This patch adds the ATI IXP southbridges support to i2c-piix4,
as it turned out those chips are compatible with it.
Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz>
Add Broadcom HT-1000 south bridge's PCI ID to i2c-piix driver. Note
that at least on Supermicro H8SSL it uses non-standard SMBHSTCFG = 3
and standard values like 0 or 9 causes hangup.
Signed-off-by: Martin Devera <devik@cdi.cz>
Some of the instances of tcp_sack_block are host-endian, some - net-endian.
Define struct tcp_sack_block_wire identical to struct tcp_sack_block
with u32 replaced with __be32; annotate uses of tcp_sack_block replacing
net-endian ones with tcp_sack_block_wire. Change is obviously safe since
for cc(1) __be32 is typedefed to u32.
In some cases such as:
iph->check = 0;
iph->check = ip_fast_csum((unsigned char *)iph, iph->ihl);
GCC may optimize out the previous store.
Observed as a failure of NFS over udp (bad checksums on ip fragments)
when compiled with GCC 3.4.2.
Signed-off-by: Bob Breuer <breuerr@mc.net>
This patch fixes a confusion reiserfs has for a long time.
On release file operation reiserfs used to try to pack file data stored in
last incomplete page of some files into metadata blocks. After packing the
page got cleared with clear_page_dirty. It did not take into account that
the page may be mmaped into other process's address space. Recent
replacement for clear_page_dirty cancel_dirty_page found the confusion with
sanity check that page has to be not mapped.
The patch fixes the confusion by making reiserfs avoid tail packing if an
inode was ever mmapped. reiserfs_mmap and reiserfs_file_release are
serialized with mutex in reiserfs specific inode. reiserfs_mmap locks the
mutex and sets a bit in reiserfs specific inode flags.
reiserfs_file_release checks the bit having the mutex locked. If bit is
set - tail packing is avoided. This eliminates a possibility that mmapped
page gets cancel_page_dirty-ed.
Signed-off-by: Vladimir Saveliev <vs@namesys.com>
Add pci_get_legacy_ide_irq() identical to the one used by i386/x86_64.
Fixes amd74xx driver build on ia64 (bugzilla bug #6644).
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Add support for the temperature sensor(s) found in AMD K8 CPUs.
arcmsr is a driver for the Areca Raid controller, a host based RAID
subsystem that speaks SCSI at the firmware level.
This patch is quite a clean up over the initial submission with
contributions from:
Randy Dunlap <rdunlap@xenotime.net>
Christoph Hellwig <hch@lst.de>
Matthew Wilcox <matthew@wil.cx>
Signed-off-by: Erich Chen <erich@areca.com.tw>
The command complete event of the exit periodic inquiry command must
clear the HCI_INQUIRY flag and finish the HCI request.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
RESTORE_CONTEXT lost a newline:
http://www.mail-archive.com/kgdb-bugreport@lists.sourceforge.net/msg00559.html
Reported by Steven M. Christey.
This updated patch adds the Intel ICH9 LPC and SMBus Controller DID's.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
SYSENTER can cause a NT to be set which might cause crashes on the IRET
in the next task.
Following similar i386 patch from Linus.
Backport to 2.6.16 by Chuck Ebbert <76306.1226@compuserve.com>
[Changed 'set_debugreg' to the older 'set_debug' in setup64.c
and added raw_local_save_flags() from 2.6.19 to system.h]
Signed-off-by: Andi Kleen <ak@suse.de>
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
(And reset it on new thread creation)
It turns out that eflags is important to save and restore not just
because of iopl, but due to the magic bits like the NT bit, which we
don't want leaking between different threads.
Backported to 2.6.16 by Chuck Ebbert <76306.1226@compuserve.com>
[Backport consisted of removing the CFI annotations.]
The bridge netfilter code needs to check for space at the
front of the skb before overwriting; otherwise if skb from
device doesn't have headroom, then it will cause random
memory corruption.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Add some nVidia chipset ID's support.
Added MCP61 support to sata_nv and amd74xx.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Unhide the SMBus controller on the Asus PU-DLS board.
This fixes bug #6763.
The nVidia CK804 PCI-E chipset supports the AER extended capability
but sometimes fails to link it (with some BIOS or after a warm reboot).
It makes the AER cap invisible to pci_find_ext_capability().
The patch adds a quirk to set the missing bit that controls the
linking of the capability.
By the way, it removes the corresponding code in the myri10ge driver.
Signed-off-by: Brice Goglin <brice@myri.com>
The naming of the constant defined for PCI ID 1022:7450 does not seem
to match the information at http://pciids.sourceforge.net/:
http://pci-ids.ucw.cz/iii/?i=1022
There 1022:7450 is listed as "AMD-8131 PCI-X Bridge" while 1022:7451
is listed as "AMD-8131 PCI-X IOAPIC". Yet, the current definition for
0x7450 is PCI_DEVICE_ID_AMD_8131_APIC. It seems to me like that name
should map to 0x7451, while a name like PCI_DEVICE_ID_AMD_8131_BRIDGE
should map to 0x7450.
<linux/mempolicy.h> uses struct mm_struct and relies on a definition or
declaration somehow magically being dragged in which may result in a
build:
CC mm/mempolicy.o
In file included from mm/mempolicy.c:69:
include/linux/mempolicy.h:150: warning: 'struct mm_struct' declared inside parameter list
include/linux/mempolicy.h:150: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/mempolicy.h:174: warning: 'struct mm_struct' declared inside parameter list
mm/mempolicy.c:673: error: conflicting types for 'do_migrate_pages'
include/linux/mempolicy.h:174: error: previous declaration of 'do_migrate_pages' was here
mm/mempolicy.c:1696: error: conflicting types for 'mpol_rebind_mm'
include/linux/mempolicy.h:150: error: previous declaration of 'mpol_rebind_mm' was here
make[1]: *** [mm/mempolicy.o] Error 1
make: *** [mm] Error 2
Including <linux/sched.h> is a step into direction of include hell so
fixed by adding a forward declaration of struct mm_struct instead.
Spotted by Thomas Voegtle.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
sbi->s_group_desc is an array of pointers to buffer_head. memcpy() of
buffer size from address of buffer_head is a bad idea - it will generate
junk in any case, may oops if buffer_head is close to the end of slab
page and next page is not mapped and isn't what was intended there.
IOW, ->b_data is missing in that call. Fortunately, result doesn't go
into the primary on-disk data structures, so only backup ones get crap
written to them; that had allowed this bug to remain unnoticed until
now.
The IGMPV3_EXP() macro doesn't correctly shift the normalization bit, so
time-out values are longer than they should be.
Thanks to Dirk Ooms for finding the problem in IGMPv3 - MLDv2 had a
similar problem that was already fixed a year ago. :-(
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
Calculation of IPX checksum got buggered about 2.4.0. The old variant
mangled the packet; that got fixed, but calculation itself got buggered.
Restored the correct logics, fixed a subtle breakage we used to have even
back then: if the sum is 0 mod 0xffff, we want to return 0, not 0xffff.
The latter has special meaning for IPX (cheksum disabled). Observation
(and obvious fix) nicked from history of FreeBSD ipx_cksum.c...
This patch prevents cross-region mappings
on IA64 and SPARC which could lead to system crash.
Adrian Bunk:
Adapted to 2.6.16.
Signed-Off-By: Kirill Korotaev <dev@openvz.org>
When pskb_trim has to defer to ___pksb_trim to trim the frag_list part of
the packet, the frag_list is not updated to reflect the trimming. This
will usually work fine until you hit something that uses the packet length
or tail from the frag_list.
Examples include esp_output and ip_fragment.
Another problem caused by this is that you can end up with a linear packet
with a frag_list attached.
It is possible to get away with this if we audit everything to make sure
that they always consult skb->len before going down onto frag_list. In
fact we can do the samething for the paged part as well to avoid copying
the data area of the skb. For now though, let's do the conservative fix
and update frag_list.
Many thanks to Marco Berizzi for helping me to track down this bug.
This 4-year old bug took 3 months to track down. Marco was very patient
indeed :)
Quadro NVS280 is a dual-head PCIe card with PCI ID 10de:00fd and subsystem I
10de:0215.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
http://bugzilla.kernel.org/show_bug.cgi?id=5653
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
This patch enables agpgart on a Via "PT880 Ultra" based motherboard
(Asus P4V800D-X). The PCI ID of the PT880 Ultra is 0x0308 instead of
0x0258 of the PT880.
The patched via-agp passes testgart.
Signed-off-by: Magnus Kessler <Magnus.Kessler@gmx.net>
Signed-off-by: Dave Jones <davej@redhat.com>
Fixes inconsistent use of "uint32_t" vs. "u_int32_t".
Fix pfkeyv2 userspace builds.
Signed-off-by: Tushar Gohad <tgohad@mvista.com>
Signed-off-by: Alan Cox <alan@redhat.com>
Jack Steiner identified a problem where XPC can cause a silent
data corruption. On module load, the placement may cause the
xpc_remote_copy_buffer to span two physical pages. DMA transfers are
done to the start virtual address translated to physical.
This patch changes the buffer from a statically allocated buffer to a
kmalloc'd buffer. Dean Nelson reviewed this before posting. I have
tested it in the configuration that was showing the memory corruption
and verified it works. I also added a BUG_ON statement to help catch
this if a similar situation is encountered.
Signed-off-by: Robin Holt <holt@sgi.com>
Signed-off-by: Dean Nelson <dcn@sgi.com>
Signed-off-by: Jack Steiner <steiner@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
The inode number out of an NFS file handle gets passed eventually to
ext3_get_inode_block() without any checking. If ext3_get_inode_block()
allows it to trigger an error, then bad filehandles can have unpleasant
effect - ext3_error() will usually cause a forced read-only remount, or a
panic if `errors=panic' was used.
So remove the call to ext3_error there and put a matching check in
ext3/namei.c where inode numbers are read off storage.
Andrew Morton fixed an off-by-one error.
Dann Frazier ported the patch to 2.6.16.
Signed-off-by: Neil Brown <neilb@suse.de>
Make SCTP handle broadcast properly
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
sctp_make_abort_user() now takes the msg_len along with the msg
so that we don't have to recalculate the bytes in iovec.
It also uses memcpy_fromiovec() so that we don't go beyond the
length allocated.
It is good to have this fix even if verify_iovec() is fixed to
return error on overflow.
Acked-by: David Miller <davem@davemloft.net>
Something is wrong with the 3-multiply (vs. 4-multiply) optimized
version of _FP_MUL_MEAT_2_*(), so just use the slower version
which actually computes correct values.
Noticed by Rene Rebe
- Fixed locking of struct i2o_exec_wait in Executive-OSM
- Removed LCT Notify in i2o_exec_probe() which caused freeing memory and
accessing freed memory during first enumeration of I2O devices
- Added missing locking in i2o_exec_lct_notify()
- removed put_device() of I2O controller in i2o_iop_remove() which caused
the controller structure get freed to early
- Fixed size of mempool in i2o_iop_alloc()
- Fixed access to freed memory in i2o_msg_get()
See http://bugzilla.kernel.org/show_bug.cgi?id=6561
Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Using asm-generic/dma-mapping.h does not work because pushing
the call down to pci_alloc_coherent() causes the gfp_t argument
of dma_alloc_coherent() to be ignored.
Fix this by implementing things directly, and adding a gfp_t
argument we can use in the internal call down to the PCI DMA
implementation of pci_alloc_coherent().
This fixes massive memory corruption when using the sound driver
layer, which passes things like __GFP_COMP down into these
routines and (correctly) expects that to work.
This is a disk eater when sound is used, so it's pretty critical.
If we move a mapping from one virtual address to another,
and this changes the virtual color of the mapping to those
pages, we can see corrupt data due to D-cache aliasing.
Check for and deal with this by overriding the move_pte()
macro. Set things up so that other platforms can cleanly
override the move_pte() macro too.
This long standing bug corrupts user memory, and in particular
has been notorious for corrupting Debian package database
files on sparc64 boxes.
(CVE-2006-1858)
When performing bound checks during the parameter processing, we
want to use the real chunk and paramter lengths for bounds instead
of the rounded ones. This prevents us from potentially walking of
the end if the chunk length was miscalculated. We still use rounded
lengths when advancing the pointer. This was found during a
conformance test that changed the chunk length without modifying
parameters.
(Vlad noted elsewhere: the most you'd overflow is 3 bytes, so problem
is parameter dependent).
(CVE-2006-2275)
This patch fixes a deadlock situation in the receive path by allowing
temporary spillover of the receive buffer.
- If the chunk we receive has a tsn that immediately follows the ctsn,
accept it even if we run out of receive buffer space and renege data with
higher TSNs.
- Once we accept one chunk in a packet, accept all the remaining chunks
even if we run out of receive buffer space.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Mark Butler <butlerm@middle.net>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
The FXSAVE information leak patch introduced a bug in FP exception
handling: it clears FP exceptions only when there are already
none outstanding. Mikael Pettersson reported that causes problems
with the Erlang runtime and has tested this fix.
Acked-by: Mikael Pettersson <mikpe@it.uu.se>
Gcc might emit an absolute address for the the "m" constraint which
gas unfortunately does not permit.
Proposed fix for ptep_get_and_clear_full PAE bug. Pte_clear had the same bug,
so use the same fix for both. Turns out pmd_clear had it as well, but pgds
are not affected.
The problem is rather intricate. Page table entries in PAE mode are 64-bits
wide, but the only atomic 8-byte write operation available in 32-bit mode is
cmpxchg8b, which is expensive (at least on P4), and thus avoided. But it can
happen that the processor may prefetch entries into the TLB in the middle of an
operation which clears a page table entry. So one must always clear the P-bit
in the low word of the page table entry first when clearing it.
Since the sequence *ptep = __pte(0) leaves the order of the write dependent on
the compiler, it must be coded explicitly as a clear of the low word followed
by a clear of the high word. Further, there must be a write memory barrier
here to enforce proper ordering by the compiler (and, in the future, by the
processor as well).
On > 4GB memory machines, the implementation of pte_clear for PAE was clearly
deficient, as it could leave virtual mappings of physical memory above 4GB
aliased to memory below 4GB in the TLB. The implementation of
ptep_get_and_clear_full has a similar bug, although not nearly as likely to
occur, since the mappings being cleared are in the process of being destroyed,
and should never be dereferenced again.
But, as luck would have it, it is possible to trigger bugs even without ever
dereferencing these bogus TLB mappings, even if the clear is followed fairly
soon after with a TLB flush or invalidation. The problem is that memory above
4GB may now be aliased into the first 4GB of memory, and in fact, may hit a
region of memory with non-memory semantics. These regions include AGP and PCI
space. As such, these memory regions are not cached by the processor. This
introduces the bug.
The processor can speculate memory operations, including memory writes, as long
as they are committed with the proper ordering. Speculating a memory write to
a linear address that has a bogus TLB mapping is possible. Normally, the
speculation is harmless. But for cached memory, it does leave the falsely
speculated cacheline unmodified, but in a dirty state. This cache line will be
eventually written back. If this cacheline happens to intersect a region of
memory that is not protected by the cache coherency protocol, it can corrupt
data in I/O memory, which is generally a very bad thing to do, and can cause
total system failure or just plain undefined behavior.
These bugs are extremely unlikely, but the severity is of such magnitude, and
the fix so simple that I think fixing them immediately is justified. Also,
they are nearly impossible to debug.
Signed-off-by: Zachary Amsden <zach@vmware.com>
Repair /proc/devices early-termination regression.
2.6.16 broke /proc/devices. An application often gets an
EOF before the end of data is reached, if that application
uses a series of short read(2)s to access the data. I have
used read buffers of varying sizes with varying degrees
of unsuccess (larger sizes get further into the data than
smaller sizes, following a simple pattern). It appears
that the only safe way to get the data is to use a single
read buffer larger than all the data in /proc/devices.
The following example demonstates the problem:
# dd if=/proc/devices bs=1
Character devices:
1 mem
27+0 records in
27+0 records out
This patch is a backport of the fix recently accepted to
Linus's tree:
commit 68eef3b4791572ecb70249c7fb145bb3742dd899
[PATCH] Simplify proc/devices and fix early termination regression
It replaces the complex, state-machine algorithm introduced
in 2.6.16 with a simple algorithm, modeled on the implementation
of /proc/interrupts.
[akpm@osdl.org: cleanups, simplifications]
Signed-off-by: Joe Korty <joe.korty@ccur.com>
Backport for_each_possible_cpu() into 2.6.16. Fixes the alpha build, and any
future occurrences.
