Change-Id: I86e68c57846fe14de7620edf4c241ad7d9e46df2
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/106491
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Satya Popuri <spopuri@nvidia.com>
this commit exposes following power management parameter through
sysfs:
- clockgate_delay: delay after which module is clock gated after
it goes idle. this read/write attribute & unit is ms.
- powergate_delay: delay after which module is power gated after
it is clock gated. this is read/write attribute & unit is ms.
- refcount: current reference count on the module. this is
read-only attribute.
path is: /sys/devices/host1x/<device-name>/acm/ where
<device-name> = name of device node like gr2d or gr3d etc
Bug 845598
Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/108827
Reviewed-by: Francis Hart <fhart@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
mac80211 leaves sinfo->assoc_req_ies uninitialized, causing a random
pointer memory access in nl80211_send_station.
Instead of checking if the pointer is null, use sinfo->filled, like
the rest of the fields.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Remove version from nvhost_device name, and use a new field,
version, to distinguish between IP versions. This restores the
sysfs API for 3D clock scaling back to its original path.
Change-Id: I444ef728b7cab9e5ea3a08f3c7be0f1661209686
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/108501
Reviewed-by: Simone Willett <swillett@nvidia.com>
Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Reviewed-on: http://git-master/r/104076
The range parameters & slew rate from the blocks-camera are being passed
down to ODM and then to kernel. Generic structure added for sharing
the data between ODM and kernel instead of specific structure.
Bug 954874
Change-Id: I84656e36a5a2721c007de78aa5c20f5dfeb00361
Signed-off-by: Naren Bhat <nbhat@nvidia.com>
Reviewed-on: http://git-master/r/102077
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
- Adding flag to treat warning as error.
- Handling warnings of unused variable, structures and functions,
wrong return type, wrong type comparision.
Bug 949219
Change-Id: I9d02387ce1073c4e46f69d01669285aa3754f1d9
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104968
Adding CMD56 implementation.
Doing the following for manfid 0x90 and FW revisions 0x73 and
0x7b (both are non-standard custom FW):
1. Adding change to issue BKOPS_START whenever 20 seconds have gone
by without any slow write operations.
2. Adding change to issue CMD56 to refresh (custom feature) 1 block
whenever 60 seconds have gone by without any slow write operations.
Corresponding changes are already there in embedded branches:
http://git-master/r/#change,93247
http://git-master/r/#change,97555
Bug 847037.
Bug 874256.
Bug 963737.
Change-Id: Ie36b52620a75320abfedc36d1408647b36eddb46
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/102259
Reviewed-by: Luis Dib <ldib@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Changed USB1_UTMIP_XCVR_CFG0_0 register value with values
provided by sys-eng
* Implemented algo as described on Bug 974236
* Added variable 'usb_calib_mask' in 'usb platform data' to
make distinction on how many bits to mask in usb_calib_0 fuse
Bug 978870
Bug 972436
Change-Id: I71f27b0cf5ffe33a9896238b01c52650ca632352
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103308
Add builtin_host variable to tegra USB platform data structure
bug 947300
Change-Id: I0c5efd245a63c4331959f18faf316f1632e1801e
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/106982
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Change-Id: Ie391d6d11fad7b76b0bf5daff67ac46663651dc0
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-on: http://git-master/r/105265
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
drivers/media/video/tegra/nvavp/nvavp_dev.c
Change-Id: I7779b0ce58004f80cccf6193148ac49551ce5da5
Introducing LIGHTSENSOR_IOCTL_SET_DELAY to set the polling interval
Bug 993924
Change-Id: I3a4513799d3d96b9c3b701c1194b31562bf8f1e2
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/106185
Bug 992947
Change-Id: I0d1ecc9f8f042956cbe631779260a38573936616
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/105776
Add a macro of_match_ptr() that allows the .of_match_table
entry in the driver structures to be assigned without having
an #ifdef xxx NULL for the case that OF is not enabled
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
(cherry picked from commit 3a1e362e3f3cd571b3974b8d44b8e358ec7a098c)
Change-Id: Ib0365629efb6f203f8d87b487f66f99417e71bb3
Reviewed-on: http://git-master/r/105929
As gpio support for tps65910 is on gpio driver, registering
gpio support as the mfd sub devices instead of calling gpio_init()
from the core probe.
(cherry picked from commit 32df986e985921386b75b4bd1117102bf65fe095)
Change-Id: I631596313528ab192d7d8c2f376965ccc989c313
Reviewed-on: http://git-master/r/105926
This change removes the read/write callback functions in favor of common
regmap accessors inside the header file. This change also makes use of
regmap_read/write for single register access which maps better onto what this
driver actually needs.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
(Cherry-pick from mainline
3f7e82759c692df473675ed06fb90b20f1f225c3)
Change-Id: Ida79b196acf65ed14ff9fd2cc1f7c0048f99ba2b
Reviewed-on: http://git-master/r/105922
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
Adding support for device sleep through the external input control
signal "SLEEP".
Changing the SLEEP signal state can switch the device into SLEEP and
ACTIVE state.
Also adding sleep configuration for different resources so that they
should be keep on during sleep state of device.
(Cherry-picked from mainline
201cf052810d20814a77ca0e0045a2c1a3508a1f)
Change-Id: Iec18bfcc7a1df6442e833dccaa1d39407918f710
Reviewed-on: http://git-master/r/105920
Change the mechanism of enabling the force PWM mode through
regulator set mode. This can be dynamically configured now.
In the REGULATOR_MODE_FAST the force PWM is enabled and in
REGULATOR_MODE_NORMAL the force PWM is disabled.
Cherry-picked from mainline commit 9a00630
Change-Id: I39a77dbe5d0c4c2a5b81dbfe51163a65894bc98c
Reviewed-on: http://git-master/r/105832
Bug 949219
Change-Id: I91a67d30869e9800c483f112d58b9f76e2dbe361
Reviewed-on: http://git-master/r/103534
The PMIC device RC5T583 from RICOH supports 8 gpios.
Adding gpio driver for this device to access the pins
control through gpio library.
[grant.likely: slight cosmetic changes]
e9fe32bcadb8a7a40411d77f168abd45941b049b)
Change-Id: Id11f0dec229a92ce0ddcf606376ff83b6e14ca90
Reviewed-on: http://git-master/r/105885
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
The combination of commit 1b1247dd75aa5cf5fae54a3bec7280046e9c7957
"mfd: Add support for RICOH PMIC RC5T583"
and commit 6ffc3270210efa2bea526953a142ffc908f5bd86
"regulator: Add support for RICOH PMIC RC5T583 regulator"
are causing the i386 allmodconfig builds to fail with this:
ERROR: "rc5t583_update" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_set_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_clear_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_read" [drivers/regulator/rc5t583-regulator.ko] undefined!
and this:
ERROR: "rc5t583_ext_power_req_config" [drivers/regulator/rc5t583-regulator.ko] undefined!
For the 1st four, make the simple ops static inline, instead of
polluting the namespace with trivial exports. For the last one,
add an EXPORT_SYMBOL.
(cherry picked from commit 82ea267f7dc853a5e6a724916a70a10656efdfc2)
Change-Id: I7f03cc5c0005883eb8355170cdc7996a9c392091
Reviewed-on: http://git-master/r/105878
The RC5T583 PMIC from RICOH consists of 4 DCDC and 10
LDOs. This driver supports the control of different
regulator output through regulator interface.
This driver depends on MFD driver of RC5T583 and uses
mfd rc5t583 apis to communicate to device for accessing
different device's registers.
(Cherry-picked from mainline commit
6ffc3270210efa2bea526953a142ffc908f5bd86)
Change-Id: If6bcc9c987fc97ff6f0c61e53de715cd84d0151b
Reviewed-on: http://git-master/r/105877
Bug 986402
Change-Id: Id12540e31f8d7d9a04d764ed012310a685eafb8d
Signed-off-by: Tom Cherry <tcherry@nvidia.com>
Reviewed-on: http://git-master/r/104269
Change default PM QoS request value for minimum online cpus
parameter from 1 to 0. This is consistent with all other
PM_QOS_MAX type parameters, and allow to differentiate request
for 1 CPU and "no request".
Change-Id: I548449d0b7a443b77f7f065e1e1f10dffc5587ed
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/102119
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Implements a group hold so that the gain, frame length, and
coarse time can all be written in one ioctl call
Also fixes AEC manual control register value
Also implements bulk i2c send in the same way as ov5650
Bug 953910
Change-Id: Iaa2e8ac6c0156564920696afaa099321db6314f6
Signed-off-by: Pablo Ceballos <pceballos@nvidia.com>
Reviewed-on: http://git-master/r/94380
Reviewed-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Patrick Shehane <pshehane@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Implement per channel counter for jobs in each priority level. If
there are jobs active with higher priority than the one being
submitted, throttle.
Bug 926690
Change-Id: I5fed341e3f248325873b31d1c53bf57bf0a78074
Reviewed-on: http://git-master/r/104939
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Remove nvmap_pin_array() and nvmap_patch_word() and their utility
functions.
Bug 965206
Change-Id: I217a427934b0b99b5252b33ab3ac4eaaa8c7e076
Reviewed-on: http://git-master/r/104451
Replace usage of nvmap_pinarray_elem with own nvhost_reloc and
nvhost_reloc_shift structs.
Bug 965206
Change-Id: I90618d8a34d79156d8880d9925dadbf416353811
Reviewed-on: http://git-master/r/104450
Modify USB structures of platform data. Based on the new
platform data structures modifying the initialization in
board files.
Bug 887361
Change-Id: Ie6347a078c9a596a4debe21a353e127ddde35220
Reviewed-on: http://git-master/r/103597
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
- Implement new focuser ad5816 driver.
- Complies to latest NVC framework.
Bug 947792
Change-Id: I1661de027062d2a9b4112fd24dc255d810c7afa0
Signed-off-by: Sudhir Vyas <svyas@nvidia.com>
Reviewed-on: http://git-master/r/103131
- remove usage of custom interface of nvmap to patch the relocs and
and pin the gathers/relocs
- convert code that references nvmap_handle to nvmap_handle_ref
- add logic to pin and map only unique gathers and relocs
- rename nvhost_channel_gather to nvhost_job_gather, because it's
used in nvhost_job code only
Bug 965206
Change-Id: Iaa7fbac9e4a7b08c0a7c1e184b8dd3566e1edfe2
Reviewed-on: http://git-master/r/95299
Avoid multiple CONFIG_TEGRA_NVMAP ifdefs.
Change-Id: Ic186a8203d8b2291d3d39ce8b612b33bee16f531
Reviewed-on: http://git-master/r/103937
Add id for nct1008 compatible thermal sensor:
NCT72
Bug 961970
Change-Id: I792af664f73b6d1c8317a35c66330cf571cf3aba
Reviewed-on: http://git-master/r/100465
Signed-off-by: Chandler Zhang <chazhang@nvidia.com>
[danifu@nvidia.com: resolved conflicits in nct1008.c]
Signed-off-by: Daniel Fu <danifu@nvidia.com>
Reviewed-on: http://git-master/r/103581
- currently, function pointers are inside nvhost_device
- these functions abstract the device specific implementation
of a functionality per SoC
- move them to nvhost_driver so that nvhost_device can be
instantiated from arch code using board files/device trees
- add support to use single driver for multiple devices using
concept of id_table. this will be useful in supporting
multiple SoC devices binding single driver
- also add some notes about how device name is expected
Bug 871237
Change-Id: I4c75d7121d26c3bdc50f058e0d144d89ca0edbd9
Reviewed-on: http://git-master/r/100985
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Export nvmap_duplicate_handle_id() for usage by other drivers. It is
already being used in nvavp and tegradc, and nvhost needs it to be
able to move the relocation code to inside nvhost.
Bug 965206
Change-Id: I3f818d1faa967886e834aa457a99dfdb61bc6b85
Reviewed-on: http://git-master/r/103587
Adds a global alpha parameter to each window. It provides a default
alpha value for pixel formats that do not include alpha.
Change-Id: I5465864877a727b4daed0eb32fb8219e2ccb663e
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/101806
To prepare for kernel modularization, nvmap include file need to be
moved from mach-tegra/include to kernel/include.
Bug 854182
Change-Id: I9eab484830d114873f15a99fb93355aac3405709
Reviewed-on: http://git-master/r/102719
Enable output discharge always to have faster ramp-down
time.
bug 981330
Change-Id: I0a00ab38e9be631a58bc8b11148be5c3c508d119
Reviewed-on: http://git-master/r/102882
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Add EMC clock rate control to tegra_camera ioctl.
This change allows user space to change EMC clock requirement
for camera based on use case and resolution.
For example, video recording use case needs more than double
memory bandwidth of preview use case.
Bug 964635
Change-Id: Ibe5a77a810869b53b6e057f2ee62ebb96997c2f4
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/101274
Allow clk API users to simplify their cleanup paths by providing a
managed version of clk_get() and clk_put().
a8a97db984bdc5e89d42e41891543d2daaf314cb
Change-Id: Ib36c0c82063928937166b6014fca92025bc83878
Reviewed-on: http://git-master/r/102860
This driver supports ivoltage regulator driver for MAX8973
voltage regulator chip. The MAX8973 high-efficiency, three-phase,
DC-DC step-down switching regulator delivers up to 9A of
output current.
bug 981355
Change-Id: I6e4ff62139face4e47e2be269554a64c2654e74b
Reviewed-on: http://git-master/r/102148
The regulator module consists of 1 DCDC. The output voltage
is configurable and is meant for supply power to the core
voltage of Soc.
Change-Id: Ic62d100a588f7b6f1b30c11fd44a925c97393069
Reviewed-on: http://git-master/r/100653
A new trace event is added for tracing cpu suspend start and end
Change-Id: I2506e3aed0692c44fb4325e9d381cea53228b0c3
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Reviewed-on: http://git-master/r/101748
add ov5640 yuv sensor support - initial.
bug 921322
Change-Id: I813afa8963e39afe475f9fdd43152cfaf1a16ae1
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/99506
Add trace events for updating the syncpt value from hardware, and
wait check.
Change-Id: If17de153ae36c0665fe0af2f405dfe42f7fcd656
Reviewed-on: http://git-master/r/101524
Reviewed-by: Ken Adams <kadams@nvidia.com>
Add context switch to the ftrace dump.
Change-Id: I5df032273982b919fb94263cff38d8b8b6b6be45
Reviewed-on: http://git-master/r/101523
This implementation sets governor for a cpu using existing
cpufreq interfaces.
bug 871958
Change-Id: Ic4e7e2a2b0babaf1829b559b5db211666d449b86
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/97939
bug 949219
Change-Id: Ied38dc0ff7ade8b15561747cde6d552f2597e9e6
Reviewed-on: http://git-master/r/92307
