path: root/include
2014-02-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "We have a small collection of fixes in my for-linus branch. The big thing that stands out is a revert of a new ioctl. Users haven't shipped yet in btrfs-progs, and Dave Sterba found a better way to export the information" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use right clone root offset for compressed extents btrfs: fix null pointer deference at btrfs_sysfs_add_one+0x105 Btrfs: unset DCACHE_DISCONNECTED when mounting default subvol Btrfs: fix max_inline mount option Btrfs: fix a lockdep warning when cleaning up aborted transaction Revert "btrfs: add ioctl to export size of global metadata reservation"
2014-02-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "Mostly minor fixes this time to v3.14-rc1 related changes. Also included is one fix for a free after use regression in persistent reservations UNREGISTER logic that is CC'ed to >= v3.11.y stable" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: Target/sbc: Fix protection copy routine IB/srpt: replace strict_strtoul() with kstrtoul() target: Simplify command completion by removing CMD_T_FAILED flag iser-target: Fix leak on failure in isert_conn_create_fastreg_pool iscsi-target: Fix SNACK Type 1 + BegRun=0 handling target: Fix missing length check in spc_emulate_evpd_83() qla2xxx: Remove last vestiges of qla_tgt_cmd.cmd_list target: Fix 32-bit + CONFIG_LBDAF=n link error w/ sector_div target: Fix free-after-use regression in PR unregister
2014-02-15Merge branches 'irq-urgent-for-linus' and 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq update from Thomas Gleixner: "Fix from the urgent branch: a trivial oneliner adding the missing Kconfig dependency curing build failures which have been discovered by several build robots. The update in the irq-core branch provides a new function in the irq/devres code, which is a prerequisite for driver developers to get rid of boilerplate code all over the place. Not a bugfix, but it has zero impact on the current kernel due to the lack of users. It's simpler to provide the infrastructure to interested parties via your tree than fulfilling the wishlist of driver maintainers on which particular commit or tag this should be based on" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=n * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Add devm_request_any_context_irq()
2014-02-15Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Kevin Hilman: "A collection of ARM SoC fixes for v3.14-rc1. Mostly a collection of Kconfig, device tree data and compilation fixes along with fix to drivers/phy that fixes a boot regression on some Marvell mvebu platforms" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: dma: mv_xor: Silence a bunch of LPAE-related warnings ARM: ux500: disable msp2 device tree node ARM: zynq: Reserve not DMAable space in front of the kernel ARM: multi_v7_defconfig: Select CONFIG_SOC_DRA7XX ARM: imx6: Initialize low-power mode early again ARM: pxa: fix various compilation problems ARM: pxa: fix compilation problem on AM300EPD board ARM: at91: add Atmel's SAMA5D3 Xplained board spi/atmel: document clock properties mmc: atmel-mci: document clock properties ARM: at91: enable USB host on at91sam9n12ek board ARM: at91/dt: fix sama5d3 ohci hclk clock reference ARM: at91/dt: sam9263: fix compatibility string for the I2C ata: sata_mv: Fix probe failures with optional phys drivers: phy: Add support for optional phys drivers: phy: Make NULL a valid phy reference ARM: fix HAVE_ARM_TWD selection for OMAP and shmobile ARM: moxart: move DMA_OF selection to driver ARM: hisi: fix kconfig warning on HAVE_ARM_TWD
2014-02-14Merge tag 'usb-3.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here is a bunch of USB fixes for 3.14-rc3. Most of these are xhci reverts, fixing a bunch of reported issues with USB 3 host controller issues that loads of people have been hitting (with the exception of kernel developers, all of our machines seem to be working fine, which is why these took so long to get resolved...) There are some other minor fixes and new device ids, as ususal. All have been in linux-next successfully" * tag 'usb-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (22 commits) usb: option: blacklist ZTE MF667 net interface Revert "usb: xhci: Link TRB must not occur within a USB payload burst" Revert "xhci: Avoid infinite loop when sg urb requires too many trbs" Revert "xhci: Set scatter-gather limit to avoid failed block writes." xhci 1.0: Limit arbitrarily-aligned scatter gather. Modpost: fixed USB alias generation for ranges including 0x9 and 0xA usb: core: Fix potential memory leak adding dyn USBdevice IDs USB: ftdi_sio: add Tagsys RFID Reader IDs usb: qcserial: add Netgear Aircard 340U usb-storage: enable multi-LUN scanning when needed USB: simple: add Dynastream ANT USB-m Stick device support usb-storage: add unusual-devs entry for BlackBerry 9000 usb-storage: restrict bcdDevice range for Super Top in Cypress ATACB usb: phy: move some error messages to debug usb: ftdi_sio: add Mindstorms EV3 console adapter usb: dwc2: fix memory corruption in dwc2 driver usb: dwc2: fix role switch breakage usb: dwc2: bail out early when booting with "nousb" Revert "xhci: replace xhci_read_64() with readq()" Revert "xhci: replace xhci_write_64() with writeq()" ...
2014-02-14Merge tag 'char-misc-3.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc fixes from Greg KH: "Here are some small char/misc driver fixes, along with some documentation updates, for 3.14-rc3. Nothing major, just a number of fixes for reported issues" * tag 'char-misc-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Revert "misc: eeprom: sunxi: Add new compatibles" Revert "ARM: sunxi: dt: Convert to the new SID compatibles" misc: mic: fix possible signed underflow (undefined behavior) in userspace API ARM: sunxi: dt: Convert to the new SID compatibles misc: eeprom: sunxi: Add new compatibles misc: genwqe: Fix potential memory leak when pinning memory Documentation:Update Documentation/zh_CN/arm64/memory.txt Documentation:Update Documentation/zh_CN/arm64/booting.txt Documentation:Chinese translation of Documentation/arm64/tagged-pointers.txt raw: set range for MAX_RAW_DEVS raw: test against runtime value of max_raw_minors Drivers: hv: vmbus: Don't timeout during the initial connection with host Drivers: hv: vmbus: Specify the target CPU that should receive notification VME: Correct read/write alignment algorithm mei: don't unset read cb ptr on reset mei: clear write cb from waiting list on reset
2014-02-14Revert "btrfs: add ioctl to export size of global metadata reservation"Chris Mason
This reverts commit 01e219e8069516cdb98594d417b8bb8d906ed30d. David Sterba found a different way to provide these features without adding a new ioctl. We haven't released any progs with this ioctl yet, so I'm taking this out for now until we finalize things. Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: David Sterba <dsterba@suse.cz> CC: Jeff Mahoney <jeffm@suse.com>
2014-02-14Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "A collection of small fixes: - There still seem to be problems with asm goto which requires the empty asm hack. - If SMAP is disabled at compile time, don't enable it nor try to interpret a page fault as an SMAP violation. - Fix a case of unbounded recursion while tracing" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, smap: smap_violation() is bogus if CONFIG_X86_SMAP is off x86, smap: Don't enable SMAP if CONFIG_X86_SMAP is disabled compiler/gcc4: Make quirk for asm_volatile_goto() unconditional x86: Use preempt_disable_notrace() in cycles_2_ns()
2014-02-14Merge tag 'pm+acpi-3.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These include a fix for a recent intel_pstate regression, a fix for a regression in the ACPI-based PCI hotplug (ACPIPHP) code introduced during the 3.12 cycle, fixes for two bugs in the ACPI core introduced recently and a MAINTAINERS update related to cpufreq. Specifics: - Fix for a recent regression in the intel_pstate driver that introduced a race condition causing systems to crash during initialization in some situations. This removes the affected code altogether. From Dirk Brandewie. - ACPIPHP fix for a regression introduced during the 3.12 cycle causing devices to be dropped as a result of bus check notifications after system resume on some systems due to the way ACPIPHP interprets _STA return values (arguably incorrectly). From Mika Westerberg. - ACPI dock driver fix for a problem causing docking to fail due to a check that always fails after recent ACPI core changes (found by code inspection). - ACPI container driver fix to prevent memory from being leaked in an error code path after device_register() failures. - Update of the arm_big_little cpufreq driver maintainer's e-mail address" * tag 'pm+acpi-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: MAINTAINERS / cpufreq: update Sudeep's email address intel_pstate: Remove energy reporting from pstate_sample tracepoint ACPI / container: Fix error code path in container_device_attach() ACPI / hotplug / PCI: Relax the checking of _STA return values ACPI / dock: Use acpi_device_enumerated() to check if dock is present
2014-02-14Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO fixes from Jens Axboe: "Second round of updates and fixes for 3.14-rc2. Most of this stuff has been queued up for a while. The notable exception is the blk-mq changes, which are naturally a bit more in flux still. The pull request contains: - Two bug fixes for the new immutable vecs, causing crashes with raid or swap. From Kent. - Various blk-mq tweaks and fixes from Christoph. A fix for integrity bio's from Nic. - A few bcache fixes from Kent and Darrick Wong. - xen-blk{front,back} fixes from David Vrabel, Matt Rushton, Nicolas Swenson, and Roger Pau Monne. - Fix for a vec miscount with integrity vectors from Martin. - Minor annotations or fixes from Masanari Iida and Rashika Kheria. - Tweak to null_blk to do more normal FIFO processing of requests from Shlomo Pongratz. - Elevator switching bypass fix from Tejun. - Softlockup in blkdev_issue_discard() fix when !CONFIG_PREEMPT from me" * 'for-linus' of git://git.kernel.dk/linux-block: (31 commits) block: add cond_resched() to potentially long running ioctl discard loop xen-blkback: init persistent_purge_work work_struct blk-mq: pair blk_mq_start_request / blk_mq_requeue_request blk-mq: dont assume rq->errors is set when returning an error from ->queue_rq block: Fix cloning of discard/write same bios block: Fix type mismatch in ssize_t_blk_mq_tag_sysfs_show blk-mq: rework flush sequencing logic null_blk: use blk_complete_request and blk_mq_complete_request virtio_blk: use blk_mq_complete_request blk-mq: rework I/O completions fs: Add prototype declaration to appropriate header file include/linux/bio.h fs: Mark function as static in fs/bio-integrity.c block/null_blk: Fix completion processing from LIFO to FIFO block: Explicitly handle discard/write same segments block: Fix nr_vecs for inline integrity vectors blk-mq: Add bio_integrity setup to blk_mq_make_request blk-mq: initialize sg_reserved_size blk-mq: handle dma_drain_size blk-mq: divert __blk_put_request for MQ ops blk-mq: support at_head inserations for blk_execute_rq ...
2014-02-14Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull RDMA/InfiniBand fixes from Roland Dreier: - Fix some rough edges from the "IP addressing for IBoE" merge - Other misc fixes, mostly to hardware drivers * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (21 commits) RDMA/ocrdma: Fix load time panic during GID table init RDMA/ocrdma: Fix traffic class shift IB/iser: Fix use after free in iser_snd_completion() IB/iser: Avoid dereferencing iscsi_iser conn object when not bound to iser connection IB/usnic: Fix smatch endianness error IB/mlx5: Remove dependency on X86 mlx5: Add include of <linux/slab.h> because of kzalloc()/kfree() use IB/qib: Add missing serdes init sequence RDMA/cxgb4: Add missing neigh_release in LE-Workaround path IB: Report using RoCE IP based gids in port caps IB/mlx4: Build the port IBoE GID table properly under bonding IB/mlx4: Do IBoE GID table resets per-port IB/mlx4: Do IBoE locking earlier when initializing the GID table IB/mlx4: Move rtnl locking to the right place IB/mlx4: Make sure GID index 0 is always occupied IB/mlx4: Don't allocate range of steerable UD QPs for Ethernet-only device RDMA/amso1100: Fix error return code RDMA/nes: Fix error return code IB/mlx5: Don't set "block multicast loopback" capability IB/mlx5: Fix binary compatibility with libmlx5 ...
2014-02-14Merge branches 'cma', 'cxgb4', 'iser', 'misc', 'mlx4', 'mlx5', 'nes', ↵Roland Dreier
'ocrdma', 'qib' and 'usnic' into for-next
2014-02-13mlx5: Add include of <linux/slab.h> because of kzalloc()/kfree() useRoland Dreier
On some architectures (for example, arm), we don't end up indirectly pulling in the declaration of kzalloc() and kfree(), and so building anything that includes <linux/mlx5/driver.h> breaks. Fix this by adding an explicit include to get the declaration. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-02-13IB: Report using RoCE IP based gids in port capsMoni Shoua
For userspace RoCE UD QPs we need to know the GID format that the kernel uses, e.g when working over older kernels. For that end, add a new port capability IB_PORT_IP_BASED_GIDS and report it when query port is issued. Signed-off-by: Moni Shoua <monis@mellanox.co.il> Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-02-13compiler/gcc4: Make quirk for asm_volatile_goto() unconditionalSteven Noonan
I started noticing problems with KVM guest destruction on Linux 3.12+, where guest memory wasn't being cleaned up. I bisected it down to the commit introducing the new 'asm goto'-based atomics, and found this quirk was later applied to those. Unfortunately, even with GCC 4.8.2 (which ostensibly fixed the known 'asm goto' bug) I am still getting some kind of miscompilation. If I enable the asm_volatile_goto quirk for my compiler, KVM guests are destroyed correctly and the memory is cleaned up. So make the quirk unconditional for now, until bug is found and fixed. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Steven Noonan <steven@uplinklabs.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/1392274867-15236-1-git-send-email-steven@uplinklabs.net Link: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-13Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: MAINTAINERS / cpufreq: update Sudeep's email address intel_pstate: Remove energy reporting from pstate_sample tracepoint
2014-02-13intel_pstate: Remove energy reporting from pstate_sample tracepointDirk Brandewie
Remove the reporting of energy since it does not provide any useful information about the state of the driver and will be a maintainance headache going forward since the RAPL energy units register is not architectural and subject to change between micro-architectures References: https://bugzilla.kernel.org/show_bug.cgi?id=69831 Fixes: b69880f9ccf7 (intel_pstate: Add trace point to report internal state.) Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-12target: Simplify command completion by removing CMD_T_FAILED flagRoland Dreier
The CMD_T_FAILED flag is set used in one place to record the result of a trivial test, and it is only tested once, few lines later. We might as well make the code simpler and easier to read by directly doing the test of "success" where we want to use it. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-02-12Merge tag 'stable/for-linus-3.14-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: "This has an healthy amount of code being removed - which we do not use anymore (the only user of it was ia64 Xen which had been removed already). The other bug-fixes are to make Xen ARM be able to use the new event channel mechanism and proper export of header files to user-space. Summary: - Fix ARM and Xen FIFO not working. - Remove more Xen ia64 vestigates. - Fix UAPI missing Xen files" * tag 'stable/for-linus-3.14-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: ia64/xen: Remove Xen support for ia64 even more xen: install xen/gntdev.h and xen/gntalloc.h xen/events: bind all new interdomain events to VCPU0
2014-02-12Merge tag 'gpio-v3.14-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO fixes from Linus Walleij: "Here are some accumulated patches with small fixes for this and that in a few GPIO drivers, and a more important fix to an #ifdef in the GPIO consumer header. Summary: - Get #ifdef's right in the <linux/gpio/consumer.h> header. - Minor fixes to tb10x, clps711x, bcm281xx, intel-mid and xtensa GPIO drivers" * tag 'gpio-v3.14-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio: consumer.h: Move forward declarations outside #ifdef gpio: tb10x: GPIO_TB10X needs to select GENERIC_IRQ_CHIP gpio: clps711x: Add module alias to support module auto loading gpio: bcm281xx: Update MODULE_AUTHOR gpio: intel-mid: fix the incorrect return of idle callback gpio: xtensa: fix build when XCHAL_HAVE_CP is 0
2014-02-12Merge tag 'spi-v3.14-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi fixes from Mark Brown: "A few driver and documentation fixes, plus a fix for double error handling which had crept in due to the confusing documentation - it wasn't clear if the core or the driver was responsible for cleanup in error cases so both tried to do it with unfortunate results" * tag 'spi-v3.14-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: spi: nuc900: Set SPI_LSB_FIRST for master->mode_bits if hw->pdata->lsb is true spi: rspi: Document support for Renesas QSPI in Kconfig spi: Fix crash with double message finalisation on error handling spi: correct the transfer_one_message documentation wording spi: document the transfer_one spi_master callback spi: spi.h: clarify the documentation of transfer_one
2014-02-12Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Nothing too crazy. Radeon irq fixes, i915 regression fixes, exynos fixes, tda998x chip fixes, and a bunch of msm fixes" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (31 commits) drm/i915: Pair va_copy with va_end in i915_error_vprintf drm/i915: Fix intel_pipe_to_cpu_transcoder for UMS drm/i915: Disable dp aux irq on g4x drm/msm: bigger synchronization hammer drm/exynos: Convert to use the standard hdmi.h header drm/exynos: Fix trivial typo drm/exynos: Remove unnecessary semicolon drm/exynos: Fix multiplatform breakage for ipp/gsc drm/exynos: Fix freeing issues in exynos_drm_drv.c drm/radeon: add missing include in btc_dpm.c drm/radeon/dpm: fix uninitialized read from stack in kv_dpm_late_enable drm/radeon: remove useless return drm/radeon/dpm: use stored max_vddc rather than looking it up drm/radeon/dpm: use the driver state for dpm debugfs drm/radeon: fix UVD IRQ support on 7xx drm/radeon: fix UVD IRQ support on SI drm/msm: fix deadlock in bo create fail path drm/msm/mdp4: cursor fixes drm/msm/mdp4: pageflip fixes drm/msm/mdp5: fix ref leaks in error paths ...
2014-02-11Merge tag 'dt-fixes-for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree fixes from Rob Herring: - Fix compile error drivers/spi/spi-rspi.c with !CONFIG_OF - Fix warnings for unused/uninitialized variables with !CONFIG_OF - Fix PCIe bus matching for powerpc - Add documentation for various vendor strings * tag 'dt-fixes-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: DT: Add vendor prefix for Spansion Inc. of/device: Nullify match table in of_match_device() for CONFIG_OF=n dt-bindings: add vendor-prefix for neonode of: fix PCI bus match for PCIe slots of: restructure for_each macros to fix compile warnings of: add vendor prefix for Honeywell of: Update qcom vendor prefix description of: add vendor prefix for Allwinner Technology
2014-02-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix flexcan build on big endian, from Arnd Bergmann 2) Correctly attach cpsw to GPIO bitbang MDIO drive, from Stefan Roese 3) udp_add_offload has to use GFP_ATOMIC since it can be invoked from non-sleepable contexts. From Or Gerlitz 4) vxlan_gro_receive() does not iterate over all possible flows properly, fix also from Or Gerlitz 5) CAN core doesn't use a proper SKB destructor when it hooks up sockets to SKBs. Fix from Oliver Hartkopp 6) ip_tunnel_xmit() can use an uninitialized route pointer, fix from Eric Dumazet 7) Fix address family assignment in IPVS, from Michal Kubecek 8) Fix ath9k build on ARM, from Sujith Manoharan 9) Make sure fail_over_mac only applies for the correct bonding modes, from Ding Tianhong 10) The udp offload code doesn't use RCU correctly, from Shlomo Pongratz 11) Handle gigabit features properly in generic PHY code, from Florian Fainelli 12) Don't blindly invoke link operations in rtnl_link_get_slave_info_data_size, they are optional. Fix from Fernando Luis Vazquez Cao 13) Add USB IDs for Netgear Aircard 340U, from Bjørn Mork 14) Handle netlink packet padding properly in openvswitch, from Thomas Graf 15) Fix oops when deleting chains in nf_tables, from Patrick McHardy 16) Fix RX stalls in xen-netback driver, from Zoltan Kiss 17) Fix deadlock in mac80211 stack, from Emmanuel Grumbach 18) inet_nlmsg_size() forgets to consider ifa_cacheinfo, fix from Geert Uytterhoeven 19) tg3_change_mtu() can deadlock, fix from Nithin Sujir 20) Fix regression in setting SCTP local source addresses on accepted sockets, caused by some generic ipv6 socket changes. Fix from Matija Glavinic Pecotic 21) IPPROTO_* must be pure defines, otherwise module aliases don't get constructed properly. Fix from Jan Moskyto 22) IPV6 netconsole setup doesn't work properly unless an explicit source address is specified, fix from Sabrina Dubroca 23) Use __GFP_NORETRY for high order skb page allocations in sock_alloc_send_pskb and skb_page_frag_refill. From Eric Dumazet 24) Fix a regression added in netconsole over bridging, from Cong Wang 25) TCP uses an artificial offset of 1ms for SRTT, but this doesn't jive well with TCP pacing which needs the SRTT to be accurate. Fix from Eric Dumazet 26) Several cases of missing header file includes from Rashika Kheria 27) Add ZTE MF667 device ID to qmi_wwan driver, from Raymond Wanyoike 28) TCP Small Queues doesn't handle nonagle properly in some corner cases, fix from Eric Dumazet 29) Remove extraneous read_unlock in bond_enslave, whoops. From Ding Tianhong 30) Fix 9p trans_virtio handling of vmalloc buffers, from Richard Yao * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (136 commits) 6lowpan: fix lockdep splats alx: add missing stats_lock spinlock init 9p/trans_virtio.c: Fix broken zero-copy on vmalloc() buffers bonding: remove unwanted bond lock for enslave processing USB2NET : SR9800 : One chip USB2.0 USB2NET SR9800 Device Driver Support tcp: tsq: fix nonagle handling bridge: Prevent possible race condition in br_fdb_change_mac_address bridge: Properly check if local fdb entry can be deleted when deleting vlan bridge: Properly check if local fdb entry can be deleted in br_fdb_delete_by_port bridge: Properly check if local fdb entry can be deleted in br_fdb_change_mac_address bridge: Fix the way to check if a local fdb entry can be deleted bridge: Change local fdb entries whenever mac address of bridge device changes bridge: Fix the way to find old local fdb entries in br_fdb_change_mac_address bridge: Fix the way to insert new local fdb entries in br_fdb_changeaddr bridge: Fix the way to find old local fdb entries in br_fdb_changeaddr tcp: correct code comment stating 3 min timeout for FIN_WAIT2, we only do 1 min net: vxge: Remove unused device pointer net: qmi_wwan: add ZTE MF667 3c59x: Remove unused pointer in vortex_eisa_cleanup() net: fix 'ip rule' iif/oif device rename ...
2014-02-11block: Fix cloning of discard/write same biosKent Overstreet
Immutable biovecs changed the way bio segments are treated in such a way that bio_for_each_segment() cannot now do what we want for discard/write same bios, since bi_size means something completely different for them. Fortunately discard and write same bios never have more than a single biovec, so bio_for_each_segment() is unnecessary and not terribly meaningful for them, but we still have to special case them in a few places. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Tested-by: Richard W.M. Jones <rjones@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-11ia64/xen: Remove Xen support for ia64 even morePaul Bolle
Commit d52eefb47d4e ("ia64/xen: Remove Xen support for ia64") removed the Kconfig symbol XEN_XENCOMM. But it didn't remove the code depending on that symbol. Remove that code now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-02-11xen: install xen/gntdev.h and xen/gntalloc.hDavid Vrabel
xen/gntdev.h and xen/gntalloc.h both provide userspace ABIs so they should be installed. CC: stable@vger.kernel.org Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-02-11Merge remote-tracking branches 'spi/fix/doc', 'spi/fix/nuc900' and ↵Mark Brown
'spi/fix/rspi' into spi-linus
2014-02-11Merge tag 'drm-intel-fixes-2014-02-06' of ↵Dave Airlie
ssh://git.freedesktop.org/git/drm-intel into drm-next Just minor stuff really, on vlv dp fix and two patches to tune down some opregion sanity check. Plus MAINTAINERS update for the new git repo, which is the only reason I've really bothered with this pull request. * tag 'drm-intel-fixes-2014-02-06' of ssh://git.freedesktop.org/git/drm-intel: drm/i915: demote opregion excessive timeout WARN_ONCE to DRM_INFO_ONCE drm: add DRM_INFO_ONCE() to print a one-time DRM_INFO() message MAINTAINERS: Update drm/i915 git repo drm/i915: vlv: fix DP PHY lockup due to invalid PP sequencer setup
2014-02-10smp.h: fix x86+cpu.c sparse warnings about arch nonboot CPU callsPaul Gortmaker
Use what we already do for arch_disable_smp_support() to fix these: arch/x86/kernel/smpboot.c:1155:6: warning: symbol 'arch_enable_nonboot_cpus_begin' was not declared. Should it be static? arch/x86/kernel/smpboot.c:1160:6: warning: symbol 'arch_enable_nonboot_cpus_end' was not declared. Should it be static? kernel/cpu.c:512:13: warning: symbol 'arch_enable_nonboot_cpus_begin' was not declared. Should it be static? kernel/cpu.c:516:13: warning: symbol 'arch_enable_nonboot_cpus_end' was not declared. Should it be static? Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10Merge branch 'stable/for-jens-3.14' of ↵Jens Axboe
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip into for-linus Konrad writes: Please git pull the following branch: git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip.git stable/for-jens-3.14 which is based off v3.13-rc6. If you would like me to rebase it on a different branch/tag I would be more than happy to do so. The patches are all bug-fixes and hopefully can go in 3.14. They deal with xen-blkback shutdown and cause memory leaks as well as shutdown races. They should go to stable tree and if you are OK with I will ask them to backport those fixes. There is also a fix to xen-blkfront to deal with unexpected state transition. And lastly a fix to the header where it was using the __aligned__ unnecessarily.
2014-02-10blk-mq: rework flush sequencing logicChristoph Hellwig
Witch to using a preallocated flush_rq for blk-mq similar to what's done with the old request path. This allows us to set up the request properly with a tag from the actually allowed range and ->rq_disk as needed by some drivers. To make life easier we also switch to dynamic allocation of ->flush_rq for the old path. This effectively reverts most of "blk-mq: fix for flush deadlock" and "blk-mq: Don't reserve a tag for flush request" Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-10blk-mq: rework I/O completionsChristoph Hellwig
Rework I/O completions to work more like the old code path. blk_mq_end_io now stays out of the business of deferring completions to others CPUs and calling blk_mark_rq_complete. The latter is very important to allow completing requests that have timed out and thus are already marked completed, the former allows using the IPI callout even for driver specific completions instead of having to reimplement them. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "A couple of fixes, both -stable fodder. The O_SYNC bug is fairly old..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fix a kmap leak in virtio_console fix O_SYNC|O_APPEND syncing the wrong range on write()
2014-02-09net: Move prototype declaration to header file include/net/net_namespace.h ↵Rashika Kheria
from net/ipx/af_ipx.c Move prototype declaration of function to header file include/net/net_namespace.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/sysctl_net_ipx.c: net/ipx/sysctl_net_ipx.c:33:6: warning: no previous prototype for ‘ipx_register_sysctl’ [-Wmissing-prototypes] net/ipx/sysctl_net_ipx.c:38:6: warning: no previous prototype for ‘ipx_unregister_sysctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/datalink.h from ↵Rashika Kheria
net/ipx/af_ipx.c Move prototype declarations of function to header file include/net/datalink.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/pe2.c: net/ipx/pe2.c:20:24: warning: no previous prototype for ‘make_EII_client’ [-Wmissing-prototypes] net/ipx/pe2.c:32:6: warning: no previous prototype for ‘destroy_EII_client’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/ipx.h from ↵Rashika Kheria
net/ipx/af_ipx.c Move prototype declaration of functions to header file include/net/ipx.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/ipx_route.c:33:19: warning: no previous prototype for ‘ipxrtr_lookup’ [-Wmissing-prototypes] net/ipx/ipx_route.c:52:5: warning: no previous prototype for ‘ipxrtr_add_route’ [-Wmissing-prototypes] net/ipx/ipx_route.c:94:6: warning: no previous prototype for ‘ipxrtr_del_routes’ [-Wmissing-prototypes] net/ipx/ipx_route.c:149:5: warning: no previous prototype for ‘ipxrtr_route_skb’ [-Wmissing-prototypes] net/ipx/ipx_route.c:171:5: warning: no previous prototype for ‘ipxrtr_route_packet’ [-Wmissing-prototypes] net/ipx/ipx_route.c:261:5: warning: no previous prototype for ‘ipxrtr_ioctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to include/net/ipx.h from net/ipx/ipx_route.cRashika Kheria
Move prototype definition of function to header file include/net/ipx.h from net/ipx/ipx_route.c because they are used by more than one file. This eliminates the following warning from net/ipx/af_ipx.c: net/ipx/af_ipx.c:193:23: warning: no previous prototype for ‘ipxitf_find_using_net’ [-Wmissing-prototypes] net/ipx/af_ipx.c:577:5: warning: no previous prototype for ‘ipxitf_send’ [-Wmissing-prototypes] net/ipx/af_ipx.c:1219:8: warning: no previous prototype for ‘ipx_cksum’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/dn.h from ↵Rashika Kheria
net/decnet/af_decnet.c Move prototype declaration of functions to header file include/net/dn.h from net/decnet/af_decnet.c because they are used by more than one file. This eliminates the following warning in net/decnet/af_decnet.c: net/decnet/sysctl_net_decnet.c:354:6: warning: no previous prototype for ‘dn_register_sysctl’ [-Wmissing-prototypes] net/decnet/sysctl_net_decnet.c:359:6: warning: no previous prototype for ‘dn_unregister_sysctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to appropriate header file from ↵Rashika Kheria
decnet/af_decnet.c Move prototype declaration of functions to header file include/net/dn_route.h from net/decnet/af_decnet.c because it is used by more than one file. This eliminates the following warning in net/decnet/dn_route.c: net/decnet/dn_route.c:629:5: warning: no previous prototype for ‘dn_route_rcv’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/nftables/IPVS fixes for net The following patchset contains Netfilter/IPVS fixes, mostly nftables fixes, most relevantly they are: * Fix a crash in the h323 conntrack NAT helper due to expectation list corruption, from Alexey Dobriyan. * A couple of RCU race fixes for conntrack, one manifests by hitting BUG_ON in nf_nat_setup_info() and the destroy path, patches from Andrey Vagin and me. * Dump direction attribute in nft_ct only if it is set, from Arturo Borrero. * Fix IPVS bug in its own connection tracking system that may lead to copying only 4 bytes of the IPv6 address when initializing the ip_vs_conn object, from Michal Kubecek. * Fix -EBUSY errors in nftables when deleting the rules, chain and tables in a row due mixture of asynchronous and synchronous object releasing, from me. * Three fixes for the nf_tables set infrastructure when using intervals and mappings, from me. * Four patches to fixing the nf_tables log, reject and ct expressions from the new inet table, from Patrick McHardy. * Fix memory overrun in the map that is used to dynamically allocate names from anonymous sets, also from Patrick. * Fix a potential oops if you dump a set with NFPROTO_UNSPEC and a table name, from Patrick McHardy. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09fs: Add prototype declaration to appropriate header file include/linux/bio.hRashika Kheria
Add prototype declaration to header file include/linux/bio.h because it is used by more than one file. This eliminates the following warning in bio-integrity.c: fs/bio-integrity.c:214:14: warning: no previous prototype for ‘bio_integrity_tag_size’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-09fix O_SYNC|O_APPEND syncing the wrong range on write()Al Viro
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support) when sync_page_range() had been introduced; generic_file_write{,v}() correctly synced pos_after_write - written .. pos_after_write - 1 but generic_file_aio_write() synced pos_before_write .. pos_before_write + written - 1 instead. Which is not the same thing with O_APPEND, obviously. A couple of years later correct variant had been killed off when everything switched to use of generic_file_aio_write(). All users of generic_file_aio_write() are affected, and the same bug has been copied into other instances of ->aio_write(). The fix is trivial; the only subtle point is that generic_write_sync() ought to be inlined to avoid calculations useless for the majority of calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-02-09genirq: Add devm_request_any_context_irq()Stephen Boyd
Some drivers use request_any_context_irq() but there isn't a devm_* function for it. Add one so that these drivers don't need to explicitly free the irq on driver detach. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: linux-arm-kernel@lists.infradead.org Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Link: http://lkml.kernel.org/r/1388709460-19222-3-git-send-email-sboyd@codeaurora.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-08Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "Quite a varied little collection of fixes. Most of them are relatively small or isolated; the biggest one is Mel Gorman's fixes for TLB range flushing. A couple of AMD-related fixes (including not crashing when given an invalid microcode image) and fix a crash when compiled with gcov" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Unify valid container checks x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y x86/efi: Allow mapping BGRT on x86-32 x86: Fix the initialization of physnode_map x86, cpu hotplug: Fix stack frame warning in check_irq_vectors_for_cpu_disable() x86/intel/mid: Fix X86_INTEL_MID dependencies arch/x86/mm/srat: Skip NUMA_NO_NODE while parsing SLIT mm, x86: Revisit tlb_flushall_shift tuning for page flushes except on IvyBridge x86: mm: change tlb_flushall_shift for IvyBridge x86/mm: Eliminate redundant page table walk during TLB range flushing x86/mm: Clean up inconsistencies when flushing TLB ranges mm, x86: Account for TLB flushes only when debugging x86/AMD/NB: Fix amd_set_subcaches() parameter type x86/quirks: Add workaround for AMD F16h Erratum792 x86, doc, kconfig: Fix dud URL for Microcode data
2014-02-07misc: mic: fix possible signed underflow (undefined behavior) in userspace APISudeep Dutt
iovcnt is declared as a signed integer in both the userspace API and as a local variable in mic_virtio.c. The while() loop in mic_virtio.c iterates until the local variable iovcnt reaches the value 0. If userspace passes e.g. INT_MIN as iovcnt field, this loop then appears to depend on an undefined behavior (signed underflow) to complete. The fix is to use unsigned integers in both the userspace API and the local variable. This issue was reported @ https://lkml.org/lkml/2014/1/10/10 Reported-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reviewed-by: Ashutosh Dixit <ashutosh.dixit@intel.com> Signed-off-by: Sudeep Dutt <sudeep.dutt@intel.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Revert "usb: xhci: Link TRB must not occur within a USB payload burst"Sarah Sharp
This reverts commit 35773dac5f862cb1c82ea151eba3e2f6de51ec3e. It's a hack that caused regressions in the usb-storage and userspace USB drivers that use usbfs and libusb. Commit 70cabb7d992f "xhci 1.0: Limit arbitrarily-aligned scatter gather." should fix the issues seen with the ax88179_178a driver on xHCI 1.0 hosts, without causing regressions. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@vger.kernel.org # 3.12
2014-02-07Merge tag 'efi-urgent' into x86/urgentH. Peter Anvin
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit). Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-07blk-mq: support at_head inserations for blk_execute_rqChristoph Hellwig
This is neede for proper SG_IO operation as well as various uses of blk_execute_rq from the SCSI midlayer. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-07xen-blkif: drop struct blkif_request_segment_alignedRoger Pau Monne
This was wrongly introduced in commit 402b27f9, the only difference between blkif_request_segment_aligned and blkif_request_segment is that the former has a named padding, while both share the same memory layout. Also correct a few minor glitches in the description, including for it to no longer assume PAGE_SIZE == 4096. Signed-off-by: Roger Pau Monné <roger.pau@citrix.com> [Description fix by Jan Beulich] Signed-off-by: Jan Beulich <jbeulich@suse.com> Reported-by: Jan Beulich <jbeulich@suse.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Tested-by: Matt Rushton <mrushton@amazon.com> Cc: Matt Wilson <msw@amazon.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
