Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
(cherry picked from commit 07a5fa4abd8b6965d4585d3b110f89bdf5612aff)
(cherry picked from commit 792608e9c215141fa4b870b7b2a23767a1ef12f4)
(cherry picked from commit a55465dca7befd31f4ffa54508d4e2d1e701b8dc)
(cherry picked from commit 6ad414fe710d4fd3a8c8c6c2ad8fefcfcc207968)
(cherry picked from commit 50496a1fab6c6a90b77da4b247321a88e632bd46)
(cherry picked from commit f4d663ce6357e533f107ce3789bd8848c94bea81)
(cherry picked from commit 6c5a86f529a9e9ca4c9aca5fa477e9557d4a3d3d)
We add a report function pointer to struct crypto_type. This function
pointer is used from the crypto userspace configuration API to report
crypto algorithms to userspace.
(cherry picked from commit b6aa63c09ba3b150a1030f9c95c7647361e7910e)
This patch adds a basic userspace configuration API for the crypto layer.
With this it is possible to instantiate, remove and to show crypto
algorithms from userspace.
(cherry picked from commit a38f7907b926e4c6c7d389ad96cc38cec2e5a9e9)
Update mxt driver to upstream version.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Traditionally, any System-on-Chip based platform creates a flat list
of platform_devices directly under /sys/devices/platform.
In order to give these some better structure, this introduces a new
bus type for soc_devices that are registered with the new
soc_device_register() function. All devices that are on the same
chip should then be registered as child devices of the soc device.
The soc bus also exports a few standardised device attributes which
allow user space to query the specific type of soc.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
(cherry picked from commit 74d1d82cdaaec727f5072eb1c9f49b7e920e076f)
eMMC's may have a hardware reset line. This patch provides a
host controller operation to implement hardware reset and
a function to reset and reinitialize the card. Also, for MMC,
the reset is always performed before initialization.
The host must set the new host capability MMC_CAP_HW_RESET
to enable hardware reset.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
(cherry picked from commit b2499518b5ad7e28bb3ed348fd3f370eeb1e36c0)
commit 95272c29378ee7dc15f43fa2758cb28a5913a06d upstream.
-ftracer can duplicate asm blocks causing compilation to fail in
noclone functions. For example, KVM declares a global variable
in an asm like
asm("2: ... \n
.pushsection data \n
.global vmx_return \n
vmx_return: .long 2b");
and -ftracer causes a double declaration.
Cc: Michal Marek <mmarek@suse.cz>
Cc: stable@vger.kernel.org
Cc: kvm@vger.kernel.org
Reported-by: Linda Walsh <lkml@tlinx.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
(cherry picked from commit 5d814ad8d35e5e23e0c27fb0f0b80c1044ecefad)
commit cb984d101b30eb7478d32df56a0023e4603cba7f upstream.
As gcc major version numbers are going to advance rather rapidly in the
future, there's no real value in separate files for each compiler
version.
Deduplicate some of the macros #defined in each file too.
Neaten comments using normal kernel commenting style.
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Sasha Levin <levinsasha928@gmail.com>
Cc: Alan Modra <amodra@gmail.com>
[ philm: backport to 3.10-stable ]
Signed-off-by: Philip Müller <philm@manjaro.org>
(cherry picked from commit a4a4f1cd733fe5b345db4e8cc19bb8868d562a8a)
Throughout compiler*.h, many version checks are made. These can be
simplified by using the macro that gcc's documentation recommends.
However, my primary reason for adding this is that I need bug-check
macros that are enabled at certain gcc versions and it's cleaner to use
this macro than the tradition method:
#if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ => 2)
If you add patch level, it gets this ugly:
#if __GNUC__ > 4 || (__GNUC__ == 4 && (__GNUC_MINOR__ > 2 || \
__GNUC_MINOR__ == 2 __GNUC_PATCHLEVEL__ >= 1))
As opposed to:
#if GCC_VERSION >= 40201
While having separate headers for gcc 3 & 4 eliminates some of this
verbosity, they can still be cleaned up by this.
See also:
http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Acked-by: Borislav Petkov <bp@alien8.de>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Joe Perches <joe@perches.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
(cherry picked from commit 3f3f8d2f48acfd8ed3b8e6b7377935da57b27b16)
Commit 5963e317b1e9d2a ("ftrace/x86: Do not change stacks in DEBUG when
calling lockdep") prevented lockdep calls from the int3 breakpoint handler
from reseting the stack if a function that was called was in the process
of being converted for tracing and had a breakpoint on it. The idea is,
before calling the lockdep code, do a load_idt() to the special IDT that
kept the breakpoint stack from reseting. This worked well as a quick fix
for this kernel release, until a certain config caused a lockup in the
function tracer start up tests.
Investigating it, I found that the load_idt that was used to prevent
the int3 from changing stacks was itself being traced!
Even though the config had CONFIG_OPTIMIZE_INLINING disabled, and
all 'inline' tags were set to always inline, there were still cases that
it did not inline! This was caused by CONFIG_PARAVIRT_GUEST, where it
would add a pointer to the native_load_idt() which made that function
to be traced.
Commit 45959ee7aa645815a ("ftrace: Do not function trace inlined functions")
only touched the 'inline' tags when CONFIG_OPMITIZE_INLINING was enabled.
PARAVIRT_GUEST shows that this was not enough and we need to also
mark always_inline with notrace as well.
Reported-by: Fengguang Wu <wfg@linux.intel.com>
Tested-by: Fengguang Wu <wfg@linux.intel.com>
(cherry picked from commit 93b3cca1ccd30b1ad290951a3fc7c10c73db7313)
When gcc inlines a function, it does not mark it with the mcount
prologue, which in turn means that inlined functions are not traced
by the function tracer. But if CONFIG_OPTIMIZE_INLINING is set, then
gcc is allowed not to inline a function that is marked inline.
Depending on the options and the compiler, a function may or may
not be traced by the function tracer, depending on whether gcc
decides to inline a function or not. This has caused several
problems in the pass becaues gcc is not always consistent with
what it decides to inline between different gcc versions.
Some places should not be traced (like paravirt native_* functions)
and these are mostly marked as inline. When gcc decides not to
inline the function, and if that function should not be traced, then
the ftrace function tracer will suddenly break when it use to work
fine. This becomes even harder to debug when different versions of
gcc will not inline that function, making the same kernel and config
work for some gcc versions and not work for others.
By making all functions marked inline to not be traced will remove
the ambiguity that gcc adds when it comes to tracing functions marked
inline. All gcc versions will be consistent with what functions are
traced and having volatile working code will be removed.
Note, only the inline macro when CONFIG_OPTIMIZE_INLINING is set needs
to have notrace added, as the attribute __always_inline will force
the function to be inlined and then not traced.
(cherry picked from commit 45959ee7aa645815a5ce303a0ea1e48a21e67c6a)
We're missing include/linux/compiler-gcc5.h which is required now
because gcc branched off to v5 in trunk.
Just copy the relevant bits out of include/linux/compiler-gcc4.h,
no new code is added as of now.
This fixes a build error when using gcc 5.
Cc: <stable@vger.kernel.org>
(cherry picked from commit 71458cfc782eafe4b27656e078d379a34e472adf)
Just scratching an itch here, but it makes more sense to use the
static keyword if you think about how the compiler treats inline
functions.
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Alwin Beukers <alwin@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
Signed-off-by: Franky Lin <frankyl@broadcom.com>
(cherry picked from commit 084455524f0d46dd210b4397898aff73579b97e8)
Certain Hynix eMMC 4.41 cards might get broken when HPI feature is used
and hence this patch disables the HPI feature for such buggy cards.
As some of the other features like BKOPs/Cache/Sanitize are dependent on
HPI feature, those features would also get disabled if HPI is disabled.
Change-Id: I6a638ce089cbd977122e47aecb721bc3f0adf7b0
Signed-off-by: Pratibhasagar V <pratibha@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Fix ported from the following Android MSM kernel commit:
https://www.codeaurora.org/cgit/quic/la/kernel/msm/commit/?id=84af3731019921a28d595dbf6cbf00539706a42c
It is fully legal for a controller to start handling busy-end interrupt
before it has signaled that the command has completed. So make sure
we do things in the proper order, Or it results that command interrupt
is ignored so it can cause unexpected operations. This is founded at some
toshiba emmc with the bellow warning.
"mmc0: Got command interrupt 0x00000001 even though
no command operation was in progress."
This issue has been also reported by Youssef TRIKI:
It is not specific to Toshiba devices, and happens with eMMC devices
as well as SD card which support Auto-CMD12 rather than CMD23.
Also, similar patch is submitted by:
Gwendal Grignou <gwendal@chromium.org>
Changes since v1:
Fixed conflict with the next of git.linaro.org/people/ulf.hansson/mmc.git
and Tested if issue is fixed again.
Signed-off-by: Hankyung Yu <hankyung.yu@lge.com>
Signed-off-by: Chanho Min <chanho.min@lge.com>
Tested-by: Youssef TRIKI <youssef.triki@st.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit e99783a45220a2c5f5a598e0e81213ecf2dbcf2f)
Ths patch allows runtime PM for sdhci-pci, runtime suspending after
inactivity of 50ms and ensuring runtime resume before SDHC registers
are accessed. During runtime suspend, interrupts are masked.
The host controller state is restored at runtime resume.
For Medfield, the host controller's card detect mechanism is
supplanted by an always-on GPIO which provides for card detect wake-up.
(cherry picked from commit 66fd8ad5100b5003046aa744a4f12fa31bb831f9)
drivers/mtd/ubi/ubi.h
drivers/mtd/ubi/wl.c
Add tracepoints to record the start and end of each mmc block
operation. This includes read, write, erase, secure erase,
trim, secure trim1 and secure trim 2, discard and
sanitize commands.
Change-Id: Ic5d1cbdb9adb940d8b1a2a13c73970023575df50
Signed-off-by: Ken Sumrall <ksumrall@android.com>
Signed-off-by: Iliyan Malchev <malchev@google.com>
drivers/mmc/card/block.c
drivers/mmc/core/core.c
(cherry picked from commit 4de9a433c26e47d9b4a93105eb92935321100786)
Support discard feature if MID field in the CID register is 0x15, EXT.CSD[192]
(device version) is 5 and Bit 0 in the EXT.CSD[64] is 1. Also removed REQ_SECURE flag
check to avoid kernel hang.
This patch is released from samsung.
Change-Id: I4023a900680e9bca10c40311b09ed077a22617db
(cherry picked from commit 4acc227edfb631d377e14911287c1b73682fc9c2)
Change-Id: I89b544afbb0a109a222621a9948399fba8f77693
Change-Id: Ie366a152100a478e7811b4395f3fae9794bb1386
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45221
Reviewed-by: Ban Feng <Ban_Feng@asus.com>
Tested-by: Ban Feng <Ban_Feng@asus.com>
Reviewed-by: Sam hblee <Sam_hblee@asus.com>
drivers/mmc/core/mmc.c
include/linux/mmc/card.h
asdf
(tegra-l4t-r16-16.5)
drivers/media/video/tegra_v4l2_camera.c
drivers/mmc/host/sdhci.c
drivers/watchdog/tegra_wdt.c
include/media/tegra_v4l2_camera.h
nvhost_job_unpin should always get the nvmap_handle_ref
from rb_entry after validating handle and presence
in the tree.
Bug 1478467
Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/436076
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Change-Id: I67c50ff86b53a6c1001d2b688251dc55bd2eff55
Reviewed-on: http://git-master/r/419070
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v
capable, and it truthfully reports so in its capabilities. This
alternate voltage is used for driving new "UHS-I" SD cards at their
full speed.
However, what the controller doesn't know is that the motherboard
physically doesn't have a 1.8v supply available.
Add a quirk so that systems such as this one can override disable
1.8v support, adding support for UHS-I cards (by running them at
3.3v).
This avoids a problem where the system would first try to run the
card at 1.8v, fail, and then not be able to fully reset the card
to retry at the normal 3.3v voltage.
This is more appropriate than using the MISSING_CAPS quirk, which
is intended for cases where the SDHCI controller is actually lying
about its capabilities, and would force us to somehow override both
caps words from another source.
Bug 1402031
Change-Id: I7ca070a13241e6403eb2e243ebbc441a311110bc
Signed-off-by: Daniel Drake <dsd@laptop.org>
Reviewed-by: Philip Rakity <prakity@nvidia.com>
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: http://git-master/r/346323
Tested-by: Matthew Pedro <mapedro@nvidia.com>
This commit adds settings such as:
- values of horizontal/vertical active start,
- enabling/disabling internal sync,
to the private data of decoders: MAX9526, ADV7180, TVP5150,
OV7670 and AS0260.
The feature is available through *_tegra_camera_platform_data
struct initialised in board-*.c files.
This commit adds a method that MAC drivers may call in order to find out
the device number of their associated PTP Hardware Clock.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
This commit adds a new ethtool ioctl that exposes the SO_TIMESTAMPING
capabilities of a network interface. In addition, user space programs
can use this ioctl to discover the PTP Hardware Clock (PHC) device
associated with the interface.
Since software receive time stamps are handled by the stack, the generic
ethtool code can answer the query correctly in case the MAC or PHY
drivers lack special time stamping features.
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
Add a new ethtool operation (get_rxfh_indir_size) to get the
indirectional table size. Use this to validate the user buffer size
before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get
the number of RX rings, and validate the contents of the new
indirection table before calling set_rxfh_indir. Remove this
validation from drivers.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Dimitris Michailidis <dm@chelsio.com>
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
In order to use the auxiliar ADC inputs of STMPE811 devices we need
to add resources for the ADC block. Also move the ADC macros from
the touchscreen driver to the general header file. We will need them
for the ADC driver in future.
The current ioctl define implies that this func expects to be passed a
64bit number directly rather than a pointer to a 64bit. The code that
processes this ioctl shows that it clearly expects a pointer.
It'd be best if we could change the type to "__s64*", but that would
change the generated ioctl number thus breaking the userland ABI. So
just add a comment for intrepid developers.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
export access to the 'Local Shared OS and T_Crit Limit'
register.
full speed.
3.3v).
OV5650 is a RAW sensor outputing Bayer RAW 8 or RAW 10 data.
This driver uses SoC camera interface and supports several
different resolution.
Change-Id: I8075b63b42f7949a264bdef446f5ed8bdc0a9eee
Reviewed-on: http://git-master/r/200223
Make it accessible outside of drivers/video/tegra. V4L2 driver needs
to set some platform_data.
Add suport for T20.
Change-Id: I98353c2874ea28cfa0a7a5dd8a1dc4c586af4dd7
Signed-off-by: Andrew Chew <achew@nvidia.com>
Reviewed-on: http://git-master/r/200220
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Add functions to get the requested number of pseudo-random bytes.
The difference from get_random_bytes() is that it generates pseudo-random
numbers by prandom_u32(). It doesn't consume the entropy pool, and the
sequence is reproducible if the same rnd_state is used. So it is suitable
for generating random bytes for testing.
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Eilon Greenstein <eilong@broadcom.com>
Cc: David Laight <david.laight@aculab.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Robert Love <robert.w.love@intel.com>
Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu>
This renames all random32 functions to have 'prandom_' prefix as follows:
void prandom_seed(u32 seed); /* rename from srandom32() */
u32 prandom_u32(void); /* rename from random32() */
void prandom_seed_state(struct rnd_state *state, u64 seed);
/* rename from prandom32_seed() */
u32 prandom_u32_state(struct rnd_state *state);
/* rename from prandom32() */
The purpose of this renaming is to prevent some kernel developers from
assuming that prandom32() and random32() might imply that only
prandom32() was the one using a pseudo-random number generator by
prandom32's "p", and the result may be a very embarassing security
exposure. This concern was expressed by Theodore Ts'o.
And furthermore, I'm going to introduce new functions for getting the
requested number of pseudo-random bytes. If I continue to use both
prandom32 and random32 prefixes for these functions, the confusion
is getting worse.
As a result of this renaming, "prandom_" is the common prefix for
pseudo-random number library.
Currently, srandom32() and random32() are preserved because it is
difficult to rename too many users at once.
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
In order to allow tighter integration with external thermal throttling
code add local temperature and remote critical shutdown temperature
hooks. Rename the existing hooks for clarity.
In order to allow integrating with external thermal throttling code add
a probe callback and remote over-temperature shutdown hooks.
