path: root/include
2015-02-05quota: Switch ->get_dqblk() and ->set_dqblk() to use bytes as space unitsJan Kara
commit 14bf61ffe6ac54afcd1e888a4407fe16054483db upstream. Currently ->get_dqblk() and ->set_dqblk() use struct fs_disk_quota which tracks space limits and usage in 512-byte blocks. However VFS quotas track usage in bytes (as some filesystems require that) and we need to somehow pass this information. Upto now it wasn't a problem because we didn't do any unit conversion (thus VFS quota routines happily stuck number of bytes into d_bcount field of struct fd_disk_quota). Only if you tried to use Q_XGETQUOTA or Q_XSETQLIM for VFS quotas (or Q_GETQUOTA / Q_SETQUOTA for XFS quotas), you got bogus results. Hardly anyone tried this but reportedly some Samba users hit the problem in practice. So when we want interfaces compatible we need to fix this. We bite the bullet and define another quota structure used for passing information from/to ->get_dqblk()/->set_dqblk. It's somewhat sad we have to have more conversion routines in fs/quota/quota.c and another copying of quota structure slows down getting of quota information by about 2% but it seems cleaner than overloading e.g. units of d_bcount to bytes. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-05vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream. The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29crypto: prefix module autoloading with "crypto-"Kees Cook
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream. This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29ACPI / PM: Do not disable wakeup GPEs that have not been enabledRafael J. Wysocki
commit 175f8e2650f7ca6b33d338be3ccc1c00e89594ea upstream. In some cases acpi_device_wakeup() may be called to ensure wakeup power to be off for a given device even though that device's wakeup GPE has not been enabled so far. It calls acpi_disable_gpe() on a GPE that's not enabled and this causes ACPICA to return the AE_LIMIT status code from that call which then is reported as an error by the ACPICA's debug facilities (if enabled). This may lead to a fair amount of confusion, so introduce a new ACPI device wakeup flag to store the wakeup GPE status and avoid disabling wakeup GPEs that have not been enabled. Reported-and-tested-by: Venkat Raghavulu <venkat.raghavulu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: get rid of radix tree gfp mask for pagecache_get_pageMichal Hocko
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream. Commit 2457aec63745 ("mm: non-atomically mark page accessed during page cache allocation where possible") has added a separate parameter for specifying gfp mask for radix tree allocations. Not only this is less than optimal from the API point of view because it is error prone, it is also buggy currently because grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then the radix tree allocation wouldn't obey the restriction and might recurse into filesystem and cause deadlocks. This is the case for most filesystems unfortunately because only ext4 and gfs2 are using AOP_FLAG_NOFS. Let's simply remove radix_gfp_mask parameter because the allocation context is same for both page cache and for the radix tree. Just make sure that the radix tree gets only the sane subset of the mask (e.g. do not pass __GFP_WRITE). Long term it is more preferable to convert remaining users of AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this interface even further. Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29time: settimeofday: Validate the values of tv from userSasha Levin
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream. An unvalidated user input is multiplied by a constant, which can result in an undefined behaviour for large values. While this is validated later, we should avoid triggering undefined behaviour. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> [jstultz: include trivial milisecond->microsecond correction noticed by Andy] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29PCI: Add flag for devices where we can't use bus resetAlex Williamson
commit f331a859e0ee5a898c1f47596eddad4c4f02d657 upstream. Enable a mechanism for devices to quirk that they do not behave when doing a PCI bus reset. We require a modest level of spec compliant behavior in order to do a reset, for instance the device should come out of reset without throwing errors and PCI config space should be accessible after reset. This is too much to ask for some devices. Link: http://lkml.kernel.org/r/20140923210318.498dacbd@dualc.maya.org Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29PCI: Add pci_claim_bridge_resource() to clip window if necessaryYinghai Lu
commit 8505e729a2f6eb0803ff943a15f133dd10afff3a upstream. Add pci_claim_bridge_resource() to claim a PCI-PCI bridge window. This is like regular pci_claim_resource(), except that if we fail to claim the window, we check to see if we can reduce the size of the window and try again. This is for scenarios like this: pci_bus 0000:00: root bus resource [mem 0xc0000000-0xffffffff] pci 0000:00:01.0: bridge window [mem 0xbdf00000-0xddefffff 64bit pref] pci 0000:01:00.0: reg 0x10: [mem 0xc0000000-0xcfffffff pref] The 00:01.0 window is illegal: it starts before the host bridge window, so we have to assume the [0xbdf00000-0xbfffffff] region is inaccessible. We can make it legal by clipping it to [mem 0xc0000000-0xddefffff 64bit pref]. Previously we discarded the 00:01.0 window and tried to reassign that part of the hierarchy from scratch. That is a problem because Linux doesn't always assign things optimally. For example, in this case, BIOS put the 01:00.0 device in a prefetchable window below 4GB, but after 5b28541552ef, Linux puts the prefetchable window above 4GB where the 32-bit 01:00.0 device can't use it. Clipping the 00:01.0 window is less intrusive than completely reassigning things and is sufficient to let us use most of the BIOS configuration. Of course, it's possible that devices below 00:01.0 will no longer fit. If that's the case, we'll have to reassign things. But that's a separate problem. [bhelgaas: changelog, split into separate patch] Link: https://bugzilla.kernel.org/show_bug.cgi?id=85491 Reported-by: Marek Kordik <kordikmarek@gmail.com> Fixes: 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources") Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29libata: allow sata_sil24 to opt-out of tag ordered submissionDan Williams
commit 72dd299d5039a336493993dcc63413cf31d0e662 upstream. Ronny reports: https://bugzilla.kernel.org/show_bug.cgi?id=87101 "Since commit 8a4aeec8d "libata/ahci: accommodate tag ordered controllers" the access to the harddisk on the first SATA-port is failing on its first access. The access to the harddisk on the second port is working normal. When reverting the above commit, access to both harddisks is working fine again." Maintain tag ordered submission as the default, but allow sata_sil24 to continue with the old behavior. Cc: Tejun Heo <tj@kernel.org> Reported-by: Ronny Hegewald <Ronny.Hegewald@online.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29can: m_can: tag current CAN FD controllers as non-ISOOliver Hartkopp
commit 6cfda7fbebe8a4fd33ea5722fa0212f98f643c35 upstream. During the CAN FD standardization process within the ISO it turned out that the failure detection capability has to be improved. The CAN in Automation organization (CiA) defined the already implemented CAN FD controllers as 'non-ISO' and the upcoming improved CAN FD controllers as 'ISO' compliant. See at http://www.can-cia.com/index.php?id=1937 Finally there will be three types of CAN FD controllers in the future: 1. ISO compliant (fixed) 2. non-ISO compliant (fixed, like the M_CAN IP v3.0.1 in m_can.c) 3. ISO/non-ISO CAN FD controllers (switchable, like the PEAK USB FD) So the current M_CAN driver for the M_CAN IP v3.0.1 has to expose its non-ISO implementation by setting the CAN_CTRLMODE_FD_NON_ISO ctrlmode at startup. As this bit cannot be switched at configuration time CAN_CTRLMODE_FD_NON_ISO must not be set in ctrlmode_supported of the current M_CAN driver. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27genirq: Prevent proc race against freeing of irq descriptorsThomas Gleixner
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream. Since the rework of the sparse interrupt code to actually free the unused interrupt descriptors there exists a race between the /proc interfaces to the irq subsystem and the code which frees the interrupt descriptor. CPU0 CPU1 show_interrupts() desc = irq_to_desc(X); free_desc(desc) remove_from_radix_tree(); kfree(desc); raw_spinlock_irq(&desc->lock); /proc/interrupts is the only interface which can actively corrupt kernel memory via the lock access. /proc/stat can only read from freed memory. Extremly hard to trigger, but possible. The interfaces in /proc/irq/N/ are not affected by this because the removal of the proc file is serialized in procfs against concurrent readers/writers. The removal happens before the descriptor is freed. For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue as the descriptor is never freed. It's merely cleared out with the irq descriptor lock held. So any concurrent proc access will either see the old correct value or the cleared out ones. Protect the lookup and access to the irq descriptor in show_interrupts() with the sparse_irq_lock. Provide kstat_irqs_usr() which is protecting the lookup and access with sparse_irq_lock and switch /proc/stat to use it. Document the existing kstat_irqs interfaces so it's clear that the caller needs to take care about protection. The users of these interfaces are either not affected due to SPARSE_IRQ=n or already protected against removal. Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator" Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27uapi/linux/target_core_user.h: fix headers_install.sh badnessKyle McMartin
commit 3875f15207f9ecb3f24a8e91e7ad196899139595 upstream. scripts/headers_install.sh will transform __packed to __attribute__((packed)), so the #ifndef is not necessary. (and, in fact, it's problematic, because we'll end up with the header containing: #ifndef __attribute__((packed)) #define __attribu... and so forth.) Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27net: Generalize ndo_gso_check to ndo_features_checkJesse Gross
[ Upstream commit 5f35227ea34bb616c436d9da47fc325866c428f3 ] GSO isn't the only offload feature with restrictions that potentially can't be expressed with the current features mechanism. Checksum is another although it's a general issue that could in theory apply to anything. Even if it may be possible to implement these restrictions in other ways, it can result in duplicate code or inefficient per-packet behavior. This generalizes ndo_gso_check so that drivers can remove any features that don't make sense for a given packet, similar to netif_skb_features(). It also converts existing driver restrictions to the new format, completing the work that was done to support tunnel protocols since the issues apply to checksums as well. By actually removing features from the set that are used to do offloading, it solves another problem with the existing interface. In these cases, GSO would run with the original set of features and not do anything because it appears that segmentation is not required. CC: Tom Herbert <therbert@google.com> CC: Joe Stringer <joestringer@nicira.com> CC: Eric Dumazet <edumazet@google.com> CC: Hayes Wang <hayeswang@realtek.com> Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Tom Herbert <therbert@google.com> Fixes: 04ffcb255f22 ("net: Add ndo_gso_check") Tested-by: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27in6: fix conflict with glibcstephen hemminger
[ Upstream commit 6d08acd2d32e3e877579315dc3202d7a5f336d98 ] Resolve conflicts between glibc definition of IPV6 socket options and those defined in Linux headers. Looks like earlier efforts to solve this did not cover all the definitions. It resolves warnings during iproute2 build. Please consider for stable as well. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: propagate error from stack expansion even for guard pageLinus Torvalds
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream. Jay Foad reports that the address sanitizer test (asan) sometimes gets confused by a stack pointer that ends up being outside the stack vma that is reported by /proc/maps. This happens due to an interaction between RLIMIT_STACK and the guard page: when we do the guard page check, we ignore the potential error from the stack expansion, which effectively results in a missing guard page, since the expected stack expansion won't have been done. And since /proc/maps explicitly ignores the guard page (commit d7824370e263: "mm: fix up some user-visible effects of the stack guard page"), the stack pointer ends up being outside the reported stack area. This is the minimal patch: it just propagates the error. It also effectively makes the guard page part of the stack limit, which in turn measn that the actual real stack is one page less than the stack limit. Let's see if anybody notices. We could teach acct_stack_growth() to allow an extra page for a grow-up/grow-down stack in the rlimit test, but I don't want to add more complexity if it isn't needed. Reported-and-tested-by: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: protect set_page_dirty() from ongoing truncationJohannes Weiner
commit 2d6d7f98284648c5ed113fe22a132148950b140f upstream. Tejun, while reviewing the code, spotted the following race condition between the dirtying and truncation of a page: __set_page_dirty_nobuffers() __delete_from_page_cache() if (TestSetPageDirty(page)) page->mapping = NULL if (PageDirty()) dec_zone_page_state(page, NR_FILE_DIRTY); dec_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE); if (page->mapping) account_page_dirtied(page) __inc_zone_page_state(page, NR_FILE_DIRTY); __inc_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE); which results in an imbalance of NR_FILE_DIRTY and BDI_RECLAIMABLE. Dirtiers usually lock out truncation, either by holding the page lock directly, or in case of zap_pte_range(), by pinning the mapcount with the page table lock held. The notable exception to this rule, though, is do_wp_page(), for which this race exists. However, do_wp_page() already waits for a locked page to unlock before setting the dirty bit, in order to prevent a race where clear_page_dirty() misses the page bit in the presence of dirty ptes. Upgrade that wait to a fully locked set_page_dirty() to also cover the situation explained above. Afterwards, the code in set_page_dirty() dealing with a truncation race is no longer needed. Remove it. Reported-by: Tejun Heo <tj@kernel.org> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16Revert "mac80211: Fix accounting of the tailroom-needed counter"Johannes Berg
commit 1e359a5de861a57aa04d92bb620f52a5c1d7f8b1 upstream. This reverts commit ca34e3b5c808385b175650605faa29e71e91991b. It turns out that the p54 and cw2100 drivers assume that there's tailroom even when they don't say they really need it. However, there's currently no way for them to explicitly say they do need it, so for now revert this. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=90331. Fixes: ca34e3b5c808 ("mac80211: Fix accounting of the tailroom-needed counter") Reported-by: Christopher Chavez <chrischavez@gmx.us> Bisected-by: Larry Finger <Larry.Finger@lwfinger.net> Debugged-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16Drivers: hv: util: make struct hv_do_fcopy match Hyper-V host messagesVitaly Kuznetsov
commit 31d4ea1a093fcf668d5f95af44b8d41488bdb7ec upstream. An attempt to fix fcopy on i586 (bc5a5b0 Drivers: hv: util: Properly pack the data for file copy functionality) led to a regression on x86_64 (and actually didn't fix i586 breakage). Fcopy messages from Hyper-V host come in the following format: struct do_fcopy_hdr | 36 bytes 0000 | 4 bytes offset | 8 bytes size | 4 bytes data | 6144 bytes On x86_64 struct hv_do_fcopy matched this format without ' __attribute__((packed))' and on i586 adding ' __attribute__((packed))' to it doesn't change anything. Keep the structure packed and add padding to match re reality. Tested both i586 and x86_64 on Hyper-V Server 2012 R2. Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16tracing/sched: Check preempt_count() for current when reading task->stateSteven Rostedt (Red Hat)
commit aee4e5f3d3abb7a2239dd02f6d8fb173413fd02f upstream. When recording the state of a task for the sched_switch tracepoint a check of task_preempt_count() is performed to see if PREEMPT_ACTIVE is set. This is because, technically, a task being preempted is really in the TASK_RUNNING state, and that is what should be recorded when tracing a sched_switch, even if the task put itself into another state (it hasn't scheduled out in that state yet). But with the change to use per_cpu preempt counts, the task_thread_info(p)->preempt_count is no longer used, and instead task_preempt_count(p) is used. The problem is that this does not use the current preempt count but a stale one from a previous sched_switch. The task_preempt_count(p) uses saved_preempt_count and not preempt_count(). But for tracing sched_switch, if p is current, we really want preempt_count(). I hit this bug when I was tracing sleep and the call from do_nanosleep() scheduled out in the "RUNNING" state. sleep-4290 [000] 537272.259992: sched_switch: sleep:4290 [120] R ==> swapper/0:0 [120] sleep-4290 [000] 537272.260015: kernel_stack: <stack trace> => __schedule (ffffffff8150864a) => schedule (ffffffff815089f8) => do_nanosleep (ffffffff8150b76c) => hrtimer_nanosleep (ffffffff8108d66b) => SyS_nanosleep (ffffffff8108d750) => return_to_handler (ffffffff8150e8e5) => tracesys_phase2 (ffffffff8150c844) After a bit of hair pulling, I found that the state was really TASK_INTERRUPTIBLE, but the saved_preempt_count had an old PREEMPT_ACTIVE set and caused the sched_switch tracepoint to show it as RUNNING. Link: http://lkml.kernel.org/r/20141210174428.3cb7542a@gandalf.local.home Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Fixes: 01028747559a "sched: Create more preempt_count accessors" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16pstore-ram: Allow optional mapping with pgprot_noncachedTony Lindgren
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream. On some ARMs the memory can be mapped pgprot_noncached() and still be working for atomic operations. As pointed out by Colin Cross <ccross@android.com>, in some cases you do want to use pgprot_noncached() if the SoC supports it to see a debug printk just before a write hanging the system. On ARMs, the atomic operations on strongly ordered memory are implementation defined. So let's provide an optional kernel parameter for configuring pgprot_noncached(), and use pgprot_writecombine() by default. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rob Herring <robherring2@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16powerpc: add little endian flag to syscall_get_arch()Richard Guy Briggs
commit 63f13448d81c910a284b096149411a719cbed501 upstream. Since both ppc and ppc64 have LE variants which are now reported by uname, add that flag (__AUDIT_ARCH_LE) to syscall_get_arch() and add AUDIT_ARCH_PPC64LE variant. Without this, perf trace and auditctl fail. Mainline kernel reports ppc64le (per a058801) but there is no matching AUDIT_ARCH_PPC64LE. Since 32-bit PPC LE is not supported by audit, don't advertise it in AUDIT_ARCH_PPC* variants. See: https://www.redhat.com/archives/linux-audit/2014-August/msg00082.html https://www.redhat.com/archives/linux-audit/2014-December/msg00004.html Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08audit: restore AUDIT_LOGINUID unset ABIRichard Guy Briggs
commit 041d7b98ffe59c59fdd639931dea7d74f9aa9a59 upstream. A regression was caused by commit 780a7654cee8: audit: Make testing for a valid loginuid explicit. (which in turn attempted to fix a regression caused by e1760bd) When audit_krule_to_data() fills in the rules to get a listing, there was a missing clause to convert back from AUDIT_LOGINUID_SET to AUDIT_LOGINUID. This broke userspace by not returning the same information that was sent and expected. The rule: auditctl -a exit,never -F auid=-1 gives: auditctl -l LIST_RULES: exit,never f24=0 syscall=all when it should give: LIST_RULES: exit,never auid=-1 (0xffffffff) syscall=all Tag it so that it is reported the same way it was set. Create a new private flags audit_krule field (pflags) to store it that won't interact with the public one from the API. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Add a knob to disable setgroups on a per user namespace basisEric W. Biederman
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream. - Expose the knob to user space through a proc file /proc/<pid>/setgroups A value of "deny" means the setgroups system call is disabled in the current processes user namespace and can not be enabled in the future in this user namespace. A value of "allow" means the segtoups system call is enabled. - Descendant user namespaces inherit the value of setgroups from their parents. - A proc file is used (instead of a sysctl) as sysctls currently do not allow checking the permissions at open time. - Writing to the proc file is restricted to before the gid_map for the user namespace is set. This ensures that disabling setgroups at a user namespace level will never remove the ability to call setgroups from a process that already has that ability. A process may opt in to the setgroups disable for itself by creating, entering and configuring a user namespace or by calling setns on an existing user namespace with setgroups disabled. Processes without privileges already can not call setgroups so this is a noop. Prodcess with privilege become processes without privilege when entering a user namespace and as with any other path to dropping privilege they would not have the ability to call setgroups. So this remains within the bounds of what is possible without a knob to disable setgroups permanently in a user namespace. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Don't allow setgroups until a gid mapping has been setablishedEric W. Biederman
commit 273d2c67c3e179adb1e74f403d1e9a06e3f841b5 upstream. setgroups is unique in not needing a valid mapping before it can be called, in the case of setgroups(0, NULL) which drops all supplemental groups. The design of the user namespace assumes that CAP_SETGID can not actually be used until a gid mapping is established. Therefore add a helper function to see if the user namespace gid mapping has been established and call that function in the setgroups permission check. This is part of the fix for CVE-2014-8989, being able to drop groups without privilege using user namespaces. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08groups: Consolidate the setgroups permission checksEric W. Biederman
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream. Today there are 3 instances of setgroups and due to an oversight their permission checking has diverged. Add a common function so that they may all share the same permission checking code. This corrects the current oversight in the current permission checks and adds a helper to avoid this in the future. A user namespace security fix will update this new helper, shortly. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-04uapi: fix to export linux/vm_sockets.hMasahiro Yamada
A typo "header=y" was introduced by commit 7071cf7fc435 ("uapi: add missing network related headers to kbuild"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-28Merge tag 'staging-3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging/IIO driver fixes from Greg KH: "Here are some staging and IIO driver fixes for 3.18-rc7 that resolve a number of reported issues, and a new device id for a staging wireless driver. All of these have been in linux-next" * tag 'staging-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8188eu: Add new device ID for DLink GO-USB-N150 staging: r8188eu: Fix scheduling while atomic error introduced in commit fadbe0cd iio: accel: bmc150: set low default thresholds iio: accel: bmc150: Fix iio_event_spec direction iio: accel: bmc150: Send x, y and z motion separately iio: accel: bmc150: Error handling when mode set fails iio: gyro: bmg160: Fix iio_event_spec direction iio: gyro: bmg160: Send x, y and z motion separately iio: gyro: bmg160: Don't let interrupt mode to be open drain iio: gyro: bmg160: Error handling when mode set fails iio: adc: men_z188_adc: Add terminating entry for men_z188_ids iio: accel: kxcjk-1013: Fix kxcjk10013_set_range iio: Fix IIO_EVENT_CODE_EXTRACT_DIR bit mask
2014-11-28Merge tag 'sound-3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "No excitement, here are only minor fixes: an endian fix for the new DSD format we added in 3.18, a fix for HP mute LED, and a fix for Native Instrument quirk" * tag 'sound-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: pcm: Add big-endian DSD sample formats and fix XMOS DSD sample format ALSA: hda - One more HP machine needs to change mute led quirk ALSA: usb-audio: Use snd_usb_ctl_msg() for Native Instruments quirk
2014-11-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Several small fixes here: 1) Don't crash in tg3 driver when the number of tx queues has been configured to be different from the number of rx queues. From Thadeu Lima de Souza Cascardo. 2) VLAN filter not disabled properly in promisc mode in ixgbe driver, from Vlad Yasevich. 3) Fix OOPS on dellink op in VTI tunnel driver, from Xin Long. 4) IPV6 GRE driver WCCP code checks skb->protocol for ETH_P_IP instead of ETH_P_IPV6, whoops. From Yuri Chislov. 5) Socket matching in ping driver is buggy when packet AF does not match socket's AF. Fix from Jane Zhou. 6) Fix checksum calculation errors in VXLAN due to where the udp_tunnel6_xmit_skb() helper gets it's saddr/daddr from. From Alexander Duyck. 7) Fix 5G detection problem in rtlwifi driver, from Larry Finger. 8) Fix NULL deref in tcp_v{4,6}_send_reset, from Eric Dumazet. 9) Various missing netlink attribute verifications in bridging code, from Thomas Graf. 10) tcp_recvmsg() unconditionally calls ipv4 ip_recv_error even for ipv6 sockets, whoops. Fix from Willem de Bruijn" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (29 commits) net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socks bridge: Sanitize IFLA_EXT_MASK for AF_BRIDGE:RTM_GETLINK bridge: Add missing policy entry for IFLA_BRPORT_FAST_LEAVE net: Check for presence of IFLA_AF_SPEC net: Validate IFLA_BRIDGE_MODE attribute length bridge: Validate IFLA_BRIDGE_FLAGS attribute length stmmac: platform: fix default values of the filter bins setting net/mlx4_core: Limit count field to 24 bits in qp_alloc_res net: dsa: bcm_sf2: reset switch prior to initialization net: dsa: bcm_sf2: fix unmapping registers in case of errors tg3: fix ring init when there are more TX than RX channels tcp: fix possible NULL dereference in tcp_vX_send_reset() rtlwifi: Change order in device startup rtlwifi: rtl8821ae: Fix 5G detection problem Revert "netfilter: conntrack: fix race in __nf_conntrack_confirm against get_next_corpse" vxlan: Fix boolean flip in VXLAN_F_UDP_ZERO_CSUM6_[TX|RX] ip6_udp_tunnel: Fix checksum calculation net-timestamp: Fix a documentation typo net/ping: handle protocol mismatching scenario af_packet: fix sparse warning ...
2014-11-26net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socksWillem de Bruijn
TCP timestamping introduced MSG_ERRQUEUE handling for TCP sockets. If the socket is of family AF_INET6, call ipv6_recv_error instead of ip_recv_error. This change is more complex than a single branch due to the loadable ipv6 module. It reuses a pre-existing indirect function call from ping. The ping code is safe to call, because it is part of the core ipv6 module and always present when AF_INET6 sockets are active. Fixes: 4ed2d765 (net-timestamp: TCP timestamping) Signed-off-by: Willem de Bruijn <willemb@google.com> ---- It may also be worthwhile to add WARN_ON_ONCE(sk->family == AF_INET6) to ip_recv_error. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26Merge tag 'iio-fixes-for-3.18c' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: Third set of IIO fixes for the 3.18 cycle. Most of these are fairly standard little fixes, a bmc150 and bmg160 patch is to make an ABI change to indicated a specific axis in an event rather than the generic option in the original drivers. As both of these drivers are new in this cycle it would be ideal to push this minor change through even though it isn't strictly a fix. A couple of other 'fixes' change defaults for some settings on these new drivers to more intuitive calues. Looks like some useful feedback has been coming in for this driver since it was applied. * IIO_EVENT_CODE_EXTRACT_DIR bit mask was wrong and has been for a while 0xCF clearly doesn't give a contiguous bitmask. * kxcjk-1013 range setting was failing to mask out the previous value in the register and hence was 'enable only'. * men_z188 device id table wasn't null terminated. * bmg160 and bmc150 both failed to correctly handling an error in mode setting. * bmg160 and bmc150 both had a bug in setting the event direction in the event spec (leads to an attribute name being incorrect) * bmg160 defaulted to an open drain output for the interrupt - as a default this obviously only works with some interrupt chips - hence change the default to push-pull (note this is a new driver so we aren't going to cause any regressions with this change). * bmc150 had an unintuitive default for the rate of change (motion detector) so change it to 0 (new driver so change of default won't cause any regressions).
2014-11-26kvm: fix kvm_is_mmio_pfn() and rename to kvm_is_reserved_pfn()Ard Biesheuvel
This reverts commit 85c8555ff0 ("KVM: check for !is_zero_pfn() in kvm_is_mmio_pfn()") and renames the function to kvm_is_reserved_pfn. The problem being addressed by the patch above was that some ARM code based the memory mapping attributes of a pfn on the return value of kvm_is_mmio_pfn(), whose name indeed suggests that such pfns should be mapped as device memory. However, kvm_is_mmio_pfn() doesn't do quite what it says on the tin, and the existing non-ARM users were already using it in a way which suggests that its name should probably have been 'kvm_is_reserved_pfn' from the beginning, e.g., whether or not to call get_page/put_page on it etc. This means that returning false for the zero page is a mistake and the patch above should be reverted. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-11-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Ben Herrenschmidt: "This series fix a nasty issue with radeon adapters on powerpc servers, it's all CC'ed stable and has the relevant maintainers ack's/reviews. Basically, some (radeon) adapters have issues with MSI addresses above 1T (only support 40-bits). We had powerpc specific quirk but it only listed a specific revision of an adapter that we shipped with our machines and didn't properly handle the audio function which some distros enable nowadays. So we made the quirk generic and fixed both the graphic and audio drivers properly to use it. Without that, ppc64 server machines will crash at boot with a radeon adapter. Note: This has been brewing for a while, it just needed a last respin which got delayed due to us moving ozlabs to a new location in town and other such things taking priority" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/pci: Remove unused force_32bit_msi quirk powerpc/pseries: Honor the generic "no_64bit_msi" flag powerpc/powernv: Honor the generic "no_64bit_msi" flag sound/radeon: Move 64-bit MSI quirk from arch to driver gpu/radeon: Set flag to indicate broken 64-bit MSI PCI/MSI: Add device flag indicating that 64-bit MSIs don't work ALSA: hda - Limit 40bit DMA for AMD HDMI controllers
2014-11-25Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
https://git.linaro.org/people/mike.turquette/linux Pull clock fixes from Mike Turquette: "The fixes for the clock framework are all regressions in drivers, plus a single fix in one of the basic clock templates. No fixes to the core this time around. As with most clock driver fixes these run the gamut from fixing a build warning to fixing wrecked memory timings, with a little USB tossed in for fun" * tag 'clk-fixes-for-linus' of https://git.linaro.org/people/mike.turquette/linux: clk: pxa: fix pxa27x CCCR bit usage clk-divider: Fix READ_ONLY when divider > 1 clk: qcom: Fix duplicate rbcpr clock name clk: at91: usb: fix at91sam9x5 recalc, round and set rate clk: at91: usb: fix at91rm9200 round and set rate
2014-11-24PCI/MSI: Add device flag indicating that 64-bit MSIs don't workBenjamin Herrenschmidt
This can be set by quirks/drivers to be used by the architecture code that assigns the MSI addresses. We additionally add verification in the core MSI code that the values assigned by the architecture do satisfy the limitation in order to fail gracefully if they don't (ie. the arch hasn't been updated to deal with that quirk yet). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: <stable@vger.kernel.org> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2014-11-23Merge branch 'for-3.18-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu fix from Tejun Heo: "This contains one patch to fix a race condition which can lead to percpu_ref using a percpu pointer which is corrupted with a set DEAD bit. The bug was introduced while separating out the ATOMIC mode flag from the DEAD flag. The fix is pretty straight forward. I just committed the patch to the percpu tree but am sending out the pull request early as I'll be on vacation for a week. The patch should be fairly safe and while the latency will be higher I'll be checking emails" * 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu-ref: fix DEAD flag contamination of percpu pointer
2014-11-23percpu-ref: fix DEAD flag contamination of percpu pointerTejun Heo
While decoupling ATOMIC and DEAD flags, f47ad4578461 ("percpu_ref: decouple switching to percpu mode and reinit") updated __ref_is_percpu() so that it only tests ATOMIC flag to determine whether the ref is in percpu mode or not; however, while DEAD implies ATOMIC, the two flags are set separately during percpu_ref_kill() and if __ref_is_percpu() races percpu_ref_kill(), it may see DEAD w/o ATOMIC. Because __ref_is_percpu() returns @ref->percpu_count_ptr value verbatim as the percpu pointer after testing ATOMIC, the pointer may now be contaminated with the DEAD flag. This can be fixed by clearing the flag bits before returning the pointer which was the fix proposed by Shaohua; however, as DEAD implies ATOMIC, we can just test for both flags at once and avoid the explicit masking. Update __ref_is_percpu() so that it tests that both ATOMIC and DEAD are clear before returning @ref->percpu_count_ptr as the percpu pointer. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-Reviewed-by: Shaohua Li <shli@kernel.org> Link: http://lkml.kernel.org/r/995deb699f5b873c45d667df4add3b06f73c2c25.1416638887.git.shli@kernel.org Fixes: f47ad4578461 ("percpu_ref: decouple switching to percpu mode and reinit")
2014-11-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix BUG when decrypting empty packets in mac80211, from Ronald Wahl. 2) nf_nat_range is not fully initialized and this is copied back to userspace, from Daniel Borkmann. 3) Fix read past end of b uffer in netfilter ipset, also from Dan Carpenter. 4) Signed integer overflow in ipv4 address mask creation helper inet_make_mask(), from Vincent BENAYOUN. 5) VXLAN, be2net, mlx4_en, and qlcnic need ->ndo_gso_check() methods to properly describe the device's capabilities, from Joe Stringer. 6) Fix memory leaks and checksum miscalculations in openvswitch, from Pravin B SHelar and Jesse Gross. 7) FIB rules passes back ambiguous error code for unreachable routes, making behavior confusing for userspace. Fix from Panu Matilainen. 8) ieee802154fake_probe() doesn't release resources properly on error, from Alexey Khoroshilov. 9) Fix skb_over_panic in add_grhead(), from Daniel Borkmann. 10) Fix access of stale slave pointers in bonding code, from Nikolay Aleksandrov. 11) Fix stack info leak in PPP pptp code, from Mathias Krause. 12) Cure locking bug in IPX stack, from Jiri Bohac. 13) Revert SKB fclone memory freeing optimization that is racey and can allow accesses to freed up memory, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (71 commits) tcp: Restore RFC5961-compliant behavior for SYN packets net: Revert "net: avoid one atomic operation in skb_clone()" virtio-net: validate features during probe cxgb4 : Fix DCB priority groups being returned in wrong order ipx: fix locking regression in ipx_sendmsg and ipx_recvmsg openvswitch: Don't validate IPv6 label masks. pptp: fix stack info leak in pptp_getname() brcmfmac: don't include linux/unaligned/access_ok.h cxgb4i : Don't block unload/cxgb4 unload when remote closes TCP connection ipv6: delete protocol and unregister rtnetlink when cleanup net/mlx4_en: Add VXLAN ndo calls to the PF net device ops too bonding: fix curr_active_slave/carrier with loadbalance arp monitoring mac80211: minstrel_ht: fix a crash in rate sorting vxlan: Inline vxlan_gso_check(). can: m_can: update to support CAN FD features can: m_can: fix incorrect error messages can: m_can: add missing delay after setting CCCR_INIT bit can: m_can: fix not set can_dlc for remote frame can: m_can: fix possible sleep in napi poll can: m_can: add missing message RAM initialization ...
2014-11-21Merge tag 'sound-3.18-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This batch ended up as a relatively high volume due to pending ASoC fixes. But most of fixes there are trivial and/or device- specific fixes and quirks, so safe to apply. The only (ASoC) core fixes are the DPCM race fix and the machine-driver matching fix for componentization" * tag 'sound-3.18-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - fix the mic mute led problem for Latitude E5550 ALSA: hda - move DELL_WMI_MIC_MUTE_LED to the tail in the quirk chain ASoC: wm_adsp: Avoid attempt to free buffers that might still be in use ALSA: usb-audio: Set the Control Selector to SU_SELECTOR_CONTROL for UAC2 ALSA: usb-audio: Add ctrl message delay quirk for Marantz/Denon devices ASoC: sgtl5000: Fix SMALL_POP bit definition ASoC: cs42l51: re-hook of_match_table pointer ASoC: rt5670: change dapm routes of PLL connection ASoC: rt5670: correct the incorrect default values ASoC: samsung: Add MODULE_DEVICE_TABLE for Snow ASoC: max98090: Correct pclk divisor settings ASoC: dpcm: Fix race between FE/BE updates and trigger ASoC: Fix snd_soc_find_dai() matching component by name ASoC: rsnd: remove unsupported PAUSE flag ASoC: fsi: remove unsupported PAUSE flag ASoC: rt5645: Mark RT5645_TDM_CTRL_3 as readable ASoC: rockchip-i2s: fix infinite loop in rockchip_snd_rxctrl ASoC: es8328-i2c: Fix i2c_device_id name field in es8328_id ASoC: fsl_asrc: Add reg_defaults for regmap to fix kernel dump
2014-11-21Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes: two NUMA fixes, two cputime fixes and an RCU/lockdep fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/cputime: Fix clock_nanosleep()/clock_gettime() inconsistency sched/cputime: Fix cpu_timer_sample_group() double accounting sched/numa: Avoid selecting oneself as swap target sched/numa: Fix out of bounds read in sched_init_numa() sched: Remove lockdep check in sched_move_task()
2014-11-21Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core fix from Ingo Molnar: "Fix GENMASK macro shift overflow" Nobody seems to currently use GENMASK() to fill every single last bit (which is what overflows) in-tree, and gcc would warn about it, so we have that going for us. But apparently there are pending changes that want this. * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: bitops: Fix shift overflow in GENMASK macros
2014-11-21ALSA: pcm: Add big-endian DSD sample formats and fix XMOS DSD sample formatJussi Laako
This patch fixes XMOS DSD sample format to DSD_U32_BE and also adds DSD_U16_BE and DSD_U32_BE sample formats. Signed-off-by: Jussi Laako <jussi@sonarnerd.net> Acked-by: Jurgen Kramer <gtmkramer@xs4all.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-19Merge tag 'linux-can-fixes-for-3.18-20141118' of ↵David S. Miller
git://gitorious.org/linux-can/linux-can Marc Kleine-Budde says: ==================== pull-request: can 2014-11-18 this is a pull request of 17 patches for net/master for the v3.18 release cycle. The last patch of this pull request ("can: m_can: update to support CAN FD features") adds, as the description says, a new feature to the m_can driver. As the m_can driver has been added in v3.18 there is no risk of causing a regression. Give me a note if this is not okay and I'll create a new pull request without it. There is a patch for the CAN infrastructure by Thomas Körper which fixes calling kfree_skb() from interrupt context. Roman Fietze fixes a typo also in the infrastructure. A patch by Dong Aisheng adds a generic helper function to tell if a skb is normal CAN or CAN-FD frame. Alexey Khoroshilov of the Linux Driver Verification project fixes a memory leak in the esd_usb2 driver. Two patches by Sudip Mukherjee remove unused variables and fixe the signess of a variable. Three patches by me add the missing .ndo_change_mtu callback to the xilinx_can, rcar_can and gs_usb driver. The remaining patches improve the m_can driver: David Cohen adds the missing CONFIG_HAS_IOMEM dependency. Dong Aisheng provides 6 bugfix patches (most important: missing RAM init, sleep in NAPI poll, dlc in RTR). While the last of his patches adds CAN FD support to the driver. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18vxlan: Inline vxlan_gso_check().Joe Stringer
Suggested-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Joe Stringer <joestringer@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18can: dev: add can_is_canfd_skb() APIDong Aisheng
The CAN device drivers can use can_is_canfd_skb() to check if the frame to send is on CAN FD mode or normal CAN mode. Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Dong Aisheng <b29396@freescale.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-11-17clk-divider: Fix READ_ONLY when divider > 1James Hogan
Commit 79c6ab509558 (clk: divider: add CLK_DIVIDER_READ_ONLY flag) in v3.16 introduced the CLK_DIVIDER_READ_ONLY flag which caused the recalc_rate() and round_rate() clock callbacks to be omitted. However using this flag has the unfortunate side effect of causing the clock recalculation code when a clock rate change is attempted to always treat it as a pass-through clock, i.e. with a fixed divide of 1, which may not be the case. Child clock rates are then recalculated using the wrong parent rate. Therefore instead of dropping the recalc_rate() and round_rate() callbacks, alter clk_divider_bestdiv() to always report the current divider as the best divider so that it is never altered. For me the read only clock was the system clock, which divided the PLL rate by 2, from which both the UART and the SPI clocks were divided. Initial setting of the UART rate set it correctly, but when the SPI clock was set, the other child clocks were miscalculated. The UART clock was recalculated using the PLL rate as the parent rate, resulting in a UART new_rate of double what it should be, and a UART which spewed forth garbage when the rate changes were propagated. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Thomas Abraham <thomas.ab@samsung.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Max Schwarz <max.schwarz@online.de> Cc: <stable@vger.kernel.org> # v3.16+ Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-11-17clk: qcom: Fix duplicate rbcpr clock nameGeorgi Djakov
There is a duplication in a clock name for apq8084 platform that causes the following warning: "RBCPR_CLK_SRC" redefined Resolve this by adding a MMSS_ prefix to this clock and making its name coherent with msm8974 platform. Fixes: 2b46cd23a5a2 ("clk: qcom: Add APQ8084 Multimedia Clock Controller (MMCC) support") Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-11-17Merge remote-tracking branches 'asoc/fix/adsp', 'asoc/fix/cs41l51', ↵Mark Brown
'asoc/fix/dpcm', 'asoc/fix/es8328', 'asoc/fix/fsl-asrc', 'asoc/fix/max98090', 'asoc/fix/rcar', 'asoc/fix/rockchip' and 'asoc/fix/rt5645' into asoc-linus
2014-11-16Merge tag 'armsoc-for-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another small set of fixes: - some DT compatible typo fixes - irq setup fix dealing with irq storms on orion - i2c quirk generalization for mvebu - a handful of smaller fixes for OMAP - a couple of added file patterns for OMAP entries in MAINTAINERS" * tag 'armsoc-for-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: at91/dt: Fix sama5d3x typos pinctrl: dra: dt-bindings: Fix output pull up/down MAINTAINERS: Update entry for omap related .dts files to cover new SoCs MAINTAINERS: add more files under OMAP SUPPORT ARM: dts: AM437x-SK-EVM: Fix DCDC3 voltage ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltage ARM: dts: AM43x-EPOS-EVM: Fix DCDC3 voltage ARM: dts: am335x-evm: Fix 5th NAND partition's name ARM: orion: Fix for certain sequence of request_irq can cause irq storm ARM: mvebu: armada xp: Generalize use of i2c quirk
