path: root/include
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Add helper functions for frequently used callbacksTakashi Iwai
Added helper functions for frequenty used callbacks: snd_ctl_boolean_mono_info() and snd_ctl_boolean_stereo_info() Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] snd-emu10k1: Add support for E-Mu 1616 PCI, 1616M PCI, 0404 PCI, E-MuJames Courtier-Dutton
Notebook. Description: The .device=0x0008 chips have new, but different EMU32 in/out channels. Driver updated to make use of these EMU32 channels. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-15Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (95 commits) [ARM] 4578/1: CM-x270: PCMCIA support [ARM] 4577/1: ITE 8152 PCI bridge support [ARM] 4576/1: CM-X270 machine support [ARM] pxa: Avoid pxa_gpio_mode() in gpio_direction_{in,out}put() [ARM] pxa: move pxa_set_mode() from pxa2xx_mainstone.c to mainstone.c [ARM] pxa: move pxa_set_mode() from pxa2xx_lubbock.c to lubbock.c [ARM] pxa: Make cpu_is_pxaXXX dependent on configuration symbols [ARM] pxa: PXA3xx base support [NET] smc91x: fix PXA DMA support code [SERIAL] Fix console initialisation ordering [ARM] pxa: tidy up arch/arm/mach-pxa/Makefile [ARM] Update arch/arm/Kconfig for drivers/Kconfig changes [ARM] 4600/1: fix kernel build failure with build-id-supporting binutils [ARM] 4599/1: Preserve ATAG list for use with kexec (2.6.23) [ARM] Rename consistent_sync() as dma_cache_maint() [ARM] 4572/1: ep93xx: add cirrus logic edb9307 support [ARM] 4596/1: S3C2412: Correct IRQs for SDI+CF and add decoding support [ARM] 4595/1: ns9xxx: define registers as void __iomem * instead of volatile u32 [ARM] 4594/1: ns9xxx: use the new gpio functions [ARM] 4593/1: ns9xxx: implement generic clockevents ...
2007-10-15Merge branch 'locks' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'locks' of git://linux-nfs.org/~bfields/linux: nfsd: remove IS_ISMNDLCK macro Rework /proc/locks via seq_files and seq_list helpers fs/locks.c: use list_for_each_entry() instead of list_for_each() NFS: clean up explicit check for mandatory locks AFS: clean up explicit check for mandatory locks 9PFS: clean up explicit check for mandatory locks GFS2: clean up explicit check for mandatory locks Cleanup macros for distinguishing mandatory locks Documentation: move locks.txt in filesystems/ locks: add warning about mandatory locking races Documentation: move mandatory locking documentation to filesystems/ locks: Fix potential OOPS in generic_setlease() Use list_first_entry in locks_wake_up_blocks locks: fix flock_lock_file() comment Memory shortage can result in inconsistent flocks state locks: kill redundant local variable locks: reverse order of posix_locks_conflict() arguments
2007-10-15Merge branch 'release' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of ssh://master.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] build fix for scatterlist
2007-10-15Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) [IPV6]: Consolidate the ip6_pol_route_(input|output) pair [TCP]: Make snd_cwnd_cnt 32-bit [TCP]: Update the /proc/net/tcp documentation [NETNS]: Don't panic on creating the namespace's loopback [NEIGH]: Ensure that pneigh_lookup is protected with RTNL [INET]: kmalloc+memset -> kzalloc in frag_alloc_queue [ISDN]: Fix compile with CONFIG_ISDN_X25 disabled. [IPV6]: Replace sk_buff ** with sk_buff * in input handlers [SELINUX]: Update for netfilter ->hook() arg changes. [INET]: Consolidate the xxx_put [INET]: Small cleanup for xxx_put after evictor consolidation [INET]: Consolidate the xxx_evictor [INET]: Consolidate the xxx_frag_destroy [INET]: Consolidate xxx_the secret_rebuild [INET]: Consolidate the xxx_frag_kill [INET]: Collect common frag sysctl variables together [INET]: Collect frag queues management objects together [INET]: Move common fields from frag_queues in one place. [TG3]: Fix performance regression on 5705. [ISDN]: Remove local copy of device name to make sure renames work. ...
2007-10-15[IA64] build fix for scatterlistTony Luck
include/scsi/scsi_eh.h:79: error: field `sense_sgl' has incomplete type x86 resolves this by including scatterlist.h from dma-mapping.h which seems as good a place as any. Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: use full RCU API Input: remove tsdev interface Input: add support for Blackfin BF54x Keypad controller Input: appletouch - another fix for idle reset logic HWMON: hdaps - switch to using input-polldev Input: add support for SEGA Dreamcast keyboard Input: omap-keyboard - don't pretend we support changing keymap Input: lifebook - fix X and Y axis range Input: usbtouchscreen - add support for GeneralTouch devices Input: fix open count handling in input interfaces Input: keyboard - add CapsShift lock Input: adbhid - produce all CapsLock key events Input: ALPS - add signature for ThinkPad R61 Input: jornada720_kbd - send MSC_SCAN events Input: add support for the HP Jornada 7xx (710/720/728) touchscreen Input: add support for HP Jornada 7xx onboard keyboard Input: add support for HP Jornada onboard keyboard (HP6XX) Input: ucb1400_ts - use schedule_timeout_uninterruptible Input: xpad - fix dependancy on LEDS class Input: auto-select INPUT for MAC_EMUMOUSEBTN option ... Resolved conflicts manually in drivers/hwmon/applesmc.c: converting from a class device to a device and converting to use input-polldev created a few apparently trivial clashes..
2007-10-15[TCP]: Make snd_cwnd_cnt 32-bitIlpo Järvinen
Very little point of having 32-bit snd_cnwd if this is not 32-bit as well, as a number of snd_cwnd incrementation formulas assume that snd_cwnd_cnt can be at least as large as snd_cwnd. Whether 32-bit is useful was discussed when e0ef57cc56c3c96 was made: http://marc.info/?l=linux-netdev&m=117218144409825&w=2 Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Replace sk_buff ** with sk_buff * in input handlersHerbert Xu
With all the users of the double pointers removed from the IPv6 input path, this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input handlers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_putPavel Emelyanov
These ones use the generic data types too, so move them in one place. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_evictorPavel Emelyanov
The evictors collect some statistics for ipv4 and ipv6, so make it return the number of evicted queues and account them all at once in the caller. The XXX_ADD_STATS_BH() macros are just for this case, but maybe there are places in code, that can make use of them as well. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_frag_destroyPavel Emelyanov
To make in possible we need to know the exact frag queue size for inet_frags->mem management and two callbacks: * to destoy the skb (optional, used in conntracks only) * to free the queue itself (mandatory, but later I plan to move the allocation and the destruction of frag_queues into the common place, so this callback will most likely be optional too). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate xxx_the secret_rebuildPavel Emelyanov
This code works with the generic data types as well, so move this into inet_fragment.c This move makes it possible to hide the secret_timer management and the secret_rebuild routine completely in the inet_fragment.c Introduce the ->hashfn() callback in inet_frags() to get the hashfun for a given inet_frag_queue() object. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Consolidate the xxx_frag_killPavel Emelyanov
Since now all the xxx_frag_kill functions now work with the generic inet_frag_queue data type, this can be moved into a common place. The xxx_unlink() code is moved as well. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Collect common frag sysctl variables togetherPavel Emelyanov
Some sysctl variables are used to tune the frag queues management and it will be useful to work with them in a common way in the future, so move them into one structure, moreover they are the same for all the frag management codes. I don't place them in the existing inet_frags object, introduced in the previous patch for two reasons: 1. to keep them in the __read_mostly section; 2. not to export the whole inet_frags objects outside. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Collect frag queues management objects togetherPavel Emelyanov
There are some objects that are common in all the places which are used to keep track of frag queues, they are: * hash table * LRU list * rw lock * rnd number for hash function * the number of queues * the amount of memory occupied by queues * secret timer Move all this stuff into one structure (struct inet_frags) to make it possible use them uniformly in the future. Like with the previous patch this mostly consists of hunks like - write_lock(&ipfrag_lock); + write_lock(&ip4_frags.lock); To address the issue with exporting the number of queues and the amount of memory occupied by queues outside the .c file they are declared in, I introduce a couple of helpers. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Move common fields from frag_queues in one place.Pavel Emelyanov
Introduce the struct inet_frag_queue in include/net/inet_frag.h file and place there all the common fields from three structs: * struct ipq in ipv4/ip_fragment.c * struct nf_ct_frag6_queue in nf_conntrack_reasm.c * struct frag_queue in ipv6/reassembly.c After this, replace these fields on appropriate structures with this structure instance and fix the users to use correct names i.e. hunks like - atomic_dec(&fq->refcnt); + atomic_dec(&fq->q.refcnt); (these occupy most of the patch) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[ISDN]: Remove local copy of device name to make sure renames work.Karsten Keil
Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPVS]: Replace local version of skb_make_writableHerbert Xu
This patch removes the IPVS-specific version of skb_make_writable and replaces it with the netfilter one. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Do not copy skb in skb_make_writableHerbert Xu
Now that all callers of netfilter can guarantee that the skb is not shared, we no longer have to copy the skb in skb_make_writable. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV4]: Change ip_defrag to return an integerHerbert Xu
Now that ip_frag always returns the packet given to it on input, we can change it to return an integer indicating error instead. This patch does that and updates all its callers accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[SKBUFF]: Add skb_morphHerbert Xu
This patch creates a new function skb_morph that's just like skb_clone except that it lets user provide the spare skb that will be overwritten by the one that's to be cloned. This will be used by IP fragment reassembly so that we get back the same skb that went in last (rather than the head skb that we get now which requires us to carry around double pointers all over the place). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15add new prom.h for AU1x00Yoichi Yuasa
Add new prom.h for AU1x00. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15Use dcr_host_t.base in dcr_unmap()Michael Ellerman
With the base stored in dcr_host_t, there's no need for callers to pass the dcr_n into dcr_unmap(). In fact this removes the possibility of them passing the incorrect value, which would then be iounmap()'ed. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15Add dcr_host_t.base in dcr_read()/dcr_write()Michael Ellerman
Now that all users of dcr_read()/dcr_write() add the dcr_host_t.base, we can save them the trouble and do it in dcr_read()/dcr_write(). As some background to why we just went through all this jiggery-pokery, benh sayeth: Initially the goal of the dcr_read/dcr_write routines was to operate like mfdcr/mtdcr which take absolute DCR numbers. The reason is that on 4xx hardware, indirect DCR access is a pain (goes through a table of instructions) and it's useful to have the compiler resolve an absolute DCR inline. We decided that wasn't worth the API bastardisation since most places where absolute DCR values are used are low level 4xx-only code which may as well continue using mfdcr/mtdcr, while the new API is designed for device "instances" that can exist on 4xx and Axon type platforms and may be located at variable DCR offsets. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15Add skb_is_gso_v6Brice Goglin
Add skb_is_gso_v6(). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15Merge branch 'pxa' into develRussell King
2007-10-15[ARM] 4577/1: ITE 8152 PCI bridge supportMike Rapoport
This patch provides driver for ITE 8152 PCI bridge. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] 4576/1: CM-X270 machine supportMike Rapoport
This patch provides core support for CM-X270 platform. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: Avoid pxa_gpio_mode() in gpio_direction_{in,out}put()Russell King
pxa_gpio_mode() is a universal call that fiddles with the GAFR (gpio alternate function register.) GAFR does not exist on PXA3 CPUs, but instead the alternate functions are controlled via the MFP support code. Platforms are expected to configure the MFP according to their needs in their platform support code rather than drivers. We extend this idea to the GAFR, and make the gpio_direction_*() functions purely operate on the GPIO level. This means platform support code is entirely responsible for configuring the GPIOs alternate functions on all PXA CPU types. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: Make cpu_is_pxaXXX dependent on configuration symbolsRussell King
Make the cpu_is_pxaXXX() macros define to zero when support for a particular CPU is disabled. This allows us to eliminate code for CPUs which aren't enabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: PXA3xx base supporteric miao
Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits) NFSv4: Fix a typo in nfs_inode_reclaim_delegation NFS: Add a boot parameter to disable 64 bit inode numbers NFS: nfs_refresh_inode should clear cache_validity flags on success NFS: Fix a connectathon regression in NFSv3 and NFSv4 NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode SUNRPC: Don't call xprt_release in call refresh SUNRPC: Don't call xprt_release() if call_allocate fails SUNRPC: Fix buggy UDP transmission [23/37] Clean up duplicate includes in [2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static SUNRPC: Use correct type in buffer length calculations SUNRPC: Fix default hostname created in rpc_create() nfs: add server port to rpc_pipe info file NFS: Get rid of some obsolete macros NFS: Simplify filehandle revalidation NFS: Ensure that nfs_link() returns a hashed dentry NFS: Be strict about dentry revalidation when doing exclusive create NFS: Don't zap the readdir caches upon error NFS: Remove the redundant nfs_reval_fsid() NFSv3: Always use directory post-op attributes in nfs3_proc_lookup ... Fix up trivial conflict due to sock_owned_by_user() cleanup manually in net/sunrpc/xprtsock.c
2007-10-15Merge branch 'v2.6.24-lockdep' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep * 'v2.6.24-lockdep' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep: lockdep: annotate dir vs file i_mutex lockdep: per filesystem inode lock class lockdep: annotate kprobes irq fiddling lockdep: annotate rcu_read_{,un}lock{,_bh} lockdep: annotate journal_start() lockdep: s390: connect the sysexit hook lockdep: x86_64: connect the sysexit hook lockdep: i386: connect the sysexit hook lockdep: syscall exit check lockdep: fixup mutex annotations lockdep: fix mismatched lockdep_depth/curr_chain_hash lockdep: Avoid /proc/lockdep & lock_stat infinite output lockdep: maintainers
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] update sn2_defconfig [IA64] Fix kernel hangup in kdump on INIT [IA64] Fix kernel panic in kdump on INIT [IA64] Remove vector from ia64_machine_kexec() [IA64] Fix race when multiple cpus go through MCA [IA64] Remove needless delay in MCA rendezvous [IA64] add driver for ACPI methods to call native firmware [IA64] abstract SAL_CALL wrapper to allow other firmware entry points [IA64] perfmon: Remove exit_pfm_fs() [IA64] tree-wide: Misc __cpu{initdata, init, exit} annotations
2007-10-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: (140 commits) sched: sync wakeups preempt too sched: affine sync wakeups sched: guest CPU accounting: maintain guest state in KVM sched: guest CPU accounting: maintain stats in account_system_time() sched: guest CPU accounting: add guest-CPU /proc/<pid>/stat fields sched: guest CPU accounting: add guest-CPU /proc/stat field sched: domain sysctl fixes: add terminator comment sched: domain sysctl fixes: do not crash on allocation failure sched: domain sysctl fixes: unregister the sysctl table before domains sched: domain sysctl fixes: use for_each_online_cpu() sched: domain sysctl fixes: use kcalloc() Make scheduler debug file operations const sched: enable wake-idle on CONFIG_SCHED_MC=y sched: reintroduce topology.h tunings sched: allow the immediate migration of cache-cold tasks sched: debug, improve migration statistics sched: debug: increase width of debug line sched: activate task_hot() only on fair-scheduled tasks sched: reintroduce cache-hot affinity sched: speed up context-switches a bit ...
2007-10-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits) [SCSI] gdth: fix CONFIG_ISA build failure [SCSI] esp_scsi: remove __dev{init,exit} [SCSI] gdth: !use_sg cleanup and use of scsi accessors [SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2 [SCSI] gdth: Setup proper per-command private data [SCSI] gdth: Remove gdth_ctr_tab[] [SCSI] gdth: switch to modern scsi host registration [SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes [SCSI] gdth: clean up host private data [SCSI] gdth: Remove virt hosts [SCSI] gdth: Reorder scsi_host_template intitializers [SCSI] gdth: kill gdth_{read,write}[bwl] wrappers [SCSI] gdth: Remove 2.4.x support, in-kernel changelog [SCSI] gdth: split out pci probing [SCSI] gdth: split out eisa probing [SCSI] gdth: split out isa probing gdth: Make one abuse of scsi_cmnd less obvious [SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation [SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution [SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE ...
2007-10-15Merge branch 'nfs-server-stable' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'nfs-server-stable' of git://linux-nfs.org/~bfields/linux: knfsd: query filesystem for NFSv4 getattr of FATTR4_MAXNAME knfsd: nfsv4 delegation recall should take reference on client knfsd: don't shutdown callbacks until nfsv4 client is freed knfsd: let nfsd manage timing out its own leases knfsd: Add source address to sunrpc svc errors knfsd: 64 bit ino support for NFS server svcgss: move init code into separate function knfsd: remove code duplication in nfsd4_setclientid() nfsd warning fix knfsd: fix callback rpc cred knfsd: move nfsv4 slab creation/destruction to module init/exit knfsd: spawn kernel thread to probe callback channel knfsd: nfs4 name->id mapping not correctly parsing negative downcall knfsd: demote some printk()s to dprintk()s knfsd: cleanup of nfsd4 cmp_* functions knfsd: delete code made redundant by map_new_errors nfsd: fix horrible indentation in nfsd_setattr nfsd: remove unused cache_for_each macro nfsd: tone down inaccurate dprintk
2007-10-15HID: fix HIDIOCGRDESC memory access in hidrawJiri Kosina
Fix bogus copying of data into userspace when HIDIOCGRDESC is issued. HID-transport layer makes sure that dev->hid->rdesc is not larger than HID_MAX_DESCRIPTOR_SIZE. Noticed-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15sched: guest CPU accounting: maintain stats in account_system_time()Laurent Vivier
modify account_system_time() to add cputime to cpustat->guest if we are running a VCPU. We add this cputime to cpustat->user instead of cpustat->system because this part of KVM code is in fact user code although it is executed in the kernel. We duplicate VCPU time between guest and user to allow an unmodified "top(1)" to display correct value. A modified "top(1)" is able to display good cpu user time and cpu guest time by subtracting cpu guest time from cpu user time. Update "gtime" in task_struct accordingly. Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: guest CPU accounting: add guest-CPU /proc/<pid>/stat fieldsLaurent Vivier
like for cpustat, introduce the "gtime" (guest time of the task) and "cgtime" (guest time of the task children) fields for the tasks. Modify signal_struct and task_struct. Modify /proc/<pid>/stat to display these new fields. Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: guest CPU accounting: add guest-CPU /proc/stat fieldLaurent Vivier
as recent CPUs introduce a third running state, after "user" and "system", we need a new field, "guest", in cpustat to store the time used by the CPU to run virtual CPU. Modify /proc/stat to display this new field. Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: enable wake-idle on CONFIG_SCHED_MC=yIngo Molnar
most multicore CPUs today have shared L2 caches, so tune things so that the spreading amongst cores is more aggressive. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: reintroduce topology.h tuningsIngo Molnar
reintroduce the 2.6.22 topology.h tunings again - they result in slightly better balancing. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: debug, improve migration statisticsIngo Molnar
add new migration statistics when SCHED_DEBUG and SCHEDSTATS is enabled. Available in /proc/<PID>/sched. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: reintroduce cache-hot affinityIngo Molnar
reintroduce a simplified version of cache-hot/cold scheduling affinity. This improves performance with certain SMP workloads, such as sysbench. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: prevent wakeup over-schedulingMike Galbraith
Prevent wakeup over-scheduling. Once a task has been preempted by a task of the same or lower priority, it becomes ineligible for repeated preemption by same until it has been ticked, or slept. Instead, the task is marked for preemption at the next tick. Tasks of higher priority still preempt immediately. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
