path: root/include
2013-04-26Add file_ns_capable() helper function for open-time capability checkingLinus Torvalds
commit 935d8aabd4331f47a89c3e1daa5779d23cf244ee upstream. Nothing is using it yet, but this will allow us to delay the open-time checks to use time, without breaking the normal UNIX permission semantics where permissions are determined by the opener (and the file descriptor can then be passed to a different process, or the process can drop capabilities). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Shea Levy <shea@shealevy.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25vm: add vm_iomap_memory() helper functionLinus Torvalds
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e upstream. Various drivers end up replicating the code to mmap() their memory buffers into user space, and our core memory remapping function may be very flexible but it is unnecessarily complicated for the common cases to use. Our internal VM uses pfn's ("page frame numbers") which simplifies things for the VM, and allows us to pass physical addresses around in a denser and more efficient format than passing a "phys_addr_t" around, and having to shift it up and down by the page size. But it just means that drivers end up doing that shifting instead at the interface level. It also means that drivers end up mucking around with internal VM things like the vma details (vm_pgoff, vm_start/end) way more than they really need to. So this just exports a function to map a certain physical memory range into user space (using a phys_addr_t based interface that is much more natural for a driver) and hides all the complexity from the driver. Some drivers will still end up tweaking the vm_page_prot details for things like prefetching or cacheability etc, but that's actually relevant to the driver, rather than caring about what the page offset of the mapping is into the particular IO memory region. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-25ssb: implement spurious tone avoidanceRafał Miłecki
commit 46fc4c909339f5a84d1679045297d9d2fb596987 upstream. And make use of it in b43. This fixes a regression introduced with 49d55cef5b1925a5c1efb6aaddaa40fc7c693335 b43: N-PHY: implement spurious tone avoidance This commit made BCM4322 use only MCS 0 on channel 13, which of course resulted in performance drop (down to 0.7Mb/s). Reported-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25KVM: Allow cross page reads and writes from cached translations.Andrew Honig
commit 8f964525a121f2ff2df948dac908dcc65be21b5b upstream. This patch adds support for kvm_gfn_to_hva_cache_init functions for reads and writes that will cross a page. If the range falls within the same memslot, then this will be a fast operation. If the range is split between two memslots, then the slower kvm_read_guest and kvm_write_guest are used. Tested: Test against kvm_clock unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25kthread: Prevent unpark race which puts threads on the wrong cpuThomas Gleixner
commit f2530dc71cf0822f90bb63ea4600caaef33a66bb upstream. The smpboot threads rely on the park/unpark mechanism which binds per cpu threads on a particular core. Though the functionality is racy: CPU0 CPU1 CPU2 unpark(T) wake_up_process(T) clear(SHOULD_PARK) T runs leave parkme() due to !SHOULD_PARK bind_to(CPU2) BUG_ON(wrong CPU) We cannot let the tasks move themself to the target CPU as one of those tasks is actually the migration thread itself, which requires that it starts running on the target cpu right away. The solution to this problem is to prevent wakeups in park mode which are not from unpark(). That way we can guarantee that the association of the task to the target cpu is working correctly. Add a new task state (TASK_PARKED) which prevents other wakeups and use this state explicitly for the unpark wakeup. Peter noticed: Also, since the task state is visible to userspace and all the parked tasks are still in the PID space, its a good hint in ps and friends that these tasks aren't really there for the moment. The migration thread has another related issue. CPU0 CPU1 Bring up CPU2 create_thread(T) park(T) wait_for_completion() parkme() complete() sched_set_stop_task() schedule(TASK_PARKED) The sched_set_stop_task() call is issued while the task is on the runqueue of CPU1 and that confuses the hell out of the stop_task class on that cpu. So we need the same synchronizaion before sched_set_stop_task(). Reported-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Dave Hansen <dave@sr71.net> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Acked-by: Peter Ziljstra <peterz@infradead.org> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: dhillf@gmail.com Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1304091635430.21884@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16ftrace: Move ftrace_filter_lseek out of CONFIG_DYNAMIC_FTRACE sectionSteven Rostedt (Red Hat)
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream. As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the ftrace_pid_fops is defined when DYNAMIC_FTRACE is not. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16tracing: Fix possible NULL pointer dereferencesNamhyung Kim
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream. Currently set_ftrace_pid and set_graph_function files use seq_lseek for their fops. However seq_open() is called only for FMODE_READ in the fops->open() so that if an user tries to seek one of those file when she open it for writing, it sees NULL seq_file and then panic. It can be easily reproduced with following command: $ cd /sys/kernel/debug/tracing $ echo 1234 | sudo tee -a set_ftrace_pid In this example, GNU coreutils' tee opens the file with fopen(, "a") and then the fopen() internally calls lseek(). Link: http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16x86-32: Fix possible incomplete TLB invalidate with PAE pagetablesDave Hansen
commit 1de14c3c5cbc9bb17e9dcc648cda51c0c85d54b9 upstream. This patch attempts to fix: https://bugzilla.kernel.org/show_bug.cgi?id=56461 The symptom is a crash and messages like this: chrome: Corrupted page table at address 34a03000 *pdpt = 0000000000000000 *pde = 0000000000000000 Bad pagetable: 000f [#1] PREEMPT SMP Ingo guesses this got introduced by commit 611ae8e3f520 ("x86/tlb: enable tlb flush range support for x86") since that code started to free unused pagetables. On x86-32 PAE kernels, that new code has the potential to free an entire PMD page and will clear one of the four page-directory-pointer-table (aka pgd_t entries). The hardware aggressively "caches" these top-level entries and invlpg does not actually affect the CPU's copy. If we clear one we *HAVE* to do a full TLB flush, otherwise we might continue using a freed pmd page. (note, we do this properly on the population side in pud_populate()). This patch tracks whenever we clear one of these entries in the 'struct mmu_gather', and ensures that we follow up with a full tlb flush. BTW, I disassembled and checked that: if (tlb->fullmm == 0) and if (!tlb->fullmm && !tlb->need_flush_all) generate essentially the same code, so there should be zero impact there to the !PAE case. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Artem S Tashkinov <t.artem@mailcity.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12spinlocks and preemption points need to be at least compiler barriersLinus Torvalds
commit 386afc91144b36b42117b0092893f15bc8798a80 upstream. In UP and non-preempt respectively, the spinlocks and preemption disable/enable points are stubbed out entirely, because there is no regular code that can ever hit the kind of concurrency they are meant to protect against. However, while there is no regular code that can cause scheduling, we _do_ end up having some exceptional (literally!) code that can do so, and that we need to make sure does not ever get moved into the critical region by the compiler. In particular, get_user() and put_user() is generally implemented as inline asm statements (even if the inline asm may then make a call instruction to call out-of-line), and can obviously cause a page fault and IO as a result. If that inline asm has been scheduled into the middle of a preemption-safe (or spinlock-protected) code region, we obviously lose. Now, admittedly this is *very* unlikely to actually ever happen, and we've not seen examples of actual bugs related to this. But partly exactly because it's so hard to trigger and the resulting bug is so subtle, we should be extra careful to get this right. So make sure that even when preemption is disabled, and we don't have to generate any actual *code* to explicitly tell the system that we are in a preemption-disabled region, we need to at least tell the compiler not to move things around the critical region. This patch grew out of the same discussion that caused commits 79e5f05edcbf ("ARC: Add implicit compiler barrier to raw_local_irq* functions") and 3e2e0d2c222b ("tile: comment assumption about __insn_mtspr for <asm/irqflags.h>") to come about. Note for stable: use discretion when/if applying this. As mentioned, this bug may never have actually bitten anybody, and gcc may never have done the required code motion for it to possibly ever trigger in practice. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12libata: Set max sector to 65535 for Slimtype DVD A DS8A8SH driveShan Hai
commit a32450e127fc6e5ca6d958ceb3cfea4d30a00846 upstream. The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than 65535, and the blow backtrace is observed on locking up: INFO: task flush-8:32:1130 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000 ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000 ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000 ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000 Call Trace: [<ffffffff8168fc2d>] schedule+0x5d/0x70 [<ffffffff8168fccc>] io_schedule+0x8c/0xd0 [<ffffffff81324461>] get_request+0x731/0x7d0 [<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90 [<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40 [<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110 [<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0 [<ffffffff81322176>] generic_make_request+0xc6/0x120 [<ffffffff81322308>] submit_bio+0x138/0x160 [<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120 [<ffffffff811d1f61>] submit_bh+0x1f1/0x220 [<ffffffff811d48b8>] __block_write_full_page+0x228/0x340 [<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100 [<ffffffff811d4ae5>] block_write_full_page+0x15/0x20 [<ffffffff811d9268>] blkdev_writepage+0x18/0x20 [<ffffffff81142527>] __writepage+0x17/0x40 [<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0 [<ffffffff81142510>] ? set_page_dirty+0x70/0x70 [<ffffffff81143a61>] generic_writepages+0x51/0x80 [<ffffffff81143ab0>] do_writepages+0x20/0x50 [<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0 [<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0 [<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0 [<ffffffff811cad43>] wb_writeback+0x1a3/0x330 [<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50 [<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70 [<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260 [<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240 [<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0 [<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260 [<ffffffff81083550>] kthread+0xc0/0xd0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 [<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 The above trace was triggered by "dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768" It was previously working by accident, since another bug introduced by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused all drives to use maxsect=65535. Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12libata: Use integer return value for atapi_command_packet_setShan Hai
commit d8668fcb0b257d9fdcfbe5c172a99b8d85e1cd82 upstream. The function returns type of ATAPI drives so it should return integer value. The commit 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) since v2.6.39 changed the type of return value from int to bool, the change would cause all of the ATAPI class drives to be treated as TYPE_TAPE and the max_sectors of the drives to be set to 65535 because of the commit f8d8e5799b7(libata: increase 128 KB / cmd limit for ATAPI tape drives), for the function would return true for all ATAPI class drives and the TYPE_TAPE is defined as 0x01. Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05net: fix *_DIAG_MAX constantsAndrey Vagin
[ Upstream commit ae5fc98728c8bbbd6d7cab0b9781671fc4419c1b ] Follow the common pattern and define *_DIAG_MAX like: [...] __XXX_DIAG_MAX, }; Because everyone is used to do: struct nlattr *attrs[XXX_DIAG_MAX+1]; nla_parse([...], XXX_DIAG_MAX, [...] Reported-by: Thomas Graf <tgraf@suug.ch> Cc: "David S. Miller" <davem@davemloft.net> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Eric Dumazet <edumazet@google.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05thermal: shorten too long mcast group nameMasatake YAMATO
[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter adds an assertion to genetlink to prevent this from happening again in the future. ] The original name is too long. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05signal: Define __ARCH_HAS_SA_RESTORER so we know whether to clear sa_restorerBen Hutchings
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side struct sigaction declarations'. flush_signal_handlers() needs to know whether sigaction::sa_restorer is defined, not whether SA_RESTORER is defined. Define the __ARCH_HAS_SA_RESTORER macro to indicate this. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05USB: serial: add modem-status-change wait queueJohan Hovold
commit e5b33dc9d16053c2ae4c2c669cf008829530364b upstream. Add modem-status-change wait queue to struct usb_serial_port that subdrivers can use to implement TIOCMIWAIT. Currently subdrivers use a private wait queue which may have been released when waking up after device disconnected. Note that we're adding a new wait queue rather than reusing the tty-port one as we do not want to get woken up at hangup (yet). Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05userns: Restrict when proc and sysfs can be mountedEric W. Biederman
commit 87a8ebd637dafc255070f503909a053cf0d98d3f upstream. Only allow unprivileged mounts of proc and sysfs if they are already mounted when the user namespace is created. proc and sysfs are interesting because they have content that is per namespace, and so fresh mounts are needed when new namespaces are created while at the same time proc and sysfs have content that is shared between every instance. Respect the policy of who may see the shared content of proc and sysfs by only allowing new mounts if there was an existing mount at the time the user namespace was created. In practice there are only two interesting cases: proc and sysfs are mounted at their usual places, proc and sysfs are not mounted at all (some form of mount namespace jail). Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05vfs: Add a mount flag to lock read only bind mountsEric W. Biederman
commit 90563b198e4c6674c63672fae1923da467215f45 upstream. When a read-only bind mount is copied from mount namespace in a higher privileged user namespace to a mount namespace in a lesser privileged user namespace, it should not be possible to remove the the read-only restriction. Add a MNT_LOCK_READONLY mount flag to indicate that a mount must remain read-only. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05userns: Don't allow creation if the user is chrootedEric W. Biederman
commit 3151527ee007b73a0ebd296010f1c0454a919c7d upstream. Guarantee that the policy of which files may be access that is established by setting the root directory will not be violated by user namespaces by verifying that the root directory points to the root of the mount namespace at the time of user namespace creation. Changing the root is a privileged operation, and as a matter of policy it serves to limit unprivileged processes to files below the current root directory. For reasons of simplicity and comprehensibility the privilege to change the root directory is gated solely on the CAP_SYS_CHROOT capability in the user namespace. Therefore when creating a user namespace we must ensure that the policy of which files may be access can not be violated by changing the root directory. Anyone who runs a processes in a chroot and would like to use user namespace can setup the same view of filesystems with a mount namespace instead. With this result that this is not a practical limitation for using user namespaces. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05xen/blkback: correctly respond to unknown, non-native requestsDavid Vrabel
commit 0e367ae46503cfe7791460c8ba8434a5d60b2bd5 upstream. If the frontend is using a non-native protocol (e.g., a 64-bit frontend with a 32-bit backend) and it sent an unrecognized request, the request was not translated and the response would have the incorrect ID. This may cause the frontend driver to behave incorrectly or crash. Since the ID field in the request is always in the same place, regardless of the request type we can get the correct ID and make a valid response (which will report BLKIF_RSP_EOPNOTSUPP). This bug affected 64-bit SLES 11 guests when using a 32-bit backend. This guest does a BLKIF_OP_RESERVED_1 (BLKIF_OP_PACKET in the SLES source) and would crash in blkif_int() as the ID in the response would be invalid. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05xen-pciback: notify hypervisor about devices intended to be assigned to guestsJan Beulich
commit 909b3fdb0dd4f3db07b2d75425a00a2adb551383 upstream. For MSI-X capable devices the hypervisor wants to write protect the MSI-X table and PBA, yet it can't assume that resources have been assigned to their final values at device enumeration time. Thus have pciback do that notification, as having the device controlled by it is a prerequisite to assigning the device to guests anyway. This is the kernel part of hypervisor side commit 4245d33 ("x86/MSI: add mechanism to fully protect MSI-X table from PV guest accesses") on the master branch of git://xenbits.xen.org/xen.git. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28drm/radeon: add Richland pci idsAlex Deucher
commit b75bbaa038ffc426e88ea3df6c4ae11834fc3e4f upstream. Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28inet: limit length of fragment queue hash table bucket listsHannes Frederic Sowa
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ] This patch introduces a constant limit of the fragment queue hash table bucket list lengths. Currently the limit 128 is choosen somewhat arbitrary and just ensures that we can fill up the fragment cache with empty packets up to the default ip_frag_high_thresh limits. It should just protect from list iteration eating considerable amounts of cpu. If we reach the maximum length in one hash bucket a warning is printed. This is implemented on the caller side of inet_frag_find to distinguish between the different users of inet_fragment.c. I dropped the out of memory warning in the ipv4 fragment lookup path, because we already get a warning by the slab allocator. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28net: cdc_ncm, cdc_mbim: allow user to prefer NCM for backwards compatibilityBjørn Mork
[ Upstream commit 1e8bbe6cd02fc300c88bd48244ce61ad9c7d1776 ] commit bd329e1 ("net: cdc_ncm: do not bind to NCM compatible MBIM devices") introduced a new policy, preferring MBIM for dual NCM/MBIM functions if the cdc_mbim driver was enabled. This caused a regression for users wanting to use NCM. Devices implementing NCM backwards compatibility according to section 3.2 of the MBIM v1.0 specification allow either NCM or MBIM on a single USB function, using different altsettings. The cdc_ncm and cdc_mbim drivers will both probe such functions, and must agree on a common policy for selecting either MBIM or NCM. Until now, this policy has been set at build time based on CONFIG_USB_NET_CDC_MBIM. Use a module parameter to set the system policy at runtime, allowing the user to prefer NCM on systems with the cdc_mbim driver. Cc: Greg Suarez <gsuarez@smithmicro.com> Cc: Alexey Orishko <alexey.orishko@stericsson.com> Reported-by: Geir Haatveit <nospam@haatveit.nu> Reported-by: Tommi Kyntola <kynde@ts.ray.fi> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=54791 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28skb: Propagate pfmemalloc on skb from head page onlyPavel Emelyanov
[ Upstream commit cca7af3889bfa343d33d5e657a38d876abd10e58 ] Hi. I'm trying to send big chunks of memory from application address space via TCP socket using vmsplice + splice like this mem = mmap(128Mb); vmsplice(pipe[1], mem); /* splice memory into pipe */ splice(pipe[0], tcp_socket); /* send it into network */ When I'm lucky and a huge page splices into the pipe and then into the socket _and_ client and server ends of the TCP connection are on the same host, communicating via lo, the whole connection gets stuck! The sending queue becomes full and app stops writing/splicing more into it, but the receiving queue remains empty, and that's why. The __skb_fill_page_desc observes a tail page of a huge page and erroneously propagates its page->pfmemalloc value onto socket (the pfmemalloc on tail pages contain garbage). Then this skb->pfmemalloc leaks through lo and due to the tcp_v4_rcv sk_filter if (skb->pfmemalloc && !sock_flag(sk, SOCK_MEMALLOC)) /* true */ return -ENOMEM goto release_and_discard; no packets reach the socket. Even TCP re-transmits are dropped by this, as skb cloning clones the pfmemalloc flag as well. That said, here's the proper page->pfmemalloc propagation onto socket: we must check the huge-page's head page only, other pages' pfmemalloc and mapping values do not contain what is expected in this place. However, I'm not sure whether this fix is _complete_, since pfmemalloc propagation via lo also oesn't look great. Both, bit propagation from page to skb and this check in sk_filter, were introduced by c48a11c7 (netvm: propagate page->pfmemalloc to skb), in v3.5 so Mel and stable@ are in Cc. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28tcp: fix skb_availroom()Eric Dumazet
[ Upstream commit 16fad69cfe4adbbfa813de516757b87bcae36d93 ] Chrome OS team reported a crash on a Pixel ChromeBook in TCP stack : https://code.google.com/p/chromium/issues/detail?id=182056 commit a21d45726acac (tcp: avoid order-1 allocations on wifi and tx path) did a poor choice adding an 'avail_size' field to skb, while what we really needed was a 'reserved_tailroom' one. It would have avoided commit 22b4a4f22da (tcp: fix retransmit of partially acked frames) and this commit. Crash occurs because skb_split() is not aware of the 'avail_size' management (and should not be aware) Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Mukesh Agrawal <quiche@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28ipv4: fix definition of FIB_TABLE_HASHSZDenis V. Lunev
[ Upstream commit 5b9e12dbf92b441b37136ea71dac59f05f2673a9 ] a long time ago by the commit commit 93456b6d7753def8760b423ac6b986eb9d5a4a95 Author: Denis V. Lunev <den@openvz.org> Date: Thu Jan 10 03:23:38 2008 -0800 [IPV4]: Unify access to the routing tables. the defenition of FIB_HASH_TABLE size has obtained wrong dependency: it should depend upon CONFIG_IP_MULTIPLE_TABLES (as was in the original code) but it was depended from CONFIG_IP_ROUTE_MULTIPATH This patch returns the situation to the original state. The problem was spotted by Tingwei Liu. Signed-off-by: Denis V. Lunev <den@openvz.org> CC: Tingwei Liu <tingw.liu@gmail.com> CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20atmel_lcdfb: fix 16-bpp modes on older SOCsJohan Hovold
commit a79eac7165ed62114e6ca197195aa5060a54f137 upstream. Fix regression introduced by commit 787f9fd23283 ("atmel_lcdfb: support 16bit BGR:565 mode, remove unsupported 15bit modes") which broke 16-bpp modes for older SOCs which use IBGR:555 (msb is intensity) rather than BGR:565. Use SOC-type to determine the pixel layout. Tested on at91sam9263 and at91sam9g45. Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20mtd: nand: reintroduce NAND_NO_READRDY as NAND_NEED_READRDYBrian Norris
commit 5bc7c33ca93a285dcfe7b7fd64970f6314440ad1 upstream. This partially reverts commit 1696e6bc2ae83734e64e206ac99766ea19e9a14e ("mtd: nand: kill NAND_NO_READRDY"). In that patch I overlooked a few things. The original documentation for NAND_NO_READRDY included "True for all large page devices, as they do not support autoincrement." I was conflating "not support autoincrement" with the NAND_NO_AUTOINCR option, which was in fact doing nothing. So, when I dropped NAND_NO_AUTOINCR, I concluded that I then could harmlessly drop NAND_NO_READRDY. But of course the fact the NAND_NO_AUTOINCR was doing nothing didn't mean NAND_NO_READRDY was doing nothing... So, NAND_NO_READRDY is re-introduced as NAND_NEED_READRDY and applied only to those few remaining small-page NAND which needed it in the first place. Reported-by: Alexander Shiyan <shc_work@mail.ru> Tested-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20perf,x86: fix link failure for non-Intel configsDavid Rientjes
commit 6c4d3bc99b3341067775efd4d9d13cc8e655fd7c upstream. Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after suspend/resume") introduces a link failure since perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL: arch/x86/power/built-in.o: In function `restore_processor_state': (.text+0x45c): undefined reference to `perf_restore_debug_store' Fix it by defining the dummy function appropriately. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20perf,x86: fix kernel crash with PEBS/BTS after suspend/resumeStephane Eranian
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream. This patch fixes a kernel crash when using precise sampling (PEBS) after a suspend/resume. Turns out the CPU notifier code is not invoked on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly by the kernel and keeps it power-on/resume value of 0 causing any PEBS measurement to crash when running on CPU0. The workaround is to add a hook in the actual resume code to restore the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0, the DS_AREA will be restored twice but this is harmless. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20tty/serial: Add support for Altera serial portLey Foon Tan
commit e06c93cacb82dd147266fd1bdb2d0a0bd45ff2c1 upstream. Add support for Altera 8250/16550 compatible serial port. Signed-off-by: Ley Foon Tan <lftan@altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14mfd: rtsx: Fix issue that booting OS with SD card insertedWei WANG
commit c3481955f6c78c8dd99921759306d7469c999ec2 upstream. Realtek card reader supports both SD and MS card. According to the settings of rtsx MFD driver, SD host will be probed before MS host. If we boot/reboot Linux with SD card inserted, the resetting flow of SD card will succeed, and the following resetting flow of MS is sure to fail. Then MS upper-level driver will ask rtsx driver to turn power off. This request leads to the result that the following SD commands fail and SD card can't be accessed again. In this commit, Realtek's SD and MS host driver will check whether the card that upper driver requesting is the one existing in the slot. If not, Realtek's host driver will refuse the operation to make sure the exlusive accessing at the same time. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Cc: Tim Gardner <rtg.canonical@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14dm: fix truncated status stringsMikulas Patocka
commit fd7c092e711ebab55b2688d3859d95dfd0301f73 upstream. Avoid returning a truncated table or status string instead of setting the DM_BUFFER_FULL_FLAG when the last target of a table fills the buffer. When processing a table or status request, the function retrieve_status calls ti->type->status. If ti->type->status returns non-zero, retrieve_status assumes that the buffer overflowed and sets DM_BUFFER_FULL_FLAG. However, targets don't return non-zero values from their status method on overflow. Most targets returns always zero. If a buffer overflow happens in a target that is not the last in the table, it gets noticed during the next iteration of the loop in retrieve_status; but if a buffer overflow happens in the last target, it goes unnoticed and erroneously truncated data is returned. In the current code, the targets behave in the following way: * dm-crypt returns -ENOMEM if there is not enough space to store the key, but it returns 0 on all other overflows. * dm-thin returns errors from the status method if a disk error happened. This is incorrect because retrieve_status doesn't check the error code, it assumes that all non-zero values mean buffer overflow. * all the other targets always return 0. This patch changes the ti->type->status function to return void (because most targets don't use the return code). Overflow is detected in retrieve_status: if the status method fills up the remaining space completely, it is assumed that buffer overflow happened. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04pstore: Avoid deadlock in panic and emergency-restart pathSeiji Aguchi
commit 9f244e9cfd70c7c0f82d3c92ce772ab2a92d9f64 upstream. [Issue] When pstore is in panic and emergency-restart paths, it may be blocked in those paths because it simply takes spin_lock. This is an example scenario which pstore may hang up in a panic path: - cpuA grabs psinfo->buf_lock - cpuB panics and calls smp_send_stop - smp_send_stop sends IRQ to cpuA - after 1 second, cpuB gives up on cpuA and sends an NMI instead - cpuA is now in an NMI handler while still holding buf_lock - cpuB is deadlocked This case may happen if a firmware has a bug and cpuA is stuck talking with it more than one second. Also, this is a similar scenario in an emergency-restart path: - cpuA grabs psinfo->buf_lock and stucks in a firmware - cpuB kicks emergency-restart via either sysrq-b or hangcheck timer. And then, cpuB is deadlocked by taking psinfo->buf_lock again. [Solution] This patch avoids the deadlocking issues in both panic and emergency_restart paths by introducing a function, is_non_blocking_path(), to check if a cpu can be blocked in current path. With this patch, pstore is not blocked even if another cpu has taken a spin_lock, in those paths by changing from spin_lock_irqsave to spin_trylock_irqsave. In addition, according to a comment of emergency_restart() in kernel/sys.c, spin_lock shouldn't be taken in an emergency_restart path to avoid deadlock. This patch fits the comment below. <snip> /** * emergency_restart - reboot the system * * Without shutting down any hardware or taking any locks * reboot the system. This is called when we know we are in * trouble so this is our best effort to reboot. This is * safe to call in interrupt context. */ void emergency_restart(void) <snip> Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04xen-blkfront: drop the use of llist_for_each_entry_safeKonrad Rzeszutek Wilk
commit f84adf4921ae3115502f44ff467b04bf2f88cf04 upstream. Replace llist_for_each_entry_safe with a while loop. llist_for_each_entry_safe can trigger a bug in GCC 4.1, so it's best to remove it and use a while loop and do the deletion manually. Specifically this bug can be triggered by hot-unplugging a disk, either by doing xm block-detach or by save/restore cycle. BUG: unable to handle kernel paging request at fffffffffffffff0 IP: [<ffffffffa0047223>] blkif_free+0x63/0x130 [xen_blkfront] The crash call trace is: ... bad_area_nosemaphore+0x13/0x20 do_page_fault+0x25e/0x4b0 page_fault+0x25/0x30 ? blkif_free+0x63/0x130 [xen_blkfront] blkfront_resume+0x46/0xa0 [xen_blkfront] xenbus_dev_resume+0x6c/0x140 pm_op+0x192/0x1b0 device_resume+0x82/0x1e0 dpm_resume+0xc9/0x1a0 dpm_resume_end+0x15/0x30 do_suspend+0x117/0x1e0 When drilling down to the assembler code, on newer GCC it does .L29: cmpq $-16, %r12 #, persistent_gnt check je .L30 #, out of the loop .L25: ... code in the loop testq %r13, %r13 # n je .L29 #, back to the top of the loop cmpq $-16, %r12 #, persistent_gnt check movq 16(%r12), %r13 # <variable>.node.next, n jne .L25 #, back to the top of the loop .L30: While on GCC 4.1, it is: L78: ... code in the loop testq %r13, %r13 # n je .L78 #, back to the top of the loop movq 16(%rbx), %r13 # <variable>.node.next, n jmp .L78 #, back to the top of the loop Which basically means that the exit loop condition instead of being: &(pos)->member != NULL; is: ; which makes the loop unbound. Since xen-blkfront is the only user of the llist_for_each_entry_safe macro remove it from llist.h. Orabug: 16263164 Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04quota: autoload the quota_v2 module for QFMT_VFS_V1 quota formatTheodore Ts'o
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream. Otherwise, ext4 file systems with the quota featured enable will get a very confusing "No such process" error message if the quota code is built as a module and the quota_v2 module has not been loaded. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28vlan: adjust vlan_set_encap_proto() for its callersCong Wang
[ Upstream commit da8c87241c26aac81a64c7e4d21d438a33018f4e ] There are two places to call vlan_set_encap_proto(): vlan_untag() and __pop_vlan_tci(). vlan_untag() assumes skb->data points after mac addr, otherwise the following code vhdr = (struct vlan_hdr *) skb->data; vlan_tci = ntohs(vhdr->h_vlan_TCI); __vlan_hwaccel_put_tag(skb, vlan_tci); skb_pull_rcsum(skb, VLAN_HLEN); won't be correct. But __pop_vlan_tci() assumes points _before_ mac addr. In vlan_set_encap_proto(), it looks for some magic L2 value after mac addr: rawp = skb->data; if (*(unsigned short *) rawp == 0xFFFF) ... Therefore __pop_vlan_tci() is obviously wrong. A quick fix is avoiding using skb->data in vlan_set_encap_proto(), use 'vhdr+1' is always correct in both cases. Signed-off-by: Cong Wang <amwang@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ipv4: fix error handling in icmp_protocol.Li Wei
[ Upstream commit 5b0520425e5ea81ba95ec486dd6bbb59a09fff0e ] Now we handle icmp errors in each transport protocol's err_handler, for icmp protocols, that is ping_err. Since this handler only care of those icmp errors triggered by echo request, errors triggered by echo reply(which sent by kernel) are sliently ignored. So wrap ping_err() with icmp_err() to deal with those icmp errors. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ipv6: use a stronger hash for tcpEric Dumazet
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ] It looks like its possible to open thousands of TCP IPv6 sessions on a server, all landing in a single slot of TCP hash table. Incoming packets have to lookup sockets in a very long list. We should hash all bits from foreign IPv6 addresses, using a salt and hash mix, not a simple XOR. inet6_ehashfn() can also separately use the ports, instead of xoring them. Reported-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ipv6: fix race condition regarding dst->expires and dst->from.YOSHIFUJI Hideaki
[ Upstream commit ecd9883724b78cc72ed92c98bcb1a46c764fff21 ] Eric Dumazet wrote: | Some strange crashes happen in rt6_check_expired(), with access | to random addresses. | | At first glance, it looks like the RTF_EXPIRES and | stuff added in commit 1716a96101c49186b | (ipv6: fix problem with expired dst cache) | are racy : same dst could be manipulated at the same time | on different cpus. | | At some point, our stack believes rt->dst.from contains a dst pointer, | while its really a jiffie value (as rt->dst.expires shares the same area | of memory) | | rt6_update_expires() should be fixed, or am I missing something ? | | CC Neil because of https://bugzilla.redhat.com/show_bug.cgi?id=892060 Because we do not have any locks for dst_entry, we cannot change essential structure in the entry; e.g., we cannot change reference to other entity. To fix this issue, split 'from' and 'expires' field in dst_entry out of union. Once it is 'from' is assigned in the constructor, keep the reference until the very last stage of the life time of the object. Of course, it is unsafe to change 'from', so make rt6_set_from simple just for fresh entries. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Neil Horman <nhorman@tuxdriver.com> CC: Gao Feng <gaofeng@cn.fujitsu.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Reviewed-by: Eric Dumazet <edumazet@google.com> Reported-by: Steinar H. Gunderson <sesse@google.com> Reviewed-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28net: fix a compile error when SOCK_REFCNT_DEBUG is enabledYing Xue
[ Upstream commit dec34fb0f5b7873de45132a84a3af29e61084a6b ] When SOCK_REFCNT_DEBUG is enabled, below build error is met: kernel/sysctl_binary.o: In function `sk_refcnt_debug_release': include/net/sock.h:1025: multiple definition of `sk_refcnt_debug_release' kernel/sysctl.o:include/net/sock.h:1025: first defined here kernel/audit.o: In function `sk_refcnt_debug_release': include/net/sock.h:1025: multiple definition of `sk_refcnt_debug_release' kernel/sysctl.o:include/net/sock.h:1025: first defined here make[1]: *** [kernel/built-in.o] Error 1 make: *** [kernel] Error 2 So we decide to make sk_refcnt_debug_release static to eliminate the error. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: Yet another band-aid for fixing lockdep messTakashi Iwai
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream. I've still got lockdep warnings even after Alan's patch, and it seems that yet more band aids are required to paper over similar paths for unbind_con_driver() and unregister_con_driver(). After this hack, lockdep warnings are finally gone. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: rework locking to fix lock ordering on takeoverAlan Cox
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream. Adjust the console layer to allow a take over call where the caller already holds the locks. Make the fb layer lock in order. This is partly a band aid, the fb layer is terminally confused about the locking rules it uses for its notifiers it seems. [akpm@linux-foundation.org: remove stray non-ascii char, tidy comment] [akpm@linux-foundation.org: export do_take_over_console()] [airlied: cleanup another non-ascii char] Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28vgacon/vt: clear buffer attributes when we load a 512 character font (v2)Dave Airlie
commit 2a2483072393b27f4336ab068a1f48ca19ff1c1e upstream. When we switch from 256->512 byte font rendering mode, it means the current contents of the screen is being reinterpreted. The bit that holds the high bit of the 9-bit font, may have been previously set, and thus the new font misrenders. The problem case we see is grub2 writes spaces with the bit set, so it ends up with data like 0x820, which gets reinterpreted into 0x120 char which the font translates into G with a circumflex. This flashes up on screen at boot and is quite ugly. A current side effect of this patch though is that any rendering on the screen changes color to a slightly darker color, but at least the screen no longer corrupts. v2: as suggested by hpa, always clear the attribute space, whether we are are going to or from 512 chars. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: usb: Fix Processing Unit Descriptor parsersPawel Moll
commit b531f81b0d70ffbe8d70500512483227cc532608 upstream. Commit 99fc86450c439039d2ef88d06b222fd51a779176 "ALSA: usb-mixer: parse descriptors with structs" introduced a set of useful parsers for descriptors. Unfortunately the parses for the Processing Unit Descriptor came with a very subtle bug... Functions uac_processing_unit_iProcessing() and uac_processing_unit_specific() were indexing the baSourceID array forgetting the fields before the iProcessing and process-specific descriptors. The problem was observed with Sound Blaster Extigy mixer, where nNrModes in Up/Down-mix Processing Unit Descriptor was accessed at offset 10 of the descriptor (value 0) instead of offset 15 (value 7). In result the resulting control had interesting limit values: Simple mixer control 'Channel Routing Mode Select',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - -1 Mono: -1 [100%] Fixed by starting from the bmControls, which was calculated correctly, instead of baSourceID. Now the mentioned control is fine: Simple mixer control 'Channel Routing Mode Select',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 6 Mono: 0 [0%] Signed-off-by: Pawel Moll <mail@pawelmoll.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28pps: Add pps_lookup_dev() functionGeorge Spelvin
commit 513b032c98b4b9414aa4e9b4a315cb1bf0380101 upstream. The PPS serial line discipline wants to attach a PPS device to a tty without changing the tty code to add a struct pps_device * pointer. Since the number of PPS devices in a typical system is generally very low (n=1 is by far the most common), it's practical to search the entire list of allocated pps devices. (We capture the timestamp before the lookup, so the timing isn't affected.) It is a bit ugly that this function, which is part of the in-kernel PPS API, has to be in pps.c as opposed to kapi,c, but that's not something that affects users. Signed-off-by: George Spelvin <linux@horizon.com> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28serial_core: Fix type definition for PORT_BRCM_TRUMANAGE.Michael Chan
commit 85f024401bf80746ae08b7fd5809a9b16accf0b1 upstream. It was mistakenly defined to be 24 instead of the next higher number 25. Reported-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Stephen Hurd <shurd@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-12Merge branch 'autofs-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux into akpm Pull hp parisc automounter fix from Helge Deller: "This unbreaks automounter support for the parisc architecture (and probably aarch64 as well)."" * 'autofs-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: unbreak automounter support on 64-bit kernel with 32-bit userspace (v2)
2013-02-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Revert iwlwifi reclaimed packet tracking, it causes problems for a bunch of folks. From Emmanuel Grumbach. 2) Work limiting code in brcmsmac wifi driver can clear tx status without processing the event. From Arend van Spriel. 3) rtlwifi USB driver processes wrong SKB, fix from Larry Finger. 4) l2tp tunnel delete can race with close, fix from Tom Parkin. 5) pktgen_add_device() failures are not checked at all, fix from Cong Wang. 6) Fix unintentional removal of carrier off from tun_detach(), otherwise we confuse userspace, from Michael S. Tsirkin. 7) Don't leak socket reference counts and ubufs in vhost-net driver, from Jason Wang. 8) vmxnet3 driver gets it's initial carrier state wrong, fix from Neil Horman. 9) Protect against USB networking devices which spam the host with 0 length frames, from Bjørn Mork. 10) Prevent neighbour overflows in ipv6 for locally destined routes, from Marcelo Ricardo. This is the best short-term fix for this, a longer term fix has been implemented in net-next. 11) L2TP uses ipv4 datagram routines in it's ipv6 code, whoops. This mistake is largely because the ipv6 functions don't even have some kind of prefix in their names to suggest they are ipv6 specific. From Tom Parkin. 12) Check SYN packet drops properly in tcp_rcv_fastopen_synack(), from Yuchung Cheng. 13) Fix races and TX skb freeing bugs in via-rhine's NAPI support, from Francois Romieu and your's truly. 14) Fix infinite loops and divides by zero in TCP congestion window handling, from Eric Dumazet, Neal Cardwell, and Ilpo Järvinen. 15) AF_PACKET tx ring handling can leak kernel memory to userspace, fix from Phil Sutter. 16) Fix error handling in ipv6 GRE tunnel transmit, from Tommi Rantala. 17) Protect XEN netback driver against hostile frontend putting garbage into the rings, don't leak pages in TX GOP checking, and add proper resource releasing in error path of xen_netbk_get_requests(). From Ian Campbell. 18) SCTP authentication keys should be cleared out and released with kzfree(), from Daniel Borkmann. 19) L2TP is a bit too clever trying to maintain skb->truesize, and ends up corrupting socket memory accounting to the point where packet sending is halted indefinitely. Just remove the adjustments entirely, they aren't really needed. From Eric Dumazet. 20) ATM Iphase driver uses a data type with the same name as the S390 headers, rename to fix the build. From Heiko Carstens. 21) Fix a typo in copying the inner network header offset from one SKB to another, from Pravin B Shelar. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (56 commits) net: sctp: sctp_endpoint_free: zero out secret key data net: sctp: sctp_setsockopt_auth_key: use kzfree instead of kfree atm/iphase: rename fregt_t -> ffreg_t net: usb: fix regression from FLAG_NOARP code l2tp: dont play with skb->truesize net: sctp: sctp_auth_key_put: use kzfree instead of kfree netback: correct netbk_tx_err to handle wrap around. xen/netback: free already allocated memory on failure in xen_netbk_get_requests xen/netback: don't leak pages on failure in xen_netbk_tx_check_gop. xen/netback: shutdown the ring if it contains garbage. net: qmi_wwan: add more Huawei devices, including E320 net: cdc_ncm: add another Huawei vendor specific device ipv6/ip6_gre: fix error case handling in ip6gre_tunnel_xmit() tcp: fix for zero packets_in_flight was too broad brcmsmac: rework of mac80211 .flush() callback operation ssb: unregister gpios before unloading ssb bcma: unregister gpios before unloading bcma rtlwifi: Fix scheduling while atomic bug net: usbnet: fix tx_dropped statistics tcp: ipv6: Update MIB counters for drops ...
2013-02-08unbreak automounter support on 64-bit kernel with 32-bit userspace (v2)Helge Deller
automount-support is broken on the parisc architecture, because the existing #if list does not include a check for defined(__hppa__). The HPPA (parisc) architecture is similiar to other 64bit Linux targets where we have to define autofs_wqt_t (which is passed back and forth to user space) as int type which has a size of 32bit across 32 and 64bit kernels. During the discussion on the mailing list, H. Peter Anvin suggested to invert the #if list since only specific platforms (specifically those who do not have a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned long type. This suggestion is probably the best way to go, since Arm64 (and maybe others?) seems to have a non-working automounter. So in the long run even for other new upcoming architectures this inverted check seem to be the best solution, since it will not require them to change this #if again (unless they are 64bit only). Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Ian Kent <raven@themaw.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> CC: James Bottomley <James.Bottomley@HansenPartnership.com> CC: Rolf Eike Beer <eike-kernel@sf-tec.de>
