While an interface is down, many implementations of
ethtool_ops::get_link, including the default, ethtool_op_get_link(),
will report the last link state seen while the interface was up. In
general the current physical link state is not available if the
interface is down.
Define ETHTOOL_GLINK to reflect whether the interface *and* any
physical port have a working link, and consistently return 0 when the
interface is down.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
(cherry picked from commit e596e6e4d578f2639416e620d367a3af34814a40)
Cc: Wang Weidong <wangweidong1@huawei.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
pending data
CVE-2013-4162
BugLink: http://bugs.launchpad.net/bugs/1205070
We accidentally call down to ip6_push_pending_frames when uncorking
pending AF_INET data on a ipv6 socket. This results in the following
splat (from Dave Jones):
skbuff: skb_under_panic: text:ffffffff816765f6 len:48 put:40 head:ffff88013deb6df0 data:ffff88013deb6dec tail:0x2c end:0xc0 dev:<NULL>
kernel BUG at net/core/skbuff.c:126!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in: dccp_ipv4 dccp 8021q garp bridge stp dlci mpoa snd_seq_dummy sctp fuse hidp tun bnep nfnetlink scsi_transport_iscsi rfcomm can_raw can_bcm af_802154 appletalk caif_socket can caif ipt_ULOG x25 rose af_key pppoe pppox ipx phonet irda llc2 ppp_generic slhc p8023 psnap p8022 llc crc_ccitt atm bluetooth
+netrom ax25 nfc rfkill rds af_rxrpc coretemp hwmon kvm_intel kvm crc32c_intel snd_hda_codec_realtek ghash_clmulni_intel microcode pcspkr snd_hda_codec_hdmi snd_hda_intel snd_hda_codec snd_hwdep usb_debug snd_seq snd_seq_device snd_pcm e1000e snd_page_alloc snd_timer ptp snd pps_core soundcore xfs libcrc32c
CPU: 2 PID: 8095 Comm: trinity-child2 Not tainted 3.10.0-rc7+ #37
task: ffff8801f52c2520 ti: ffff8801e6430000 task.ti: ffff8801e6430000
RIP: 0010:[<ffffffff816e759c>] [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP: 0018:ffff8801e6431de8 EFLAGS: 00010282
RAX: 0000000000000086 RBX: ffff8802353d3cc0 RCX: 0000000000000006
RDX: 0000000000003b90 RSI: ffff8801f52c2ca0 RDI: ffff8801f52c2520
RBP: ffff8801e6431e08 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000001 R12: ffff88022ea0c800
R13: ffff88022ea0cdf8 R14: ffff8802353ecb40 R15: ffffffff81cc7800
FS: 00007f5720a10740(0000) GS:ffff880244c00000(0000) knlGS:0000000000000000
CR2: 0000000005862000 CR3: 000000022843c000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600
Stack:
ffff88013deb6dec 000000000000002c 00000000000000c0 ffffffff81a3f6e4
ffff8801e6431e18 ffffffff8159a9aa ffff8801e6431e90 ffffffff816765f6
ffffffff810b756b 0000000700000002 ffff8801e6431e40 0000fea9292aa8c0
Call Trace:
[<ffffffff8159a9aa>] skb_push+0x3a/0x40
[<ffffffff816765f6>] ip6_push_pending_frames+0x1f6/0x4d0
[<ffffffff810b756b>] ? mark_held_locks+0xbb/0x140
[<ffffffff81694919>] udp_v6_push_pending_frames+0x2b9/0x3d0
[<ffffffff81694660>] ? udplite_getfrag+0x20/0x20
[<ffffffff8162092a>] udp_lib_setsockopt+0x1aa/0x1f0
[<ffffffff811cc5e7>] ? fget_light+0x387/0x4f0
[<ffffffff816958a4>] udpv6_setsockopt+0x34/0x40
[<ffffffff815949f4>] sock_common_setsockopt+0x14/0x20
[<ffffffff81593c31>] SyS_setsockopt+0x71/0xd0
[<ffffffff816f5d54>] tracesys+0xdd/0xe2
Code: 00 00 48 89 44 24 10 8b 87 d8 00 00 00 48 89 44 24 08 48 8b 87 e8 00 00 00 48 c7 c7 c0 04 aa 81 48 89 04 24 31 c0 e8 e1 7e ff ff <0f> 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55
RIP [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP <ffff8801e6431de8>
This patch adds a check if the pending data is of address family AF_INET
and directly calls udp_push_ending_frames from udp_v6_push_pending_frames
if that is the case.
This bug was found by Dave Jones with trinity.
(Also move the initialization of fl6 below the AF_INET check, even if
not strictly necessary.)
Cc: Dave Jones <davej@redhat.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
(back ported from commit 8822b64a0fa64a5dd1dfcf837c5b0be83f8c05d1)
Signed-off-by: Luis Henriques <luis.henriques@canonical.com>
Acked-by: Brad Figg <brad.figg@canonical.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit d049f74f2dbe71354d43d393ac3a188947811348 upstream
The get_dumpable() return value is not boolean. Most users of the
function actually want to be testing for non-SUID_DUMP_USER(1) rather than
SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a
protected state. Almost all places did this correctly, excepting the two
places fixed in this patch.
Wrong logic:
if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ }
or
if (dumpable == 0) { /* be protective */ }
or
if (!dumpable) { /* be protective */ }
Correct logic:
if (dumpable != SUID_DUMP_USER) { /* be protective */ }
or
if (dumpable != 1) { /* be protective */ }
Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a
user was able to ptrace attach to processes that had dropped privileges to
that user. (This may have been partially mitigated if Yama was enabled.)
The macros have been moved into the file that declares get/set_dumpable(),
which means things like the ia64 code can see them too.
CVE-2013-2929
Reported-by: Vasily Kulikov <segoon@openwall.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: <stable@vger.kernel.org>
[dannf: backported to Debian's 2.6.32]
Various drivers end up replicating the code to mmap() their memory
buffers into user space, and our core memory remapping function may be
very flexible but it is unnecessarily complicated for the common cases
to use.
Our internal VM uses pfn's ("page frame numbers") which simplifies
things for the VM, and allows us to pass physical addresses around in a
denser and more efficient format than passing a "phys_addr_t" around,
and having to shift it up and down by the page size. But it just means
that drivers end up doing that shifting instead at the interface level.
It also means that drivers end up mucking around with internal VM things
like the vma details (vm_pgoff, vm_start/end) way more than they really
need to.
So this just exports a function to map a certain physical memory range
into user space (using a phys_addr_t based interface that is much more
natural for a driver) and hides all the complexity from the driver.
Some drivers will still end up tweaking the vm_page_prot details for
things like prefetching or cacheability etc, but that's actually
relevant to the driver, rather than caring about what the page offset of
the mapping is into the particular IO memory region.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
(cherry picked from commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e)
[WT: only needed in 2.6.32 for next commit]
functions
[ Upstream commit 85fbaa75037d0b6b786ff18658ddf0b4014ce2a4 ]
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
CVE-2013-7266
BugLink: http://bugs.launchpad.net/bugs/1267081
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
(back ported from commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c)
Acked-by: Andy Whitcroft <andy.whitcroft@canonical.com>
Acked-by: Stefan Bader <stefan.bader@canonical.com>
[ Upstream commit 61e76b178dbe7145e8d6afa84bb4ccea71918994 ]
RFC 4443 has defined two additional codes for ICMPv6 type 1 (destination
unreachable) messages:
5 - Source address failed ingress/egress policy
6 - Reject route to destination
Now they are treated as protocol error and icmpv6_err_convert() converts them
to EPROTO.
RFC 4443 says:
"Codes 5 and 6 are more informative subsets of code 1."
Treat codes 5 and 6 as code 1 (EACCES)
Btw, connect() returning -EPROTO confuses firefox, so that fallback to
other/IPv4 addresses does not work:
https://bugzilla.mozilla.org/show_bug.cgi?id=910773
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit f46078cfcd77fa5165bf849f5e568a7ac5fa569c ]
It is not allowed for an ipv6 packet to contain multiple fragmentation
headers. So discard packets which were already reassembled by
fragmentation logic and send back a parameter problem icmp.
The updates for RFC 6980 will come in later, I have to do a bit more
research here.
[ Upstream commit b1a5a34bd0b8767ea689e68f8ea513e9710b671e ]
Ver and type in pppoe_hdr should be swapped as defined by RFC2516
section-4.
[ Upstream commit e87b3998d795123b4139bc3f25490dd236f68212 ]
dst->xfrm is conditionally defined. Provide accessor funtion that
is always available.
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit c52e2421f7368fd36cbe330d2cf41b10452e39a9 ]
TCP stack should make sure it owns skbs before mangling them.
We had various crashes using bnx2x, and it turned out gso_size
was cleared right before bnx2x driver was populating TC descriptor
of the _previous_ packet send. TCP stack can sometime retransmit
packets that are still in Qdisc.
Of course we could make bnx2x driver more robust (using
ACCESS_ONCE(shinfo->gso_size) for example), but the bug is TCP stack.
We have identified two points where skb_unclone() was needed.
This patch adds a WARN_ON_ONCE() to warn us if we missed another
fix of this kind.
Kudos to Neal for finding the root cause of this bug. Its visible
using small MSS.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream
Many drivers need to validate the characteristics of their HID report
during initialization to avoid misusing the reports. This adds a common
helper to perform validation of the report exisitng, the field existing,
and the expected number of values within the field.
Cc: stable@vger.kernel.org
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
[jmm: backported to 2.6.32]
[wt: dev_err() in 2.6.32 instead of hid_err()]
commit 43622021d2e2b82ea03d883926605bdd0525e1d1 upstream
The "Report ID" field of a HID report is used to build indexes of
reports. The kernel's index of these is limited to 256 entries, so any
malicious device that sets a Report ID greater than 255 will trigger
memory corruption on the host:
[ 1347.156239] BUG: unable to handle kernel paging request at ffff88094958a878
[ 1347.156261] IP: [<ffffffff813e4da0>] hid_register_report+0x2a/0x8b
CVE-2013-2888
Cc: stable@kernel.org
[jmm: backport to 2.6.32]
commit d5ccd496601b8776a516d167a6485754575dc38f upstream
Attempt to reduce the number of IP packets emitted in response to single
SCTP packet (2e3216cd) introduced a complication - if a packet contains
two COOKIE_ECHO chunks and nothing else then SCTP state machine corks the
socket while processing first COOKIE_ECHO and then loses the association
and forgets to uncork the socket. To deal with the issue add new SCTP
command which can be used to set association explictly. Use this new
command when processing second COOKIE_ECHO chunk to restore the context
for SCTP state machine.
Signed-off-by: Max Matveev <makc@redhat.com>
Thomas Bork reported that commit c6203cd ("scsi: use __uX
types for headers exported to user space") caused a regression
as now he's getting this warning :
> /usr/src/linux-2.6.32-eisfair-1/usr/include/scsi/scsi_netlink.h:108:
> found __[us]{8,16,32,64} type without #include <linux/types.h>
This issue was addressed later by commit 10db4e1 ("headers:
include linux/types.h where appropriate"), so let's just pick the
relevant part from it.
Cc: Thomas Bork <tom@eisfair.net>
[ Backport of upstream commit 87c48fa3b4630905f98268dde838ee43626a060c ]
Fernando Gont reported current IPv6 fragment identification generation
was not secure, because using a very predictable system-wide generator,
allowing various attacks.
IPv4 uses inetpeer cache to address this problem and to get good
performance. We'll use this mechanism when IPv6 inetpeer is stable
enough in linux-3.1
For the time being, we use jhash on destination address to provide less
predictable identifications. Also remove a spinlock and use cmpxchg() to
get better SMP performance.
Reported-by: Fernando Gont <fernando@gont.com.ar>
[bwh: Backport further to 2.6.32]
[ This combines upstream commit
2f53384424251c06038ae612e56231b96ab610ee and the follow-on bug fix
commit 35f9c09fe9c72eb8ca2b8e89a593e1c151f28fc2 ]
vmsplice()/splice(pipe, socket) call do_tcp_sendpages() one page at a
time, adding at most 4096 bytes to an skb. (assuming PAGE_SIZE=4096)
The call to tcp_push() at the end of do_tcp_sendpages() forces an
immediate xmit when pipe is not already filled, and tso_fragment() try
to split these skb to MSS multiples.
4096 bytes are usually split in a skb with 2 MSS, and a remaining
sub-mss skb (assuming MTU=1500)
This makes slow start suboptimal because many small frames are sent to
qdisc/driver layers instead of big ones (constrained by cwnd and packets
in flight of course)
In fact, applications using sendmsg() (adding an additional memory copy)
instead of vmsplice()/splice()/sendfile() are a bit faster because of
this anomaly, especially if serving small files in environments with
large initial [c]wnd.
Call tcp_push() only if MSG_MORE is not set in the flags parameter.
This bit is automatically provided by splice() internals but for the
last page, or on all pages if user specified SPLICE_F_MORE splice()
flag.
In some workloads, this can reduce number of sent logical packets by an
order of magnitude, making zero-copy TCP actually faster than
one-copy :)
Reported-by: Tom Herbert <therbert@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Mahesh Bandewar <maheshb@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
commit f6d8bd051c391c1c0458a30b2a7abcd939329259 upstream.
We lack proper synchronization to manipulate inet->opt ip_options
Problem is ip_make_skb() calls ip_setup_cork() and
ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options),
without any protection against another thread manipulating inet->opt.
Another thread can change inet->opt pointer and free old one under us.
Use RCU to protect inet->opt (changed to inet->inet_opt).
Instead of handling atomic refcounts, just copy ip_options when
necessary, to avoid cache line dirtying.
We cant insert an rcu_head in struct ip_options since its included in
skb->cb[], so this patch is large because I had to introduce a new
ip_options_rcu structure.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
[dannf/bwh: backported to Debian's 2.6.32]
commit 0720a06a7518c9d0c0125bd5d1f3b6264c55c3dd upstream.
The utf8s_to_utf16s conversion routine needs to be improved. Unlike
its utf16s_to_utf8s sibling, it doesn't accept arguments specifying
the maximum length of the output buffer or the endianness of its
16-bit output.
This patch (as1501) adds the two missing arguments, and adjusts the
only two places in the kernel where the function is called. A
follow-on patch will add a third caller that does utilize the new
capabilities.
The two conversion routines are still annoyingly inconsistent in the
way they handle invalid byte combinations. But that's a subject for a
different patch.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Clemens Ladisch <clemens@ladisch.de>
[bwh: Bakckported to 2.6.32: drop Hyper-V change]
commit eeb5b4ae81f4a750355fa0c15f4fea22fdf83be1 upstream.
I found that the length of a file name when created cannot exceed 255
characters, yet, pathconf(), via statfs(), returns the maximum as 260.
Signed-off-by: Kevin Dankwardt <k@kcomputing.com>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Commit 9e4f5e29 ("FC Pass Thru support") exported a number of header files
in include/scsi to user space, but didn't change the uX types to the
userspace-compatible __uX types. Without that you'll get compile errors
when including them - E.G.:
include/scsi/scsi.h:145: error: expected specifier-qualifier-list before `u8'
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: James Smart <james.smart@emulex.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
(cherry picked from commit 083c8c1e60e5c27a277e87dbeb6b89b47937559f)
commit b22d127a39ddd10d93deee3d96e643657ad53a49 upstream.
shared_policy_replace() use of sp_alloc() is unsafe. 1) sp_node cannot
be dereferenced if sp->lock is not held and 2) another thread can modify
sp_node between spin_unlock for allocating a new sp node and next
spin_lock. The bug was introduced before 2.6.12-rc2.
Kosaki's original patch for this problem was to allocate an sp node and
policy within shared_policy_replace and initialise it when the lock is
reacquired. I was not keen on this approach because it partially
duplicates sp_alloc(). As the paths were sp->lock is taken are not that
performance critical this patch converts sp->lock to sp->mutex so it can
sleep when calling sp_alloc().
[kosaki.motohiro@jp.fujitsu.com: Original patch]
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Josh Boyer <jwboyer@gmail.com>
commit ad4b3fb7ff9940bcdb1e4cd62bd189d10fa636ba upstream.
Unfortunately with !CONFIG_PAGEFLAGS_EXTENDED, (!PageHead) is false, and
(PageHead) is true, for tail pages. If this is indeed the intended
behavior, which I doubt because it breaks cache cleaning on some ARM
systems, then the nomenclature is highly problematic.
This patch makes sure PageHead is only true for head pages and PageTail
is only true for tail pages, and neither is true for non-compound pages.
[ This buglet seems ancient - seems to have been introduced back in Apr
2008 in commit 6a1e7f777f61: "pageflags: convert to the use of new
macros". And the reason nobody noticed is because the PageHead()
tests are almost all about just sanity-checking, and only used on
pages that are actual page heads. The fact that the old code returned
true for tail pages too was thus not really noticeable. - Linus ]
Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Will Deacon <Will.Deacon@arm.com>
Cc: Steve Capper <Steve.Capper@arm.com>
Cc: Christoph Lameter <cl@linux.com>
commit 85f2a2ef1d0ab99523e0b947a2b723f5650ed6aa upstream.
When allocating memory fails, page is NULL. page_to_pfn() will
cause the kernel panicked if we don't use sparsemem vmemmap.
Link: http://lkml.kernel.org/r/505AB1FF.8020104@cn.fujitsu.com
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
ptrace: introduce signal_wake_up_state() and ptrace_signal_wake_up()
CVE-2013-0871
BugLink: http://bugs.launchpad.net/bugs/1129192
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
(backported from commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82)
kernel/ptrace.c
kernel/signal.c
Acked-by: Colin King <colin.king@canonical.com>
commit d740269867021faf4ce38a449353d2b986c34a67 upstream
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
commit b66c5984017533316fd1951770302649baf1aa33 upstream
If a series of scripts are executed, each triggering module loading via
unprintable bytes in the script header, kernel stack contents can leak
into the command line.
Normally execution of binfmt_script and binfmt_misc happens recursively.
However, when modules are enabled, and unprintable bytes exist in the
bprm->buf, execution will restart after attempting to load matching
binfmt modules. Unfortunately, the logic in binfmt_script and
binfmt_misc does not expect to get restarted. They leave bprm->interp
pointing to their local stack. This means on restart bprm->interp is
left pointing into unused stack memory which can then be copied into the
userspace argv areas.
After additional study, it seems that both recursion and restart remains
the desirable way to handle exec with scripts, misc, and modules. As
such, we need to protect the changes to interp.
This changes the logic to require allocation for any changes to the
bprm->interp. To avoid adding a new kmalloc to every exec, the default
value is left as-is. Only when passing through binfmt_script or
binfmt_misc does an allocation take place.
For a proof of concept, see DoTest.sh from:
http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/
commit d0bd587a80960d7ba7e0c8396e154028c9045c54 upstream
Implement UMH_KILLABLE, should be used along with UMH_WAIT_EXEC/PROC.
The caller must ensure that subprocess_info->path/etc can not go away
until call_usermodehelper_freeinfo().
call_usermodehelper_exec(UMH_KILLABLE) does
wait_for_completion_killable. If it fails, it uses
xchg(&sub_info->complete, NULL) to serialize with umh_complete() which
does the same xhcg() to access sub_info->complete.
If call_usermodehelper_exec wins, it can safely return. umh_complete()
should get NULL and call call_usermodehelper_freeinfo().
Otherwise we know that umh_complete() was already called, in this case
call_usermodehelper_exec() falls back to wait_for_completion() which
should succeed "very soon".
Note: UMH_NO_WAIT == -1 but it obviously should not be used with
UMH_KILLABLE. We delay the neccessary cleanup to simplify the back
porting.
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Tejun Heo <tj@kernel.org>
This reverts commit fb1e75389bd06fd5987e9cda1b4e0305c782f854.
"Benjamin S." <sbenni@gmx.de> reports that the patch in question
causes a big drop in sequential throughput for him, dropping from
200MB/sec down to only 70MB/sec.
Needs to be investigated more fully, for now lets just revert the
offending commit.
include/linux/blkdev.h
(cherry picked from commit 79da0644a8e0838522828f106e4049639eea6baf)
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream.
With the new interrupt sampling system, we are no longer using the
timer_rand_state structure in the irq descriptor, so we can stop
initializing it now.
[ Merged in fixes from Sedat to find some last missing references to
rand_initialize_irq() ]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
[PG: in .34 the irqdesc.h content is in irq.h instead.]
commit c2557a303ab6712bb6e09447df828c557c710ac9 upstream.
Create a new function, get_random_bytes_arch() which will use the
architecture-specific hardware random number generator if it is
present. Change get_random_bytes() to not use the HW RNG, even if it
is avaiable.
The reason for this is that the hw random number generator is fast (if
it is present), but it requires that we trust the hardware
manufacturer to have not put in a back door. (For example, an
increasing counter encrypted by an AES key known to the NSA.)
It's unlikely that Intel (for example) was paid off by the US
Government to do this, but it's impossible for them to prove otherwise
--- especially since Bull Mountain is documented to use AES as a
whitener. Hence, the output of an evil, trojan-horse version of
RDRAND is statistically indistinguishable from an RDRAND implemented
to the specifications claimed by Intel. Short of using a tunnelling
electronic microscope to reverse engineer an Ivy Bridge chip and
disassembling and analyzing the CPU microcode, there's no way for us
to tell for sure.
Since users of get_random_bytes() in the Linux kernel need to be able
to support hardware systems where the HW RNG is not present, most
time-sensitive users of this interface have already created their own
cryptographic RNG interface which uses get_random_bytes() as a seed.
So it's much better to use the HW RNG to improve the existing random
number generator, by mixing in any entropy returned by the HW RNG into
/dev/random's entropy pool, but to always _use_ /dev/random's entropy
pool.
This way we get almost of the benefits of the HW RNG without any
potential liabilities. The only benefits we forgo is the
speed/performance enhancements --- and generic kernel code can't
depend on depend on get_random_bytes() having the speed of a HW RNG
anyway.
For those places that really want access to the arch-specific HW RNG,
if it is available, we provide get_random_bytes_arch().
commit a2080a67abe9e314f9e9c2cc3a4a176e8a8f8793 upstream.
Add a new interface, add_device_randomness() for adding data to the
random pool that is likely to differ between two devices (or possibly
even per boot). This would be things like MAC addresses or serial
numbers, or the read-out of the RTC. This does *not* add any actual
entropy to the pool, but it initializes the pool to different values
for devices that might otherwise be identical and have very little
entropy available to them (particularly common in the embedded world).
[ Modified by tytso to mix in a timestamp, since there may be some
variability caused by the time needed to detect/configure the hardware
in question. ]
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream.
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>.
[PG: minor adjustment required since .34 doesn't have f9e4989eb8
which renames "status" to "random" in kernel/irq/handle.c ]
commit 63d77173266c1791f1553e9e8ccea65dc87c4485 upstream.
Add support for architecture-specific hooks into the kernel-directed
random number generator interfaces. This patchset does not use the
architecture random number generator interfaces for the
userspace-directed interfaces (/dev/random and /dev/urandom), thus
eliminating the need to distinguish between them based on a pool
pointer.
Changes in version 3:
- Moved the hooks from extract_entropy() to get_random_bytes().
- Changes the hooks to inlines.
Cc: Matt Mackall <mpm@selenic.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
[PG: .34 already had "unsigned int ret" in get_random_int, so the
diffstat here is slightly smaller than that of 63d7717. ]
commit 28d82dc1c4edbc352129f97f4ca22624d1fe61de upstream.
The current epoll code can be tickled to run basically indefinitely in
both loop detection path check (on ep_insert()), and in the wakeup paths.
The programs that tickle this behavior set up deeply linked networks of
epoll file descriptors that cause the epoll algorithms to traverse them
indefinitely. A couple of these sample programs have been previously
posted in this thread: https://lkml.org/lkml/2011/2/25/297.
To fix the loop detection path check algorithms, I simply keep track of
the epoll nodes that have been already visited. Thus, the loop detection
becomes proportional to the number of epoll file descriptor and links.
This dramatically decreases the run-time of the loop check algorithm. In
one diabolical case I tried it reduced the run-time from 15 mintues (all
in kernel time) to .3 seconds.
Fixing the wakeup paths could be done at wakeup time in a similar manner
by keeping track of nodes that have already been visited, but the
complexity is harder, since there can be multiple wakeups on different
cpus...Thus, I've opted to limit the number of possible wakeup paths when
the paths are created.
This is accomplished, by noting that the end file descriptor points that
are found during the loop detection pass (from the newly added link), are
actually the sources for wakeup events. I keep a list of these file
descriptors and limit the number and length of these paths that emanate
from these 'source file descriptors'. In the current implemetation I
allow 1000 paths of length 1, 500 of length 2, 100 of length 3, 50 of
length 4 and 10 of length 5. Note that it is sufficient to check the
'source file descriptors' reachable from the newly added link, since no
other 'source file descriptors' will have newly added links. This allows
us to check only the wakeup paths that may have gotten too long, and not
re-check all possible wakeup paths on the system.
In terms of the path limit selection, I think its first worth noting that
the most common case for epoll, is probably the model where you have 1
epoll file descriptor that is monitoring n number of 'source file
descriptors'. In this case, each 'source file descriptor' has a 1 path of
length 1. Thus, I believe that the limits I'm proposing are quite
reasonable and in fact may be too generous. Thus, I'm hoping that the
proposed limits will not prevent any workloads that currently work to
fail.
In terms of locking, I have extended the use of the 'epmutex' to all
epoll_ctl add and remove operations. Currently its only used in a subset
of the add paths. I need to hold the epmutex, so that we can correctly
traverse a coherent graph, to check the number of paths. I believe that
this additional locking is probably ok, since its in the setup/teardown
paths, and doesn't affect the running paths, but it certainly is going to
add some extra overhead. Also, worth noting is that the epmuex was
recently added to the ep_ctl add operations in the initial path loop
detection code using the argument that it was not on a critical path.
Another thing to note here, is the length of epoll chains that is allowed.
Currently, eventpoll.c defines:
/* Maximum number of nesting allowed inside epoll sets */
This basically means that I am limited to a graph depth of 5 (EP_MAX_NESTS
+ 1). However, this limit is currently only enforced during the loop
check detection code, and only when the epoll file descriptors are added
in a certain order. Thus, this limit is currently easily bypassed. The
newly added check for wakeup paths, stricly limits the wakeup paths to a
length of 5, regardless of the order in which ep's are linked together.
Thus, a side-effect of the new code is a more consistent enforcement of
the graph depth.
Thus far, I've tested this, using the sample programs previously
mentioned, which now either return quickly or return -EINVAL. I've also
testing using the piptest.c epoll tester, which showed no difference in
performance. I've also created a number of different epoll networks and
tested that they behave as expectded.
I believe this solves the original diabolical test cases, while still
preserving the sane epoll nesting.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Cc: Nelson Elhage <nelhage@ksplice.com>
Cc: Davide Libenzi <davidel@xmailserver.org>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit 9993bc635d01a6ee7f6b833b4ee65ce7c06350b1 upstream.
When a machine boots up, the TSC generally gets reset. However,
when kexec is used to boot into a kernel, the TSC value would be
carried over from the previous kernel. The computation of
cycns_offset in set_cyc2ns_scale is prone to an overflow, if the
machine has been up more than 208 days prior to the kexec. The
overflow happens when we multiply *scale, even though there is
enough room to store the final answer.
We fix this issue by decomposing tsc_now into the quotient and
remainder of division by CYC2NS_SCALE_FACTOR and then performing
the multiplication separately on the two components.
Refactor code to share the calculation with the previous
fix in __cycles_2_ns().
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: John Stultz <john.stultz@linaro.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Paul Turner <pjt@google.com>
Cc: john stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/20120310004027.19291.88460.stgit@dungbeetle.mtv.corp.google.com
[ Upstream commit 03606895cd98c0a628b17324fd7b5ff15db7e3cd ]
Niccolo Belli reported ipsec crashes in case we handle a frame without
mac header (atm in his case)
Before copying mac header, better make sure it is present.
Bugzilla reference: https://bugzilla.kernel.org/show_bug.cgi?id=42809
Reported-by: Niccolò Belli <darkbasic@linuxsystems.it>
Tested-by: Niccolò Belli <darkbasic@linuxsystems.it>
commit 90481622d75715bfcb68501280a917dbfe516029 upstream
hugetlbfs_{get,put}_quota() are badly named. They don't interact with the
general quota handling code, and they don't much resemble its behaviour.
Rather than being about maintaining limits on on-disk block usage by
particular users, they are instead about maintaining limits on in-memory
page usage (including anonymous MAP_PRIVATE copied-on-write pages)
associated with a particular hugetlbfs filesystem instance.
Worse, they work by having callbacks to the hugetlbfs filesystem code from
the low-level page handling code, in particular from free_huge_page().
This is a layering violation of itself, but more importantly, if the
kernel does a get_user_pages() on hugepages (which can happen from KVM
amongst others), then the free_huge_page() can be delayed until after the
associated inode has already been freed. If an unmount occurs at the
wrong time, even the hugetlbfs superblock where the "quota" limits are
stored may have been freed.
Andrew Barry proposed a patch to fix this by having hugepages, instead of
storing a pointer to their address_space and reaching the superblock from
there, had the hugepages store pointers directly to the superblock,
bumping the reference count as appropriate to avoid it being freed.
Andrew Morton rejected that version, however, on the grounds that it made
the existing layering violation worse.
This is a reworked version of Andrew's patch, which removes the extra, and
some of the existing, layering violation. It works by introducing the
concept of a hugepage "subpool" at the lower hugepage mm layer - that is a
finite logical pool of hugepages to allocate from. hugetlbfs now creates
a subpool for each filesystem instance with a page limit set, and a
pointer to the subpool gets added to each allocated hugepage, instead of
the address_space pointer used now. The subpool has its own lifetime and
is only freed once all pages in it _and_ all other references to it (i.e.
superblocks) are gone.
subpools are optional - a NULL subpool pointer is taken by the code to
mean that no subpool limits are in effect.
Previous discussion of this bug found in: "Fix refcounting in hugetlbfs
quota handling.". See: https://lkml.org/lkml/2011/8/11/28 or
http://marc.info/?l=linux-mm&m=126928970510627&w=1
v2: Fixed a bug spotted by Hillf Danton, and removed the extra parameter to
alloc_huge_page() - since it already takes the vma, it is not necessary.
Signed-off-by: Andrew Barry <abarry@cray.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Hillf Danton <dhillf@gmail.com>
commit 3e515705a1f46beb1c942bb8043c16f8ac7b1e9e upstream
If some vcpus are created before KVM_CREATE_IRQCHIP, then
irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading
to potential NULL pointer dereferences.
Fix by:
- ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called
- ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP
This is somewhat long winded because vcpu->arch.apic is created without
kvm->lock held.
Based on earlier patch by Michael Ellerman.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit b69f2292063d2caf37ca9aec7d63ded203701bf3 upstream
With CLONE_IO, parent's io_context->nr_tasks is incremented, but never
decremented whenever copy_process() fails afterwards, which prevents
exit_io_context() from calling IO schedulers exit functions.
Give a task_struct to exit_io_context(), and call exit_io_context() instead of
put_io_context() in copy_process() cleanup path.
Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com>
commit e0bccd315db0c2f919e7fcf9cb60db21d9986f52 upstream
Define some constant offsets for CALL_REQUEST based on the description
at <http://www.techfest.com/networking/wan/x25plp.htm> and the
definition of ROSE as using 10-digit (5-byte) addresses. Use them
consistently. Validate all implicit and explicit facilities lengths.
Validate the address length byte rather than either trusting or
assuming its value.
This is a -stable backport of cee58483cf56e0ba355fdd97ff5e8925329aa936
Andreas Bombe reported that the added ktime_t overflow checking added to
timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of
timekeeping inputs") was causing problems with X.org because it caused
timeouts larger then KTIME_T to be invalid.
Previously, these large timeouts would be clamped to KTIME_MAX and would
never expire, which is valid.
This patch splits the ktime_t overflow checking into a new
timespec_valid_strict function, and converts the timekeeping codes
internal checking to use this more strict function.
Reported-and-tested-by: Andreas Bombe <aeb@debian.org>
Cc: Zhouping Liu <zliu@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Linux Kernel <linux-kernel@vger.kernel.org>
This is a -stable backport of 4e8b14526ca7fb046a81c94002c1c43b6fdf0e9b
Unexpected behavior could occur if the time is set to a value large
enough to overflow a 64bit ktime_t (which is something larger then the
year 2262).
Also unexpected behavior could occur if large negative offsets are
injected via adjtimex.
So this patch improves the sanity check timekeeping inputs by
improving the timespec_valid() check, and then makes better use of
timespec_valid() to make sure we don't set the time to an invalid
negative value or one that overflows ktime_t.
Note: This does not protect from setting the time close to overflowing
ktime_t and then letting natural accumulation cause the overflow.
Reported-by: CAI Qian <caiqian@redhat.com>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Link: http://lkml.kernel.org/r/1344454580-17031-1-git-send-email-john.stultz@linaro.org
This is a backport of f6c06abfb3972ad4914cef57d8348fcb2932bc3b
To finally fix the infamous leap second issue and other race windows
caused by functions which change the offsets between the various time
bases (CLOCK_MONOTONIC, CLOCK_REALTIME and CLOCK_BOOTTIME) we need a
function which atomically gets the current monotonic time and updates
the offsets of CLOCK_REALTIME and CLOCK_BOOTTIME with minimalistic
overhead. The previous patch which provides ktime_t offsets allows us
to make this function almost as cheap as ktime_get() which is going to
be replaced in hrtimer_interrupt().
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/1341960205-56738-7-git-send-email-johnstul@us.ibm.com
This is a backport of f55a6faa384304c89cfef162768e88374d3312cb
clock_was_set() cannot be called from hard interrupt context because
it calls on_each_cpu().
For fixing the widely reported leap seconds issue it is necessary to
call it from hard interrupt context, i.e. the timer tick code, which
does the timekeeping updates.
Provide a new function which denotes it in the hrtimer cpu base
structure of the cpu on which it is called and raise the hrtimer
softirq. We then execute the clock_was_set() notificiation from
softirq context in run_hrtimer_softirq(). The hrtimer softirq is
rarely used, so polling the flag there is not a performance issue.
[ tglx: Made it depend on CONFIG_HIGH_RES_TIMERS. We really should get
rid of all this ifdeffery ASAP ]
Reported-by: Jan Engelhardt <jengelh@inai.de>
Link: http://lkml.kernel.org/r/1341960205-56738-2-git-send-email-johnstul@us.ibm.com
This is a backport of 6b43ae8a619d17c4935c3320d2ef9e92bdeed05d
This should have been backported when it was commited, but I
mistook the problem as requiring the ntp_lock changes
that landed in 3.4 in order for it to occur.
Unfortunately the same issue can happen (with only one cpu)
as follows:
do_adjtimex()
write_seqlock_irq(&xtime_lock);
process_adjtimex_modes()
process_adj_status()
ntp_start_leap_timer()
hrtimer_start()
hrtimer_reprogram()
tick_program_event()
clockevents_program_event()
ktime_get()
seq = req_seqbegin(xtime_lock); [DEADLOCK]
This deadlock will no always occur, as it requires the
leap_timer to force a hrtimer_reprogram which only happens
if its set and there's no sooner timer to expire.
NOTE: This patch, being faithful to the original commit,
introduces a bug (we don't update wall_to_monotonic),
which will be resovled by backporting a following fix.
Original commit message below:
Since commit 7dffa3c673fbcf835cd7be80bb4aec8ad3f51168 the ntp
subsystem has used an hrtimer for triggering the leapsecond
adjustment. However, this can cause a potential livelock.
Thomas diagnosed this as the following pattern:
CPU 0 CPU 1
do_adjtimex()
spin_lock_irq(&ntp_lock);
process_adjtimex_modes(); timer_interrupt()
process_adj_status(); do_timer()
ntp_start_leap_timer(); write_lock(&xtime_lock);
hrtimer_start(); update_wall_time();
hrtimer_reprogram(); ntp_tick_length()
tick_program_event() spin_lock(&ntp_lock);
ktime_get()
This patch tries to avoid the problem by reverting back to not using
an hrtimer to inject leapseconds, and instead we handle the leapsecond
processing in the second_overflow() function.
The downside to this change is that on systems that support highres
timers, the leap second processing will occur on a HZ tick boundary,
(ie: ~1-10ms, depending on HZ) after the leap second instead of
possibly sooner (~34us in my tests w/ x86_64 lapic).
This patch applies on top of tip/timers/core.
CC: Sasha Levin <levinsasha928@gmail.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Diagnoised-by: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Sasha Levin <levinsasha928@gmail.com>
commit 5189fa19a4b2b4c3bec37c3a019d446148827717 upstream.
There is only one error code to return for a bad user-space buffer
pointer passed to a system call in the same address space as the
system call is executed, and that is EFAULT. Furthermore, the
low-level access routines, which catch most of the faults, return
EFAULT already.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Roland McGrath <roland@hack.frob.com>
commit c8e252586f8d5de906385d8cf6385fee289a825e upstream.
The regset common infrastructure assumed that regsets would always
have .get and .set methods, but not necessarily .active methods.
Unfortunately people have since written regsets without .set methods.
Rather than putting in stub functions everywhere, handle regsets with
null .get or .set methods explicitly.
