commit ede1b4290781ae82ccf0f2ecc6dada8d3dd35779 upstream.
PowerTOP would like to be able to trace timers.
Unfortunately, the current timer tracing is not very useful: the
actual timer function is not recorded in the trace at the start
of timer execution.
Although this is recorded for timer "start" time (when it gets
armed), this is not useful; most timers get started early, and a
tracer like PowerTOP will never see this event, but will only
see the actual running of the timer.
This patch just adds the function to the timer tracing; I've
verified with PowerTOP that now it can get useful information
about timers.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: xiaoguangrong@cn.fujitsu.com
LKML-Reference: <4C6C5FA9.3000405@linux.intel.com>
commit cff0d6e6edac7672b3f915bb4fb59f279243b7f9 upstream.
Commit fc6055a5ba31e2c14e36e8939f9bf2b6d586a7f5 (net: Introduce
skb_orphan_try()) allows an early orphan of the skb and takes care on
tx timestamping, which needs the sk-reference in the skb on driver level.
So does the can-raw socket, which has not been taken into account here.
The patch below adds a 'prevent_sk_orphan' bit in the skb tx shared info,
which fixes the problem discovered by Matthias Fuchs here:
http://marc.info/?t=128030411900003&r=1&w=2
Even if it's not a primary tx timestamp topic it fits well into some skb
shared tx context. Or should be find a different place for the information to
protect the sk reference until it reaches the driver level?
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
commit 31d1d48e199e99077fb30f6fb9a793be7bec756f upstream.
Make /dev/console get initialised before any initialisation routine that
invokes modprobe because if modprobe fails, it's going to want to open
/dev/console, presumably to write an error message to.
The problem with that is that if the /dev/console driver is not yet
initialised, the chardev handler will call request_module() to invoke
modprobe, which will fail, because we never compile /dev/console as a
module.
This will lead to a modprobe loop, showing the following in the kernel
log:
request_module: runaway loop modprobe char-major-5-1
This can happen, for example, when the built in md5 module can't find
the built in cryptomgr module (because the latter fails to initialise).
The md5 module comes before the call to tty_init(), presumably because
'crypto' comes before 'drivers' alphabetically.
Fix this by calling tty_init() from chrdev_init().
commit 297c5eee372478fc32fec5fe8eed711eedb13f3d upstream.
It's a really simple list, and several of the users want to go backwards
in it to find the previous vma. So rather than have to look up the
previous entry with 'find_vma_prev()' or something similar, just make it
doubly linked instead.
Tested-by: Ian Campbell <ijc@hellion.org.uk>
commit 8ae664184c45def51ff0b61d4bd6c6671db6cb4f upstream.
This patch prevent to schedule while atomic by changing the
flchip_shared spinlock into a mutex. This should be save since no atomic
path will use this lock.
It was suggested by Arnd Bergmann and Vasiliy Kulikov.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 56385a12d9bb9e173751f74b6c430742018cafc0 upstream.
With some hardware combinations, the PCM interrupts are acknowledged
before the period boundary from the emu10k1 chip. The midlevel PCM code
gets confused and the playback stream is interrupted.
It seems that the interrupt processing shift by 2 samples is enough
to fix this issue. This default value does not harm other,
non-affected hardware.
More information: Kernel bugzilla bug#16300
[A copmile warning fixed by tiwai]
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 0a7992c90828a65281c3c9cf180be3b432d277b2 upstream.
The ACPI_PREEMPTION_POINT() logic was introduced in commit 8bd108d
(ACPICA: add preemption point after each opcode parse). The follow up
commits abe1dfab6, 138d15692, c084ca70 tried to fix the preemption logic
back and forth, but nobody noticed that the usage of
in_atomic_preempt_off() in that context is wrong.
The check which guards the call of cond_resched() is:
if (!in_atomic_preempt_off() && !irqs_disabled())
in_atomic_preempt_off() is not intended for general use as the comment
above the macro definition clearly says:
* Check whether we were atomic before we did preempt_disable():
* (used by the scheduler, *after* releasing the kernel lock)
On a CONFIG_PREEMPT=n kernel the usage of in_atomic_preempt_off() works by
accident, but with CONFIG_PREEMPT=y it's just broken.
The whole purpose of the ACPI_PREEMPTION_POINT() is to reduce the latency
on a CONFIG_PREEMPT=n kernel, so make ACPI_PREEMPTION_POINT() depend on
CONFIG_PREEMPT=n and remove the in_atomic_preempt_off() check.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16210
[akpm@linux-foundation.org: fix build]
Cc: Len Brown <lenb@kernel.org>
Cc: Francois Valenduc <francois.valenduc@tvcablenet.be>
Cc: Lin Ming <ming.m.lin@intel.com>
commit 685fd0b4ea3f0f1d5385610b0d5b57775a8d5842 upstream.
A small number of users of IRQF_TIMER are using it for the implied no
suspend behaviour on interrupts which are not timer interrupts.
Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to
__IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: xen-devel@lists.xensource.com
Cc: linux-input@vger.kernel.org
Cc: linuxppc-dev@ozlabs.org
Cc: devicetree-discuss@lists.ozlabs.org
LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com>
commit 38117d1495e587fbb10d6e55733139a27893cef5 upstream.
commit 4565956dc0847985c0403c9ebbf274b6a122e1e2 upstream.
The header file l2tp.h should be exported to the installed include/linux/
tree for userspace programs.
This patch fixes compilation errors in L2TP userspace apps which want to
use the new L2TP support introduced in 2.6.35.
Signed-off-by: James Chapman <jchapman@katalix.com>
commit 396e894d289d69bacf5acd983c97cd6e21a14c08 upstream.
Norbert reported that nohz_ratelimit() causes his laptop to burn about
4W (40%) extra. For now back out the change and see if we can adjust
the power management code to make better decisions.
Reported-by: Norbert Preining <preining@logic.at>
Acked-by: Mike Galbraith <efault@gmx.de>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <new-submission>
commit 93362a875fc69881ae69299efaf19a55a1f57db0 upstream.
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
BIO_RW_* bits
commit aca27ba9618276dd2f777bcd5a1419589ccf1ca8 upstream.
Commit a82afdf (block: use the same failfast bits for bio and request)
moved BIO_RW_* bits around such that they match up with REQ_* bits.
Unfortunately, fs.h hard coded RW_MASK, RWA_MASK, READ, WRITE, READA
and SWRITE as 0, 1, 2 and 3, and expected them to match with BIO_RW_*
bits. READ/WRITE didn't change but BIO_RW_AHEAD was moved to bit 4
instead of bit 1, breaking RWA_MASK, READA and SWRITE.
This patch updates RWA_MASK, READA and SWRITE such that they match the
BIO_RW_* bits again. A follow up patch will update the definitions to
directly use BIO_RW_* bits so that this kind of breakage won't happen
again.
Neil also spotted missing RWA_MASK conversion.
Stable: The offending commit a82afdf was released with v2.6.32, so
this patch should be applied to all kernels since then but it must
_NOT_ be applied to kernels earlier than that.
Reported-and-bisected-by: Vladislav Bolkhovitin <vst@vlnb.net>
Root-caused-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 7a4dec53897ecd3367efb1e12fe8a4edc47dc0e9 upstream.
If sget() finds a matching superblock being set up, it'll
grab an active reference to it and grab s_umount. That's
fine - we'll wait for completion of foofs_get_sb() that way.
However, if said foofs_get_sb() fails we'll end up holding
the halfway-created superblock. deactivate_locked_super()
called by foofs_get_sb() will just unlock the sucker since
we are holding another active reference to it.
What we need is a way to tell if superblock has been successfully
set up. Unfortunately, neither ->s_root nor the check for
MS_ACTIVE quite fit. Cheap and easy way, suitable for backport:
new flag set by the (only) caller of ->get_sb(). If that flag
isn't present by the time sget() grabbed s_umount on preexisting
superblock it has found, it's seeing a stillborn and should
just bury it with deactivate_locked_super() (and repeat the search).
Longer term we want to set that flag in ->get_sb() instances (and
check for it to distinguish between "sget() found us a live sb"
and "sget() has allocated an sb, we need to set it up" in there,
instead of checking ->s_root as we do now).
commit 1297c05a8dfb568c689f057d51a65eebe5ddc86f upstream.
New evergreen and r7xx ids.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit 06c4648d46d1b757d6b9591a86810be79818b60c upstream.
Currently such notifications are only generated when the device comes up or the
address changes. However one use case for these notifications is to enable
faster network recovery after a virtual machine migration (by causing switches
to relearn their MAC tables). A migration appears to the network stack as a
temporary loss of carrier and therefore does not trigger either of the current
conditions. Rather than adding carrier up as a trigger (which can cause issues
when interfaces a flapping) simply add an interface which the driver can use
to explicitly trigger the notification.
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: netdev@vger.kernel.org
nfs_commit_inode() needs to be defined irrespectively of whether or not
we are supporting NFSv3 and NFSv4.
Allow the compiler to optimise away code in the NFSv2-only case by
converting it into an inlined stub function.
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
See https://bugzilla.kernel.org/show_bug.cgi?id=16056
If other processes are blocked waiting for kswapd to free up some memory so
that they can make progress, then we cannot allow kswapd to block on those
processes.
Cc: stable@kernel.org
Fix __task_cred()'s lockdep check by removing the following validation
condition:
lockdep_tasklist_lock_is_held()
as commit_creds() does not take the tasklist_lock, and nor do most of the
functions that call it, so this check is pointless and it can prevent
detection of the RCU lock not being held if the tasklist_lock is held.
Instead, add the following validation condition:
task->exit_state >= 0
to permit the access if the target task is dead and therefore unable to change
its own credentials.
Fix __task_cred()'s comment to:
(1) discard the bit that says that the caller must prevent the target task
from being deleted. That shouldn't need saying.
(2) Add a comment indicating the result of __task_cred() should not be passed
directly to get_cred(), but rather than get_task_cred() should be used
instead.
Also put a note into the documentation to enforce this point there too.
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
It's possible for get_task_cred() as it currently stands to 'corrupt' a set of
credentials by incrementing their usage count after their replacement by the
task being accessed.
What happens is that get_task_cred() can race with commit_creds():
TASK_1 TASK_2 RCU_CLEANER
-->get_task_cred(TASK_2)
rcu_read_lock()
__cred = __task_cred(TASK_2)
-->commit_creds()
old_cred = TASK_2->real_cred
TASK_2->real_cred = ...
put_cred(old_cred)
call_rcu(old_cred)
[__cred->usage == 0]
get_cred(__cred)
[__cred->usage == 1]
rcu_read_unlock()
-->put_cred_rcu()
panic()
However, since a tasks credentials are generally not changed very often, we can
reasonably make use of a loop involving reading the creds pointer and using
atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero.
If successful, we can safely return the credentials in the knowledge that, even
if the task we're accessing has released them, they haven't gone to the RCU
cleanup code.
We then change task_state() in procfs to use get_task_cred() rather than
calling get_cred() on the result of __task_cred(), as that suffers from the
same problem.
Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be
tripped when it is noticed that the usage count is not zero as it ought to be,
for example:
kernel BUG at kernel/cred.c:168!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/kernel/mm/ksm/run
CPU 0
Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex
745
RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45
RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202
RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff
RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0
RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0
R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001
FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000
CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0
Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0)
Stack:
ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45
<0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000
<0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246
Call Trace:
[<ffffffff810698cd>] put_cred+0x13/0x15
[<ffffffff81069b45>] commit_creds+0x16b/0x175
[<ffffffff8106aace>] set_current_groups+0x47/0x4e
[<ffffffff8106ac89>] sys_setgroups+0xf6/0x105
[<ffffffff81009b02>] system_call_fastpath+0x16/0x1b
Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00
48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b
04 25 00 cc 00 00 48 3b b8 58 04 00 00 75
RIP [<ffffffff81069881>] __put_cred+0xc/0x45
RSP <ffff88019e7e9eb8>
---[ end trace df391256a100ebdd ]---
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6:
davinci: da850/omap-l138 evm: account for DEFDCDC{2,3} being tied high
regulator: tps6507x: allow driver to use DEFDCDC{2,3}_HIGH register
wm8350-regulator: fix wm8350_register_regulator error handling
ab3100: fix off-by-one value range checking for voltage selector
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
In TPS6507x, depending on the status of DEFDCDC{2,3} pin either
DEFDCDC{2,3}_LOW or DEFDCDC{2,3}_HIGH register needs to be read or
programmed to change the output voltage.
The current driver assumes DEFDCDC{2,3} pins are always tied low
and thus operates only on DEFDCDC{2,3}_LOW register. This need
not always be the case (as is found on OMAP-L138 EVM).
Unfortunately, software cannot read the status of DEFDCDC{2,3} pins.
So, this information is passed through platform data depending on
how the board is wired.
Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
s2io: fixing DBG_PRINT() macro
ath9k: fix dma direction for map/unmap in ath_rx_tasklet
net: dev_forward_skb should call nf_reset
net sched: fix race in mirred device removal
tun: avoid BUG, dump packet on GSO errors
bonding: set device in RLB ARP packet handler
wimax/i2400m: Add PID & VID for Intel WiMAX 6250
ipv6: Don't add routes to ipv6 disabled interfaces.
net: Fix skb_copy_expand() handling of ->csum_start
net: Fix corruption of skb csum field in pskb_expand_head() of net/core/skbuff.c
macvtap: Limit packet queue length
ixgbe/igb: catch invalid VF settings
bnx2x: Advance a module version
bnx2x: Protect statistics ramrod and sequence number
bnx2x: Protect a SM state change
wireless: use netif_rx_ni in ieee80211_send_layer2_update
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI / Sleep: Allow the NVS saving to be skipped during suspend to RAM
ACPI: create "processor.bm_check_disable" boot param
ACPI: skip checking BM_STS if the BIOS doesn't ask for it
ACPI: fix unused function warning
ACPI: processor: fix processor_physically_present on UP
ACPI video: fix string mismatch for Sony SR290 laptop
ACPI battery: don't invoke power_supply_changed twice when battery is hot-added
ACPI: handle systems which asynchoronously enable ACPI mode
This fixes hang when target device of mirred packet classifier
action is removed.
If a mirror or redirection action is configured to cause packets
to go to another device, the classifier holds a ref count, but was assuming
the adminstrator cleaned up all redirections before removing. The fix
is to add a notifier and cleanup during unregister.
The new list is implicitly protected by RTNL mutex because
it is held during filter add/delete as well as notifier.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
Commit 2a6b69765ad794389f2fc3e14a0afa1a995221c2
(ACPI: Store NVS state even when entering suspend to RAM) caused the
ACPI suspend code save the NVS area during suspend and restore it
during resume unconditionally, although it is known that some systems
need to use acpi_sleep=s4_nonvs for hibernation to work. To allow
the affected systems to avoid saving and restoring the NVS area
during suspend to RAM and resume, introduce kernel command line
option acpi_sleep=nonvs and make acpi_sleep=s4_nonvs work as its
alias temporarily (add acpi_sleep=s4_nonvs to the feature removal
file).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16396 .
Reported-and-tested-by: tomas m <tmezzadra@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
vmlinux.lds: fix .data..init_task output section (fix popwerpc boot)
powerpc: Fix erroneous lmb->memblock conversions
powerpc/mm: Add some debug output when hash insertion fails
powerpc/mm: Fix bugs in huge page hashing
powerpc/mm: Move around testing of _PAGE_PRESENT in hash code
powerpc/mm: Handle hypervisor pte insert failure in __hash_page_huge
powerpc/kexec: Fix boundary case for book-e kexec memory limits
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Fix fallback to cplus_demangle() when bfd_demangle() is not available
perf annotate: Fix handling of goto labels that are valid hex numbers
tracing: Properly align linker defined symbols
perf symbols: Fix directory descriptor leaking
perf: Fix various display bugs with parent filtering
The .data..init_task output section was missing
a load offset causing a popwerpc target to fail to boot.
Sean MacLennan tracked it down to the definition of
INIT_TASK_DATA_SECTION().
There are only two users of INIT_TASK_DATA_SECTION()
in the kernel today: cris and popwerpc.
cris do not support relocatable kernels and is thus not
impacted by this change.
Fix INIT_TASK_DATA_SECTION() to specify load offset like
all other output sections.
Reported-by: Sean MacLennan <smaclennan@pikatech.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
It turns out that there is a bit in the _CST for Intel FFH C3
that tells the OS if we should be checking BM_STS or not.
Linux has been unconditionally checking BM_STS.
If the chip-set is configured to enable BM_STS,
it can retard or completely prevent entry into
deep C-states -- as illustrated by turbostat:
http://userweb.kernel.org/~lenb/acpi/utils/pmtools/turbostat/
ref: Intel Processor Vendor-Specific ACPI Interface Specification
table 4 "_CST FFH GAS Field Encoding"
Bit 1: Set to 1 if OSPM should use Bus Master avoidance for this C-state
https://bugzilla.kernel.org/show_bug.cgi?id=15886
Mark Wagner reported OOM symptoms when sending UDP traffic over
a macvtap link to a kvm receiver.
This appears to be caused by the fact that macvtap packet queues
are unlimited in length. This means that if the receiver can't
keep up with the rate of flow, then we will hit OOM. Of course
it gets worse if the OOM killer then decides to kill the receiver.
This patch imposes a cap on the packet queue length, in the same
way as the tuntap driver, using the device TX queue length.
Please note that macvtap currently has no way of giving congestion
notification, that means the software device TX queue cannot be
used and packets will always be dropped once the macvtap driver
queue fills up.
This shouldn't be a great problem for the scenario where macvtap
is used to feed a kvm receiver, as the traffic is most likely
external in origin so congestion notification can't be applied
anyway.
Of course, if anybody decides to complain about guest-to-guest
UDP packet loss down the track, then we may have to revisit this.
Incidentally, this patch also fixes a real memory leak when
macvtap_get_queue fails.
Chris Wright noticed that for this patch to work, we need a
non-zero TX queue length. This patch includes his work to change
the default macvtap TX queue length to 500.
Reported-by: Mark Wagner <mwagner@redhat.com>
Acked-by: Chris Wright <chrisw@sous-sol.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
sysrq,kdb: Use __handle_sysrq() for kdb's sysrq function
debug_core,kdb: fix kgdb_connected bit set in the wrong place
Fix merge regression from external kdb to upstream kdb
repair gdbstub to match the gdbserial protocol specification
kdb: break out of kdb_ll() when command is terminated
The kdb code should not toggle the sysrq state in case an end user
wants to try and resume the normal kernel execution.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
math-emu: correct test for downshifting fraction in _FP_FROM_INT()
perf: Add DWARF register lookup for sparc
MAINTAINERS: Add SBUS driver path to sparc entry.
drivers/sbus: Remove unnecessary casts of private_data
sparc: remove homegrown L1_CACHE_ALIGN macro
sparc64: fix the build error due to smp_kgdb_capture_client()
sparc64: Fix maybe_change_configuration() PCR setting.
arch/sparc/kernel: Eliminate what looks like a NULL pointer dereference
sparc64: Update defconfig.
sunsu: Fix use after free in su_remove().
sunserial: Don't call add_preferred_console() when console= is specified.
sparc32: Kill none_mask, it's bogus.
The kernel's math-emu code contains a macro _FP_FROM_INT() which is
used to convert an integer to a raw normalized floating-point value.
It does this basically in three steps:
1. Compute the exponent from the number of leading zero bits.
2. Downshift large fractions to put the MSB in the right position
for normalized fractions.
3. Upshift small fractions to put the MSB in the right position.
There is an boundary error in step 2, causing a fraction with its
MSB exactly one bit above the normalized MSB position to not be
downshifted. This results in a non-normalized raw float, which when
packed becomes a massively inaccurate representation for that input.
The impact of this depends on a number of arch-specific factors,
but it is known to have broken emulation of FXTOD instructions
on UltraSPARC III, which was originally reported as GCC bug 44631
<http://gcc.gnu.org/bugzilla/show_bug.cgi?id=44631>.
Any arch which uses math-emu to emulate conversions from integers to
same-size floats may be affected.
The fix is simple: the exponent comparison used to determine if the
fraction should be downshifted must be "<=" not "<".
I'm sending a kernel module to test this as a reply to this message.
There are also SPARC user-space test cases in the GCC bug entry.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/r600: fix possible NULL pointer derefernce
drm/radeon/kms: add quirk for ASUS HD 3600 board
include/linux/vgaarb.h: add missing part of include guard
drm/nouveau: Fix crashes during fbcon init on single head cards.
drm/nouveau: fix pcirom vbios shadow breakage from acpi rom patch
drm/radeon/kms: fix shared ddc harder
drm/i915: enable low power render writes on GEN3 hardware.
drm/i915: Define MI_ARB_STATE bits
vmwgfx: return -EFAULT if copy_to_user fails
fb: handle allocation failure in alloc_apertures()
drm: radeon: check kzalloc() result
drm/ttm: Fix build on architectures without AGP
drm/radeon/kms: fix gtt MC base alignment on rs4xx/rs690/rs740 asics
drm/radeon/kms: fix possible mis-detection of sideport on rs690/rs740
drm/radeon/kms: fix legacy tv-out pal mode
vgaarb.h was missing the #define of the #ifndef at the top for the guard
to prevent multiple #include's from causing re-define errors
Signed-off-by: Doug Goldstein <cardoe@gentoo.org>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits)
bridge: Partially disable netpoll support
tcp: fix crash in tcp_xmit_retransmit_queue
IPv6: fix CoA check in RH2 input handler (mip6_rthdr_input())
ibmveth: lost IRQ while closing/opening device leads to service loss
rt2x00: Fix lockdep warning in rt2x00lib_probe_dev()
vhost: avoid pr_err on condition guest can trigger
ipmr: Don't leak memory if fib lookup fails.
vhost-net: avoid flush under lock
net: fix problem in reading sock TX queue
net/core: neighbour update Oops
net: skb_tx_hash() fix relative to skb_orphan_try()
rfs: call sock_rps_record_flow() in tcp_splice_read()
xfrm: do not assume that template resolving always returns xfrms
hostap_pci: set dev->base_addr during probe
axnet_cs: use spin_lock_irqsave in ax_interrupt
dsa: Fix Kconfig dependencies.
act_nat: not all of the ICMP packets need an IP header payload
r8169: incorrect identifier for a 8168dp
Phonet: fix skb leak in pipe endpoint accept()
Bluetooth: Update sec_level/auth_type for already existing connections
If a single-threaded process does a file-descriptor operation, and some
other process accesses that same file descriptor via /proc, the current
rcu_dereference_check_fdtable() can give a false-positive RCU-lockdep
splat due to the reference count being increased by the /proc access after
the reference-count check in fget_light() but before the check in
rcu_dereference_check_fdtable().
This commit prevents this false positive by checking for a single-threaded
process. To avoid #include hell, this commit uses the wrapper for
thread_group_empty(current) defined by rcu_my_thread_group_empty()
provided in a separate commit.
Located-by: Miles Lane <miles.lane@gmail.com>
Located-by: Eric Dumazet <eric.dumazet@gmail.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
We define a number of symbols in the linker scipt like this:
__start_syscalls_metadata = .;
*(__syscalls_metadata)
But we do not know the alignment of "." when we assign
the __start_syscalls_metadata symbol.
gcc started to uses bigger alignment for structs (32 bytes),
so we saw situations where the linker due to alignment
constraints increased the value of "." after the symbol assignment.
This resulted in boot fails.
Fix this by forcing a 32 byte alignment of "." before the
assignment.
This patch introduces the forced alignment for
ftrace_events and syscalls_metadata.
It may be required in more places.
Reported-by: Zeev Tarantov <zeev.tarantov@gmail.com>
LKML-Reference: <20100710063459.GA14596@merkur.ravnborg.org>
If the kzalloc() fails we should return NULL. All the places that call
alloc_apertures() check for this already.
Acked-by: James Simmons <jsimmons@infradead.org>
Acked-by: Marcin Slusarz <marcin.slusarz@gmail.com>
The current shrinker implementation requires the registered callback
to have global state to work from. This makes it difficult to shrink
caches that are not global (e.g. per-filesystem caches). Pass the shrinker
structure to the callback so that users can embed the shrinker structure
in the context the shrinker needs to operate on and get back to it in the
callback via container_of().
Signed-off-by: Dave Chinner <dchinner@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: fall back to original BIOS BAR addresses
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2: Silence gcc warning in ocfs2_write_zero_page().
jbd2/ocfs2: Fix block checksumming when a buffer is used in several transactions
ocfs2/dlm: Remove BUG_ON from migration in the rare case of a down node
ocfs2: Don't duplicate pages past i_size during CoW.
ocfs2: tighten up strlen() checking
ocfs2: Make xattr reflink work with new local alloc reservation.
ocfs2: make xattr extension work with new local alloc reservation.
ocfs2: Remove the redundant cpu_to_le64.
ocfs2/dlm: don't access beyond bitmap size
ocfs2: No need to zero pages past i_size.
ocfs2: Zero the tail cluster when extending past i_size.
ocfs2: When zero extending, do it by page.
ocfs2: Limit default local alloc size within bitmap range.
ocfs2: Move orphan scan work to ocfs2_wq.
fs/ocfs2/dlm: Add missing spin_unlock
If we fail to assign resources to a PCI BAR, this patch makes us try the
original address from BIOS rather than leaving it disabled.
Linux tries to make sure all PCI device BARs are inside the upstream
PCI host bridge or P2P bridge apertures, reassigning BARs if necessary.
Windows does similar reassignment.
Before this patch, if we could not move a BAR into an aperture, we left
the resource unassigned, i.e., at address zero. Windows leaves such BARs
at the original BIOS addresses, and this patch makes Linux do the same.
This is a bit ugly because we disable the resource long before we try to
reassign it, so we have to keep track of the BIOS BAR address somewhere.
For lack of a better place, I put it in the struct pci_dev.
I think it would be cleaner to attempt the assignment immediately when the
claim fails, so we could easily remember the original address. But we
currently claim motherboard resources in the middle, after attempting to
claim PCI resources and before assigning new PCI resources, and changing
that is a fairly big job.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16263
Reported-by: Andrew <nitr0@seti.kr.ua>
Tested-by: Andrew <nitr0@seti.kr.ua>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
tracing: Add alignment to syscall metadata declarations
perf: Sync callchains with period based hits
perf: Resurrect flat callchains
perf: Version String fix, for fallback if not from git
perf: Version String fix, using kernel version
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: w90p910_ts - fix call to setup_timer()
Input: synaptics - fix wrong dimensions check
Input: i8042 - mark stubs in i8042.h "static inline"
OCFS2 uses t_commit trigger to compute and store checksum of the just
committed blocks. When a buffer has b_frozen_data, checksum is computed
for it instead of b_data but this can result in an old checksum being
written to the filesystem in the following scenario:
1) transaction1 is opened
2) handle1 is opened
3) journal_access(handle1, bh)
- This sets jh->b_transaction to transaction1
4) modify(bh)
5) journal_dirty(handle1, bh)
6) handle1 is closed
7) start committing transaction1, opening transaction2
8) handle2 is opened
9) journal_access(handle2, bh)
- This copies off b_frozen_data to make it safe for transaction1 to commit.
jh->b_next_transaction is set to transaction2.
10) jbd2_journal_write_metadata() checksums b_frozen_data
11) the journal correctly writes b_frozen_data to the disk journal
12) handle2 is closed
- There was no dirty call for the bh on handle2, so it is never queued for
any more journal operation
13) Checkpointing finally happens, and it just spools the bh via normal buffer
writeback. This will write b_data, which was never triggered on and thus
contains a wrong (old) checksum.
This patch fixes the problem by calling the trigger at the moment data is
frozen for journal commit - i.e., either when b_frozen_data is created by
do_get_write_access or just before we write a buffer to the log if
b_frozen_data does not exist. We also rename the trigger to t_frozen as
that better describes when it is called.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
