[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d
and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter
adds an assertion to genetlink to prevent this from happening
again in the future. ]
The original name is too long.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
commit a93bc0c6e07ed9bac44700280e65e2945d864fd4 upstream.
[Problem]
efi_pstore creates sysfs entries, which enable users to access to NVRAM,
in a write callback. If a kernel panic happens in an interrupt context,
it may fail because it could sleep due to dynamic memory allocations during
creating sysfs entries.
[Patch Description]
This patch removes sysfs operations from a write callback by introducing
a workqueue updating sysfs entries which is scheduled after the write
callback is called.
Also, the workqueue is kicked in a just oops case.
A system will go down in other cases such as panic, clean shutdown and emergency
restart. And we don't need to create sysfs entries because there is no chance for
users to access to them.
efi_pstore will be robust against a kernel panic in an interrupt context with this patch.
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Acked-by: Matt Fleming <matt.fleming@intel.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
[bwh: Backported to 3.2:
- Adjust contest
- Don't check reason in efi_pstore_write(), as it is not given as a
parameter
- Move up declaration of __efivars]
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ]
This patch introduces a constant limit of the fragment queue hash
table bucket list lengths. Currently the limit 128 is choosen somewhat
arbitrary and just ensures that we can fill up the fragment cache with
empty packets up to the default ip_frag_high_thresh limits. It should
just protect from list iteration eating considerable amounts of cpu.
If we reach the maximum length in one hash bucket a warning is printed.
This is implemented on the caller side of inet_frag_find to distinguish
between the different users of inet_fragment.c.
I dropped the out of memory warning in the ipv4 fragment lookup path,
because we already get a warning by the slab allocator.
Cc: Jesper Dangaard Brouer <jbrouer@redhat.com>
[ Upstream commit 16fad69cfe4adbbfa813de516757b87bcae36d93 ]
Chrome OS team reported a crash on a Pixel ChromeBook in TCP stack :
https://code.google.com/p/chromium/issues/detail?id=182056
commit a21d45726acac (tcp: avoid order-1 allocations on wifi and tx
path) did a poor choice adding an 'avail_size' field to skb, while
what we really needed was a 'reserved_tailroom' one.
It would have avoided commit 22b4a4f22da (tcp: fix retransmit of
partially acked frames) and this commit.
Crash occurs because skb_split() is not aware of the 'avail_size'
management (and should not be aware)
Reported-by: Mukesh Agrawal <quiche@chromium.org>
[ Upstream commit 5b9e12dbf92b441b37136ea71dac59f05f2673a9 ]
a long time ago by the commit
commit 93456b6d7753def8760b423ac6b986eb9d5a4a95
Author: Denis V. Lunev <den@openvz.org>
Date: Thu Jan 10 03:23:38 2008 -0800
[IPV4]: Unify access to the routing tables.
the defenition of FIB_HASH_TABLE size has obtained wrong dependency:
it should depend upon CONFIG_IP_MULTIPLE_TABLES (as was in the original
code) but it was depended from CONFIG_IP_ROUTE_MULTIPATH
This patch returns the situation to the original state.
The problem was spotted by Tingwei Liu.
Signed-off-by: Denis V. Lunev <den@openvz.org>
CC: Tingwei Liu <tingw.liu@gmail.com>
CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
commit 6c4d3bc99b3341067775efd4d9d13cc8e655fd7c upstream.
Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after
suspend/resume") introduces a link failure since
perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL:
arch/x86/power/built-in.o: In function `restore_processor_state':
(.text+0x45c): undefined reference to `perf_restore_debug_store'
Fix it by defining the dummy function appropriately.
Signed-off-by: David Rientjes <rientjes@google.com>
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream.
This patch fixes a kernel crash when using precise sampling (PEBS)
after a suspend/resume. Turns out the CPU notifier code is not invoked
on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly
by the kernel and keeps it power-on/resume value of 0 causing any PEBS
measurement to crash when running on CPU0.
The workaround is to add a hook in the actual resume code to restore
the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0,
the DS_AREA will be restored twice but this is harmless.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Stephane Eranian <eranian@google.com>
commit 0720a06a7518c9d0c0125bd5d1f3b6264c55c3dd upstream.
The utf8s_to_utf16s conversion routine needs to be improved. Unlike
its utf16s_to_utf8s sibling, it doesn't accept arguments specifying
the maximum length of the output buffer or the endianness of its
16-bit output.
This patch (as1501) adds the two missing arguments, and adjusts the
only two places in the kernel where the function is called. A
follow-on patch will add a third caller that does utilize the new
capabilities.
The two conversion routines are still annoyingly inconsistent in the
way they handle invalid byte combinations. But that's a subject for a
different patch.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Clemens Ladisch <clemens@ladisch.de>
commit e06c93cacb82dd147266fd1bdb2d0a0bd45ff2c1 upstream.
Add support for Altera 8250/16550 compatible serial port.
Signed-off-by: Ley Foon Tan <lftan@altera.com>
[bwh: Backported to 3.2: adjust filenames, context]
commit 68d929862e29a8b52a7f2f2f86a0600423b093cd upstream.
UEFI variables are typically stored in flash. For various reasons, avaiable
space is typically not reclaimed immediately upon the deletion of a
variable - instead, the system will garbage collect during initialisation
after a reboot.
Some systems appear to handle this garbage collection extremely poorly,
failing if more than 50% of the system flash is in use. This can result in
the machine refusing to boot. The safest thing to do for the moment is to
forbid writes if they'd end up using more than half of the storage space.
We can make this more finegrained later if we come up with a method for
identifying the broken machines.
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
- Drop efivarfs changes and unused check_var_size()
- Add error codes to include/linux/efi.h, added upstream by
commit 5d9db883761a ('efi: Add support for a UEFI variable filesystem')
- Add efi_status_to_err(), added upstream by commit 7253eaba7b17
('efivarfs: Return an error if we fail to read a variable')]
commit d80a361d779a9f19498943d1ca84243209cd5647 upstream.
[Issue]
As discussed in a thread below, Running out of space in EFI isn't a well-tested scenario.
And we wouldn't expect all firmware to handle it gracefully.
http://marc.info/?l=linux-kernel&m=134305325801789&w=2
On the other hand, current efi_pstore doesn't check a remaining space of storage at writing time.
Therefore, efi_pstore may not work if it tries to write a large amount of data.
[Patch Description]
To avoid handling the situation above, this patch checks if there is a space enough to log with
QueryVariableInfo() before writing data.
Acked-by: Mike Waychison <mikew@google.com>
commit fd7c092e711ebab55b2688d3859d95dfd0301f73 upstream.
Avoid returning a truncated table or status string instead of setting
the DM_BUFFER_FULL_FLAG when the last target of a table fills the
buffer.
When processing a table or status request, the function retrieve_status
calls ti->type->status. If ti->type->status returns non-zero,
retrieve_status assumes that the buffer overflowed and sets
DM_BUFFER_FULL_FLAG.
However, targets don't return non-zero values from their status method
on overflow. Most targets returns always zero.
If a buffer overflow happens in a target that is not the last in the
table, it gets noticed during the next iteration of the loop in
retrieve_status; but if a buffer overflow happens in the last target, it
goes unnoticed and erroneously truncated data is returned.
In the current code, the targets behave in the following way:
* dm-crypt returns -ENOMEM if there is not enough space to store the
key, but it returns 0 on all other overflows.
* dm-thin returns errors from the status method if a disk error happened.
This is incorrect because retrieve_status doesn't check the error
code, it assumes that all non-zero values mean buffer overflow.
* all the other targets always return 0.
This patch changes the ti->type->status function to return void (because
most targets don't use the return code). Overflow is detected in
retrieve_status: if the status method fills up the remaining space
completely, it is assumed that buffer overflow happened.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
- Adjust context
- dm_status_fn doesn't take a status_flags parameter
- Bump the last component of each current version (verified not to
match any version used in mainline)
- Drop changes to dm-verity]
commit d740269867021faf4ce38a449353d2b986c34a67 upstream.
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
[bwh: Backported to 3.2: adjust context]
commit d0bd587a80960d7ba7e0c8396e154028c9045c54 upstream.
Implement UMH_KILLABLE, should be used along with UMH_WAIT_EXEC/PROC.
The caller must ensure that subprocess_info->path/etc can not go away
until call_usermodehelper_freeinfo().
call_usermodehelper_exec(UMH_KILLABLE) does
wait_for_completion_killable. If it fails, it uses
xchg(&sub_info->complete, NULL) to serialize with umh_complete() which
does the same xhcg() to access sub_info->complete.
If call_usermodehelper_exec wins, it can safely return. umh_complete()
should get NULL and call call_usermodehelper_freeinfo().
Otherwise we know that umh_complete() was already called, in this case
call_usermodehelper_exec() falls back to wait_for_completion() which
should succeed "very soon".
Note: UMH_NO_WAIT == -1 but it obviously should not be used with
UMH_KILLABLE. We delay the neccessary cleanup to simplify the back
porting.
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Tejun Heo <tj@kernel.org>
When backporting commit ebebd49a8eab ('8250/16?50: Add support for
Broadcom TruManage redirected serial port') I took the next
available port type number for PORT_BRCM_TRUMANAGE (22).
However, the 8250 port type numbers are exposed to userland through
the TIOC{G,S}SERIAL ioctls and so must remain stable. Redefine
PORT_BRCM_TRUMANAGE as 25, matching mainline as of commit
85f024401bf807.
This leaves port types 22-24 within the valid range for 8250 but not
implemented there. Change serial8250_verify_port() to specifically
reject these and change serial8250_type() to return "unknown" for them
(though I'm not sure why it would ever see them).
commit 9f244e9cfd70c7c0f82d3c92ce772ab2a92d9f64 upstream.
[Issue]
When pstore is in panic and emergency-restart paths, it may be blocked
in those paths because it simply takes spin_lock.
This is an example scenario which pstore may hang up in a panic path:
- cpuA grabs psinfo->buf_lock
- cpuB panics and calls smp_send_stop
- smp_send_stop sends IRQ to cpuA
- after 1 second, cpuB gives up on cpuA and sends an NMI instead
- cpuA is now in an NMI handler while still holding buf_lock
- cpuB is deadlocked
This case may happen if a firmware has a bug and
cpuA is stuck talking with it more than one second.
Also, this is a similar scenario in an emergency-restart path:
- cpuA grabs psinfo->buf_lock and stucks in a firmware
- cpuB kicks emergency-restart via either sysrq-b or hangcheck timer.
And then, cpuB is deadlocked by taking psinfo->buf_lock again.
[Solution]
This patch avoids the deadlocking issues in both panic and emergency_restart
paths by introducing a function, is_non_blocking_path(), to check if a cpu
can be blocked in current path.
With this patch, pstore is not blocked even if another cpu has
taken a spin_lock, in those paths by changing from spin_lock_irqsave
to spin_trylock_irqsave.
In addition, according to a comment of emergency_restart() in kernel/sys.c,
spin_lock shouldn't be taken in an emergency_restart path to avoid
deadlock. This patch fits the comment below.
<snip>
* emergency_restart - reboot the system
* Without shutting down any hardware or taking any locks
* reboot the system. This is called when we know we are in
* trouble so this is our best effort to reboot. This is
* safe to call in interrupt context.
void emergency_restart(void)
<snip>
Acked-by: Don Zickus <dzickus@redhat.com>
- Adjust context
- Add #include <linux/kmsg_dump.h>]
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ]
It looks like its possible to open thousands of TCP IPv6
sessions on a server, all landing in a single slot of TCP hash
table. Incoming packets have to lookup sockets in a very
long list.
We should hash all bits from foreign IPv6 addresses, using
a salt and hash mix, not a simple XOR.
inet6_ehashfn() can also separately use the ports, instead
of xoring them.
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
commit 4f4ffc3a5398ef9bdbb32db04756d7d34e356fcf upstream.
automount-support is broken on the parisc architecture, because the existing
#if list does not include a check for defined(__hppa__). The HPPA (parisc)
architecture is similiar to other 64bit Linux targets where we have to define
autofs_wqt_t (which is passed back and forth to user space) as int type which
has a size of 32bit across 32 and 64bit kernels.
During the discussion on the mailing list, H. Peter Anvin suggested to invert
the #if list since only specific platforms (specifically those who do not have
a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned
long type.
This suggestion is probably the best way to go, since Arm64 (and maybe others?)
seems to have a non-working automounter. So in the long run even for other new
upcoming architectures this inverted check seem to be the best solution, since
it will not require them to change this #if again (unless they are 64bit only).
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
CC: James Bottomley <James.Bottomley@HansenPartnership.com>
CC: Rolf Eike Beer <eike-kernel@sf-tec.de>
[bwh: Backported to 3.2: adjust filename]
commit 3a2d63f87989e01437ba994df5f297528c353d7d upstream.
There are two problems with shutdown in the NBD driver.
1: Receiving the NBD_DISCONNECT ioctl does not sync the filesystem.
This patch adds the sync operation into __nbd_ioctl()'s
NBD_DISCONNECT handler. This is useful because BLKFLSBUF is restricted
to processes that have CAP_SYS_ADMIN, and the NBD client may not
possess it (fsync of the block device does not sync the filesystem,
either).
2: Once we clear the socket we have no guarantee that later reads will
come from the same backing storage.
The patch adds calls to kill_bdev() in __nbd_ioctl()'s socket
clearing code so the page cache is cleaned, lest reads that hit on the
page cache will return stale data from the previously-accessible disk.
Example:
# qemu-nbd -r -c/dev/nbd0 /dev/sr0
# file -s /dev/nbd0
/dev/stdin: # UDF filesystem data (version 1.5) etc.
# qemu-nbd -d /dev/nbd0
# qemu-nbd -r -c/dev/nbd0 /dev/sda
# file -s /dev/nbd0
While /dev/sda has:
# file -s /dev/sda
/dev/sda: x86 boot sector; etc.
Acked-by: Paul Clements <Paul.Clements@steeleye.com>
Cc: Alex Bligh <alex@alex.org.uk>
- Adjusted context
- s/\bnbd\b/lo/
- Incorporate export of kill_bdev() from commit ff01bb483265
('fs: move code out of buffer.c')]
schedule
commit 21a92735f660eaecf69a6f2e777f18463760ec32 upstream.
With an RCU based mmu_notifier implementation, any callout to
mmu_notifier_invalidate_range_{start,end}() or
mmu_notifier_invalidate_page() would not be allowed to call schedule()
as that could potentially allow a modification to the mmu_notifier
structure while it is currently being used.
Since srcu allocs 4 machine words per instance per cpu, we may end up
with memory exhaustion if we use srcu per mm. So all mms share a global
srcu. Note that during large mmu_notifier activity exit & unregister
paths might hang for longer periods, but it is tolerable for current
mmu_notifier clients.
Signed-off-by: Sagi Grimberg <sagig@mellanox.co.il>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Haggai Eran <haggaie@mellanox.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
commit b531f81b0d70ffbe8d70500512483227cc532608 upstream.
Commit 99fc86450c439039d2ef88d06b222fd51a779176 "ALSA: usb-mixer:
parse descriptors with structs" introduced a set of useful parsers
for descriptors. Unfortunately the parses for the Processing Unit
Descriptor came with a very subtle bug...
Functions uac_processing_unit_iProcessing() and
uac_processing_unit_specific() were indexing the baSourceID array
forgetting the fields before the iProcessing and process-specific
descriptors.
The problem was observed with Sound Blaster Extigy mixer,
where nNrModes in Up/Down-mix Processing Unit Descriptor
was accessed at offset 10 of the descriptor (value 0)
instead of offset 15 (value 7). In result the resulting
control had interesting limit values:
Simple mixer control 'Channel Routing Mode Select',0
Capabilities: volume volume-joined penum
Playback channels: Mono
Capture channels: Mono
Limits: 0 - -1
Mono: -1 [100%]
Fixed by starting from the bmControls, which was calculated
correctly, instead of baSourceID.
Now the mentioned control is fine:
Limits: 0 - 6
Mono: 0 [0%]
Signed-off-by: Pawel Moll <mail@pawelmoll.com>
commit fcf29481fb8e106daad6688f2e898226ee928992 upstream.
This patch fixes a bug in core_tpg_check_initiator_node_acl() ->
core_tpg_get_initiator_node_acl() where a dynamically created
se_node_acl generated during session login would be skipped during
subsequent lookup due to the '!acl->dynamic_node_acl' check, causing
a new se_node_acl to be created with a duplicate ->initiatorname.
This would occur when a fabric endpoint was configured with
TFO->tpg_check_demo_mode()=1 + TPF->tpg_check_demo_mode_cache()=1
preventing the release of an existing se_node_acl during se_session
shutdown.
Also, drop the unnecessary usage of core_tpg_get_initiator_node_acl()
within core_dev_init_initiator_node_lun_acl() that originally
required the extra '!acl->dynamic_node_acl' check, and just pass
the configfs provided se_node_acl pointer instead.
[bwh: Backported to 3.2: adjust context, filename of header]
commit 513b032c98b4b9414aa4e9b4a315cb1bf0380101 upstream.
The PPS serial line discipline wants to attach a PPS device to a tty
without changing the tty code to add a struct pps_device * pointer.
Since the number of PPS devices in a typical system is generally very low
(n=1 is by far the most common), it's practical to search the entire list
of allocated pps devices. (We capture the timestamp before the lookup,
so the timing isn't affected.)
It is a bit ugly that this function, which is part of the in-kernel
PPS API, has to be in pps.c as opposed to kapi,c, but that's not
something that affects users.
Signed-off-by: George Spelvin <linux@horizon.com>
Acked-by: Rodolfo Giometti <giometti@enneenne.com>
commit 9749f30f1a387070e6e8351f35aeb829eacc3ab6 upstream.
Inspired by the list_for_each_entry() macro
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream.
I've still got lockdep warnings even after Alan's patch, and it seems that
yet more band aids are required to paper over similar paths for
unbind_con_driver() and unregister_con_driver(). After this hack, lockdep
warnings are finally gone.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream.
Adjust the console layer to allow a take over call where the caller
already holds the locks. Make the fb layer lock in order.
This is partly a band aid, the fb layer is terminally confused about the
locking rules it uses for its notifiers it seems.
[akpm@linux-foundation.org: remove stray non-ascii char, tidy comment]
[akpm@linux-foundation.org: export do_take_over_console()]
[airlied: cleanup another non-ascii char]
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 2a2483072393b27f4336ab068a1f48ca19ff1c1e upstream.
When we switch from 256->512 byte font rendering mode, it means the
current contents of the screen is being reinterpreted. The bit that holds
the high bit of the 9-bit font, may have been previously set, and thus
the new font misrenders.
The problem case we see is grub2 writes spaces with the bit set, so it
ends up with data like 0x820, which gets reinterpreted into 0x120 char
which the font translates into G with a circumflex. This flashes up on
screen at boot and is quite ugly.
A current side effect of this patch though is that any rendering on the
screen changes color to a slightly darker color, but at least the screen
no longer corrupts.
v2: as suggested by hpa, always clear the attribute space, whether we
are are going to or from 512 chars.
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream.
Otherwise, ext4 file systems with the quota featured enable will get a
very confusing "No such process" error message if the quota code is
built as a module and the quota_v2 module has not been loaded.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Acked-by: Jan Kara <jack@suse.cz>
commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82 upstream.
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
call_console_drivers
This patch corrects a buffer overflow in kernels from 3.0 to 3.4 when calling
log_prefix() function from call_console_drivers().
This bug existed in previous releases but has been revealed with commit
162a7e7500f9664636e649ba59defe541b7c2c60 (2.6.39 => 3.0) that made changes
about how to allocate memory for early printk buffer (use of memblock_alloc).
It disappears with commit 7ff9554bb578ba02166071d2d487b7fc7d860d62 (3.4 => 3.5)
that does a refactoring of printk buffer management.
In log_prefix(), the access to "p[0]", "p[1]", "p[2]" or
"simple_strtoul(&p[1], &endp, 10)" may cause a buffer overflow as this
function is called from call_console_drivers by passing "&LOG_BUF(cur_index)"
where the index must be masked to do not exceed the buffer's boundary.
The trick is to prepare in call_console_drivers() a buffer with the necessary
data (PRI field of syslog message) to be safely evaluated in log_prefix().
This patch can be applied to stable kernel branches 3.0.y, 3.2.y and 3.4.y.
Without this patch, one can freeze a server running this loop from shell :
$ export DUMMY=`cat /dev/urandom | tr -dc '12345AZERTYUIOPQSDFGHJKLMWXCVBNazertyuiopqsdfghjklmwxcvbn' | head -c255`
$ while true do ; echo $DUMMY > /dev/kmsg ; done
The "server freeze" depends on where memblock_alloc does allocate printk buffer :
if the buffer overflow is inside another kernel allocation the problem may not
be revealed, else the server may hangs up.
Signed-off-by: Alexandre SIMON <Alexandre.Simon@univ-lorraine.fr>
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream.
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
https://bugzilla.kernel.org/show_bug.cgi?id=47121
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
- Adjust context (a lot)
- Add efi_is_native() function from commit 5189c2a7c776
('x86: efi: Turn off efi_enabled after setup on mixed fw/kernel')
- Make efi_init() bail out when booted non-native, as it would previously
not be called in this case
- Drop inapplicable changes to start_kernel()]
commit ebebd49a8eab5e9aa1b1f8f1614ccc3c2120f886 upstream.
Add support for the UART device present in Broadcom TruManage capable
NetXtreme chips (ie: 5761m 5762, and 5725).
This implementation has a hidden transmit FIFO, so running in single-byte
interrupt mode results in too many interrupts. The UART_CAP_HFIFO
capability was added to track this. It continues to reload the THR as long
as the THRE and TSRE bits are set in the LSR up to a specified limit (1024
is used here).
Signed-off-by: Stephen Hurd <shurd@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
- Adjust filenames
- Adjust context
- First available port type number is 22 not 24
- s/uart_8250_port/uart_port/
- Use serial_in() not serial_port_in()]
[ Upstream commit 0c24604b68fc7810d429d6c3657b6f148270e528 ]
Implement the RFC 5691 mitigation against Blind
Reset attack using SYN bit.
Section 4.2 of RFC 5961 advises to send a Challenge ACK and drop
incoming packet, instead of resetting the session.
Add a new SNMP counter to count number of challenge acks sent
in response to SYN packets.
(netstat -s | grep TCPSYNChallenge)
Remove obsolete TCPAbortOnSyn, since we no longer abort a TCP session
because of a SYN flag.
Cc: Kiran Kumar Kella <kkiran@broadcom.com>
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ]
Reset attack using RST bit.
Idea is to validate incoming RST sequence,
to match RCV.NXT value, instead of previouly accepted
window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND)
If sequence is in window but not an exact match, send
a "challenge ACK", so that the other part can resend an
RST with the appropriate sequence.
Add a new sysctl, tcp_challenge_ack_limit, to limit
number of challenge ACK sent per second.
Add a new SNMP counter to count number of challenge acks sent.
(netstat -s | grep TCPChallengeACK)
[ Upstream commit e337e24d6624e74a558aa69071e112a65f7b5758 ]
If in either of the above functions inet_csk_route_child_sock() or
__inet_inherit_port() fails, the newsk will not be freed:
unreferenced object 0xffff88022e8a92c0 (size 1592):
comm "softirq", pid 0, jiffies 4294946244 (age 726.160s)
hex dump (first 32 bytes):
0a 01 01 01 0a 01 01 02 00 00 00 00 a7 cc 16 00 ................
02 00 03 01 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff8153d190>] kmemleak_alloc+0x21/0x3e
[<ffffffff810ab3e7>] kmem_cache_alloc+0xb5/0xc5
[<ffffffff8149b65b>] sk_prot_alloc.isra.53+0x2b/0xcd
[<ffffffff8149b784>] sk_clone_lock+0x16/0x21e
[<ffffffff814d711a>] inet_csk_clone_lock+0x10/0x7b
[<ffffffff814ebbc3>] tcp_create_openreq_child+0x21/0x481
[<ffffffff814e8fa5>] tcp_v4_syn_recv_sock+0x3a/0x23b
[<ffffffff814ec5ba>] tcp_check_req+0x29f/0x416
[<ffffffff814e8e10>] tcp_v4_do_rcv+0x161/0x2bc
[<ffffffff814eb917>] tcp_v4_rcv+0x6c9/0x701
[<ffffffff814cea9f>] ip_local_deliver_finish+0x70/0xc4
[<ffffffff814cec20>] ip_local_deliver+0x4e/0x7f
[<ffffffff814ce9f8>] ip_rcv_finish+0x1fc/0x233
[<ffffffff814cee68>] ip_rcv+0x217/0x267
[<ffffffff814a7bbe>] __netif_receive_skb+0x49e/0x553
[<ffffffff814a7cc3>] netif_receive_skb+0x50/0x82
This happens, because sk_clone_lock initializes sk_refcnt to 2, and thus
a single sock_put() is not enough to free the memory. Additionally, things
like xfrm, memcg, cookie_values,... may have been initialized.
We have to free them properly.
This is fixed by forcing a call to tcp_done(), ending up in
inet_csk_destroy_sock, doing the final sock_put(). tcp_done() is necessary,
because it ends up doing all the cleanup on xfrm, memcg, cookie_values,
xfrm,...
Before calling tcp_done, we have to set the socket to SOCK_DEAD, to
force it entering inet_csk_destroy_sock. To avoid the warning in
inet_csk_destroy_sock, inet_num has to be set to 0.
As inet_csk_destroy_sock does a dec on orphan_count, we first have to
increase it.
Calling tcp_done() allows us to remove the calls to
tcp_clear_xmit_timer() and tcp_cleanup_congestion_control().
A similar approach is taken for dccp by calling dccp_done().
This is in the kernel since 093d282321 (tproxy: fix hash locking issue
when using port redirection in __inet_inherit_port()), thus since
version >= 2.6.37.
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
commit 45959ee7aa645815a5ce303a0ea1e48a21e67c6a upstream.
When gcc inlines a function, it does not mark it with the mcount
prologue, which in turn means that inlined functions are not traced
by the function tracer. But if CONFIG_OPTIMIZE_INLINING is set, then
gcc is allowed not to inline a function that is marked inline.
Depending on the options and the compiler, a function may or may
not be traced by the function tracer, depending on whether gcc
decides to inline a function or not. This has caused several
problems in the pass becaues gcc is not always consistent with
what it decides to inline between different gcc versions.
Some places should not be traced (like paravirt native_* functions)
and these are mostly marked as inline. When gcc decides not to
inline the function, and if that function should not be traced, then
the ftrace function tracer will suddenly break when it use to work
fine. This becomes even harder to debug when different versions of
gcc will not inline that function, making the same kernel and config
work for some gcc versions and not work for others.
By making all functions marked inline to not be traced will remove
the ambiguity that gcc adds when it comes to tracing functions marked
inline. All gcc versions will be consistent with what functions are
traced and having volatile working code will be removed.
Note, only the inline macro when CONFIG_OPTIMIZE_INLINING is set needs
to have notrace added, as the attribute __always_inline will force
the function to be inlined and then not traced.
commit 5b632fe85ec82e5c43740b52e74c66df50a37db3 upstream.
Commit f0425beda4d404a6e751439b562100b902ba9c98 "mac80211: retry sending
failed BAR frames later instead of tearing down aggr" caused regression
on rt2x00 hardware (connection hangs). This regression was fixed by
commit be03d4a45c09ee5100d3aaaedd087f19bc20d01 "rt2x00: Don't let
mac80211 send a BAR when an AMPDU subframe fails". But the latter
commit caused yet another problem reported in
https://bugzilla.kernel.org/show_bug.cgi?id=42828#c22
After long discussion in this thread:
http://mid.gmane.org/20121018075615.GA18212@redhat.com
and testing various alternative solutions, which failed on one or other
setup, we have no other good fix for the issues like just revert both
mentioned earlier commits.
To do not affect other hardware which benefit from commit
f0425beda4d404a6e751439b562100b902ba9c98, instead of reverting it,
introduce flag that when used will restore mac80211 behaviour before
the commit.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
[replaced link with mid.gmane.org that has message-id]
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream.
Since commit e303297e6c3a ("mm: extended batches for generic
mmu_gather") we are batching pages to be freed until either
tlb_next_batch cannot allocate a new batch or we are done.
This works just fine most of the time but we can get in troubles with
non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY)
on large machines where too aggressive batching might lead to soft
lockups during process exit path (exit_mmap) because there are no
scheduling points down the free_pages_and_swap_cache path and so the
freeing can take long enough to trigger the soft lockup.
The lockup is harmless except when the system is setup to panic on
softlockup which is not that unusual.
The simplest way to work around this issue is to limit the maximum
number of batches in a single mmu_gather. 10k of collected pages should
be safe to prevent from soft lockups (we would have 2ms for one) even if
they are all freed without an explicit scheduling point.
This patch doesn't add any new explicit scheduling points because it
relies on zap_pmd_range during page tables zapping which calls
cond_resched per PMD.
The following lockup has been reported for 3.0 kernel with a huge
process (in order of hundreds gigs but I do know any more details).
BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053]
Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod
Supported: Yes
CPU 56
Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7
RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10
RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206
RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80
RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206
RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400
R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e
R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e
FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0
Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100)
Call Trace:
release_pages+0xc5/0x260
free_pages_and_swap_cache+0x9d/0xc0
tlb_flush_mmu+0x5c/0x80
tlb_finish_mmu+0xe/0x50
exit_mmap+0xbd/0x120
mmput+0x49/0x120
exit_mm+0x122/0x160
do_exit+0x17a/0x430
do_group_exit+0x3d/0xb0
get_signal_to_deliver+0x247/0x480
do_signal+0x71/0x1b0
do_notify_resume+0x98/0xb0
int_signal+0x12/0x17
DWARF2 unwinder stuck at int_signal+0x12/0x17
commit ad4b3fb7ff9940bcdb1e4cd62bd189d10fa636ba upstream.
Unfortunately with !CONFIG_PAGEFLAGS_EXTENDED, (!PageHead) is false, and
(PageHead) is true, for tail pages. If this is indeed the intended
behavior, which I doubt because it breaks cache cleaning on some ARM
systems, then the nomenclature is highly problematic.
This patch makes sure PageHead is only true for head pages and PageTail
is only true for tail pages, and neither is true for non-compound pages.
[ This buglet seems ancient - seems to have been introduced back in Apr
2008 in commit 6a1e7f777f61: "pageflags: convert to the use of new
macros". And the reason nobody noticed is because the PageHead()
tests are almost all about just sanity-checking, and only used on
pages that are actual page heads. The fact that the old code returned
true for tail pages too was thus not really noticeable. - Linus ]
Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Will Deacon <Will.Deacon@arm.com>
Cc: Steve Capper <Steve.Capper@arm.com>
Cc: Christoph Lameter <cl@linux.com>
commit 812089e01b9f65f90fc8fc670d8cce72a0e01fbb upstream.
Otherwise it fails like this on cards like the Transcend 16GB SDHC card:
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 15.0 GiB
mmcblk0: error -110 sending status command, retrying
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0
Tested on my Lenovo x200 laptop.
[bhelgaas: changelog]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Chris Ball <cjb@laptop.org>
CC: Manoj Iyer <manoj.iyer@canonical.com>
commit fe0c9610bb68dd0aad1017456f5e3c31264d70c2 upstream.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit b66c5984017533316fd1951770302649baf1aa33 upstream.
If a series of scripts are executed, each triggering module loading via
unprintable bytes in the script header, kernel stack contents can leak
into the command line.
Normally execution of binfmt_script and binfmt_misc happens recursively.
However, when modules are enabled, and unprintable bytes exist in the
bprm->buf, execution will restart after attempting to load matching
binfmt modules. Unfortunately, the logic in binfmt_script and
binfmt_misc does not expect to get restarted. They leave bprm->interp
pointing to their local stack. This means on restart bprm->interp is
left pointing into unused stack memory which can then be copied into the
userspace argv areas.
After additional study, it seems that both recursion and restart remains
the desirable way to handle exec with scripts, misc, and modules. As
such, we need to protect the changes to interp.
This changes the logic to require allocation for any changes to the
bprm->interp. To avoid adding a new kmalloc to every exec, the default
value is left as-is. Only when passing through binfmt_script or
binfmt_misc does an allocation take place.
For a proof of concept, see DoTest.sh from:
http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/
This is extracted from Mel Gorman's commit 5a178119b0fb ('mm: add
support for direct_IO to highmem pages') upstream.
Required to backport commit b9cdc88df8e6 ('virtio: 9p: correctly pass
physical address to userspace for high pages').
commit dd67d32dbc5de299d70cc9e10c6c1e29ffa56b92 upstream.
A task is considered frozen enough between freezer_do_not_count() and
freezer_count() and freezers use freezer_should_skip() to test this
condition. This supposedly works because freezer_count() always calls
try_to_freezer() after clearing %PF_FREEZER_SKIP.
However, there currently is nothing which guarantees that
freezer_count() sees %true freezing() after clearing %PF_FREEZER_SKIP
when freezing is in progress, and vice-versa. A task can escape the
freezing condition in effect by freezer_count() seeing !freezing() and
freezer_should_skip() seeing %PF_FREEZER_SKIP.
This patch adds smp_mb()'s to freezer_count() and
freezer_should_skip() such that either %true freezing() is visible to
freezer_count() or !PF_FREEZER_SKIP is visible to
freezer_should_skip().
- Adjust context and indentation
- freezer_do_not_count() and freezer_count() are no-ops for kernel tasks]
css_set
commit 5edee61edeaaebafe584f8fb7074c1ef4658596b upstream.
cgroup core has a bug which violates a basic rule about event
notifications - when a new entity needs to be added, you add that to
the notification list first and then make the new entity conform to
the current state. If done in the reverse order, an event happening
inbetween will be lost.
cgroup_subsys->fork() is invoked way before the new task is added to
the css_set. Currently, cgroup_freezer is the only user of ->fork()
and uses it to make new tasks conform to the current state of the
freezer. If FROZEN state is requested while fork is in progress
between cgroup_fork_callbacks() and cgroup_post_fork(), the child
could escape freezing - the cgroup isn't frozen when ->fork() is
called and the freezer couldn't see the new task on the css_set.
This patch moves cgroup_subsys->fork() invocation to
cgroup_post_fork() after the new task is added to the css_set.
cgroup_fork_callbacks() is removed.
Because now a task may be migrated during cgroup_subsys->fork(),
freezer_fork() is updated so that it adheres to the usual RCU locking
and the rather pointless comment on why locking can be different there
is removed (if it doesn't make anything simpler, why even bother?).
- Adjust context
- Iterate over first CGROUP_BUILTIN_SUBSYS_COUNT elements of subsys
- cgroup_subsys::fork takes cgroup_subsys pointer as first parameter]
commit 18a2f371f5edf41810f6469cb9be39931ef9deb9 upstream.
This fixes a regression in 3.7-rc, which has since gone into stable.
Commit 00442ad04a5e ("mempolicy: fix a memory corruption by refcount
imbalance in alloc_pages_vma()") changed get_vma_policy() to raise the
refcount on a shmem shared mempolicy; whereas shmem_alloc_page() went
on expecting alloc_page_vma() to drop the refcount it had acquired.
This deserves a rework: but for now fix the leak in shmem_alloc_page().
Hugh: shmem_swapin() did not need a fix, but surely it's clearer to use
the same refcounting there as in shmem_alloc_page(), delete its onstack
mempolicy, and the strange mpol_cond_copy() and __mpol_cond_copy() -
those were invented to let swapin_readahead() make an unknown number of
calls to alloc_pages_vma() with one mempolicy; but since 00442ad04a5e,
alloc_pages_vma() has kept refcount in balance, so now no problem.
Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com>
commit 87f4d7c1d36f44b0822053b7e5dedc31fdd0ab99 upstream.
This patch updates the adjfreq callback description to include a note that the
delta in ppb is always relative to the base frequency, and not to the current
frequency of the hardware clock.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
CC: Richard Cochran <richard.cochran@gmail.com>
CC: John Stultz <john.stultz@linaro.org>
commit 95a7d76897c1e7243d4137037c66d15cbf2cce76 upstream.
As Mukesh explained it, the MMUEXT_TLB_FLUSH_ALL allows the
hypervisor to do a TLB flush on all active vCPUs. If instead
we were using the generic one (which ends up being xen_flush_tlb)
we end up making the MMUEXT_TLB_FLUSH_LOCAL hypercall. But
before we make that hypercall the kernel will IPI all of the
vCPUs (even those that were asleep from the hypervisor
perspective). The end result is that we needlessly wake them
up and do a TLB flush when we can just let the hypervisor
do it correctly.
This patch gives around 50% speed improvement when migrating
idle guest's from one host to another.
Oracle-bug: 14630170
Tested-by: Jingjie Jiang <jingjie.jiang@oracle.com>
Suggested-by: Mukesh Rathor <mukesh.rathor@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 9b395bc3be1cebf0144a127c7e67d56dbdac0930 upstream.
A number of places in the mesh code don't check that
the frame data is present and in the skb header when
trying to access. Add those checks and the necessary
pskb_may_pull() calls. This prevents accessing data
that doesn't actually exist.
To do this, export ieee80211_get_mesh_hdrlen() to be
able to use it in mac80211.
