* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (41 commits)
Revert "Seperate read and write statistics of in_flight requests"
cfq-iosched: don't delay async queue if it hasn't dispatched at all
block: Topology ioctls
cfq-iosched: use assigned slice sync value, not default
cfq-iosched: rename 'desktop' sysfs entry to 'low_latency'
cfq-iosched: implement slower async initiate and queue ramp up
cfq-iosched: delay async IO dispatch, if sync IO was just done
cfq-iosched: add a knob for desktop interactiveness
Add a tracepoint for block request remapping
block: allow large discard requests
block: use normal I/O path for discard requests
swapfile: avoid NULL pointer dereference in swapon when s_bdev is NULL
fs/bio.c: move EXPORT* macros to line after function
Add missing blk_trace_remove_sysfs to be in pair with blk_trace_init_sysfs
cciss: fix build when !PROC_FS
block: Do not clamp max_hw_sectors for stacking devices
block: Set max_sectors correctly for stacking devices
cciss: cciss_host_attr_groups should be const
cciss: Dynamically allocate the drive_info_struct for each logical drive.
cciss: Add usage_count attribute to each logical drive in /sys
This reverts commit a9327cac440be4d8333bba975cbbf76045096275.
Corrado Zoccolo <czoccolo@gmail.com> reports:
"with 2.6.32-rc1 I started getting the following strange output from
"iostat -kx 2":
Linux 2.6.31bisect (et2) 04/10/2009 _i686_ (2 CPU)
avg-cpu: %user %nice %system %iowait %steal %idle
10,70 0,00 3,16 15,75 0,00 70,38
Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s
avgrq-sz avgqu-sz await svctm %util
sda 18,22 0,00 0,67 0,01 14,77 0,02
43,94 0,01 10,53 39043915,03 2629219,87
sdb 60,89 9,68 50,79 3,04 1724,43 50,52
65,95 0,70 13,06 488437,47 2629219,87
2,72 0,00 0,74 0,00 0,00 96,53
sda 0,00 0,00 0,00 0,00 0,00 0,00
0,00 0,00 0,00 0,00 100,00
sdb 0,00 0,00 0,00 0,00 0,00 0,00
6,68 0,00 0,99 0,00 0,00 92,33
4,40 0,00 0,73 1,47 0,00 93,40
sdb 0,00 4,00 0,00 3,00 0,00 28,00
18,67 0,06 19,50 333,33 100,00
Global values for service time and utilization are garbage. For
interval values, utilization is always 100%, and service time is
higher than normal.
I bisected it down to:
[a9327cac440be4d8333bba975cbbf76045096275] Seperate read and write
and verified that reverting just that commit indeed solves the issue
on 2.6.32-rc1."
So until this is debugged, revert the bad commit.
Not all users of the topology information want to use libblkid. Provide
the topology information through bdev ioctls.
Also clarify sector size comments for existing BLK ioctls.
This slowly ramps up the async queue depth based on the time
passed since the sync IO, and doesn't allow async at all until
a sync slice period has passed.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (46 commits)
cnic: Fix NETDEV_UP event processing.
uvesafb/connector: Disallow unpliviged users to send netlink packets
pohmelfs/connector: Disallow unpliviged users to configure pohmelfs
dst/connector: Disallow unpliviged users to configure dst
dm/connector: Only process connector packages from privileged processes
connector: Removed the destruct_data callback since it is always kfree_skb()
connector/dm: Fixed a compilation warning
connector: Provide the sender's credentials to the callback
connector: Keep the skb in cn_callback_data
e1000e/igb/ixgbe: Don't report an error if devices don't support AER
net: Fix wrong sizeof
net: splice() from tcp to pipe should take into account O_NONBLOCK
net: Use sk_mark for routing lookup in more places
sky2: irqname based on pci address
skge: use unique IRQ name
IPv4 TCP fails to send window scale option when window scale is zero
net/ipv4/tcp.c: fix min() type mismatch warning
Kconfig: STRIP: Remove stale bits of STRIP help text
NET: mkiss: Fix typo
tg3: Remove prev_vlan_tag from struct tx_ring_info
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Acked-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
This patch clean up/fixes for memcg's uncharge soft limit path.
Problems:
Now, res_counter_charge()/uncharge() handles softlimit information at
charge/uncharge and softlimit-check is done when event counter per memcg
goes over limit. Now, event counter per memcg is updated only when
memory usage is over soft limit. Here, considering hierarchical memcg
management, ancesotors should be taken care of.
Now, ancerstors(hierarchy) are handled in charge() but not in uncharge().
This is not good.
Prolems:
1. memcg's event counter incremented only when softlimit hits. That's bad.
It makes event counter hard to be reused for other purpose.
2. At uncharge, only the lowest level rescounter is handled. This is bug.
Because ancesotor's event counter is not incremented, children should
take care of them.
3. res_counter_uncharge()'s 3rd argument is NULL in most case.
ops under res_counter->lock should be small. No "if" sentense is better.
Fixes:
* Removed soft_limit_xx poitner and checks in charge and uncharge.
Do-check-only-when-necessary scheme works enough well without them.
* make event-counter of memcg incremented at every charge/uncharge.
(per-cpu area will be accessed soon anyway)
* All ancestors are checked at soft-limit-check. This is necessary because
ancesotor's event counter may never be modified. Then, they should be
checked at the same time.
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Balbir Singh <balbir@in.ibm.com>
The asm-generic/gpio.h header uses the might_sleep() macro but doesn't
include the header for it, so any source code that might include
linux/gpio.h before linux/kernel.h can easily lead to a build failure.
[akpm@linux-foundation.org: fix KVM]
Since 2.6.31 now has request-based device-mapper, it's useful to have
a tracepoint for request-remapping as well as bio-remapping.
This patch adds a tracepoint for request-remapping, trace_block_rq_remap().
Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Currently we set the bio size to the byte equivalent of the blocks to
be trimmed when submitting the initial DISCARD ioctl. That means it
is subject to the max_hw_sectors limitation of the HBA which is
much lower than the size of a DISCARD request we can support.
Add a separate max_discard_sectors tunable to limit the size for discard
requests.
We limit the max discard request size in bytes to 32bit as that is the
limit for bio->bi_size. This could be much larger if we had a way to pass
that information through the block layer.
prepare_discard_fn() was being called in a place where memory allocation
was effectively impossible. This makes it inappropriate for all but
the most trivial translations of Linux's DISCARD operation to the block
command set. Additionally adding a payload there makes the ownership
of the bio backing unclear as it's now allocated by the device driver
and not the submitter as usual.
It is replaced with QUEUE_FLAG_DISCARD which is used to indicate whether
the queue supports discard operations or not. blkdev_issue_discard now
allocates a one-page, sector-length payload which is the right thing
for the common ATA and SCSI implementations.
The mtd implementation of prepare_discard_fn() is replaced with simply
checking for the request being a discard.
Largely based on a previous patch from Matthew Wilcox <matthew@wil.cx>
which did the prepare_discard_fn but not the different payload allocation
yet.
introduced in commit 1d54ad6da9192fed5dd3b60224d9f2dfea0dcd82.
Release kobject also in case the request_fn is NULL.
Problem was noticed via kmemleak backtrace when some sysfs entries were
note properly destroyed during device removal:
unreferenced object 0xffff88001aa76640 (size 80):
comm "lvcreate", pid 2120, jiffies 4294885144
hex dump (first 32 bytes):
01 00 00 00 00 00 00 00 f0 65 a7 1a 00 88 ff ff .........e......
90 66 a7 1a 00 88 ff ff 86 1d 53 81 ff ff ff ff .f........S.....
backtrace:
[<ffffffff813f9cc6>] kmemleak_alloc+0x26/0x60
[<ffffffff8111d693>] kmem_cache_alloc+0x133/0x1c0
[<ffffffff81195891>] sysfs_new_dirent+0x41/0x120
[<ffffffff81194b0c>] sysfs_add_file_mode+0x3c/0xb0
[<ffffffff81197c81>] internal_create_group+0xc1/0x1a0
[<ffffffff81197d93>] sysfs_create_group+0x13/0x20
[<ffffffff810d8004>] blk_trace_init_sysfs+0x14/0x20
[<ffffffff8123f45c>] blk_register_queue+0x3c/0xf0
[<ffffffff812447e4>] add_disk+0x94/0x160
[<ffffffffa00d8b08>] dm_create+0x598/0x6e0 [dm_mod]
[<ffffffffa00de951>] dev_create+0x51/0x350 [dm_mod]
[<ffffffffa00de823>] ctl_ioctl+0x1a3/0x240 [dm_mod]
[<ffffffffa00de8f2>] dm_compat_ctl_ioctl+0x12/0x20 [dm_mod]
[<ffffffff81177bfd>] compat_sys_ioctl+0xcd/0x4f0
[<ffffffff81036ed8>] sysenter_dispatch+0x7/0x2c
[<ffffffffffffffff>] 0xffffffffffffffff
Signed-off-by: Zdenek Kabelac <zkabelac@redhat.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
The conversion solves the problem that firmware size was set to 64KB
while non PnP cards have 128KB firmware files.
An additional firmware initialization code has been moved from the OSS
driver.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
ax25: Fix possible oops in ax25_make_new
net: restore tx timestamping for accelerated vlans
Phonet: fix mutex imbalance
sit: fix off-by-one in ipip6_tunnel_get_prl
net: Fix sock_wfree() race
net: Make setsockopt() optlen be unsigned.
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
MIPS: Avoid spurious make includecheck message
MIPS: VPE: Get rid of BKL.
MIPS: VPE: Fix build after the credential changes a while ago.
MIPS: Excite: Get rid of BKL.
MIPS: Sibyte: Get rid of BKL.
MIPS: BCM63xx: Add PCMCIA & Cardbus support.
MIPS: MSP71xx: request_irq() failure ignored in msp_pcibios_config_access()
MIPS: Decrease size of au1xxx_dbdma_pm_regs[][]
MIPS: SMP: Inline arch_send_call_function_{single_ipi,ipi_mask}
MIPS: SMP: Fix build.
MIPS: MIPSxx SC: Avoid destructive invalidation on partial L2 cachelines.
MIPS: Sibyte: Fix compilation error.
MIPS: BCM1480: Re-apply patch lost due to bad resolution of merge conflict.
MIPS: BCM63xx: Add serial driver for bcm63xx integrated UART.
MIPS: Loongson2: Fix typo "enalbe" -> "enable"
MIPS: SMTC: Remove duplicate structure field initialization
MIPS: Remove duplicated #include
MIPS: BCM63xx: Remove duplicated #include
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: Fix time encoding with extra epoch bits
ext4: Add a stub for mpage_da_data in the trace header
jbd2: Use tracepoints for history file
ext4: Use tracepoints for mb_history trace file
ext4, jbd2: Drop unneeded printks at mount and unmount time
ext4: Handle nested ext4_journal_start/stop calls without a journal
ext4: Make sure ext4_dirty_inode() updates the inode in no journal mode
ext4: Avoid updating the inode table bh twice in no journal mode
ext4: EXT4_IOC_MOVE_EXT: Check for different original and donor inodes first
ext4: async direct IO for holes and fallocate support
ext4: Use end_io callback to avoid direct I/O fallback to buffered I/O
ext4: Split uninitialized extents for direct I/O
ext4: release reserved quota when block reservation for delalloc retry
ext4: Adjust ext4_da_writepages() to write out larger contiguous chunks
ext4: Fix hueristic which avoids group preallocation for closed files
ext4: Use ext4_msg() for ext4_da_writepage() errors
ext4: Update documentation about quota mount options
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / yenta: Fix cardbus suspend/resume regression
PM / PCMCIA: Drop second argument of pcmcia_socket_dev_suspend()
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits)
sony-laptop: re-read the rfkill state when resuming from suspend
sony-laptop: check for rfkill hard block at load time
wext: add back wireless/ dir in sysfs for cfg80211 interfaces
wext: Add bound checks for copy_from_user
mac80211: improve/fix mlme messages
cfg80211: always get BSS
iwlwifi: fix 3945 ucode info retrieval after failure
iwlwifi: fix memory leak in command queue handling
iwlwifi: fix debugfs buffer handling
cfg80211: don't set privacy w/o key
cfg80211: wext: don't display BSSID unless associated
net: Add explicit bound checks in net/socket.c
bridge: Fix double-free in br_add_if.
isdn: fix netjet/isdnhdlc build errors
atm: dereference of he_dev->rbps_virt in he_init_group()
ax25: Add missing dev_put in ax25_setsockopt
Revert "sit: stateless autoconf for isatap"
net: fix double skb free in dcbnl
net: fix nlmsg len size for skb when error bit is set.
net: fix vlan_get_size to include vlan_flags size
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (25 commits)
drm/radeon/kms: Convert R520 to new init path and associated cleanup
drm/radeon/kms: Convert RV515 to new init path and associated cleanup
drm: fix radeon DRM warnings when !CONFIG_DEBUG_FS
drm: fix drm_fb_helper warning when !CONFIG_MAGIC_SYSRQ
drm/r600: fix memory leak introduced with 64k malloc avoidance fix.
drm/kms: make fb helper work for all drivers.
drm/radeon/r600: fix offset handling in CS parser
drm/radeon/kms/r600: fix forcing pci mode on agp cards
drm/radeon/kms: fix for the extra pages copying.
drm/radeon/kms/r600: add support for vline relocs
drm/radeon/kms: fix some bugs in vline reloc
drm/radeon/kms/r600: clamp vram to aperture size
drm/kms: protect against fb helper not being created.
drm/r600: get values from the passed in IB not the copy.
drm: create gitignore file for radeon
drm/radeon/kms: remove unneeded master create/destroy functions.
drm/kms: start adding command line interface using fb.
fb: change rules for global rules match.
drm/radeon/kms: don't require up to 64k allocations. (v2)
drm/radeon/kms: enable dac load detection by default.
Trivial conflicts in drivers/gpu/drm/radeon/radeon_asic.h due to adding
'->vga_set_state' function pointers.
The tracepoint ext4_da_write_pages has a struct mpage_da_data*
parameter, but that struct is only defined in fs/ext4/ext4.h. This
patch adds a forward declaration for that struct, so this tracepoint
header can still be used by tools like SystemTap.
This is a continuation of the fix in commit 3661d286.
http://sourceware.org/bugzilla/show_bug.cgi?id=10703
Signed-off-by: Josh Stone <jistone@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
The /proc/fs/jbd2/<dev>/history was maintained manually; by using
tracepoints, we can get all of the existing functionality of the /proc
file plus extra capabilities thanks to the ftrace infrastructure. We
save memory as a bonus.
The /proc/fs/ext4/<dev>/mb_history was maintained manually, and had a
number of problems: it required a largish amount of memory to be
allocated for each ext4 filesystem, and the s_mb_history_lock
introduced a CPU contention problem.
By ripping out the mb_history code and replacing it with ftrace
tracepoints, and we get more functionality: timestamps, event
filtering, the ability to correlate mballoc history with other ext4
tracepoints, etc.
pcmcia_socket_dev_suspend() doesn't use its second argument, so it
may be dropped safely.
This change is necessary for the subsequent yenta suspend/resume fix.
Cc: stable@kernel.org
The move away from having drivers assign wireless handlers,
in favour of making cfg80211 assign them, broke the sysfs
registration (the wireless/ dir went missing) because the
handlers are now assigned only after registration, which is
too late.
Fix this by special-casing cfg80211-based devices, all
of which are required to have an ieee80211_ptr, in the
sysfs code, and also using get_wireless_stats() to have
the same values reported as in procfs.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Reported-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Tested-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Work around problems in the writeback code to force out writebacks in
larger chunks than just 4mb, which is just too small. This also works
around limitations in the ext4 block allocator, which can't allocate
more than 2048 blocks at a time. So we need to defeat the round-robin
characteristics of the writeback code and try to write out as many
blocks in one inode before allowing the writeback code to move on to
another inode. We add a a new per-filesystem tunable,
max_writeback_mb_bump, which caps this to a default of 128mb per
inode.
This initialises the fb helper with the connector helper,
so that the fb cmdline code works for intel as well.
The following commit made console open fails while booting:
commit b50989dc444599c8b21edc23536fc305f4e9b7d5
Author: Alan Cox <alan@linux.intel.com>
Date: Sat Sep 19 13:13:22 2009 -0700
tty: make the kref destructor occur asynchronously
Due to tty release routines run in a workqueue now, error like the
following will be reported while booting:
INIT open /dev/console Input/output error
It also causes hibernation regression to appear as reported at
http://bugzilla.kernel.org/show_bug.cgi?id=14229
The reason is that now there's latency issue with closing, but when
we open a "closing not finished" tty, -EIO will be returned.
Fix it as per the following Alan's suggestion:
Fun but it's actually not a bug and the fix is wrong in itself as
the port may be closing but not yet being destructed, in which case
it seems to do the wrong thing. Opening a tty that is closing (and
could be closing for long periods) is supposed to return -EIO.
I suspect a better way to deal with this and keep the old console
timing is to split tty->shutdown into two functions.
tty->shutdown() - called synchronously just before we dump the tty
onto the waitqueue for destruction
tty->cleanup() - called when the destructor runs.
We would then do the shutdown part which can occur in IRQ context
fine, before queueing the rest of the release (from tty->magic = 0
... the end) to occur asynchronously
The USB update in -next would then need a call like
if (tty->cleanup)
tty->cleanup(tty);
at the top of the async function and the USB shutdown to be split
between shutdown and cleanup as the USB resource cleanup and final
tidy cannot occur synchronously as it needs to sleep.
In other words the logic becomes
final kref put
make object unfindable
async
clean it up
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
[ rjw: Rebased on top of 2.6.31-git, reworked the changelog. ]
Signed-off-by: "Rafael J. Wysocki" <rjw@sisk.pl>
[ Changed serial naming to match new rules, dropped tty_shutdown as per
comments from Alan Stern - Linus ]
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
This reverts commit 645069299a1c7358cf7330afe293f07552f11a5d.
While the code does not actually break anything, it does not completely follow
RFC5214 yet. After talking back with Fred L. Templin, I agree that completing the
ISATAP specific RS/RA code, would pollute the kernel a lot with code that is better
implemented in userspace.
The kernel should not send RS packages for ISATAP at all.
Signed-off-by: Sascha Hlusiak <contact@saschahlusiak.de>
Acked-by: Fred L. Templin <Fred.L.Templin@boeing.com>
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds:
leds: move leds-clevo-mail's probe function to .devinit.text
leds: Fix indentation in LEDS_LP3944 Kconfig entry
leds: Fix LED names
leds: Fix leds-pca9532 whitespace issues
leds: fix coding style in worker thread code for ledtrig-gpio.
leds: gpio-leds: fix typographics fault
leds: Add WM831x status LED driver
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight:
backlight: new driver for ADP5520/ADP5501 MFD PMICs
backlight: extend event support to also support poll()
backlight/eeepc-laptop: Update the backlight state when we change brightness
backlight/acpi: Update the backlight state when we change brightness
backlight: Allow drivers to update the core, and generate events on changes
backlight: switch to da903x driver to dev_pm_ops
backlight: Add support for the Avionic Design Xanthos backlight device.
backlight: spi driver for LMS283GF05 LCD
backlight: move hp680-bl's probe function to .devinit.text
backlight: Add support for new Apple machines.
backlight: mbp_nvidia_bl: add support for MacBookAir 1,1
backlight: Add WM831x backlight driver
Trivial conflicts due to '#ifdef CONFIG_PM' differences in
drivers/video/backlight/da903x_bl.c
* remove asm/atomic.h inclusion from kref.h -- not needed, linux/types.h
is enough for atomic_t
* remove linux/kref.h inclusion from files which do not need it.
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Dont use openat()
perf tools: Fix buffer allocation
perf tools: .gitignore += perf*.html
perf tools: Handle relative paths while loading module symbols
perf tools: Fix module symbol loading bug
perf_event, x86: Fix 'perf sched record' crashing the machine
perf_event: Update PERF_EVENT_FORK header definition
perf stat: Fix zero total printouts
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
modules, tracing: Remove stale struct marker signature from module_layout()
tracing/workqueue: Use %pf in workqueue trace events
tracing: Fix a comment and a trivial format issue in tracepoint.h
tracing: Fix failure path in ftrace_regex_open()
tracing: Fix failure path in ftrace_graph_write()
tracing: Check the return value of trace_get_user()
tracing: Fix off-by-one in trace_get_user()
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (32 commits)
ACPI: i2c-scmi: don't use acpi_device_uid()
ACPI: simplify building device HID/CID list
ACPI: remove acpi_device_uid() and related stuff
ACPI: remove acpi_device.flags.hardware_id
ACPI: remove acpi_device.flags.compatible_ids
ACPI: maintain a single list of _HID and _CID IDs
ACPI: make sure every acpi_device has an ID
ACPI: use acpi_device_hid() when possible
ACPI: fix synthetic HID for \_SB_
ACPI: handle re-enumeration, when acpi_devices might already exist
ACPI: factor out device type and status checking
ACPI: add acpi_bus_get_status_handle()
ACPI: use acpi_walk_namespace() to enumerate devices
ACPI: identify device tree root by null parent pointer, not ACPI_BUS_TYPE
ACPI: enumerate namespace before adding functional fixed hardware devices
ACPI: convert acpi_bus_scan() to operate on an acpi_handle
ACPI: add acpi_bus_get_parent() and remove "parent" arguments
ACPI: remove unnecessary argument checking
ACPI: remove redundant "type" arguments
ACPI: remove acpi_device_set_context() "type" argument
Sometimes we only want to write pages from a specific super_block,
so allow that to be passed in.
This fixes a problem with commit 56a131dcf7ed36c3c6e36bea448b674ea85ed5bb
causing writeback on all super_blocks on a bdi, where we only really
want to sync a specific sb from writeback_inodes_sb().
Nobody uses acpi_device_uid(), so this patch removes it.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Every acpi_device has at least one ID (if there's no _HID or _CID, we
give it a synthetic or default ID). So there's no longer a need to
check whether an ID exists; we can just use it.
We now keep a single list of IDs that includes both the _HID and any
_CIDs. We no longer need to keep track of whether the device has a _CID.
There's no need to treat _HID and _CID differently. Keeping them in
a single list makes code that uses the IDs a little simpler because it
can just traverse the list rather than checking "do we have a HID?",
"do we have any CIDs?"
Reviewed-by: Alex Chiang <achiang@hp.com>
Add acpi_bus_get_status_handle() so we can get the status of a namespace
object before building a struct acpi_device.
This removes a use of "device->flags.dynamic_status", a cached indicator of
whether _STA exists. It seems simpler and more reliable to just evaluate
_STA and catch AE_NOT_FOUND errors.
We can identify the root of the ACPI device tree by the fact that it
has no parent. This is simpler than passing around ACPI_BUS_TYPE_SYSTEM
and will help remove special treatment of the device tree root.
Currently, we add the root by hand with ACPI_BUS_TYPE_SYSTEM. If we
traverse the tree treating the root as just another device and use
acpi_get_type(), the root shows up as ACPI_TYPE_DEVICE.
