path: root/include
2019-09-09ASoC: Define a set of DAPM pre/post-up eventsOleksandr Suvorov
Prepare to use SND_SOC_DAPM_PRE_POST_PMU definition to reduce coming code size and make it more readable. Cc: stable@vger.kernel.org Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Patch-cc: stable Patch-cc: Sasha Levin <sashal@kernel.org> Series-changes: 5 - Add explicit stable tag Series-changes: 4 - CC the patch to kernel-stable Series-changes: 2 - Fix patch formatting
2018-11-29Input: atmel_mxt_ts - add support for reset lineSebastian Reichel
Provide support for controlling reset pin. If this is not driven correctly the device will be held in reset and will not respond. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> (cherry picked from commit 51a32466a0ca40843039b6d1f1e719bc93db8a21)
2018-11-29Revert "input: atmel_mxt_ts: support reset gpio line"Dominik Sliwa
This reverts commit 28531a1ff5ca27c0ab7e2f99bbb0058858b72aa5.
2018-09-27mtd: nand: add missing nand manufacturers idsMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-09-12give up on gcc ilog2() constant optimizationsLinus Torvalds
gcc-7 has an "optimization" pass that completely screws up, and generates the code expansion for the (impossible) case of calling ilog2() with a zero constant, even when the code gcc compiles does not actually have a zero constant. And we try to generate a compile-time error for anybody doing ilog2() on a constant where that doesn't make sense (be it zero or negative). So now gcc7 will fail the build due to our sanity checking, because it created that constant-zero case that didn't actually exist in the source code. There's a whole long discussion on the kernel mailing about how to work around this gcc bug. The gcc people themselevs have discussed their "feature" in https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785 but it's all water under the bridge, because while it looked at one point like it would be solved by the time gcc7 was released, that was not to be. So now we have to deal with this compiler braindamage. And the only simple approach seems to be to just delete the code that tries to warn about bad uses of ilog2(). So now "ilog2()" will just return 0 not just for the value 1, but for any non-positive value too. It's not like I can recall anybody having ever actually tried to use this function on any invalid value, but maybe the sanity check just meant that such code never made it out in public. Reported-by: Laura Abbott <labbott@redhat.com> Cc: John Stultz <john.stultz@linaro.org>, Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c) Conflicts: tools/include/linux/log2.h File does not exist in the 3.1 kernel, change dropped. This helps with the move to GCC 8. | include/linux/log2.h:22:1: error: ignoring attribute 'noreturn' because it conflicts with attribute 'const' [-Werror=attributes] | int ____ilog2_NaN(void); Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-06-19input: atmel_mxt_ts: support reset gpio lineDominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 22a2065b9a3fa6ad458e3100b66c4acaa05f2466) Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add a flag to identify crypto instancesSteffen Klassert
The upcomming crypto user configuration api needs to identify crypto instances. This patch adds a flag that is set if the algorithm is an instance that is build from templates. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 64a947b1337b93061da7c7af1f6ce6b2431b70ae) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for cipher type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 07a5fa4abd8b6965d4585d3b110f89bdf5612aff) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for rng type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 792608e9c215141fa4b870b7b2a23767a1ef12f4) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for pcompress type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit a55465dca7befd31f4ffa54508d4e2d1e701b8dc) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for aead type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 6ad414fe710d4fd3a8c8c6c2ad8fefcfcc207968) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for blkcipher type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 50496a1fab6c6a90b77da4b247321a88e632bd46) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for shash type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit f4d663ce6357e533f107ce3789bd8848c94bea81) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for larval type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 6c5a86f529a9e9ca4c9aca5fa477e9557d4a3d3d) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add a report function pointer to crypto_typeSteffen Klassert
We add a report function pointer to struct crypto_type. This function pointer is used from the crypto userspace configuration API to report crypto algorithms to userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit b6aa63c09ba3b150a1030f9c95c7647361e7910e) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace configuration APISteffen Klassert
This patch adds a basic userspace configuration API for the crypto layer. With this it is possible to instantiate, remove and to show crypto algorithms from userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit a38f7907b926e4c6c7d389ad96cc38cec2e5a9e9) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-26input: atmel_mxt_ts driver updateNick Dyer
Update mxt driver to upstream version. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-03-31drivers/base: add bus for System-on-Chip devicesLee Jones
Traditionally, any System-on-Chip based platform creates a flat list of platform_devices directly under /sys/devices/platform. In order to give these some better structure, this introduces a new bus type for soc_devices that are registered with the new soc_device_register() function. All devices that are on the same chip should then be registered as child devices of the soc device. The soc bus also exports a few standardised device attributes which allow user space to query the specific type of soc. Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> (cherry picked from commit 74d1d82cdaaec727f5072eb1c9f49b7e920e076f)
2017-03-31mmc: core: add eMMC hardware reset supportAdrian Hunter
eMMC's may have a hardware reset line. This patch provides a host controller operation to implement hardware reset and a function to reset and reinitialize the card. Also, for MMC, the reset is always performed before initialization. The host must set the new host capability MMC_CAP_HW_RESET to enable hardware reset. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit b2499518b5ad7e28bb3ed348fd3f370eeb1e36c0)
2016-09-29compiler-gcc: disable -ftracer for __noclone functionsPaolo Bonzini
commit 95272c29378ee7dc15f43fa2758cb28a5913a06d upstream. -ftracer can duplicate asm blocks causing compilation to fail in noclone functions. For example, KVM declares a global variable in an asm like asm("2: ... \n .pushsection data \n .global vmx_return \n vmx_return: .long 2b"); and -ftracer causes a double declaration. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: stable@vger.kernel.org Cc: kvm@vger.kernel.org Reported-by: Linda Walsh <lkml@tlinx.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Willy Tarreau <w@1wt.eu> (cherry picked from commit 5d814ad8d35e5e23e0c27fb0f0b80c1044ecefad)
2016-09-29compiler-gcc: integrate the various compiler-gcc[345].h filesJoe Perches
commit cb984d101b30eb7478d32df56a0023e4603cba7f upstream. As gcc major version numbers are going to advance rather rapidly in the future, there's no real value in separate files for each compiler version. Deduplicate some of the macros #defined in each file too. Neaten comments using normal kernel commenting style. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Segher Boessenkool <segher@kernel.crashing.org> Cc: Sasha Levin <levinsasha928@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Alan Modra <amodra@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [ philm: backport to 3.10-stable ] Signed-off-by: Philip Müller <philm@manjaro.org> Signed-off-by: Willy Tarreau <w@1wt.eu> (cherry picked from commit a4a4f1cd733fe5b345db4e8cc19bb8868d562a8a)
2016-09-29compiler-gcc.h: Add gcc-recommended GCC_VERSION macroDaniel Santos
Throughout compiler*.h, many version checks are made. These can be simplified by using the macro that gcc's documentation recommends. However, my primary reason for adding this is that I need bug-check macros that are enabled at certain gcc versions and it's cleaner to use this macro than the tradition method: #if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ => 2) If you add patch level, it gets this ugly: #if __GNUC__ > 4 || (__GNUC__ == 4 && (__GNUC_MINOR__ > 2 || \ __GNUC_MINOR__ == 2 __GNUC_PATCHLEVEL__ >= 1)) As opposed to: #if GCC_VERSION >= 40201 While having separate headers for gcc 3 & 4 eliminates some of this verbosity, they can still be cleaned up by this. See also: http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Acked-by: Borislav Petkov <bp@alien8.de> Acked-by: David Rientjes <rientjes@google.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Joe Perches <joe@perches.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 3f3f8d2f48acfd8ed3b8e6b7377935da57b27b16)
2016-09-29ftrace: Make all inline tags also include notraceSteven Rostedt
Commit 5963e317b1e9d2a ("ftrace/x86: Do not change stacks in DEBUG when calling lockdep") prevented lockdep calls from the int3 breakpoint handler from reseting the stack if a function that was called was in the process of being converted for tracing and had a breakpoint on it. The idea is, before calling the lockdep code, do a load_idt() to the special IDT that kept the breakpoint stack from reseting. This worked well as a quick fix for this kernel release, until a certain config caused a lockup in the function tracer start up tests. Investigating it, I found that the load_idt that was used to prevent the int3 from changing stacks was itself being traced! Even though the config had CONFIG_OPTIMIZE_INLINING disabled, and all 'inline' tags were set to always inline, there were still cases that it did not inline! This was caused by CONFIG_PARAVIRT_GUEST, where it would add a pointer to the native_load_idt() which made that function to be traced. Commit 45959ee7aa645815a ("ftrace: Do not function trace inlined functions") only touched the 'inline' tags when CONFIG_OPMITIZE_INLINING was enabled. PARAVIRT_GUEST shows that this was not enough and we need to also mark always_inline with notrace as well. Reported-by: Fengguang Wu <wfg@linux.intel.com> Tested-by: Fengguang Wu <wfg@linux.intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> (cherry picked from commit 93b3cca1ccd30b1ad290951a3fc7c10c73db7313)
2016-09-29ftrace: Do not function trace inlined functionsSteven Rostedt
When gcc inlines a function, it does not mark it with the mcount prologue, which in turn means that inlined functions are not traced by the function tracer. But if CONFIG_OPTIMIZE_INLINING is set, then gcc is allowed not to inline a function that is marked inline. Depending on the options and the compiler, a function may or may not be traced by the function tracer, depending on whether gcc decides to inline a function or not. This has caused several problems in the pass becaues gcc is not always consistent with what it decides to inline between different gcc versions. Some places should not be traced (like paravirt native_* functions) and these are mostly marked as inline. When gcc decides not to inline the function, and if that function should not be traced, then the ftrace function tracer will suddenly break when it use to work fine. This becomes even harder to debug when different versions of gcc will not inline that function, making the same kernel and config work for some gcc versions and not work for others. By making all functions marked inline to not be traced will remove the ambiguity that gcc adds when it comes to tracing functions marked inline. All gcc versions will be consistent with what functions are traced and having volatile working code will be removed. Note, only the inline macro when CONFIG_OPTIMIZE_INLINING is set needs to have notrace added, as the attribute __always_inline will force the function to be inlined and then not traced. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> (cherry picked from commit 45959ee7aa645815a5ce303a0ea1e48a21e67c6a)
2016-03-21kernel: add support for gcc 5Sasha Levin
We're missing include/linux/compiler-gcc5.h which is required now because gcc branched off to v5 in trunk. Just copy the relevant bits out of include/linux/compiler-gcc4.h, no new code is added as of now. This fixes a build error when using gcc 5. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 71458cfc782eafe4b27656e078d379a34e472adf)
2016-03-21bcma: use static keyword for inline function declaration in bcma.hArend van Spriel
Just scratching an itch here, but it makes more sense to use the static keyword if you think about how the compiler treats inline functions. Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com> Reviewed-by: Alwin Beukers <alwin@broadcom.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Franky Lin <frankyl@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> (cherry picked from commit 084455524f0d46dd210b4397898aff73579b97e8)
2015-10-14mmc: core: Disable HPI for certain Hynix eMMC cardsMarcel Ziswiler
Certain Hynix eMMC 4.41 cards might get broken when HPI feature is used and hence this patch disables the HPI feature for such buggy cards. As some of the other features like BKOPs/Cache/Sanitize are dependent on HPI feature, those features would also get disabled if HPI is disabled. Change-Id: I6a638ce089cbd977122e47aecb721bc3f0adf7b0 Signed-off-by: Pratibhasagar V <pratibha@codeaurora.org> Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org> Fix ported from the following Android MSM kernel commit: https://www.codeaurora.org/cgit/quic/la/kernel/msm/commit/?id=84af3731019921a28d595dbf6cbf00539706a42c
2015-10-11mmc: sdhci: handle busy-end interrupt during commandChanho Min
It is fully legal for a controller to start handling busy-end interrupt before it has signaled that the command has completed. So make sure we do things in the proper order, Or it results that command interrupt is ignored so it can cause unexpected operations. This is founded at some toshiba emmc with the bellow warning. "mmc0: Got command interrupt 0x00000001 even though no command operation was in progress." This issue has been also reported by Youssef TRIKI: It is not specific to Toshiba devices, and happens with eMMC devices as well as SD card which support Auto-CMD12 rather than CMD23. Also, similar patch is submitted by: Gwendal Grignou <gwendal@chromium.org> Changes since v1: Fixed conflict with the next of git.linaro.org/people/ulf.hansson/mmc.git and Tested if issue is fixed again. Signed-off-by: Hankyung Yu <hankyung.yu@lge.com> Signed-off-by: Chanho Min <chanho.min@lge.com> Tested-by: Youssef TRIKI <youssef.triki@st.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit e99783a45220a2c5f5a598e0e81213ecf2dbcf2f)
2015-10-09mmc: sdhci-pci: add runtime pm supportAdrian Hunter
Ths patch allows runtime PM for sdhci-pci, runtime suspending after inactivity of 50ms and ensuring runtime resume before SDHC registers are accessed. During runtime suspend, interrupts are masked. The host controller state is restored at runtime resume. For Medfield, the host controller's card detect mechanism is supplanted by an always-on GPIO which provides for card detect wake-up. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit 66fd8ad5100b5003046aa744a4f12fa31bb831f9)
2015-03-30Merge remote-tracking branch 'remotes/ubifs-v3.1/master' into tegra-nand-nextMarcel Ziswiler
Conflicts: drivers/mtd/ubi/ubi.h drivers/mtd/ubi/wl.c
2015-02-03mmc: Add tracepoints of mmc block operationsKen Sumrall
Add tracepoints to record the start and end of each mmc block operation. This includes read, write, erase, secure erase, trim, secure trim1 and secure trim 2, discard and sanitize commands. Change-Id: Ic5d1cbdb9adb940d8b1a2a13c73970023575df50 Signed-off-by: Ken Sumrall <ksumrall@android.com> Signed-off-by: Iliyan Malchev <malchev@google.com> Conflicts: drivers/mmc/card/block.c drivers/mmc/core/core.c (cherry picked from commit 4de9a433c26e47d9b4a93105eb92935321100786)
2015-02-03mmc: core: new discard feature support at Samsung eMMC v4.41+.singhome_lee
Support discard feature if MID field in the CID register is 0x15, EXT.CSD[192] (device version) is 5 and Bit 0 in the EXT.CSD[64] is 1. Also removed REQ_SECURE flag check to avoid kernel hang. This patch is released from samsung. Change-Id: I4023a900680e9bca10c40311b09ed077a22617db (cherry picked from commit 4acc227edfb631d377e14911287c1b73682fc9c2) Conflicts: drivers/mmc/card/block.c
2015-02-03eMMC: Add Product revision, Sector count and driver init logban_feng
Change-Id: I89b544afbb0a109a222621a9948399fba8f77693 Change-Id: Ie366a152100a478e7811b4395f3fae9794bb1386 Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45221 Reviewed-by: Ban Feng <Ban_Feng@asus.com> Tested-by: Ban Feng <Ban_Feng@asus.com> Reviewed-by: Sam hblee <Sam_hblee@asus.com> Conflicts: drivers/mmc/core/mmc.c include/linux/mmc/card.h asdf
2015-01-16Merge remote-tracking branch 'remotes/nvidia/l4t/l4t-r16-r2' into tegra-nextMarcel Ziswiler
(tegra-l4t-r16-16.5) Conflicts: drivers/media/video/tegra_v4l2_camera.c drivers/mmc/host/sdhci.c drivers/watchdog/tegra_wdt.c include/media/tegra_v4l2_camera.h
2015-01-09media: Added Analog Devices ADV7280 video decoder driverWojciech Bieganski
2014-07-31video: tegra: nvhost: validate nvmap_handle_refBibek Basu
nvhost_job_unpin should always get the nvmap_handle_ref from rb_entry after validating handle and presence in the tree. Bug 1478467 Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/436076 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2014-06-04Added continuous mode capture supportAlex Feinman
Signed-off-by: Bryan Wu <pengw@nvidia.com> Change-Id: I67c50ff86b53a6c1001d2b688251dc55bd2eff55 Reviewed-on: http://git-master/r/419070 Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2014-05-28mmc: sdhci: add quirk for lack of 1.8v supportJeetesh Burman
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Bug 1402031 Change-Id: I7ca070a13241e6403eb2e243ebbc441a311110bc Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Jeetesh Burman <jburman@nvidia.com> Reviewed-on: http://git-master/r/346323 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2014-04-22media: added camera settings per decoderWojciech Bieganski
This commit adds settings such as: - values of horizontal/vertical active start, - enabling/disabling internal sync, to the private data of decoders: MAX9526, ADV7180, TVP5150, OV7670 and AS0260. The feature is available through *_tegra_camera_platform_data struct initialised in board-*.c files.
2014-03-31ptp: Add a method for obtaining the device index.Richard Cochran
This commit adds a method that MAC drivers may call in order to find out the device number of their associated PTP Hardware Clock. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-31ethtool: Introduce a method for getting time stamping capabilities.Richard Cochran
This commit adds a new ethtool ioctl that exposes the SO_TIMESTAMPING capabilities of a network interface. In addition, user space programs can use this ioctl to discover the PTP Hardware Clock (PHC) device associated with the interface. Since software receive time stamps are handled by the stack, the generic ethtool code can answer the query correctly in case the MAC or PHY drivers lack special time stamping features. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-31ethtool: Centralise validation of ETHTOOL_{G, S}RXFHINDIR parametersBen Hutchings
Add a new ethtool operation (get_rxfh_indir_size) to get the indirectional table size. Use this to validate the user buffer size before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get the number of RX rings, and validate the contents of the new indirection table before calling set_rxfh_indir. Remove this validation from drivers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: drivers/media/video/tegra_v4l2_camera.c reverted to current driver supporting ACM rather than CSI2 drivers/media/video/videobuf2-dma-nvmap.c drivers/video/tegra/host/Makefile
2014-01-29input: touchscreen: added platform data for Fusion touchscreenStefan Agner
Added platform data struct to define interrupt and reset GPIO. This allows to initialize the touchscreen controller inside the driver rather then in each platform and use the driver as a module.
2013-12-09mfd: stmpe: add ADC block resourcesStefan Agner
In order to use the auxiliar ADC inputs of STMPE811 devices we need to add resources for the ADC block. Also move the ADC macros from the touchscreen driver to the general header file. We will need them for the ADC driver in future.
2013-07-05UBI: document UBI_IOCVOLUP better in user headerMike Frysinger
The current ioctl define implies that this func expects to be passed a 64bit number directly rather than a pointer to a 64bit. The code that processes this ioctl shows that it clearly expects a pointer. It'd be best if we could change the type to "__s64*", but that would change the generated ioctl number thus breaking the userland ABI. So just add a comment for intrepid developers. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-06-24hwmon: lm95245: add local critical shutdown temp hookMax Krummenacher
export access to the 'Local Shared OS and T_Crit Limit' register.
2013-04-18mmc: sdhci: add quirk for lack of 1.8v supportDaniel Drake
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-03-05media: soc_camera: add OV5650 SoC camera I2C device driverBryan Wu
OV5650 is a RAW sensor outputing Bayer RAW 8 or RAW 10 data. This driver uses SoC camera interface and supports several different resolution. Change-Id: I8075b63b42f7949a264bdef446f5ed8bdc0a9eee Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/200223 GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-03-05tegra: Make tegra_vi01_device accessibleAndrew Chew
Make it accessible outside of drivers/video/tegra. V4L2 driver needs to set some platform_data. Add suport for T20. Change-Id: I98353c2874ea28cfa0a7a5dd8a1dc4c586af4dd7 Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/200220 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
