path: root/include
2010-08-02firmware_class: fix memory leak - free allocated pagesDavid Woodhouse
commit dd336c554d8926c3348a2d5f2a5ef5597f6d1a06 upstream. fix memory leak introduced by the patch 6e03a201bbe: firmware: speed up request_firmware() 1. vfree won't release pages there were allocated explicitly and mapped using vmap. The memory has to be vunmap-ed and the pages needs to be freed explicitly 2. page array is moved into the 'struct firmware' so that we can free it from release_firmware() and not only in fw_dev_release() The fix doesn't break the firmware load speed. Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Singed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02libertas/sdio: 8686: set ECSI bit for 1-bit transfersDaniel Mack
commit 8a64c0f6b7ec7f758c4ef445e49f479e27fa2236 upstream. When operating in 1-bit mode, SDAT1 is used as dedicated interrupt line. However, the 8686 will only drive this line when the ECSI bit is set in the CCCR_IF register. Thanks to Alagu Sankar for pointing me in the right direction. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alagu Sankar <alagusankar@embwise.com> Cc: Volker Ernst <volker.ernst@txtr.com> Cc: Dan Williams <dcbw@redhat.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Holger Schurig <hs4233@mail.mn-solutions.de> Cc: Bing Zhao <bzhao@marvell.com> Cc: libertas-dev@lists.infradead.org Cc: linux-wireless@vger.kernel.org Cc: linux-mmc@vger.kernel.org Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ACPI: Unconditionally set SCI_EN on resumeMatthew Garrett
commit b6dacf63e9fb2e7a1369843d6cef332f76fca6a3 upstream. The ACPI spec tells us that the firmware will reenable SCI_EN on resume. Reality disagrees in some cases. The ACPI spec tells us that the only way to set SCI_EN is via an SMM call. https://bugzilla.kernel.org/show_bug.cgi?id=13745 shows us that doing so may break machines. Tracing the ACPI calls made by Windows shows that it unconditionally sets SCI_EN on resume with a direct register write, and therefore the overwhelming probability is that everything is fine with this behaviour. Signed-off-by: Matthew Garrett <mjg@redhat.com> Tested-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com> Cc: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ACPI: skip checking BM_STS if the BIOS doesn't ask for itLen Brown
commit 718be4aaf3613cf7c2d097f925abc3d3553c0605 upstream. It turns out that there is a bit in the _CST for Intel FFH C3 that tells the OS if we should be checking BM_STS or not. Linux has been unconditionally checking BM_STS. If the chip-set is configured to enable BM_STS, it can retard or completely prevent entry into deep C-states -- as illustrated by turbostat: http://userweb.kernel.org/~lenb/acpi/utils/pmtools/turbostat/ ref: Intel Processor Vendor-Specific ACPI Interface Specification table 4 "_CST FFH GAS Field Encoding" Bit 1: Set to 1 if OSPM should use Bus Master avoidance for this C-state https://bugzilla.kernel.org/show_bug.cgi?id=15886 Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ethtool: Fix potential user buffer overflow for ETHTOOL_{G, S}RXFHBen Hutchings
commit bf988435bd5b53529f4408a8efb1f433f6ddfda9 upstream. struct ethtool_rxnfc was originally defined in 2.6.27 for the ETHTOOL_{G,S}RXFH command with only the cmd, flow_type and data fields. It was then extended in 2.6.30 to support various additional commands. These commands should have been defined to use a new structure, but it is too late to change that now. Since user-space may still be using the old structure definition for the ETHTOOL_{G,S}RXFH commands, and since they do not need the additional fields, only copy the originally defined fields to and from user-space. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ahci,ata_generic: let ata_generic handle new MBP w/ MCP89Tejun Heo
commit c6353b4520788e34098bbf61c73fb9618ca7fdd6 upstream. For yet unknown reason, MCP89 on MBP 7,1 doesn't work w/ ahci under linux but the controller doesn't require explicit mode setting and works fine with ata_generic. Make ahci ignore the controller on MBP 7,1 and let ata_generic take it for now. Reported in bko#15923. https://bugzilla.kernel.org/show_bug.cgi?id=15923 NVIDIA is investigating why ahci mode doesn't work. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peer Chen <pchen@nvidia.com> Reported-by: Anders Østhus <grapz666@gmail.com> Reported-by: Andreas Graf <andreas_graf@csgraf.de> Reported-by: Benoit Gschwind <gschwind@gnu-log.net> Reported-by: Damien Cassou <damien.cassou@gmail.com> Reported-by: tixetsal@juno.com Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02mac80211: Handle mesh action frames in ieee80211_rx_h_actionJavier Cardona
commit 1cb561f83793191cf86a2db3948d28f5f42df9ff upstream. This fixes the problem introduced in commit 8404080568613d93ad7cf0a16dfb68 which broke mesh peer link establishment. changes: v2 Added missing break (Johannes) v3 Broke original patch into two (Johannes) Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02fb: fix colliding defines for fb flags.Dave Airlie
commit b26c949755c06ec79e55a75817210083bd78fc9a upstream. When I added the flags I must have been using a 25 line terminal and missed the following flags. The collided with flag has one user in staging despite being in-tree for 5 years. I'm happy to push this via my drm tree unless someone really wants to do it. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02math-emu: correct test for downshifting fraction in _FP_FROM_INT()Mikael Pettersson
commit f8324e20f8289dffc646d64366332e05eaacab25 upstream. The kernel's math-emu code contains a macro _FP_FROM_INT() which is used to convert an integer to a raw normalized floating-point value. It does this basically in three steps: 1. Compute the exponent from the number of leading zero bits. 2. Downshift large fractions to put the MSB in the right position for normalized fractions. 3. Upshift small fractions to put the MSB in the right position. There is an boundary error in step 2, causing a fraction with its MSB exactly one bit above the normalized MSB position to not be downshifted. This results in a non-normalized raw float, which when packed becomes a massively inaccurate representation for that input. The impact of this depends on a number of arch-specific factors, but it is known to have broken emulation of FXTOD instructions on UltraSPARC III, which was originally reported as GCC bug 44631 <http://gcc.gnu.org/bugzilla/show_bug.cgi?id=44631>. Any arch which uses math-emu to emulate conversions from integers to same-size floats may be affected. The fix is simple: the exponent comparison used to determine if the fraction should be downshifted must be "<=" not "<". I'm sending a kernel module to test this as a reply to this message. There are also SPARC user-space test cases in the GCC bug entry. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02net: fix problem in reading sock TX queueTom Herbert
commit b0f77d0eae0c58a5a9691a067ada112ceeae2d00 upstream. Fix problem in reading the tx_queue recorded in a socket. In dev_pick_tx, the TX queue is read by doing a check with sk_tx_queue_recorded on the socket, followed by a sk_tx_queue_get. The problem is that there is not mutual exclusion across these calls in the socket so it it is possible that the queue in the sock can be invalidated after sk_tx_queue_recorded is called so that sk_tx_queue get returns -1, which sets 65535 in queue_index and thus dev_pick_tx returns 65536 which is a bogus queue and can cause crash in dev_queue_xmit. We fix this by only calling sk_tx_queue_get which does the proper checks. The interface is that sk_tx_queue_get returns the TX queue if the sock argument is non-NULL and TX queue is recorded, else it returns -1. sk_tx_queue_recorded is no longer used so it can be completely removed. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ssb: Handle Netbook devices where the SPROM address is changedChristoph Fritz
For some Netbook computers with Broadcom BCM4312 wireless interfaces, the SPROM has been moved to a new location. When the ssb driver tries to read the old location, the systems hangs when trying to read a non-existent location. Such freezes are particularly bad as they do not log the failure. This patch is modified from commit da1fdb02d9200ff28b6f3a380d21930335fe5429 with some pieces from other mainline changes so that it can be applied to stable 2.6.34.Y. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05KVM: VMX: enable VMXON check with SMX enabled (Intel TXT)Shane Wang
Per document, for feature control MSR: Bit 1 enables VMXON in SMX operation. If the bit is clear, execution of VMXON in SMX operation causes a general-protection exception. Bit 2 enables VMXON outside SMX operation. If the bit is clear, execution of VMXON outside SMX operation causes a general-protection exception. This patch is to enable this kind of check with SMX for VMXON in KVM. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> (cherry picked from commit cafd66595d92591e4bd25c3904e004fc6f897e2d)
2010-07-05vfs: add NOFOLLOW flag to umount(2)Miklos Szeredi
commit db1f05bb85d7966b9176e293f3ceead1cb8b5d79 upstream. Add a new UMOUNT_NOFOLLOW flag to umount(2). This is needed to prevent symlink attacks in unprivileged unmounts (fuse, samba, ncpfs). Additionally, return -EINVAL if an unknown flag is used (and specify an explicitly unused flag: UMOUNT_UNUSED). This makes it possible for the caller to determine if a flag is supported or not. CC: Eugene Teo <eugene@redhat.com> CC: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05sctp: Fix skb_over_panic resulting from multiple invalid parameter errors ↵Neil Horman
(CVE-2010-1173) (v4) commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809 upstream. Ok, version 4 Change Notes: 1) Minor cleanups, from Vlads notes Summary: Hey- Recently, it was reported to me that the kernel could oops in the following way: <5> kernel BUG at net/core/skbuff.c:91! <5> invalid operand: 0000 [#1] <5> Modules linked in: sctp netconsole nls_utf8 autofs4 sunrpc iptable_filter ip_tables cpufreq_powersave parport_pc lp parport vmblock(U) vsock(U) vmci(U) vmxnet(U) vmmemctl(U) vmhgfs(U) acpiphp dm_mirror dm_mod button battery ac md5 ipv6 uhci_hcd ehci_hcd snd_ens1371 snd_rawmidi snd_seq_device snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_ac97_codec snd soundcore pcnet32 mii floppy ext3 jbd ata_piix libata mptscsih mptsas mptspi mptscsi mptbase sd_mod scsi_mod <5> CPU: 0 <5> EIP: 0060:[<c02bff27>] Not tainted VLI <5> EFLAGS: 00010216 (2.6.9-89.0.25.EL) <5> EIP is at skb_over_panic+0x1f/0x2d <5> eax: 0000002c ebx: c033f461 ecx: c0357d96 edx: c040fd44 <5> esi: c033f461 edi: df653280 ebp: 00000000 esp: c040fd40 <5> ds: 007b es: 007b ss: 0068 <5> Process swapper (pid: 0, threadinfo=c040f000 task=c0370be0) <5> Stack: c0357d96 e0c29478 00000084 00000004 c033f461 df653280 d7883180 e0c2947d <5> 00000000 00000080 df653490 00000004 de4f1ac0 de4f1ac0 00000004 df653490 <5> 00000001 e0c2877a 08000800 de4f1ac0 df653490 00000000 e0c29d2e 00000004 <5> Call Trace: <5> [<e0c29478>] sctp_addto_chunk+0xb0/0x128 [sctp] <5> [<e0c2947d>] sctp_addto_chunk+0xb5/0x128 [sctp] <5> [<e0c2877a>] sctp_init_cause+0x3f/0x47 [sctp] <5> [<e0c29d2e>] sctp_process_unk_param+0xac/0xb8 [sctp] <5> [<e0c29e90>] sctp_verify_init+0xcc/0x134 [sctp] <5> [<e0c20322>] sctp_sf_do_5_1B_init+0x83/0x28e [sctp] <5> [<e0c25333>] sctp_do_sm+0x41/0x77 [sctp] <5> [<c01555a4>] cache_grow+0x140/0x233 <5> [<e0c26ba1>] sctp_endpoint_bh_rcv+0xc5/0x108 [sctp] <5> [<e0c2b863>] sctp_inq_push+0xe/0x10 [sctp] <5> [<e0c34600>] sctp_rcv+0x454/0x509 [sctp] <5> [<e084e017>] ipt_hook+0x17/0x1c [iptable_filter] <5> [<c02d005e>] nf_iterate+0x40/0x81 <5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151 <5> [<c02e0c7f>] ip_local_deliver_finish+0xc6/0x151 <5> [<c02d0362>] nf_hook_slow+0x83/0xb5 <5> [<c02e0bb2>] ip_local_deliver+0x1a2/0x1a9 <5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151 <5> [<c02e103e>] ip_rcv+0x334/0x3b4 <5> [<c02c66fd>] netif_receive_skb+0x320/0x35b <5> [<e0a0928b>] init_stall_timer+0x67/0x6a [uhci_hcd] <5> [<c02c67a4>] process_backlog+0x6c/0xd9 <5> [<c02c690f>] net_rx_action+0xfe/0x1f8 <5> [<c012a7b1>] __do_softirq+0x35/0x79 <5> [<c0107efb>] handle_IRQ_event+0x0/0x4f <5> [<c01094de>] do_softirq+0x46/0x4d Its an skb_over_panic BUG halt that results from processing an init chunk in which too many of its variable length parameters are in some way malformed. The problem is in sctp_process_unk_param: if (NULL == *errp) *errp = sctp_make_op_error_space(asoc, chunk, ntohs(chunk->chunk_hdr->length)); if (*errp) { sctp_init_cause(*errp, SCTP_ERROR_UNKNOWN_PARAM, WORD_ROUND(ntohs(param.p->length))); sctp_addto_chunk(*errp, WORD_ROUND(ntohs(param.p->length)), param.v); When we allocate an error chunk, we assume that the worst case scenario requires that we have chunk_hdr->length data allocated, which would be correct nominally, given that we call sctp_addto_chunk for the violating parameter. Unfortunately, we also, in sctp_init_cause insert a sctp_errhdr_t structure into the error chunk, so the worst case situation in which all parameters are in violation requires chunk_hdr->length+(sizeof(sctp_errhdr_t)*param_count) bytes of data. The result of this error is that a deliberately malformed packet sent to a listening host can cause a remote DOS, described in CVE-2010-1173: http://cve.mitre.org/cgi-bin/cvename.cgi?name=2010-1173 I've tested the below fix and confirmed that it fixes the issue. We move to a strategy whereby we allocate a fixed size error chunk and ignore errors we don't have space to report. Tested by me successfully Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05tracing: Fix null pointer deref with SEND_SIG_FORCEDOleg Nesterov
commit b9b76dfaac6fa2c289ee8a005be637afd2da7e2f upstream. BUG: unable to handle kernel NULL pointer dereference at 0000000000000006 IP: [<ffffffff8107bd37>] ftrace_raw_event_signal_generate+0x87/0x140 TP_STORE_SIGINFO() forgets about SEND_SIG_FORCED, fix. We should probably export is_si_special() and change TP_STORE_SIGINFO() to use it in the longer term. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jason Baron <jbaron@redhat.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <20100603213409.GA8307@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05wrong type for 'magic' argument in simple_fill_super()Roberto Sassu
commit 7d683a09990ff095a91b6e724ecee0ff8733274a upstream. It's used to superblock ->s_magic, which is unsigned long. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Reviewed-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05ahci: add pci quirk for JMB362Tejun Heo
commit 4daedcfe8c6851aa01cc1997220f2577f4039c13 upstream. JMB362 is a new variant of jmicron controller which is similar to JMB360 but has two SATA ports instead of one. As there is no PATA port, single function AHCI mode can be used as in JMB360. Add pci quirk for JMB362. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Aries Lee <arieslee@jmicron.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05tmpfs: insert tmpfs cache pages to inactive list at firstKOSAKI Motohiro
commit e9d6c157385e4efa61cb8293e425c9d8beba70d3 upstream. Shaohua Li reported parallel file copy on tmpfs can lead to OOM killer. This is regression of caused by commit 9ff473b9a7 ("vmscan: evict streaming IO first"). Wow, It is 2 years old patch! Currently, tmpfs file cache is inserted active list at first. This means that the insertion doesn't only increase numbers of pages in anon LRU, but it also reduces anon scanning ratio. Therefore, vmscan will get totally confused. It scans almost only file LRU even though the system has plenty unused tmpfs pages. Historically, lru_cache_add_active_anon() was used for two reasons. 1) Intend to priotize shmem page rather than regular file cache. 2) Intend to avoid reclaim priority inversion of used once pages. But we've lost both motivation because (1) Now we have separate anon and file LRU list. then, to insert active list doesn't help such priotize. (2) In past, one pte access bit will cause page activation. then to insert inactive list with pte access bit mean higher priority than to insert active list. Its priority inversion may lead to uninteded lru chun. but it was already solved by commit 645747462 (vmscan: detect mapped file pages used only once). (Thanks Hannes, you are great!) Thus, now we can use lru_cache_add_anon() instead. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26revert "procfs: provide stack information for threads" and its fixup commitsRobin Holt
commit 34441427aab4bdb3069a4ffcda69a99357abcb2e upstream. Originally, commit d899bf7b ("procfs: provide stack information for threads") attempted to introduce a new feature for showing where the threadstack was located and how many pages are being utilized by the stack. Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was applied to fix the NO_MMU case. Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on 64-bit") was applied to fix a bug in ia32 executables being loaded. Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel threads") was applied to fix a bug which had kernel threads printing a userland stack address. Commit 1306d603f ('proc: partially revert "procfs: provide stack information for threads"') was then applied to revert the stack pages being used to solve a significant performance regression. This patch nearly undoes the effect of all these patches. The reason for reverting these is it provides an unusable value in field 28. For x86_64, a fork will result in the task->stack_start value being updated to the current user top of stack and not the stack start address. This unpredictability of the stack_start value makes it worthless. That includes the intended use of showing how much stack space a thread has. Other architectures will get different values. As an example, ia64 gets 0. The do_fork() and copy_process() functions appear to treat the stack_start and stack_size parameters as architecture specific. I only partially reverted c44972f1 ("procfs: disable per-task stack usage on NOMMU") . If I had completely reverted it, I would have had to change mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is configured. Since I could not test the builds without significant effort, I decided to not change mm/Makefile. I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on 64-bit") . I left the KSTK_ESP() change in place as that seemed worthwhile. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Stefani Seibold <stefani@seibold.net> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26dma-mapping: fix dma_sync_single_range_*FUJITA Tomonori
commit f33d7e2d2d113a63772bbc993cdec3b5327f0ef1 upstream. dma_sync_single_range_for_cpu() and dma_sync_single_range_for_device() use a wrong address with a partial synchronization. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12sctp: Fix oops when sending queued ASCONF chunksVlad Yasevich
[ Upstream commit c0786693404cffd80ca3cb6e75ee7b35186b2825 ] When we finish processing ASCONF_ACK chunk, we try to send the next queued ASCONF. This action runs the sctp state machine recursively and it's not prepared to do so. kernel BUG at kernel/timer.c:790! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/module/ipv6/initstate Modules linked in: sha256_generic sctp libcrc32c ipv6 dm_multipath uinput 8139too i2c_piix4 8139cp mii i2c_core pcspkr virtio_net joydev floppy virtio_blk virtio_pci [last unloaded: scsi_wait_scan] Pid: 0, comm: swapper Not tainted 2.6.34-rc4 #15 /Bochs EIP: 0060:[<c044a2ef>] EFLAGS: 00010286 CPU: 0 EIP is at add_timer+0xd/0x1b EAX: cecbab14 EBX: 000000f0 ECX: c0957b1c EDX: 03595cf4 ESI: cecba800 EDI: cf276f00 EBP: c0957aa0 ESP: c0957aa0 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process swapper (pid: 0, ti=c0956000 task=c0988ba0 task.ti=c0956000) Stack: c0957ae0 d1851214 c0ab62e4 c0ab5f26 0500ffff 00000004 00000005 00000004 <0> 00000000 d18694fd 00000004 1666b892 cecba800 cecba800 c0957b14 00000004 <0> c0957b94 d1851b11 ceda8b00 cecba800 cf276f00 00000001 c0957b14 000000d0 Call Trace: [<d1851214>] ? sctp_side_effects+0x607/0xdfc [sctp] [<d1851b11>] ? sctp_do_sm+0x108/0x159 [sctp] [<d1863386>] ? sctp_pname+0x0/0x1d [sctp] [<d1861a56>] ? sctp_primitive_ASCONF+0x36/0x3b [sctp] [<d185657c>] ? sctp_process_asconf_ack+0x2a4/0x2d3 [sctp] [<d184e35c>] ? sctp_sf_do_asconf_ack+0x1dd/0x2b4 [sctp] [<d1851ac1>] ? sctp_do_sm+0xb8/0x159 [sctp] [<d1863334>] ? sctp_cname+0x0/0x52 [sctp] [<d1854377>] ? sctp_assoc_bh_rcv+0xac/0xe1 [sctp] [<d1858f0f>] ? sctp_inq_push+0x2d/0x30 [sctp] [<d186329d>] ? sctp_rcv+0x797/0x82e [sctp] Tested-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Yuansong Qiao <ysqiao@research.ait.ie> Signed-off-by: Shuaijun Zhang <szhang@research.ait.ie> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12sctp: avoid irq lock inversion while call sk->sk_data_ready()Wei Yongjun
[ Upstream commit 561b1733a465cf9677356b40c27653dd45f1ac56 ] sk->sk_data_ready() of sctp socket can be called from both BH and non-BH contexts, but the default sk->sk_data_ready(), sock_def_readable(), can not be used in this case. Therefore, we have to make a new function sctp_data_ready() to grab sk->sk_data_ready() with BH disabling. ========================================================= [ INFO: possible irq lock inversion dependency detected ] 2.6.33-rc6 #129 --------------------------------------------------------- sctp_darn/1517 just changed the state of lock: (clock-AF_INET){++.?..}, at: [<c06aab60>] sock_def_readable+0x20/0x80 but this lock took another, SOFTIRQ-unsafe lock in the past: (slock-AF_INET){+.-...} and interrupts could create inverse lock ordering between them. other info that might help us debug this: 1 lock held by sctp_darn/1517: #0: (sk_lock-AF_INET){+.+.+.}, at: [<cdfe363d>] sctp_sendmsg+0x23d/0xc00 [sctp] Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12libata: Fix accesses at LBA28 boundary (old bug, but nasty) (v2)Mark Lord
commit 45c4d015a92f72ec47acd0c7557abdc0c8a6499d upstream. Most drives from Seagate, Hitachi, and possibly other brands, do not allow LBA28 access to sector number 0x0fffffff (2^28 - 1). So instead use LBA48 for such accesses. This bug could bite a lot of systems, especially when the user has taken care to align partitions to 4KB boundaries. On misaligned systems, it is less likely to be encountered, since a 4KB read would end at 0x10000000 rather than at 0x0fffffff. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12hugetlb: fix infinite loop in get_futex_key() when backed by huge pagesMel Gorman
commit 23be7468e8802a2ac1de6ee3eecb3ec7f14dc703 upstream. If a futex key happens to be located within a huge page mapped MAP_PRIVATE, get_futex_key() can go into an infinite loop waiting for a page->mapping that will never exist. See https://bugzilla.redhat.com/show_bug.cgi?id=552257 for more details about the problem. This patch makes page->mapping a poisoned value that includes PAGE_MAPPING_ANON mapped MAP_PRIVATE. This is enough for futex to continue but because of PAGE_MAPPING_ANON, the poisoned value is not dereferenced or used by futex. No other part of the VM should be dereferencing the page->mapping of a hugetlbfs page as its page cache is not on the LRU. This patch fixes the problem with the test case described in the bugzilla. [akpm@linux-foundation.org: mel cant spel] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Darren Hart <darren@dvhart.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26KVM: Increase NR_IOBUS_DEVS limit to 200Sridhar Samudrala
(Cherry-picked from commit e80e2a60ff7914dae691345a976c80bbbff3ec74) This patch increases the current hardcoded limit of NR_IOBUS_DEVS from 6 to 200. We are hitting this limit when creating a guest with more than 1 virtio-net device using vhost-net backend. Each virtio-net device requires 2 such devices to service notifications from rx/tx queues. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26KVM: fix the handling of dirty bitmaps to avoid overflowsTakuya Yoshikawa
(Cherry-picked from commit 87bf6e7de1134f48681fd2ce4b7c1ec45458cb6d) Int is not long enough to store the size of a dirty bitmap. This patch fixes this problem with the introduction of a wrapper function to calculate the sizes of dirty bitmaps. Note: in mark_page_dirty(), we have to consider the fact that __set_bit() takes the offset as int, not long. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26module: fix __module_ref_addr()Mathieu Desnoyers
The __module_ref_addr() problem disappears in 2.6.34-rc kernels because these percpu accesses were re-factored. __module_ref_addr() should use per_cpu_ptr() to obfuscate the pointer (RELOC_HIDE is needed for per cpu pointers). This non-standard per-cpu pointer use has been introduced by commit 720eba31f47aeade8ec130ca7f4353223c49170f It causes a NULL pointer exception on some configurations when CONFIG_TRACING is enabled on 2.6.33. This patch fixes the problem (acknowledged by Randy who reported the bug). It did not appear to hurt previously because most of the accesses were done through local_inc, which probably obfuscated the access enough that no compiler optimizations were done. But with local_read() done when CONFIG_TRACING is active, this becomes a problem. Non-CONFIG_TRACING is probably affected as well (module.c contains local_set and local_read that use __module_ref_addr()), but I guess nobody noticed because we've been lucky enough that the compiler did not generate the inappropriate optimization pattern there. This patch should be queued for the 2.6.29.x through 2.6.33.x stable branches. (tested on 2.6.33.1 x86_64) Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> CC: Eric Dumazet <dada1@cosmosbay.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Peter Zijlstra <a.p.zijlstra@chello.nl> CC: Tejun Heo <tj@kernel.org> CC: Ingo Molnar <mingo@elte.hu> CC: Andrew Morton <akpm@linux-foundation.org> CC: Linus Torvalds <torvalds@linux-foundation.org> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26x86/PCI: irq and pci_ids patch for Intel Cougar Point DeviceIDsSeth Heasley
commit 93da6202264ce1256b04db8008a43882ae62d060 upstream. This patch adds the Intel Cougar Point (PCH) LPC and SMBus Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26pci: Update pci_set_vga_state() to call arch functionsMike Travis
commit 95a8b6efc5d07103583f706c8a5889437d537939 upstream. Update pci_set_vga_state to call arch dependent functions to enable Legacy VGA I/O transactions to be redirected to correct target. [akpm@linux-foundation.org: make pci_register_set_vga_state() __init] Signed-off-by: Mike Travis <travis@sgi.com> LKML-Reference: <201002022238.o12McE1J018723@imap1.linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26dm ioctl: introduce flag indicating uevent was generatedPeter Rajnoha
commit 3abf85b5b5851b5f28d3d8a920ebb844edd08352 upstream. Set a new DM_UEVENT_GENERATED_FLAG when returning from ioctls to indicate that a uevent was actually generated. This tells the userspace caller that it may need to wait for the event to be processed. Signed-off-by: Peter Rajnoha <prajnoha@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26drm/radeon/kms: add FireMV 2400 PCI ID.Dave Airlie
commit 79b9517a33a283c5d9db875c263670ed1e055f7e upstream. This is an M24/X600 chip. From RH# 581927 Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26NFSv4: fix delegated lockingTrond Myklebust
commit 0df5dd4aae211edeeeb84f7f84f6d093406d7c22 upstream. Arnaud Giersch reports that NFSv4 locking is broken when we hold a delegation since commit 8e469ebd6dc32cbaf620e134d79f740bf0ebab79 (NFSv4: Don't allow posix locking against servers that don't support it). According to Arnaud, the lock succeeds the first time he opens the file (since we cannot do a delegated open) but then fails after we start using delegated opens. The following patch fixes it by ensuring that locking behaviour is governed by a per-filesystem capability flag that is initially set, but gets cleared if the server ever returns an OPEN without the NFS4_OPEN_RESULT_LOCKTYPE_POSIX flag being set. Reported-by: Arnaud Giersch <arnaud.giersch@iut-bm.univ-fcomte.fr> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26include/linux/kfifo.h: fix INIT_KFIFO()David Härdeman
commit 530cd330dc3865e3107304a6e84fdc332aa72f7d upstream. DECLARE_KFIFO creates a union with a struct kfifo and a buffer array with size [size + sizeof(struct kfifo)]. INIT_KFIFO then sets the buffer pointer in struct kfifo to point to the beginning of the buffer array which means that the first call to kfifo_in will overwrite members of the struct kfifo. Signed-off-by: David Härdeman <david@hardeman.nu> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26raw: fsync method is now requiredAnton Blanchard
commit 55ab3a1ff843e3f0e24d2da44e71bffa5d853010 upstream. Commit 148f948ba877f4d3cdef036b1ff6d9f68986706a (vfs: Introduce new helpers for syncing after writing to O_SYNC file or IS_SYNC inode) broke the raw driver. We now call through generic_file_aio_write -> generic_write_sync -> vfs_fsync_range. vfs_fsync_range has: if (!fop || !fop->fsync) { ret = -EINVAL; goto out; } But drivers/char/raw.c doesn't set an fsync method. We have two options: fix it or remove the raw driver completely. I'm happy to do either, the fact this has been broken for so long suggests it is rarely used. The patch below adds an fsync method to the raw driver. My knowledge of the block layer is pretty sketchy so this could do with a once over. If we instead decide to remove the raw driver, this patch might still be useful as a backport to 2.6.33 and 2.6.32. Signed-off-by: Anton Blanchard <anton@samba.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <jens.axboe@oracle.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Tested-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26Freezer: Fix buggy resume test for tasks frozen with cgroup freezerMatt Helsley
commit 5a7aadfe2fcb0f69e2acc1fbefe22a096e792fc9 upstream. When the cgroup freezer is used to freeze tasks we do not want to thaw those tasks during resume. Currently we test the cgroup freezer state of the resuming tasks to see if the cgroup is FROZEN. If so then we don't thaw the task. However, the FREEZING state also indicates that the task should remain frozen. This also avoids a problem pointed out by Oren Ladaan: the freezer state transition from FREEZING to FROZEN is updated lazily when userspace reads or writes the freezer.state file in the cgroup filesystem. This means that resume will thaw tasks in cgroups which should be in the FROZEN state if there is no read/write of the freezer.state file to trigger this transition before suspend. NOTE: Another "simple" solution would be to always update the cgroup freezer state during resume. However it's a bad choice for several reasons: Updating the cgroup freezer state is somewhat expensive because it requires walking all the tasks in the cgroup and checking if they are each frozen. Worse, this could easily make resume run in N^2 time where N is the number of tasks in the cgroup. Finally, updating the freezer state from this code path requires trickier locking because of the way locks must be ordered. Instead of updating the freezer state we rely on the fact that lazy updates only manage the transition from FREEZING to FROZEN. We know that a cgroup with the FREEZING state may actually be FROZEN so test for that state too. This makes sense in the resume path even for partially-frozen cgroups -- those that really are FREEZING but not FROZEN. Reported-by: Oren Ladaan <orenl@cs.columbia.edu> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26drm/radeon: add new RS880 pci idAlex Deucher
commit 338e2b1d571e4873908b199c90d6a31f65137fe3 upstream. This should go to 2.6.33 stable as well. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01quota: manage reserved space when quota is not active [v2]Dmitry Monakhov
commit c469070aea5a0ada45a836937c776fd3083dae2b upstream. Since we implemented generic reserved space management interface, then it is possible to account reserved space even when quota is not active (similar to i_blocks/i_bytes). Without this patch following testcase result in massive comlain from WARN_ON in dquot_claim_space() TEST_CASE: mount /dev/sdb /mnt -oquota dd if=/dev/zero of=/mnt/test bs=1M count=1 quotaon /mnt # fs_reserved_spave == 1Mb # quota_reserved_space == 0, because quota was disabled dd if=/dev/zero of=/mnt/test seek=1 bs=1M count=1 # fs_reserved_spave == 2Mb # quota_reserved_space == 1Mb sync # ->dquot_claim_space() -> WARN_ON Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01skbuff: remove unused dma_head & dma_maps fieldsAlexander Duyck
[ Upstream commit 03e6d819c2cb2cc8ce5642669a0a7c72336ee7a2 ] The dma map fields in the skb_shared_info structure no longer has any users and can be dropped since it is making the skb_shared_info unecessarily larger. Running slabtop show that we were using 4K slabs for the skb->head on x86_64 w/ an allocation size of 1522. It turns out that the dma_head and dma_maps array made skb_shared large enough that we had crossed over the 2k boundary with standard frames and as such we were using 4k blocks of memory for all skbs. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01net: Potential null skb->dev dereferenceEric Dumazet
[ Upstream commit 0641e4fbf2f824faee00ea74c459a088d94905fd ] When doing "ifenslave -d bond0 eth0", there is chance to get NULL dereference in netif_receive_skb(), because dev->master suddenly becomes NULL after we tested it. We should use ACCESS_ONCE() to avoid this (or rcu_dereference()) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01netlink: fix unaligned access in nla_get_be64()Pablo Neira Ayuso
[ Upstream commit f5d410f2ea7ba340f11815a56e05b9fa9421c421 ] This patch fixes a unaligned access in nla_get_be64() that was introduced by myself in a17c859849402315613a0015ac8fbf101acf0cc1. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01netfilter: ctnetlink: fix reliable event delivery if message building failsPablo Neira Ayuso
[ Upstream commit 37b7ef7203240b3aba577bb1ff6765fe15225976 ] This patch fixes a bug that allows to lose events when reliable event delivery mode is used, ie. if NETLINK_BROADCAST_SEND_ERROR and NETLINK_RECV_NO_ENOBUFS socket options are set. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01netlink: fix NETLINK_RECV_NO_ENOBUFS in netlink_set_err()Pablo Neira Ayuso
[ Upstream commit 1a50307ba1826e4da0024e64b245ce4eadf7688a ] Currently, ENOBUFS errors are reported to the socket via netlink_set_err() even if NETLINK_RECV_NO_ENOBUFS is set. However, that should not happen. This fixes this problem and it changes the prototype of netlink_set_err() to return the number of sockets that have set the NETLINK_RECV_NO_ENOBUFS socket option. This return value is used in the next patch in these bugfix series. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01ipsec: Fix bogus bundle flowiHerbert Xu
[ Upstream commit 87c1e12b5eeb7b30b4b41291bef8e0b41fc3dde9 ] When I merged the bundle creation code, I introduced a bogus flowi value in the bundle. Instead of getting from the caller, it was instead set to the flow in the route object, which is totally different. The end result is that the bundles we created never match, and we instead end up with an ever growing bundle list. Thanks to Jamal for find this problem. Reported-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01net: add __must_check to sk_add_backlogZhu Yi
[ Upstream commit 4045635318538d3ddd2007720412fdc4b08f6a62 ] Add the "__must_check" tag to sk_add_backlog() so that any failure to check and drop packets will be warned about. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01net: backlog functions renameZhu Yi
[ Upstream commit a3a858ff18a72a8d388e31ab0d98f7e944841a62 ] sk_add_backlog -> __sk_add_backlog sk_add_backlog_limited -> sk_add_backlog Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01net: add limit for socket backlogZhu Yi
[ Upstream commit 8eae939f1400326b06d0c9afe53d2a484a326871 ] We got system OOM while running some UDP netperf testing on the loopback device. The case is multiple senders sent stream UDP packets to a single receiver via loopback on local host. Of course, the receiver is not able to handle all the packets in time. But we surprisingly found that these packets were not discarded due to the receiver's sk->sk_rcvbuf limit. Instead, they are kept queuing to sk->sk_backlog and finally ate up all the memory. We believe this is a secure hole that a none privileged user can crash the system. The root cause for this problem is, when the receiver is doing __release_sock() (i.e. after userspace recv, kernel udp_recvmsg -> skb_free_datagram_locked -> release_sock), it moves skbs from backlog to sk_receive_queue with the softirq enabled. In the above case, multiple busy senders will almost make it an endless loop. The skbs in the backlog end up eat all the system memory. The issue is not only for UDP. Any protocols using socket backlog is potentially affected. The patch adds limit for socket backlog so that the backlog size cannot be expanded endlessly. Reported-by: Alex Shi <alex.shi@intel.com> Cc: David Miller <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "Pekka Savola (ipv6)" <pekkas@netcore.fi> Cc: Patrick McHardy <kaber@trash.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Cc: Jon Maloy <jon.maloy@ericsson.com> Cc: Allan Stephens <allan.stephens@windriver.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01mac80211: Retry null data frame for power saveVivek Natarajan
commit 375177bf35efc08e1bd37bbda4cc0c8cc4db8500 upstream. Even if the null data frame is not acked by the AP, mac80211 goes into power save. This might lead to loss of frames from the AP. Prevent this by restarting dynamic_ps_timer when ack is not received for null data frames. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01if_tunnel.h: add missing ams/byteorder.h includePaulius Zaleckas
commit 9bf35c8dddd56f7f247a27346f74f5adc18071f4 upstream. When compiling userspace application which includes if_tunnel.h and uses GRE_* defines you will get undefined reference to __cpu_to_be16. Fix this by adding missing #include <asm/byteorder.h> Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01kfifo: fix KFIFO_INIT in include/linux/kfifo.hDavid Härdeman
commit 4c87684d32e8f95715d53039dcd2d998dc63d1eb upstream. include/linux/kfifo.h first defines and then undefines __kfifo_initializer which is used by INIT_KFIFO (which is also a macro, so building a module which uses INIT_KFIFO will fail). Signed-off-by: David Härdeman <david@hardeman.nu> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tty: Take a 256 byte padding into account when buffering below sub-page unitsMel Gorman
commit 352fa6ad16b89f8ffd1a93b4419b1a8f2259feab upstream. The TTY layer takes some care to ensure that only sub-page allocations are made with interrupts disabled. It does this by setting a goal of "TTY_BUFFER_PAGE" to allocate. Unfortunately, while TTY_BUFFER_PAGE takes the size of tty_buffer into account, it fails to account that tty_buffer_find() rounds the buffer size out to the next 256 byte boundary before adding on the size of the tty_buffer. This patch adjusts the TTY_BUFFER_PAGE calculation to take into account the size of the tty_buffer and the padding. Once applied, tty_buffer_alloc() should not require high-order allocations. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
