commit f8d570a4745835f2238a33b537218a1bb03fc671 and
3b53fbf4314594fa04544b02b2fc6e607912da18 upstream (because once wasn't
good enough...)
__scm_destroy() walks the list of file descriptors in the scm_fp_list
pointed to by the scm_cookie argument.
Those, in turn, can close sockets and invoke __scm_destroy() again.
There is nothing which limits how deeply this can occur.
The idea for how to fix this is from Linus. Basically, we do all of
the fput()s at the top level by collecting all of the scm_fp_list
objects hit by an fput(). Inside of the initial __scm_destroy() we
keep running the list until it is empty.
[ Upstream commit 930cc144a043ff95e56b6888fa51c618b33f89e7 ]
I'm trying to move the powerpc math-emu code to use the include/math-emu bits.
In doing so I've been using TestFloat to see how good or bad we are
doing. For the most part the current math-emu code that PPC uses has
a number of issues that the code in include/math-emu seems to solve
(plus bugs we've had for ever that no one every realized).
Anyways, I've come across a case that we are flagging underflow and
inexact because we think we have a denormalized result from a double
precision divide:
000.FFFFFFFFFFFFF / 3FE.FFFFFFFFFFFFE
soft: 001.0000000000000 ..... syst: 001.0000000000000 ...ux
What it looks like is the results out of FP_DIV_D are:
D:
sign: 0
mantissa: 01000000 00000000
exp: -1023 (0)
The problem seems like we aren't normalizing the result and bumping the exp.
Now that I'm digging into this a bit I'm thinking my issue has to do with
the fix DaveM put in place from back in Aug 2007 (commit
405849610fd96b4f34cd1875c4c033228fea6c0f):
[MATH-EMU]: Fix underflow exception reporting.
2) we ended up rounding back up to normal (this is the case where
we set the exponent to 1 and set the fraction to zero), this
should set inexact too
Another example, "0x0.0000000000001p-1022 / 16.0", should signal both
inexact and underflow. The cpu implementations and ieee1754
literature is very clear about this. This is case #2 above.
Here is the distilled glibc test case from Jakub Jelinek which prompted that
commit:
#include <float.h>
#include <fenv.h>
#include <stdio.h>
volatile double d = DBL_MIN;
volatile double e = 0x0.0000000000001p-1022;
volatile double f = 16.0;
int
main (void)
printf ("%x\n", fetestexcept (FE_UNDERFLOW));
d /= f;
e /= f;
return 0;
It looks like the case I have we are exact before rounding, but think it
looks like the rounding case since it appears as if "overflow is set".
000.FFFFFFFFFFFFF / 3FE.FFFFFFFFFFFFE = 001.0000000000000
I think the following adds the check for my case and still works for the
issue your commit was trying to resolve.
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: workaround for bogus gcc warning in ide_sysfs_register_port()
ide-cd: Optiarc DVD RW AD-7200A does play audio
IDE: Fix platform device registration in Swarm IDE driver (v2)
ide-dma: fix ide_build_dmatable() for TRM290
ide-cd: temporary tray close fix
This one fixes http://bugzilla.kernel.org/show_bug.cgi?id=11602.
A more generic fix for drives which cannot autoclose tray will follow.
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
[bart: add an extra parentheses for consistency with the rest of kernel code]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
include/linux/stacktrace.h:13: warning:
'struct task_struct' declared inside parameter list
(This might be a hard error on sparc64, which uses this header and has
-Werror)
Reported-by: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Arjan van de Ven <arjan@infradead.org>
Rework of SMTC support to make it work with the new clock event system,
allowing "tickless" operation, and to make it compatible with the use of
the "wait_irqoff" idle loop. The new clocking scheme means that the
previously optional IPI instant replay mechanism is now required, and has
been made more robust.
Signed-off-by: Kevin D. Kissell <kevink@paralogos.com>
Though from a hardware perspective it would be sensible to use only a
32-bit unsigned int type Linux defines interrupt flags to be stored in
an unsigned long and nothing else.
The previous patch db203d53d474aa068984e409d807628f5841da1b ("mm:
tiny-shmem fix lock ordering: mmap_sem vs i_mutex") to fix the lock
ordering in tiny-shmem breaks shared anonymous and IPC memory on NOMMU
architectures because it was using the expanding truncate to signal ramfs
to allocate a physically contiguous RAM backing the inode (otherwise it is
unusable for "memory mapping" it to userspace).
However do_truncate is what caused the lock ordering error, due to it
taking i_mutex. In this case, we can actually just call ramfs directly to
allocate memory for the mapping, rather than go via truncate.
Acked-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Matt Mackall <mpm@selenic.com>
Fix inotify lock order reversal with mmap_sem due to holding locks over
copy_to_user.
Reported-by: "Daniel J Blueman" <daniel.blueman@gmail.com>
Tested-by: "Daniel J Blueman" <daniel.blueman@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
af_key: Free dumping state on socket close
XFRM,IPv6: initialize ip6_dst_blackhole_ops.kmem_cachep
ipv6: NULL pointer dereferrence in tcp_v6_send_ack
tcp: Fix NULL dereference in tcp_4_send_ack()
sctp: Fix kernel panic while process protocol violation parameter
iucv: Fix mismerge again.
ipsec: Fix pskb_expand_head corruption in xfrm_state_check_space
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
hrtimer: prevent migration of per CPU hrtimers
hrtimer: mark migration state
hrtimer: fix migration of CB_IRQSAFE_NO_SOFTIRQ hrtimers
hrtimer: migrate pending list on cpu offline
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Since call to function sctp_sf_abort_violation() need paramter 'arg' with
'struct sctp_chunk' type, it will read the chunk type and chunk length from
the chunk_hdr member of chunk. But call to sctp_sf_violation_paramlen()
always with 'struct sctp_paramhdr' type's parameter, it will be passed to
sctp_sf_abort_violation(). This may cause kernel panic.
|-- sctp_sf_abort_violation()
|-- sctp_make_abort_violation()
This patch fixed this problem. This patch also fix two place which called
sctp_sf_violation_paramlen() with wrong paramter type.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Impact: per CPU hrtimers can be migrated from a dead CPU
The hrtimer code has no knowledge about per CPU timers, but we need to
prevent the migration of such timers and warn when such a timer is
active at migration time.
Explicitely mark the timers as per CPU and use a more understandable
mode descriptor for the interrupts safe unlocked callback mode, which
is used by hrtimer_sleeper and the scheduler code.
Impact: during migration active hrtimers can be seen as inactive
The migration code removes the hrtimers from the queues of the dead
CPU and sets the state temporary to INACTIVE. The enqueue code sets it
to ACTIVE/PENDING again.
Prevent that the wrong state can be seen by using a separate migration
state bit.
On x86_64 the gdb serial register structure defines the PS (also known
as eflags), CS and SS registers as 4 bytes entities.
This patch splits the x86_64 regnames enum into a 32 and 64 version to
account for the 32 bit entities in the gdb serial packets.
Also the program counter is properly filled in for the sleeping
threads.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The BX and DX registers in the gdb serial register packet need to be
flipped for gdb to receive the correct data.
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fixe the definition of PTRS_PER_PGD
[MIPS] au1000: Fix gpio direction
Move asm-arm/cnt32_to_63.h to include/linux/ so that MN10300 can make
use of it too.
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: fix put_data error handling
9p: use an IS_ERR test rather than a NULL test
9p: introduce missing kfree
9p-trans_fd: fix and clean up module init/exit paths
9p-trans_fd: don't do fs segment mangling in p9_fd_poll()
9p-trans_fd: clean up p9_conn_create()
9p-trans_fd: fix trans_fd::p9_conn_destroy()
9p: implement proper trans module refcounting and unregistration
9p trans modules aren't refcounted nor were they unregistered
properly. Fix it.
* Add 9p_trans_module->owner and reference the module on each trans
instance creation and put it on destruction.
* Protect v9fs_trans_list with a spinlock. This isn't strictly
necessary as the list is manipulated only during module loading /
unloading but it's a good idea to make the API safe.
* Unregister trans modules when the corresponding module is being
unloaded.
* While at it, kill unnecessary EXPORT_SYMBOL on p9_trans_fd_init().
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
When we use > 4KB's page size the original definition is not consistent
with PGDIR_SIZE. For exeample, if we use 16KB page size the PGDIR_SHIFT is
(14-2) + 14 = 26, PGDIR_SIZE is 2^26,so the PTRS_PER_PGD should be:
2^32/2^26 = 2^6
but the original definition of PTRS_PER_PGD is 4096 (PGDIR_ORDER = 0).
So, this definition needs to be consistent with the PGDIR_SIZE.
And the new definition is consistent with the PGD init in pagetable_init().
Signed-off-by: Dajie Tan <jiankemeng@gmail.com>
timers: fix build error in !oneshot case
x86: c1e_idle: don't mark TSC unstable if CPU has invariant TSC
x86: prevent C-states hang on AMD C1E enabled machines
clockevents: prevent mode mismatch on cpu online
clockevents: check broadcast device not tick device
clockevents: prevent stale tick_next_period for onlining CPUs
x86: prevent stale state of c1e_mask across CPU offline/online
clockevents: prevent cpu online to interfere with nohz
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: fix compiler warnings in pci_get_subsys()
PCI: Fix pcie_aspm=force
linux/time.h conflicts with time.h from glibc
It breaks building smbmount from samba. It's regression introduced by
commit 76308da (" smb.h: uses struct timespec but didn't include
linux/time.h").
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: <stable@kernel.org> [2.6.26.x]
Impact: System hang when AMD C1E machines switch into C2/C3
AMD C1E enabled systems do not work with normal ACPI C-states
even if the BIOS is advertising them. Limit the C-states to
C1 for the ACPI processor idle code.
Impact: hang which happens across CPU offline/online on AMD C1E systems.
When a CPU goes offline then the corresponding bit in the broadcast
mask is cleared. For AMD C1E enabled CPUs we do not reenable the
broadcast when the CPU comes online again as we do not clear the
corresponding bit in the c1e_mask, which keeps track which CPUs
have been switched to broadcast already. So on those !$@#& machines
we never switch back to broadcasting after a CPU offline/online cycle.
Clear the bit when the CPU plays dead.
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IPoIB: Fix deadlock on RTNL between bcast join comp and ipoib_stop()
RDMA/nes: Fix client side QP destroy
IB/mlx4: Fix up fast register page list format
mlx4_core: Set RAE and init mtt_sz field in FRMR MPT entries
this patch turns the netdev timeout WARN_ON_ONCE() into a WARN_ONCE(),
so that the device and driver names are inside the warning message.
This helps automated tools like kerneloops.org to collect the data
and do statistics, as well as making it more likely that humans
cut-n-paste the important message as part of a bugreport.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This fill fix the following regression list entry:
Bug-Entry : http://bugzilla.kernel.org/show_bug.cgi?id=11276
Subject : build error: CONFIG_OPTIMIZE_INLINING=y causes gcc 4.2 to do stupid things
Submitter : Randy Dunlap <randy.dunlap@oracle.com>
Date : 2008-08-06 17:18 (38 days old)
References : http://marc.info/?l=linux-kernel&m=121804329014332&w=4
http://lkml.org/lkml/2008/7/22/353
Handled-By : Bjorn Helgaas <bjorn.helgaas@hp.com>
Patch : http://lkml.org/lkml/2008/7/22/364
with what I believe is a better fix than the one referenced
in the regression entry above.
These PNP header interfaces try to work in such a way that
you can reference some of them even if PNP is not enabled,
and the compiler was expected to optimize everything away.
Which is mostly fine, except that there was one interface
for which there was not provided an inline "NOP" implementation.
Once we add that, all of these compile failures cannot handle
any more.
pnp: Provide NOP inline implementation of pnp_get_resource() when !PNP
Fixes kernel bugzilla #11276.
pci_get_subsys() changed in 2.6.26 so that the from pointer is modified
when the call is being invoked, so fix up the 'const' marking of it that
the compiler is complaining about.
Reported-by: Rufus & Azrael <rufus-azrael@numericable.fr>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Byte swap the addresses in the page list for fast register work requests
to big endian to match what the HCA expectx. Also, the addresses must
have the "present" bit set so that the HCA knows it can access them.
Otherwise the HCA will fault the first time it accesses the memory
region.
Signed-off-by: Vladimir Sokolovsky <vlad@mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
[libata] LBA28/LBA48 off-by-one bug in ata.h
sata_inic162x: enable LED blinking
ata: duplicate variable sparse warning
niu: panic on reset
netlink: fix overrun in attribute iteration
[Bluetooth] Fix regression from using default link policy
ath9k: Assign seq# when mac80211 requests this
- 8-bit interface mode never worked properly. The only adapter I have
which supports the 8b mode (the Jmicron) had some problems with its
clock wiring and they discovered it only now. We also discovered that
ProHG media is more sensitive to the ordering of initialization
commands.
- Make the driver fall back to highest supported mode instead of always
falling back to serial. The driver will attempt the switch to 8b mode
for any new MSPro card, but not all of them support it. Previously,
these new cards ended up in serial mode, which is not the best idea
(they work fine with 4b, after all).
- Edit some macros for better conformance to Sony documentation
Signed-off-by: Alex Dubov <oakad@yahoo.com>
The iterator for_each_zone_zonelist() uses a struct zoneref *z cursor when
scanning zonelists to keep track of where in the zonelist it is. The
zoneref that is returned corresponds to the the next zone that is to be
scanned, not the current one. It was intended to be treated as an opaque
list.
When the page allocator is scanning a zonelist, it marks elements in the
zonelist corresponding to zones that are temporarily full. As the
zonelist is being updated, it uses the cursor here;
if (NUMA_BUILD)
zlc_mark_zone_full(zonelist, z);
This is intended to prevent rescanning in the near future but the zoneref
cursor does not correspond to the zone that has been found to be full.
This is an easy misunderstanding to make so this patch corrects the
problem by changing zoneref cursor to be the current zone being scanned
instead of the next one.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Andy Whitcroft <apw@shadowen.org>
akpm: these have no callers at this time, but they shall soon, so let's
get them right.
Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
Cc: Tony Lindgren <tony@atomide.com>
I recently bought 3 HGST P7K500-series 500GB SATA drives and
had trouble accessing the block right on the LBA28-LBA48 border.
Here's how it fails (same for all 3 drives):
# dd if=/dev/sdc bs=512 count=1 skip=268435455 > /dev/null
dd: reading `/dev/sdc': Input/output error
0+0 records in
0+0 records out
0 bytes (0 B) copied, 0.288033 seconds, 0.0 kB/s
# dmesg
ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
ata1.00: BMDMA stat 0x25
ata1.00: cmd c8/00:08:f8:ff:ff/00:00:00:00:00/ef tag 0 dma 4096 in
res 51/04:08:f8:ff:ff/00:00:00:00:00/ef Emask 0x1 (device error)
ata1.00: status: { DRDY ERR }
ata1.00: error: { ABRT }
ata1.00: configured for UDMA/33
ata1: EH complete
After some investigations, it turned out this seems to be caused
by misinterpretation of the ATA specification on LBA28 access.
Following part is the code in question:
=== include/linux/ata.h ===
static inline int lba_28_ok(u64 block, u32 n_block)
/* check the ending block number */
return ((block + n_block - 1) < ((u64)1 << 28)) && (n_block <= 256);
HGST drive (sometimes) fails with LBA28 access of {block = 0xfffffff,
n_block = 1}, and this behavior seems to be comformant. Other drives,
including other HGST drives are not that strict, through.
>From the ATA specification:
(http://www.t13.org/Documents/UploadedDocuments/project/d1410r3b-ATA-ATAPI-6.pdf)
8.15.29 Word (61:60): Total number of user addressable sectors
This field contains a value that is one greater than the total number
of user addressable sectors (see 6.2). The maximum value that shall
be placed in this field is 0FFFFFFFh.
So the driver shouldn't use the value of 0xfffffff for LBA28 request
as this exceeds maximum user addressable sector. The logical maximum
value for LBA28 is 0xffffffe.
The obvious fix is to cut "- 1" part, and the patch attached just do
that. I've been using the patched kernel for about a month now, and
the same fix is also floating on the net for some time. So I believe
this fix works reliably.
Just FYI, many Windows/Intel platform users also seems to be struck
by this, and HGST has issued a note pointing to Intel ICH8/9 driver.
"28-bit LBA command is being used to access LBAs 29-bits in length"
http://www.hitachigst.com/hddt/knowtree.nsf/cffe836ed7c12018862565b000530c74/b531b8bce8745fb78825740f00580e23
Also, *BSDs seems to have similar fix included sometime around ~2004,
through I have not checked out exact portion of the code.
Signed-off-by: Taisuke Yamada <tai@rakugaki.org>
kmemcheck reported this:
kmemcheck: Caught 16-bit read from uninitialized memory (f6c1ba30)
0500110001508abf050010000500000002017300140000006f72672e66726565
i i i i i i i i i i i i i u u u u u u u u u u u u u u u u u u u
Pid: 3462, comm: wpa_supplicant Not tainted (2.6.27-rc3-00054-g6397ab9-dirty #13)
EIP: 0060:[<c05de64a>] EFLAGS: 00010296 CPU: 0
EIP is at nla_parse+0x5a/0xf0
EAX: 00000008 EBX: fffffffd ECX: c06f16c0 EDX: 00000005
ESI: 00000010 EDI: f6c1ba30 EBP: f6367c6c ESP: c0a11e88
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
CR0: 8005003b CR2: f781cc84 CR3: 3632f000 CR4: 000006d0
DR0: c0ead9bc DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff4ff0 DR7: 00000400
[<c05d4b23>] rtnl_setlink+0x63/0x130
[<c05d5f75>] rtnetlink_rcv_msg+0x165/0x200
[<c05ddf66>] netlink_rcv_skb+0x76/0xa0
[<c05d5dfe>] rtnetlink_rcv+0x1e/0x30
[<c05dda21>] netlink_unicast+0x281/0x290
[<c05ddbe9>] netlink_sendmsg+0x1b9/0x2b0
[<c05beef2>] sock_sendmsg+0xd2/0x100
[<c05bf945>] sys_sendto+0xa5/0xd0
[<c05bf9a6>] sys_send+0x36/0x40
[<c05c03d6>] sys_socketcall+0x1e6/0x2c0
[<c020353b>] sysenter_do_call+0x12/0x3f
[<ffffffff>] 0xffffffff
This is the line in nla_ok():
* nla_ok - check if the netlink attribute fits into the remaining bytes
* @nla: netlink attribute
* @remaining: number of bytes remaining in attribute stream
static inline int nla_ok(const struct nlattr *nla, int remaining)
return remaining >= sizeof(*nla) &&
nla->nla_len >= sizeof(*nla) &&
nla->nla_len <= remaining;
It turns out that remaining can become negative due to alignment in
nla_next(). But GCC promotes "remaining" to unsigned in the test
against sizeof(*nla) above. Therefore the test succeeds, and the
nla_for_each_attr() may access memory outside the received buffer.
A short example illustrating this point is here:
#include <stdio.h>
main(void)
printf("%d\n", -1 >= sizeof(int));
...which prints "1".
This patch adds a cast in front of the sizeof so that GCC will make
a signed comparison and fix the illegal memory dereference. With the
patch applied, there is no kmemcheck report.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: disable sysfs parts of the disk command filter
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] fix check of PQ and PDT bits for WLUNs
[SCSI] make scsi_check_sense HARDWARE_ERROR return ADD_TO_MLQUEUE on retry
[SCSI] scsi_dh: make check_sense return ADD_TO_MLQUEUE
[SCSI] zfcp: Remove duplicated unlikely() macros.
[SCSI] zfcp: channel cannot be detached due to refcount imbalance
[SCSI] zfcp: Fix reference counter for remote ports
[SCSI] zfcp: Simplify ccw notify handler
[SCSI] zfcp: Correctly query end flag in gpn_ft response
[SCSI] zfcp: Fix request queue locking
[SCSI] sd: select CRC_T10DIF only when necessary
We still have life time issues with the sysfs command filter kobject,
so disable it for 2.6.27 release. We can revisit this and make it work
properly for 2.6.28, for 2.6.27 release it's too risky.
ipv6: Fix OOPS in ip6_dst_lookup_tail().
ipsec: Restore larval states and socket policies in dump
[Bluetooth] Reject L2CAP connections on an insecure ACL link
[Bluetooth] Enforce correct authentication requirements
[Bluetooth] Fix reference counting during ACL config stage
It was introduced by "vsprintf: add support for '%pS' and '%pF' pointer
formats" in commit 0fe1ef24f7bd0020f29ffe287dfdb9ead33ca0b2. However,
the current way its coded doesn't work on parisc64. For two reasons: 1)
parisc isn't in the #ifdef and 2) parisc has a different format for
function descriptors
Make dereference_function_descriptor() more accommodating by allowing
architecture overrides. I put the three overrides (for parisc64, ppc64
and ia64) in arch/kernel/module.c because that's where the kernel
internal linker which knows how to deal with function descriptors sits.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
The Security Mode 4 of the Bluetooth 2.1 specification has strict
authentication and encryption requirements. It is the initiators job
to create a secure ACL link. However in case of malicious devices, the
acceptor has to make sure that the ACL is encrypted before allowing
any kind of L2CAP connection. The only exception here is the PSM 1 for
the service discovery protocol, because that is allowed to run on an
insecure ACL link.
Previously it was enough to reject a L2CAP connection during the
connection setup phase, but with Bluetooth 2.1 it is forbidden to
do any L2CAP protocol exchange on an insecure link (except SDP).
The new hci_conn_check_link_mode() function can be used to check the
integrity of an ACL link. This functions also takes care of the cases
where Security Mode 4 is disabled or one of the devices is based on
an older specification.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
With the introduction of Security Mode 4 and Simple Pairing from the
Bluetooth 2.1 specification it became mandatory that the initiator
requires authentication and encryption before any L2CAP channel can
be established. The only exception here is PSM 1 for the service
discovery protocol (SDP). It is meant to be used without any encryption
since it contains only public information. This is how Bluetooth 2.0
and before handle connections on PSM 1.
For Bluetooth 2.1 devices the pairing procedure differentiates between
no bonding, general bonding and dedicated bonding. The L2CAP layer
wrongly uses always general bonding when creating new connections, but it
should not do this for SDP connections. In this case the authentication
requirement should be no bonding and the just-works model should be used,
but in case of non-SDP connection it is required to use general bonding.
If the new connection requires man-in-the-middle (MITM) protection, it
also first wrongly creates an unauthenticated link key and then later on
requests an upgrade to an authenticated link key to provide full MITM
protection. With Simple Pairing the link key generation is an expensive
operation (compared to Bluetooth 2.0 and before) and doing this twice
during a connection setup causes a noticeable delay when establishing
a new connection. This should be avoided to not regress from the expected
Bluetooth 2.0 connection times. The authentication requirements are known
up-front and so enforce them.
To fulfill these requirements the hci_connect() function has been extended
with an authentication requirement parameter that will be stored inside
the connection information and can be retrieved by userspace at any
time. This allows the correct IO capabilities exchange and results in
the expected behavior.
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: arch_reinit_sched_domains() must destroy domains to force rebuild
sched, cpuset: rework sched domains and CPU hotplug handling (v4)
bridge: don't allow setting hello time to zero
netns : fix kernel panic in timewait socket destruction
pkt_sched: Fix qdisc state in net_tx_action()
netfilter: nf_conntrack_irc: make sure string is terminated before calling simple_strtoul
netfilter: nf_conntrack_gre: nf_ct_gre_keymap_flush() fixlet
netfilter: nf_conntrack_gre: more locking around keymap list
netfilter: nf_conntrack_sip: de-static helper pointers
