signed-off-by: Colin Cross <ccross@android.com>
(cherry picked from commit e8945b26135c260f91c12a85cc911a165ab07504)
Rebase-Id: R3051e65e6a756bdad25ade5f865b383d9a2164e3
Looks for ieee registration number 0x000c03 as per HDMI spec.
CEA-861-E section D.6.8.
Change-Id: I6875b24c66e8754510edabcb4f9ba682a50d6ac1
Signed-off-by: Erik Gilling <konkers@android.com>
Signed-off-by: Lajos Molnar <molnar@ti.com>
CEA defines multiple timings with dual timing ratios that cannot
be distinguished from timings parameters. Added 2 new fb flags
to specify 4:3 or 16:9 display ratios.
Also added a flag that denotes CEA formats that require repeating
pixels.
Change-Id: I75d413babdcb4048a0ccce6548ed386ad0e52318
These mode are directly from the CEA-861-E spec.
Change-Id: Ic29390fb8dfc4605da1f95aaee0e2e775dfc0a4a
This reverts commit c326f06779fb6bdd7f92c3ede8d1bebbe2fafbfa.
Change-Id: I82497fc756552740836eaa2f608fecaea409cfeb
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Change-Id: Ied3851e0cb801f607499493f1e552f42daa97e6b
Signed-off-by: Ari Hirvonen <ahirvonen@nvidia.com>
Device /dev/nvhdcpX is used to manage NVHDCP on framebuffer /dev/fbX.
These devices are created on hdmi driver initialition when it is
attached to dc. Currently only one nvhdcp device may be created. An ioctl
interface is in video/nvhdcp.h
Check for repeaters and store repeater info. userspace application
queries this status to authenticate the connection. When authentication
fails, auto-renegotiate every 1.75 seconds. Give up after 5 failed attempts,
reset after hotplug or policy change.
use TEGRA_DC_OUT_NVHDCP_POLICY_ON_DEMAND in tegra_dc_out.flags in board
panel configuration to select a different default policy at probe. Currently
only TEGRA_DC_OUT_NVHDCP_POLICY_ALWAYS_ON is supported.
Change-Id: I0db66fc86096b98d2604544061721d291523de75
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Tested-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Phillip Smith <psmith@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Looks for ieee registration numver 0x000c03 as per HDMI spec.
Replace the PM-only driver for NCT1008 with a new version written by
Varun Wadekar and Dmitriy Gruzman. Add a callback to an alarm
function specified in the board platform data.
Change-Id: Ib429533930ee75af3402d24b0bc286da9f6ee67b
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Initial version of the NCT1008 driver to turn off the sensor when the
device is suspended. This improves standby current drain.
Change-Id: Ia64613c33c0052434d5e304c434605611e5ef789
Signed-off-by: Greg Meiste <w30289@motorola.com>
- Refactor DMA interactions to handle continuous single-buffered DMA
- Remove PIO support (obsolete, conflicts with new buffer management)
- Remove sample rate conversion (obsolete)
- Remove error-reporting logic
- Remove TEGRA_AUDIO_IN/OUT_GET/SET_BUF_CONFIG
- Add TEGRA_AUDIO_IN/OUT_GET/SET_NUM_BUFS
Change-Id: I8f21a0bb314aac3b7d1bb4918bda9141e58db38d
Signed-off-by: Iliyan Malchev <malchev@google.com>
Change-Id: I4bed4d37bc275cca9ef69390c217498529121db0
Change-Id: Ia72e022ad1217ffe75915465ca0e886b16d1a64a
Signed-off-by: Dima Zavin <dima@android.com>
Change-Id: I9233c5d7c678f6a9ba1c23af686137bf4d6a4291
The tegra_camera device includes all clock and regulator
functionality needed to support camera on tegra.
Change-Id: I281f1cb5f360276af832309e35dbe17c98b62bb3
Creates /dev/spdif_out and /dev/spdif_out_ctl for playback and control
settings. Playback is working.
Change-Id: Ic312271b96a8bb8d8b2696448d3ff7fd73a7a851
-- Ignore kfifo thresholds on recording and playback and adjust the delays.
-- Take out the code from TEGRA_AUDIO_IN_STOP into a separate function
stop_recording_nosync()
-- Rename stop_recording() to wait_for_recording_to_stop().
-- add ioctl(TEGRA_AUDIO_OUT_FLUSH), which blocks the caller until the output
fifo is drained. While the caller is blocked, pending write() calls will
return immediately with whatever data they had managed to queue up.
-- removed ioctl(TEGRA_AUDIO_OUT_PRELOAD_FIFO)
-- since TEGRA_AUDIO_OUT_FLUSH and TEGRA_AUDIO_IN_STOP act similarly, moved
audio_driver_state::recording_cancelled to audio_stream::stop and changed
the code accordingly. Renamed functions wait_for_recording_to_stop() and
stop_recording_nosync() to wait_till_stopped() and request_stop_nosync()
since they handle both playback and recording.
-- print errors on close() if wakelocks are still held
-- Call request_stop_nosync() on close() of a recording file handle
-- Do not use struct audio_stream::active for playback streams. Instead,
where applicable, use kfifo_len(). As a consequence, playback kfifo
underruns are no longer reported. These were bogus anyway, as we really
need the DMA engine to tell us if there are underruns.
-- Because of above item, had to rework tx_fifo_atn_store(),
rx_fifo_atn_store(), and __attr_fifo_atn_write().
-- Set struct audio_stream::active for a recording stream to true when a
recording starts, and set it to false when recording get stopped. Do not
set/clear it within the body of read(), because just being within read()
does not mean that recording is in progress.
-- In tegra_audio_read(), check for stop == true before calling
start_recording_if_necessary(); this makes sure that if a user calls read()
after calling ioctl(TEGRA_AUDIO_IN_STOP), recording will not resume unless
ioctl(TEGRA_AUDIO_IN_START) gets called, or the file is closed and
re-opened.
-- Fixed TEGRA_AUDIO_IN_START
-- In PIO mode, enabled FIFOs before enabling interrupts as specified in the
TRM.
-- Added missing break in tegra_audio_ioctl().
-- Silenced some debug spew
includes changes by:
Antti Hatala <ahatala@nvidia.com> (1)
Gary King <gking@nvidia.com> (1)
Erik Gilling <konkers@android.com> (2)
video: tegra: dc: use nvhost driver for host1x power management
video: tegra: fb: add ioctl to flip dc windows to nvmap handles
video: tegra: dc: increment syncpoints following window flips
video: tegra: drain syncpt waits on display disable
Original commit messages:
Incrementing the frame done syncpoint value from the display interrupt
requires that the host module is powered on. As the syncpoint state is
saved and restored automatically by the host driver a cpu increment of
a syncpoint in the powered down state will be lost.
Also adds checks for host module being powered.
tegra user-space graphics drivers may allocate framebuffers using
nvmap rather than rendering to the common framebuffer, this may
be done to support deeper buffer pipelining, color formats
and pixel layouts other than the initial bootup framebuffer,
etc.
to use this ioctl, a caller must first specify an nvmap fd
which is already open in the calling process so that the
subsequent flip ioctls may be properly validated. flips are performed
asynchronously, with flip completion notifications provided back to
the caller via the host1x syncpoint mechanism
based on earlier changes made by Antti Hatala <ahatala@nvidia.com>
and Erik Gilling <konkers@android.com>
Change-Id: I4e8a8bb92085a485d65fd87d89112b2969ee37ff
Signed-off-by: Gary King <gking@nvidia.com>
Change-Id: I3bcc0a91cb379c0bd6ef382a5bf10e2406e55697
Added an ioctl to set the bit format for I2S between "DSP"/"PCM" mode and
normal mode (set by board file)
This reverts commit 3543d53703c5a1ed0b987c77e7a79226c3a24f45.
-- creates /dev/spdif_out and /dev/spdif_out_ctl for playback and control
settings.
-- playback only
Change-Id: I19af1d41e13dedef650784835339ef9718300d0c
This patch replaces the error counter with two separate error counters, one for
late dma callbacks, and another for overruns (during recording) or underruns
(during playback). The ioctls TEGRA_AUDIO_IN_GET_ERROR_COUNT and
TEGRA_AUDIO_OUT_GET_ERROR_COUNT now take a pointer to a struct containing both
error counters.
the panjit touchscreen needs to be reset when returning from
deep sleep mode; add a platform data structure to specify
the reset GPIO.
perform the reset during _probe, since the code already needs
to exist for _resume
delete a bunch of unused preprocessor defines
Change-Id: I71ae65dec45710b0eab4625036edf75064d4cc2b
The host (or host1x) bus sits between the cpu core and the 3d, 2d, camera,
display, and mpeg encoder functions. It contains provides DMA channels,
hardware mutexes, and synchronization points.
Add an ioctl to allow the TX fifo to be loaded with data before playback
starts. Playback can then be started by calling write() on the FIFO, even
with a length of 0. This will cause the pending data to be played out.
-- Use consistently the various state flags:
-- active is set only when there is a read or write in flight
-- recording_canncelled is set only when recording is stopped via the ioctl()
-- dma_has_it is used to determine whether DMA is already in flight; do not
use the state of the fifos for this (e.g., if the TX fifo is empty, do not
assume that playback is stopped)
-- added a stop_completion (implemented for readers only) so that readers
closing a stream can wait until DMA or PIO transactions are stopped
-- Split /dev/audio0_{in,out} into /dev/audio0_{in,in_ctl,out,out_ctl} where the
_ctl versions have the ioctl()s
-- Introduced an error count per audio_stream; error count is reset on open, can
be read back & reset through an ioctl
-- Add ioctls for configuring buffer, threshold, and DMA-transaction sizes from
user space.
-- Buffer sizes are provided in orders of magnitude.
-- Allocate max-sized buffers during probe, and allow the user to resize them
only within the original allocation, to avoid the risk from kmalloc failing
due to kernel-heap fragmentation, and also to avoid race conditions on DMA
shut-down.
-- In tegra_audio_write(), moved the call to start_playback_if_necessary()
immediately after writing to the fifo. Otherwise, when the fifo size is
smaller than what the user is trying to write, the user will block before
playback is started.
-- Silenced printk spew on spinning on i2s registers after transactions are
completed.
-- Cleaned up a 80-col style violation in downsample()
downsampling:
-- add ioctl()s to downsample recorded data
-- supported frequencies are 8kHz, 11.025kHz, 22.05kHz, and 44.1kHz
-- downsamping to stereo and mono
-- default is 11.025kHz mono
fixes:
-- fix crashes from dequeuing DMA requests twice
-- add audio_in_stream (identical to audio_out_stream, may merge them later)
-- add support for DMA and PIO recording
-- add ioctls for /dev/audio<n>_in to start and stop recording
this adds support for dynamically reprogramming the I2C controller's
pin mux on transaction boundaries to enable one controller to be
registered as multiple I2C bus adapters with the kernel. this allows
platform designers an additional tool to resolve clock rate, I/O
voltage and electrical loading restrictions between the platform's
peripherals.
the i2c-tegra platform data is extended to support this; platforms
which use this feature should pass in the number of busses which
should be created for each controller, the starting adapter number
to use and the clock rate and pin mux for each virtual bus.
Change-Id: I57a96deb7b7b793222ec3f8cc3a941917a023609
commit 09f363c7363eb10cfb4b82094bd7064e5608258b upstream.
The callback must not return -1 when nr_to_scan is zero. Fix the bug in
fs/super.c and add this requirement to the callback specification.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 1788ea6e3b2a58cf4fb00206e362d9caff8d86a7 upstream.
commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return
from an OPEN call. Prior to that patch, that caused the client to fall
back to doing a normal lookup. When that patch went in, the code began
returning that error to userspace. The d_revalidate codepath however
never had the corresponding change, so it was still possible to end up
with a NULL ctx->state pointer after that.
That patch caused a regression. When we attempt to open a directory that
does not have a cached dentry, that open now errors out with EISDIR. If
you attempt the same open with a cached dentry, it will succeed.
Fix this by reverting the change in nfs_atomic_lookup and allowing
attempts to open directories to fall back to a normal lookup
Also, add a NFSv4-specific f_ops->open routine that just returns
-ENOTDIR. This should never be called if things are working properly,
but if it ever is, then the dprintk may help in debugging.
To facilitate this, a new file_operations field is also added to the
nfs_rpc_ops struct.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit b872a37437e93df9d112ce674752b3b3a0a17020 upstream.
Noticed by Egbert.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Egbert Eich <eich@suse.de>
commit c1056b42a87b59375f8f81a92ef029165f44fcce upstream.
Recently the ACPI ops structs were constified but the inline version
of register_hotplug_dock_device() was overlooked (see also commit
9c8b04b, June 25 2011). Update the inline function
register_hotplug_dock_device() that is enabled with
CONFIG_ACPI_DOCK=n too. This patch fixes at least the following
compiler warnings:
drivers/ata/libata-acpi.c: In function .ata_acpi_associate.:
drivers/ata/libata-acpi.c:266:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
include/acpi/acpi_drivers.h:146:19: note: expected .struct acpi_dock_ops *. but argument is of type .const struct acpi_dock_ops *.
drivers/ata/libata-acpi.c:275:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
Signed-off-by: Len Brown <len.brown@intel.com>
commit 00dfb8df5bf8c3afe4c0bb8361133156b06b7a2c upstream.
This should make eDP more reliable.
commit b35a35b556f5e6b7993ad0baf20173e75c09ce8c upstream.
This avoids duplicating the function in every arch gup_fast.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
commit 1cd9f0976aa4606db8d6e3dc3edd0aca8019372a upstream.
This doesn't make much sense, and it exposes a bug in the kernel where
attempts to create a new file in an append-only directory using
O_CREAT will fail (but still leave a zero-length file). This was
discovered when xfstests #79 was generalized so it could run on all
file systems.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 70b50f94f1644e2aa7cb374819cfd93f3c28d725 upstream.
Michel while working on the working set estimation code, noticed that
calling get_page_unless_zero() on a random pfn_to_page(random_pfn)
wasn't safe, if the pfn ended up being a tail page of a transparent
hugepage under splitting by __split_huge_page_refcount().
He then found the problem could also theoretically materialize with
page_cache_get_speculative() during the speculative radix tree lookups
that uses get_page_unless_zero() in SMP if the radix tree page is freed
and reallocated and get_user_pages is called on it before
page_cache_get_speculative has a chance to call get_page_unless_zero().
So the best way to fix the problem is to keep page_tail->_count zero at
all times. This will guarantee that get_page_unless_zero() can never
succeed on any tail page. page_tail->_mapcount is guaranteed zero and
is unused for all tail pages of a compound page, so we can simply
account the tail page references there and transfer them to
tail_page->_count in __split_huge_page_refcount() (in addition to the
head_page->_mapcount).
While debugging this s/_count/_mapcount/ change I also noticed get_page is
called by direct-io.c on pages returned by get_user_pages. That wasn't
entirely safe because the two atomic_inc in get_page weren't atomic. As
opposed to other get_user_page users like secondary-MMU page fault to
establish the shadow pagetables would never call any superflous get_page
after get_user_page returns. It's safer to make get_page universally safe
for tail pages and to use get_page_foll() within follow_page (inside
get_user_pages()). get_page_foll() is safe to do the refcounting for tail
pages without taking any locks because it is run within PT lock protected
critical sections (PT lock for pte and page_table_lock for
pmd_trans_huge).
The standard get_page() as invoked by direct-io instead will now take
the compound_lock but still only for tail pages. The direct-io paths
are usually I/O bound and the compound_lock is per THP so very
finegrined, so there's no risk of scalability issues with it. A simple
direct-io benchmarks with all lockdep prove locking and spinlock
debugging infrastructure enabled shows identical performance and no
overhead. So it's worth it. Ideally direct-io should stop calling
get_page() on pages returned by get_user_pages(). The spinlock in
get_page() is already optimized away for no-THP builds but doing
get_page() on tail pages returned by GUP is generally a rare operation
and usually only run in I/O paths.
This new refcounting on page_tail->_mapcount in addition to avoiding new
RCU critical sections will also allow the working set estimation code to
work without any further complexity associated to the tail page
refcounting with THP.
Reported-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
commit 1fa1e7f615f4d3ae436fa319af6e4eebdd4026a8 upstream.
Since the commit below which added O_PATH support to the *at() calls, the
error return for readlink/readlinkat for the empty pathname has switched
from ENOENT to EINVAL:
commit 65cfc6722361570bfe255698d9cd4dccaf47570d
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sun Mar 13 15:56:26 2011 -0400
readlinkat(), fchownat() and fstatat() with empty relative pathnames
This is both unexpected for userspace and makes readlink/readlinkat
inconsistant with all other interfaces; and inconsistant with our stated
return for these pathnames.
As the readlinkat call does not have a flags parameter we cannot use the
AT_EMPTY_PATH approach used in the other calls. Therefore expose whether
the original path is infact entry via a new user_path_at_empty() path
lookup function. Use this to determine whether to default to EINVAL or
ENOENT for failures.
Addresses http://bugs.launchpad.net/bugs/817187
[akpm@linux-foundation.org: remove unused getname_flags()]
Signed-off-by: Andy Whitcroft <apw@canonical.com>
commit f5252e009d5b87071a919221e4f6624184005368 upstream.
The /proc/vmallocinfo shows information about vmalloc allocations in
vmlist that is a linklist of vm_struct. It, however, may access pages
field of vm_struct where a page was not allocated. This results in a null
pointer access and leads to a kernel panic.
Why this happens: In __vmalloc_node_range() called from vmalloc(), newly
allocated vm_struct is added to vmlist at __get_vm_area_node() and then,
some fields of vm_struct such as nr_pages and pages are set at
__vmalloc_area_node(). In other words, it is added to vmlist before it is
fully initialized. At the same time, when the /proc/vmallocinfo is read,
it accesses the pages field of vm_struct according to the nr_pages field
at show_numa_info(). Thus, a null pointer access happens.
The patch adds the newly allocated vm_struct to the vmlist *after* it is
fully initialized. So, it can avoid accessing the pages field with
unallocated page when show_numa_info() is called.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
commit 24dd85ff723f142093f44244764b9b5c152235b8 upstream.
For the !HAVE_ATOMIC_IOMAP case the stub functions did not call
pagefault_disable/_enable. The i915 driver relies on the map
actually being atomic, otherwise it can deadlock with it's own
pagefault handler in the gtt pwrite fastpath.
This is exercised by gem_mmap_gtt from the intel-gpu-toosl gem
testsuite.
v2: Chris Wilson noted the lack of an include.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38115
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream.
This adds a mechanism to resume selected IRQs during syscore_resume
instead of dpm_resume_noirq.
Under Xen we need to resume IRQs associated with IPIs early enough
that the resched IPI is unmasked and we can therefore schedule
ourselves out of the stop_machine where the suspend/resume takes
place.
This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME".
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com>
Cc: xen-devel <xen-devel@lists.xensource.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk
commit cbbc719fccdb8cbd87350a05c0d33167c9b79365 upstream.
The parameter's origin type is long. On an i386 architecture, it can
easily be larger than 0x80000000, causing this function to convert it
to a sign-extended u64 type.
Change the type to unsigned long so we get the correct result.
Signed-off-by: hank <pyu@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
[ build fix ]
commit da92b194cc36b5dc1fbd85206aeeffd80bee0c39 upstream.
The pair of functions,
* skb_clone_tx_timestamp()
* skb_complete_tx_timestamp()
were designed to allow timestamping in PHY devices. The first
function, called during the MAC driver's hard_xmit method, identifies
PTP protocol packets, clones them, and gives them to the PHY device
driver. The PHY driver may hold onto the packet and deliver it at a
later time using the second function, which adds the packet to the
socket's error queue.
As pointed out by Johannes, nothing prevents the socket from
disappearing while the cloned packet is sitting in the PHY driver
awaiting a timestamp. This patch fixes the issue by taking a reference
on the socket for each such packet. In addition, the comments
regarding the usage of these function are expanded to highlight the
rule that PHY drivers must use skb_complete_tx_timestamp() to release
the packet, in order to release the socket reference, too.
These functions first appeared in v2.6.36.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit c1225158a8dad9e9d5eee8a17dbbd9c7cda05ab9 upstream.
The same function is used by idmap, gss and blocklayout code. Make it
generic.
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Jim Rees <rees@umich.edu>
commit 276532ba9666b36974cbe16f303fc8be99c9da17 upstream.
The Kirkwood gave an unaligned memory access error on
line 742 of drivers/usb/host/echi-hcd.c:
"ehci->last_periodic_enable = ktime_get_real();"
Signed-off-by: Harro Haan <hrhaan@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
