The 2-bit gates found i.MX and Vybrid SoC support different clock
configuration:
0b00: clk disabled
0b01: clk enabled in RUN mode but disabled in WAIT and STOP mode
0b10: clk enabled in RUN, WAIT and STOP mode (only Vybrid)
0b11: clk enabled in RUN and WAIT mode
For some clocks, we might want to configure different behaviour,
e.g. a memory clock should be on even in STOP mode. Add a new
function imx_clk_gate2_cgr which allow to configure specific
gate values through the cgr_val parameter.
Add helper irq_chip_enable_parent and irq_chip_disable_parent. The
helper implement the default behavior in case irq_enable or irq_disable
is not implemented for the parent interrupt chip, which is calling the
irq_mask or irq_unmask respectively.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Cc: marc.zyngier@arm.com
Cc: linux@arm.linux.org.uk
Cc: u.kleine-koenig@pengutronix.de
Cc: olof@lixom.net
Cc: arnd@arndb.de
Cc: daniel.lezcano@linaro.org
Cc: mark.rutland@arm.com
Cc: pawel.moll@arm.com
Cc: robh+dt@kernel.org
Cc: ijc+devicetree@hellion.org.uk
Cc: galak@codeaurora.org
Cc: mcoquelin.stm32@gmail.com
Cc: shawn.guo@linaro.org
Cc: kernel@pengutronix.de
Cc: jason@lakedaemon.net
Link: http://lkml.kernel.org/r/1431769465-26867-3-git-send-email-stefan@agner.ch
commit 764ad8ba8cd4c6f836fca9378f8c5121aece0842 upstream.
The current buffer is much too small if you have a relatively long
hostname. Bring it up to the size of the one that SETCLIENTID has.
Reported-by: Michael Skralivetsky <michael.skralivetsky@primarydata.com>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 496e7ce2a46562938edcb74f65b26068ee8895f6 upstream.
If GPIOLIB=n:
drivers/leds/leds-gpio.c: In function ‘gpio_leds_create’:
drivers/leds/leds-gpio.c:187: error: implicit declaration of function ‘devm_get_gpiod_from_child’
drivers/leds/leds-gpio.c:187: warning: assignment makes pointer from integer without a cast
Add dummies for fwnode_get_named_gpiod() and devm_get_gpiod_from_child()
for the !GPIOLIB case to fix this.
Fixes: 40b7318319281b1b ("gpio: Support for unified device properties interface")
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Bryan Wu <cooloney@gmail.com>
commit c8fff7bc5bba6bd59cad40441c189c4efe7190f6 upstream.
Node 0 might be offline as well as any other numa node,
in this case kernel cannot handle memory allocation and crashes.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: 0c3f061c195c ("of: implement of_node_to_nid as a weak function")
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit b86a50c3b5414eafdbee7f34af4a201a4a7817c2 upstream.
Cleanup commit 73679e508201 ("compiler-intel.h: Remove duplicate
definition") removed the double definition of __memory_barrier()
intrinsics.
However, in doing so, it also removed the preceding #undef barrier by
accident, meaning, the actual barrier() macro from compiler-gcc.h with
inline asm is still in place as __GNUC__ is provided.
Subsequently, barrier() can never be defined as __memory_barrier() from
compiler.h since it already has a definition in place and if we trust
the comment in compiler-intel.h, ecc doesn't support gcc specific asm
statements.
I don't have an ecc at hand (unsure if that's still used in the field?)
and only found this by accident during code review, a revert of that
cleanup would be simplest option.
Fixes: 73679e508201 ("compiler-intel.h: Remove duplicate definition")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Reviewed-by: Pranith Kumar <bobby.prani@gmail.com>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: mancha security <mancha1@zoho.com>
commit 0ea61381788a37d864f9841b0fe97d40f7058f3b upstream.
ACPICA commit 4da56eeae0749dfe8491285c1e1fad48f6efafd8
The following commit temporarily disables correct 64-bit FADT addresses
favor during the period the root cause of the bug is not fixed:
Commit: 85dbd5801f62b66e2aa7826aaefcaebead44c8a6
ACPICA: Tables: Restore old behavor to favor 32-bit FADT addresses.
With enough protections, this patch re-enables 64-bit FADT addresses by
default. If regressions are reported against such change, this patch should
be bisected and reverted.
Note that 64-bit FACS favor and 64-bit firmware waking vector favor are
excluded by this commit in order not to break OSPMs. Lv Zheng.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=74021
Link: https://github.com/acpica/acpica/commit/4da56eea
Reported-and-tested-by: Oswald Buddenhagen <ossi@kde.org>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
commit c04be18448355441a0c424362df65b6422e27bda upstream.
ACPICA commit 90f5332a15e9d9ba83831ca700b2b9f708274658
This patch adds a new FACS initialization flag for acpi_tb_initialize().
acpi_enable_subsystem() might be invoked several times in OS bootup process,
and we don't want FACS initialization to be invoked twice. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/90f5332a
commit c04e1fb4396d27f18296db0f914760fa7fe8223a upstream.
ACPICA commit f7b86f35416e3d1f71c3d816ff5075ddd33ed486
The following commit is reported to have broken s2ram on some platforms:
Commit: 0249ed2444d65d65fc3f3f64f398f1ad0b7e54cd
ACPICA: Add option to favor 32-bit FADT addresses.
The platform reports 2 FACS tables (which is not allowed by ACPI
specification) and the new 32-bit address favor rule forces OSPMs to use
the FACS table reported via FADT's X_FIRMWARE_CTRL field.
The root cause of the reported bug might be one of the followings:
1. BIOS may favor the 64-bit firmware waking vector address when the
version of the FACS is greater than 0 and Linux currently only supports
resuming from the real mode, so the 64-bit firmware waking vector has
never been set and might be invalid to BIOS while the commit enables
higher version FACS.
2. BIOS may favor the FACS reported via the "FIRMWARE_CTRL" field in the
FADT while the commit doesn't set the firmware waking vector address of
the FACS reported by "FIRMWARE_CTRL", it only sets the firware waking
vector address of the FACS reported by "X_FIRMWARE_CTRL".
This patch excludes the cases that can trigger the bugs caused by the root
cause 2.
There is no handshaking mechanism can be used by OSPM to tell BIOS which
FACS is currently used. Thus the FACS reported by "FIRMWARE_CTRL" may still
be used by BIOS and the 0 value of the 32-bit firmware waking vector might
trigger such failure.
This patch tries to favor 32bit FACS address in another way where both the
FACS reported by "FIRMWARE_CTRL" and the FACS reported by "X_FIRMWARE_CTRL"
are loaded so that further commit can set firmware waking vector in the
both tables to ensure we can exclude the cases that trigger the bugs caused
by the root cause 2. The exclusion is split into 2 commits as this commit
is also useful for dumping more ACPI tables, it won't get reverted when
such exclusion is no longer necessary. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/f7b86f35
commit 0294112ee3135fbd15eaa70015af8283642dd970 upstream.
This effectively reverts the following three commits:
7bc10388ccdd ACPI / resources: free memory on error in add_region_before()
0f1b414d1907 ACPI / PNP: Avoid conflicting resource reservations
b9a5e5e18fbf ACPI / init: Fix the ordering of acpi_reserve_resources()
(commit b9a5e5e18fbf introduced regressions some of which, but not
all, were addressed by commit 0f1b414d1907 and commit 7bc10388ccdd
was a fixup on top of the latter) and causes ACPI fixed hardware
resources to be reserved at the fs_initcall_sync stage of system
initialization.
The story is as follows. First, a boot regression was reported due
to an apparent resource reservation ordering change after a commit
that shouldn't lead to such changes. Investigation led to the
conclusion that the problem happened because acpi_reserve_resources()
was executed at the device_initcall() stage of system initialization
which wasn't strictly ordered with respect to driver initialization
(and with respect to the initialization of the pcieport driver in
particular), so a random change causing the device initcalls to be
run in a different order might break things.
The response to that was to attempt to run acpi_reserve_resources()
as soon as we knew that ACPI would be in use (commit b9a5e5e18fbf).
However, that turned out to be too early, because it caused resource
reservations made by the PNP system driver to fail on at least one
system and that failure was addressed by commit 0f1b414d1907.
That fix still turned out to be insufficient, though, because
calling acpi_reserve_resources() before the fs_initcall stage of
system initialization caused a boot regression to happen on the
eCAFE EC-800-H20G/S netbook. That meant that we only could call
acpi_reserve_resources() at the fs_initcall initialization stage
or later, but then we might just as well call it after the PNP
initalization in which case commit 0f1b414d1907 wouldn't be
necessary any more.
For this reason, the changes made by commit 0f1b414d1907 are reverted
(along with a memory leak fixup on top of that commit), the changes
made by commit b9a5e5e18fbf that went too far are reverted too and
acpi_reserve_resources() is changed into fs_initcall_sync, which
will cause it to be executed after the PNP subsystem initialization
(which is an fs_initcall) and before device initcalls (including
the pcieport driver initialization) which should avoid the initial
issue.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=100581
Link: http://marc.info/?t=143092384600002&r=1&w=2
Link: https://bugzilla.kernel.org/show_bug.cgi?id=99831
Link: http://marc.info/?t=143389402600001&r=1&w=2
Fixes: b9a5e5e18fbf "ACPI / init: Fix the ordering of acpi_reserve_resources()"
Reported-by: Roland Dreier <roland@purestorage.com>
commit 648a9bc5308d952f2c80772301b339f73026f013 upstream.
Since the hardware sometimes mysteriously totally flummoxes the 64bit
read of a 64bit register when read using a single instruction, split the
read into two instructions. Since the read here is of automatically
incrementing timestamp counters, we also have to be very careful in
order to make sure that it does not increment between the two
instructions.
However, since userspace tried to workaround this issue and so enshrined
this ABI for a broken hardware read and in the process neglected that
the read only fails in some environments, we have to introduce a new
uABI flag for userspace to request the 2x32 bit accurate read of the
timestamp.
v2: Fix alignment check and include details of the workaround for
userspace.
Reported-by: Karol Herbst <freedesktop@karolherbst.de>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=91317
Testcase: igt/gem_reg_read
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Michał Winiarski <michal.winiarski@intel.com>
Tested-by: Michał Winiarski <michal.winiarski@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 60f207a5b6d8f23c2e8388b415e8d5c7311cc79d upstream.
for_each_*_in_state validate array index after
access to array elements, thus perform out of bounds read.
Fix this by validating index in the first place and read
array element iff validation was successful.
Fixes: df63b9994eaf ("drm/atomic: Add for_each_{connector,crtc,plane}_in_state helper macros")
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
commit 6b8eeca65b18ae77e175cc2b6571731f0ee413bf upstream.
I've only seen this once, and I failed to capture the
lockdep backtrace, but I did some investigations.
If we are calling into the MST layer from EDID probing,
we have the mode_config mutex held, if during that EDID
probing, the MST hub goes away, then we can get a deadlock
where the connector destruction function in the driver
tries to retake the mode config mutex.
This offloads connector destruction to a workqueue,
and avoid the subsequenct lock ordering issue.
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
limit
commit af34d637637eabaf49406eb35c948cd51ba262a6 upstream.
Since no longer limiting max_sectors to BLK_DEF_MAX_SECTORS (commit 34b48db66e08),
data corruption may occur on ST380013AS drive configured on 82801JI (ICH10 Family)
SATA controller. This patch will allow the driver to limit max_sectors as before
# cat /sys/block/sdb/queue/max_sectors_kb
512
I was able to double the max_sectors_kb value up to 16384 on linux-4.2.0-rc2
before seeing corruption, but seems safer to use previous limit. Without this
patch max_sectors_kb will be 32767.
tj: Minor comment update.
Reported-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: David Milburn <dmilburn@redhat.com>
Fixes: 34b48db66e08 ("block: remove artifical max_hw_sectors cap")
commit 71d126fd28de2d4d9b7b2088dbccd7ca62fad6e0 upstream.
Some devices lose data on TRIM whether queued or not. This patch adds
a horkage to disable TRIM.
tj: Collapsed unnecessary if() nesting.
Signed-off-by: Arne Fitzenreiter <arne_f@ipfire.org>
commit 5d3abf8ff67f49271a42c0f7fa4f20f9e046bf0e upstream.
Some devices advertise support for the READ/WRITE LOG DMA EXT commands
but fail when we try to issue them. This can lead to queued TRIM being
unintentionally disabled since the relevant feature flag is located in a
general purpose log page.
Fall back to unqueued READ LOG EXT if the DMA variant fails while
reading a log page.
Reviewed-by: Hannes Reinecke <hare@suse.de>
commit 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a upstream.
If updating journal superblock fails after journal data has been
flushed, the error is omitted and this will mislead the caller as a
normal case. In ocfs2, the checkpoint will be treated successfully
and the other node can get the lock to update. Since the sb_start is
still pointing to the old log block, it will rewrite the journal data
during journal recovery by the other node. Thus the new updates will
be overwritten and ocfs2 corrupts. So in above case we have to return
the error, and ocfs2_commit_cache will take care of the error and
prevent the other node to do update first. And only after recovering
journal it can do the new updates.
The issue discussion mail can be found at:
https://oss.oracle.com/pipermail/ocfs2-devel/2015-June/010856.html
http://comments.gmane.org/gmane.comp.file-systems.ext4/48841
[ Fixed bug in patch which allowed a non-negative error return from
jbd2_cleanup_journal_tail() to leak out of jbd2_fjournal_flush(); this
was causing xfstests ext4/306 to fail. -- Ted ]
Reported-by: Yiwen Jiang <jiangyiwen@huawei.com>
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Tested-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
commit bd7ade3cd9b0850264306f5c2b79024a417b6396 upstream.
sb_getblk() is used during ext4 (and possibly other FSes) writeback
paths. Sometimes such path require allocating memory and guaranteeing
that such allocation won't block. Currently, however, there is no way
to provide user flags for sb_getblk which could lead to deadlocks.
This patch implements a sb_getblk_gfp with the only difference it can
accept user-provided GFP flags.
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
commit 1e25aa9641e8f3fa39cd5e46b4afcafd7f12a44b upstream.
By default all the sensors are runtime suspended state (lowest power
state). During Linux suspend process, all the run time suspended
devices are resumed and then suspended. This caused all sensors to
power up and introduced delay in suspend time, when we introduced
runtime PM for HID sensors. The opposite process happens during resume
process.
To fix this, we do powerup process of the sensors only when the request
is issued from user (raw or tiggerred). In this way when runtime,
resume calls for powerup it will simply return as this will not match
user requested state.
Note this is a regression fix as the increase in suspend / resume
times can be substantial (report of 8 seconds on Len's laptop!)
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Tested-by: Len Brown <len.brown@intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 3a9ad0b4fdcd57f775d3615004c8c64c021a9e7d upstream.
David Ahern reported that d63e2e1f3df9 ("sparc/PCI: Clip bridge windows
to fit in upstream windows") fails to boot on sparc/T5-8:
pci 0000:06:00.0: reg 0x184: can't handle BAR above 4GB (bus address 0x110204000)
The problem is that sparc64 assumed that dma_addr_t only needed to hold DMA
addresses, i.e., bus addresses returned via the DMA API (dma_map_single(),
etc.), while the PCI core assumed dma_addr_t could hold *any* bus address,
including raw BAR values. On sparc64, all DMA addresses fit in 32 bits, so
dma_addr_t is a 32-bit type. However, BAR values can be 64 bits wide, so
they don't fit in a dma_addr_t. d63e2e1f3df9 added new checking that
tripped over this mismatch.
Add pci_bus_addr_t, which is wide enough to hold any PCI bus address,
including both raw BAR values and DMA addresses. This will be 64 bits
on 64-bit platforms and on platforms with a 64-bit dma_addr_t. Then
dma_addr_t only needs to be wide enough to hold addresses from the DMA API.
[bhelgaas: changelog, bugzilla, Kconfig to ensure pci_bus_addr_t is at
least as wide as dma_addr_t, documentation]
Fixes: d63e2e1f3df9 ("sparc/PCI: Clip bridge windows to fit in upstream windows")
Fixes: 23b13bc76f35 ("PCI: Fail safely if we can't handle BARs larger than 4GB")
Link: http://lkml.kernel.org/r/CAE9FiQU1gJY1LYrxs+ma5LCTEEe4xmtjRG0aXJ9K_Tsu+m9Wuw@mail.gmail.com
Link: http://lkml.kernel.org/r/1427857069-6789-1-git-send-email-yinghai@kernel.org
Link: https://bugzilla.kernel.org/show_bug.cgi?id=96231
Reported-by: David Ahern <david.ahern@oracle.com>
Tested-by: David Ahern <david.ahern@oracle.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 0824965140fff1bf640a987dc790d1594a8e0699 upstream.
Refine the mechanism introduced by commit f244d8b623da ("ACPIPHP / radeon /
nouveau: Fix VGA switcheroo problem related to hotplug") to propagate the
ignore_hotplug setting of the device to its parent bridge in case hotplug
notifications related to the graphics adapter switching are given for the
bridge rather than for the device itself (they need to be ignored in both
cases).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=61891
Link: https://bugs.freedesktop.org/show_bug.cgi?id=88927
Fixes: b440bde74f04 ("PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device")
Reported-and-tested-by: tiagdtd-lava <tiagdtd-lava@yahoo.de>
commit 8a8c35fadfaf55629a37ef1a8ead1b8fb32581d2 upstream.
Beginning at commit d52d3997f843 ("ipv6: Create percpu rt6_info"), the
following INFO splat is logged:
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-next-20150612 #1 Not tainted
kernel/sched/core.c:7318 Illegal context switch in RCU-bh read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
3 locks held by systemd/1:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815f0c8f>] rtnetlink_rcv+0x1f/0x40
#1: (rcu_read_lock_bh){......}, at: [<ffffffff816a34e2>] ipv6_add_addr+0x62/0x540
#2: (addrconf_hash_lock){+...+.}, at: [<ffffffff816a3604>] ipv6_add_addr+0x184/0x540
stack backtrace:
CPU: 0 PID: 1 Comm: systemd Not tainted 4.1.0-rc7-next-20150612 #1
Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014
Call Trace:
dump_stack+0x4c/0x6e
lockdep_rcu_suspicious+0xe7/0x120
___might_sleep+0x1d5/0x1f0
__might_sleep+0x4d/0x90
kmem_cache_alloc+0x47/0x250
create_object+0x39/0x2e0
kmemleak_alloc_percpu+0x61/0xe0
pcpu_alloc+0x370/0x630
Additional backtrace lines are truncated. In addition, the above splat
is followed by several "BUG: sleeping function called from invalid
context at mm/slub.c:1268" outputs. As suggested by Martin KaFai Lau,
these are the clue to the fix. Routine kmemleak_alloc_percpu() always
uses GFP_KERNEL for its allocations, whereas it should follow the gfp
from its callers.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tejun Heo <tj@kernel.org>
commit 7f1a57fdd6cb6e7be2ed31878a34655df38e1861 upstream.
Don't call the power_supply_changed() from power_supply_register() when
parent is still probing because it may lead to accessing parent too
early.
In bq27x00_battery this caused NULL pointer exception because uevent of
power_supply_changed called back the the get_property() method provided
by the driver. The get_property() method accessed pointer which should
be returned by power_supply_register().
Starting from bq27x00_battery_probe():
di->bat = power_supply_register()
kobject_uevent()
power_supply_uevent()
power_supply_show_property()
power_supply_get_property()
bq27x00_battery_get_property()
dereference of di->bat which is NULL here
The dereference of di->bat (value returned by power_supply_register())
is the currently visible problem. However calling back the methods
provided by driver before ending the probe may lead to accessing other
driver-related data which is not yet initialized.
The call to power_supply_changed() is postponed till probing ends -
mutex of parent device is released.
Reported-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 297d716f6260 ("power_supply: Change ownership from driver to core")
Tested-By: Dr. H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
commit 0f1b414d190724617eb1cdd615592fa8cd9d0b50 upstream.
Commit b9a5e5e18fbf "ACPI / init: Fix the ordering of
acpi_reserve_resources()" overlooked the fact that the memory
and/or I/O regions reserved by acpi_reserve_resources() may
conflict with those reserved by the PNP "system" driver.
If that conflict actually takes place, it causes the reservations
made by the "system" driver to fail while before commit b9a5e5e18fbf
all reservations made by it and by acpi_reserve_resources() would be
successful. In turn, that allows the resources that haven't been
reserved by the "system" driver to be used by others (e.g. PCI) which
sometimes leads to functional problems (up to and including boot
failures).
To fix that issue, introduce a common resource reservation routine,
acpi_reserve_region(), to be used by both acpi_reserve_resources()
and the "system" driver, that will track all resources reserved by
it and avoid making conflicting requests.
commit b064a8fa77dfead647564c46ac8fc5b13bd1ab73 upstream.
Commit 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before
timekeeping_init()" moved the ACPI subsystem initialization,
including the ACPI mode enabling, to an earlier point in the
initialization sequence, to allow the timekeeping subsystem
use ACPI early. Unfortunately, that resulted in boot regressions
on some systems and the early ACPI initialization was moved toward
its original position in the kernel initialization code by commit
c4e1acbb35e4 "ACPI / init: Invoke early ACPI initialization later".
However, that turns out to be insufficient, as boot is still broken
on the Tyan S8812 mainboard.
To fix that issue, split the ACPI early initialization code into
two pieces so the majority of it still located in acpi_early_init()
and the part switching over the platform into the ACPI mode goes into
a new function, acpi_subsystem_init(), executed at the original early
ACPI initialization spot.
That fixes the Tyan S8812 boot problem, but still allows ACPI
tables to be loaded earlier which is useful to the EFI code in
efi_enter_virtual_mode().
Link: https://bugzilla.kernel.org/show_bug.cgi?id=97141
Fixes: 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before timekeeping_init()"
Reported-and-tested-by: Marius Tolzmann <tolzmann@molgen.mpg.de>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Lee, Chun-Yi <jlee@suse.com>
commit 1b852bceb0d111e510d1a15826ecc4a19358d512 upstream.
Fresh mounts of proc and sysfs are a very special case that works very
much like a bind mount. Unfortunately the current structure can not
preserve the MNT_LOCK... mount flags. Therefore refactor the logic
into a form that can be modified to preserve those lock bits.
Add a new filesystem flag FS_USERNS_VISIBLE that requires some mount
of the filesystem be fully visible in the current mount namespace,
before the filesystem may be mounted.
Move the logic for calling fs_fully_visible from proc and sysfs into
fs/namespace.c where it has greater access to mount namespace state.
commit 87d2846fcf88113fae2341da1ca9a71f0d916f2c upstream.
Add two functions sysfs_create_mount_point and
sysfs_remove_mount_point that hang a permanently empty directory off
of a kobject or remove a permanently emptpy directory hanging from a
kobject. Export these new functions so modular filesystems can use
them.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit ea015218f2f7ace2dad9cedd21ed95bdba2886d7 upstream.
Add a new function kernfs_create_empty_dir that can be used to create
directory that can not be modified.
Update the code to use make_empty_dir_inode when reporting a
permanently empty directory to the vfs.
Update the code to not allow adding to permanently empty directories.
commit f9bd6733d3f11e24f3949becf277507d422ee1eb upstream.
Add a magic sysctl table sysctl_mount_point that when used to
create a directory forces that directory to be permanently empty.
Update the code to use make_empty_dir_inode when accessing permanently
empty directories.
Update /proc/sys/fs/binfmt_misc to be a permanently empty directory.
commit fbabfd0f4ee2e8847bf56edf481249ad1bb8c44d upstream.
To ensure it is safe to mount proc and sysfs I need to check if
filesystems that are mounted on top of them are mounted on truly empty
directories. Given that some directories can gain entries over time,
knowing that a directory is empty right now is insufficient.
Therefore add supporting infrastructure for permantently empty
directories that proc and sysfs can use when they create mount points
for filesystems and fs_fully_visible can use to test for permanently
empty directories to ensure that nothing will be gained by mounting a
fresh copy of proc or sysfs.
[ Upstream commit 2d45a02d0166caf2627fe91897c6ffc3b19514c4 ]
->auto_asconf_splist is per namespace and mangled by functions like
sctp_setsockopt_auto_asconf() which doesn't guarantee any serialization.
Also, the call to inet_sk_copy_descendant() was backuping
->auto_asconf_list through the copy but was not honoring
->do_auto_asconf, which could lead to list corruption if it was
different between both sockets.
This commit thus fixes the list handling by using ->addr_wq_lock
spinlock to protect the list. A special handling is done upon socket
creation and destruction for that. Error handlig on sctp_init_sock()
will never return an error after having initialized asconf, so
sctp_destroy_sock() can be called without addrq_wq_lock. The lock now
will be take on sctp_close_sock(), before locking the socket, so we
don't do it in inverse order compared to sctp_addr_wq_timeout_handler().
Instead of taking the lock on sctp_sock_migrate() for copying and
restoring the list values, it's preferred to avoid rewritting it by
implementing sctp_copy_descendant().
Issue was found with a test application that kept flipping sysctl
default_auto_asconf on and off, but one could trigger it by issuing
simultaneous setsockopt() calls on multiple sockets or by
creating/destroying sockets fast enough. This is only triggerable
locally.
Fixes: 9f7d653b67ae ("sctp: Add Auto-ASCONF support (core).")
Reported-by: Ji Jianwen <jiji@redhat.com>
Suggested-by: Neil Horman <nhorman@tuxdriver.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
This tells userspace that it's safe to use the RADEON_VA_UNMAP operation
of the DRM_RADEON_GEM_VA ioctl.
Cc: stable@vger.kernel.org
(NOTE: Backporting this commit requires at least backports of commits
26d4d129b6042197b4cbc8341c0618f99231af2f,
48afbd70ac7b6aa62e8d452091023941d8085f8a and
c29c0876ec05d51a93508a39b90b92c29ba6423d as well, otherwise using
RADEON_VA_UNMAP runs into trouble)
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Christian König <christian.koenig@amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Most of commits are regression fixes for HD-audio: a few corner case
fixes for regmap transition, and i915 binding issues.
In addition, a quirk for another USB-audio device supporting DSD"
* tag 'sound-4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Abort the probe without i915 binding for HSW/BDW
ALSA: hda - Re-add the lost fake mute support
ALSA: hda - Continue probing even if i915 binding fails
ALSA: hda - Don't actually write registers for caps overwrites
ALSA: hda - fix number of devices query on hotplug
ALSA: usb-audio: add native DSD support for JLsounds I2SoverUSB
Pull VT-d hardware workarounds from David Woodhouse:
"This contains a workaround for hardware issues which I *thought* were
never going to be seen on production hardware. I'm glad I checked
that before the 4.1 release...
Firstly, PASID support is so broken on existing chips that we're just
going to declare the old capability bit 28 as 'reserved' and change
the VT-d spec to move PASID support to another bit. So any existing
hardware doesn't support SVM; it only sets that (now) meaningless bit
28.
That patch *wasn't* imperative for 4.1 because we don't have PASID
support yet. But *even* the extended context tables are broken — if
you just enable the wider tables and use none of the new bits in them,
which is precisely what 4.1 does, you find that translations don't
work. It's this problem which I thought was caught in time to be
fixed before production, but wasn't.
To avoid triggering this issue, we now *only* enable the extended
context tables on hardware which also advertises "we have PASID
support and we actually tested it this time" with the new PASID
feature bit.
In addition, I've added an 'intel_iommu=ecs_off' command line
parameter to allow us to disable it manually if we need to"
* git://git.infradead.org/intel-iommu:
iommu/vt-d: Only enable extended context tables if PASID is supported
iommu/vt-d: Change PASID support to bit 40 of Extended Capability Register
Yet another regression by the transition to regmap cache; for better
usability, we had the fake mute control using the zero amp value for
Conexant codecs, and this was forgotten in the new hda core code.
Since the bits 4-7 are unused for the amp registers (as we follow the
syntax of AMP_GET verb), the bit 4 is now used to indicate the fake
mute. For setting this flag, snd_hda_codec_amp_update() becomes a
function from a simple macro. The bonus is that it gained a proper
function description.
The existing hardware implementations with PASID support advertised in
bit 28? Forget them. They do not exist. Bit 28 means nothing. When we
have something that works, it'll use bit 40. Do not attempt to infer
anything meaningful from bit 28.
This will be reflected in an updated VT-d spec in the extremely near
future.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg KH:
"Here are two fixes for the driver core that resolve some reported
issues.
One is a regression from 4.0, the other a fixes a reported oops that
has been there since 3.19.
Both have been in linux-next for a while with no problems"
* tag 'driver-core-4.1-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
drivers/base: cacheinfo: handle absence of caches
drivers: of/base: move of_init to driver_init
Pull perf fixes from Ingo Molnar:
"The biggest chunk of the changes are two regression fixes: a HT
workaround fix and an event-group scheduling fix. It's been verified
with 5 days of fuzzer testing.
Other fixes:
- eBPF fix
- a BIOS breakage detection fix
- PMU driver fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel/pt: Fix a refactoring bug
perf/x86: Tweak broken BIOS rules during check_hw_exists()
perf/x86/intel/pt: Untangle pt_buffer_reset_markers()
perf: Disallow sparse AUX allocations for non-SG PMUs in overwrite mode
perf/x86: Improve HT workaround GP counter constraint
perf/x86: Fix event/group validation
perf: Fix race in BPF program unregister
Pull block layer fixes from Jens Axboe:
"Sending this off now, as I'm not aware of other current bugs, nor do I
expect further fixes before 4.1 final. This contains two fixes:
- a fix for a bdi unregister warning that gets spewed on md, due to a
regression introduced earlier in this cycle. From Neil Brown.
- a fix for a compile warning for NVMe on 32-bit platforms, also a
regression introduced in this cycle. From Arnd Bergmann"
* 'for-linus' of git://git.kernel.dk/linux-block:
NVMe: fix type warning on 32-bit
block: discard bdi_unregister() in favour of bdi_destroy()
Pull networking fixes from David Miller:
1) Various VTI tunnel (mark handling, PMTU) bug fixes from Alexander
Duyck and Steffen Klassert.
2) Revert ethtool PHY query change, it wasn't correct. The PHY address
selected by the driver running the PHY to MAC connection decides
what PHY address GET ethtool operations return information from.
3) Fix handling of sequence number bits for encryption IV generation in
ESP driver, from Herbert Xu.
4) UDP can return -EAGAIN when we hit a bad checksum on receive, even
when there are other packets in the receive queue which is wrong.
Just respect the error returned from the generic socket recv
datagram helper. From Eric Dumazet.
5) Fix BNA driver firmware loading on big-endian systems, from Ivan
Vecera.
6) Fix regression in that we were inheriting the congestion control of
the listening socket for new connections, the intended behavior
always was to use the default in this case. From Neal Cardwell.
7) Fix NULL deref in brcmfmac driver, from Arend van Spriel.
8) OTP parsing fix in iwlwifi from Liad Kaufman.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (26 commits)
vti6: Add pmtu handling to vti6_xmit.
Revert "net: core: 'ethtool' issue with querying phy settings"
bnx2x: Move statistics implementation into semaphores
xen: netback: read hotplug script once at start of day.
xen: netback: fix printf format string warning
Revert "netfilter: ensure number of counters is >0 in do_replace()"
net: dsa: Properly propagate errors from dsa_switch_setup_one
tcp: fix child sockets to use system default congestion control if not set
udp: fix behavior of wrong checksums
sfc: free multiple Rx buffers when required
bna: fix soft lock-up during firmware initialization failure
bna: remove unreasonable iocpf timer start
bna: fix firmware loading on big-endian machines
bridge: fix br_multicast_query_expired() bug
via-rhine: Resigning as maintainer
brcmfmac: avoid null pointer access when brcmf_msgbuf_get_pktid() fails
mac80211: Fix mac80211.h docbook comments
iwlwifi: nvm: fix otp parsing in 8000 hw family
iwlwifi: pcie: fix tracking of cmd_in_flight
ip_vti/ip6_vti: Preserve skb->mark after rcv_cb call
Fixes userspace compilation error:
error: unknown type name ‘__virtio16’
__virtio16 tag;
Signed-off-by: Mikko Rapeli <mikko.rapeli@iki.fi>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Linux 3.17 and earlier are explicitly engineered so that if the app
doesn't specifically request a CC module on a listener before the SYN
arrives, then the child gets the system default CC when the connection
is established. See tcp_init_congestion_control() in 3.17 or earlier,
which says "if no choice made yet assign the current value set as
default". The change ("net: tcp: assign tcp cong_ops when tcp sk is
created") altered these semantics, so that children got their parent
listener's congestion control even if the system default had changed
after the listener was created.
This commit returns to those original semantics from 3.17 and earlier,
since they are the original semantics from 2007 in 4d4d3d1e8 ("[TCP]:
Congestion control initialization."), and some Linux congestion
control workflows depend on that.
In summary, if a listener socket specifically sets TCP_CONGESTION to
"x", or the route locks the CC module to "x", then the child gets
"x". Otherwise the child gets current system default from
net.ipv4.tcp_congestion_control. That's the behavior in 3.17 and
earlier, and this commit restores that.
Fixes: 55d8694fa82c ("net: tcp: assign tcp cong_ops when tcp sk is created")
Cc: Florian Westphal <fw@strlen.de>
Cc: Daniel Borkmann <dborkman@redhat.com>
Cc: Glenn Judd <glenn.judd@morganstanley.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Pull SCSI target fixes from Nicholas Bellinger:
"These are mostly minor fixes, with the exception of the following that
address fall-out from recent v4.1-rc1 changes:
- regression fix related to the big fabric API registration changes
and configfs_depend_item() usage, that required cherry-picking one
of HCH's patches from for-next to address the issue for v4.1 code.
- remaining TCM-USER -v2 related changes to enforce full CDB
passthrough from Andy + Ilias.
Also included is a target_core_pscsi driver fix from Andy that
addresses a long standing issue with a Scsi_Host reference being
leaked on PSCSI device shutdown"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iser-target: Fix error path in isert_create_pi_ctx()
target: Use a PASSTHROUGH flag instead of transport_types
target: Move passthrough CDB parsing into a common function
target/user: Only support full command pass-through
target/user: Update example code for new ABI requirements
target/pscsi: Don't leak scsi_host if hba is VIRTUAL_HOST
target: Fix se_tpg_tfo->tf_subsys regression + remove tf_subsystem
target: Drop signal_pending checks after interruptible lock acquire
target: Add missing parentheses
target: Fix bidi command handling
target/user: Disallow full passthrough (pass_level=0)
ISCSI: fix minor memory leak
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Johannes Berg says:
This just has a single docbook build fix. In my confusion
I'd already sent the same fix for -next, but Ben Hutchings
noted it's necessary in 4.1.
It seems like we only care if a transport is passthrough or not. Convert
transport_type to a flags field and replace TRANSPORT_PLUGIN_* with a
flag, TRANSPORT_FLAG_PASSTHROUGH.
Signed-off-by: Andy Grover <agrover@redhat.com>
Reviewed-by: Ilias Tsitsimpis <iliastsi@arrikto.com>
Aside from whether they handle BIDI ops or not, parsing of the CDB by
kernel and user SCSI passthrough modules should be identical. Move this
into a new passthrough_parse_cdb() and call it from tcm-pscsi and tcm-user.
Reported-by: Christoph Hellwig <hch@lst.de>
There is just one configfs subsystem in the target code, so we might as
well add two helpers to reference / unreference it from the core code
instead of passing pointers to it around.
This fixes a regression introduced for v4.1-rc1 with commit 9ac8928e6,
where configfs_depend_item() callers using se_tpg_tfo->tf_subsys would
fail, because the assignment from the original target_core_subsystem[]
is no longer happening at target_register_template() time.
(Fix target_core_exit_configfs pointer dereference - Sagi)
Reported-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs fixes from Dave Chinner:
"This is a little larger than I'd like late in the release cycle, but
all the fixes are for regressions introduced in the 4.1-rc1 merge, or
are needed back in -stable kernels fairly quickly as they are
filesystem corruption or userspace visible correctness issues.
Changes in this update:
- regression fix for new rename whiteout code
- regression fixes for new superblock generic per-cpu counter code
- fix for incorrect error return sign introduced in 3.17
- metadata corruption fixes that need to go back to -stable kernels"
* tag 'xfs-for-linus-4.1-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs:
xfs: fix broken i_nlink accounting for whiteout tmpfile inode
xfs: xfs_iozero can return positive errno
xfs: xfs_attr_inactive leaves inconsistent attr fork state behind
xfs: extent size hints can round up extents past MAXEXTLEN
xfs: inode and free block counters need to use __percpu_counter_compare
percpu_counter: batch size aware __percpu_counter_compare()
xfs: use percpu_counter_read_positive for mp->m_icount
Merge misc fixes from Andrew Morton:
"10 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
scripts/gdb: fix lx-lsmod refcnt
omfs: fix potential integer overflow in allocator
omfs: fix sign confusion for bitmap loop counter
omfs: set error return when d_make_root() fails
fs, omfs: add NULL terminator in the end up the token list
MAINTAINERS: update CAPABILITIES pattern
fs/binfmt_elf.c:load_elf_binary(): return -EINVAL on zero-length mappings
tracing/mm: don't trace mm_page_pcpu_drain on offline cpus
tracing/mm: don't trace mm_page_free on offline cpus
tracing/mm: don't trace kmem_cache_free on offline cpus
