commit 098507ae3ec2331476fb52e85d4040c1cc6d0ef4 upstream.
The replacement of the 'count' variable by two variables 'incs' and
'decs' to resolve some race conditions during module unloading was done
in parallel with some cleanup in the trace subsystem, and was integrated
as a merge.
Unfortunately, the formula for this replacement was wrong in the tracing
code, and the refcount in the traces was not usable as a result.
Use 'count = incs - decs' to compute the user count.
Link: http://lkml.kernel.org/p/1393924179-9147-1-git-send-email-romain.izard.pro@gmail.com
Acked-by: Ingo Molnar <mingo@kernel.org>
Fixes: c1ab9cab7509 "merge conflict resolution"
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
commit a949ae560a511fe4e3adf48fa44fefded93e5c2b upstream.
A race exists between module loading and enabling of function tracer.
CPU 1 CPU 2
load_module()
module->state = MODULE_STATE_COMING
register_ftrace_function()
mutex_lock(&ftrace_lock);
ftrace_startup()
update_ftrace_function();
ftrace_arch_code_modify_prepare()
set_all_module_text_rw();
<enables-ftrace>
ftrace_arch_code_modify_post_process()
set_all_module_text_ro();
[ here all module text is set to RO,
including the module that is
loading!! ]
blocking_notifier_call_chain(MODULE_STATE_COMING);
ftrace_init_module()
[ tries to modify code, but it's RO, and fails!
ftrace_bug() is called]
When this race happens, ftrace_bug() will produces a nasty warning and
all of the function tracing features will be disabled until reboot.
The simple solution is to treate module load the same way the core
kernel is treated at boot. To hardcode the ftrace function modification
of converting calls to mcount into nops. This is done in init/main.c
there's no reason it could not be done in load_module(). This gives
a better control of the changes and doesn't tie the state of the
module to its notifiers as much. Ftrace is special, it needs to be
treated as such.
The reason this would work, is that the ftrace_module_init() would be
called while the module is in MODULE_STATE_UNFORMED, which is ignored
by the set_all_module_text_ro() call.
Link: http://lkml.kernel.org/r/1395637826-3312-1-git-send-email-indou.takao@jp.fujitsu.com
Reported-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
[bwh: Backported to 3.2: adjust context]
commit 98fda169290b3b28c0f2db2b8f02290c13da50ef upstream.
'.done' is used to mark the completion of 'async_pf_execute()', but
'cancel_work_sync()' returns true when the work was canceled, so we
use it instead.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: Gleb Natapov <gleb@redhat.com>
[ Upstream commit ec47ea82477404631d49b8e568c71826c9b663ac ]
With the recent changes for how we compute the skb truesize it occurs to me
we are probably going to have a lot of calls to skb_end_pointer -
skb->head. Instead of running all over the place doing that it would make
more sense to just make it a separate inline skb_end_offset(skb) that way
we can return the correct value without having gcc having to do all the
optimization to cancel out skb->head - skb->head.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 30f78d8ebf7f514801e71b88a10c948275168518 ]
Francois reported that setting big mtu on loopback device could prevent
tcp sessions making progress.
We do not support (yet ?) IPv6 Jumbograms and cook corrupted packets.
We must limit the IPv6 MTU to (65535 + 40) bytes in theory.
Tested:
ifconfig lo mtu 70000
netperf -H ::1
Before patch : Throughput : 0.05 Mbits
After patch : Throughput : 35484 Mbits
Reported-by: Francois WELLENREITER <f.wellenreiter@gmail.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
commit 5017b2851373ee15c7035151853bb1448800cae2 upstream.
dmi_match() considers a substring match to be a successful match. This is
not always sufficient to distinguish between DMI data for different
systems. Add support for exact string matching using strcmp() in addition
to the substring matching using strstr().
The specific use case in the i915 driver is to allow us to use an exact
match for D510MO, without also incorrectly matching D510MOV:
.ident = "Intel D510MO",
.matches = {
DMI_MATCH(DMI_BOARD_VENDOR, "Intel"),
DMI_EXACT_MATCH(DMI_BOARD_NAME, "D510MO"),
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Cc: <annndddrr@gmail.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Cornel Panceac <cpanceac@gmail.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Greg KH <greg@kroah.com>
commit 8a4aeec8d2d6a3edeffbdfae451cdf05cbf0fefd upstream.
The AHCI spec allows implementations to issue commands in tag order
rather than FIFO order:
5.3.2.12 P:SelectCmd
HBA sets pSlotLoc = (pSlotLoc + 1) mod (CAP.NCS + 1)
or HBA selects the command to issue that has had the
PxCI bit set to '1' longer than any other command
pending to be issued.
The result is that commands posted sequentially (time-wise) may play out
of sequence when issued by hardware.
This behavior has likely been hidden by drives that arrange for commands
to complete in issue order. However, it appears recent drives (two from
different vendors that we have found so far) inflict out-of-order
completions as a matter of course. So, we need to take care to maintain
ordered submission, otherwise we risk triggering a drive to fall out of
sequential-io automation and back to random-io processing, which incurs
large latency and degrades throughput.
This issue was found in simple benchmarks where QD=2 seq-write
performance was 30-50% *greater* than QD=32 seq-write performance.
Tagging for -stable and making the change globally since it has a low
risk-to-reward ratio. Also, word is that recent versions of an unnamed
OS also does it this way now. So, drives in the field are already
experienced with this tag ordering scheme.
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Ed Ciechanowski <ed.ciechanowski@intel.com>
Reviewed-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
commit ad36d28293936b03d6b7996e9d6aadfd73c0eb08 upstream.
Added the functions task_ppid_nr_ns() and task_ppid_nr() to abstract the lookup
of the PPID (real_parent's pid_t) of a process, including rcu locking, in the
arbitrary and init_pid_ns.
This provides an alternative to sys_getppid(), which is relative to the child
process' pid namespace.
(informed by ebiederman's 6c621b7e)
Cc: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
commit af5040da01ef980670b3741b3e10733ee3e33566 upstream.
trace_block_rq_complete does not take into account that request can
be partially completed, so we can get the following incorrect output
of blkparser:
C R 232 + 240 [0]
C R 240 + 232 [0]
C R 248 + 224 [0]
C R 256 + 216 [0]
but should be:
C R 232 + 8 [0]
C R 240 + 8 [0]
C R 248 + 8 [0]
C R 256 + 8 [0]
Also, the whole output summary statistics of completed requests and
final throughput will be incorrect.
This patch takes into account real completion size of the request and
fixes wrong completion accounting.
Signed-off-by: Roman Pen <r.peniaev@gmail.com>
CC: Steven Rostedt <rostedt@goodmis.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
CC: Ingo Molnar <mingo@redhat.com>
CC: linux-kernel@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
[bwh: Backported to 3.2: drop change in blk-mq.c]
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream.
[ use zero netdev_feature mask to avoid backport of
netif_skb_dev_features function ]
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
commit de960aa9ab4decc3304959f69533eef64d05d8e8 upstream.
[ no skb_gso_seglen helper in 3.4, leave tbf alone ]
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 5a581b367b5df0531265311fc681c2abd377e5e6 upstream.
According to the C standard 3.4.3p3, overflow of a signed integer results
in undefined behavior. This commit therefore changes the definitions
of time_after(), time_after_eq(), time_after64(), and time_after_eq64()
to avoid this undefined behavior. The trick is that the subtraction
is done using unsigned arithmetic, which according to 6.2.5p9 cannot
overflow because it is defined as modulo arithmetic. This has the added
(though admittedly quite small) benefit of shortening four lines of code
by four characters each.
Note that the C standard considers the cast from unsigned to
signed to be implementation-defined, see 6.3.1.3p3. However, on a
two's-complement system, an implementation that defines anything other
than a reinterpretation of the bits is free to come to me, and I will be
happy to act as a witness for its being committed to an insane asylum.
(Although I have nothing against saturating arithmetic or signals in some
cases, these things really should not be the default when compiling an
operating-system kernel.)
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kevin Easton <kevin@guarana.org>
[ paulmck: Included time_after64() and time_after_eq64(), as suggested
by Eric Dumazet, also fixed commit message.]
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit 45ab2813d40d88fc575e753c38478de242d03f88 upstream.
If a module fails to add its tracepoints due to module tainting, do not
create the module event infrastructure in the debugfs directory. As the events
will not work and worse yet, they will silently fail, making the user wonder
why the events they enable do not display anything.
Having a warning on module load and the events not visible to the users
will make the cause of the problem much clearer.
Link: http://lkml.kernel.org/r/20140227154923.265882695@goodmis.org
Fixes: 6d723736e472 "tracing/events: add support for modules to TRACE_EVENT"
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit a9f180345f5378ac87d80ed0bea55ba421d83859 upstream.
I started noticing problems with KVM guest destruction on Linux
3.12+, where guest memory wasn't being cleaned up. I bisected it
down to the commit introducing the new 'asm goto'-based atomics,
and found this quirk was later applied to those.
Unfortunately, even with GCC 4.8.2 (which ostensibly fixed the
known 'asm goto' bug) I am still getting some kind of
miscompilation. If I enable the asm_volatile_goto quirk for my
compiler, KVM guests are destroyed correctly and the memory is
cleaned up.
So make the quirk unconditional for now, until bug is found
and fixed.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Steven Noonan <steven@uplinklabs.net>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Richard Henderson <rth@twiddle.net>
Link: http://lkml.kernel.org/r/1392274867-15236-1-git-send-email-steven@uplinklabs.net
Link: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670
commit 564eb714f5f09ac733c26860d5f0831f213fbdf1 upstream.
xen/gntdev.h and xen/gntalloc.h both provide userspace ABIs so they
should be installed.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[bwh: Backported to 3.2: no renaming is required]
commit aad560b7f63b495f48a7232fd086c5913a676e6f upstream.
At IO preparation we calculate the max pages at each device and
allocate a BIO per device of that size. The calculation was wrong
on some unaligned corner cases offset/length combination and would
make prepare return with -ENOMEM. This would be bad for pnfs-objects
that would in that case IO through MDS. And fatal for exofs were it
would fail writes with EIO.
Fix it by doing the proper math, that will work in all cases. (I
ran a test with all possible offset/length combinations this time
round).
Also when reading we do not need to allocate for the parity units
since we jump over them.
Also lower the max_io_length to take into account the parity pages
so not to allocate BIOs bigger than PAGE_SIZE
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit 28a625cbc2a14f17b83e47ef907b2658576a32aa upstream.
Having this struct in module memory could Oops when if the module is
unloaded while the buffer still persists in a pipe.
Since sock_pipe_buf_ops is essentially the same as fuse_dev_pipe_buf_steal
merge them into nosteal_pipe_buf_ops (this is the same as
default_pipe_buf_ops except stealing the page from the buffer is not
allowed).
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit ecd75ad514d73efc1bbcc5f10a13566c3ace5f53 upstream.
For some reason, some early WD drives spin up and down drives
erratically when the link is put into slumber mode which can reduce
the life expectancy of the device significantly. Unfortunately, we
don't have full list of devices and given the nature of the issue it'd
be better to err on the side of false positives than the other way
around. Let's disable LPM on all WD devices which match one of the
known problematic model prefixes and are SATA-I.
As horkage list doesn't support matching SATA capabilities, this is
implemented as two horkages - WD_BROKEN_LPM and NOLPM. The former is
set for the known prefixes and sets the latter if the matched device
is SATA-I.
Note that this isn't optimal as this disables all LPM operations and
partial link power state reportedly works fine on these; however, the
way LPM is implemented in libata makes it difficult to precisely map
libata LPM setting to specific link power state. Well, these devices
are already fairly outdated. Let's just disable whole LPM for now.
Reported-and-tested-by: Nikos Barkas <levelwol@gmail.com>
Reported-and-tested-by: Ioannis Barkas <risc4all@yahoo.com>
References: https://bugzilla.kernel.org/show_bug.cgi?id=57211
- Adjust context
- Use literal 76 instead of ATA_ID_SATA_CAPABILITY]
commit 57d2aa00dcec67afa52478730f2b524521af14fb upstream.
The issue below was found in 2.6.34-rt rather than mainline rt
kernel, but the issue still exists upstream as well.
So please let me describe how it was noticed on 2.6.34-rt:
On this version, each softirq has its own thread, it means there
is at least one RT FIFO task per cpu. The priority of these
tasks is set to 49 by default. If user launches an RT FIFO task
with priority lower than 49 of softirq RT tasks, it's possible
there are two RT FIFO tasks enqueued one cpu runqueue at one
moment. By current strategy of balancing RT tasks, when it comes
to RT tasks, we really need to put them off to a CPU that they
can run on as soon as possible. Even if it means a bit of cache
line flushing, we want RT tasks to be run with the least latency.
When the user RT FIFO task which just launched before is
running, the sched timer tick of the current cpu happens. In this
tick period, the timeout value of the user RT task will be
updated once. Subsequently, we try to wake up one softirq RT
task on its local cpu. As the priority of current user RT task
is lower than the softirq RT task, the current task will be
preempted by the higher priority softirq RT task. Before
preemption, we check to see if current can readily move to a
different cpu. If so, we will reschedule to allow the RT push logic
to try to move current somewhere else. Whenever the woken
softirq RT task runs, it first tries to migrate the user FIFO RT
task over to a cpu that is running a task of lesser priority. If
migration is done, it will send a reschedule request to the found
cpu by IPI interrupt. Once the target cpu responds the IPI
interrupt, it will pick the migrated user RT task to preempt its
current task. When the user RT task is running on the new cpu,
the sched timer tick of the cpu fires. So it will tick the user
RT task again. This also means the RT task timeout value will be
updated again. As the migration may be done in one tick period,
it means the user RT task timeout value will be updated twice
within one tick.
If we set a limit on the amount of cpu time for the user RT task
by setrlimit(RLIMIT_RTTIME), the SIGXCPU signal should be posted
upon reaching the soft limit.
But exactly when the SIGXCPU signal should be sent depends on the
RT task timeout value. In fact the timeout mechanism of sending
the SIGXCPU signal assumes the RT task timeout is increased once
every tick.
However, currently the timeout value may be added twice per
tick. So it results in the SIGXCPU signal being sent earlier
than expected.
To solve this issue, we prevent the timeout value from increasing
twice within one tick time by remembering the jiffies value of
last updating the timeout. As long as the RT task's jiffies is
different with the global jiffies value, we allow its timeout to
be updated.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Fan Du <fan.du@windriver.com>
Reviewed-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1342508623-2887-1-git-send-email-ying.xue@windriver.com
[ lizf: backported to 3.4: adjust context ]
Signed-off-by: Li Zefan <lizefan@huawei.com>
[bwh: Backported to 3.2: adjust filename]
commit 27c73ae759774e63313c1fbfeb17ba076cea64c5 upstream.
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
[Khalid Aziz: Backported to 3.4]
This was added as part of commit 3d567e0e291c ('tg3: Set 10_100_ONLY
flag for additional 10/100 Mbps devices') upstream and is needed by
the following patch to ahci.
commit d00adcc8ae9e22eca9d8af5f66c59ad9a74c90ec upstream.
Fixes rendering corruption due to incorrect
gfx configuration.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=63599
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ]
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
functions
[ Upstream commit 85fbaa75037d0b6b786ff18658ddf0b4014ce2a4 ]
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit 51c37a70aaa3f95773af560e6db3073520513912 ]
For properly initialising the Tausworthe generator [1], we have
a strict seeding requirement, that is, s1 > 1, s2 > 7, s3 > 15.
Commit 697f8d0348 ("random32: seeding improvement") introduced
a __seed() function that imposes boundary checks proposed by the
errata paper [2] to properly ensure above conditions.
However, we're off by one, as the function is implemented as:
"return (x < m) ? x + m : x;", and called with __seed(X, 1),
__seed(X, 7), __seed(X, 15). Thus, an unwanted seed of 1, 7, 15
would be possible, whereas the lower boundary should actually
be of at least 2, 8, 16, just as GSL does. Fix this, as otherwise
an initialization with an unwanted seed could have the effect
that Tausworthe's PRNG properties cannot not be ensured.
Note that this PRNG is *not* used for cryptography in the kernel.
[1] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme.ps
[2] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme2.ps
Joint work with Hannes Frederic Sowa.
Fixes: 697f8d0348a6 ("random32: seeding improvement")
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
commit 503cf95c061a0551eb684da364509297efbe55d9 upstream.
When compiling with icc, <linux/compiler-gcc.h> ends up included
because the icc environment defines __GNUC__. Thus, we neither need
nor want to have this macro defined in both compiler-gcc.h and
compiler-intel.h, and the fact that they are inconsistent just makes
the compiler spew warnings.
Reported-by: Sunil K. Pandey <sunil.k.pandey@intel.com>
Cc: Kevin B. Smith <kevin.b.smith@intel.com>
Link: http://lkml.kernel.org/n/tip-0mbwou1zt7pafij09b897lg3@git.kernel.org
commit 932e9dec380c67ec15ac3eb073bb55797d8b4801 upstream.
When running a 32bit kernel the hda_intel driver is still reporting
a 64bit dma_mask if the HW supports it.
From sound/pci/hda/hda_intel.c:
/* allow 64bit DMA address if supported by H/W */
if ((gcap & ICH6_GCAP_64OK) && !pci_set_dma_mask(pci, DMA_BIT_MASK(64)))
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(64));
else {
pci_set_dma_mask(pci, DMA_BIT_MASK(32));
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(32));
which means when there is a call to dma_alloc_coherent from
snd_malloc_dev_pages a machine address bigger than 32bit can be returned.
This can be true in particular if running the 32bit kernel as a pv dom0
under the Xen Hypervisor or PAE on bare metal.
The problem is that when calling setup_bdle to program the BLE the
dma_addr_t returned from the dma_alloc_coherent is wrongly truncated
from snd_sgbuf_get_addr if running a 32bit kernel:
static inline dma_addr_t snd_sgbuf_get_addr(struct snd_dma_buffer *dmab,
size_t offset)
struct snd_sg_buf *sgbuf = dmab->private_data;
dma_addr_t addr = sgbuf->table[offset >> PAGE_SHIFT].addr;
addr &= PAGE_MASK;
return addr + offset % PAGE_SIZE;
where PAGE_MASK in a 32bit kernel is zeroing the upper 32bit af addr.
Without this patch the HW will fetch the 32bit truncated address,
which is not the one obtained from dma_alloc_coherent and will result
to a non working audio but can corrupt host memory at a random location.
The current patch apply to v3.13-rc3-74-g6c843f5
Signed-off-by: Stefano Panella <stefano.panella@citrix.com>
Reviewed-by: Frediano Ziglio <frediano.ziglio@citrix.com>
commit 389a5390583a18e45bc4abd4439291abec5e7a63 upstream.
Now that scatterwalk_sg_chain sets the chain pointer bit the sg_page
call in scatterwalk_sg_next hits a BUG_ON when CONFIG_DEBUG_SG is
enabled. Use sg_chain_ptr instead of sg_page on a chain entry.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 41da8b5adba77e22584f8b45f9641504fa885308 upstream.
The scatterwalk_crypto_chain function invokes the scatterwalk_sg_chain
function to chain two scatterlists, but the chain pointer indication
bit is not set. When the resulting scatterlist is used, for example,
by sg_nents to count the number of scatterlist entries, a segfault occurs
because sg_nents does not follow the chain pointer to the chained scatterlist.
Update scatterwalk_sg_chain to set the chain pointer indication bit as is
done by the sg_chain function.
commit 4e58e54754dc1fec21c3a9e824bc108b05fdf46e upstream.
If an TRACE_EVENT() uses __assign_str() or __get_str on a NULL pointer
then the following oops will happen:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<c127a17b>] strlen+0x10/0x1a
*pde = 00000000 ^M
Oops: 0000 [#1] PREEMPT SMP
Modules linked in:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.13.0-rc1-test+ #2
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006^M
task: f5cde9f0 ti: f5e5e000 task.ti: f5e5e000
EIP: 0060:[<c127a17b>] EFLAGS: 00210046 CPU: 1
EIP is at strlen+0x10/0x1a
EAX: 00000000 EBX: c2472da8 ECX: ffffffff EDX: c2472da8
ESI: c1c5e5fc EDI: 00000000 EBP: f5e5fe84 ESP: f5e5fe80
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 00000000 CR3: 01f32000 CR4: 000007d0
Stack:
f5f18b90 f5e5feb8 c10687a8 0759004f 00000005 00000005 00000005 00200046
00000002 00000000 c1082a93 f56c7e28 c2472da8 c1082a93 f5e5fee4 c106bc61^M
00000000 c1082a93 00000000 00000000 00000001 00200046 00200082 00000000
Call Trace:
[<c10687a8>] ftrace_raw_event_lock+0x39/0xc0
[<c1082a93>] ? ktime_get+0x29/0x69
[<c106bc61>] lock_release+0x57/0x1a5
[<c10824dd>] read_seqcount_begin.constprop.7+0x4d/0x75
[<c1082a93>] ? ktime_get+0x29/0x69^M
[<c1082a93>] ktime_get+0x29/0x69
[<c108a46a>] __tick_nohz_idle_enter+0x1e/0x426
[<c10690e8>] ? lock_release_holdtime.part.19+0x48/0x4d
[<c10bc184>] ? time_hardirqs_off+0xe/0x28
[<c1068c82>] ? trace_hardirqs_off_caller+0x3f/0xaf
[<c108a8cb>] tick_nohz_idle_enter+0x59/0x62
[<c1079242>] cpu_startup_entry+0x64/0x192
[<c102299c>] start_secondary+0x277/0x27c
Code: 90 89 c6 89 d0 88 c4 ac 38 e0 74 09 84 c0 75 f7 be 01 00 00 00 89 f0 48 5e 5d c3 55 89 e5 57 66 66 66 66 90 83 c9 ff 89 c7 31 c0 <f2> ae f7 d1 8d 41 ff 5f 5d c3 55 89 e5 57 66 66 66 66 90 31 ff
EIP: [<c127a17b>] strlen+0x10/0x1a SS:ESP 0068:f5e5fe80
CR2: 0000000000000000
---[ end trace 01bc47bf519ec1b2 ]---
New tracepoints have been added that have allowed for NULL pointers
being assigned to strings. To fix this, change the TRACE_EVENT() code
to check for NULL and if it is, it will assign "(null)" to it instead
(similar to what glibc printf does).
Reported-by: Shuah Khan <shuah.kh@samsung.com>
Reported-by: Jovi Zhangwei <jovi.zhangwei@gmail.com>
Link: http://lkml.kernel.org/r/CAGdX0WFeEuy+DtpsJzyzn0343qEEjLX97+o1VREFkUEhndC+5Q@mail.gmail.com
Link: http://lkml.kernel.org/r/528D6972.9010702@samsung.com
Fixes: 9cbf117662e2 ("tracing/events: provide string with undefined size support")
commit 8e7ee6f5dfb56a32da760d990be908ed35b1c5bf upstream.
Define PCI_VENDOR_ID_MARVELL_EXT macro for 0x1b4b vendor ID
Signed-off-by: Xiangliang Yu <yuxiangl@marvell.com>
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 4e9b45a19241354daec281d7a785739829b52359 upstream.
On 64 bit systems the test for negative message sizes is bogus as the
size, which may be positive when evaluated as a long, will get truncated
to an int when passed to load_msg(). So a long might very well contain a
positive value but when truncated to an int it would become negative.
That in combination with a small negative value of msg_ctlmax (which will
be promoted to an unsigned type for the comparison against msgsz, making
it a big positive value and therefore make it pass the check) will lead to
two problems: 1/ The kmalloc() call in alloc_msg() will allocate a too
small buffer as the addition of alen is effectively a subtraction. 2/ The
copy_from_user() call in load_msg() will first overflow the buffer with
userland data and then, when the userland access generates an access
violation, the fixup handler copy_user_handle_tail() will try to fill the
remainder with zeros -- roughly 4GB. That almost instantly results in a
system crash or reset.
,-[ Reproducer (needs to be run as root) ]--
| #include <sys/stat.h>
| #include <sys/msg.h>
| #include <unistd.h>
| #include <fcntl.h>
| int main(void) {
| long msg = 1;
| int fd;
| fd = open("/proc/sys/kernel/msgmax", O_WRONLY);
| write(fd, "-1", 2);
| close(fd);
| msgsnd(0, &msg, 0xfffffff0, IPC_NOWAIT);
| return 0;
Fix the issue by preventing msgsz from getting truncated by consistently
using size_t for the message length. This way the size checks in
do_msgsnd() could still be passed with a negative value for msg_ctlmax but
we would fail on the buffer allocation in that case and error out.
Also change the type of m_ts from int to size_t to avoid similar nastiness
in other code paths -- it is used in similar constructs, i.e. signed vs.
unsigned checks. It should never become negative under normal
circumstances, though.
Setting msg_ctlmax to a negative value is an odd configuration and should
be prevented. As that might break existing userland, it will be handled
in a separate commit so it could easily be reverted and reworked without
reintroducing the above described bug.
Hardening mechanisms for user copy operations would have catched that bug
early -- e.g. checking slab object sizes on user copy operations as the
usercopy feature of the PaX patch does. Or, for that matter, detect the
long vs. int sign change due to truncation, as the size overflow plugin
of the very same patch does.
[akpm@linux-foundation.org: fix i386 min() warnings]
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Pax Team <pageexec@freemail.hu>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: Manfred Spraul <manfred@colorfullife.com>
- Adjust context
- Drop changes to alloc_msg() and copy_msg(), which don't exist]
commit d049f74f2dbe71354d43d393ac3a188947811348 upstream.
The get_dumpable() return value is not boolean. Most users of the
function actually want to be testing for non-SUID_DUMP_USER(1) rather than
SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a
protected state. Almost all places did this correctly, excepting the two
places fixed in this patch.
Wrong logic:
if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ }
or
if (dumpable == 0) { /* be protective */ }
or
if (!dumpable) { /* be protective */ }
Correct logic:
if (dumpable != SUID_DUMP_USER) { /* be protective */ }
or
if (dumpable != 1) { /* be protective */ }
Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a
user was able to ptrace attach to processes that had dropped privileges to
that user. (This may have been partially mitigated if Yama was enabled.)
The macros have been moved into the file that declares get/set_dumpable(),
which means things like the ia64 code can see them too.
CVE-2013-2929
Reported-by: Vasily Kulikov <segoon@openwall.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit a4d62babf988fe5dfde24437fa135ef147bc7aa0 upstream.
Hardware:
CPU: XLP832,the 64-bit OS
NOR Flash:S29GL128S 128M
Software:
Kernel:2.6.32.41
Filesystem:JFFS2
When writing files, errors appear:
Write len 182 but return retlen 180
Write of 182 bytes at 0x072c815c failed. returned -5, retlen 180
Write len 186 but return retlen 184
Write of 186 bytes at 0x072caff4 failed. returned -5, retlen 184
These errors exist only in 64-bit systems,not in 32-bit systems. After analysis, we
found that the left shift operation is wrong in map_word_load_partial. For instance:
unsigned char buf[3] ={0x9e,0x3a,0xea};
map_bankwidth(map) is 4;
for (i=0; i < 3; i++) {
int bitpos;
bitpos = (map_bankwidth(map)-1-i)*8;
orig.x[0] &= ~(0xff << bitpos);
orig.x[0] |= buf[i] << bitpos;
The value of orig.x[0] is expected to be 0x9e3aeaff, but in this situation(64-bit
System) we'll get the wrong value of 0xffffffff9e3aeaff due to the 64-bit sign
extension:
buf[i] is defined as "unsigned char" and the left-shift operation will convert it
to the type of "signed int", so when left-shift buf[i] by 24 bits, the final result
will get the wrong value: 0xffffffff9e3aeaff.
If the left-shift bits are less than 24, then sign extension will not occur. Whereas
the bankwidth of the nor flash we used is 4, therefore this BUG emerges.
Signed-off-by: Pang Xunlei <pang.xunlei@zte.com.cn>
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Signed-off-by: Lu Zhongjun <lu.zhongjun@zte.com.cn>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit bc5bd37ce48c66e9192ad2e7231e9678880f6f8e upstream.
Pavel Roskin reported that DRM_IOCTL_MODE_GETCONNECTOR was overwritting
the 4 bytes beyond the end of its structure with a 32-bit userspace
running on a 64-bit kernel. This is due to the padding gcc inserts as
the drm_mode_get_connector struct includes a u64 and its size is not a
natural multiple of u64s.
64-bit kernel:
sizeof(drm_mode_get_connector)=80, alignof=8
sizeof(drm_mode_get_encoder)=20, alignof=4
sizeof(drm_mode_modeinfo)=68, alignof=4
32-bit userspace:
sizeof(drm_mode_get_connector)=76, alignof=4
Fortuituously we can insert explicit padding to the tail of our
structures without breaking ABI.
Reported-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Dave Airlie <airlied@redhat.com>
Cc: dri-devel@lists.freedesktop.org
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream.
Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down
a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto'
constructs, as outlined here:
Implement a workaround suggested by Jakub Jelinek.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Suggested-by: Jakub Jelinek <jakub@redhat.com>
Reviewed-by: Richard Henderson <rth@twiddle.net>
- Drop inapplicable changes
- Adjust context]
commit 3f3f8d2f48acfd8ed3b8e6b7377935da57b27b16 upstream.
Throughout compiler*.h, many version checks are made. These can be
simplified by using the macro that gcc's documentation recommends.
However, my primary reason for adding this is that I need bug-check
macros that are enabled at certain gcc versions and it's cleaner to use
this macro than the tradition method:
#if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ => 2)
If you add patch level, it gets this ugly:
#if __GNUC__ > 4 || (__GNUC__ == 4 && (__GNUC_MINOR__ > 2 || \
__GNUC_MINOR__ == 2 __GNUC_PATCHLEVEL__ >= 1))
As opposed to:
#if GCC_VERSION >= 40201
While having separate headers for gcc 3 & 4 eliminates some of this
verbosity, they can still be cleaned up by this.
See also:
http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Acked-by: Borislav Petkov <bp@alien8.de>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Joe Perches <joe@perches.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit 61875f30daf60305712e25b209ef41ced2635bad upstream.
Allow architectures which have a disabled get_cycles() function to
provide a random_get_entropy() function which provides a fine-grained,
rapidly changing counter that can be used by the /dev/random driver.
For example, an architecture might have a rapidly changing register
used to control random TLB cache eviction, or DRAM refresh that
doesn't meet the requirements of get_cycles(), but which is good
enough for the needs of the random driver.
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream.
The some platforms (e.g., ARM) initializes their clocks as
late_initcalls for some unknown reason. So make sure
random_int_secret_init() is run after all of the late_initcalls are
run.
commit 74e3d1e17b2e11d175970b85acd44f5927000ba2 upstream.
Two rt tasks bind to one CPU core.
The higher priority rt task A preempts a lower priority rt task B which
has already taken the write seq lock, and then the higher priority rt
task A try to acquire read seq lock, it's doomed to lockup.
rt task A with lower priority: call write
i_size_write rt task B with higher priority: call sync, and preempt task A
write_seqcount_begin(&inode->i_size_seqcount); i_size_read
inode->i_size = i_size; read_seqcount_begin <-- lockup here...
So disable preempt when acquiring every i_size_seqcount *write* lock will
cure the problem.
[ This is a simplified -stable version of a set of upstream commits. ]
This is a replacement patch only for stable which does fix the problems
handled by the following two commits in -net:
"ip_output: do skb ufo init for peeked non ufo skb as well" (e93b7d748be887cd7639b113ba7d7ef792a7efb9)
"ip6_output: do skb ufo init for peeked non ufo skb as well" (c547dbf55d5f8cf615ccc0e7265e98db27d3fb8b)
Three frames are written on a corked udp socket for which the output
netdevice has UFO enabled. If the first and third frame are smaller than
the mtu and the second one is bigger, we enqueue the second frame with
skb_append_datato_frags without initializing the gso fields. This leads
to the third frame appended regulary and thus constructing an invalid skb.
This fixes the problem by always using skb_append_datato_frags as soon
as the first frag got enqueued to the skb without marking the packet
as SKB_GSO_UDP.
The problem with only two frames for ipv6 was fixed by "ipv6: udp
packets following an UFO enqueued packet need also be handled by UFO"
(2811ebac2521ceac84f2bdae402455baa6a7fb47).
Cc: Jiri Pirko <jiri@resnulli.us>
commit bf378d341e4873ed928dc3c636252e6895a21f50 upstream.
The PPC64 people noticed a missing memory barrier and crufty old
comments in the perf ring buffer code. So update all the comments and
add the missing barrier.
When the architecture implements local_t using atomic_long_t there
will be double barriers issued; but short of introducing more
conditional barrier primitives this is the best we can do.
Reported-by: Victor Kaplansky <victork@il.ibm.com>
Tested-by: Victor Kaplansky <victork@il.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: michael@ellerman.id.au
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: anton@samba.org
Cc: benh@kernel.crashing.org
Link: http://lkml.kernel.org/r/20131025173749.GG19466@laptop.lan
commit d7dab39b6e16d5eea78ed3c705d2a2d0772b4f06 upstream.
This is based on commit d1f5273e9adb40724a85272f248f210dc4ce919a
ext4: return 32/64-bit dir name hash according to usage type
by Fan Yong <yong.fan@whamcloud.com>
Traditionally ext2/3/4 has returned a 32-bit hash value from llseek()
to appease NFSv2, which can only handle a 32-bit cookie for seekdir()
and telldir(). However, this causes problems if there are 32-bit hash
collisions, since the NFSv2 server can get stuck resending the same
entries from the directory repeatedly.
Allow ext3 to return a full 64-bit hash (both major and minor) for
telldir to decrease the chance of hash collisions.
This patch does implement a new ext3_dir_llseek op, because with 64-bit
hashes, nfs will attempt to seek to a hash "offset" which is much
larger than ext3's s_maxbytes. So for dx dirs, we call
generic_file_llseek_size() with the appropriate max hash value as the
maximum seekable size. Otherwise we just pass through to
generic_file_llseek().
Patch-updated-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
Patch-updated-by: Eric Sandeen <sandeen@redhat.com>
(blame us if something is not correct)
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit 6a8a13e03861c0ab83ab07d573ca793cff0e5d00 upstream.
Those flags are supposed to be set by NFS readdir() to tell ext3/ext4
to 32bit (NFSv2) or 64bit hash values (offsets) in seekdir().
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
[ Upstream commit f2e5ddcc0d12f9c4c7b254358ad245c9dddce13b ]
When CONFIG_NETLABEL is disabled, the cipso_v4_validate() function could loop
forever in the main loop if opt[opt_iter +1] == 0, this will causing a kernel
crash in an SMP system, since the CPU executing this function will
stall /not respond to IPIs.
This problem can be reproduced by running the IP Stack Integrity Checker
(http://isic.sourceforge.net) using the following command on a Linux machine
connected to DUT:
"icmpsic -s rand -d <DUT IP address> -r 123456"
wait (1-2 min)
Signed-off-by: Seif Mazareeb <seif@marvell.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit e87b3998d795123b4139bc3f25490dd236f68212 ]
dst->xfrm is conditionally defined. Provide accessor funtion that
is always available.
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit c52e2421f7368fd36cbe330d2cf41b10452e39a9 ]
TCP stack should make sure it owns skbs before mangling them.
We had various crashes using bnx2x, and it turned out gso_size
was cleared right before bnx2x driver was populating TC descriptor
of the _previous_ packet send. TCP stack can sometime retransmit
packets that are still in Qdisc.
Of course we could make bnx2x driver more robust (using
ACCESS_ONCE(shinfo->gso_size) for example), but the bug is TCP stack.
We have identified two points where skb_unclone() was needed.
This patch adds a WARN_ON_ONCE() to warn us if we missed another
fix of this kind.
Kudos to Neal for finding the root cause of this bug. Its visible
using small MSS.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
commit 4b59e6c4730978679b414a8da61514a2518da512 upstream.
On large systems with a lot of memory, walking all RAM to determine page
types may take a half second or even more.
In non-blockable contexts, the page allocator will emit a page allocation
failure warning unless __GFP_NOWARN is specified. In such contexts, irqs
are typically disabled and such a lengthy delay may even result in NMI
watchdog timeouts.
To fix this, suppress the page walk in such contexts when printing the
page allocation failure warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
