path: root/include
2016-05-28Merge branch 'hash' of git://ftp.sciencehorizons.net/linuxLinus Torvalds
Pull string hash improvements from George Spelvin: "This series does several related things: - Makes the dcache hash (fs/namei.c) useful for general kernel use. (Thanks to Bruce for noticing the zero-length corner case) - Converts the string hashes in <linux/sunrpc/svcauth.h> to use the above. - Avoids 64-bit multiplies in hash_64() on 32-bit platforms. Two 32-bit multiplies will do well enough. - Rids the world of the bad hash multipliers in hash_32. This finishes the job started in commit 689de1d6ca95 ("Minimal fix-up of bad hashing behavior of hash_64()") The vast majority of Linux architectures have hardware support for 32x32-bit multiply and so derive no benefit from "simplified" multipliers. The few processors that do not (68000, h8/300 and some models of Microblaze) have arch-specific implementations added. Those patches are last in the series. - Overhauls the dcache hash mixing. The patch in commit 0fed3ac866ea ("namei: Improve hash mixing if CONFIG_DCACHE_WORD_ACCESS") was an off-the-cuff suggestion. Replaced with a much more careful design that's simultaneously faster and better. (My own invention, as there was noting suitable in the literature I could find. Comments welcome!) - Modify the hash_name() loop to skip the initial HASH_MIX(). This would let us salt the hash if we ever wanted to. - Sort out partial_name_hash(). The hash function is declared as using a long state, even though it's truncated to 32 bits at the end and the extra internal state contributes nothing to the result. And some callers do odd things: - fs/hfs/string.c only allocates 32 bits of state - fs/hfsplus/unicode.c uses it to hash 16-bit unicode symbols not bytes - Modify bytemask_from_count to handle inputs of 1..sizeof(long) rather than 0..sizeof(long)-1. This would simplify users other than full_name_hash" Special thanks to Bruce Fields for testing and finding bugs in v1. (I learned some humbling lessons about "obviously correct" code.) On the arch-specific front, the m68k assembly has been tested in a standalone test harness, I've been in contact with the Microblaze maintainers who mostly don't care, as the hardware multiplier is never omitted in real-world applications, and I haven't heard anything from the H8/300 world" * 'hash' of git://ftp.sciencehorizons.net/linux: h8300: Add <asm/hash.h> microblaze: Add <asm/hash.h> m68k: Add <asm/hash.h> <linux/hash.h>: Add support for architecture-specific functions fs/namei.c: Improve dcache hash function Eliminate bad hash multipliers from hash_32() and hash_64() Change hash_64() return value to 32 bits <linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string() fs/namei.c: Add hashlen_string() function Pull out string hash to <linux/stringhash.h>
2016-05-28<linux/hash.h>: Add support for architecture-specific functionsGeorge Spelvin
This is just the infrastructure; there are no users yet. This is modelled on CONFIG_ARCH_RANDOM; a CONFIG_ symbol declares the existence of <asm/hash.h>. That file may define its own versions of various functions, and define HAVE_* symbols (no CONFIG_ prefix!) to suppress the generic ones. Included is a self-test (in lib/test_hash.c) that verifies the basics. It is NOT in general required that the arch-specific functions compute the same thing as the generic, but if a HAVE_* symbol is defined with the value 1, then equality is tested. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Philippe De Muyter <phdm@macq.eu> Cc: linux-m68k@lists.linux-m68k.org Cc: Alistair Francis <alistai@xilinx.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp
2016-05-28Eliminate bad hash multipliers from hash_32() and hash_64()George Spelvin
The "simplified" prime multipliers made very bad hash functions, so get rid of them. This completes the work of 689de1d6ca. To avoid the inefficiency which was the motivation for the "simplified" multipliers, hash_64() on 32-bit systems is changed to use a different algorithm. It makes two calls to hash_32() instead. drivers/media/usb/dvb-usb-v2/af9015.c uses the old GOLDEN_RATIO_PRIME_32 for some horrible reason, so it inherits a copy of the old definition. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Antti Palosaari <crope@iki.fi> Cc: Mauro Carvalho Chehab <m.chehab@samsung.com>
2016-05-28Change hash_64() return value to 32 bitsGeorge Spelvin
That's all that's ever asked for, and it makes the return type of hash_long() consistent. It also allows (upcoming patch) an optimized implementation of hash_64 on 32-bit machines. I tried adding a BUILD_BUG_ON to ensure the number of bits requested was never more than 32 (most callers use a compile-time constant), but adding <linux/bug.h> to <linux/hash.h> breaks the tools/perf compiler unless tools/perf/MANIFEST is updated, and understanding that code base well enough to update it is too much trouble. I did the rest of an allyesconfig build with such a check, and nothing tripped. Signed-off-by: George Spelvin <linux@sciencehorizons.net>
2016-05-28<linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string()George Spelvin
Finally, the first use of previous two patches: eliminate the separate ad-hoc string hash functions in the sunrpc code. Now hash_str() is a wrapper around hash_string(), and hash_mem() is likewise a wrapper around full_name_hash(). Note that sunrpc code *does* call hash_mem() with a zero length, which is why the previous patch needed to handle that in full_name_hash(). (Thanks, Bruce, for finding that!) This also eliminates the only caller of hash_long which asks for more than 32 bits of output. The comment about the quality of hashlen_string() and full_name_hash() is jumping the gun by a few patches; they aren't very impressive now, but will be improved greatly later in the series. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Tested-by: J. Bruce Fields <bfields@redhat.com> Acked-by: J. Bruce Fields <bfields@redhat.com> Cc: Jeff Layton <jlayton@poochiereds.net> Cc: linux-nfs@vger.kernel.org
2016-05-28fs/namei.c: Add hashlen_string() functionGeorge Spelvin
We'd like to make more use of the highly-optimized dcache hash functions throughout the kernel, rather than have every subsystem create its own, and a function that hashes basic null-terminated strings is required for that. (The name is to emphasize that it returns both hash and length.) It's actually useful in the dcache itself, specifically d_alloc_name(). Other uses in the next patch. full_name_hash() is also tweaked to make it more generally useful: 1) Take a "char *" rather than "unsigned char *" argument, to be consistent with hash_name(). 2) Handle zero-length inputs. If we want more callers, we don't want to make them worry about corner cases. Signed-off-by: George Spelvin <linux@sciencehorizons.net>
2016-05-28Pull out string hash to <linux/stringhash.h>George Spelvin
... so they can be used without the rest of <linux/dcache.h> The hashlen_* macros will make sense next patch. Signed-off-by: George Spelvin <linux@sciencehorizons.net>
2016-05-28Merge tag 'chrome-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform Pull chrome platform updates from Olof Johansson "A handful of Chrome driver and binding changes this merge window: - a few patches to fix probing and configuration of pstore - a few patches adding Elan touchpad registration on a few devices - EC changes: a security fix dealing with max message sizes and addition of compat_ioctl support. - keyboard backlight control support There was also an accidential duplicate registration of trackpads on 'Leon', which was reverted just recently" * tag 'chrome-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform: Revert "platform/chrome: chromeos_laptop: Add Leon Touch" platform/chrome: chromeos_laptop - Add Elan touchpad for Wolf platform/chrome: chromeos_laptop - Add elan trackpad option for C720 platform/chrome: cros_ec_dev - Populate compat_ioctl platform/chrome: cros_ec_lightbar - use name instead of ID to hide lightbar attributes platform/chrome: cros_ec_dev - Fix security issue platform/chrome: Add Chrome OS keyboard backlight LEDs support platform/chrome: use to_platform_device() platform/chrome: pstore: Move to larger record size. platform/chrome: pstore: probe for ramoops buffer using acpi platform/chrome: chromeos_laptop: Add Leon Touch
2016-05-28Merge tag 'sound-4.7-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull more sound updates from Takashi Iwai: "This is the second update round for 4.7-rc1. Most of changes are about the pending ASoC updates and fixes, including a few new drivers. Below are some highlights: ASoC: - New drivers for MAX98371 and TAS5720 - SPI support for TLV320AIC32x4, along with the module split - TDM support for STI Uniperf IPs - Remaining topology API fixes / updates HDA: - A couple of Dell quirks and new Realtek codec support" * tag 'sound-4.7-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (63 commits) ALSA: hda - Fix headset mic detection problem for one Dell machine spi: spi-ep93xx: Fix the PTR_ERR() argument ALSA: hda/realtek - Add support for ALC295/ALC3254 ASoC: kirkwood: fix build failure ALSA: hda - Fix headphone noise on Dell XPS 13 9360 ASoC: ak4642: Enable cache usage to fix crashes on resume ASoC: twl6040: Disconnect AUX output pads on digital mute ASoC: tlv320aic32x4: Properly implement the positive and negative pins into the mixers rcar: src: skip disabled-SRC nodes ASoC: max98371 Remove duplicate entry in max98371_reg ASoC: twl6040: Select LPPLL during standby ASoC: rsnd: don't use prohibited number to PDMACHCRn.SRS ASoC: simple-card: Add pm callbacks to platform driver ASoC: pxa: Fix module autoload for platform drivers ASoC: topology: Fix memory leak in widget creation ASoC: Add max98371 codec driver ASoC: rsnd: count .probe/.remove for rsnd_mod_call() ASoC: topology: Check size mismatch of ABI objects before parsing ASoC: topology: Check failure to create a widget ASoC: add support for TAS5720 digital amplifier ...
2016-05-28Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Here are the outstanding target pending updates for v4.7-rc1. The highlights this round include: - Allow external PR/ALUA metadata path be defined at runtime via top level configfs attribute (Lee) - Fix target session shutdown bug for ib_srpt multi-channel (hch) - Make TFO close_session() and shutdown_session() optional (hch) - Drop se_sess->sess_kref + convert tcm_qla2xxx to internal kref (hch) - Add tcm_qla2xxx endpoint attribute for basic FC jammer (Laurence) - Refactor iscsi-target RX/TX PDU encode/decode into common code (Varun) - Extend iscsit_transport with xmit_pdu, release_cmd, get_rx_pdu, validate_parameters, and get_r2t_ttt for generic ISO offload (Varun) - Initial merge of cxgb iscsi-segment offload target driver (Varun) The bulk of the changes are Chelsio's new driver, along with a number of iscsi-target common code improvements made by Varun + Co along the way" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (29 commits) iscsi-target: Fix early sk_data_ready LOGIN_FLAGS_READY race cxgbit: Use type ISCSI_CXGBIT + cxgbit tpg_np attribute iscsi-target: Convert transport drivers to signal rdma_shutdown iscsi-target: Make iscsi_tpg_np driver show/store use generic code tcm_qla2xxx Add SCSI command jammer/discard capability iscsi-target: graceful disconnect on invalid mapping to iovec target: need_to_release is always false, remove redundant check and kfree target: remove sess_kref and ->shutdown_session iscsi-target: remove usage of ->shutdown_session tcm_qla2xxx: introduce a private sess_kref target: make close_session optional target: make ->shutdown_session optional target: remove acl_stop target: consolidate and fix session shutdown cxgbit: add files for cxgbit.ko iscsi-target: export symbols iscsi-target: call complete on conn_logout_comp iscsi-target: clear tx_thread_active iscsi-target: add new offload transport type iscsi-target: use conn_transport->transport_type in text rsp ...
2016-05-28Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull more rdma updates from Doug Ledford: "This is the second group of code for the 4.7 merge window. It looks large, but only in one sense. I'll get to that in a minute. The list of changes here breaks down as follows: - Dynamic counter infrastructure in the IB drivers This is a sysfs based code to allow free form access to the hardware counters RDMA devices might support so drivers don't need to code this up repeatedly themselves - SendOnlyFullMember multicast support - IB router support - A couple misc fixes - The big item on the list: hfi1 driver updates, plus moving the hfi1 driver out of staging There was a group of 15 patches in the hfi1 list that I thought I had in the first pull request but they weren't. So that added to the length of the hfi1 section here. As far as these go, everything but the hfi1 is pretty straight forward. The hfi1 is, if you recall, the driver that Al had complaints about how it used the write/writev interfaces in an overloaded fashion. The write portion of their interface behaved like the write handler in the IB stack proper and did bi-directional communications. The writev interface, on the other hand, only accepts SDMA request structures. The completions for those structures are sent back via an entirely different event mechanism. With the security patch, we put security checks on the write interface, however, we also knew they would be going away soon. Now, we've converted the write handler in the hfi1 driver to use ioctls from the IB reserved magic area for its bidirectional communications. With that change, Intel has addressed all of the items originally on their TODO when they went into staging (as well as many items added to the list later). As such, I moved them out, and since they were the last item in the staging/rdma directory, and I don't have immediate plans to use the staging area again, I removed the staging/rdma area. Because of the move out of staging, as well as a series of 5 patches in the hfi1 driver that removed code people thought should be done in a different way and was optional to begin with (a snoop debug interface, an eeprom driver for an eeprom connected directory to their hfi1 chip and not via an i2c bus, and a few other things like that), the line count, especially the removal count, is high" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (56 commits) staging/rdma: Remove the entire rdma subdirectory of staging IB/core: Make device counter infrastructure dynamic IB/hfi1: Fix pio map initialization IB/hfi1: Correct 8051 link parameter settings IB/hfi1: Update pkey table properly after link down or FM start IB/rdamvt: Fix rdmavt s_ack_queue sizing IB/rdmavt: Max atomic value should be a u8 IB/hfi1: Fix hard lockup due to not using save/restore spin lock IB/hfi1: Add tracing support for send with invalidate opcode IB/hfi1, qib: Add ieth to the packet header definitions IB/hfi1: Move driver out of staging IB/hfi1: Do not free hfi1 cdev parent structure early IB/hfi1: Add trace message in user IOCTL handling IB/hfi1: Remove write(), use ioctl() for user cmds IB/hfi1: Add ioctl() interface for user commands IB/hfi1: Remove unused user command IB/hfi1: Remove snoop/diag interface IB/hfi1: Remove EPROM functionality from data device IB/hfi1: Remove UI char device IB/hfi1: Remove multiple device cdev ...
2016-05-27Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull more i2c updates from Wolfram Sang: "Here is the second pull request from I2C for this merge window: - one new feature (which nearly fell through the cracks): i2c-dev does now use the cdev API so it can handle >256 minors. Seems people do need that. - two fixes for the just added DMA feature for i2c-rcar - some typo fixes" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: dev: don't start function name with 'return' i2c: dev: switch from register_chrdev to cdev API i2c: xlr: rename ARCH_TANGOX to ARCH_TANGO i2c: at91: change log when dma configuration fails misc: at24: Fix typo in at24 header file i2c: rcar: should depend on HAS_DMA i2c: rcar: use dma_request_chan()
2016-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Followups to the parallel lookup work: - update docs - restore killability of the places that used to take ->i_mutex killably now that we have down_write_killable() merged - Additionally, it turns out that I missed a prerequisite for security_d_instantiate() stuff - ->getxattr() wasn't the only thing that could be called before dentry is attached to inode; with smack we needed the same treatment applied to ->setxattr() as well" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch ->setxattr() to passing dentry and inode separately switch xattr_handler->set() to passing dentry and inode separately restore killability of old mutex_lock_killable(&inode->i_mutex) users add down_write_killable_nested() update D/f/directory-locking
2016-05-27switch ->setxattr() to passing dentry and inode separatelyAl Viro
smack ->d_instantiate() uses ->setxattr(), so to be able to call it before we'd hashed the new dentry and attached it to inode, we need ->setxattr() instances getting the inode as an explicit argument rather than obtaining it from dentry. Similar change for ->getxattr() had been done in commit ce23e64. Unlike ->getxattr() (which is used by both selinux and smack instances of ->d_instantiate()) ->setxattr() is used only by smack one and unfortunately it got missed back then. Reported-by: Seung-Woo Kim <sw0312.kim@samsung.com> Tested-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-27make IS_ERR_VALUE() complain about non-pointer-sized argumentsLinus Torvalds
Now that the allmodconfig x86-64 build is clean wrt IS_ERR_VALUE() uses on integers, add a cast to a pointer and back to the argument, so that any new mis-uses of IS_ERR_VALUE() will cause warnings like warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] so that we don't re-introduce any bogus uses. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-27mm: remove more IS_ERR_VALUE abusesLinus Torvalds
The do_brk() and vm_brk() return value was "unsigned long" and returned the starting address on success, and an error value on failure. The reasons are entirely historical, and go back to it basically behaving like the mmap() interface does. However, nobody actually wanted that interface, and it causes totally pointless IS_ERR_VALUE() confusion. What every single caller actually wants is just the simpler integer return of zero for success and negative error number on failure. So just convert to that much clearer and more common calling convention, and get rid of all the IS_ERR_VALUE() uses wrt vm_brk(). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-27mm: fix section mismatch warningLinus Torvalds
The register_page_bootmem_info_node() function needs to be marked __init in order to avoid a new warning introduced by commit f65e91df25aa ("mm: use early_pfn_to_nid in register_page_bootmem_info_node"). Otherwise you'll get a warning about how a non-init function calls early_pfn_to_nid (which is __meminit) Cc: Yang Shi <yang.shi@linaro.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-27Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A set of fixes that wasn't included in the first merge window pull request. This pull request contains: - A set of NVMe fixes from Keith, and one from Nic for the integrity side of it. - Fix from Ming, clearing ->mq_ops if we don't successfully setup a queue for multiqueue. - A set of stability fixes for bcache from Jiri, and also marking bcache as orphaned as it's no longer actively maintained (in mainline, at least)" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: clear q->mq_ops if init fail MAINTAINERS: mark bcache as orphan bcache: bch_gc_thread() is not freezable bcache: bch_allocator_thread() is not freezable bcache: bch_writeback_thread() is not freezable nvme/host: Add missing blk_integrity tag_size + flags assignments NVMe: Add device ID's with stripe quirk NVMe: Short-cut removal on surprise hot-unplug NVMe: Allow user initiated rescan NVMe: Reduce driver log spamming NVMe: Unbind driver on failure NVMe: Delete only created queues NVMe: Allocate queues only for online cpus
2016-05-27Merge tag 'drm-fixes-v4.7-rc1' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: - one IMX built-in regression fix - a set of amdgpu fixes, mostly powerplay and polaris GPU stuff - a set of i915 fixes all over, many cc'ed to stable. The i915 batch contain support for DP++ dongle detection, which is used to fix some regressions in the HDMI color depth area * tag 'drm-fixes-v4.7-rc1' of git://people.freedesktop.org/~airlied/linux: (44 commits) drm/amd: add Kconfig dependency for ACP on DRM_AMDGPU drm/amdgpu: Fix hdmi deep color support. drm/amdgpu: fix bug in fence driver fini drm/i915: Stop automatically retiring requests after a GPU hang drm/i915: Unify intel_ring_begin() drm/i915: Ignore stale wm register values on resume on ilk-bdw (v2) drm/i915/psr: Try to program link training times correctly drm/imx: Match imx-ipuv3-crtc components using device node in platform data drm/i915/bxt: Adjusting the error in horizontal timings retrieval drm/i915: Don't leave old junk in ilk active watermarks on readout drm/i915: s/DPPL/DPLL/ for SKL DPLLs drm/i915: Fix gen8 semaphores id for legacy mode drm/i915: Set crtc_state->lane_count for HDMI drm/i915/BXT: Retrieving the horizontal timing for DSI drm/i915: Protect gen7 irq_seqno_barrier with uncore lock drm/i915: Re-enable GGTT earlier during resume on pre-gen6 platforms drm/i915: Determine DP++ type 1 DVI adaptor presence based on VBT drm/i915: Enable/disable TMDS output buffers in DP++ adaptor as needed drm/i915: Respect DP++ adaptor TMDS clock limit drm: Add helper for DP++ adaptors ...
2016-05-27Merge git://git.infradead.org/intel-iommuLinus Torvalds
Pull intel IOMMU updates from David Woodhouse: "This patchset improves the scalability of the Intel IOMMU code by resolving two spinlock bottlenecks and eliminating the linearity of the IOVA allocator, yielding up to ~5x performance improvement and approaching 'iommu=off' performance" * git://git.infradead.org/intel-iommu: iommu/vt-d: Use per-cpu IOVA caching iommu/iova: introduce per-cpu caching to iova allocation iommu/vt-d: change intel-iommu to use IOVA frame numbers iommu/vt-d: avoid dev iotlb logic for domains with no dev iotlbs iommu/vt-d: only unmap mapped entries iommu/vt-d: correct flush_unmaps pfn usage iommu/vt-d: per-cpu deferred invalidation queues iommu/vt-d: refactoring of deferred flush entries
2016-05-27Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull second batch of KVM updates from Radim Krčmář: "General: - move kvm_stat tool from QEMU repo into tools/kvm/kvm_stat (kvm_stat had nothing to do with QEMU in the first place -- the tool only interprets debugfs) - expose per-vm statistics in debugfs and support them in kvm_stat (KVM always collected per-vm statistics, but they were summarised into global statistics) x86: - fix dynamic APICv (VMX was improperly configured and a guest could access host's APIC MSRs, CVE-2016-4440) - minor fixes ARM changes from Christoffer Dall: - new vgic reimplementation of our horribly broken legacy vgic implementation. The two implementations will live side-by-side (with the new being the configured default) for one kernel release and then we'll remove the legacy one. - fix for a non-critical issue with virtual abort injection to guests" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (70 commits) tools: kvm_stat: Add comments tools: kvm_stat: Introduce pid monitoring KVM: Create debugfs dir and stat files for each VM MAINTAINERS: Add kvm tools tools: kvm_stat: Powerpc related fixes tools: Add kvm_stat man page tools: Add kvm_stat vm monitor script kvm:vmx: more complete state update on APICv on/off KVM: SVM: Add more SVM_EXIT_REASONS KVM: Unify traced vector format svm: bitwise vs logical op typo KVM: arm/arm64: vgic-new: Synchronize changes to active state KVM: arm/arm64: vgic-new: enable build KVM: arm/arm64: vgic-new: implement mapped IRQ handling KVM: arm/arm64: vgic-new: Wire up irqfd injection KVM: arm/arm64: vgic-new: Add vgic_v2/v3_enable KVM: arm/arm64: vgic-new: vgic_init: implement map_resources KVM: arm/arm64: vgic-new: vgic_init: implement vgic_init KVM: arm/arm64: vgic-new: vgic_init: implement vgic_create KVM: arm/arm64: vgic-new: vgic_init: implement kvm_vgic_hyp_init ...
2016-05-27switch xattr_handler->set() to passing dentry and inode separatelyAl Viro
preparation for similar switch in ->setxattr() (see the next commit for rationale). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-27Merge tag 'asoc-v4.7-2' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v4.7 part 2 Really sorry about this late pull request. It looks like at the time I sent my pull request for v4.7 there was some conflict or other issue which caused my script to stop merging the ASoC branches at some point after the HDMI changes. It's all specific driver updates, including: - New drivers for MAX98371 and TAS5720. - SPI support for TLV320AIC32x4. - TDM support for STI Uniperf IPs. This code should all have been in -next prior to the merge window apart from some fixes, it dropped out on the 18th.
2016-05-27Merge remote-tracking branch 'asoc/topic/topology' into asoc-nextMark Brown
2016-05-27Merge tag 'drm-intel-next-fixes-2016-05-25' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next I see the main drm pull got merged, here's the first batch of fixes for 4.7 already. Fixes all around, a large portion cc: stable stuff. [airlied: the DP++ stuff is a regression fix]. * tag 'drm-intel-next-fixes-2016-05-25' of git://anongit.freedesktop.org/drm-intel: drm/i915: Stop automatically retiring requests after a GPU hang drm/i915: Unify intel_ring_begin() drm/i915: Ignore stale wm register values on resume on ilk-bdw (v2) drm/i915/psr: Try to program link training times correctly drm/i915/bxt: Adjusting the error in horizontal timings retrieval drm/i915: Don't leave old junk in ilk active watermarks on readout drm/i915: s/DPPL/DPLL/ for SKL DPLLs drm/i915: Fix gen8 semaphores id for legacy mode drm/i915: Set crtc_state->lane_count for HDMI drm/i915/BXT: Retrieving the horizontal timing for DSI drm/i915: Protect gen7 irq_seqno_barrier with uncore lock drm/i915: Re-enable GGTT earlier during resume on pre-gen6 platforms drm/i915: Determine DP++ type 1 DVI adaptor presence based on VBT drm/i915: Enable/disable TMDS output buffers in DP++ adaptor as needed drm/i915: Respect DP++ adaptor TMDS clock limit drm: Add helper for DP++ adaptors
2016-05-26Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - new option CONFIG_TRIM_UNUSED_KSYMS which does a two-pass build and unexports symbols which are not used in the current config [Nicolas Pitre] - several kbuild rule cleanups [Masahiro Yamada] - warning option adjustments for gcov etc [Arnd Bergmann] - a few more small fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (31 commits) kbuild: move -Wunused-const-variable to W=1 warning level kbuild: fix if_change and friends to consider argument order kbuild: fix adjust_autoksyms.sh for modules that need only one symbol kbuild: fix ksym_dep_filter when multiple EXPORT_SYMBOL() on the same line gcov: disable -Wmaybe-uninitialized warning gcov: disable tree-loop-im to reduce stack usage gcov: disable for COMPILE_TEST Kbuild: disable 'maybe-uninitialized' warning for CONFIG_PROFILE_ALL_BRANCHES Kbuild: change CC_OPTIMIZE_FOR_SIZE definition kbuild: forbid kernel directory to contain spaces and colons kbuild: adjust ksym_dep_filter for some cmd_* renames kbuild: Fix dependencies for final vmlinux link kbuild: better abstract vmlinux sequential prerequisites kbuild: fix call to adjust_autoksyms.sh when output directory specified kbuild: Get rid of KBUILD_STR kbuild: rename cmd_as_s_S to cmd_cpp_s_S kbuild: rename cmd_cc_i_c to cmd_cpp_i_c kbuild: drop redundant "PHONY += FORCE" kbuild: delete unnecessary "@:" kbuild: mark help target as PHONY ...
2016-05-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fixes from Andrew Morton: "10 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: drivers/pinctrl/intel/pinctrl-baytrail.c: fix build with gcc-4.4 update "mm/zsmalloc: don't fail if can't create debugfs info" dma-debug: avoid spinlock recursion when disabling dma-debug mm: oom_reaper: remove some bloat memcg: fix mem_cgroup_out_of_memory() return value. ocfs2: fix improper handling of return errno mm: slub: remove unused virt_to_obj() mm: kasan: remove unused 'reserved' field from struct kasan_alloc_meta mm: make CONFIG_DEFERRED_STRUCT_PAGE_INIT depends on !FLATMEM explicitly seqlock: fix raw_read_seqcount_latch()
2016-05-26Merge tag 'dax-locking-for-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull DAX locking updates from Ross Zwisler: "Filesystem DAX locking for 4.7 - We use a bit in an exceptional radix tree entry as a lock bit and use it similarly to how page lock is used for normal faults. This fixes races between hole instantiation and read faults of the same index. - Filesystem DAX PMD faults are disabled, and will be re-enabled when PMD locking is implemented" * tag 'dax-locking-for-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: dax: Remove i_mmap_lock protection dax: Use radix tree entry lock to protect cow faults dax: New fault locking dax: Allow DAX code to replace exceptional entries dax: Define DAX lock bit for radix tree exceptional entry dax: Make huge page handling depend of CONFIG_BROKEN dax: Fix condition for filling of PMD holes
2016-05-26Merge tag 'dax-misc-for-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull misc DAX updates from Vishal Verma: "DAX error handling for 4.7 - Until now, dax has been disabled if media errors were found on any device. This enables the use of DAX in the presence of these errors by making all sector-aligned zeroing go through the driver. - The driver (already) has the ability to clear errors on writes that are sent through the block layer using 'DSMs' defined in ACPI 6.1. Other misc changes: - When mounting DAX filesystems, check to make sure the partition is page aligned. This is a requirement for DAX, and previously, we allowed such unaligned mounts to succeed, but subsequent reads/writes would fail. - Misc/cleanup fixes from Jan that remove unused code from DAX related to zeroing, writeback, and some size checks" * tag 'dax-misc-for-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: dax: fix a comment in dax_zero_page_range and dax_truncate_page dax: for truncate/hole-punch, do zeroing through the driver if possible dax: export a low-level __dax_zero_page_range helper dax: use sb_issue_zerout instead of calling dax_clear_sectors dax: enable dax in the presence of known media errors (badblocks) dax: fallback from pmd to pte on error block: Update blkdev_dax_capable() for consistency xfs: Add alignment check for DAX mount ext2: Add alignment check for DAX mount ext4: Add alignment check for DAX mount block: Add bdev_dax_supported() for dax mount checks block: Add vfs_msg() interface dax: Remove redundant inode size checks dax: Remove pointless writeback from dax_do_io() dax: Remove zeroing from dax_io() dax: Remove dead zeroing code from fault handlers ext2: Avoid DAX zeroing to corrupt data ext2: Fix block zeroing in ext2_get_blocks() for DAX dax: Remove complete_unwritten argument DAX: move RADIX_DAX_ definitions to dax.c
2016-05-26mm: oom_reaper: remove some bloatMichal Hocko
mmput_async is currently used only from the oom_reaper which is defined only for CONFIG_MMU. We can save work_struct in mm_struct for !CONFIG_MMU. [akpm@linux-foundation.org: fix typo, per Minchan] Link: http://lkml.kernel.org/r/20160520061658.GB19172@dhcp22.suse.cz Reported-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-26mm: slub: remove unused virt_to_obj()Andrey Ryabinin
It's unused since commit 7ed2f9e66385 ("mm, kasan: SLAB support") Link: http://lkml.kernel.org/r/1464020961-2242-1-git-send-email-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-26seqlock: fix raw_read_seqcount_latch()Alexey Dobriyan
lockless_dereference() is supposed to take pointer not integer. Link: http://lkml.kernel.org/r/20160521201448.GA7429@p183.telecom.by Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates from Sage Weil: "This changeset has a few main parts: - Ilya has finished a huge refactoring effort to sync up the client-side logic in libceph with the user-space client code, which has evolved significantly over the last couple years, with lots of additional behaviors (e.g., how requests are handled when cluster is full and transitions from full to non-full). This structure of the code is more closely aligned with userspace now such that it will be much easier to maintain going forward when behavior changes take place. There are some locking improvements bundled in as well. - Zheng adds multi-filesystem support (multiple namespaces within the same Ceph cluster) - Zheng has changed the readdir offsets and directory enumeration so that dentry offsets are hash-based and therefore stable across directory fragmentation events on the MDS. - Zheng has a smorgasbord of bug fixes across fs/ceph" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (71 commits) ceph: fix wake_up_session_cb() ceph: don't use truncate_pagecache() to invalidate read cache ceph: SetPageError() for writeback pages if writepages fails ceph: handle interrupted ceph_writepage() ceph: make ceph_update_writeable_page() uninterruptible libceph: make ceph_osdc_wait_request() uninterruptible ceph: handle -EAGAIN returned by ceph_update_writeable_page() ceph: make fault/page_mkwrite return VM_FAULT_OOM for -ENOMEM ceph: block non-fatal signals for fault/page_mkwrite ceph: make logical calculation functions return bool ceph: tolerate bad i_size for symlink inode ceph: improve fragtree change detection ceph: keep leaf frag when updating fragtree ceph: fix dir_auth check in ceph_fill_dirfrag() ceph: don't assume frag tree splits in mds reply are sorted ceph: fix inode reference leak ceph: using hash value to compose dentry offset ceph: don't forbid marking directory complete after forward seek ceph: record 'offset' for each entry of readdir result ceph: define 'end/complete' in readdir reply as bit flags ...
2016-05-26misc: at24: Fix typo in at24 header fileMoritz Fischer
This commit fixes a simple typo s/mvmem/nvmem in the example. Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2016-05-26Merge tag 'nfs-for-4.7-1' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client updates from Anna Schumaker: "Highlights include: Features: - Add support for the NFS v4.2 COPY operation - Add support for NFS/RDMA over IPv6 Bugfixes and cleanups: - Avoid race that crashes nfs_init_commit() - Fix oops in callback path - Fix LOCK/OPEN race when unlinking an open file - Choose correct stateids when using delegations in setattr, read and write - Don't send empty SETATTR after OPEN_CREATE - xprtrdma: Prevent server from writing a reply into memory client has released - xprtrdma: Support using Read list and Reply chunk in one RPC call" * tag 'nfs-for-4.7-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (61 commits) pnfs: pnfs_update_layout needs to consider if strict iomode checking is on nfs/flexfiles: Use the layout segment for reading unless it a IOMODE_RW and reading is disabled nfs/flexfiles: Helper function to detect FF_FLAGS_NO_READ_IO nfs: avoid race that crashes nfs_init_commit NFS: checking for NULL instead of IS_ERR() in nfs_commit_file() pnfs: make pnfs_layout_process more robust pnfs: rework LAYOUTGET retry handling pnfs: lift retry logic from send_layoutget to pnfs_update_layout pnfs: fix bad error handling in send_layoutget flexfiles: add kerneldoc header to nfs4_ff_layout_prepare_ds flexfiles: remove pointless setting of NFS_LAYOUT_RETURN_REQUESTED pnfs: only tear down lsegs that precede seqid in LAYOUTRETURN args pnfs: keep track of the return sequence number in pnfs_layout_hdr pnfs: record sequence in pnfs_layout_segment when it's created pnfs: don't merge new ff lsegs with ones that have LAYOUTRETURN bit set pNFS/flexfiles: When initing reads or writes, we might have to retry connecting to DSes pNFS/flexfiles: When checking for available DSes, conditionally check for MDS io pNFS/flexfile: Fix erroneous fall back to read/write through the MDS NFS: Reclaim writes via writepage are opportunistic NFSv4: Use the right stateid for delegations in setattr, read and write ...
2016-05-26IB/core: Make device counter infrastructure dynamicChristoph Lameter
In practice, each RDMA device has a unique set of counters that the hardware implements. Having a central set of counters that they must all adhere to is limiting and causes many useful counters to not be available. Therefore we create a dynamic counter registration infrastructure. The driver must implement a stats structure allocation routine, in which the driver must place the directory name it wants, a list of names for all of the counters, an array of u64 counters themselves, plus a few generic configuration options. We then implement a core routine to create a sysfs file for each of the named stats elements, and a core routine to retrieve the stats when any of the sysfs attribute files are read. To avoid excessive beating on the stats generation routine in the drivers, the core code also caches the stats for a short period of time so that someone attempting to read all of the stats in a given device's directory will not result in a stats generation call per file read. Future work will attempt to standardize just the shared stats elements, and possibly add a method to get the stats via netlink in addition to sysfs. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Mark Bloch <markb@mellanox.com> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Doug Ledford <dledford@redhat.com> [ Add caching, make structure names more informative, add i40iw support, other significant rewrites from the original patch ]
2016-05-26Merge branch 'hfi1-2' into k.o/for-4.7Doug Ledford
2016-05-26Merge tag 'mmc-v4.7-rc1' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC fixes from Ulf Hansson: "Here are some mmc fixes intended for v4.7 rc1. They are based on a commit earlier in the merge window and have been tested in linux-next for a while. MMC core: - Prevent re-tuning while serving requests for RPMB partitions - Extend timeout for long read time quirk to support more eMMCs MMC host: - sdhci-acpi: Ensure connected devices are powered when probing - sdhci-pci|acpi: Remove unreliable MMC_CAP_BUS_WIDTH_TEST for Intel HWs - dw_mmc: Correct the assigning of max_blk_size - dw_mmc-rockchip: Allow RPMB partitions to be created - dw_mmc-rockchip: Set the drive phase properly" * tag 'mmc-v4.7-rc1' of git://git.linaro.org/people/ulf.hansson/mmc: mmc: sdhci-acpi: Remove MMC_CAP_BUS_WIDTH_TEST for Intel controllers mmc: sdhci-pci: Remove MMC_CAP_BUS_WIDTH_TEST for Intel controllers mmc: longer timeout for long read time quirk mmc: dw_mmc: rockchip: Set the drive phase properly mmc: dw_mmc: fix the wrong max_blk_size mmc: dw_mmc-rockchip: add MMC_CAP_CMD23 capabilities mmc: sdhci-acpi: Ensure connected devices are powered when probing ACPI / PM: Export acpi_device_fix_up_power() mmc: block: Pause re-tuning while switched to the RPMB partition mmc: block: Always switch back to main area after RPMB access mmc: core: Add a facility to "pause" re-tuning
2016-05-26Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: - Introduce generic ADC thermal driver, based on OF thermal (Laxman Dewangan) - Introduce new thermal driver for Tango chips (Marc Gonzalez) - Rockchip driver support for RK3399, RK3366, and some fixes (Caesar Wang, Elaine Zhang and Shawn Lin) - Add CPU power cooling model to Mediatek thermal driver (Dawei Chien) - Wider usage of dev_thermal_zone_of_sensor_register (Eduardo Valentin) - TI thermal driver gained a new maintainer (Keerthy). - Enabled powerclamp driver by checking CPU feature and package cstate counter instead of CPU whitelist (Jacob Pan) - Various fixes on thermal governor, OF thermal, Tegra, and RCAR * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (50 commits) thermal: tango: initialize TEMPSI_CFG thermal: rockchip: use the usleep_range instead of udelay thermal: rockchip: add the notes for better reading thermal: rockchip: Support RK3366 SoCs in the thermal driver thermal: rockchip: handle the power sequence for tsadc controller thermal: rockchip: update the tsadc table for rk3399 thermal: rockchip: fixes the code_to_temp for tsadc driver thermal: rockchip: disable thermal->clk in err case thermal: tegra: add Tegra132 specific SOC_THERM driver thermal: fix ptr_ret.cocci warnings thermal: mediatek: Add cpu dynamic power cooling model. thermal: generic-adc: Add ADC based thermal sensor driver thermal: generic-adc: Add DT binding for ADC based thermal sensor thermal: tegra: fix static checker warning thermal: tegra: mark PM functions __maybe_unused thermal: add temperature sensor support for tango SoC thermal: hisilicon: fix IRQ imbalance enabling thermal: hisilicon: support to use any sensor thermal: rcar: Remove binding docs for r8a7794 thermal: tegra: add PM support ...
2016-05-26IB/rdamvt: Fix rdmavt s_ack_queue sizingMike Marciniszyn
rdmavt allows the driver to specify the size of the ack queue, but only uses it for the modify QP limit testing for setting the atomic limit value. The driver dependent size is now used to size the s_ack_queue ring dynamicially. Since the driver knows its size, the driver will use its define for any ring size dependent code. Reviewed-by: Mitko Haralanov <mitko.haralanov@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26IB/rdmavt: Max atomic value should be a u8Mike Marciniszyn
This matches the ib_qp_attr size and avoids a extremely large value when the lower level driver registers. As part of the patch, the u8 ordinals are moved to the end of the struct to reduce pahole noted excesses. Reviewed-by: Mitko Haralanov <mitko.haralanov@intel.com> Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26Merge branches 'misc-4.7-2', 'ipoib' and 'ib-router' into k.o/for-4.7Doug Ledford
2016-05-26IB/hfi1: Remove write(), use ioctl() for user cmdsDennis Dalessandro
Remove the write() handler for user space commands now that ioctl handling is available. User apps will need to change to use ioctl from this point forward. Reviewed-by: Mitko Haralanov <mitko.haralanov@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26IB/hfi1: Add ioctl() interface for user commandsDennis Dalessandro
IOCTL is more suited to what user space commands need to do than the write() interface. Add IOCTL definitions for all existing write commands and the handling for those. The write() interface will be removed in a follow on patch. Reviewed-by: Mitko Haralanov <mitko.haralanov@intel.com> Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26IB/hfi1: Remove unused user commandDennis Dalessandro
The HFI1_CMD_SDMA_STATUS_UPD command was never implemented it has no reason to live in the driver. Remove it. Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mitko Haralanov <mitko.haralanov@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26IB/hfi1: Remove EPROM functionality from data deviceDennis Dalessandro
Remove EPROM handling from the cdev which is used for user application data traffic. Reviewed-by: Dean Luick <dean.luick@intel.com> Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26IB/hfi1: Remove multiple device cdevDennis Dalessandro
hfi1 current exports a cdev that can be used to target all of the hfi's in the system. However there is a problem with this approach in that the devices could be on different subnets. This is a problem that user space can figure out and explicitly tell the driver on which device to create a context. Remove the multi-purpose cdev leaving a dedicated cdev for each port. Also remove the striping capability that is dependent upon the user choosing the multi-purpose cdev. It is now up to user space to determine how to stripe contexts. Reviewed-by: Dean Luick <dean.luick@intel.com> Reviewed-by: Mitko Haralanov <mitko.haralanov@intel.com> Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26add down_write_killable_nested()Al Viro
2016-05-25Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Two fixes: one for a lost wakeup, the other to fix the compiler optimizing out preempt operations on ARM64 (and possibly other non-x86 architectures)" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/core: Fix remote wakeups sched/preempt: Fix preempt_count manipulations
2016-05-25Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Mostly tooling and PMU driver fixes, but also a number of late updates such as the reworking of the call-chain size limiting logic to make call-graph recording more robust, plus tooling side changes for the new 'backwards ring-buffer' extension to the perf ring-buffer" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits) perf record: Read from backward ring buffer perf record: Rename variable to make code clear perf record: Prevent reading invalid data in record__mmap_read perf evlist: Add API to pause/resume perf trace: Use the ptr->name beautifier as default for "filename" args perf trace: Use the fd->name beautifier as default for "fd" args perf report: Add srcline_from/to branch sort keys perf evsel: Record fd into perf_mmap perf evsel: Add overwrite attribute and check write_backward perf tools: Set buildid dir under symfs when --symfs is provided perf trace: Only auto set call-graph to "dwarf" when syscalls are being traced perf annotate: Sort list of recognised instructions perf annotate: Fix identification of ARM blt and bls instructions perf tools: Fix usage of max_stack sysctl perf callchain: Stop validating callchains by the max_stack sysctl perf trace: Fix exit_group() formatting perf top: Use machine->kptr_restrict_warned perf trace: Warn when trying to resolve kernel addresses with kptr_restrict=1 perf machine: Do not bail out if not managing to read ref reloc symbol perf/x86/intel/p4: Trival indentation fix, remove space ...
