On larger systems, because of the numerous ACPI, Bootmem and EFI messages,
the static log buffer overflows before the larger one specified by the
log_buf_len param is allocated. Minimize the overflow by allocating the
new log buffer as soon as possible.
On kernels without memblock, a later call to setup_log_buf from
kernel/init.c is the fallback.
[akpm@linux-foundation.org: fix CONFIG_PRINTK=n build]
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Jack Steiner <steiner@sgi.com>
On larger systems, information in the kernel log is lost because there is
so much early text printed, that it overflows the static log buffer before
the log_buf_len kernel parameter can be processed, and a bigger log buffer
allocated.
Distros are relunctant to increase memory usage by increasing the size of
the static log buffer, so minimize the problem by allocating the new log
buffer as early as possible.
This patch:
Add an error return if CONFIG_HAVE_MEMBLOCK is not set instead of having
to add #ifdef CONFIG_HAVE_MEMBLOCK around blocks of code calling that
function.
sparse can't parse warning and error attribute. then they should be
hidden from sparse.
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
commit c5e631cf65f ("ARRAY_SIZE: check for type") added __must_be_array().
But sparse can't parse this gcc extention.
Now make C=2 makes following sparse errors a lot.
kernel/futex.c:2699:25: error: No right hand side of '+'-expression
Because __must_be_array() is used for ARRAY_SIZE() macro and it is
used very widely.
This patch fixes it.
BUILD_BUG_ON() causes a syntax error to detect coding errors. So it
causes sparse to detect an error too. This reduces sparse's usefulness.
This patch makes a dummy BUILD_BUG_ON() definition for sparse.
af4f136056c9 ("security: move LSM xattrnames to xattr.h") moved the
XATTR_CAPS_SUFFIX define from capability.h to xattr.h. This makes sense
except it was previously exports to userspace but xattr.h does not export
it to userspace. This patch exports these headers to userspace to fix the
ABI regression.
There is some slight possibility that this will cause problems in other
applications which used these #defines differently (wrongly) and I could
JUST export the capabilities xattr name that we broke. Does anyonehave an
idea how exposing these headers could cause a problem?
Below is what is being exposed to userspace, included here since it isn't
clear exactly what is going to be made available from the patch.
/* Namespaces */
#define XATTR_OS2_PREFIX "os2."
#define XATTR_OS2_PREFIX_LEN (sizeof (XATTR_OS2_PREFIX) - 1)
#define XATTR_SECURITY_PREFIX "security."
#define XATTR_SECURITY_PREFIX_LEN (sizeof (XATTR_SECURITY_PREFIX) - 1)
#define XATTR_SYSTEM_PREFIX "system."
#define XATTR_SYSTEM_PREFIX_LEN (sizeof (XATTR_SYSTEM_PREFIX) - 1)
#define XATTR_TRUSTED_PREFIX "trusted."
#define XATTR_TRUSTED_PREFIX_LEN (sizeof (XATTR_TRUSTED_PREFIX) - 1)
#define XATTR_USER_PREFIX "user."
#define XATTR_USER_PREFIX_LEN (sizeof (XATTR_USER_PREFIX) - 1)
/* Security namespace */
#define XATTR_SELINUX_SUFFIX "selinux"
#define XATTR_NAME_SELINUX XATTR_SECURITY_PREFIX XATTR_SELINUX_SUFFIX
#define XATTR_SMACK_SUFFIX "SMACK64"
#define XATTR_SMACK_IPIN "SMACK64IPIN"
#define XATTR_SMACK_IPOUT "SMACK64IPOUT"
#define XATTR_NAME_SMACK XATTR_SECURITY_PREFIX XATTR_SMACK_SUFFIX
#define XATTR_NAME_SMACKIPIN XATTR_SECURITY_PREFIX XATTR_SMACK_IPIN
#define XATTR_NAME_SMACKIPOUT XATTR_SECURITY_PREFIX XATTR_SMACK_IPOUT
#define XATTR_CAPS_SUFFIX "capability"
#define XATTR_NAME_CAPS XATTR_SECURITY_PREFIX XATTR_CAPS_SUFFIX
Reported-by: Ozan Çaglayan <ozan@pardus.org.tr>
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Mimi Zohar <zohar@us.ibm.com>
Cc: Serge Hallyn <serue@us.ibm.com>
Manually adjusting the smp_affinity for IRQ's becomes unwieldy when the
cpu count is large.
Setting smp affinity to cpus 256 to 263 would be:
echo 000000ff,00000000,00000000,00000000,00000000,00000000,00000000,00000000 > smp_affinity
instead of:
echo 256-263 > smp_affinity_list
Think about what it looks like for cpus around say, 4088 to 4095.
We already have many alternate "list" interfaces:
/sys/devices/system/cpu/cpuX/indexY/shared_cpu_list
/sys/devices/system/cpu/cpuX/topology/thread_siblings_list
/sys/devices/system/cpu/cpuX/topology/core_siblings_list
/sys/devices/system/node/nodeX/cpulist
/sys/devices/pci***/***/local_cpulist
Add a companion interface, smp_affinity_list to use cpu lists instead of
cpu maps. This conforms to other companion interfaces where both a map
and a list interface exists.
This required adding a bitmap_parselist_user() function in a manner
similar to the bitmap_parse_user() function.
[akpm@linux-foundation.org: make __bitmap_parselist() static]
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
There is no CONFIG_WORKQUEUE_DEBUGFS any more, so this code is dead.
Signed-off-by: WANG Cong <amwang@redhat.com>
The macro to_class_dev() uses the deprecated structure class_device, and
the c2port_device has no member named class in the definition of the macro
to_c2port_device.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Cc: Rodolfo Giometti <giometti@linux.it>
Apps are increasingly using more than 1024 file descriptors. See
discussion in several distro bug trackers, e.g. BugLink:
http://bugs.launchpad.net/bugs/663090
https://issues.rpath.com/browse/RPL-2054
You don't want to raise the default soft limit, since that might break
apps that use select(), but it's safe to raise the default hard limit;
that way, apps that know they need lots of file descriptors can raise
their soft limit without needing root, and without user intervention.
Ubuntu is doing this with a kernel change because they have a policy of
not changing kernel defaults in userland.
While 4096 might not be enough for *all* apps, it seems to be plenty for
the apps I've seen lately that are unhappy with 1024.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Dan Kegel <dank@kegel.com>
The copy_to_user_page() function is supposed to flush the icache on the
memory that was written, but the current asm-generic version lacks that
logic. While normally it isn't a big deal as the asm-generic version of
icache flushing is a stub, it is a deal for ports that want to use the
asm-generic version as a baseline and then overlay its own specific parts
(like icache flushing).
Add SECTION_ALIGN_UP() and SECTION_ALIGN_DOWN() macro which aligns given
pfn to upper section and lower section boundary accordingly.
Required for the latest memory hotplug support for the Xen balloon driver.
Signed-off-by: Daniel Kiper <dkiper@net-space.pl>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
David Rientjes <rientjes@google.com>
Now that mm/mempolicy.c is no longer implementing /proc/pid/numa_maps
there is no need to export struct proc_maps_private to the world. Move it
to fs/proc/internal.h instead.
Signed-off-by: Stephen Wilson <wilsons@start.ca>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
When CONFIG_TMPFS=n mpol_to_str() is not declared in mempolicy.h.
However, in the NUMA case, the definition is always compiled.
Since it is not strictly true that tmpfs is the only client, and since the
symbol was always lurking around anyways, export mpol_to_str()
unconditionally. Furthermore, this will allow us to move show_numa_map()
out of mempolicy.c and into the procfs subsystem.
Cc: Randy Dunlap <rdunlap@xenotime.net>
In commit 48fce3429d ("mempolicies: unexport get_vma_policy()")
get_vma_policy() was marked static as all clients were local to
mempolicy.c.
However, the decision to generate /proc/pid/numa_maps in the numa memory
policy code and outside the procfs subsystem introduces an artificial
interdependency between the two systems. Exporting get_vma_policy() once
again is the first step to clean up this interdependency.
Remove noMMU declaration of shmem_get_unmapped_area() from mm.h: it fell
out of use in 2.6.21 and ceased to exist in 2.6.29.
Implement generic xattrs for tmpfs filesystems. The Feodra project, while
trying to replace suid apps with file capabilities, realized that tmpfs,
which is used on the build systems, does not support file capabilities and
thus cannot be used to build packages which use file capabilities. Xattrs
are also needed for overlayfs.
The xattr interface is a bit odd. If a filesystem does not implement any
{get,set,list}xattr functions the VFS will call into some random LSM hooks
and the running LSM can then implement some method for handling xattrs.
SELinux for example provides a method to support security.selinux but no
other security.* xattrs.
As it stands today when one enables CONFIG_TMPFS_POSIX_ACL tmpfs will have
xattr handler routines specifically to handle acls. Because of this tmpfs
would loose the VFS/LSM helpers to support the running LSM. To make up
for that tmpfs had stub functions that did nothing but call into the LSM
hooks which implement the helpers.
This new patch does not use the LSM fallback functions and instead just
implements a native get/set/list xattr feature for the full security.* and
trusted.* namespace like a normal filesystem. This means that tmpfs can
now support both security.selinux and security.capability, which was not
previously possible.
The basic implementation is that I attach a:
struct shmem_xattr {
struct list_head list; /* anchored by shmem_inode_info->xattr_list */
char *name;
size_t size;
char value[0];
Into the struct shmem_inode_info for each xattr that is set. This
implementation could easily support the user.* namespace as well, except
some care needs to be taken to prevent large amounts of unswappable memory
being allocated for unprivileged users.
[mszeredi@suse.cz: new config option, suport trusted.*, support symlinks]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com>
Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Tested-by: Jordi Pujol <jordipujolp@gmail.com>
The bootmem wrapper with memblock supports top-down now, so we do not need
to set the low limit to __pa(MAX_DMA_ADDRESS).
The logic should be: good to allocate above __pa(MAX_DMA_ADDRESS), but it
is ok if we can not find memory above 16M on system that has a small
amount of RAM.
Signed-off-by: Yinghai LU <yinghai@kernel.org>
Cc: Olaf Hering <olaf@aepfle.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
The problem with having two different types of counters is that developers
adding new code need to keep in mind whether it's safe to use both the
atomic and non-atomic implementations. For example, when adding new
callers of the *_mm_counter() functions a developer needs to ensure that
those paths are always executed with page_table_lock held, in case we're
using the non-atomic implementation of mm counters.
Hugh Dickins introduced the atomic mm counters in commit f412ac08c986
("[PATCH] mm: fix rss and mmlist locking"). When asked why he left the
non-atomic counters around he said,
| The only reason was to avoid adding costly atomic operations into a
| configuration that had no need for them there: the page_table_lock
| sufficed.
| Certainly it would be simpler just to delete the non-atomic variant.
| And I think it's fair to say that any configuration on which we're
| measuring performance to that degree (rather than "does it boot fast?"
| type measurements), would already be going the split ptlocks route.
Removing the non-atomic counters eases the maintenance burden because
developers no longer have to mindful of the two implementations when using
*_mm_counter().
Note that all architectures provide a means of atomically updating
atomic_long_t variables, even if they have to revert to the generic
spinlock implementation because they don't support 64-bit atomic
instructions (see lib/atomic64.c).
Signed-off-by: Matt Fleming <matt.fleming@linux.intel.com>
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Do not define PFN_SECTION_SHIFT if !CONFIG_SPARSEMEM.
CONFIG_SPARSEMEM context
pfn_to_section_nr()/section_nr_to_pfn() is valid only in CONFIG_SPARSEMEM
context. Move it to proper place.
!CONFIG_SPARSEMEM_VMEMMAP
set_page_section() is meaningful only in CONFIG_SPARSEMEM and
!CONFIG_SPARSEMEM_VMEMMAP context. Move it to proper place and amend
accordingly functions which are using it.
Acked-by: David Rientjes <rientjes@google.com>
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Consolidate the existing parameters to shrink_slab() into a new
shrink_control struct. This is needed later to pass the same struct to
shrinkers.
Pass __GFP_NORETRY|__GFP_NOWARN for readahead page allocations.
readahead page allocations are completely optional. They are OK to fail
and in particular shall not trigger OOM on themselves.
Reported-by: Dave Young <hidave.darkstar@gmail.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Pekka Enberg <penberg@kernel.org>
This originally started as a simple patch to give vmalloc() some more
verbose output on failure on top of the plain page allocator messages.
Johannes suggested that it might be nicer to lead with the vmalloc() info
_before_ the page allocator messages.
But, I do think there's a lot of value in what __alloc_pages_slowpath()
does with its filtering and so forth.
This patch creates a new function which other allocators can call instead
of relying on the internal page allocator warnings. It also gives this
function private rate-limiting which separates it from other
printk_ratelimit() users.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
cpumask_t is very big struct and cpu_vm_mask is placed wrong position.
It might lead to reduce cache hit ratio.
This patch has two change.
1) Move the place of cpumask into last of mm_struct. Because usually cpumask
is accessed only front bits when the system has cpu-hotplug capability
2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory
footprint if cpumask_size() will use nr_cpumask_bits properly in future.
In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var.
It may help to detect out of tree cpu_vm_mask users.
This patch has no functional change.
[akpm@linux-foundation.org: build fix]
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Some of these functions have grown beyond inline sanity, move them
out-of-line.
Requested-by: Andrew Morton <akpm@linux-foundation.org>
Requested-by: Hugh Dickins <hughd@google.com>
Straightforward conversion of anon_vma->lock to a mutex.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Its beyond ugly and gets in the way.
Straightforward conversion of i_mmap_lock to a mutex.
Hugh says:
"The only significant loser, I think, would be page reclaim (when
concurrent with truncation): could spin for a long time waiting for
the i_mmap_mutex it expects would soon be dropped? "
Counter points:
- cpu contention makes the spin stop (need_resched())
- zap pages should be freeing pages at a higher rate than reclaim
ever can
I think the simplification of the truncate code is definitely worth it.
Effectively reverts: 2aa15890f3c ("mm: prevent concurrent
unmap_mapping_range() on the same inode") and takes out the code that
caused its problem.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
In order to convert i_mmap_lock to a mutex we need a mutex equivalent to
spin_lock_nest_lock(), thus provide the mutex_lock_nest_lock() annotation.
As with spin_lock_nest_lock(), mutex_lock_nest_lock() allows annotation of
the locking pattern where an outer lock serializes the acquisition order
of nested locks. That is, if every time you lock multiple locks A, say A1
and A2 you first acquire N, the order of acquiring A1 and A2 is
irrelevant.
Instead of using a single batch (the small on-stack, or an allocated
page), try and extend the batch every time it runs out and only flush once
either the extend fails or we're done.
Requested-by: Nick Piggin <npiggin@kernel.dk>
In case other architectures require RCU freed page-tables to implement
gup_fast() and software filled hashes and similar things, provide the
means to do so by moving the logic into generic code.
Requested-by: David Miller <davem@davemloft.net>
Rework the existing mmu_gather infrastructure.
The direct purpose of these patches was to allow preemptible mmu_gather,
but even without that I think these patches provide an improvement to the
status quo.
The first 9 patches rework the mmu_gather infrastructure. For review
purpose I've split them into generic and per-arch patches with the last of
those a generic cleanup.
The next patch provides generic RCU page-table freeing, and the followup
is a patch converting s390 to use this. I've also got 4 patches from
DaveM lined up (not included in this series) that uses this to implement
gup_fast() for sparc64.
Then there is one patch that extends the generic mmu_gather batching.
After that follow the mm preemptibility patches, these make part of the mm
a lot more preemptible. It converts i_mmap_lock and anon_vma->lock to
mutexes which together with the mmu_gather rework makes mmu_gather
preemptible as well.
Making i_mmap_lock a mutex also enables a clean-up of the truncate code.
This also allows for preemptible mmu_notifiers, something that XPMEM I
think wants.
Furthermore, it removes the new and universially detested unmap_mutex.
This patch:
Remove the first obstacle towards a fully preemptible mmu_gather.
The current scheme assumes mmu_gather is always done with preemption
disabled and uses per-cpu storage for the page batches. Change this to
try and allocate a page for batching and in case of failure, use a small
on-stack array to make some progress.
Preemptible mmu_gather is desired in general and usable once i_mmap_lock
becomes a mutex. Doing it before the mutex conversion saves us from
having to rework the code by moving the mmu_gather bits inside the
pte_lock.
Also avoid flushing the tlb batches from under the pte lock, this is
useful even without the i_mmap_lock conversion as it significantly reduces
pte lock hold times.
[akpm@linux-foundation.org: fix comment tpyo]
Acked-by: Mel Gorman <mel@csn.ul.ie>
Currently we have expand_upwards exported while expand_downwards is
accessible only via expand_stack or expand_stack_downwards.
check_stack_guard_page is a nice example of the asymmetry. It uses
expand_stack for VM_GROWSDOWN while expand_upwards is called for
VM_GROWSUP case.
Let's clean this up by exporting both functions and make those names
consistent. Let's use expand_{upwards,downwards} because expanding
doesn't always involve stack manipulation (an example is
ia64_do_page_fault which uses expand_upwards for registers backing store
expansion). expand_downwards has to be defined for both
CONFIG_STACK_GROWS{UP,DOWN} because get_arg_page calls the downwards
version in the early process initialization phase for growsup
configuration.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
VM_BUG_ON() if effectively a BUG_ON() undef #ifdef CONFIG_DEBUG_VM. That
is exactly what we have here now, and two different folks have suggested
doing it this way.
Cc: Christoph Lameter <cl@linux.com>
Running sparse on page_alloc.c today, it errors out:
include/linux/gfp.h:254:17: error: bad constant expression
include/linux/gfp.h:254:17: error: cannot size expression
which is a line in gfp_zone():
BUILD_BUG_ON((GFP_ZONE_BAD >> bit) & 1);
That's really unfortunate, because it ends up hiding all of the other
legitimate sparse messages like this:
mm/page_alloc.c:5315:59: warning: incorrect type in argument 1 (different base types)
mm/page_alloc.c:5315:59: expected unsigned long [unsigned] [usertype] size
mm/page_alloc.c:5315:59: got restricted gfp_t [usertype] <noident>
Having sparse be able to catch these very oopsable bugs is a lot more
important than keeping a BUILD_BUG_ON(). Kill the BUILD_BUG_ON().
Compiles on x86_64 with and without CONFIG_DEBUG_VM=y. defconfig boots
fine for me.
There's a kernel-wide shortage of per-process flags, so it's always
helpful to trim one when possible without incurring a significant penalty.
It's even more important when you're planning on adding a per- process
flag yourself, which I plan to do shortly for transparent hugepages.
PF_OOM_ORIGIN is used by ksm and swapoff to prefer current since it has a
tendency to allocate large amounts of memory and should be preferred for
killing over other tasks. We'd rather immediately kill the task making
the errant syscall rather than penalizing an innocent task.
This patch removes PF_OOM_ORIGIN since its behavior is equivalent to
setting the process's oom_score_adj to OOM_SCORE_ADJ_MAX.
The process's old oom_score_adj is stored and then set to
OOM_SCORE_ADJ_MAX during the time it used to have PF_OOM_ORIGIN. The old
value is then reinstated when the process should no longer be considered a
high priority for oom killing.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Izik Eidus <ieidus@redhat.com>
Currently, cpu hotplug updates pcp->stat_threshold, but memory hotplug
doesn't. There is no reason for this.
[akpm@linux-foundation.org: fix CONFIG_SMP=n build]
Acked-by: Christoph Lameter <cl@linux.com>
Currently, memory hotplug calls setup_per_zone_wmarks() and
calculate_zone_inactive_ratio(), but doesn't call
setup_per_zone_lowmem_reserve().
It means the number of reserved pages aren't updated even if memory hot
plug occur. This patch fixes it.
When an oom killing occurs, almost all processes are getting stuck at the
following two points.
1) __alloc_pages_nodemask
2) __lock_page_or_retry
1) is not very problematic because TIF_MEMDIE leads to an allocation
failure and getting out from page allocator.
2) is more problematic. In an OOM situation, zones typically don't have
page cache at all and memory starvation might lead to greatly reduced IO
performance. When a fork bomb occurs, TIF_MEMDIE tasks don't die quickly,
meaning that a fork bomb may create new process quickly rather than the
oom-killer killing it. Then, the system may become livelocked.
This patch makes the pagefault interruptible by SIGKILL.
Cc: Matthew Wilcox <willy@linux.intel.com>
commit 2687a356 ("Add lock_page_killable") introduced killable
lock_page(). Similarly this patch introdues killable
wait_on_page_locked().
commit 2ac390370a ("writeback: add
/sys/devices/system/node/<node>/vmstat") added vmstat entry. But
strangely it only show nr_written and nr_dirtied.
# cat /sys/devices/system/node/node20/vmstat
nr_written 0
nr_dirtied 0
Of course, It's not adequate. With this patch, the vmstat show all vm
stastics as /proc/vmstat.
# cat /sys/devices/system/node/node0/vmstat
nr_free_pages 899224
nr_inactive_anon 201
nr_active_anon 17380
nr_inactive_file 31572
nr_active_file 28277
nr_unevictable 0
nr_mlock 0
nr_anon_pages 17321
nr_mapped 8640
nr_file_pages 60107
nr_dirty 33
nr_writeback 0
nr_slab_reclaimable 6850
nr_slab_unreclaimable 7604
nr_page_table_pages 3105
nr_kernel_stack 175
nr_unstable 0
nr_bounce 0
nr_vmscan_write 0
nr_writeback_temp 0
nr_isolated_anon 0
nr_isolated_file 0
nr_shmem 260
nr_dirtied 1050
nr_written 938
numa_hit 962872
numa_miss 0
numa_foreign 0
numa_interleave 8617
numa_local 962872
numa_other 0
nr_anon_transparent_hugepages 0
[akpm@linux-foundation.org: no externs in .c files]
Cc: Michael Rubin <mrubin@google.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Architectures that implement their own show_mem() function did not pass
the filter argument to show_free_areas() to appropriately avoid emitting
the state of nodes that are disallowed in the current context. This patch
now passes the filter argument to show_free_areas() so those nodes are now
avoided.
This patch also removes the show_free_areas() wrapper around
__show_free_areas() and converts existing callers to pass an empty filter.
ia64 emits additional information for each node, so skip_free_areas_zone()
must be made global to filter disallowed nodes and it is converted to use
a nid argument rather than a zone for this use case.
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
* 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linux: (21 commits)
mach-ux500: set proper I2C platform data from MOP500s
i2c-nomadik: break out single messsage transmission
i2c-nomadik: reset the hw after status check
i2c-nomadik: remove the unnecessary delay
i2c-nomadik: change the TX and RX threshold
i2c-nomadik: add code to retry on timeout failure
i2c-nomadik: use pm_runtime API
i2c-nomadik: print abort cause only on abort tag
i2c-nomadik: correct adapter timeout initialization
i2c-nomadik: remove the redundant error message
i2c-nomadik: corrrect returned error numbers
i2c-nomadik: fix speed enumerator
i2c-nomadik: make i2c timeout specific per i2c bus
i2c-nomadik: add regulator support
i2c: i2c-sh_mobile bus speed platform data V2
i2c: i2c-sh_mobile clock string removal
i2c-eg20t: Support new device ML7223 IOH
i2c: tegra: Add de-bounce cycles.
i2c: tegra: fix repeated start handling
i2c: tegra: recover from spurious interrupt storm
'for-2639/i2c-tegra' and 'for-2639/i2c-nomadik2' into for-linus/2640/i2c
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm:
dlm: make plock operation killable
dlm: remove shared message stub for recovery
dlm: delayed reply message warning
dlm: Remove superfluous call to recalc_sigpending()
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (43 commits)
TOMOYO: Fix wrong domainname validation.
SELINUX: add /sys/fs/selinux mount point to put selinuxfs
CRED: Fix load_flat_shared_library() to initialise bprm correctly
SELinux: introduce path_has_perm
flex_array: allow 0 length elements
flex_arrays: allow zero length flex arrays
flex_array: flex_array_prealloc takes a number of elements, not an end
SELinux: pass last path component in may_create
SELinux: put name based create rules in a hashtable
SELinux: generic hashtab entry counter
SELinux: calculate and print hashtab stats with a generic function
SELinux: skip filename trans rules if ttype does not match parent dir
SELinux: rename filename_compute_type argument to *type instead of *con
SELinux: fix comment to state filename_compute_type takes an objname not a qstr
SMACK: smack_file_lock can use the struct path
LSM: separate LSM_AUDIT_DATA_DENTRY from LSM_AUDIT_DATA_PATH
LSM: split LSM_AUDIT_DATA_FS into _PATH and _INODE
SELINUX: Make selinux cache VFS RCU walks safe
SECURITY: Move exec_permission RCU checks into security modules
SELinux: security_read_policy should take a size_t not ssize_t
