path: root/include
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: remove inode_add_to_list/__inode_add_to_listChristoph Hellwig
Split up inode_add_to_list/__inode_add_to_list. Locking for the two lists will be split soon so these helpers really don't buy us much anymore. The __ prefixes for the sb list helpers will go away soon, but until inode_lock is gone we'll need them to distinguish between the locked and unlocked variants. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: Implement lazy LRU updates for inodesNick Piggin
Convert the inode LRU to use lazy updates to reduce lock and cacheline traffic. We avoid moving inodes around in the LRU list during iget/iput operations so these frequent operations don't need to access the LRUs. Instead, we defer the refcount checks to reclaim-time and use a per-inode state flag, I_REFERENCED, to tell reclaim that iget has touched the inode in the past. This means that only reclaim should be touching the LRU with any frequency, hence significantly reducing lock acquisitions and the amount contention on LRU updates. This also removes the inode_in_use list, which means we now only have one list for tracking the inode LRU status. This makes it much simpler to split out the LRU list operations under it's own lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: Convert nr_inodes and nr_unused to per-cpu countersDave Chinner
The number of inodes allocated does not need to be tied to the addition or removal of an inode to/from a list. If we are not tied to a list lock, we could update the counters when inodes are initialised or destroyed, but to do that we need to convert the counters to be per-cpu (i.e. independent of a lock). This means that we have the freedom to change the list/locking implementation without needing to care about the counters. Based on a patch originally from Eric Dumazet. [AV: cleaned up a bit, fixed build breakage on weird configs Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25list.h: new helper - hlist_add_fake()Al Viro
Make node look as if it was on hlist, with hlist_del() working correctly. Usable without any locking... Convert a couple of places where we want to do that to inode->i_hash. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: inode_unhashed()Al Viro
note: for race-free uses you inode_lock held Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25unexport invalidate_inodesAl Viro
2010-10-25vfs: introduce FMODE_UNSIGNED_OFFSET for allowing negative f_posKAMEZAWA Hiroyuki
Now, rw_verify_area() checsk f_pos is negative or not. And if negative, returns -EINVAL. But, some special files as /dev/(k)mem and /proc/<pid>/mem etc.. has negative offsets. And we can't do any access via read/write to the file(device). So introduce FMODE_UNSIGNED_OFFSET to allow negative file offsets. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: allow for more than 2^31 filesEric Dumazet
Andrew, Could you please review this patch, you probably are the right guy to take it, because it crosses fs and net trees. Note : /proc/sys/fs/file-nr is a read-only file, so this patch doesnt depend on previous patch (sysctl: fix min/max handling in __do_proc_doulongvec_minmax()) Thanks ! [PATCH V4] fs: allow for more than 2^31 files Robin Holt tried to boot a 16TB system and found af_unix was overflowing a 32bit value : <quote> We were seeing a failure which prevented boot. The kernel was incapable of creating either a named pipe or unix domain socket. This comes down to a common kernel function called unix_create1() which does: atomic_inc(&unix_nr_socks); if (atomic_read(&unix_nr_socks) > 2 * get_max_files()) goto out; The function get_max_files() is a simple return of files_stat.max_files. files_stat.max_files is a signed integer and is computed in fs/file_table.c's files_init(). n = (mempages * (PAGE_SIZE / 1024)) / 10; files_stat.max_files = n; In our case, mempages (total_ram_pages) is approx 3,758,096,384 (0xe0000000). That leaves max_files at approximately 1,503,238,553. This causes 2 * get_max_files() to integer overflow. </quote> Fix is to let /proc/sys/fs/file-nr & /proc/sys/fs/file-max use long integers, and change af_unix to use an atomic_long_t instead of atomic_t. get_max_files() is changed to return an unsigned long. get_nr_files() is changed to return a long. unix_nr_socks is changed from atomic_t to atomic_long_t, while not strictly needed to address Robin problem. Before patch (on a 64bit kernel) : # echo 2147483648 >/proc/sys/fs/file-max # cat /proc/sys/fs/file-max -18446744071562067968 After patch: # echo 2147483648 >/proc/sys/fs/file-max # cat /proc/sys/fs/file-max 2147483648 # cat /proc/sys/fs/file-nr 704 0 2147483648 Reported-by: Robin Holt <holt@sgi.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David Miller <davem@davemloft.net> Reviewed-by: Robin Holt <holt@sgi.com> Tested-by: Robin Holt <holt@sgi.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: mark destroy_inode staticChristoph Hellwig
Hugetlbfs used to need it, but after the destroy_inode and evict_inode changes it's not required anymore. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25Merge branch 'davinci-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci * 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (50 commits) davinci: fix remaining board support after io_pgoffst removal davinci: mityomapl138: make file local data static arm/davinci: remove duplicated include davinci: Initial support for Omapl138-Hawkboard davinci: MityDSP-L138/MityARM-1808 read MAC address from I2C Prom davinci: add tnetv107x touchscreen platform device input: add driver for tnetv107x touchscreen controller davinci: add keypad config for tnetv107x evm board davinci: add tnetv107x keypad platform device input: add driver for tnetv107x on-chip keypad controller net: davinci_emac: cleanup unused cpdma code net: davinci_emac: switch to new cpdma layer net: davinci_emac: separate out cpdma code net: davinci_emac: cleanup unused mdio emac code omap: cleanup unused davinci mdio arch code davinci: cleanup mdio arch code and switch to phy_id net: davinci_emac: switch to new mdio omap: add mdio platform devices davinci: add mdio platform devices net: davinci_emac: separate out davinci mdio ... Fix up trivial conflict in drivers/input/keyboard/Kconfig (two entries added next to each other - one from the davinci merge, one from the input merge)
2010-10-25Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (48 commits) [S390] topology: export cpu topology via proc/sysinfo [S390] topology: move topology sysinfo code [S390] topology: clean up facility detection [S390] cleanup facility list handling [S390] enable ARCH_DMA_ADDR_T_64BIT with 64BIT [S390] dasd: ignore unsolicited interrupts for DIAG [S390] kvm: Enable z196 instruction facilities [S390] dasd: fix unsolicited interrupt recognition [S390] dasd: fix use after free in dbf [S390] kvm: Fix badness at include/asm/mmu_context.h:83 [S390] cio: fix I/O cancel function [S390] topology: change default [S390] smp: use correct cpu address in print_cpu_info() [S390] remove ieee_instruction_pointer from thread_struct [S390] cleanup system call parameter setup [S390] correct alignment of cpuid structure [S390] cleanup lowcore access from external interrupts [S390] cleanup lowcore access from program checks [S390] pgtable: move pte_mkhuge() from hugetlb.h to pgtable.h [S390] fix SIGBUS handling ...
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: uwb: Orphan the UWB and WUSB subsystems uwb: Remove the WLP subsystem and drivers
2010-10-25Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mtd/m25p80: add support to parse the partitions by OF node of/irq: of_irq.c needs to include linux/irq.h of/mips: Cleanup some include directives/files. of/mips: Add device tree support to MIPS of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch of/device: Rework to use common platform_device_alloc() for allocating devices of/xsysace: Fix OF probing on little-endian systems of: use __be32 types for big-endian device tree data of/irq: remove references to NO_IRQ in drivers/of/platform.c of/promtree: add package-to-path support to pdt of/promtree: add of_pdt namespace to pdt code of/promtree: no longer call prom_ functions directly; use an ops structure of/promtree: make drivers/of/pdt.c no longer sparc-only sparc: break out some PROM device-tree building code out into drivers/of of/sparc: convert various prom_* functions to use phandle sparc: stop exporting openprom.h header powerpc, of_serial: Endianness issues setting up the serial ports of: MTD: Fix OF probing on little-endian systems of: GPIO: Fix OF probing on little-endian systems
2010-10-25Coda: replace BKL with mutexYoshihisa Abe
Replace the BKL with a mutex to protect the venus_comm structure which binds the mountpoint with the character device and holds the upcall queues. Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Coda: push BKL regions into coda_upcall()Yoshihisa Abe
Now that shared inode state is locked using the cii->c_lock, the BKL is only used to protect the upcall queues used to communicate with the userspace cache manager. The remaining state is all local and we can push the lock further down into coda_upcall(). Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Coda: add spin lock to protect accesses to struct coda_inode_info.Yoshihisa Abe
We mostly need it to protect cached user permissions. The c_flags field is advisory, reading the wrong value is harmless and in the worst case we hit a slow path where we have to make an extra upcall to the userspace cache manager when revalidating a dentry or inode. Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (75 commits) Input: wacom - specify Cinitq supported tools Input: ab8500-ponkey - fix IRQ freeing in error path Input: adp5588-keys - use more obvious i2c_device_id name string Input: ad7877 - switch to using threaded IRQ Input: ad7877 - use attribute group to control visibility of attributes Input: serio - add support for PS2Mult multiplexer protocol Input: wacom - properly enable runtime PM Input: ad7877 - filter events where pressure is beyond the maximum Input: ad7877 - implement EV_KEY:BTN_TOUCH reporting Input: ad7877 - implement specified chip select behavior Input: hp680_ts_input - use cancel_delayed_work_sync() Input: mousedev - correct lockdep annotation Input: ads7846 - switch to using threaded IRQ Input: serio - support multiple child devices per single parent Input: synaptics - simplify pass-through port handling Input: add ROHM BU21013 touch panel controller support Input: omap4-keypad - wake-up on events & long presses Input: omap4-keypad - fix interrupt line configuration Input: omap4-keypad - SYSCONFIG register configuration Input: omap4-keypad - use platform device helpers ...
2010-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits) sh: i2c-sh7760: Replase from ctrl_* to __raw_* sh: clkfwk: Shuffle around to match the intc split up. sh: clkfwk: modify for_each_frequency end condition sh: fix clk_get() error handling sh: clkfwk: Fix fault in frequency iterator. sh: clkfwk: Add a helper for rate rounding by divisor ranges. sh: clkfwk: Abstract rate rounding helper. sh: clkfwk: support clock remapping. sh: pci: Convert to upper/lower_32_bits() helpers. sh: mach-sdk7786: Add support for the FPGA SRAM. sh: Provide a generic SRAM pool for tiny memories. sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786. sh: pci: Support slot 4 routing on SDK7786. sh: Fix up PMB locking. sh: mach-sdk7786: Add support for fpga gpios. sh: use pr_fmt for clock framework, too. sh: remove name and id from struct clk sh: free-without-alloc fix for sh_mobile_lcdcfb sh: perf: Set up perf_max_events. sh: perf: Support SH-X3 hardware counters. ... Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
2010-10-25Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: Revert "block: fix accounting bug on cross partition merges"
2010-10-25[S390] add support for nonquiescing sskeMartin Schwidefsky
Improve performance of the sske operation by using the nonquiescing variant if the affected page has no mappings established. On machines with no support for the new sske variant the mask bit will be ignored. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25uwb: Remove the WLP subsystem and driversDavid Vrabel
The only Wimedia LLC Protocol (WLP) hardware was an Intel i1480 chip with a beta release of firmware that was never commercially available as a product. This hardware and firmware is no longer available as Intel sold their UWB/WLP IP. I also see little prospect of other WLP capable hardware ever being available. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2010-10-25Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-25Merge branch 'topic/misc' into for-linusTakashi Iwai
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-24Merge branch 'devel' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/edac * 'devel' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/edac: (25 commits) i7300_edac: Properly initialize per-csrow memory size V4L/DVB: i7300_edac: better initialize page counts MAINTAINERS: Add maintainer for i7300-edac driver i7300-edac: CodingStyle cleanup i7300_edac: Improve comments i7300_edac: Cleanup: reorganize the file contents i7300_edac: Properly detect channel on CE errors i7300_edac: enrich FBD error info for corrected errors i7300_edac: enrich FBD error info for fatal errors i7300_edac: pre-allocate a buffer used to prepare err messages i7300_edac: Fix MTR x4/x8 detection logic i7300_edac: Make the debug messages coherent with the others i7300_edac: Cleanup: remove get_error_info logic i7300_edac: Add a code to cleanup error registers i7300_edac: Add support for reporting FBD errors i7300_edac: Properly detect the type of error correction i7300_edac: Detect if the device is on single mode i7300_edac: Adds detection for enhanced scrub mode on x8 i7300_edac: Clear the error bit after reading i7300_edac: Add error detection code for global errors ...
2010-10-24Revert "block: fix accounting bug on cross partition merges"Jens Axboe
This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327. Conflicts: include/linux/genhd.h It has numerous issues with the cleanup path and non-elevator devices. Revert it for now so we can come up with a clean version without rushing things. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: (27 commits) SLUB: Fix memory hotplug with !NUMA slub: Move functions to reduce #ifdefs slub: Enable sysfs support for !CONFIG_SLUB_DEBUG SLUB: Optimize slab_free() debug check slub: Move NUMA-related functions under CONFIG_NUMA slub: Add lock release annotation slub: Fix signedness warnings slub: extract common code to remove objects from partial list without locking SLUB: Pass active and inactive redzone flags instead of boolean to debug functions slub: reduce differences between SMP and NUMA Revert "Slub: UP bandaid" percpu: clear memory allocated with the km allocator percpu: use percpu allocator on UP too percpu: reduce PCPU_MIN_UNIT_SIZE to 32k vmalloc: pcpu_get/free_vm_areas() aren't needed on UP SLUB: Fix merged slab cache names Slub: UP bandaid slub: fix SLUB_RESILIENCY_TEST for dynamic kmalloc caches slub: Fix up missing kmalloc_cache -> kmem_cache_node case for memoryhotplug slub: Add dummy functions for the !SLUB_DEBUG case ...
2010-10-24Merge branch 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits) KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages KVM: Fix signature of kvm_iommu_map_pages stub KVM: MCE: Send SRAR SIGBUS directly KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED KVM: fix typo in copyright notice KVM: Disable interrupts around get_kernel_ns() KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address KVM: MMU: move access code parsing to FNAME(walk_addr) function KVM: MMU: audit: check whether have unsync sps after root sync KVM: MMU: audit: introduce audit_printk to cleanup audit code KVM: MMU: audit: unregister audit tracepoints before module unloaded KVM: MMU: audit: fix vcpu's spte walking KVM: MMU: set access bit for direct mapping KVM: MMU: cleanup for error mask set while walk guest page table KVM: MMU: update 'root_hpa' out of loop in PAE shadow path KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn() KVM: x86: Fix constant type in kvm_get_time_scale KVM: VMX: Add AX to list of registers clobbered by guest switch KVM guest: Move a printk that's using the clock before it's ready KVM: x86: TSC catchup mode ...
2010-10-24Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-viapro: Don't log nacks i2c/pca954x: Remove __devinit and __devexit from probe and remove functions MAINTAINERS: Add maintainer for PCA9541 I2C bus master selector driver i2c/mux: Driver for PCA9541 I2C Master Selector i2c: Optimize function i2c_detect() i2c: Discard warning message on device instantiation from user-space i2c-amd8111: Add proper error handling i2c: Change to new flag variable i2c: Remove unneeded inclusions of <linux/i2c-id.h> i2c: Let i2c_parent_is_i2c_adapter return the parent adapter i2c: Simplify i2c_parent_is_i2c_adapter i2c-pca-platform: Change device name of request_irq i2c: Fix Kconfig dependencies
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (47 commits) HID: fix mismerge in hid-lg HID: hidraw: fix window in hidraw_release HID: hid-sony: override usbhid_output_raw_report for Sixaxis HID: add absolute axis resolution calculation HID: force feedback support for Logitech RumblePad gamepad HID: support STmicroelectronics and Sitronix with hid-stantuml driver HID: magicmouse: Adjust major / minor axes to scale HID: Fix for problems with eGalax/DWAV multi-touch-screen HID: waltop: add support for Waltop Slim Tablet 12.1 inch HID: add NOGET quirk for AXIS 295 Video Surveillance Joystick HID: usbhid: remove unused hiddev_driver HID: magicmouse: Use hid-input parsing rather than bypassing it HID: trivial formatting fix HID: Add support for Logitech Speed Force Wireless gaming wheel HID: don't Send Feature Reports on Interrupt Endpoint HID: 3m: Adjust major / minor axes to scale HID: 3m: Correct touchscreen emulation HID: 3m: Convert to MT slots HID: 3m: Output proper orientation range HID: 3m: Adjust to sequential MT HID protocol ...
2010-10-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: Makefile - replace the use of <module>-objs with <module>-y crypto: hifn_795x - use cancel_delayed_work_sync() crypto: talitos - sparse check endian fixes crypto: talitos - fix checkpatch warning crypto: talitos - fix warning: 'alg' may be used uninitialized in this function crypto: cryptd - Adding the AEAD interface type support to cryptd crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES crypto: Kconfig - update broken web addresses crypto: omap-sham - Adjust DMA parameters crypto: fips - FIPS requires algorithm self-tests crypto: omap-aes - OMAP2/3 AES hw accelerator driver crypto: updates to enable omap aes padata: add missing __percpu markup in include/linux/padata.h MAINTAINERS: Add maintainer entries for padata/pcrypt
2010-10-24Merge branch 'master' into for-linusPekka Enberg
Conflicts: include/linux/percpu.h mm/percpu.c
2010-10-24i2c: Let i2c_parent_is_i2c_adapter return the parent adapterJean Delvare
This makes the calling site's code clearer IMHO. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Michael Lawnick <ml.lawnick@gmx.de>
2010-10-24i2c: Simplify i2c_parent_is_i2c_adapterJean Delvare
Only i2c devices can have their type set to i2c_adapter_type, so testing the bus type is redundant. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Michael Lawnick <ml.lawnick@gmx.de>
2010-10-24KVM: Fix signature of kvm_iommu_map_pages stubJan Kiszka
Breaks otherwise if CONFIG_IOMMU_API is not set. KVM-Stable-Tag. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: x86: Rename timer functionZachary Amsden
This just changes some names to better reflect the usage they will be given. Separated out to keep confusion to a minimum. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: Check for pending events before attempting injectionAvi Kivity
Instead of blindly attempting to inject an event before each guest entry, check for a possible event first in vcpu->requests. Sites that can trigger event injection are modified to set KVM_REQ_EVENT: - interrupt, nmi window opening - ppr updates - i8259 output changes - local apic irr changes - rflags updates - gif flag set - event set on exit This improves non-injecting entry performance, and sets the stage for non-atomic injection. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: MMU: Add infrastructure for two-level page walkerJoerg Roedel
This patch introduces a mmu-callback to translate gpa addresses in the walk_addr code. This is later used to translate l2_gpa addresses into l1_gpa addresses. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Expose level based interrupt capAlexander Graf
Now that we have all the level interrupt magic in place, let's expose the capability to user space, so it can make use of it! Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: MMU: rewrite audit_mappings_page() functionXiao Guangrong
There is a bugs in this function, we call gfn_to_pfn() and kvm_mmu_gva_to_gpa_read() in atomic context(kvm_mmu_audit() is called under the spinlock(mmu_lock)'s protection). This patch fix it by: - introduce gfn_to_pfn_atomic instead of gfn_to_pfn - get the mapping gfn from kvm_mmu_page_get_gfn() And it adds 'notrap' ptes check in unsync/direct sps Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: MMU: introduce gfn_to_page_many_atomic() functionXiao Guangrong
Introduce this function to get consecutive gfn's pages, it can reduce gup's overload, used by later patch Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: MMU: introduce hva_to_pfn_atomic functionXiao Guangrong
Introduce hva_to_pfn_atomic(), it's the fast path and can used in atomic context, the later patch will use it Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: PPC: Add get_pvinfo interface to query hypercall instructionsAlexander Graf
We need to tell the guest the opcodes that make up a hypercall through interfaces that are controlled by userspace. So we need to add a call for userspace to allow it to query those opcodes so it can pass them on. This is required because the hypercall opcodes can change based on the hypervisor conditions. If we're running in hardware accelerated hypervisor mode, a hypercall looks different from when we're running without hardware acceleration. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: Move kvm_guest_init out of generic codeAlexander Graf
Currently x86 is the only architecture that uses kvm_guest_init(). With PowerPC we're getting a second user, but the signature is different there and we don't need to export it, as it uses the normal kernel init framework. So let's move the x86 specific definition of that function over to the x86 specfic header file. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
