Differs from mainline, but the functionality is already there.
Backport ATA_FLAG_NO_SRST and ATA_FLAG_ASSUME_ATA. These are
originally link flags (ATA_LFLAG_*) but link abstraction doesn't exist
on 2.6.23, so make it port flags.
This is for the following workaround for ASUS P5W DH Deluxe.
These new flags don't introduce any behavior change unless set and
nobody sets them yet.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Jeff Garzik <jeff@garzik.org>
patch 1b678347121001c3c230c6eccfdf9f65c3ec1a4e in mainline.
This adds a helper to get to the "other" drive on a pair connected
to a given hwif.
Cc: Andrew Morton <akpm@osdl.org>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
patch a691efa9888e71232dfb4088fb8a8304ffc7b0f9 in mainline.
This patch (as995) cleans up the remains of the former NO_AUTOSUSPEND
quirk. Since autosuspend is disabled by default, we will let
userspace worry about which devices can safely be suspended. Thus the
lengthy series of quirk entries is no longer needed, and neither is
the quirk ID. I suppose someone might eventually run across a hub
that can't be suspended; let's ignore the possibility for now.
The patch also cleans up the hasty way in which autosuspend gets
disabled. Setting udev->autosuspend_delay to -1 wasn't quite right,
because the value is always supposed to be a multiple of HZ. It's
better to leave the delay value alone and set autosuspend_disabled,
which is what the quirk routine used to do.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
patch 96fd4cd3e40e240f0c385af87f58e74da8b7099a in mainline.
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
[NETLINK]: Fix unicast timeouts
[ Upstream commit: c3d8d1e30cace31fed6186a4b8c6b1401836d89c ]
Commit ed6dcf4a in the history.git tree broke netlink_unicast timeouts
by moving the schedule_timeout() call to a new function that doesn't
propagate the remaining timeout back to the caller. This means on each
retry we start with the full timeout again.
ipc/mqueue.c seems to actually want to wait indefinitely so this
behaviour is retained.
[TCP]: Fix size calculation in sk_stream_alloc_pskb
[ Upstream commit: fb93134dfc2a6e6fbedc7c270a31da03fce88db9 ]
We round up the header size in sk_stream_alloc_pskb so that
TSO packets get zero tail room. Unfortunately this rounding
up is not coordinated with the select_size() function used by
TCP to calculate the second parameter of sk_stream_alloc_pskb.
As a result, we may allocate more than a page of data in the
non-TSO case when exactly one page is desired.
In fact, rounding up the head room is detrimental in the non-TSO
case because it makes memory that would otherwise be available to
the payload head room. TSO doesn't need this either, all it wants
is the guarantee that there is no tail room.
So this patch fixes this by adjusting the skb_reserve call so that
exactly the requested amount (which all callers have calculated in
a precise way) is made available as tail room.
patch deea84b0ae3d26b41502ae0a39fe7fe134e703d0 in mainline.
[NET]: Fix SKB_WITH_OVERHEAD calculation
The calculation in SKB_WITH_OVERHEAD is incorrect in that it can cause
an overflow across a page boundary which is what it's meant to prevent.
In particular, the header length (X) should not be lumped together with
skb_shared_info. The latter needs to be aligned properly while the header
has no choice but to sit in front of wherever the payload is.
Therefore the correct calculation is to take away the aligned size of
skb_shared_info, and then subtract the header length. The resulting
quantity L satisfies the following inequality:
SKB_DATA_ALIGN(L + X) + sizeof(struct skb_shared_info) <= PAGE_SIZE
This is the quantity used by alloc_skb to do the actual allocation.
patch 092e9d93b3728d484a4e73df9852dc4002cf9923 in mainline.
[9P]: build fix with !CONFIG_SYSCTL
found via make randconfig build testing:
net/built-in.o: In function `init_p9':
mod.c:(.init.text+0x3b39): undefined reference to `p9_sysctl_register'
net/built-in.o: In function `exit_p9':
mod.c:(.exit.text+0x36b): undefined reference to `p9_sysctl_unregister'
Reverted upstream by commit 6a22c57b8d2a62dea7280a6b2ac807a539ef0716
Revert this commit:
commit 2e1c49db4c640b35df13889b86b9d62215ade4b6
Author: Zou Nan hai <nanhai.zou@intel.com>
Date: Fri Jun 1 00:46:28 2007 -0700
x86_64: allocate sparsemem memmap above 4G
This reverts commit 2e1c49db4c640b35df13889b86b9d62215ade4b6.
First off, testing in Fedora has shown it to cause boot failures,
bisected down by Martin Ebourne, and reported by Dave Jobes. So the
commit will likely be reverted in the 2.6.23 stable kernels.
Secondly, in the 2.6.24 model, x86-64 has now grown support for
SPARSEMEM_VMEMMAP, which disables the relevant code anyway, so while the
bug is not visible any more, it's become invisible due to the code just
being irrelevant and no longer enabled on the only architecture that
this ever affected.
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Martin Ebourne <fedora@ebourne.me.uk>
Cc: Zou Nan hai <nanhai.zou@intel.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Andy Whitcroft <apw@shadowen.org>
Cc: Chuck Ebbert <cebbert@redhat.com>
patch e3d2697669abbe26c08dc9b95e2a71c634d096ed in mainline.
The kernel's copy of struct vcpu_register_vcpu_info was out of date,
at best causing the hypercall to fail and the guest kernel to fall
back to the old mechanism, or worse, causing random memory corruption.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Stable Kernel <stable@kernel.org>
Cc: Morten =?utf-8?q?B=C3=B8geskov?= <xen-users@morten.bogeskov.dk>
Cc: Mark Williamson <mark.williamson@cl.cam.ac.uk>
patch 572afc248c33c902760f6f24a72c180f0e4f1719 in mainline.
Tested with Malta; inflates malta_defconfig by 3932 bytes. Ideally there
should be additional configuration to allow getting rid of this overhead
but that would be too much complexity at this stage of the release cycle.
patch 6eca9004dfcb274a502438a591df5b197690afb1 in mainline.
For the locking to work, only the tag map and tag bit map may be shared
(incidentally, I was just explaining this to Nick yesterday, but I
apparently didn't review the code well enough myself). But we also share
the busy list! The busy_list must be queue private, or we need a
block_queue_tag covering lock as well.
So we have to move the busy_list to the queue. This'll work fine, and
it'll actually also fix a problem with blk_queue_invalidate_tags() which
will invalidate tags across all shared queues. This is a bit confusing,
the low level driver should call it for each queue seperately since
otherwise you cannot kill tags on just a single queue for eg a hard
drive that stops responding. Since the function has no callers
currently, it's not an issue.
This is fixed with commit 6eca9004dfcb274a502438a591df5b197690afb1 in
Linus' tree.
sched: keep utime/stime monotonic
cpustats use utime/stime as a ratio against sum_exec_runtime, as a
consequence it can happen - when the ratio changes faster than time
accumulates - that either can be appear to go backwards.
Combined backport for 2.6.23 of the following patches from mainline:
commit 73a2bcb0edb9ffb0b007b3546b430e2c6e415eee
Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit 9301899be75b464ef097f0b5af7af6d9bd8f68a7
Author: Balbir Singh <balbir@linux.vnet.ibm.com>
sched: fix /proc/<PID>/stat stime/utime monotonicity, part 2
Signed-off-by: Frans Pop <elendil@planet.nl>
CC: Peter Zijlstra <a.p.zijlstra@chello.nl>
CC: Balbir Singh <balbir@linux.vnet.ibm.com>
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[IPv6]: Fix ICMPv6 redirect handling with target multicast address
[PKT_SCHED] cls_u32: error code isn't been propogated properly
[ROSE]: Fix rose.ko oops on unload
[TCP]: Fix fastpath_cnt_hint when GSO skb is partially ACKed
All the current page_mkwrite() implementations also set the page dirty. Which
results in the set_page_dirty_balance() call to _not_ call balance, because the
page is already found dirty.
This allows us to dirty a _lot_ of pages without ever hitting
balance_dirty_pages(). Not good (tm).
Force a balance call if ->page_mkwrite() was successful.
Commit a3d384029aa304f8f3f5355d35f0ae274454f7cd aka
"[AX.25]: Fix unchecked rose_add_loopback_neigh uses"
transformed rose_loopback_neigh var into statically allocated one.
However, on unload it will be kfree's which can't work.
Steps to reproduce:
modprobe rose
rmmod rose
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000008
printing eip:
c014c664
*pde = 00000000
Oops: 0000 [#1]
PREEMPT DEBUG_PAGEALLOC
Modules linked in: rose ax25 fan ufs loop usbhid rtc snd_intel8x0 snd_ac97_codec ehci_hcd ac97_bus uhci_hcd thermal usbcore button processor evdev sr_mod cdrom
CPU: 0
EIP: 0060:[<c014c664>] Not tainted VLI
EFLAGS: 00210086 (2.6.23-rc9 #3)
EIP is at kfree+0x48/0xa1
eax: 00000556 ebx: c1734aa0 ecx: f6a5e000 edx: f7082000
esi: 00000000 edi: f9a55d20 ebp: 00200287 esp: f6a5ef28
ds: 007b es: 007b fs: 0000 gs: 0033 ss: 0068
Process rmmod (pid: 1823, ti=f6a5e000 task=f7082000 task.ti=f6a5e000)
Stack: f9a55d20 f9a5200c 00000000 00000000 00000000 f6a5e000 f9a5200c f9a55a00
00000000 bf818cf0 f9a51f3f f9a55a00 00000000 c0132c60 65736f72 00000000
f69f9630 f69f9528 c014244a f6a4e900 00200246 f7082000 c01025e6 00000000
Call Trace:
[<f9a5200c>] rose_rt_free+0x1d/0x49 [rose]
[<f9a51f3f>] rose_exit+0x4c/0xd5 [rose]
[<c0132c60>] sys_delete_module+0x15e/0x186
[<c014244a>] remove_vma+0x40/0x45
[<c01025e6>] sysenter_past_esp+0x8f/0x99
[<c012bacf>] trace_hardirqs_on+0x118/0x13b
[<c01025b6>] sysenter_past_esp+0x5f/0x99
Code: 05 03 1d 80 db 5b c0 8b 03 25 00 40 02 00 3d 00 40 02 00 75 03 8b 5b 0c 8b 73 10 8b 44 24 18 89 44 24 04 9c 5d fa e8 77 df fd ff <8b> 56 08 89 f8 e8 84 f4 fd ff e8 bd 32 06 00 3b 5c 86 60 75 0f
EIP: [<c014c664>] kfree+0x48/0xa1 SS:ESP 0068:f6a5ef28
It turns out that there are a few other five-second timers in the
kernel, and if the timers get in sync, the load-average can get
artificially inflated by events that just happen to coincide.
So just offset the load average calculation it by a timer tick.
Noticed by Anders Boström, for whom the coincidence started triggering
on one of his machines with the JBD jiffies rounding code (JBD is one of
the subsystems that also end up using a 5-second timer by default).
Tested-by: Anders Boström <anders@bostrom.dyndns.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
It is ok to call prefetch() function with NULL argument, as specifically
commented in include/linux/prefetch.h. But in standard C, it is invalid
to dereference NULL pointer (see C99 standard 6.5.3.2 paragraph 4 and
note #84).
prefetch() has a memory reference for its argument.
Newer gcc versions (4.3 and above) will use that to conclude that "x"
argument is non-null and thus wreaking havok everywhere prefetch() was
inlined.
Fixed by removing cast and changing asm constraint.
[ It seems in theory gcc 4.2 could miscompile this too; although no
cases known. In 2.6.24 we should probably switch to
__builtin_prefetch() instead, but this is a simpler fix for now.
-- AK ]
Signed-off-by: Serge Belyshev <belyshev@depni.sinp.msu.ru>
Signed-off-by: Andi Kleen <ak@suse.de>
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Terminally fix local_{dec,sub}_if_positive
[MIPS] Type proof reimplementation of cmpxchg.
[MIPS] pg-r4k.c: Fix a typo in an R4600 v2 erratum workaround
Pokki <kalle.pokki@iki.fi>
Cc: Kalle Pokki <kalle.pokki@iki.fi>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
chip ethernet mac driver
They contain 64-bit instructions so wouldn't work on 32-bit kernels or
32-bit hardware. Since there are no users, blow them away. They
probably were only ever created because there are atomic_sub_if_positive
and atomic_dec_if_positive which exist only for sake of semaphores.
[MIPS] vmlinux.lds.S: Handle note sections
[MIPS] Fix value of O_TRUNC
A "cleanup" almost two years ago deleted the old definition from
<asm/fcntl.h>, so asm-generic/fcntl.h defaulted it to the the same
value as FASYNC ... which happened to be the wrong thing.
The comment being removed by this patch is incorrect and misleading.
In the following situation:
1. load ...
2. store 1 -> X
3. wmb
4. rmb
5. load a <- Y
6. store ...
4 will only ensure ordering of 1 with 5.
3 will only ensure ordering of 2 with 6.
Further, a CPU with strictly in-order stores will still only provide that
2 and 6 are ordered (effectively, it is the same as a weakly ordered CPU
with wmb after every store).
In all cases, 5 may still be executed before 2 is visible to other CPUs!
The additional piece of the puzzle that mb() provides is the store/load
ordering, which fundamentally cannot be achieved with any combination of
rmb()s and wmb()s.
This can be an unexpected result if one expected any sort of global ordering
guarantee to barriers (eg. that the barriers themselves are sequentially
consistent with other types of barriers). However sfence or lfence barriers
need only provide an ordering partial ordering of memory operations -- Consider
that wmb may be implemented as nothing more than inserting a special barrier
entry in the store queue, or, in the case of x86, it can be a noop as the store
queue is in order. And an rmb may be implemented as a directive to prevent
subsequent loads only so long as their are no previous outstanding loads (while
there could be stores still in store queues).
I can actually see the occasional load/store being reordered around lfence on
my core2. That doesn't prove my above assertions, but it does show the comment
is wrong (unless my program is -- can send it out by request).
So:
mb() and smp_mb() always have and always will require a full mfence
or lock prefixed instruction on x86. And we should remove this comment.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Paul McKenney <paulmck@us.ibm.com>
Cc: Andi Kleen <ak@suse.de>
[TCP]: Fix MD5 signature handling on big-endian.
[NET]: Zero length write() on socket should not simply return 0.
Based upon a report and initial patch by Peter Lieven.
tcp4_md5sig_key and tcp6_md5sig_key need to start with
the exact same members as tcp_md5sig_key. Because they
are both cast to that type by tcp_v{4,6}_md5_do_lookup().
Unfortunately tcp{4,6}_md5sig_key use a u16 for the key
length instead of a u8, which is what tcp_md5sig_key
uses. This just so happens to work by accident on
little-endian, but on big-endian it doesn't.
Instead of casting, just place tcp_md5sig_key as the first member of
the address-family specific structures, adjust the access sites, and
kill off the ugly casts.
The __pa() for those did assume that all symbols have XKPHYS values and
the math fails for any other address range.
This reverts commit 184c44d2049c4db7ef6ec65794546954da2c6a0e.
As noted by Dave Jones:
"Linus, please revert the above cset. It doesn't seem to be
necessary (it was added to fix a miscompile in 'make allnoconfig'
which doesn't seem to be repeatable with it reverted) and actively
breaks the ARM SA1100 framebuffer driver."
Requested-by: Dave Jones <davej@redhat.com>
Cc: Russell King <rmk+lkml@arm.linux.org.uk>
This reverts commit e66485d747505e9d960b864fc6c37f8b2afafaf0, since
Rafael Wysocki noticed that the change only works for his in -mm, not in
mainline (and that both "noapictimer" _and_ "apicmaintimer" are broken
on his hardware, but that's apparently not a regression, just a symptom
of the same issue that causes the automatic apic timer disable to not
work).
It turns out that it really doesn't work correctly on x86-64, since
x86-64 doesn't use the generic clock events for timers yet.
Thanks to Rafal for testing, and here's the ugly details on x86-64 as
per Thomas:
"I just looked into the code and the logic vs. noapictimer on SMP is
completely broken.
On i386 the noapictimer option not only disables the local APIC
timer, it also registers the CPUs for broadcasting via IPI on SMP
systems.
The x86-64 code uses the broadcast only when the local apic timer is
active, i.e. "noapictimer" is not on the command line. This defeats
the whole purpose of "noapictimer". It should be there to make boxen
work, where the local APIC timer actually has a hardware problem,
e.g. the nx6325.
The current implementation of x86_64 only fixes the ACPI c-states
related problem where the APIC timer stops in C3(2), nothing else.
On nx6325 and other AMD X2 equipped systems which have the C1E
enabled we run into the following:
PIT keeps jiffies (and the system) running, but the local APIC timer
interrupts can get out of sync due to this C1E effect.
I don't think this is a critical problem, but it is wrong
nevertheless.
I think it's safe to revert the C1E patch and postpone the fix to the
clock events conversion."
On further reflection, Thomas noted:
"It's even worse than I thought on the first check:
"noapictimer" on the command line of an SMP box prevents _ONLY_ the
boot CPU apic timer from being used. But the secondary CPU is still
unconditionally setting up the APIC timer and uses the non
calibrated variable calibration_result, which is of course 0, to
setup the APIC timer. Wreckage guaranteed."
so we'll just have to wait for the x86 merge to hopefully fix this up
for x86-64.
Tested-and-requested-by: Rafael J. Wysocki <rjw@sisk.pl>
commit 3556ddfa9284a86a59a9b78fe5894430f6ab4eef titled
[PATCH] x86-64: Disable local APIC timer use on AMD systems with C1E
solves a problem with AMD dual core laptops e.g. HP nx6325 (Turion 64
X2) with C1E enabled:
When both cores go into idle at the same time, then the system switches
into C1E state, which is basically the same as C3. This stops the local
apic timer.
This was debugged right after the dyntick merge on i386 and despite the
patch title it fixes only the 32 bit path.
x86_64 is still missing this fix. It seems that mainline is not really
affected by this issue, as the PIT is running and keeps jiffies
incrementing, but that's just waiting for trouble.
-mm suffers from this problem due to the x86_64 high resolution timer
patches.
This is a quick and dirty port of the i386 code to x86_64.
I spent quite a time with Rafael to debug the -mm / hrt wreckage until
someone pointed us to this. I really had forgotten that we debugged this
half a year ago already.
Sigh, is it just me or is there something yelling arch/x86 into my ear?
Tested-by: Rafael J. Wysocki <rjw@sisk.pl>
It gets pointer to fastcall function, expects a pointer to normal
one and calls the sucker.
[PPP_MPPE]: Don't put InterimKey on the stack
SCTP : Add paramters validity check for ASCONF chunk
SCTP: Discard OOTB packetes with bundled INIT early.
SCTP: Clean up OOTB handling and fix infinite loop processing
SCTP: Explicitely discard OOTB chunks
SCTP: Send ABORT chunk with correct tag in response to INIT ACK
SCTP: Validate buffer room when processing sequential chunks
[PATCH] mac80211: fix initialisation when built-in
[PATCH] net/mac80211/wme.c: fix sparse warning
[PATCH] cfg80211: fix initialisation if built-in
[PATCH] net/wireless/sysfs.c: Shut up build warning
If ADDIP is enabled, when an ASCONF chunk is received with ASCONF
paramter length set to zero, this will cause infinite loop.
By the way, if an malformed ASCONF chunk is received, will cause
processing to access memory without verifying.
This is because of not check the validity of parameters in ASCONF chunk.
This patch fixed this.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
While processing OOTB chunks as well as chunks with an invalid
length of 0, it was possible to SCTP to get wedged inside an
infinite loop because we didn't catch the condition correctly,
or didn't mark the packet for discard correctly.
This work is based on original findings and work by
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Len Brown <len.brown@intel.com>
Issue reported and original patch by Kevin Kissel, cleaner (imho)
implementation by me.
device_suspend() calls ACPI suspend functions, which seems to have undesired
side effects on lower idle C-states. It took me some time to realize that
especially the VAIO BIOSes (both Andrews jinxed UP and my elfstruck SMP one)
show this effect. I'm quite sure that other bug reports against suspend/resume
about turning the system into a brick have the same root cause.
After fishing in the dark for quite some time, I realized that removing the ACPI
processor module before suspend (this removes the lower C-state functionality)
made the problem disappear. Interestingly enough the propability of having a
bricked box is influenced by various factors (interrupts, size of the ram image,
...). Even adding a bunch of printks in the wrong places made the problem go
away. The previous periodic tick implementation simply pampered over the
problem, which explains why the dyntick / clockevents changes made this more
prominent.
We avoid complex functionality during the boot process and we have to do the
same during suspend/resume. It is a similar scenario and equaly fragile.
Add suspend / resume functions to the ACPI processor code and disable the lower
idle C-states across suspend/resume. Fall back to the default idle
implementation (halt) instead.
Tested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Len Brown <lenb@kernel.org>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
When compiling the Blackfin kernel, checksyscalls.pl will report lots of missing syscalls warnings.
This patch will add some missing syscalls which make sense on Blackfin arch
After appling this patch, toolchain should be rebuilt. Then recompiling the kernel with the new
toolchain.
Add minimum support for the Blackfin relocations, since we don't have
enough space in each reloc. The idea is to store a value with one
relocation so that subsequent ones can access it.
Actually, this patch is required for Blackfin. Currently if BINFMT_FLAT is
enabled, git-tree kernel will fail to compile.
Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com>
Cc: David McCullough <davidm@snapgear.com>
Cc: Greg Ungerer <gerg@snapgear.com>
Cc: Miles Bader <miles.bader@necel.com>
This reverts commit 34feb2c83beb3bdf13535a36770f7e50b47ef299.
Suresh Siddha points out that this one breaks the fundamental
requirement that you cannot free page table pages before the TLB caches
are flushed. The quicklists do not give the same kinds of guarantees
that the mmu_gather structure does, at least not in NUMA configurations.
Requested-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Andi Kleen <ak@suse.de>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
This simplifies signalfd code, by avoiding it to remain attached to the
sighand during its lifetime.
In this way, the signalfd remain attached to the sighand only during
poll(2) (and select and epoll) and read(2). This also allows to remove
all the custom "tsk == current" checks in kernel/signal.c, since
dequeue_signal() will only be called by "current".
I think this is also what Ben was suggesting time ago.
The external effect of this, is that a thread can extract only its own
private signals and the group ones. I think this is an acceptable
behaviour, in that those are the signals the thread would be able to
fetch w/out signalfd.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
add /proc/sys/kernel/sched_compat_yield to make sys_sched_yield()
more agressive, by moving the yielding task to the last position
in the rbtree.
with sched_compat_yield=0:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2539 mingo 20 0 1576 252 204 R 50 0.0 0:02.03 loop_yield
2541 mingo 20 0 1576 244 196 R 50 0.0 0:02.05 loop
with sched_compat_yield=1:
2584 mingo 20 0 1576 248 196 R 99 0.0 0:52.45 loop
2582 mingo 20 0 1576 256 204 R 0 0.0 0:00.00 loop_yield
[MIPS] cpu-bugs64.c: GCC 3.3 constraint workaround
[MIPS] DEC: Initialise ioasic_ssr_lock
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Fix timekeeping on PowerPC 601
[POWERPC] Don't expose clock vDSO functions when CPU has no timebase
[POWERPC] spusched: Fix null pointer dereference in find_victim
Add a workaround to address warnings generated on the "n" constraint by
GCC 3.3 and below.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
This patch proposes fixes to the reference counting of memory policy in the
page allocation paths and in show_numa_map(). Extracted from my "Memory
Policy Cleanups and Enhancements" series as stand-alone.
Shared policy lookup [shmem] has always added a reference to the policy,
but this was never unrefed after page allocation or after formatting the
numa map data.
Default system policy should not require additional ref counting, nor
should the current task's task policy. However, show_numa_map() calls
get_vma_policy() to examine what may be [likely is] another task's policy.
The latter case needs protection against freeing of the policy.
This patch adds a reference count to a mempolicy returned by
get_vma_policy() when the policy is a vma policy or another task's
mempolicy. Again, shared policy is already reference counted on lookup. A
matching "unref" [__mpol_free()] is performed in alloc_page_vma() for
shared and vma policies, and in show_numa_map() for shared and another
task's mempolicy. We can call __mpol_free() directly, saving an admittedly
inexpensive inline NULL test, because we know we have a non-NULL policy.
Handling policy ref counts for hugepages is a bit trickier.
huge_zonelist() returns a zone list that might come from a shared or vma
'BIND policy. In this case, we should hold the reference until after the
huge page allocation in dequeue_hugepage(). The patch modifies
huge_zonelist() to return a pointer to the mempolicy if it needs to be
unref'd after allocation.
Kernel Build [16cpu, 32GB, ia64] - average of 10 runs:
w/o patch w/ refcount patch
Avg Std Devn Avg Std Devn
Real: 100.59 0.38 100.63 0.43
User: 1209.60 0.37 1209.91 0.31
System: 81.52 0.42 81.64 0.34
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
It turned out, that the user namespace is released during the do_exit() in
exit_task_namespaces(), but the struct user_struct is released only during the
put_task_struct(), i.e. MUCH later.
On debug kernels with poisoned slabs this will cause the oops in
uid_hash_remove() because the head of the chain, which resides inside the
struct user_namespace, will be already freed and poisoned.
Since the uid hash itself is required only when someone can search it, i.e.
when the namespace is alive, we can safely unhash all the user_struct-s from
it during the namespace exiting. The subsequent free_uid() will complete the
user_struct destruction.
For example simple program
#include <sched.h>
char stack[2 * 1024 * 1024];
int f(void *foo)
return 0;
int main(void)
clone(f, stack + 1 * 1024 * 1024, 0x10000000, 0);
return 0;
run on kernel with CONFIG_USER_NS turned on will oops the
kernel immediately.
This was spotted during OpenVZ kernel testing.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Acked-by: "Serge E. Hallyn" <serue@us.ibm.com>
Surprisingly, but (spotted by Alexey Dobriyan) the uid hash still uses
list_heads, thus occupying twice as much place as it could. Convert it to
hlist_heads.
Acked-by: Serge Hallyn <serue@us.ibm.com>
