commit 0a94efb5acbb6980d7c9ab604372d93cd507e4d8 upstream.
5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be
ordered") automatically enabled ordered attribute for unbound
workqueues w/ max_active == 1. Because ordered workqueues reject
max_active and some attribute changes, this implicit ordered mode
broke cases where the user creates an unbound workqueue w/ max_active
== 1 and later explicitly changes the related attributes.
This patch distinguishes explicit and implicit ordered setting and
overrides from attribute changes if implict.
Fixes: 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered")
Cc: Holger Hoffstätte <holger@applied-asynchrony.com>
[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ]
Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we
can now trace init processes. init is initially protected with
SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but
there are a number of paths during tracing where SIGNAL_UNKILLABLE can
be implicitly cleared.
This can result in init becoming stoppable/killable after tracing. For
example, running:
while true; do kill -STOP 1; done &
strace -p 1
and then stopping strace and the kill loop will result in init being
left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but
init will now respond to future SIGSTOP signals rather than ignoring
them.
Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED
that we don't clear SIGNAL_UNKILLABLE.
Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit bb1107f7c6052c863692a41f78c000db792334bf ]
Andrey Konovalov has reported the following warning triggered by the
syzkaller fuzzer.
WARNING: CPU: 1 PID: 9935 at mm/page_alloc.c:3511 __alloc_pages_nodemask+0x159c/0x1e20
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 9935 Comm: syz-executor0 Not tainted 4.9.0-rc7+ #34
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__alloc_pages_slowpath mm/page_alloc.c:3511
__alloc_pages_nodemask+0x159c/0x1e20 mm/page_alloc.c:3781
alloc_pages_current+0x1c7/0x6b0 mm/mempolicy.c:2072
alloc_pages include/linux/gfp.h:469
kmalloc_order+0x1f/0x70 mm/slab_common.c:1015
kmalloc_order_trace+0x1f/0x160 mm/slab_common.c:1026
kmalloc_large include/linux/slab.h:422
__kmalloc+0x210/0x2d0 mm/slub.c:3723
kmalloc include/linux/slab.h:495
ep_write_iter+0x167/0xb50 drivers/usb/gadget/legacy/inode.c:664
new_sync_write fs/read_write.c:499
__vfs_write+0x483/0x760 fs/read_write.c:512
vfs_write+0x170/0x4e0 fs/read_write.c:560
SYSC_write fs/read_write.c:607
SyS_write+0xfb/0x230 fs/read_write.c:599
entry_SYSCALL_64_fastpath+0x1f/0xc2
The issue is caused by a lack of size check for the request size in
ep_write_iter which should be fixed. It, however, points to another
problem, that SLUB defines KMALLOC_MAX_SIZE too large because the its
KMALLOC_SHIFT_MAX is (MAX_ORDER + PAGE_SHIFT) which means that the
resulting page allocator request might be MAX_ORDER which is too large
(see __alloc_pages_slowpath).
The same applies to the SLOB allocator which allows even larger sizes.
Make sure that they are capped properly and never request more than
MAX_ORDER order.
Link: http://lkml.kernel.org/r/20161220130659.16461-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Alexei Starovoitov <ast@kernel.org>
commit 93be2b74279c15c2844684b1a027fdc71dd5d9bf upstream.
gcc-7 complains that wl3501_cs passes NULL into a function that
then uses the argument as the input for memcpy:
drivers/net/wireless/wl3501_cs.c: In function 'wl3501_get_scan':
include/net/iw_handler.h:559:3: error: argument 2 null where non-null expected [-Werror=nonnull]
memcpy(stream + point_len, extra, iwe->u.data.length);
This works fine here because iwe->u.data.length is guaranteed to be 0
and the memcpy doesn't actually have an effect.
Making the length check explicit avoids the warning and should have
no other effect here.
Also check the pointer itself, since otherwise we get warnings
elsewhere in the code.
[ Upstream commit 6b84202c946cd3da3a8daa92c682510e9ed80321 ]
Commit b1f5bfc27a19 ("sctp: don't dereference ptr before leaving
_sctp_walk_{params, errors}()") tried to fix the issue that it
may overstep the chunk end for _sctp_walk_{params, errors} with
'chunk_end > offset(length) + sizeof(length)'.
But it introduced a side effect: When processing INIT, it verifies
the chunks with 'param.v == chunk_end' after iterating all params
by sctp_walk_params(). With the check 'chunk_end > offset(length)
+ sizeof(length)', it would return when the last param is not yet
accessed. Because the last param usually is fwdtsn supported param
whose size is 4 and 'chunk_end == offset(length) + sizeof(length)'
This is a badly issue even causing sctp couldn't process 4-shakes.
Client would always get abort when connecting to server, due to
the failure of INIT chunk verification on server.
The patch is to use 'chunk_end <= offset(length) + sizeof(length)'
instead of 'chunk_end < offset(length) + sizeof(length)' for both
_sctp_walk_params and _sctp_walk_errors.
Fixes: b1f5bfc27a19 ("sctp: don't dereference ptr before leaving _sctp_walk_{params, errors}()")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit b1f5bfc27a19f214006b9b4db7b9126df2dfdf5a ]
If the length field of the iterator (|pos.p| or |err|) is past the end
of the chunk, we shouldn't access it.
This bug has been detected by KMSAN. For the following pair of system
calls:
socket(PF_INET6, SOCK_STREAM, 0x84 /* IPPROTO_??? */) = 3
sendto(3, "A", 1, MSG_OOB, {sa_family=AF_INET6, sin6_port=htons(0),
inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0,
sin6_scope_id=0}, 28) = 1
the tool has reported a use of uninitialized memory:
BUG: KMSAN: use of uninitialized memory in sctp_rcv+0x17b8/0x43b0
CPU: 1 PID: 2940 Comm: probe Not tainted 4.11.0-rc5+ #2926
01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x172/0x1c0 lib/dump_stack.c:52
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:927
__msan_warning_32+0x61/0xb0 mm/kmsan/kmsan_instr.c:469
__sctp_rcv_init_lookup net/sctp/input.c:1074
__sctp_rcv_lookup_harder net/sctp/input.c:1233
__sctp_rcv_lookup net/sctp/input.c:1255
sctp_rcv+0x17b8/0x43b0 net/sctp/input.c:170
sctp6_rcv+0x32/0x70 net/sctp/ipv6.c:984
ip6_input_finish+0x82f/0x1ee0 net/ipv6/ip6_input.c:279
NF_HOOK ./include/linux/netfilter.h:257
ip6_input+0x239/0x290 net/ipv6/ip6_input.c:322
dst_input ./include/net/dst.h:492
ip6_rcv_finish net/ipv6/ip6_input.c:69
ipv6_rcv+0x1dbd/0x22e0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x2f6f/0x3a20 net/core/dev.c:4208
__netif_receive_skb net/core/dev.c:4246
process_backlog+0x667/0xba0 net/core/dev.c:4866
napi_poll net/core/dev.c:5268
net_rx_action+0xc95/0x1590 net/core/dev.c:5333
__do_softirq+0x485/0x942 kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902
</IRQ>
do_softirq kernel/softirq.c:328
__local_bh_enable_ip+0x25b/0x290 kernel/softirq.c:181
local_bh_enable+0x37/0x40 ./include/linux/bottom_half.h:31
rcu_read_unlock_bh ./include/linux/rcupdate.h:931
ip6_finish_output2+0x19b2/0x1cf0 net/ipv6/ip6_output.c:124
ip6_finish_output+0x764/0x970 net/ipv6/ip6_output.c:149
NF_HOOK_COND ./include/linux/netfilter.h:246
ip6_output+0x456/0x520 net/ipv6/ip6_output.c:163
dst_output ./include/net/dst.h:486
ip6_xmit+0x1841/0x1c00 net/ipv6/ip6_output.c:261
sctp_v6_xmit+0x3b7/0x470 net/sctp/ipv6.c:225
sctp_packet_transmit+0x38cb/0x3a20 net/sctp/output.c:632
sctp_outq_flush+0xeb3/0x46e0 net/sctp/outqueue.c:885
sctp_outq_uncork+0xb2/0xd0 net/sctp/outqueue.c:750
sctp_side_effects net/sctp/sm_sideeffect.c:1773
sctp_do_sm+0x6962/0x6ec0 net/sctp/sm_sideeffect.c:1147
sctp_primitive_ASSOCIATE+0x12c/0x160 net/sctp/primitive.c:88
sctp_sendmsg+0x43e5/0x4f90 net/sctp/socket.c:1954
inet_sendmsg+0x498/0x670 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633
sock_sendmsg net/socket.c:643
SYSC_sendto+0x608/0x710 net/socket.c:1696
SyS_sendto+0x8a/0xb0 net/socket.c:1664
do_syscall_64+0xe6/0x130 arch/x86/entry/common.c:285
entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.S:246
RIP: 0033:0x401133
RSP: 002b:00007fff6d99cd38 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000004002b0 RCX: 0000000000401133
RDX: 0000000000000001 RSI: 0000000000494088 RDI: 0000000000000003
RBP: 00007fff6d99cd90 R08: 00007fff6d99cd50 R09: 000000000000001c
R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000000
R13: 00000000004063d0 R14: 0000000000406460 R15: 0000000000000000
origin:
save_stack_trace+0x37/0x40 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:302
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:198
kmsan_poison_shadow+0x6d/0xc0 mm/kmsan/kmsan.c:211
slab_alloc_node mm/slub.c:2743
__kmalloc_node_track_caller+0x200/0x360 mm/slub.c:4351
__kmalloc_reserve net/core/skbuff.c:138
__alloc_skb+0x26b/0x840 net/core/skbuff.c:231
alloc_skb ./include/linux/skbuff.h:933
sctp_packet_transmit+0x31e/0x3a20 net/sctp/output.c:570
return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.S:246
Signed-off-by: Alexander Potapenko <glider@google.com>
leaving stale TLB entries
commit 3ea277194daaeaa84ce75180ec7c7a2075027a68 upstream.
Stable note for 4.4: The upstream patch patches madvise(MADV_FREE) but 4.4
does not have support for that feature. The changelog is left
as-is but the hunk related to madvise is omitted from the backport.
Nadav Amit identified a theoritical race between page reclaim and
mprotect due to TLB flushes being batched outside of the PTL being held.
He described the race as follows:
CPU0 CPU1
user accesses memory using RW PTE
[PTE now cached in TLB]
try_to_unmap_one()
==> ptep_get_and_clear()
==> set_tlb_ubc_flush_pending()
mprotect(addr, PROT_READ)
==> change_pte_range()
==> [ PTE non-present - no flush ]
user writes using cached RW PTE
try_to_unmap_flush()
The same type of race exists for reads when protecting for PROT_NONE and
also exists for operations that can leave an old TLB entry behind such
as munmap, mremap and madvise.
For some operations like mprotect, it's not necessarily a data integrity
issue but it is a correctness issue as there is a window where an
mprotect that limits access still allows access. For munmap, it's
potentially a data integrity issue although the race is massive as an
munmap, mmap and return to userspace must all complete between the
window when reclaim drops the PTL and flushes the TLB. However, it's
theoritically possible so handle this issue by flushing the mm if
reclaim is potentially currently batching TLB flushes.
Other instances where a flush is required for a present pte should be ok
as either the page lock is held preventing parallel reclaim or a page
reference count is elevated preventing a parallel free leading to
corruption. In the case of page_mkclean there isn't an obvious path
that userspace could take advantage of without using the operations that
are guarded by this patch. Other users such as gup as a race with
reclaim looks just at PTEs. huge page variants should be ok as they
don't race with reclaim. mincore only looks at PTEs. userfault also
should be ok as if a parallel reclaim takes place, it will either fault
the page back in or read some of the data before the flush occurs
triggering a fault.
Note that a variant of this patch was acked by Andy Lutomirski but this
was for the x86 parts on top of his PCID work which didn't make the 4.13
merge window as expected. His ack is dropped from this version and
there will be a follow-on patch on top of PCID that will include his
ack.
[akpm@linux-foundation.org: tweak comments]
[akpm@linux-foundation.org: fix spello]
Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de
Reported-by: Nadav Amit <nadav.amit@gmail.com>
commit 25cdda95fda78d22d44157da15aa7ea34be3c804 upstream.
This patch fixes a OOPs originally introduced by:
commit bb048357dad6d604520c91586334c9c230366a14
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Thu Sep 5 14:54:04 2013 -0700
iscsi-target: Add sk->sk_state_change to cleanup after TCP failure
which would trigger a NULL pointer dereference when a TCP connection
was closed asynchronously via iscsi_target_sk_state_change(), but only
when the initial PDU processing in iscsi_target_do_login() from iscsi_np
process context was blocked waiting for backend I/O to complete.
To address this issue, this patch makes the following changes.
First, it introduces some common helper functions used for checking
socket closing state, checking login_flags, and atomically checking
socket closing state + setting login_flags.
Second, it introduces a LOGIN_FLAGS_INITIAL_PDU bit to know when a TCP
connection has dropped via iscsi_target_sk_state_change(), but the
initial PDU processing within iscsi_target_do_login() in iscsi_np
context is still running. For this case, it sets LOGIN_FLAGS_CLOSED,
but doesn't invoke schedule_delayed_work().
The original NULL pointer dereference case reported by MNC is now handled
by iscsi_target_do_login() doing a iscsi_target_sk_check_close() before
transitioning to FFP to determine when the socket has already closed,
or iscsi_target_start_negotiation() if the login needs to exchange
more PDUs (eg: iscsi_target_do_login returned 0) but the socket has
closed. For both of these cases, the cleanup up of remaining connection
resources will occur in iscsi_target_start_negotiation() from iscsi_np
process context once the failure is detected.
Finally, to handle to case where iscsi_target_sk_state_change() is
called after the initial PDU procesing is complete, it now invokes
conn->login_work -> iscsi_target_do_login_rx() to perform cleanup once
existing iscsi_target_sk_check_close() checks detect connection failure.
For this case, the cleanup of remaining connection resources will occur
in iscsi_target_do_login_rx() from delayed workqueue process context
Reported-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Mike Christie <mchristi@redhat.com>
Tested-by: Mike Christie <mchristi@redhat.com>
Cc: Mike Christie <mchristi@redhat.com>
Reported-by: Hannes Reinecke <hare@suse.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Varun Prakash <varun@chelsio.com>
commit 49cb77e297dc611a1b795cfeb79452b3002bd331 upstream.
This patch closes a race between se_lun deletion during configfs
unlink in target_fabric_port_unlink() -> core_dev_del_lun()
-> core_tpg_remove_lun(), when transport_clear_lun_ref() blocks
waiting for percpu_ref RCU grace period to finish, but a new
NodeACL mappedlun is added before the RCU grace period has
completed.
This can happen in target_fabric_mappedlun_link() because it
only checks for se_lun->lun_se_dev, which is not cleared until
after transport_clear_lun_ref() percpu_ref RCU grace period
finishes.
This bug originally manifested as NULL pointer dereference
OOPsen in target_stat_scsi_att_intr_port_show_attr_dev() on
v4.1.y code, because it dereferences lun->lun_se_dev without
a explicit NULL pointer check.
In post v4.1 code with target-core RCU conversion, the code
in target_stat_scsi_att_intr_port_show_attr_dev() no longer
uses se_lun->lun_se_dev, but the same race still exists.
To address the bug, go ahead and set se_lun>lun_shutdown as
early as possible in core_tpg_remove_lun(), and ensure new
NodeACL mappedlun creation in target_fabric_mappedlun_link()
fails during se_lun shutdown.
Reported-by: James Shen <jcs@datera.io>
Cc: James Shen <jcs@datera.io>
Tested-by: James Shen <jcs@datera.io>
commit 663deb47880f2283809669563c5a52ac7c6aef1a upstream.
In preparation of not locking at all for certain buffers depending on if
there's contention, make locking optional depending on the initialization
of the prz.
Signed-off-by: Joel Fernandes <joelaf@google.com>
[kees: moved locking flag into prz instead of via caller arguments]
commit 34dbbcdbf63360661ff7bda6c5f52f99ac515f92 upstream.
A lot of seqfile users seem to be using things like %pK that uses the
credentials of the current process, but that is actually completely
wrong for filesystem interfaces.
The unix semantics for permission checking files is to check permissions
at _open_ time, not at read or write time, and that is not just a small
detail: passing off stdin/stdout/stderr to a suid application and making
the actual IO happen in privileged context is a classic exploit
technique.
So if we want to be able to look at permissions at read time, we need to
use the file open credentials, not the current ones. Normal file
accesses can just use "f_cred" (or any of the helper functions that do
that, like file_ns_capable()), but the seqfile interfaces do not have
any such options.
It turns out that seq_file _does_ save away the user_ns information of
the file, though. Since user_ns is just part of the full credential
information, replace that special case with saving off the cred pointer
instead, and suddenly seq_file has all the permission information it
needs.
[sumits: this is used in Ubuntu as a fix for CVE-2015-8944]
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit 49d31c2f389acfe83417083e1208422b4091cd9e upstream.
take_dentry_name_snapshot() takes a safe snapshot of dentry name;
if the name is a short one, it gets copied into caller-supplied
structure, otherwise an extra reference to external name is grabbed
(those are never modified). In either case the pointer to stable
string is stored into the same structure.
dentry must be held by the caller of take_dentry_name_snapshot(),
but may be freely dropped afterwards - the snapshot will stay
until destroyed by release_dentry_name_snapshot().
Intended use:
struct name_snapshot s;
take_dentry_name_snapshot(&s, dentry);
access s.name
release_dentry_name_snapshot(&s);
Replaces fsnotify_oldname_...(), gets used in fsnotify to obtain the name
to pass down with event.
commit 0878fff1f42c18e448ab5b8b4f6a3eb32365b5b6 upstream.
The Generic PHY driver is a catch-all PHY driver and it should preserve
whatever prior initialization has been done by boot loader or firmware
agents. For specific PHY device configuration it is expected that a
specialized PHY driver would take over that role.
Resetting the generic PHY was a bad idea that has lead to several
complaints and downstream workarounds e.g: in OpenWrt/LEDE so restore
the behavior prior to 87aa9f9c61ad ("net: phy: consolidate PHY
reset in phy_init_hw()").
Reported-by: Felix Fietkau <nbd@nbd.name>
Fixes: 87aa9f9c61ad ("net: phy: consolidate PHY reset in phy_init_hw()")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 109704492ef637956265ec2eb72ae7b3b39eb6f4 upstream.
Currently pstore has a global spinlock for all zones. Since the zones
are independent and modify different areas of memory, there's no need
to have a global lock, so we should use a per-zone lock as introduced
here. Also, when ramoops's ftrace use-case has a FTRACE_PER_CPU flag
introduced later, which splits the ftrace memory area into a single zone
per CPU, it will eliminate the need for locking. In preparation for this,
make the locking optional.
[kees: updated commit message]
Cc: Leo Yan <leo.yan@linaro.org>
commit 5d6dee80a1e94cc284d03e06d930e60e8d3ecf7d upstream.
At the point where the kvm-vfio pseudo device wants to release its
vfio group reference, we can't always acquire a new reference to make
that happen. The group can be in a state where we wouldn't allow a
new reference to be added. This new helper function allows a caller
to match a file to a group to facilitate this. Given a file and
group, report if they match. Thus the caller needs to already have a
group reference to match to the file. This allows the deletion of a
group without acquiring a new reference.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Tested-by: Eric Auger <eric.auger@redhat.com>
commit 138d351eefb727ab9e41a3dc5f112ceb4f6e59f2 upstream.
This patch re-introduces part of a long standing login workaround that
was recently dropped by:
commit 1c99de981f30b3e7868b8d20ce5479fa1c0fea46
Date: Sun Apr 2 13:36:44 2017 -0700
iscsi-target: Drop work-around for legacy GlobalSAN initiator
Namely, the workaround for FirstBurstLength ended up being required by
Mellanox Flexboot PXE boot ROMs as reported by Robert.
So this patch re-adds the work-around for FirstBurstLength within
iscsi_check_proposer_for_optional_reply(), and makes the key optional
to respond when the initiator does not propose, nor respond to it.
Also as requested by Arun, this patch introduces a new TPG attribute
named 'login_keys_workaround' that controls the use of both the
FirstBurstLength workaround, as well as the two other existing
workarounds for gPXE iSCSI boot client.
By default, the workaround is enabled with login_keys_workaround=1,
since Mellanox FlexBoot requires it, and Arun has verified the Qlogic
MSFT initiator already proposes FirstBurstLength, so it's uneffected
by this re-adding this part of the original work-around.
Reported-by: Robert LeBlanc <robert@leblancnet.us>
Cc: Robert LeBlanc <robert@leblancnet.us>
Reviewed-by: Arun Easi <arun.easi@cavium.com>
commit f77af15165847406b15d8f70c382c4cb15846b2a upstream.
The TPM class has some common shutdown code that must be executed for
all drivers. This adds some needed functionality for that.
Signed-off-by: Josh Zimmerman <joshz@google.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Fixes: 74d6b3ceaa17 ("tpm: fix suspend/resume paths for TPM 2.0")
Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Tested-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 2c80cd57c74339889a8752b20862a16c28929c3a upstream.
list_lru_count_node() iterates over all memcgs to get the total number of
entries on the node but it can race with memcg_drain_all_list_lrus(),
which migrates the entries from a dead cgroup to another. This can return
incorrect number of entries from list_lru_count_node().
Fix this by keeping track of entries per node and simply return it in
Link: http://lkml.kernel.org/r/1498707555-30525-1-git-send-email-stummala@codeaurora.org
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Alexander Polakov <apolyakov@beget.ru>
commit f06b7549b79e29a672336d4e134524373fb7a232 upstream.
Lennert reported a failure to add different mpls encaps in a multipath
route:
$ ip -6 route add 1234::/16 \
nexthop encap mpls 10 via fe80::1 dev ens3 \
nexthop encap mpls 20 via fe80::1 dev ens3
RTNETLINK answers: File exists
The problem is that the duplicate nexthop detection does not compare
lwtunnel configuration. Add it.
Fixes: 19e42e451506 ("ipv6: support for fib route lwtunnel encap attributes")
Signed-off-by: David Ahern <dsahern@gmail.com>
Reported-by: João Taveira Araújo <joao.taveira@gmail.com>
Reported-by: Lennert Buytenhek <buytenh@wantstofly.org>
Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Tested-by: Lennert Buytenhek <buytenh@wantstofly.org>
commit 7cf916bd639bd26db7214f2205bccdb4b9306256 upstream.
The current definition is wrong. This breaks my upcoming
Aspeed virtual hub driver.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 80f18379a7c350c011d30332658aa15fe49a8fa5 upstream.
Add a central define for all valid open flags, and use it in the uniqueness
check.
commit 9b3eb54106cf6acd03f07cf0ab01c13676a226c2 upstream.
When CONFIG_XFRM_SUB_POLICY=y, xfrm_dst stores a copy of the flowi for
that dst. Unfortunately, the code that allocates and fills this copy
doesn't care about what type of flowi (flowi, flowi4, flowi6) gets
passed. In multiple code paths (from raw_sendmsg, from TCP when
replying to a FIN, in vxlan, geneve, and gre), the flowi that gets
passed to xfrm is actually an on-stack flowi4, so we end up reading
stuff from the stack past the end of the flowi4 struct.
Since xfrm_dst->origin isn't used anywhere following commit
ca116922afa8 ("xfrm: Eliminate "fl" and "pol" args to
xfrm_bundle_ok()."), just get rid of it. xfrm_dst->partner isn't used
either, so get rid of that too.
Fixes: 9d6ec938019c ("ipv4: Use flowi4 in public route lookup interfaces.")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 4d22c75d4c7b5c5f4bd31054f09103ee490878fd ]
If the last section of a core file ends with an unmapped or zero page,
the size of the file does not correspond with the last dump_skip() call.
gdb complains that the file is truncated and can be confusing to users.
After all of the vma sections are written, make sure that the file size
is no smaller than the current file position.
This problem can be demonstrated with gdb's bigcore testcase on the
sparc architecture.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: linux-fsdevel@vger.kernel.org
commit ceea5e3771ed2378668455fa21861bead7504df5 upstream.
In tests, which excercise switching of clocksources, a NULL
pointer dereference can be observed on AMR64 platforms in the
clocksource read() function:
u64 clocksource_mmio_readl_down(struct clocksource *c)
return ~(u64)readl_relaxed(to_mmio_clksrc(c)->reg) & c->mask;
This is called from the core timekeeping code via:
cycle_now = tkr->read(tkr->clock);
tkr->read is the cached tkr->clock->read() function pointer.
When the clocksource is changed then tkr->clock and tkr->read
are updated sequentially. The code above results in a sequential
load operation of tkr->read and tkr->clock as well.
If the store to tkr->clock hits between the loads of tkr->read
and tkr->clock, then the old read() function is called with the
new clock pointer. As a consequence the read() function
dereferences a different data structure and the resulting 'reg'
pointer can point anywhere including NULL.
This problem was introduced when the timekeeping code was
switched over to use struct tk_read_base. Before that, it was
theoretically possible as well when the compiler decided to
reload clock in the code sequence:
now = tk->clock->read(tk->clock);
Add a helper function which avoids the issue by reading
tk_read_base->clock once into a local variable clk and then issue
the read function via clk->read(clk). This guarantees that the
read() function always gets the proper clocksource pointer handed
in.
Since there is now no use for the tkr.read pointer, this patch
also removes it, and to address stopping the fast timekeeper
during suspend/resume, it introduces a dummy clocksource to use
rather then just a dummy read function.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Stephen Boyd <stephen.boyd@linaro.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Daniel Mentz <danielmentz@google.com>
Link: http://lkml.kernel.org/r/1496965462-20003-2-git-send-email-john.stultz@linaro.org
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
[gkh: minor build fixes for 4.4]
commit 93491ced3c87c94b12220dbac0527e1356702179 upstream.
Add define for the maximum number of ports on a SuperSpeed hub as per
USB 3.1 spec Table 10-5, and use it when verifying the retrieved hub
descriptor.
This specifically avoids benign attempts to update the DeviceRemovable
mask for non-existing ports (should we get that far).
Fixes: dbe79bbe9dcb ("USB 3.0 Hub Changes")
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit 90427ef5d2a4b9a24079889bf16afdcdaebc4240 ]
ip6_make_flowlabel() determines the flow label for IPv6 packets. It's
supposed to be passed a flow label, which it returns as is if non-0 and
in some other cases, otherwise it calculates a new value.
The problem is callers often pass a flowi6.flowlabel, which may also
contain traffic class bits. If the traffic class is non-0
ip6_make_flowlabel() mistakes the non-0 it gets as a flow label and
returns the whole thing. Thus it can return a 'flow label' longer than
20b and the low 20b of that is typically 0 resulting in packets with 0
label. Moreover, different packets of a flow may be labeled differently.
For a TCP flow with ECN non-payload and payload packets get different
labels as exemplified by this pair of consecutive packets:
(pure ACK)
Internet Protocol Version 6, Src: 2002:af5:11a3::, Dst: 2002:af5:11a2::
0110 .... = Version: 6
.... 0000 0000 .... .... .... .... .... = Traffic Class: 0x00 (DSCP: CS0, ECN: Not-ECT)
.... 0000 00.. .... .... .... .... .... = Differentiated Services Codepoint: Default (0)
.... .... ..00 .... .... .... .... .... = Explicit Congestion Notification: Not ECN-Capable Transport (0)
.... .... .... 0001 1100 1110 0100 1001 = Flow Label: 0x1ce49
Payload Length: 32
Next Header: TCP (6)
(payload)
.... 0000 0010 .... .... .... .... .... = Traffic Class: 0x02 (DSCP: CS0, ECN: ECT(0))
.... .... ..10 .... .... .... .... .... = Explicit Congestion Notification: ECN-Capable Transport codepoint '10' (2)
.... .... .... 0000 0000 0000 0000 0000 = Flow Label: 0x00000
Payload Length: 688
This patch allows ip6_make_flowlabel() to be passed more than just a
flow label and has it extract the part it really wants. This was simpler
than modifying the callers. With this patch packets like the above become
.... .... .... 1010 1111 1010 0101 1110 = Flow Label: 0xafa5e
Payload Length: 32
Payload Length: 688
Signed-off-by: Dimitris Michailidis <dmichail@google.com>
[ Upstream commit e26bfebdfc0d212d366de9990a096665d5c0209a ]
Under some circumstances, an fscache object can become queued such that it
fscache_object_work_func() can be called once the object is in the
OBJECT_DEAD state. This results in the kernel oopsing when it tries to
invoke the handler for the state (which is hard coded to 0x2).
The way this comes about is something like the following:
(1) The object dispatcher is processing a work state for an object. This
is done in workqueue context.
(2) An out-of-band event comes in that isn't masked, causing the object to
be queued, say EV_KILL.
(3) The object dispatcher finishes processing the current work state on
that object and then sees there's another event to process, so,
without returning to the workqueue core, it processes that event too.
It then follows the chain of events that initiates until we reach
OBJECT_DEAD without going through a wait state (such as
WAIT_FOR_CLEARANCE).
At this point, object->events may be 0, object->event_mask will be 0
and oob_event_mask will be 0.
(4) The object dispatcher returns to the workqueue processor, and in due
course, this sees that the object's work item is still queued and
invokes it again.
(5) The current state is a work state (OBJECT_DEAD), so the dispatcher
jumps to it - resulting in an OOPS.
When I'm seeing this, the work state in (1) appears to have been either
LOOK_UP_OBJECT or CREATE_OBJECT (object->oob_table is
fscache_osm_lookup_oob).
The window for (2) is very small:
(A) object->event_mask is cleared whilst the event dispatch process is
underway - though there's no memory barrier to force this to the top
of the function.
The window, therefore is from the time the object was selected by the
workqueue processor and made requeueable to the time the mask was
cleared.
(B) fscache_raise_event() will only queue the object if it manages to set
the event bit and the corresponding event_mask bit was set.
The enqueuement is then deferred slightly whilst we get a ref on the
object and get the per-CPU variable for workqueue congestion. This
slight deferral slightly increases the probability by allowing extra
time for the workqueue to make the item requeueable.
Handle this by giving the dead state a processor function and checking the
for the dead state address rather than seeing if the processor function is
address 0x2. The dead state processor function can then set a flag to
indicate that it's occurred and give a warning if it occurs more than once
per object.
If this race occurs, an oops similar to the following is seen (note the RIP
value):
BUG: unable to handle kernel NULL pointer dereference at 0000000000000002
IP: [<0000000000000002>] 0x1
PGD 0
Oops: 0010 [#1] SMP
Modules linked in: ...
CPU: 17 PID: 16077 Comm: kworker/u48:9 Not tainted 3.10.0-327.18.2.el7.x86_64 #1
Hardware name: HP ProLiant DL380 Gen9/ProLiant DL380 Gen9, BIOS P89 12/27/2015
Workqueue: fscache_object fscache_object_work_func [fscache]
task: ffff880302b63980 ti: ffff880717544000 task.ti: ffff880717544000
RIP: 0010:[<0000000000000002>] [<0000000000000002>] 0x1
RSP: 0018:ffff880717547df8 EFLAGS: 00010202
RAX: ffffffffa0368640 RBX: ffff880edf7a4480 RCX: dead000000200200
RDX: 0000000000000002 RSI: 00000000ffffffff RDI: ffff880edf7a4480
RBP: ffff880717547e18 R08: 0000000000000000 R09: dfc40a25cb3a4510
R10: dfc40a25cb3a4510 R11: 0000000000000400 R12: 0000000000000000
R13: ffff880edf7a4510 R14: ffff8817f6153400 R15: 0000000000000600
FS: 0000000000000000(0000) GS:ffff88181f420000(0000) knlGS:0000000000000000
CR2: 0000000000000002 CR3: 000000000194a000 CR4: 00000000001407e0
Stack:
ffffffffa0363695 ffff880edf7a4510 ffff88093f16f900 ffff8817faa4ec00
ffff880717547e60 ffffffff8109d5db 00000000faa4ec18 0000000000000000
ffff8817faa4ec18 ffff88093f16f930 ffff880302b63980 ffff88093f16f900
Call Trace:
[<ffffffffa0363695>] ? fscache_object_work_func+0xa5/0x200 [fscache]
[<ffffffff8109d5db>] process_one_work+0x17b/0x470
[<ffffffff8109e4ac>] worker_thread+0x21c/0x400
[<ffffffff8109e290>] ? rescuer_thread+0x400/0x400
[<ffffffff810a5acf>] kthread+0xcf/0xe0
[<ffffffff810a5a00>] ? kthread_create_on_node+0x140/0x140
[<ffffffff816460d8>] ret_from_fork+0x58/0x90
Acked-by: Jeremy McNicoll <jeremymc@redhat.com>
Tested-by: Frank Sorenson <sorenson@redhat.com>
Tested-by: Benjamin Coddington <bcodding@redhat.com>
Reviewed-by: Benjamin Coddington <bcodding@redhat.com>
commit 29905b52fad0854351f57bab867647e4982285bf upstream.
The function order_base_2() is defined (according to the comment block)
as returning zero on input zero, but subsequently passes the input into
roundup_pow_of_two(), which is explicitly undefined for input zero.
This has gone unnoticed until now, but optimization passes in GCC 7 may
produce constant folded function instances where a constant value of
zero is passed into order_base_2(), resulting in link errors against the
deliberately undefined '____ilog2_NaN'.
So update order_base_2() to adhere to its own documented interface.
[ See
http://marc.info/?l=linux-kernel&m=147672952517795&w=2
and follow-up discussion for more background. The gcc "optimization
pass" is really just broken, but now the GCC trunk problem seems to
have escaped out of just specially built daily images, so we need to
work around it in mainline. - Linus ]
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 864b9a393dcb5aed09b8fd31b9bbda0fdda99374 upstream.
We have seen an early OOM killer invocation on ppc64 systems with
crashkernel=4096M:
kthreadd invoked oom-killer: gfp_mask=0x16040c0(GFP_KERNEL|__GFP_COMP|__GFP_NOTRACK), nodemask=7, order=0, oom_score_adj=0
kthreadd cpuset=/ mems_allowed=7
CPU: 0 PID: 2 Comm: kthreadd Not tainted 4.4.68-1.gd7fe927-default #1
Call Trace:
dump_stack+0xb0/0xf0 (unreliable)
dump_header+0xb0/0x258
out_of_memory+0x5f0/0x640
__alloc_pages_nodemask+0xa8c/0xc80
kmem_getpages+0x84/0x1a0
fallback_alloc+0x2a4/0x320
kmem_cache_alloc_node+0xc0/0x2e0
copy_process.isra.25+0x260/0x1b30
_do_fork+0x94/0x470
kernel_thread+0x48/0x60
kthreadd+0x264/0x330
ret_from_kernel_thread+0x5c/0xa4
Mem-Info:
active_anon:0 inactive_anon:0 isolated_anon:0
active_file:0 inactive_file:0 isolated_file:0
unevictable:0 dirty:0 writeback:0 unstable:0
slab_reclaimable:5 slab_unreclaimable:73
mapped:0 shmem:0 pagetables:0 bounce:0
free:0 free_pcp:0 free_cma:0
Node 7 DMA free:0kB min:0kB low:0kB high:0kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:52428800kB managed:110016kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:320kB slab_unreclaimable:4672kB kernel_stack:1152kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
lowmem_reserve[]: 0 0 0 0
Node 7 DMA: 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 0kB
0 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 0kB
Total swap = 0kB
819200 pages RAM
0 pages HighMem/MovableOnly
817481 pages reserved
0 pages cma reserved
0 pages hwpoisoned
the reason is that the managed memory is too low (only 110MB) while the
rest of the the 50GB is still waiting for the deferred intialization to
be done. update_defer_init estimates the initial memoty to initialize
to 2GB at least but it doesn't consider any memory allocated in that
range. In this particular case we've had
Reserving 4096MB of memory at 128MB for crashkernel (System RAM: 51200MB)
so the low 2GB is mostly depleted.
Fix this by considering memblock allocations in the initial static
initialization estimation. Move the max_initialise to
reset_deferred_meminit and implement a simple memblock_reserved_memory
helper which iterates all reserved blocks and sums the size of all that
start below the given address. The cumulative size is than added on top
of the initial estimation. This is still not ideal because
reset_deferred_meminit doesn't consider holes and so reservation might
be above the initial estimation whihch we ignore but let's make the
logic simpler until we really need to handle more complicated cases.
Fixes: 3a80a7fa7989 ("mm: meminit: initialise a subset of struct pages if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set")
Link: http://lkml.kernel.org/r/20170531104010.GI27783@dhcp22.suse.cz
Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
commit 52bd2d62ce6758d811edcbd2256eb9ea7f6a56cb upstream.
skb->sender_cpu and skb->napi_id share a common storage,
and we had various bugs about this.
We had to call skb_sender_cpu_clear() in some places to
not leave a prior skb->napi_id and fool netdev_pick_tx()
As suggested by Alexei, we could split the space so that
these errors can not happen.
0 value being reserved as the common (not initialized) value,
let's reserve [1 .. NR_CPUS] range for valid sender_cpu,
and [NR_CPUS+1 .. ~0U] for valid napi_id.
This will allow proper busy polling support over tunnels.
Suggested-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Paul Menzel <pmenzel@molgen.mpg.de>
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
commit 41c25707d21716826e3c1f60967f5550610ec1c9 upstream.
In most cases, a cgroup controller don't care about the liftimes of
cgroups. For the controller, a css becomes online when ->css_online()
is called on it and offline when ->css_offline() is called.
However, cpuset is special in that the user interface it exposes cares
whether certain cgroups exist or not. Combined with the RCU delay
between cgroup removal and css offlining, this can lead to user
visible behavior oddities where operations which should succeed after
cgroup removals fail for some time period. The effects of cgroup
removals are delayed when seen from userland.
This patch adds css_is_dying() which tests whether offline is pending
and updates is_cpuset_online() so that the function returns false also
while offline is pending. This gets rid of the userland visible
delays.
Reported-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Link: http://lkml.kernel.org/r/327ca1f5-7957-fbb9-9e5f-9ba149d40ba2@oracle.com
commit ec9ee4acd97c0039a61c0ae4f12705767ae62153 upstream.
Commit d07e22597d1d ("mm: mmap: add new /proc tunable for mmap_base
ASLR") added the ability to choose from a range of values to use for
entropy count in generating the random offset to the mmap_base address.
The maximum value on this range was set to 32 bits for 64-bit x86
systems, but this value could be increased further, requiring more than
the 32 bits of randomness provided by get_random_int(), as is already
possible for arm64. Add a new function: get_random_long() which more
naturally fits with the mmap usage of get_random_int() but operates
exactly the same as get_random_int().
Also, fix the shifting constant in mmap_rnd() to be an unsigned long so
that values greater than 31 bits generate an appropriate mask without
overflow. This is especially important on x86, as its shift instruction
uses a 5-bit mask for the shift operand, which meant that any value for
mmap_rnd_bits over 31 acts as a no-op and effectively disables mmap_base
randomization.
Finally, replace calls to get_random_int() with get_random_long() where
appropriate.
This patch (of 2):
Add get_random_long().
Signed-off-by: Daniel Cashman <dcashman@android.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nick Kralevich <nnk@google.com>
Cc: Jeff Vander Stoep <jeffv@google.com>
Cc: Mark Salyzyn <salyzyn@android.com>
commit c70d9d809fdeecedb96972457ee45c49a232d97f upstream.
When I introduced ptracer_cred I failed to consider the weirdness of
fork where the task_struct copies the old value by default. This
winds up leaving ptracer_cred set even when a process forks and
the child process does not wind up being ptraced.
Because ptracer_cred is not set on non-ptraced processes whose
parents were ptraced this has broken the ability of the enlightenment
window manager to start setuid children.
Fix this by properly initializing ptracer_cred in ptrace_init_task
This must be done with a little bit of care to preserve the current value
of ptracer_cred when ptrace carries through fork. Re-reading the
ptracer_cred from the ptracing process at this point is inconsistent
with how PT_PTRACE_CAP has been maintained all of these years.
Tested-by: Takashi Iwai <tiwai@suse.de>
Fixes: 64b875f7ac8a ("ptrace: Capture the ptracer's creds not PT_PTRACE_CAP")
[ Upstream commit 77d4b1d36926a9b8387c6b53eeba42bcaaffcea3 ]
Alexander reported various KASAN messages triggered in recent kernels
The problem is that ping sockets should not use udp_poll() in the first
place, and recent changes in UDP stack finally exposed this old bug.
Fixes: c319b4d76b9e ("net: ipv4: add IPPROTO_ICMP socket kind")
Fixes: 6d0bfe226116 ("net: ipv6: Add IPv6 support to the ping socket.")
Reported-by: Sasha Levin <alexander.levin@verizon.com>
Cc: Solar Designer <solar@openwall.com>
Cc: Vasiliy Kulikov <segoon@openwall.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
Acked-By: Lorenzo Colitti <lorenzo@google.com>
Tested-By: Lorenzo Colitti <lorenzo@google.com>
commit 35d2f80b07bbe03fb358afb0bdeff7437a7d67ff upstream.
It appears that TCP checksum offloading has been broken for
Q-in-Q vlans. The behavior was execerbated by the
series
commit afb0bc972b52 ("Merge branch 'stacked_vlan_tso'")
that that enabled accleleration features on stacked vlans.
However, event without that series, it is possible to trigger
this issue. It just requires a lot more specialized configuration.
The root cause is the interaction between how
netdev_intersect_features() works, the features actually set on
the vlan devices and HW having the ability to run checksum with
longer headers.
The issue starts when netdev_interesect_features() replaces
NETIF_F_HW_CSUM with a combination of NETIF_F_IP_CSUM | NETIF_F_IPV6_CSUM,
if the HW advertises IP|IPV6 specific checksums. This happens
for tagged and multi-tagged packets. However, HW that enables
IP|IPV6 checksum offloading doesn't gurantee that packets with
arbitrarily long headers can be checksummed.
This patch disables IP|IPV6 checksums on the packet for multi-tagged
packets.
CC: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
CC: Michal Kubecek <mkubecek@suse.cz>
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Acked-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
[ Upstream commit 3fb07daff8e99243366a081e5129560734de4ada ]
Andrey Konovalov reported crashes in ipv4_mtu()
I could reproduce the issue with KASAN kernels, between
10.246.7.151 and 10.246.7.152 :
1) 20 concurrent netperf -t TCP_RR -H 10.246.7.152 -l 1000 &
2) At the same time run following loop :
while :
do
ip ro add 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
ip ro del 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
done
Cong Wang attempted to add back rt->fi in commit
82486aa6f1b9 ("ipv4: restore rt->fi for reference counting")
but this proved to add some issues that were complex to solve.
Instead, I suggested to add a refcount to the metrics themselves,
being a standalone object (in particular, no reference to other objects)
I tried to make this patch as small as possible to ease its backport,
instead of being super clean. Note that we believe that only ipv4 dst
need to take care of the metric refcount. But if this is wrong,
this patch adds the basic infrastructure to extend this to other
families.
Many thanks to Julian Anastasov for reviewing this patch, and Cong Wang
for his efforts on this problem.
Fixes: 2860583fe840 ("ipv4: Kill rt->fi")
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
commit 30e7d894c1478c88d50ce94ddcdbd7f9763d9cdd upstream.
Enabling the tracer selftest triggers occasionally the warning in
text_poke(), which warns when the to be modified page is not marked
reserved.
The reason is that the tracer selftest installs kprobes on functions marked
__init for testing. These probes are removed after the tests, but that
removal schedules the delayed kprobes_optimizer work, which will do the
actual text poke. If the work is executed after the init text is freed,
then the warning triggers. The bug can be reproduced reliably when the work
delay is increased.
Flush the optimizer work and wait for the optimizing/unoptimizing lists to
become empty before returning from the kprobes tracer selftest. That
ensures that all operations which were queued due to the probes removal
have completed.
Link: http://lkml.kernel.org/r/20170516094802.76a468bb@gandalf.local.home
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Fixes: 6274de498 ("kprobes: Support delayed unoptimizing")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 480dd46b9d6812e5fb7172c305ee0f1154c26eed upstream.
The ability to change the max_rx_aggregation frames is useful
in cases of IOP.
There exist some devices (latest mobile phones and some AP's)
that tend to not respect a BA sessions maximum size (in Kbps).
These devices won't respect the AMPDU size that was negotiated during
association (even though they do respect the maximal number of packets).
This violation is characterized by a valid number of packets in
a single AMPDU. Even so, the total size will exceed the size negotiated
during association.
Eventually, this will cause some undefined behavior, which in turn
causes the hw to drop packets, causing the throughput to plummet.
This patch will make the subframe limitation to be held by each station,
instead of being held only by hw.
Signed-off-by: Maxim Altshul <maxim.altshul@ti.com>
commit 50ea05efaf3bed7dd34bcc2635a8b3f53bd0ccc1 upstream.
Currently mac80211 does not inform the driver of the session
block ack timeout when starting a rx aggregation session.
Drivers that manage the reorder buffer need to know this
parameter.
Seeing that there are now too many arguments for the
drv_ampdu_action() function, wrap them inside a structure.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
commit fad471860c097844432c7cf5d3ae6a0a059c2bdc upstream.
Currently mac80211 does not inform the driver of the window
size when starting an RX aggregation session.
To enable managing the reorder buffer in the driver or hardware
the window size is needed.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit d36ad77f702356afb1009d2987b0ab55da4c7d57 upstream.
This patch converts core_tpg_set_initiator_node_queue_depth()
to use struct se_node_acl->acl_sess_list when performing
explicit se_tpg_tfo->shutdown_session() for active sessions,
in order for new se_node_acl->queue_depth to take effect.
This follows how core_tpg_del_initiator_node_acl() currently
works when invoking se_tpg_tfo->shutdown-session(), and ahead
of the next patch to take se_node_acl->acl_kref during lookup,
the extra get_initiator_node_acl() can go away. In order to
achieve this, go ahead and change target_get_session() to use
kref_get_unless_zero() and propigate up the return value
to know when a session is already being released.
This is because se_node_acl->acl_group is already protecting
se_node_acl->acl_group reference via configfs, and shutdown
within core_tpg_del_initiator_node_acl() won't occur until
sys_write() to core_tpg_set_initiator_node_queue_depth()
attribute returns back to user-space.
Also, drop the left-over iscsi-target hack, and obtain
se_portal_group->session_lock in lio_tpg_shutdown_session()
internally. Remove iscsi-target wrapper and unused se_tpg +
force parameters and associated code.
Reported-by: Christoph Hellwig <hch@lst.de>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
commit 19b7ccf8651df09d274671b53039c672a52ad84d upstream.
Commit 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk")
introduced blk_integrity_revalidate(), which seems to assume ownership
of the stable pages flag and unilaterally clears it if no blk_integrity
profile is registered:
if (bi->profile)
disk->queue->backing_dev_info->capabilities |=
BDI_CAP_STABLE_WRITES;
else
disk->queue->backing_dev_info->capabilities &=
~BDI_CAP_STABLE_WRITES;
It's called from revalidate_disk() and rescan_partitions(), making it
impossible to enable stable pages for drivers that support partitions
and don't use blk_integrity: while the call in revalidate_disk() can be
trivially worked around (see zram, which doesn't support partitions and
hence gets away with zram_revalidate_disk()), rescan_partitions() can
be triggered from userspace at any time. This breaks rbd, where the
ceph messenger is responsible for generating/verifying CRCs.
Since blk_integrity_{un,}register() "must" be used for (un)registering
the integrity profile with the block layer, move BDI_CAP_STABLE_WRITES
setting there. This way drivers that call blk_integrity_register() and
use integrity infrastructure won't interfere with drivers that don't
but still want stable pages.
Fixes: 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk")
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Tested-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
[idryomov@gmail.com: backport to < 4.11: bdi is embedded in queue]
Signed-off-by: Jens Axboe <axboe@fb.com>
commit b9dd46188edc2f0d1f37328637860bb65a771124 upstream.
F2FS uses 4 bytes to represent block address. As a result, supported
size of disk is 16 TB and it equals to 16 * 1024 * 1024 / 2 segments.
Signed-off-by: Jin Qian <jinqian@google.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit 242d3a49a2a1a71d8eb9f953db1bcaa9d698ce00 ]
For each netns (except init_net), we initialize its null entry
in 3 places:
1) The template itself, as we use kmemdup()
2) Code around dst_init_metrics() in ip6_route_net_init()
3) ip6_route_dev_notify(), which is supposed to initialize it after
loopback registers
Unfortunately the last one still happens in a wrong order because
we expect to initialize net->ipv6.ip6_null_entry->rt6i_idev to
net->loopback_dev's idev, thus we have to do that after we add
idev to loopback. However, this notifier has priority == 0 same as
ipv6_dev_notf, and ipv6_dev_notf is registered after
ip6_route_dev_notifier so it is called actually after
ip6_route_dev_notifier. This is similar to commit 2f460933f58e
("ipv6: initialize route null entry in addrconf_init()") which
fixes init_net.
Fix it by picking a smaller priority for ip6_route_dev_notifier.
Also, we have to release the refcnt accordingly when unregistering
loopback_dev because device exit functions are called before subsys
exit functions.
Acked-by: David Ahern <dsahern@gmail.com>
Tested-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 2f460933f58eee3393aba64f0f6d14acb08d1724 ]
Andrey reported a crash on init_net.ipv6.ip6_null_entry->rt6i_idev
since it is always NULL.
This is clearly wrong, we have code to initialize it to loopback_dev,
unfortunately the order is still not correct.
loopback_dev is registered very early during boot, we lose a chance
to re-initialize it in notifier. addrconf_init() is called after
ip6_route_init(), which means we have no chance to correct it.
Fix it by moving this initialization explicitly after
ipv6_add_dev(init_net.loopback_dev) in addrconf_init().
Tested-by: Andrey Konovalov <andreyknvl@google.com>
commit a89b94b53371bbfa582787c2fa3378000ea4263d upstream.
We're currently emulating the vbus and id interrupts in the OTGSC
read API, but we also need to make sure that if we're handling
the events with extcon that we don't enable the interrupts for
those events in the hardware. Therefore, properly emulate this
register if we're using extcon, but don't enable the interrupts.
This allows me to get my cable connect/disconnect working
properly without getting spurious interrupts on my device that
uses an extcon for these two events.
Acked-by: Peter Chen <peter.chen@nxp.com>
Cc: "Ivan T. Ivanov" <iivanov.xz@gmail.com>
Fixes: 3ecb3e09b042 ("usb: chipidea: Use extcon framework for VBUS and ID detect")
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit fddcca5107051adf9e4481d2a79ae0616577fd2c upstream.
When map_word gets too large, we use a lot of kernel stack, and for
MTD_MAP_BANK_WIDTH_32, this means we use more than the recommended
1024 bytes in a number of functions:
drivers/mtd/chips/cfi_cmdset_0020.c: In function 'cfi_staa_write_buffers':
drivers/mtd/chips/cfi_cmdset_0020.c:651:1: warning: the frame size of 1336 bytes is larger than 1024 bytes [-Wframe-larger-than=]
drivers/mtd/chips/cfi_cmdset_0020.c: In function 'cfi_staa_erase_varsize':
drivers/mtd/chips/cfi_cmdset_0020.c:972:1: warning: the frame size of 1208 bytes is larger than 1024 bytes [-Wframe-larger-than=]
drivers/mtd/chips/cfi_cmdset_0001.c: In function 'do_write_buffer':
drivers/mtd/chips/cfi_cmdset_0001.c:1835:1: warning: the frame size of 1240 bytes is larger than 1024 bytes [-Wframe-larger-than=]
This can be avoided if all operations on the map word are done
indirectly and the stack gets reused between the calls. We can
mostly achieve this by selecting MTD_COMPLEX_MAPPINGS whenever
MTD_MAP_BANK_WIDTH_32 is set, but for the case that no other
bank width is enabled, we also need to use a non-constant
map_bankwidth() to convince the compiler to use less stack.
[Brian: this patch mostly achieves its goal by forcing
MTD_COMPLEX_MAPPINGS (and the accompanying indirection) for 256-bit
mappings; the rest of the change is mostly a wash, though it helps
reduce stack size slightly. If we really care about supporting
256-bit mappings though, we should consider rewriting some of this
code to avoid keeping and assigning so many 256-bit objects on the
stack.]
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
[ Upstream commit 557c44be917c322860665be3d28376afa84aa936 ]
Andrey reported a fault in the IPv6 route code:
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 4035 Comm: a.out Not tainted 4.11.0-rc7+ #250
task: ffff880069809600 task.stack: ffff880062dc8000
RIP: 0010:ip6_rt_cache_alloc+0xa6/0x560 net/ipv6/route.c:975
RSP: 0018:ffff880062dced30 EFLAGS: 00010206
RAX: dffffc0000000000 RBX: ffff8800670561c0 RCX: 0000000000000006
RDX: 0000000000000003 RSI: ffff880062dcfb28 RDI: 0000000000000018
RBP: ffff880062dced68 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880062dcfb28 R14: dffffc0000000000 R15: 0000000000000000
FS: 00007feebe37e7c0(0000) GS:ffff88006cb00000(0000) knlGS:0000000000000000
CR2: 00000000205a0fe4 CR3: 000000006b5c9000 CR4: 00000000000006e0
Call Trace:
ip6_pol_route+0x1512/0x1f20 net/ipv6/route.c:1128
ip6_pol_route_output+0x4c/0x60 net/ipv6/route.c:1212
Andrey's syzkaller program passes rtmsg.rtmsg_flags with the RTF_PCPU bit
set. Flags passed to the kernel are blindly copied to the allocated
rt6_info by ip6_route_info_create making a newly inserted route appear
as though it is a per-cpu route. ip6_rt_cache_alloc sees the flag set
and expects rt->dst.from to be set - which it is not since it is not
really a per-cpu copy. The subsequent call to __ip6_dst_alloc then
generates the fault.
Fix by checking for the flag and failing with EINVAL.
Fixes: d52d3997f843f ("ipv6: Create percpu rt6_info")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
