path: root/include
2015-10-31Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "This should be our final batch of fixes for 4.3: - A patch from Sudeep Holla that fixes annotation of wakeup sources properly, old unused format seems to have spread through copying. - Two patches from Tony for OMAP. One dealing with MUSB setup problems due to runtime PM being enabled too early on the parent device. The other fixes IRQ numbering for OMAP1" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: usb: musb: omap2430: Fix regression caused by driver core change ARM: OMAP1: fix incorrect INT_DMA_LCD ARM: dts: fix gpio-keys wakeup-source property
2015-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix two regressions in ipv6 route lookups, particularly wrt output interface specifications in the lookup key. From David Ahern. 2) Fix checks in ipv6 IPSEC tunnel pre-encap fragmentation, from Herbert Xu. 3) Fix mis-advertisement of 1000BASE-T on bcm63xx_enet, from Simon Arlott. 4) Some smsc phys misbehave with energy detect mode enabled, so add a DT property and disable it on such switches. From Heiko Schocher. 5) Fix TSO corruption on TX in mv643xx_eth, from Philipp Kirchhofer. 6) Fix regression added by removal of openvswitch vport stats, from James Morse. 7) Vendor Kconfig options should be bool, not tristate, from Andreas Schwab. 8) Use non-_BH() net stats bump in tcp_xmit_probe_skb(), otherwise we barf during TCP REPAIR operations. 9) Fix various bugs in openvswitch conntrack support, from Joe Stringer. 10) Fix NETLINK_LIST_MEMBERSHIPS locking, from David Herrmann. 11) Don't have VSOCK do sock_put() in interrupt context, from Jorgen Hansen. 12) Fix skb_realloc_headroom() failures properly in ISDN, from Karsten Keil. 13) Add some device IDs to qmi_wwan, from Bjorn Mork. 14) Fix ovs egress tunnel information when using lwtunnel devices, from Pravin B Shelar. 15) Add missing NETIF_F_FRAGLIST to macvtab feature list, from Jason Wang. 16) Fix incorrect handling of throw routes when the result of the throw cannot find a match, from Xin Long. 17) Protect ipv6 MTU calculations from wrap-around, from Hannes Frederic Sowa. 18) Fix failed autonegotiation on KSZ9031 micrel PHYs, from Nathan Sullivan. 19) Add missing memory barries in descriptor accesses or xgbe driver, from Thomas Lendacky. 20) Fix release conditon test in pppoe_release(), from Guillaume Nault. 21) Fix gianfar bugs wrt filter configuration, from Claudiu Manoil. 22) Fix violations of RX buffer alignment in sh_eth driver, from Sergei Shtylyov. 23) Fixing missing of_node_put() calls in various places around the networking, from Julia Lawall. 24) Fix incorrect leaf now walking in ipv4 routing tree, from Alexander Duyck. 25) RDS doesn't check pskb_pull()/pskb_trim() return values, from Sowmini Varadhan. 26) Fix VLAN configuration in mlx4 driver, from Jack Morgenstein. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (79 commits) ipv6: protect mtu calculation of wrap-around and infinite loop by rounding issues Revert "Merge branch 'ipv6-overflow-arith'" net/mlx4: Copy/set only sizeof struct mlx4_eqe bytes net/mlx4_en: Explicitly set no vlan tags in WQE ctrl segment when no vlan is present vhost: fix performance on LE hosts bpf: sample: define aarch64 specific registers amd-xgbe: Fix race between access of desc and desc index RDS-TCP: Recover correctly from pskb_pull()/pksb_trim() failure in rds_tcp_data_recv forcedeth: fix unilateral interrupt disabling in netpoll path openvswitch: Fix skb leak using IPv6 defrag ipv6: Export nf_ct_frag6_consume_orig() openvswitch: Fix double-free on ip_defrag() errors fib_trie: leaf_walk_rcu should not compute key if key is less than pn->key net: mv643xx_eth: add missing of_node_put ath6kl: add missing of_node_put net: phy: mdio: add missing of_node_put netdev/phy: add missing of_node_put net: netcp: add missing of_node_put net: thunderx: add missing of_node_put ipv6: gre: support SIT encapsulation ...
2015-10-29Revert "Merge branch 'ipv6-overflow-arith'"Hannes Frederic Sowa
Linus dislikes these changes. To not hold up the net-merge let's revert it for now and fix the bug like Linus suggested. This reverts commit ec3661b42257d9a06cf0d318175623ac7a660113, reversing changes made to c80dbe04612986fd6104b4a1be21681b113b5ac9. Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-28ARM: OMAP1: fix incorrect INT_DMA_LCDAaro Koskinen
Commit 685e2d08c54b ("ARM: OMAP1: Change interrupt numbering for sparse IRQ") turned on SPARSE_IRQ on OMAP1, but forgot to change the number of INT_DMA_LCD. This broke the boot at least on Nokia 770, where the device hangs during framebuffer initialization. Fix by defining INT_DMA_LCD like the other interrupts. Cc: stable@vger.kernel.org # v4.2+ Fixes: 685e2d08c54b ("ARM: OMAP1: Change interrupt numbering for sparse IRQ") Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-10-27blkcg: fix incorrect read/write sync/async stat accountingTejun Heo
While unifying how blkcg stats are collected, 77ea733884eb ("blkcg: move io_service_bytes and io_serviced stats into blkcg_gq") incorrectly used bio->flags instead of bio->rw to tell the IO type. This made IOs to be accounted as the wrong type. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 77ea733884eb ("blkcg: move io_service_bytes and io_serviced stats into blkcg_gq") Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-24Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A final set of fixes for 4.3. It is (again) bigger than I would have liked, but it's all been through the testing mill and has been carefully reviewed by multiple parties. Each fix is either a regression fix for this cycle, or is marked stable. You can scold me at KS. The pull request contains: - Three simple fixes for NVMe, fixing regressions since 4.3. From Arnd, Christoph, and Keith. - A single xen-blkfront fix from Cathy, fixing a NULL dereference if an error is returned through the staste change callback. - Fixup for some bad/sloppy code in nbd that got introduced earlier in this cycle. From Markus Pargmann. - A blk-mq tagset use-after-free fix from Junichi. - A backing device lifetime fix from Tejun, fixing a crash. - And finally, a set of regression/stable fixes for cgroup writeback from Tejun" * 'for-linus' of git://git.kernel.dk/linux-block: writeback: remove broken rbtree_postorder_for_each_entry_safe() usage in cgwb_bdi_destroy() NVMe: Fix memory leak on retried commands block: don't release bdi while request_queue has live references nvme: use an integer value to Linux errno values blk-mq: fix use-after-free in blk_mq_free_tag_set() nvme: fix 32-bit build warning writeback: fix incorrect calculation of available memory for memcg domains writeback: memcg dirty_throttle_control should be initialized with wb->memcg_completions writeback: bdi_writeback iteration must not skip dying ones writeback: fix bdi_writeback iteration in wakeup_dirtytime_writeback() writeback: laptop_mode_timer_fn() needs rcu_read_lock() around bdi_writeback iteration nbd: Add locking for tasks xen-blkfront: check for null drvdata in blkback_changed (XenbusStateClosing)
2015-10-23Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes: two KASAN fixes, two EFI boot fixes, two boot-delay optimization fixes, and a fix for a IRQ handling hang observed on virtual platforms" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm, kasan: Silence KASAN warnings in get_wchan() compiler, atomics, kasan: Provide READ_ONCE_NOCHECK() x86, kasan: Fix build failure on KASAN=y && KMEMCHECK=y kernels x86/smpboot: Fix CPU #1 boot timeout x86/smpboot: Fix cpu_init_udelay=10000 corner case boot parameter misbehavior x86/ioapic: Disable interrupts when re-routing legacy IRQs x86/setup: Extend low identity map to cover whole kernel range x86/efi: Fix multiple GOP device support
2015-10-23Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fixes from Andrew Morton: "9 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: ocfs2/dlm: unlock lockres spinlock before dlm_lockres_put fault-inject: fix inverted interval/probability values in printk lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y mm: make sendfile(2) killable thp: use is_zero_pfn() only after pte_present() check mailmap: update Javier Martinez Canillas' email MAINTAINERS: add Sergey as zsmalloc reviewer mm: cma: fix incorrect type conversion for size during dma allocation kmod: don't run async usermode helper as a child of kworker thread
2015-10-23overflow-arith: begin to add support for overflow builtin functionsHannes Frederic Sowa
The idea of the overflow-arith.h header is to collect overflow checking functions in one central place. If gcc compiler supports the __builtin_overflow_* builtins we use them because they might give better performance, otherwise the code falls back to normal overflow checking functions. The builtin_overflow functions are supported by gcc-5 and clang. The matter of supporting clang is to just provide a corresponding CC_HAVE_BUILTIN_OVERFLOW, because the specific overflow checking builtins don't differ between gcc and clang. I just provide overflow_usub function here as I intend this to get merged into net, more functions will definitely follow as they are needed. Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-23Merge tag 'sound-4.3-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "There is nothing to worry you much, only a few small & stable patches are found for usual stuff, HD-audio (a Lenovo laptop quirk, a fix for minor error handling) and ASoC (trivial fixes for RT298 and WM codecs). The only remaining major change is the fix for ASoC SX_TLV control that was overseen during refactoring, but the fix itself is trivial and safe" * tag 'sound-4.3-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: wm8962: mark cache_dirty flag after software reset in pm_resume ASoC: rt298: fix wrong setting of gpio2_en ASoC: wm8904: Correct number of EQ registers ALSA: hda - Fix deadlock at error in building PCM ASoC: Add info callback for SX_TLV controls ASoC: rt298: correct index default value ALSA: hda - Fix inverted internal mic on Lenovo G50-80 ALSA: hdac: Explicitly add io.h
2015-10-23mm: cma: fix incorrect type conversion for size during dma allocationRohit Vaswani
This was found during userspace fuzzing test when a large size dma cma allocation is made by driver(like ion) through userspace. show_stack+0x10/0x1c dump_stack+0x74/0xc8 kasan_report_error+0x2b0/0x408 kasan_report+0x34/0x40 __asan_storeN+0x15c/0x168 memset+0x20/0x44 __dma_alloc_coherent+0x114/0x18c Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-22openvswitch: Fix egress tunnel info.Pravin B Shelar
While transitioning to netdev based vport we broke OVS feature which allows user to retrieve tunnel packet egress information for lwtunnel devices. Following patch fixes it by introducing ndo operation to get the tunnel egress info. Same ndo operation can be used for lwtunnel devices and compat ovs-tnl-vport devices. So after adding such device operation we can remove similar operation from ovs-vport. Fixes: 614732eaa12d ("openvswitch: Use regular VXLAN net_device device"). Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-23Merge remote-tracking branches 'asoc/fix/rt298', 'asoc/fix/sx', ↵Mark Brown
'asoc/fix/wm8904' and 'asoc/fix/wm8962' into asoc-linus
2015-10-21openvswitch: Clarify conntrack COMMIT behaviourJoe Stringer
The presence of this attribute does not modify the ct_state for the current packet, only future packets. Make this more clear in the header definition. Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Thomas Graf <tgraf@suug.ch> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-20ASoC: wm8904: Correct number of EQ registersCharles Keepax
There are 24 EQ registers not 25, I suspect this bug came about because the registers start at EQ1 not zero. The bug is relatively harmless as the extra register written is an unused one. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2015-10-20compiler, atomics, kasan: Provide READ_ONCE_NOCHECK()Andrey Ryabinin
Some code may perform racy by design memory reads. This could be harmless, yet such code may produce KASAN warnings. To hide such accesses from KASAN this patch introduces READ_ONCE_NOCHECK() macro. KASAN will not check the memory accessed by READ_ONCE_NOCHECK(). The KernelThreadSanitizer (KTSAN) is going to ignore it as well. This patch creates __read_once_size_nocheck() a clone of __read_once_size(). The only difference between them is 'no_sanitized_address' attribute appended to '*_nocheck' function. This attribute tells the compiler that instrumentation of memory accesses should not be applied to that function. We declare it as static '__maybe_unsed' because GCC is not capable to inline such function: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=67368 With KASAN=n READ_ONCE_NOCHECK() is just a clone of READ_ONCE(). Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de> Cc: kasan-dev <kasan-dev@googlegroups.com> Link: http://lkml.kernel.org/r/1445243838-17763-2-git-send-email-aryabinin@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Account for extra headroom in ath9k driver, from Felix Fietkau. 2) Fix OOPS in pppoe driver due to incorrect socket state transition, from Guillaume Nault. 3) Kill memory leak in amd-xgbe debugfx, from Geliang Tang. 4) Power management fixes for iwlwifi, from Johannes Berg. 5) Fix races in reqsk_queue_unlink(), from Eric Dumazet. 6) Fix dst_entry usage in ARP replies, from Jiri Benc. 7) Cure OOPSes with SO_GET_FILTER, from Daniel Borkmann. 8) Missing allocation failure check in amd-xgbe, from Tom Lendacky. 9) Various resource allocation/freeing cures in DSA< from Neil Armstrong. 10) A series of bug fixes in the openvswitch conntrack support, from Joe Stringer. 11) Fix two cases (BPF and act_mirred) where we have to clean the sender cpu stored in the SKB before transmitting. From WANG Cong and Alexei Starovoitov. 12) Disable VLAN filtering in promiscuous mode in mlx5 driver, from Achiad Shochat. 13) Older bnx2x chips cannot do 4-tuple UDP hashing, so prevent this configuration via ethtool. From Yuval Mintz. 14) Don't call rt6_uncached_list_flush_dev() from rt6_ifdown() when 'dev' is NULL, from Eric Biederman. 15) Prevent stalled link synchronization in tipc, from Jon Paul Maloy. 16) kcalloc() gstrings ethtool buffer before having driver fill it in, in order to prevent kernel memory leaking. From Joe Perches. 17) Fix mixxing rt6_info initialization for blackhole routes, from Martin KaFai Lau. 18) Kill VLAN regression in via-rhine, from Andrej Ota. 19) Missing pfmemalloc check in sk_add_backlog(), from Eric Dumazet. 20) Fix spurious MSG_TRUNC signalling in netlink dumps, from Ronen Arad. 21) Scrube SKBs when pushing them between namespaces in openvswitch, from Joe Stringer. 22) bcmgenet enables link interrupts too early, fix from Florian Fainelli. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (92 commits) net: bcmgenet: Fix early link interrupt enabling tunnels: Don't require remote endpoint or ID during creation. openvswitch: Scrub skb between namespaces xen-netback: correctly check failed allocation net: asix: add support for the Billionton GUSB2AM-1G-B USB adapter netlink: Trim skb to alloc size to avoid MSG_TRUNC net: add pfmemalloc check in sk_add_backlog() via-rhine: fix VLAN receive handling regression. ipv6: Initialize rt6_info properly in ip6_blackhole_route() ipv6: Move common init code for rt6_info to a new function rt6_info_init() Bluetooth: Fix initializing conn_params in scan phase Bluetooth: Fix conn_params list update in hci_connect_le_scan_cleanup Bluetooth: Fix remove_device behavior for explicit connects Bluetooth: Fix LE reconnection logic Bluetooth: Fix reference counting for LE-scan based connections Bluetooth: Fix double scan updates mlxsw: core: Fix race condition in __mlxsw_emad_transmit tipc: move fragment importance field to new header position ethtool: Use kcalloc instead of kmalloc for ethtool_get_strings tipc: eliminate risk of stalled link synchronization ...
2015-10-17net: add pfmemalloc check in sk_add_backlog()Eric Dumazet
Greg reported crashes hitting the following check in __sk_backlog_rcv() BUG_ON(!sock_flag(sk, SOCK_MEMALLOC)); The pfmemalloc bit is currently checked in sk_filter(). This works correctly for TCP, because sk_filter() is ran in tcp_v[46]_rcv() before hitting the prequeue or backlog checks. For UDP or other protocols, this does not work, because the sk_filter() is ran from sock_queue_rcv_skb(), which might be called _after_ backlog queuing if socket is owned by user by the time packet is processed by softirq handler. Fixes: b4b9e35585089 ("netvm: set PF_MEMALLOC as appropriate during SKB processing") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Greg Thelen <gthelen@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-16Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Nothing too crazy or exciting: - two MAINTAINERS entries that I didn't see the point in delaying. - one drm mst fix to stop sending uninitialised data to monitors - two amdgpu fixes - one radeon mst tiling fix - one vmwgfx regression fix - one virtio warning fix. I have found one locking problem that needs a bit of reorg to fix, but I'm not sure it's worth putting in -fixes as I don't think we've seen it hit in the real world ever, I just found it using the virtio-gpu driver when working on it. I'll possibly send it next week once I've time to discuss with Daniel" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/virtio: use %llu format string form atomic64_t MAINTAINERS: Add myself as maintainer for the gma500 driver MAINTAINERS: add a maintainer for the atmel-hlcdc DRM driver drm/amdgpu: Keep the pflip interrupts always enabled v7 drm/amdgpu: adjust default dispclk (v2) drm/dp/mst: make mst i2c transfer code more robust. drm/radeon: attach tile property to mst connector drm/vmwgfx: Fix kernel NULL pointer dereference on older hardware
2015-10-16ASoC: Add info callback for SX_TLV controlsCharles Keepax
SX_TLV controls are intended for situations where the register behind the control has some non-zero value indicating the minimum gain and then gains increasing from there and eventually overflowing through zero. Currently every CODEC implementing these controls specifies the minimum as the non-zero value for the minimum and the maximum as the number of gain settings available. This means when the info callback subtracts the minimum value from the maximum value to calculate the number of gain levels available it is actually under reporting the available levels. This patch fixes this issue by adding a new snd_soc_info_volsw_sx callback that does not subtract the minimum value. Fixes: 1d99f2436d0d ("ASoC: core: Rework SOC_DOUBLE_R_SX_TLV add SOC_SINGLE_SX_TLV") Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Tested-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2015-10-15block: don't release bdi while request_queue has live referencesTejun Heo
bdi's are initialized in two steps, bdi_init() and bdi_register(), but destroyed in a single step by bdi_destroy() which, for a bdi embedded in a request_queue, is called during blk_cleanup_queue() which makes the queue invisible and starts the draining of remaining usages. A request_queue's user can access the congestion state of the embedded bdi as long as it holds a reference to the queue. As such, it may access the congested state of a queue which finished blk_cleanup_queue() but hasn't reached blk_release_queue() yet. Because the congested state was embedded in backing_dev_info which in turn is embedded in request_queue, accessing the congested state after bdi_destroy() was called was fine. The bdi was destroyed but the memory region for the congested state remained accessible till the queue got released. a13f35e87140 ("writeback: don't embed root bdi_writeback_congested in bdi_writeback") changed the situation. Now, the root congested state which is expected to be pinned while request_queue remains accessible is separately reference counted and the base ref is put during bdi_destroy(). This means that the root congested state may go away prematurely while the queue is between bdi_dstroy() and blk_cleanup_queue(), which was detected by Andrey's KASAN tests. The root cause of this problem is that bdi doesn't distinguish the two steps of destruction, unregistration and release, and now the root congested state actually requires a separate release step. To fix the issue, this patch separates out bdi_unregister() and bdi_exit() from bdi_destroy(). bdi_unregister() is called from blk_cleanup_queue() and bdi_exit() from blk_release_queue(). bdi_destroy() is now just a simple wrapper calling the two steps back-to-back. While at it, the prototype of bdi_destroy() is moved right below bdi_setup_and_register() so that the counterpart operations are located together. Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: a13f35e87140 ("writeback: don't embed root bdi_writeback_congested in bdi_writeback") Cc: stable@vger.kernel.org # v4.2+ Reported-and-tested-by: Andrey Konovalov <andreyknvl@google.com> Link: http://lkml.kernel.org/g/CAAeHK+zUJ74Zn17=rOyxacHU18SgCfC6bsYW=6kCY5GXJBwGfQ@mail.gmail.com Reviewed-by: Jan Kara <jack@suse.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-15drm/dp/mst: make mst i2c transfer code more robust.Dave Airlie
This zeroes the msg so no random stack data ends up getting sent, it also limits the function to not accepting > 4 i2c msgs. Cc: stable@vger.kernel.org Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-10-12rtnetlink: fix gcc -Wconversion warningArad, Ronen
RTA_ALIGNTO is currently define as 4. It has to be 4U to prevent warning for RTA_ALIGN and RTA_DATA expansions when -Wconversion gcc option is enabled. This follows NLMSG_ALIGNTO definition in <include/uapi/linux/netlink.h>. Signed-off-by: Ronen Arad <ronen.arad@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-12arm64: Fix MINSIGSTKSZ and SIGSTKSZManjeet Pawar
MINSIGSTKSZ and SIGSTKSZ for ARM64 are not correctly set in latest kernel. This patch fixes this issue. This issue is reported in LTP (testcase: sigaltstack02.c). Testcase failed when sigaltstack() called with stack size "MINSIGSTKSZ - 1" Since in Glibc-2.22, MINSIGSTKSZ is set to 5120 but in kernel it is set to 2048 so testcase gets failed. Testcase Output: sigaltstack02 1 TPASS : stgaltstack() fails, Invalid Flag value,errno:22 sigaltstack02 2 TFAIL : sigaltstack() returned 0, expected -1,errno:12 Reported Issue in Glibc Bugzilla: Bugfix in Glibc-2.22: [Bug 16850] https://sourceware.org/bugzilla/show_bug.cgi?id=16850 Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Akhilesh Kumar <akhilesh.k@samsung.com> Signed-off-by: Manjeet Pawar <manjeet.p@samsung.com> Signed-off-by: Rohit Thapliyal <r.thapliyal@samsung.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-10-12writeback: fix incorrect calculation of available memory for memcg domainsTejun Heo
For memcg domains, the amount of available memory was calculated as min(the amount currently in use + headroom according to memcg, total clean memory) This isn't quite correct as what should be capped by the amount of clean memory is the headroom, not the sum of memory in use and headroom. For example, if a memcg domain has a significant amount of dirty memory, the above can lead to a value which is lower than the current amount in use which doesn't make much sense. In most circumstances, the above leads to a number which is somewhat but not drastically lower. As the amount of memory which can be readily allocated to the memcg domain is capped by the amount of system-wide clean memory which is not already assigned to the memcg itself, the number we want is the amount currently in use + min(headroom according to memcg, clean memory elsewhere in the system) This patch updates mem_cgroup_wb_stats() to return the number of filepages and headroom instead of the calculated available pages. mdtc_cap_avail() is renamed to mdtc_calc_avail() and performs the above calculation from file, headroom, dirty and globally clean pages. v2: Dummy mem_cgroup_wb_stats() implementation wasn't updated leading to build failure when !CGROUP_WRITEBACK. Fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: c2aa723a6093 ("writeback: implement memcg writeback domain based throttling") Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-12writeback: bdi_writeback iteration must not skip dying onesTejun Heo
bdi_for_each_wb() is used in several places to wake up or issue writeback work items to all wb's (bdi_writeback's) on a given bdi. The iteration is performed by walking bdi->cgwb_tree; however, the tree only indexes wb's which are currently active. For example, when a memcg gets associated with a different blkcg, the old wb is removed from the tree so that the new one can be indexed. The old wb starts dying from then on but will linger till all its inodes are drained. As these dying wb's may still host dirty inodes, writeback operations which affect all wb's must include them. bdi_for_each_wb() skipping dying wb's led to sync(2) missing and failing to sync the inodes belonging to those wb's. This patch adds a RCU protected @bdi->wb_list which lists all wb's beloinging to that bdi. wb's are added on creation and removed on release rather than on the start of destruction. bdi_for_each_wb() usages are replaced with list_for_each[_continue]_rcu() iterations over @bdi->wb_list and bdi_for_each_wb() and its helpers are removed. v2: Updated as per Jan. last_wb ref leak in bdi_split_work_to_wbs() fixed and unnecessary list head severing in cgwb_bdi_destroy() removed. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Artem Bityutskiy <dedekind1@gmail.com> Fixes: ebe41ab0c79d ("writeback: implement bdi_for_each_wb()") Link: http://lkml.kernel.org/g/1443012552.19983.209.camel@gmail.com Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-11Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "Three trivial commits: - Fix a kerneldoc regression - Export handle_bad_irq to unbreak a driver in next - Add an accessor for the of_node field so refactoring in next does not depend on merge ordering" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqdomain: Add an accessor for the of_node field genirq: Fix handle_bad_irq kerneldoc comment genirq: Export handle_bad_irq
2015-10-10Merge tag 'usb-4.3-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are some small USB and PHY fixes and quirk updates for 4.3-rc5. Nothing major here, full details in the shortlog, and all of these have been in linux-next for a while" * tag 'usb-4.3-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: usb: Add device quirk for Logitech PTZ cameras USB: chaoskey read offset bug USB: Add reset-resume quirk for two Plantronics usb headphones. usb: renesas_usbhs: Add support for R-Car H3 usb: renesas_usbhs: fix build warning if 64-bit architecture usb: gadget: bdc: fix memory leak phy: berlin-sata: Fix module autoload for OF platform driver phy: rockchip-usb: power down phy when rockchip phy probe phy: qcom-ufs: fix build error when the component is built as a module
2015-10-09irqdomain: Add an accessor for the of_node fieldMarc Zyngier
As we're about to remove the of_node field from the irqdomain structure, introduce an accessor for it. Subsequent patches will take care of the actual repainting. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Jason Cooper <jason@lakedaemon.net> Link: http://lkml.kernel.org/r/1444402211-1141-1-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-08af_unix: constify the sock parameter in unix_sk()Paul Moore
Make unix_sk() just like inet[6]_sk() by constify'ing the sock parameter. Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-07openvswitch: Change CT_ATTR_FLAGS to CT_ATTR_COMMITJoe Stringer
Previously, the CT_ATTR_FLAGS attribute, when nested under the OVS_ACTION_ATTR_CT, encoded a 32-bit bitmask of flags that modify the semantics of the ct action. It's more extensible to just represent each flag as a nested attribute, and this requires no additional error checking to reject flags that aren't currently supported. Suggested-by: Ben Pfaff <blp@nicira.com> Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-07openvswitch: Extend ct_state match field to 32 bitsJoe Stringer
The ct_state field was initially added as an 8-bit field, however six of the bits are already being used and use cases are already starting to appear that may push the limits of this field. This patch extends the field to 32 bits while retaining the internal representation of 8 bits. This should cover forward compatibility of the ABI for the foreseeable future. This patch also reorders the OVS_CS_F_* bits to be sequential. Suggested-by: Jarno Rajahalme <jrajahalme@nicira.com> Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-07openvswitch: Fix typos in CT headersJoe Stringer
These comments hadn't caught up to their implementations, fix them. Fixes: 7f8a436eaa2c "openvswitch: Add conntrack action" Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-06Merge tag 'for-linus-4.3b-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen bug fixes from David Vrabel: - Fix VM save performance regression with x86 PV guests - Make kexec work in x86 PVHVM guests (if Xen has the soft-reset ABI) - Other minor fixes. * tag 'for-linus-4.3b-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: x86/xen/p2m: hint at the last populated P2M entry x86/xen: Do not clip xen_e820_map to xen_e820_map_entries when sanitizing map x86/xen: Support kexec/kdump in HVM guests by doing a soft reset xen/x86: Don't try to write syscall-related MSRs for PV guests xen: use correct type for HYPERVISOR_memory_op()
2015-10-05openvswitch: Rename LABEL->LABELSJoe Stringer
Conntrack LABELS (plural) are exposed by conntrack; rename the OVS name for these to be consistent with conntrack. Fixes: c2ac667 "openvswitch: Allow matching on conntrack label" Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-05tcp/dccp: fix old style declarationsRaanan Avargil
I’m using the compilation flag -Werror=old-style-declaration, which requires that the “inline” word would come at the beginning of the code line. $ make drivers/net/ethernet/intel/e1000e/e1000e.ko ... include/net/inet_timewait_sock.h:116:1: error: ‘inline’ is not at beginning of declaration [-Werror=old-style-declaration] static void inline inet_twsk_schedule(struct inet_timewait_sock *tw, int timeo) include/net/inet_timewait_sock.h:121:1: error: ‘inline’ is not at beginning of declaration [-Werror=old-style-declaration] static void inline inet_twsk_reschedule(struct inet_timewait_sock *tw, int timeo) Fixes: ed2e92394589 ("tcp/dccp: fix timewait races in timer handling") Signed-off-by: Raanan Avargil <raanan.avargil@intel.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-04Merge branch 'strscpy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull strscpy string copy function implementation from Chris Metcalf. Chris sent this during the merge window, but I waffled back and forth on the pull request, which is why it's going in only now. The new "strscpy()" function is definitely easier to use and more secure than either strncpy() or strlcpy(), both of which are horrible nasty interfaces that have serious and irredeemable problems. strncpy() has a useless return value, and doesn't NUL-terminate an overlong result. To make matters worse, it pads a short result with zeroes, which is a performance disaster if you have big buffers. strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking the insane NUL padding, but having a differently broken return value which returns the original length of the source string. Which means that it will read characters past the count from the source buffer, and you have to trust the source to be properly terminated. It also makes error handling fragile, since the test for overflow is unnecessarily subtle. strscpy() avoids both these problems, guaranteeing the NUL termination (but not excessive padding) if the destination size wasn't zero, and making the overflow condition very obvious by returning -E2BIG. It also doesn't read past the size of the source, and can thus be used for untrusted source data too. So why did I waffle about this for so long? Every time we introduce a new-and-improved interface, people start doing these interminable series of trivial conversion patches. And every time that happens, somebody does some silly mistake, and the conversion patch to the improved interface actually makes things worse. Because the patch is mindnumbing and trivial, nobody has the attention span to look at it carefully, and it's usually done over large swatches of source code which means that not every conversion gets tested. So I'm pulling the strscpy() support because it *is* a better interface. But I will refuse to pull mindless conversion patches. Use this in places where it makes sense, but don't do trivial patches to fix things that aren't actually known to be broken. * 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: use global strscpy() rather than private copy string: provide strscpy() Make asm/word-at-a-time.h available on all architectures
2015-10-03Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Bunch of fixes all over the place, all pretty small: amdgpu, i915, exynos, one qxl and one vmwgfx. There is also a bunch of mst fixes, I left some cleanups in the series as I didn't think it was worth splitting up the tested series" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (37 commits) drm/dp/mst: add some defines for logical/physical ports drm/dp/mst: drop cancel work sync in the mstb destroy path (v2) drm/dp/mst: split connector registration into two parts (v2) drm/dp/mst: update the link_address_sent before sending the link address (v3) drm/dp/mst: fixup handling hotplug on port removal. drm/dp/mst: don't pass port into the path builder function drm/radeon: drop radeon_fb_helper_set_par drm: handle cursor_set2 in restore_fbdev_mode drm/exynos: Staticize local function in exynos_drm_gem.c drm/exynos: fimd: actually disable dp clock drm/exynos: dp: remove suspend/resume functions drm/qxl: recreate the primary surface when the bo is not primary drm/amdgpu: only print meaningful VM faults drm/amdgpu/cgs: remove import_gpu_mem drm/i915: Call non-locking version of drm_kms_helper_poll_enable(), v2 drm: Add a non-locking version of drm_kms_helper_poll_enable(), v2 drm/vmwgfx: Fix a command submission hang regression drm/exynos: remove unused mode_fixup() code drm/exynos: remove decon_mode_fixup() drm/exynos: remove fimd_mode_fixup() ...
2015-10-02Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "Another week, another round of fixes. These have been brewing for a bit and in various iterations, but I feel pretty comfortable about the quality of them. They fix real issues. The pull request is mostly blk-mq related, and the only one not fixing a real bug, is the tag iterator abstraction from Christoph. But it's pretty trivial, and we'll need it for another fix soon. Apart from the blk-mq fixes, there's an NVMe affinity fix from Keith, and a single fix for xen-blkback from Roger fixing failure to free requests on disconnect" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: factor out a helper to iterate all tags for a request_queue blk-mq: fix racy updates of rq->errors blk-mq: fix deadlock when reading cpu_list blk-mq: avoid inserting requests before establishing new mapping blk-mq: fix q->mq_usage_counter access race blk-mq: Fix use after of free q->mq_map blk-mq: fix sysfs registration/unregistration race blk-mq: avoid setting hctx->tags->cpumask before allocation NVMe: Set affinity after allocating request queues xen/blkback: free requests on disconnection
2015-10-02Merge git://git.infradead.org/intel-iommuLinus Torvalds
Pull IOVA fixes from David Woodhouse: "The main fix here is the first one, fixing the over-allocation of size-aligned requests. The other patches simply make the existing IOVA code available to users other than the Intel VT-d driver, with no functional change. I concede the latter really *should* have been submitted during the merge window, but since it's basically risk-free and people are waiting to build on top of it and it's my fault I didn't get it in, I (and they) would be grateful if you'd take it" * git://git.infradead.org/intel-iommu: iommu: Make the iova library a module iommu: iova: Export symbols iommu: iova: Move iova cache management to the iova library iommu/iova: Avoid over-allocating when size-aligned
2015-10-02drm/dp/mst: add some defines for logical/physical portsDave Airlie
This just removes the magic number. Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-10-02drm/dp/mst: split connector registration into two parts (v2)Dave Airlie
In order to cache the EDID properly for tiled displays, we need to retrieve it before we register the connector with userspace, otherwise userspace can call get resources and try and get the edid before we've even cached it. This fixes some problems when hotplugging mst monitors, with X/mutter running. As mutter seems to get 0 modes for one of the monitors in the tile. v2: fix warning in radeon handle tile setting in cached path rather than get edid path. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-10-01Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "12 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: dmapool: fix overflow condition in pool_find_page() thermal: avoid division by zero in power allocator memcg: remove pcp_counter_lock kprobes: use _do_fork() in samples to make them work again drivers/input/joystick/Kconfig: zhenhua.c needs BITREVERSE memcg: make mem_cgroup_read_stat() unsigned memcg: fix dirty page migration dax: fix NULL pointer in __dax_pmd_fault() mm: hugetlbfs: skip shared VMAs when unmapping private pages to satisfy a fault mm/slab: fix unexpected index mapping result of kmalloc_size(INDEX_NODE+1) userfaultfd: remove kernel header include from uapi header arch/x86/include/asm/efi.h: fix build failure
2015-10-01Merge tag 'pm+acpi-4.3-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "These are fixes mostly, for a few changes made in this cycle (the intel_idle driver, the OPP library, the ACPI EC driver, turbostat) and for some issues that have just been discovered (ACPI PCI IRQ management, PCI power management documentation, turbostat), with a couple of cleanups on top of them. Specifics: - intel_idle driver fixup for the recently added Skylake chips support (Len Brown). - Operating Performance Points (OPP) library fix related to the recently added support for new DT bindings and a fix for a typo in a comment (Viresh Kumar, Stephen Boyd). - ACPI EC driver fix for a recently introduced memory leak in an error code path (Lv Zheng). - ACPI PCI IRQ management fix for the issue where an ISA IRQ is shared with a PCI device which requires it to be configured in a different way and may cause an interrupt storm to happen as a result with an extra ACPI SCI IRQ handling simplification on top of it (Jiang Liu). - Update of the PCI power management documentation that became outdated and started to actively confuse the readers to make it actually reflect the code (Rafael J Wysocki). - turbostat fixes including an IVB Xeon regression fix (related to the --debug command line option), Skylake adjustment for the TSC running at a frequency that doesn't match the base one exactly, and a Knights Landing quirk to account for the fact that it only updates APERF and MPERF every 1024 clock cycles plus bumping up the turbostat version number (Len Brown, Hubert Chrzaniuk)" * tag 'pm+acpi-4.3-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: tools/power turbosat: update version number tools/power turbostat: SKL: Adjust for TSC difference from base frequency tools/power turbostat: KNL workaround for %Busy and Avg_MHz tools/power turbostat: IVB Xeon: fix --debug regression ACPI / PCI: Remove duplicated penalty on SCI IRQ ACPI, PCI, irq: Do not share PCI IRQ with ISA IRQ ACPI / EC: Fix a memory leak issue in acpi_ec_query() PM / OPP: Fix typo modifcation -> modification PCI / PM: Update runtime PM documentation for PCI devices PM / OPP: of_property_count_u32_elems() can return errors intel_idle: Skylake Client Support - updated
2015-10-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix regression in SKB partial checksum handling, from Pravin B Shalar. 2) Fix VLAN inside of VXLAN handling in i40e driver, from Jesse Brandeburg. 3) Cure softlockups during accept() in SCTP, from Karl Heiss. 4) MSG_PEEK should return multiple SKBs worth of data in AF_UNIX, from Aaron Conole. 5) IPV6 erroneously ignores output interface specifier in lookup key for route lookups, fix from David Ahern. 6) In Marvell DSA driver, forward unknown frames to CPU port, from Andrew Lunn. 7) Mission flow flag initializations in some code paths, from David Ahern. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: Initialize flow flags in input path net: dsa: fix preparation of a port STP update testptp: Silence compiler warnings on ppc64 net/mlx4: Handle return codes in mlx4_qp_attach_common dsa: mv88e6xxx: Enable forwarding for unknown to the CPU port skbuff: Fix skb checksum partial check. net: ipv6: Add RT6_LOOKUP_F_IFACE flag if oif is set net sysfs: Print link speed as signed integer bna: fix error handling af_unix: return data from multiple SKBs on recv() with MSG_PEEK flag af_unix: Convert the unix_sk macro to an inline function for type safety net: sctp: Don't use 64 kilobyte lookup table for four elements l2tp: protect tunnel->del_work by ref_count net/ibm/emac: bump version numbers for correct work with ethtool sctp: Prevent soft lockup when sctp_accept() is called during a timeout event sctp: Whitespace fix i40e/i40evf: check for stopped admin queue i40e: fix VLAN inside VXLAN r8169: fix handling rtl_readphy result net: hisilicon: fix handling platform_get_irq result
2015-10-01memcg: remove pcp_counter_lockGreg Thelen
Commit 733a572e66d2 ("memcg: make mem_cgroup_read_{stat|event}() iterate possible cpus instead of online") removed the last use of the per memcg pcp_counter_lock but forgot to remove the variable. Kill the vestigial variable. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01memcg: fix dirty page migrationGreg Thelen
The problem starts with a file backed dirty page which is charged to a memcg. Then page migration is used to move oldpage to newpage. Migration: - copies the oldpage's data to newpage - clears oldpage.PG_dirty - sets newpage.PG_dirty - uncharges oldpage from memcg - charges newpage to memcg Clearing oldpage.PG_dirty decrements the charged memcg's dirty page count. However, because newpage is not yet charged, setting newpage.PG_dirty does not increment the memcg's dirty page count. After migration completes newpage.PG_dirty is eventually cleared, often in account_page_cleaned(). At this time newpage is charged to a memcg so the memcg's dirty page count is decremented which causes underflow because the count was not previously incremented by migration. This underflow causes balance_dirty_pages() to see a very large unsigned number of dirty memcg pages which leads to aggressive throttling of buffered writes by processes in non root memcg. This issue: - can harm performance of non root memcg buffered writes. - can report too small (even negative) values in memory.stat[(total_)dirty] counters of all memcg, including the root. To avoid polluting migrate.c with #ifdef CONFIG_MEMCG checks, introduce page_memcg() and set_page_memcg() helpers. Test: 0) setup and enter limited memcg mkdir /sys/fs/cgroup/test echo 1G > /sys/fs/cgroup/test/memory.limit_in_bytes echo $$ > /sys/fs/cgroup/test/cgroup.procs 1) buffered writes baseline dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k sync grep ^dirty /sys/fs/cgroup/test/memory.stat 2) buffered writes with compaction antagonist to induce migration yes 1 > /proc/sys/vm/compact_memory & rm -rf /data/tmp/foo dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k kill % sync grep ^dirty /sys/fs/cgroup/test/memory.stat 3) buffered writes without antagonist, should match baseline rm -rf /data/tmp/foo dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k sync grep ^dirty /sys/fs/cgroup/test/memory.stat (speed, dirty residue) unpatched patched 1) 841 MB/s 0 dirty pages 886 MB/s 0 dirty pages 2) 611 MB/s -33427456 dirty pages 793 MB/s 0 dirty pages 3) 114 MB/s -33427456 dirty pages 891 MB/s 0 dirty pages Notice that unpatched baseline performance (1) fell after migration (3): 841 -> 114 MB/s. In the patched kernel, post migration performance matches baseline. Fixes: c4843a7593a9 ("memcg: add per cgroup dirty page accounting") Signed-off-by: Greg Thelen <gthelen@google.com> Reported-by: Dave Hansen <dave.hansen@intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> [4.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01userfaultfd: remove kernel header include from uapi headerAndre Przywara
As include/uapi/linux/userfaultfd.h is a user visible header file, it should not include kernel-exclusive header files. So trying to build the userfaultfd test program from the selftests directory fails, since it contains a reference to linux/compiler.h. As it turns out, that header is not really needed there, so we can simply remove it to fix that issue. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma fixes from Doug Ledford: - Fixes for mlx5 related issues - Fixes for ipoib multicast handling * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: IB/ipoib: increase the max mcast backlog queue IB/ipoib: Make sendonly multicast joins create the mcast group IB/ipoib: Expire sendonly multicast joins IB/mlx5: Remove pa_lkey usages IB/mlx5: Remove support for IB_DEVICE_LOCAL_DMA_LKEY IB/iser: Add module parameter for always register memory xprtrdma: Replace global lkey with lkey local to PD
2015-10-01Merge branches 'pm-pci' and 'acpi-pci'Rafael J. Wysocki
* pm-pci: PCI / PM: Update runtime PM documentation for PCI devices * acpi-pci: ACPI / PCI: Remove duplicated penalty on SCI IRQ ACPI, PCI, irq: Do not share PCI IRQ with ISA IRQ
