commit 26e8220adb0aec43b7acafa0f1431760eee28522 upstream.
Apparently the same card model has two IDs, so this patch
complements the commit 39aced68d664291db3324d0fcf0985ab5626aac2
adding the missing one.
Signed-off-by: Flavio Leitner <fbl@redhat.com>
commit cee58483cf56e0ba355fdd97ff5e8925329aa936 upstream
Andreas Bombe reported that the added ktime_t overflow checking added to
timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of
timekeeping inputs") was causing problems with X.org because it caused
timeouts larger then KTIME_T to be invalid.
Previously, these large timeouts would be clamped to KTIME_MAX and would
never expire, which is valid.
This patch splits the ktime_t overflow checking into a new
timespec_valid_strict function, and converts the timekeeping codes
internal checking to use this more strict function.
Reported-and-tested-by: Andreas Bombe <aeb@debian.org>
Cc: Zhouping Liu <zliu@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 4e8b14526ca7fb046a81c94002c1c43b6fdf0e9b upstream
Unexpected behavior could occur if the time is set to a value large
enough to overflow a 64bit ktime_t (which is something larger then the
year 2262).
Also unexpected behavior could occur if large negative offsets are
injected via adjtimex.
So this patch improves the sanity check timekeeping inputs by
improving the timespec_valid() check, and then makes better use of
timespec_valid() to make sure we don't set the time to an invalid
negative value or one that overflows ktime_t.
Note: This does not protect from setting the time close to overflowing
ktime_t and then letting natural accumulation cause the overflow.
Reported-by: CAI Qian <caiqian@redhat.com>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Link: http://lkml.kernel.org/r/1344454580-17031-1-git-send-email-john.stultz@linaro.org
commit 8323f26ce3425460769605a6aece7a174edaa7d1 upstream.
Stefan reported a crash on a kernel before a3e5d1091c1 ("sched:
Don't call task_group() too many times in set_task_rq()"), he
found the reason to be that the multiple task_group()
invocations in set_task_rq() returned different values.
Looking at all that I found a lack of serialization and plain
wrong comments.
The below tries to fix it using an extra pointer which is
updated under the appropriate scheduler locks. Its not pretty,
but I can't really see another way given how all the cgroup
stuff works.
Reported-and-tested-by: Stefan Bader <stefan.bader@canonical.com>
Link: http://lkml.kernel.org/r/1340364965.18025.71.camel@twins
commit 0bce9c46bf3b15f485d82d7e81dabed6ebcc24b1 upstream.
ARM recently moved to asm-generic/mutex-xchg.h for its mutex
implementation after the previous implementation was found to be missing
some crucial memory barriers. However, this has revealed some problems
running hackbench on SMP platforms due to the way in which the
MUTEX_SPIN_ON_OWNER code operates.
The symptoms are that a bunch of hackbench tasks are left waiting on an
unlocked mutex and therefore never get woken up to claim it. This boils
down to the following sequence of events:
Task A Task B Task C Lock value
0 1
1 lock() 0
2 lock() 0
3 spin(A) 0
4 unlock() 1
5 lock() 0
6 cmpxchg(1,0) 0
7 contended() -1
8 lock() 0
9 spin(C) 0
10 unlock() 1
11 cmpxchg(1,0) 0
12 unlock() 1
At this point, the lock is unlocked, but Task B is in an uninterruptible
sleep with nobody to wake it up.
This patch fixes the problem by ensuring we put the lock into the
contended state if we fail to acquire it on the fastpath, ensuring that
any blocked waiters are woken up when the mutex is released.
Cc: Chris Mason <chris.mason@fusionio.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Link: http://lkml.kernel.org/n/tip-6e9lrw2avczr0617fzl5vqb8@git.kernel.org
commit c3f52af3e03013db5237e339c817beaae5ec9e3a upstream.
When the NFS_COOKIEVERF helper macro was converted into a static
inline function in commit 99fadcd764 (nfs: convert NFS_*(inode)
helpers to static inline), we broke the initialisation of the
readdir cookies, since that depended on doing a memset with an
argument of 'sizeof(NFS_COOKIEVERF(inode))' which therefore
changed from sizeof(be32 cookieverf[2]) to sizeof(be32 *).
At this point, NFS_COOKIEVERF seems to be more of an obfuscation
than a helper, so the best thing would be to just get rid of it.
Also see: https://bugzilla.kernel.org/show_bug.cgi?id=46881
Reported-by: Andi Kleen <andi@firstfloor.org>
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 85f2a2ef1d0ab99523e0b947a2b723f5650ed6aa upstream.
When allocating memory fails, page is NULL. page_to_pfn() will
cause the kernel panicked if we don't use sparsemem vmemmap.
Link: http://lkml.kernel.org/r/505AB1FF.8020104@cn.fujitsu.com
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
commit 05cf96398e1b6502f9e191291b715c7463c9d5dd upstream.
I found following definition in include/linux/memory.h, in my IA64
platform, SECTION_SIZE_BITS is equal to 32, and MIN_MEMORY_BLOCK_SIZE
will be 0.
#define MIN_MEMORY_BLOCK_SIZE (1 << SECTION_SIZE_BITS)
Because MIN_MEMORY_BLOCK_SIZE is int type and length of 32bits,
so MIN_MEMORY_BLOCK_SIZE(1 << 32) will will equal to 0.
Actually when SECTION_SIZE_BITS >= 31, MIN_MEMORY_BLOCK_SIZE will be wrong.
This will cause wrong system memory infomation in sysfs.
I think it should be:
#define MIN_MEMORY_BLOCK_SIZE (1UL << SECTION_SIZE_BITS)
And "echo offline > memory0/state" will cause following call trace:
kernel BUG at mm/memory_hotplug.c:885!
sh[6455]: bugcheck! 0 [1]
Pid: 6455, CPU 0, comm: sh
psr : 0000101008526030 ifs : 8000000000000fa4 ip : [<a0000001008c40f0>] Not tainted (3.6.0-rc1)
ip is at offline_pages+0x210/0xee0
Call Trace:
show_stack+0x80/0xa0
show_regs+0x640/0x920
die+0x190/0x2c0
die_if_kernel+0x50/0x80
ia64_bad_break+0x3d0/0x6e0
ia64_native_leave_kernel+0x0/0x270
alloc_pages_current+0x180/0x2a0
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 60e233a56609fd963c59e99bd75c663d63fa91b6 upstream.
Fengguang Wu <fengguang.wu@intel.com> writes:
> After the __devinit* removal series, I can still get kernel panic in
> show_uevent(). So there are more sources of bug..
> Debug patch:
> @@ -343,8 +343,11 @@ static ssize_t show_uevent(struct device
> goto out;
> /* copy keys to file */
> - for (i = 0; i < env->envp_idx; i++)
> + dev_err(dev, "uevent %d env[%d]: %s/.../%s\n", env->buflen, env->envp_idx, top_kobj->name, dev->kobj.name);
> + for (i = 0; i < env->envp_idx; i++) {
> + printk(KERN_ERR "uevent %d env[%d]: %s\n", (int)count, i, env->envp[i]);
> count += sprintf(&buf[count], "%s\n", env->envp[i]);
> Oops message, the env[] is again not properly initilized:
> [ 44.068623] input input0: uevent 61 env[805306368]: input0/.../input0
> [ 44.069552] uevent 0 env[0]: (null)
This is a completely different CONFIG_HOTPLUG problem, only
demonstrating another reason why CONFIG_HOTPLUG should go away. I had a
hard time trying to disable it anyway ;-)
The problem this time is lots of code assuming that a call to
add_uevent_var() will guarantee that env->buflen > 0. This is not true
if CONFIG_HOTPLUG is unset. So things like this end up overwriting
env->envp_idx because the array index is -1:
if (add_uevent_var(env, "MODALIAS="))
return -ENOMEM;
len = input_print_modalias(&env->buf[env->buflen - 1],
sizeof(env->buf) - env->buflen,
dev, 0);
Don't know what the best action is, given that there seem to be a *lot*
of this around the kernel. This patch "fixes" the problem for me, but I
don't know if it can be considered an appropriate fix.
[ It is the correct fix for now, for 3.7 forcing CONFIG_HOTPLUG to
always be on is the longterm fix, but it's too late for 3.6 and older
kernels to resolve this that way - gregkh ]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit a6fa941d94b411bbd2b6421ffbde6db3c93e65ab upstream.
Don't mess with file refcounts (or keep a reference to file, for
that matter) in perf_event. Use explicit refcount of its own
instead. Deal with the race between the final reference to event
going away and new children getting created for it by use of
atomic_long_inc_not_zero() in inherit_event(); just have the
latter free what it had allocated and return NULL, that works
out just fine (children of siblings of something doomed are
created as singletons, same as if the child of leader had been
created and immediately killed).
Link: http://lkml.kernel.org/r/20120820135925.GG23464@ZenIV.linux.org.uk
commit b161dfa6937ae46d50adce8a7c6b12233e96e7bd upstream.
IBM reported a soft lockup after applying the fix for the rename_lock
deadlock. Commit c83ce989cb5f ("VFS: Fix the nfs sillyrename regression
in kernel 2.6.38") was found to be the culprit.
The nfs sillyrename fix used DCACHE_DISCONNECTED to indicate that the
dentry was killed. This flag can be set on non-killed dentries too,
which results in infinite retries when trying to traverse the dentry
tree.
This patch introduces a separate flag: DCACHE_DENTRY_KILLED, which is
only set in d_kill() and makes try_to_ascend() test only this flag.
IBM reported successful test results with this patch.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
[ Upstream commit 1485348d2424e1131ea42efc033cbd9366462b01 ]
Cache the device gso_max_segs in sock::sk_gso_max_segs and use it to
limit the size of TSO skbs. This avoids the need to fall back to
software GSO for local TCP senders.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
[ Upstream commit 30b678d844af3305cda5953467005cebb5d7b687 ]
A peer (or local user) may cause TCP to use a nominal MSS of as little
as 88 (actual MSS of 76 with timestamps). Given that we have a
sufficiently prodigious local sender and the peer ACKs quickly enough,
it is nevertheless possible to grow the window for such a connection
to the point that we will try to send just under 64K at once. This
results in a single skb that expands to 861 segments.
In some drivers with TSO support, such an skb will require hundreds of
DMA descriptors; a substantial fraction of a TX ring or even more than
a full ring. The TX queue selected for the skb may stall and trigger
the TX watchdog repeatedly (since the problem skb will be retried
after the TX reset). This particularly affects sfc, for which the
issue is designated as CVE-2012-3412.
Therefore:
1. Add the field net_device::gso_max_segs holding the device-specific
limit.
2. In netif_skb_features(), if the number of segments is too high then
mask out GSO features to force fall back to software GSO.
commit d81a5d1956731c453b85c141458d4ff5d6cc5366 upstream.
A lot of Broadcom Bluetooth devices provides vendor specific interface
class and we are getting flooded by patches adding new device support.
This change will help us enable support for any other Broadcom with vendor
specific device that arrives in the future.
Only the product id changes for those devices, so this macro would be
perfect for us:
{ USB_VENDOR_AND_INTERFACE_INFO(0x0a5c, 0xff, 0x01, 0x01) }
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Acked-by: Henrik Rydberg <rydberg@bitmath.se>
commit 59ee93a528b94ef4e81a08db252b0326feff171f upstream.
The irq_to_gpio function was removed from the pxa platform
in linux-3.2, and this driver has been broken since.
There is actually no in-tree user of this driver that adds
this platform device, but the driver can and does get enabled
on some platforms.
Without this patch, building ezx_defconfig results in:
drivers/mfd/ezx-pcap.c: In function 'pcap_isr_work':
drivers/mfd/ezx-pcap.c:205:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration]
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream.
With the new interrupt sampling system, we are no longer using the
timer_rand_state structure in the irq descriptor, so we can stop
initializing it now.
[ Merged in fixes from Sedat to find some last missing references to
rand_initialize_irq() ]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 00ce1db1a634746040ace24c09a4e3a7949a3145 upstream.
commit c2557a303ab6712bb6e09447df828c557c710ac9 upstream.
Create a new function, get_random_bytes_arch() which will use the
architecture-specific hardware random number generator if it is
present. Change get_random_bytes() to not use the HW RNG, even if it
is avaiable.
The reason for this is that the hw random number generator is fast (if
it is present), but it requires that we trust the hardware
manufacturer to have not put in a back door. (For example, an
increasing counter encrypted by an AES key known to the NSA.)
It's unlikely that Intel (for example) was paid off by the US
Government to do this, but it's impossible for them to prove otherwise
--- especially since Bull Mountain is documented to use AES as a
whitener. Hence, the output of an evil, trojan-horse version of
RDRAND is statistically indistinguishable from an RDRAND implemented
to the specifications claimed by Intel. Short of using a tunnelling
electronic microscope to reverse engineer an Ivy Bridge chip and
disassembling and analyzing the CPU microcode, there's no way for us
to tell for sure.
Since users of get_random_bytes() in the Linux kernel need to be able
to support hardware systems where the HW RNG is not present, most
time-sensitive users of this interface have already created their own
cryptographic RNG interface which uses get_random_bytes() as a seed.
So it's much better to use the HW RNG to improve the existing random
number generator, by mixing in any entropy returned by the HW RNG into
/dev/random's entropy pool, but to always _use_ /dev/random's entropy
pool.
This way we get almost of the benefits of the HW RNG without any
potential liabilities. The only benefits we forgo is the
speed/performance enhancements --- and generic kernel code can't
depend on depend on get_random_bytes() having the speed of a HW RNG
anyway.
For those places that really want access to the arch-specific HW RNG,
if it is available, we provide get_random_bytes_arch().
commit a2080a67abe9e314f9e9c2cc3a4a176e8a8f8793 upstream.
Add a new interface, add_device_randomness() for adding data to the
random pool that is likely to differ between two devices (or possibly
even per boot). This would be things like MAC addresses or serial
numbers, or the read-out of the RTC. This does *not* add any actual
entropy to the pool, but it initializes the pool to different values
for devices that might otherwise be identical and have very little
entropy available to them (particularly common in the embedded world).
[ Modified by tytso to mix in a timestamp, since there may be some
variability caused by the time needed to detect/configure the hardware
in question. ]
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream.
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>
commit 63d77173266c1791f1553e9e8ccea65dc87c4485 upstream.
Add support for architecture-specific hooks into the kernel-directed
random number generator interfaces. This patchset does not use the
architecture random number generator interfaces for the
userspace-directed interfaces (/dev/random and /dev/urandom), thus
eliminating the need to distinguish between them based on a pool
pointer.
Changes in version 3:
- Moved the hooks from extract_entropy() to get_random_bytes().
- Changes the hooks to inlines.
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "Theodore Ts'o" <tytso@mit.edu>
commit 6575820221f7a4dd6eadecf7bf83cdd154335eda upstream.
Currently, all workqueue cpu hotplug operations run off
CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to
ensure that workqueue is up and running while bringing up a CPU before
other notifiers try to use workqueue on the CPU.
Per-cpu workqueues are supposed to remain working and bound to the CPU
for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even
with workqueue offlining running with higher priority because
workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which
runs the per-cpu workqueue without concurrency management without
explicitly detaching the existing workers.
However, if the trustee needs to create new workers, it creates
unbound workers which may wander off to other CPUs while
CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU
down is cancelled, the per-CPU workqueue may end up with workers which
aren't bound to the CPU.
While reliably reproducible with a convoluted artificial test-case
involving scheduling and flushing CPU burning work items from CPU down
notifiers, this isn't very likely to happen in the wild, and, even
when it happens, the effects are likely to be hidden by the following
successful CPU down.
Fix it by using different priorities for up and down notifiers - high
priority for up operations and low priority for down operations.
Workqueue cpu hotplug operations will soon go through further cleanup.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
commit cc9a6c8776615f9c194ccf0b63a0aa5628235545 upstream.
Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely
expensive and severely impacted page allocator performance. This
is part of a series of patches that reduce page allocator overhead.
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when
changing cpuset's mems") wins a super prize for the largest number of
memory barriers entered into fast paths for one commit.
[get|put]_mems_allowed is incredibly heavy with pairs of full memory
barriers inserted into a number of hot paths. This was detected while
investigating at large page allocator slowdown introduced some time
after 2.6.32. The largest portion of this overhead was shown by
oprofile to be at an mfence introduced by this commit into the page
allocator hot path.
For extra style points, the commit introduced the use of yield() in an
implementation of what looks like a spinning mutex.
This patch replaces the full memory barriers on both read and write
sides with a sequence counter with just read barriers on the fast path
side. This is much cheaper on some architectures, including x86. The
main bulk of the patch is the retry logic if the nodemask changes in a
manner that can cause a false failure.
While updating the nodemask, a check is made to see if a false failure
is a risk. If it is, the sequence number gets bumped and parallel
allocators will briefly stall while the nodemask update takes place.
In a page fault test microbenchmark, oprofile samples from
__alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The
actual results were
3.3.0-rc3 3.3.0-rc3
rc3-vanilla nobarrier-v2r1
Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%)
Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%)
Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%)
Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%)
Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%)
Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%)
Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%)
Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%)
Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%)
Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%)
Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%)
Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%)
Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%)
Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%)
Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%)
MMTests Statistics: duration
Sys Time Running Test (seconds) 135.68 132.17
User+Sys Time Running Test (seconds) 164.2 160.13
Total Elapsed Time (seconds) 123.46 120.87
The overall improvement is small but the System CPU time is much
improved and roughly in correlation to what oprofile reported (these
performance figures are without profiling so skew is expected). The
actual number of page faults is noticeably improved.
For benchmarks like kernel builds, the overall benefit is marginal but
the system CPU time is slightly reduced.
To test the actual bug the commit fixed I opened two terminals. The
first ran within a cpuset and continually ran a small program that
faulted 100M of anonymous data. In a second window, the nodemask of the
cpuset was continually randomised in a loop.
Without the commit, the program would fail every so often (usually
within 10 seconds) and obviously with the commit everything worked fine.
With this patch applied, it also worked fine so the fix should be
functionally equivalent.
Cc: Miao Xie <miaox@cn.fujitsu.com>
Cc: Christoph Lameter <cl@linux.com>
commit a6bc32b899223a877f595ef9ddc1e89ead5072b8 upstream.
Stable note: Not tracked in Buzilla. This was part of a series that
reduced interactivity stalls experienced when THP was enabled.
These stalls were particularly noticable when copying data
to a USB stick but the experiences for users varied a lot.
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT
mode that avoids writing back pages to backing storage. Async compaction
maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT.
For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is
used.
This avoids sync compaction stalling for an excessive length of time,
particularly when copying files to a USB stick where there might be a
large number of dirty pages backed by a filesystem that does not support
->writepages.
[aarcange@redhat.com: This patch is heavily based on Andrea's work]
[akpm@linux-foundation.org: fix fs/nfs/write.c build]
[akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build]
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Andy Isaacson <adi@hexapodia.org>
Cc: Nai Xia <nai.xia@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
commit c82449352854ff09e43062246af86bdeb628f0c3 upstream.
Stable note: Not tracked in Bugzilla. A fix aimed at preserving page aging
information by reducing LRU list churning had the side-effect of
reducing THP allocation success rates. This was part of a series
to restore the success rates while preserving the reclaim fix.
Commit 39deaf85 ("mm: compaction: make isolate_lru_page() filter-aware")
noted that compaction does not migrate dirty or writeback pages and that
is was meaningless to pick the page and re-add it to the LRU list. This
had to be partially reverted because some dirty pages can be migrated by
compaction without blocking.
This patch updates "mm: compaction: make isolate_lru_page" by skipping
over pages that migration has no possibility of migrating to minimise LRU
disruption.
Reviewed-by: Rik van Riel<riel@redhat.com>
within ->migratepage
commit b969c4ab9f182a6e1b2a0848be349f99714947b0 upstream.
aging information by reducing LRU list churning had the side-effect
of reducing THP allocation success rates. This was part of a series
Asynchronous compaction is used when allocating transparent hugepages to
avoid blocking for long periods of time. Due to reports of stalling,
there was a debate on disabling synchronous compaction but this severely
impacted allocation success rates. Part of the reason was that many dirty
pages are skipped in asynchronous compaction by the following check;
if (PageDirty(page) && !sync &&
mapping->a_ops->migratepage != migrate_page)
rc = -EBUSY;
This skips over all mapping aops using buffer_migrate_page() even though
it is possible to migrate some of these pages without blocking. This
patch updates the ->migratepage callback with a "sync" parameter. It is
the responsibility of the callback to fail gracefully if migration would
block.
commit f80c0673610e36ae29d63e3297175e22f70dde5f upstream.
Stable note: Not tracked in Bugzilla. THP and compaction disrupt the LRU list
leading to poor reclaim decisions which has a variable
performance impact.
In __zone_reclaim case, we don't want to shrink mapped page. Nonetheless,
we have isolated mapped page and re-add it into LRU's head. It's
unnecessary CPU overhead and makes LRU churning.
Of course, when we isolate the page, the page might be mapped but when we
try to migrate the page, the page would be not mapped. So it could be
migrated. But race is rare and although it happens, it's no big deal.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 39deaf8585152f1a35c1676d3d7dc6ae0fb65967 upstream.
list leading to poor reclaim decisions which has a variable
performance impact.
In async mode, compaction doesn't migrate dirty or writeback pages. So,
it's meaningless to pick the page and re-add it to lru list.
Of course, when we isolate the page in compaction, the page might be dirty
or writeback but when we try to migrate the page, the page would be not
dirty, writeback. So it could be migrated. But it's very unlikely as
isolate and migration cycle is much faster than writeout.
So, this patch helps cpu overhead and prevent unnecessary LRU churning.
commit 4356f21d09283dc6d39a6f7287a65ddab61e2808 upstream.
Stable note: Not tracked in Bugzilla. This patch makes later patches
easier to apply but has no other impact.
Change ISOLATE_XXX macro with bitwise isolate_mode_t type. Normally,
macro isn't recommended as it's type-unsafe and making debugging harder as
symbol cannot be passed throught to the debugger.
Quote from Johannes
" Hmm, it would probably be cleaner to fully convert the isolation mode
into independent flags. INACTIVE, ACTIVE, BOTH is currently a
tri-state among flags, which is a bit ugly."
This patch moves isolate mode from swap.h to mmzone.h by memcontrol.h
commit 095760730c1047c69159ce88021a7fa3833502c8 upstream.
Stable note: This patch makes later patches easier to apply but otherwise
has little to justify it. It is a diagnostic patch that was part
of a series addressing excessive slab shrinking after GFP_NOFS
failures. There is detailed information on the series' motivation
at https://lkml.org/lkml/2011/6/2/42 .
It is impossible to understand what the shrinkers are actually doing
without instrumenting the code, so add a some tracepoints to allow
insight to be gained.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
This is a backport of f6c06abfb3972ad4914cef57d8348fcb2932bc3b
To finally fix the infamous leap second issue and other race windows
caused by functions which change the offsets between the various time
bases (CLOCK_MONOTONIC, CLOCK_REALTIME and CLOCK_BOOTTIME) we need a
function which atomically gets the current monotonic time and updates
the offsets of CLOCK_REALTIME and CLOCK_BOOTTIME with minimalistic
overhead. The previous patch which provides ktime_t offsets allows us
to make this function almost as cheap as ktime_get() which is going to
be replaced in hrtimer_interrupt().
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/1341960205-56738-7-git-send-email-johnstul@us.ibm.com
This is a backport of f55a6faa384304c89cfef162768e88374d3312cb
clock_was_set() cannot be called from hard interrupt context because
it calls on_each_cpu().
For fixing the widely reported leap seconds issue it is necessary to
call it from hard interrupt context, i.e. the timer tick code, which
does the timekeeping updates.
Provide a new function which denotes it in the hrtimer cpu base
structure of the cpu on which it is called and raise the hrtimer
softirq. We then execute the clock_was_set() notificiation from
softirq context in run_hrtimer_softirq(). The hrtimer softirq is
rarely used, so polling the flag there is not a performance issue.
[ tglx: Made it depend on CONFIG_HIGH_RES_TIMERS. We really should get
rid of all this ifdeffery ASAP ]
Reported-by: Jan Engelhardt <jengelh@inai.de>
Link: http://lkml.kernel.org/r/1341960205-56738-2-git-send-email-johnstul@us.ibm.com
This is a backport of 6b43ae8a619d17c4935c3320d2ef9e92bdeed05d
This should have been backported when it was commited, but I
mistook the problem as requiring the ntp_lock changes
that landed in 3.4 in order for it to occur.
Unfortunately the same issue can happen (with only one cpu)
as follows:
do_adjtimex()
write_seqlock_irq(&xtime_lock);
process_adjtimex_modes()
process_adj_status()
ntp_start_leap_timer()
hrtimer_start()
hrtimer_reprogram()
tick_program_event()
clockevents_program_event()
ktime_get()
seq = req_seqbegin(xtime_lock); [DEADLOCK]
This deadlock will no always occur, as it requires the
leap_timer to force a hrtimer_reprogram which only happens
if its set and there's no sooner timer to expire.
NOTE: This patch, being faithful to the original commit,
introduces a bug (we don't update wall_to_monotonic),
which will be resovled by backporting a following fix.
Original commit message below:
Since commit 7dffa3c673fbcf835cd7be80bb4aec8ad3f51168 the ntp
subsystem has used an hrtimer for triggering the leapsecond
adjustment. However, this can cause a potential livelock.
Thomas diagnosed this as the following pattern:
CPU 0 CPU 1
do_adjtimex()
spin_lock_irq(&ntp_lock);
process_adjtimex_modes(); timer_interrupt()
process_adj_status(); do_timer()
ntp_start_leap_timer(); write_lock(&xtime_lock);
hrtimer_start(); update_wall_time();
hrtimer_reprogram(); ntp_tick_length()
tick_program_event() spin_lock(&ntp_lock);
ktime_get()
This patch tries to avoid the problem by reverting back to not using
an hrtimer to inject leapseconds, and instead we handle the leapsecond
processing in the second_overflow() function.
The downside to this change is that on systems that support highres
timers, the leap second processing will occur on a HZ tick boundary,
(ie: ~1-10ms, depending on HZ) after the leap second instead of
possibly sooner (~34us in my tests w/ x86_64 lapic).
This patch applies on top of tip/timers/core.
CC: Sasha Levin <levinsasha928@gmail.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Diagnoised-by: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Sasha Levin <levinsasha928@gmail.com>
commit d8adde17e5f858427504725218c56aef90e90fc7 upstream.
kswapd_stop() is called to destroy the kswapd work thread when all memory
of a NUMA node has been offlined. But kswapd_stop() only terminates the
work thread without resetting NODE_DATA(nid)->kswapd to NULL. The stale
pointer will prevent kswapd_run() from creating a new work thread when
adding memory to the memory-less NUMA node again. Eventually the stale
pointer may cause invalid memory access.
An example stack dump as below. It's reproduced with 2.6.32, but latest
kernel has the same issue.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81051a94>] exit_creds+0x12/0x78
PGD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/system/memory/memory391/state
CPU 11
Modules linked in: cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq microcode fuse loop dm_mod tpm_tis rtc_cmos i2c_i801 rtc_core tpm serio_raw pcspkr sg tpm_bios igb i2c_core iTCO_wdt rtc_lib mptctl iTCO_vendor_support button dca bnx2 usbhid hid uhci_hcd ehci_hcd usbcore sd_mod crc_t10dif edd ext3 mbcache jbd fan ide_pci_generic ide_core ata_generic ata_piix libata thermal processor thermal_sys hwmon mptsas mptscsih mptbase scsi_transport_sas scsi_mod
Pid: 7949, comm: sh Not tainted 2.6.32.12-qiuxishi-5-default #92 Tecal RH2285
RIP: 0010:exit_creds+0x12/0x78
RSP: 0018:ffff8806044f1d78 EFLAGS: 00010202
RAX: 0000000000000000 RBX: ffff880604f22140 RCX: 0000000000019502
RDX: 0000000000000000 RSI: 0000000000000202 RDI: 0000000000000000
RBP: ffff880604f22150 R08: 0000000000000000 R09: ffffffff81a4dc10
R10: 00000000000032a0 R11: ffff880006202500 R12: 0000000000000000
R13: 0000000000c40000 R14: 0000000000008000 R15: 0000000000000001
FS: 00007fbc03d066f0(0000) GS:ffff8800282e0000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000000 CR3: 000000060f029000 CR4: 00000000000006e0
Process sh (pid: 7949, threadinfo ffff8806044f0000, task ffff880603d7c600)
Stack:
ffff880604f22140 ffffffff8103aac5 ffff880604f22140 ffffffff8104d21e
ffff880006202500 0000000000008000 0000000000c38000 ffffffff810bd5b1
0000000000000000 ffff880603d7c600 00000000ffffdd29 0000000000000003
Call Trace:
__put_task_struct+0x5d/0x97
kthread_stop+0x50/0x58
offline_pages+0x324/0x3da
memory_block_change_state+0x179/0x1db
store_mem_state+0x9e/0xbb
sysfs_write_file+0xd0/0x107
vfs_write+0xad/0x169
sys_write+0x45/0x6e
system_call_fastpath+0x16/0x1b
Code: ff 4d 00 0f 94 c0 84 c0 74 08 48 89 ef e8 1f fd ff ff 5b 5d 31 c0 41 5c c3 53 48 8b 87 20 06 00 00 48 89 fb 48 8b bf 18 06 00 00 <8b> 00 48 c7 83 18 06 00 00 00 00 00 00 f0 ff 0f 0f 94 c0 84 c0
RIP exit_creds+0x12/0x78
RSP <ffff8806044f1d78>
[akpm@linux-foundation.org: add pglist_data.kswapd locking comments]
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
commit dbf0e4c7257f8d684ec1a3c919853464293de66e upstream.
Quite a few ASUS computers experience a nasty problem, related to the
EHCI controllers, when going into system suspend. It was observed
that the problem didn't occur if the controllers were not put into the
D3 power state before starting the suspend, and commit
151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during
suspend on ASUS computers) was created to do this.
It turned out this approach messed up other computers that didn't have
the problem -- it prevented USB wakeup from working. Consequently
commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b (USB: add
NO_D3_DURING_SLEEP flag and revert 151b61284776be2) was merged; it
reverted the earlier commit and added a whitelist of known good board
names.
Now we know the actual cause of the problem. Thanks to AceLan Kao for
tracking it down.
According to him, an engineer at ASUS explained that some of their
BIOSes contain a bug that was added in an attempt to work around a
problem in early versions of Windows. When the computer goes into S3
suspend, the BIOS tries to verify that the EHCI controllers were first
quiesced by the OS. Nothing's wrong with this, but the BIOS does it
by checking that the PCI COMMAND registers contain 0 without checking
the controllers' power state. If the register isn't 0, the BIOS
assumes the controller needs to be quiesced and tries to do so. This
involves making various MMIO accesses to the controller, which don't
work very well if the controller is already in D3. The end result is
a system hang or memory corruption.
Since the value in the PCI COMMAND register doesn't matter once the
controller has been suspended, and since the value will be restored
anyway when the controller is resumed, we can work around the BIOS bug
simply by setting the register to 0 during system suspend. This patch
(as1590) does so and also reverts the second commit mentioned above,
which is now unnecessary.
In theory we could do this for every PCI device. However to avoid
introducing new problems, the patch restricts itself to EHCI host
controllers.
Finally the affected systems can suspend with USB wakeup working
properly.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=37632
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42728
Based-on-patch-by: AceLan Kao <acelan.kao@canonical.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Dâniel Fraga <fragabr@gmail.com>
Tested-by: Javier Marcet <jmarcet@gmail.com>
Tested-by: Andrey Rahmatullin <wrar@wrar.name>
Tested-by: Oleksij Rempel <bug-track@fisher-privat.net>
Tested-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
[ Upstream commit 5ee31c6898ea5537fcea160999d60dc63bc0c305 ]
In the transmit path of the bonding driver, skb->cb is used to
stash the skb->queue_mapping so that the bonding device can set its
own queue mapping. This value becomes corrupted since the skb->cb is
also used in __dev_xmit_skb.
When transmitting through bonding driver, bond_select_queue is
called from dev_queue_xmit. In bond_select_queue the original
skb->queue_mapping is copied into skb->cb (via bond_queue_mapping)
and skb->queue_mapping is overwritten with the bond driver queue.
Subsequently in dev_queue_xmit, __dev_xmit_skb is called which writes
the packet length into skb->cb, thereby overwriting the stashed
queue mappping. In bond_dev_queue_xmit (called from hard_start_xmit),
the queue mapping for the skb is set to the stashed value which is now
the skb length and hence is an invalid queue for the slave device.
If we want to save skb->queue_mapping into skb->cb[], best place is to
add a field in struct qdisc_skb_cb, to make sure it wont conflict with
other layers (eg : Qdiscc, Infiniband...)
This patchs also makes sure (struct qdisc_skb_cb)->data is aligned on 8
bytes :
netem qdisc for example assumes it can store an u64 in it, without
misalignment penalty.
Note : we only have 20 bytes left in (struct qdisc_skb_cb)->data[].
The largest user is CHOKe and it fills it.
Based on a previous patch from Tom Herbert.
Reported-by: Tom Herbert <therbert@google.com>
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Roland Dreier <roland@kernel.org>
[ Upstream commit 20e2a86485967c385d7c7befc1646e4d1d39362e ]
When NetLabel is not enabled, e.g. CONFIG_NETLABEL=n, and the system
receives a CIPSO tagged packet it is dropped (cipso_v4_validate()
returns non-zero). In most cases this is the correct and desired
behavior, however, in the case where we are simply forwarding the
traffic, e.g. acting as a network bridge, this becomes a problem.
This patch fixes the forwarding problem by providing the basic CIPSO
validation code directly in ip_options_compile() without the need for
the NetLabel or CIPSO code. The new validation code can not perform
any of the CIPSO option label/value verification that
cipso_v4_validate() does, but it can verify the basic CIPSO option
format.
The behavior when NetLabel is enabled is unchanged.
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b upstream.
This patch (as1558) fixes a problem affecting several ASUS computers:
The machine crashes or corrupts memory when going into suspend if the
ehci-hcd driver is bound to any controllers. Users have been forced
to unbind or unload ehci-hcd before putting their systems to sleep.
After extensive testing, it was determined that the machines don't
like going into suspend when any EHCI controllers are in the PCI D3
power state. Presumably this is a firmware bug, but there's nothing
we can do about it except to avoid putting the controllers in D3
during system sleep.
The patch adds a new flag to indicate whether the problem is present,
and avoids changing the controller's power state if the flag is set.
Runtime suspend is unaffected; this matters only for system suspend.
However as a side effect, the controller will not respond to remote
wakeup requests while the system is asleep. Hence USB wakeup is not
functional -- but of course, this is already true in the current state
of affairs.
A similar patch has already been applied as commit
suspend on ASUS computers). The patch supersedes that one and reverts
it. There are two differences:
The old patch added the flag at the USB level; this patch
adds it at the PCI level.
The old patch applied to all chipsets with the same vendor,
subsystem vendor, and product IDs; this patch makes an
exception for a known-good system (based on DMI information).
Tested-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl>
commit a2bef8ce826dd1e787fd8ad9b6e0566ba59dab43 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 617c8c11236716dcbda877e764b7bf37c6fd8063 ]
At the beginning of __skb_cow, headroom gets set to a minimum of
NET_SKB_PAD. This causes unnecessary reallocations if the buffer was not
cloned and the headroom is just below NET_SKB_PAD, but still more than the
amount requested by the caller.
This was showing up frequently in my tests on VLAN tx, where
vlan_insert_tag calls skb_cow_head(skb, VLAN_HLEN).
Locally generated packets should have enough headroom, and for forward
paths, we already have NET_SKB_PAD bytes of headroom, so we don't need to
add any extra space here.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
[ Upstream commit e0268868ba064980488fc8c194db3d8e9fb2959c ]
dst_check() will take care of SA (and obsolete field), hence
IPsec rekeying scenario is taken into account.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Vlad Yaseivch <vyasevich@gmail.com>
[ Upstream commit 59b9997baba5242997ddc7bd96b1391f5275a5a4 ]
This reverts commit 8a83a00b0735190384a348156837918271034144.
It causes regressions for S390 devices, because it does an
unconditional DST drop on SKBs for vlans and the QETH device
needs the neighbour entry hung off the DST for certain things
on transmit.
Arnd can't remember exactly why he even needed this change.
drivers/net/macvlan.c
net/8021q/vlan_dev.c
net/core/dev.c
[ Upstream commit 0c1833797a5a6ec23ea9261d979aa18078720b74 ]
Since commit ad0081e43a
"ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed"
the fragment of packets is incorrect.
because tunnel mode needs IPsec headers and trailer for all fragments,
while on transport mode it is sufficient to add the headers to the
first fragment and the trailer to the last.
so modify mtu and maxfraglen base on ipsec mode and if fragment is first
or last.
with my test,it work well(every fragment's size is the mtu)
and does not trigger slow fragment path.
Changes from v1:
though optimization, mtu_prev and maxfraglen_prev can be delete.
replace xfrm mode codes with dst_entry's new frag DST_XFRM_TUNNEL.
add fuction ip6_append_data_mtu to make codes clearer.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
commit 26c191788f18129af0eb32a358cdaea0c7479626 upstream.
When holding the mmap_sem for reading, pmd_offset_map_lock should only
run on a pmd_t that has been read atomically from the pmdp pointer,
otherwise we may read only half of it leading to this crash.
PID: 11679 TASK: f06e8000 CPU: 3 COMMAND: "do_race_2_panic"
#0 [f06a9dd8] crash_kexec at c049b5ec
#1 [f06a9e2c] oops_end at c083d1c2
#2 [f06a9e40] no_context at c0433ded
#3 [f06a9e64] bad_area_nosemaphore at c043401a
#4 [f06a9e6c] __do_page_fault at c0434493
#5 [f06a9eec] do_page_fault at c083eb45
#6 [f06a9f04] error_code (via page_fault) at c083c5d5
EAX: 01fb470c EBX: fff35000 ECX: 00000003 EDX: 00000100 EBP:
00000000
DS: 007b ESI: 9e201000 ES: 007b EDI: 01fb4700 GS: 00e0
CS: 0060 EIP: c083bc14 ERR: ffffffff EFLAGS: 00010246
#7 [f06a9f38] _spin_lock at c083bc14
#8 [f06a9f44] sys_mincore at c0507b7d
#9 [f06a9fb0] system_call at c083becd
start len
EAX: ffffffda EBX: 9e200000 ECX: 00001000 EDX: 6228537f
DS: 007b ESI: 00000000 ES: 007b EDI: 003d0f00
SS: 007b ESP: 62285354 EBP: 62285388 GS: 0033
CS: 0073 EIP: 00291416 ERR: 000000da EFLAGS: 00000286
This should be a longstanding bug affecting x86 32bit PAE without THP.
Only archs with 64bit large pmd_t and 32bit unsigned long should be
affected.
With THP enabled the barrier() in pmd_none_or_trans_huge_or_clear_bad()
would partly hide the bug when the pmd transition from none to stable,
by forcing a re-read of the *pmd in pmd_offset_map_lock, but when THP is
enabled a new set of problem arises by the fact could then transition
freely in any of the none, pmd_trans_huge or pmd_trans_stable states.
So making the barrier in pmd_none_or_trans_huge_or_clear_bad()
unconditional isn't good idea and it would be a flakey solution.
This should be fully fixed by introducing a pmd_read_atomic that reads
the pmd in order with THP disabled, or by reading the pmd atomically
with cmpxchg8b with THP enabled.
Luckily this new race condition only triggers in the places that must
already be covered by pmd_none_or_trans_huge_or_clear_bad() so the fix
is localized there but this bug is not related to THP.
NOTE: this can trigger on x86 32bit systems with PAE enabled with more
than 4G of ram, otherwise the high part of the pmd will never risk to be
truncated because it would be zero at all times, in turn so hiding the
SMP race.
This bug was discovered and fully debugged by Ulrich, quote:
pmd_none_or_trans_huge_or_clear_bad() loads the content of edx and
eax.
496 static inline int pmd_none_or_trans_huge_or_clear_bad(pmd_t
*pmd)
497 {
498 /* depend on compiler for an atomic pmd read */
499 pmd_t pmdval = *pmd;
// edi = pmd pointer
0xc0507a74 <sys_mincore+548>: mov 0x8(%esp),%edi
// edx = PTE page table high address
0xc0507a84 <sys_mincore+564>: mov 0x4(%edi),%edx
// eax = PTE page table low address
0xc0507a8e <sys_mincore+574>: mov (%edi),%eax
Please note that the PMD is not read atomically. These are two "mov"
instructions where the high order bits of the PMD entry are fetched
first. Hence, the above machine code is prone to the following race.
- The PMD entry {high|low} is 0x0000000000000000.
The "mov" at 0xc0507a84 loads 0x00000000 into edx.
- A page fault (on another CPU) sneaks in between the two "mov"
instructions and instantiates the PMD.
- The PMD entry {high|low} is now 0x00000003fda38067.
The "mov" at 0xc0507a8e loads 0xfda38067 into eax.
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
commit bbbc4c4d8c5face097d695f9bf3a39647ba6b7e7 upstream.
Commit 06e8935feb ("optimized SDIO IRQ handling for single irq")
introduced some spurious calls to SDIO function interrupt handlers,
such as when the SDIO IRQ thread is started, or the safety check
performed upon a system resume. Let's add a flag to perform the
optimization only when a real interrupt is signaled by the host
driver and we know there is no point confirming it.
Reported-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit 080399aaaf3531f5b8761ec0ac30ff98891e8686 upstream.
We have a bug report open where a squashfs image mounted on ppc64 would
exhibit errors due to trying to read beyond the end of the disk. It can
easily be reproduced by doing the following:
[root@ibm-p750e-02-lp3 ~]# ls -l install.img
-rw-r--r-- 1 root root 142032896 Apr 30 16:46 install.img
[root@ibm-p750e-02-lp3 ~]# mount -o loop ./install.img /mnt/test
[root@ibm-p750e-02-lp3 ~]# dd if=/dev/loop0 of=/dev/null
dd: reading `/dev/loop0': Input/output error
277376+0 records in
277376+0 records out
142016512 bytes (142 MB) copied, 0.9465 s, 150 MB/s
In dmesg, you'll find the following:
squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 43.106012] attempt to access beyond end of device
[ 43.106029] loop0: rw=0, want=277410, limit=277408
[ 43.106039] Buffer I/O error on device loop0, logical block 138704
[ 43.106053] attempt to access beyond end of device
[ 43.106057] loop0: rw=0, want=277412, limit=277408
[ 43.106061] Buffer I/O error on device loop0, logical block 138705
[ 43.106066] attempt to access beyond end of device
[ 43.106070] loop0: rw=0, want=277414, limit=277408
[ 43.106073] Buffer I/O error on device loop0, logical block 138706
[ 43.106078] attempt to access beyond end of device
[ 43.106081] loop0: rw=0, want=277416, limit=277408
[ 43.106085] Buffer I/O error on device loop0, logical block 138707
[ 43.106089] attempt to access beyond end of device
[ 43.106093] loop0: rw=0, want=277418, limit=277408
[ 43.106096] Buffer I/O error on device loop0, logical block 138708
[ 43.106101] attempt to access beyond end of device
[ 43.106104] loop0: rw=0, want=277420, limit=277408
[ 43.106108] Buffer I/O error on device loop0, logical block 138709
[ 43.106112] attempt to access beyond end of device
[ 43.106116] loop0: rw=0, want=277422, limit=277408
[ 43.106120] Buffer I/O error on device loop0, logical block 138710
[ 43.106124] attempt to access beyond end of device
[ 43.106128] loop0: rw=0, want=277424, limit=277408
[ 43.106131] Buffer I/O error on device loop0, logical block 138711
[ 43.106135] attempt to access beyond end of device
[ 43.106139] loop0: rw=0, want=277426, limit=277408
[ 43.106143] Buffer I/O error on device loop0, logical block 138712
[ 43.106147] attempt to access beyond end of device
[ 43.106151] loop0: rw=0, want=277428, limit=277408
[ 43.106154] Buffer I/O error on device loop0, logical block 138713
[ 43.106158] attempt to access beyond end of device
[ 43.106162] loop0: rw=0, want=277430, limit=277408
[ 43.106166] attempt to access beyond end of device
[ 43.106169] loop0: rw=0, want=277432, limit=277408
[ 43.106307] attempt to access beyond end of device
[ 43.106311] loop0: rw=0, want=277470, limit=2774
Squashfs manages to read in the end block(s) of the disk during the
mount operation. Then, when dd reads the block device, it leads to
block_read_full_page being called with buffers that are beyond end of
disk, but are marked as mapped. Thus, it would end up submitting read
I/O against them, resulting in the errors mentioned above. I fixed the
problem by modifying init_page_buffers to only set the buffer mapped if
it fell inside of i_size.
Cheers,
Jeff
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Nick Piggin <npiggin@kernel.dk>
Changes from v1->v2: re-used max_block, as suggested by Nick Piggin.
commit 05c69d298c96703741cac9a5cbbf6c53bd55a6e2 upstream.
6d1d8050b4bc8 "block, partition: add partition_meta_info to hd_struct"
added part_unpack_uuid() which assumes that the passed in buffer has
enough space for sprintfing "%pU" - 37 characters including '\0'.
Unfortunately, b5af921ec0233 "init: add support for root devices
specified by partition UUID" supplied 33 bytes buffer to the function
leading to the following panic with stackprotector enabled.
Kernel panic - not syncing: stack-protector: Kernel stack corrupted in: ffffffff81b14c7e
[<ffffffff815e226b>] panic+0xba/0x1c6
[<ffffffff81b14c7e>] ? printk_all_partitions+0x259/0x26xb
[<ffffffff810566bb>] __stack_chk_fail+0x1b/0x20
[<ffffffff81b15c7e>] printk_all_paritions+0x259/0x26xb
[<ffffffff81aedfe0>] mount_block_root+0x1bc/0x27f
[<ffffffff81aee0fa>] mount_root+0x57/0x5b
[<ffffffff81aee23b>] prepare_namespace+0x13d/0x176
[<ffffffff8107eec0>] ? release_tgcred.isra.4+0x330/0x30
[<ffffffff81aedd60>] kernel_init+0x155/0x15a
[<ffffffff81087b97>] ? schedule_tail+0x27/0xb0
[<ffffffff815f4d24>] kernel_thread_helper+0x5/0x10
[<ffffffff81aedc0b>] ? start_kernel+0x3c5/0x3c5
[<ffffffff815f4d20>] ? gs_change+0x13/0x13
Increase the buffer size, remove the dangerous part_unpack_uuid() and
use snprintf() directly from printk_all_partitions().
Reported-by: Szymon Gruszczynski <sz.gruszczynski@googlemail.com>
Cc: Will Drewry <wad@chromium.org>
commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa upstream.
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Oliver Neukum <oneukum@suse.de>
commit 2f624278626677bfaf73fef97f86b37981621f5c upstream.
We really need to use a ACCESS_ONCE() on the sequence value read in
__read_seqcount_begin(), because otherwise the compiler might end up
reloading the value in between the test and the return of it. As a
result, it might end up returning an odd value (which means that a write
is in progress).
If the reader is then fast enough that that odd value is still the
current one when the read_seqcount_retry() is done, we might end up with
a "successful" read sequence, even despite the concurrent write being
active.
In practice this probably never really happens - there just isn't
anything else going on around the read of the sequence count, and the
common case is that we end up having a read barrier immediately
afterwards.
So the code sequence in which gcc might decide to reaload from memory is
small, and there's no reason to believe it would ever actually do the
reload. But if the compiler ever were to decide to do so, it would be
incredibly annoying to debug. Let's just make sure.
commit f5c2347ee20a8d6964d6a6b1ad04f200f8d4dfa7 upstream.
<asm-generic/statfs.h> is exported to userspace, so using
BITS_PER_LONG is invalid. We need to use __BITS_PER_LONG instead.
This is kernel bugzilla 43165.
Reported-by: H.J. Lu <hjl.tools@gmail.com>
Link: http://lkml.kernel.org/r/1335465916-16965-1-git-send-email-hpa@linux.intel.com
