path: root/include
2011-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) tg3: Remove 5719 jumbo frames and TSO blocks tg3: Break larger frags into 4k chunks for 5719 tg3: Add tx BD budgeting code tg3: Consolidate code that calls tg3_tx_set_bd() tg3: Add partial fragment unmapping code tg3: Generalize tg3_skb_error_unmap() tg3: Remove short DMA check for 1st fragment tg3: Simplify tx bd assignments tg3: Reintroduce tg3_tx_ring_info ASIX: Use only 11 bits of header for data size ASIX: Simplify condition in rx_fixup() Fix cdc-phonet build bonding: reduce noise during init bonding: fix string comparison errors net: Audit drivers to identify those needing IFF_TX_SKB_SHARING cleared net: add IFF_SKB_TX_SHARED flag to priv_flags net: sock_sendmsg_nosec() is static forcedeth: fix vlans gianfar: fix bug caused by 87c288c6e9aa31720b72e2bc2d665e24e1653c3e gro: Only reset frag0 when skb can be pulled ...
2011-07-28Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (75 commits) md/raid10: handle further errors during fix_read_error better. md/raid10: Handle read errors during recovery better. md/raid10: simplify read error handling during recovery. md/raid10: record bad blocks due to write errors during resync/recovery. md/raid10: attempt to fix read errors during resync/check md/raid10: Handle write errors by updating badblock log. md/raid10: clear bad-block record when write succeeds. md/raid10: avoid writing to known bad blocks on known bad drives. md/raid10 record bad blocks as needed during recovery. md/raid10: avoid reading known bad blocks during resync/recovery. md/raid10 - avoid reading from known bad blocks - part 3 md/raid10: avoid reading from known bad blocks - part 2 md/raid10: avoid reading from known bad blocks - part 1 md/raid10: Split handle_read_error out from raid10d. md/raid10: simplify/reindent some loops. md/raid5: Clear bad blocks on successful write. md/raid5. Don't write to known bad block on doubtful devices. md/raid5: write errors should be recorded as bad blocks if possible. md/raid5: use bad-block log to improve handling of uncorrectable read errors. md/raid5: avoid reading from known bad blocks. ...
2011-07-27net: add IFF_SKB_TX_SHARED flag to priv_flagsNeil Horman
Pktgen attempts to transmit shared skbs to net devices, which can't be used by some drivers as they keep state information in skbs. This patch adds a flag marking drivers as being able to handle shared skbs in their tx path. Drivers are defaulted to being unable to do so, but calling ether_setup enables this flag, as 90% of the drivers calling ether_setup touch real hardware and can handle shared skbs. A subsequent patch will audit drivers to ensure that the flag is set properly Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Jiri Pirko <jpirko@redhat.com> CC: Robert Olsson <robert.olsson@its.uu.se> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Alexey Dobriyan <adobriyan@gmail.com> CC: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits) tpm_nsc: Fix bug when loading multiple TPM drivers tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block tpm: Fix compilation warning when CONFIG_PNP is not defined TOMOYO: Update kernel-doc. tpm: Fix a typo tpm_tis: Probing function for Intel iTPM bug tpm_tis: Fix the probing for interrupts tpm_tis: Delay ACPI S3 suspend while the TPM is busy tpm_tis: Re-enable interrupts upon (S3) resume tpm: Fix display of data in pubek sysfs entry tpm_tis: Add timeouts sysfs entry tpm: Adjust interface timeouts if they are too small tpm: Use interface timeouts returned from the TPM tpm_tis: Introduce durations sysfs entry tpm: Adjust the durations if they are too small tpm: Use durations returned from TPM TOMOYO: Enable conditional ACL. TOMOYO: Allow using argv[]/envp[] of execve() as conditions. TOMOYO: Allow using executable's realpath and symlink's target as conditions. TOMOYO: Allow using owner/group etc. of file objects as conditions. ... Fix up trivial conflict in security/tomoyo/realpath.c
2011-07-28md: load/store badblock list from v1.x metadataNeilBrown
Space must have been allocated when array was created. A feature flag is set when the badblock list is non-empty, to ensure old kernels don't load and trust the whole device. We only update the on-disk badblocklist when it has changed. If the badblocklist (or other metadata) is stored on a bad block, we don't cope very well. If metadata has no room for bad block, flag bad-blocks as disabled, and do the same for 0.90 metadata. Signed-off-by: NeilBrown <neilb@suse.de>
2011-07-27Merge branch 'nfs-for-3.1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'nfs-for-3.1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (44 commits) NFSv4: Don't use the delegation->inode in nfs_mark_return_delegation() nfs: don't use d_move in nfs_async_rename_done RDMA: Increasing RPCRDMA_MAX_DATA_SEGS SUNRPC: Replace xprt->resend and xprt->sending with a priority queue SUNRPC: Allow caller of rpc_sleep_on() to select priority levels SUNRPC: Support dynamic slot allocation for TCP connections SUNRPC: Clean up the slot table allocation SUNRPC: Initalise the struct xprt upon allocation SUNRPC: Ensure that we grab the XPRT_LOCK before calling xprt_alloc_slot pnfs: simplify pnfs files module autoloading nfs: document nfsv4 sillyrename issues NFS: Convert nfs4_set_ds_client to EXPORT_SYMBOL_GPL SUNRPC: Convert the backchannel exports to EXPORT_SYMBOL_GPL SUNRPC: sunrpc should not explicitly depend on NFS config options NFS: Clean up - simplify the switch to read/write-through-MDS NFS: Move the pnfs write code into pnfs.c NFS: Move the pnfs read code into pnfs.c NFS: Allow the nfs_pageio_descriptor to signal that a re-coalesce is needed NFS: Use the nfs_pageio_descriptor->pg_bsize in the read/write request NFS: Cache rpc_ops in struct nfs_pageio_descriptor ...
2011-07-27Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: Convert to DIV_ROUND_UP_SECTOR_T usage for sectors / dev_max_sectors kernel.h: Add DIV_ROUND_UP_ULL and DIV_ROUND_UP_SECTOR_T macro usage iscsi-target: Add iSCSI fabric support for target v4.1 iscsi: Add Serial Number Arithmetic LT and GT into iscsi_proto.h iscsi: Use struct scsi_lun in iscsi structs instead of u8[8] iscsi: Resolve iscsi_proto.h naming conflicts with drivers/target/iscsi
2011-07-27proc: make struct proc_dir_entry::name a terminal array rather than a pointerDavid Howells
Since __proc_create() appends the name it is given to the end of the PDE structure that it allocates, there isn't a need to store a name pointer. Instead we can just replace the name pointer with a terminal char array of _unspecified_ length. The compiler will simply append the string to statically defined variables of PDE type overlapping any hole at the end of the structure and, unlike specifying an explicitly _zero_ length array, won't give a warning if you try to statically initialise it with a string of more than zero length. Also, whilst we're at it: (1) Move namelen to end just prior to name and reduce it to a single byte (name shouldn't be longer than NAME_MAX). (2) Move pde_unload_lock two places further on so that if it's four bytes in size on a 64-bit machine, it won't cause an unused hole in the PDE struct. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (22 commits) ALSA: hda - Cirrus Logic CS421x support ALSA: Make pcm.h self-contained ALSA: hda - Allow codec-specific set_power_state ops ALSA: hda - Add post_suspend patch ops ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PM ALSA: hda - Make sure mute led reflects master mute state ALSA: hda - Fix invalid mute led state on resume of IDT codecs ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver" ALSA: hda - Add support of the 4 internal speakers on certain HP laptops ALSA: Make snd_pcm_debug_name usable outside pcm_lib ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parser ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context. ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: SAMSUNG: Modify I2S driver to support idma ASoC: davinci: add missing break statement ASoC: davinci: fix codec start and stop functions ASoC: dapm - add DAPM macro for external enum widgets ASoC: Acknowledge WM8962 interrupts before acting on them ASoC: sgtl5000: guide user when regulator support is needed ASoC: sgtl5000: refactor registering internal ldo ...
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (53 commits) Input: synaptics - fix reporting of min coordinates Input: tegra-kbc - enable key autorepeat Input: kxtj9 - fix locking typo in kxtj9_set_poll() Input: kxtj9 - fix bug in probe() Input: intel-mid-touch - remove pointless checking for variable 'found' Input: hp_sdc - staticize hp_sdc_kicker() Input: pmic8xxx-keypad - fix a leak of the IRQ during init failure Input: cy8ctmg110_ts - set reset_pin and irq_pin from platform data Input: cy8ctmg110_ts - constify i2c_device_id table Input: cy8ctmg110_ts - fix checking return value of i2c_master_send Input: lifebook - make dmi callback functions return 1 Input: atkbd - make dmi callback functions return 1 Input: gpio_keys - switch to using SIMPLE_DEV_PM_OPS Input: gpio_keys - add support for device-tree platform data Input: aiptek - remove double define Input: synaptics - set minimum coordinates as reported by firmware Input: synaptics - process button bits in AGM packets Input: synaptics - rename set_slot to be more descriptive Input: synaptics - fuzz position for touchpad with reduced filtering Input: synaptics - set resolution for MT_POSITION_X/Y axes ...
2011-07-27gro: Only reset frag0 when skb can be pulledHerbert Xu
Currently skb_gro_header_slow unconditionally resets frag0 and frag0_len. However, when we can't pull on the skb this leaves the GRO fields in an inconsistent state. This patch fixes this by only resetting those fields after the pskb_may_pull test. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: merge fchmod() and fchmodat() guts, kill ancient broken kludge xfs: fix misspelled S_IS...() xfs: get rid of open-coded S_ISREG(), etc. vfs: document locking requirements for d_move, __d_move and d_materialise_unique omfs: fix (mode & S_IFDIR) abuse btrfs: S_ISREG(mode) is not mode & S_IFREG... ima: fmode_t misspelled as mode_t... pci-label.c: size_t misspelled as mode_t jffs2: S_ISLNK(mode & S_IFMT) is pointless snd_msnd ->mode is fmode_t, not mode_t v9fs_iop_get_acl: get rid of unused variable vfs: dont chain pipe/anon/socket on superblock s_inodes list Documentation: Exporting: update description of d_splice_alias fs: add missing unlock in default_llseek()
2011-07-26Merge branch 'next/devel2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits) OMAP: Add debugfs node to show the summary of all clocks OMAP2+: hwmod: Follow the recommended PRCM module enable sequence OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming OMAP2+: PM: idle clkdms only if already in idle OMAP2+: clockdomain: add clkdm_in_hwsup() OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition() OMAP4: hwmod: Introduce the module control in hwmod control OMAP4: cm: Add two new APIs for modulemode control OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure OMAP4: hwmod data: Add PRM context register offset OMAP4: prm: Remove deprecated functions OMAP4: prm: Replace warm reset API with the offset based version OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros OMAP: hwmod: Wait the idle status to be disabled OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros OMAP2+: hwmod: Init clkdm field at boot time OMAP4: hwmod data: Add clock domain attribute OMAP4: clock data: Add missing divider selection for auxclks ...
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-26Merge branch 'next/fixes2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/fixes2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (24 commits) ASoC: omap: McBSP: fix build breakage on OMAP1 OMAP: hwmod: fix the i2c-reset timeout during bootup I2C: OMAP2+: add correct functionality flags to all omap2plus i2c dev_attr I2C: OMAP2+: Tag all OMAP2+ hwmod defintions with I2C IP revision I2C: OMAP1/OMAP2+: create omap I2C functionality flags for each cpu_... test I2C: OMAP2+: Introduce I2C IP versioning constants I2C: OMAP2+: increase omap_i2c_dev_attr flags from u8 to u32 I2C: OMAP2+: Set hwmod flags to only allow 16-bit accesses to i2c OMAP4: hwmod data: Change DSS main_clk scheme OMAP4: powerdomain data: Remove unsupported MPU powerdomain state OMAP4: clock data: Keep GPMC clocks always enabled and hardware managed OMAP4: powerdomain data: Fix core mem states and missing cefuse flag OMAP2+: PM: Initialise sleep_switch to a non-valid value OMAP4: hwmod data: Modify DSS opt clocks OMAP4: iommu: fix clock name omap: iovmm: s/sg_dma_len(sg)/sg->length/ omap: iommu: fix pte programming arm: omap3: cm-t35: fix slow path warning arm: omap3: cm-t35: minor comments fixes omap: ZOOM: QUART: Request reset GPIO ...
2011-07-26asm-generic/atomic.h: allow SMP peeps to leverage thisMike Frysinger
Only a few core funcs need to be implemented for SMP systems, so allow the arches to override them while getting the rest for free. At least, this is enough to allow the Blackfin SMP port to use things. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Arun Sharma <asharma@fb.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic/atomic.h: add atomic_set_mask() helperMike Frysinger
Since arches are expected to implement this guy, add a common version for people the same way as atomic_clear_mask is handled. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Arun Sharma <asharma@fb.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic/atomic.h: fix type used in atomic_clear_maskMike Frysinger
The atomic helpers are supposed to take an atomic_t pointer, not a random unsigned long pointer. So convert atomic_clear_mask over. While we're here, also add some nice documentation to the func. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Arun Sharma <asharma@fb.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic/atomic.h: simplify inc/dec test helpersMike Frysinger
We already declared inc/dec helpers, so we don't need to call the atomic_{add,sub}_return funcs directly. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Arun Sharma <asharma@fb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: Update comments in atomic.hArun Sharma
This clarifies the differences between <linux/atomic.h> and <asm-generic/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Suggested-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26fault-injection: use debugfs_remove_recursiveAkinobu Mita
Use debugfs_remove_recursive() to simplify initialization and deinitialization of fault injection debugfs files. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26fault-injection: remove nonexistent function externAkinobu Mita
should_fail_srandom() does not exist. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ramoops: make record_size a module parameterSergiu Iordache
The size of the dump is currently set using the RECORD_SIZE macro which is set to a page size. This patch makes the record size a module parameter and allows it to be set through platform data as well to allow larger dumps if needed. Signed-off-by: Sergiu Iordache <sergiu@chromium.org> Acked-by: Marco Stornelli <marco.stornelli@gmail.com> Cc: "Ahmed S. Darwish" <darwish.07@gmail.com> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ramoops: move dump_oops into platform dataSergiu Iordache
The platform driver currently allows setting the mem_size and mem_address. ince dump_oops is also a module parameter it would be more consistent if it could be set through platform data as well. Signed-off-by: Sergiu Iordache <sergiu@chromium.org> Acked-by: Marco Stornelli <marco.stornelli@gmail.com> Cc: "Ahmed S. Darwish" <darwish.07@gmail.com> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26panic, vt: do not force oops output when panic_timeout < 0Mandeep Singh Baines
Don't force output if you intend to reboot immediately. In this patch, I'm disabling the functionality enabled by vc->vc_panic_force_write if panic_timeout < 0 (i.e. no timeout). vc_panic_force_write is only enabled for fb video consoles if the FBINFO_CAN_FORCE_OUTPUT flag is set. For our application, we're using ram_oops to preserved the panic in memory. We want to reliably, and as fast as possible, machine_restart. The vc_panic_force_write flag results in a bunch of graphics driver code to be invoked which slows down restart and decreases reliability. Since we're already storing the panic in RAM and are going to reboot immediately, there is no benefit in mode switching back to the vc in order to display the panic output. The log buffer will get flushed by the console_unblank() call so remote management consoles should see all output. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Olaf Hering <olaf@aepfle.de> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Dave Airlie <airlied@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26include/linux/dma-mapping.h: remove DMA_xxBIT_MASK macrosWANG Cong
git grep shows there are no users in tree, so we can remove them safely. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ipc: introduce shm_rmid_forced sysctlVasiliy Kulikov
Add support for the shm_rmid_forced sysctl. If set to 1, all shared memory objects in current ipc namespace will be automatically forced to use IPC_RMID. The POSIX way of handling shmem allows one to create shm objects and call shmdt(), leaving shm object associated with no process, thus consuming memory not counted via rlimits. With shm_rmid_forced=1 the shared memory object is counted at least for one process, so OOM killer may effectively kill the fat process holding the shared memory. It obviously breaks POSIX - some programs relying on the feature would stop working. So set shm_rmid_forced=1 only if you're sure nobody uses "orphaned" memory. Use shm_rmid_forced=0 by default for compatability reasons. The feature was previously impemented in -ow as a configure option. [akpm@linux-foundation.org: fix documentation, per Randy] [akpm@linux-foundation.org: fix warning] [akpm@linux-foundation.org: readability/conventionality tweaks] [akpm@linux-foundation.org: fix shm_rmid_forced/shm_forced_rmid confusion, use standard comment layout] Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serge.hallyn@canonical.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Solar Designer <solar@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26cpumask: add cpumask_var_t documentationKOSAKI Motohiro
cpumask_var_t has one notable difference from cpumask_t. Add the explanation. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Thiago Farina <tfransosi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26cpusets: randomize node rotor used in cpuset_mem_spread_node()Michal Hocko
[ This patch has already been accepted as commit 0ac0c0d0f837 but later reverted (commit 35926ff5fba8) because it itroduced arch specific __node_random which was defined only for x86 code so it broke other archs. This is a followup without any arch specific code. Other than that there are no functional changes.] Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] [mhocko@suse.cz: Make it arch independent] [akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Menage <menage@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: add memory.vmscan_statKAMEZAWA Hiroyuki
The commit log of 0ae5e89c60c9 ("memcg: count the soft_limit reclaim in...") says it adds scanning stats to memory.stat file. But it doesn't because we considered we needed to make a concensus for such new APIs. This patch is a trial to add memory.scan_stat. This shows - the number of scanned pages(total, anon, file) - the number of rotated pages(total, anon, file) - the number of freed pages(total, anon, file) - the number of elaplsed time (including sleep/pause time) for both of direct/soft reclaim. The biggest difference with oringinal Ying's one is that this file can be reset by some write, as # echo 0 ...../memory.scan_stat Example of output is here. This is a result after make -j 6 kernel under 300M limit. [kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.scan_stat [kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.vmscan_stat scanned_pages_by_limit 9471864 scanned_anon_pages_by_limit 6640629 scanned_file_pages_by_limit 2831235 rotated_pages_by_limit 4243974 rotated_anon_pages_by_limit 3971968 rotated_file_pages_by_limit 272006 freed_pages_by_limit 2318492 freed_anon_pages_by_limit 962052 freed_file_pages_by_limit 1356440 elapsed_ns_by_limit 351386416101 scanned_pages_by_system 0 scanned_anon_pages_by_system 0 scanned_file_pages_by_system 0 rotated_pages_by_system 0 rotated_anon_pages_by_system 0 rotated_file_pages_by_system 0 freed_pages_by_system 0 freed_anon_pages_by_system 0 freed_file_pages_by_system 0 elapsed_ns_by_system 0 scanned_pages_by_limit_under_hierarchy 9471864 scanned_anon_pages_by_limit_under_hierarchy 6640629 scanned_file_pages_by_limit_under_hierarchy 2831235 rotated_pages_by_limit_under_hierarchy 4243974 rotated_anon_pages_by_limit_under_hierarchy 3971968 rotated_file_pages_by_limit_under_hierarchy 272006 freed_pages_by_limit_under_hierarchy 2318492 freed_anon_pages_by_limit_under_hierarchy 962052 freed_file_pages_by_limit_under_hierarchy 1356440 elapsed_ns_by_limit_under_hierarchy 351386416101 scanned_pages_by_system_under_hierarchy 0 scanned_anon_pages_by_system_under_hierarchy 0 scanned_file_pages_by_system_under_hierarchy 0 rotated_pages_by_system_under_hierarchy 0 rotated_anon_pages_by_system_under_hierarchy 0 rotated_file_pages_by_system_under_hierarchy 0 freed_pages_by_system_under_hierarchy 0 freed_anon_pages_by_system_under_hierarchy 0 freed_file_pages_by_system_under_hierarchy 0 elapsed_ns_by_system_under_hierarchy 0 total_xxxx is for hierarchy management. This will be useful for further memcg developments and need to be developped before we do some complicated rework on LRU/softlimit management. This patch adds a new struct memcg_scanrecord into scan_control struct. sc->nr_scanned at el is not designed for exporting information. For example, nr_scanned is reset frequentrly and incremented +2 at scanning mapped pages. To avoid complexity, I added a new param in scan_control which is for exporting scanning score. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Andrew Bresticker <abrestic@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: consolidate memory cgroup lru stat functionsKAMEZAWA Hiroyuki
In mm/memcontrol.c, there are many lru stat functions as.. mem_cgroup_zone_nr_lru_pages mem_cgroup_node_nr_file_lru_pages mem_cgroup_nr_file_lru_pages mem_cgroup_node_nr_anon_lru_pages mem_cgroup_nr_anon_lru_pages mem_cgroup_node_nr_unevictable_lru_pages mem_cgroup_nr_unevictable_lru_pages mem_cgroup_node_nr_lru_pages mem_cgroup_nr_lru_pages mem_cgroup_get_local_zonestat Some of them are under #ifdef MAX_NUMNODES >1 and others are not. This seems bad. This patch consolidates all functions into mem_cgroup_zone_nr_lru_pages() mem_cgroup_node_nr_lru_pages() mem_cgroup_nr_lru_pages() For these functions, "which LRU?" information is passed by a mask. example: mem_cgroup_nr_lru_pages(mem, BIT(LRU_ACTIVE_ANON)) And I added some macro as ALL_LRU, ALL_LRU_FILE, ALL_LRU_ANON. example: mem_cgroup_nr_lru_pages(mem, ALL_LRU) BTW, considering layout of NUMA memory placement of counters, this patch seems to be better. Now, when we gather all LRU information, we scan in following orer for_each_lru -> for_each_node -> for_each_zone. This means we'll touch cache lines in different node in turn. After patch, we'll scan for_each_node -> for_each_zone -> for_each_lru(mask) Then, we'll gather information in the same cacheline at once. [akpm@linux-foundation.org: fix warnigns, build error] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: export memory cgroup's swappiness with mem_cgroup_swappiness()KAMEZAWA Hiroyuki
Each memory cgroup has a 'swappiness' value which can be accessed by get_swappiness(memcg). The major user is try_to_free_mem_cgroup_pages() and swappiness is passed by argument. It's propagated by scan_control. get_swappiness() is a static function but some planned updates will need to get swappiness from files other than memcontrol.c This patch exports get_swappiness() as mem_cgroup_swappiness(). With this, we can remove the argument of swapiness from try_to_free... and drop swappiness from scan_control. only memcg uses it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (23 commits) ceph: document unlocked d_parent accesses ceph: explicitly reference rename old_dentry parent dir in request ceph: document locking for ceph_set_dentry_offset ceph: avoid d_parent in ceph_dentry_hash; fix ceph_encode_fh() hashing bug ceph: protect d_parent access in ceph_d_revalidate ceph: protect access to d_parent ceph: handle racing calls to ceph_init_dentry ceph: set dir complete frag after adding capability rbd: set blk_queue request sizes to object size ceph: set up readahead size when rsize is not passed rbd: cancel watch request when releasing the device ceph: ignore lease mask ceph: fix ceph_lookup_open intent usage ceph: only link open operations to directory unsafe list if O_CREAT|O_TRUNC ceph: fix bad parent_inode calc in ceph_lookup_open ceph: avoid carrying Fw cap during write into page cache libceph: don't time out osd requests that haven't been received ceph: report f_bfree based on kb_avail rather than diffing. ceph: only queue capsnap if caps are dirty ceph: fix snap writeback when racing with writes ...
2011-07-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t ext3.txt: update the links in the section "useful links" to the latest ones ext3: Fix data corruption in inodes with journalled data ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get ext3: Fix compilation with -DDX_DEBUG quota: Remove unused declaration jbd: Use WRITE_SYNC in journal checkpoint. jbd: Fix oops in journal_remove_journal_head() ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs() ext3/ioctl.c: silence sparse warnings about different address spaces ext3/ext4 Documentation: remove bh/nobh since it has been deprecated ext3: Improve truncate error handling ext3: use proper little-endian bitops ext2: include fs.h into ext2_fs.h ext3: Fix oops in ext3_try_to_allocate_with_rsv() jbd: fix a bug of leaking jh->b_jcount jbd: remove dependency on __GFP_NOFAIL ext3: Convert ext3 to new truncate calling convention jbd: Add fixed tracepoints ext3: Add fixed tracepoints Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and new fixed tracepoints.
2011-07-26libceph: don't time out osd requests that haven't been receivedSage Weil
Keep track of when an outgoing message is ACKed (i.e., the server fully received it and, presumably, queued it for processing). Time out OSD requests only if it's been too long since they've been received. This prevents timeouts and connection thrashing when the OSDs are simply busy and are throttling the requests they read off the network. Reviewed-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-07-26Merge branch 'x86-olpc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-olpc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc-xo15-sci: Enable EC wakeup capability x86, olpc: Fix dependency on POWER_SUPPLY x86, olpc: Add XO-1.5 SCI driver x86, olpc: Add XO-1 RTC driver x86, olpc-xo1-sci: Propagate power supply/battery events x86, olpc-xo1-sci: Add lid switch functionality x86, olpc-xo1-sci: Add GPE handler and ebook switch functionality x86, olpc: EC SCI wakeup mask functionality x86, olpc: Add XO-1 SCI driver and power button control x86, olpc: Add XO-1 suspend/resume support x86, olpc: Rename olpc-xo1 to olpc-xo1-pm x86, olpc: Move CS5536-related constants to cs5535.h x86, olpc: Add missing elements to device tree
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback: (27 commits) mm: properly reflect task dirty limits in dirty_exceeded logic writeback: don't busy retry writeback on new/freeing inodes writeback: scale IO chunk size up to half device bandwidth writeback: trace global_dirty_state writeback: introduce max-pause and pass-good dirty limits writeback: introduce smoothed global dirty limit writeback: consolidate variable names in balance_dirty_pages() writeback: show bdi write bandwidth in debugfs writeback: bdi write bandwidth estimation writeback: account per-bdi accumulated written pages writeback: make writeback_control.nr_to_write straight writeback: skip tmpfs early in balance_dirty_pages_ratelimited_nr() writeback: trace event writeback_queue_io writeback: trace event writeback_single_inode writeback: remove .nonblocking and .encountered_congestion writeback: remove writeback_control.more_io writeback: skip balance_dirty_pages() for in-memory fs writeback: add bdi_dirty_limit() kernel-doc writeback: avoid extra sync work at enqueue time writeback: elevate queue_io() into wb_writeback() ... Fix up trivial conflicts in fs/fs-writeback.c and mm/filemap.c
2011-07-26vfs: dont chain pipe/anon/socket on superblock s_inodes listEric Dumazet
Workloads using pipes and sockets hit inode_sb_list_lock contention. superblock s_inodes list is needed for quota, dirty, pagecache and fsnotify management. pipe/anon/socket fs are clearly not candidates for these. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (135 commits) drm/radeon/kms: fix DP training for DPEncoderService revision bigger than 1.1 drm/radeon/kms: add missing vddci setting on NI+ drm/radeon: Add a rmb() in IH processing drm/radeon: ATOM Endian fix for atombios_crtc_program_pll() drm/radeon: Fix the definition of RADEON_BUF_SWAP_32BIT drm/radeon: Do an MMIO read on interrupts when not uisng MSIs drm/radeon: Writeback endian fixes drm/radeon: Remove a bunch of useless _iomem casts drm/gem: add support for private objects DRM: clean up and document parsing of video= parameter DRM: Radeon: Fix section mismatch. drm: really make debug levels match in edid failure code drm/radeon/kms: fix i2c map for rv250/280 drm/nouveau/gr: disable fifo access and idle before suspend ctx unload drm/nouveau: pass flag to engine fini() method on suspend drm/nouveau: replace nv04_graph_fifo_access() use with direct reg bashing drm/nv40/gr: rewrite/split context takedown functions drm/nouveau: detect disabled device in irq handler and return IRQ_NONE drm/nouveau: ignore connector type when deciding digital/analog on DVI-I drm/nouveau: Add a quirk for Gigabyte NX86T ...
2011-07-26Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-07-26ALSA: Make pcm.h self-containedTakashi Iwai
Move the macros depending on snd_mask_min() and co out of pcm.h into pcm_params.h. Otherwise using some params_*() macros will give comiple errors without inclusion of pcm_params.h. Also use hw_param_interval_c() and hw_param_mask_c() for const pointer. Reported-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-26kernel.h: Add DIV_ROUND_UP_ULL and DIV_ROUND_UP_SECTOR_T macro usageNicholas Bellinger
Add new DIV_ROUND_UP_SECTOR_T macro usage for 32-bit architectures requiring a new DIV_ROUND_UP_ULL, and existing 64-bit usage with DIV_ROUND_UP. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
2011-07-25Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (26 commits) amba pl011: workaround for uart registers lockup n_gsm: fix the wrong FCS handling pch_uart: add missing comment about OKI ML7223 pch_uart: Add MSI support tty: fix "IRQ45: nobody cared" PTI feature to allow user to name and mark masterchannel request. 0 for o PTI Makefile bug. tty: serial: samsung.c remove legacy PM code. SERIAL: SC26xx: Fix link error. serial: mrst_max3110: initialize waitqueue earlier mrst_max3110: Change max missing message priority. tty: s5pv210: Add delay loop on fifo reset function for UART tty/serial: Fix XSCALE serial ports, e.g. ce4100 serial: bfin_5xx: fix off-by-one with resource size drivers/tty: use printk_ratelimited() instead of printk_ratelimit() tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structs tty: n_gsm: Add raw-ip support tty: n_gsm: expose gsmtty device nodes at ldisc open time pch_phub: Fix register miss-setting issue serial: 8250, increase PASS_LIMIT ...
2011-07-25Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (115 commits) EHCI: fix direction handling for interrupt data toggles USB: serial: add IDs for WinChipHead USB->RS232 adapter USB: OHCI: fix another regression for NVIDIA controllers usb: gadget: m66592-udc: add pullup function usb: gadget: m66592-udc: add function for external controller usb: gadget: r8a66597-udc: add pullup function usb: renesas_usbhs: support multi driver usb: renesas_usbhs: inaccessible pipe is not an error usb: renesas_usbhs: care buff alignment when dma handler USB: PL2303: correctly handle baudrates above 115200 usb: r8a66597-hcd: fixup USB_PORT_STAT_C_SUSPEND shift usb: renesas_usbhs: compile/config are rescued usb: renesas_usbhs: fixup comment-out usb: update email address in ohci-sh and r8a66597-hcd usb: r8a66597-hcd: add function for external controller EHCI: only power off port if over-current is active USB: mon: Allow to use usbmon without debugfs USB: EHCI: go back to using the system clock for QH unlinks ehci: add pci quirk for Ordissimo and RM Slate 100 too ehci: refactor pci quirk to use standard dmi_check_system method ... Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
